  4. js-controller 3.2 jetzt im STABLE!
    6.4k
275 Beiträge 58 Kommentatoren 106.7k Aufrufe 51 Beobachtet
  • apollon77A Offline
    #182
    Leute .. back to topic bitte. Kein bashing auf andere user bitte.
    • Q Offline
      Q Offline
      quinti
      #183
      hallo versuche auf 3.2.16 von 2.2.10 auf einem Windows System upzudaten. Sowohl mit upgrade self aus auch mit Versionsangabe folgender Fehler:
      C:\ioBroker>npm i iobroker.js-controller@3.2.16
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated fsevents@2.1.3: "Please update to latest v2.3 or v2.2"
      npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules\chokidar\node_modules\fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules\iobroker.info\node_modules\osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: abstract-socket@^2.0.0 (node_modules\iobroker.radar2\node_modules\dbus-next\node_modules\abstract-socket):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for abstract-socket@2.1.1: wanted {"os":"linux","arch":"any"} (current: {"os":"win32","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules\iobroker.unifi\node_modules\chokidar\node_modules\fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
      npm WARN enoent ENOENT: no such file or directory, open 'C:\ioBroker\node_modules\iobroker.radar\package.json'
      npm WARN ws@7.4.2 requires a peer of bufferutil@^4.0.1 but none is installed. You must install peer dependencies yourself.
      npm WARN ws@7.4.2 requires a peer of utf-8-validate@^5.0.2 but none is installed. You must install peer dependencies yourself.
      npm WARN ws@7.4.3 requires a peer of bufferutil@^4.0.1 but none is installed. You must install peer dependencies yourself.
      npm WARN ws@7.4.3 requires a peer of utf-8-validate@^5.0.2 but none is installed. You must install peer dependencies yourself.
      npm WARN ws@7.4.4 requires a peer of bufferutil@^4.0.1 but none is installed. You must install peer dependencies yourself.
      npm WARN ws@7.4.4 requires a peer of utf-8-validate@^5.0.2 but none is installed. You must install peer dependencies yourself.
      npm WARN pg@8.5.1 requires a peer of pg-native@>=2.0.0 but none is installed. You must install peer dependencies yourself.
      npm ERR! path C:\ioBroker\node_modules\.bin\semver.cmd
      npm ERR! code EEXIST
      npm ERR! Refusing to delete C:\ioBroker\node_modules\.bin\semver.cmd: ..\semver\bin\semver symlink target is not controlled by npm C:\ioBroker\node_modules\semver
      npm ERR! File exists: C:\ioBroker\node_modules\.bin\semver.cmd
      npm ERR! Move it away, and try again.
      npm ERR!     C:\Users\Hermann\AppData\Roaming\npm-cache\_logs\2021-03-14T12_22_10_258Z-debug.log
      C:\ioBroker>
      Thomas BraunT cashC 2 Antworten Letzte Antwort
      • Q quinti
        C:\ioBroker>
        #184
        @quinti sagte in js-controller 3.2 jetzt im STABLE!:
        Auch wenn ich von Windows keine Ahnung habe hört sich das ganz vernünftig an.
        Q 1 Antwort Letzte Antwort
        • Q quinti
          C:\ioBroker>
          cashC Offline
          cashC Offline
          cash
          #185
          Ich habe das Update dann auch mal gewagt und es alles geklappt. Die Freude ist allerdings etwas getrübt da es bei 3 Adaptern Fehlermeldungen gibt.
          Das bekannte:
          has no existing object, this might lead to an error in future versions
          Bei all den drei Adapern gibt es dazu schon ein Issue auf Github.
          Es sind alles Adapter die zwar von ein paar Usern genutzt werden, die auch funktionieren die aber vom Entwickler nicht mehr gepflegt werden wie z. B. der Sonos Adapter.
          Das finde ich schon etwas Schade. Nach meiner Meinung sollten diese Adapter abgekündigt werden und sich einfach nicht mehr installieren lassen. Man sieht es ja eigentlich an den Github Einträgen die teilweise sehr alt sind. Klar löst es nicht das Problem aber als User weiß man dann wo man dran ist. So hat man aber die Hoffnung das sich noch wer kümmert. Und ich spreche hier ja nicht mal von Feature Request sondern einfach nur Fehlerbehebungen. Vielleicht sollte man sich auch damit mal beschäftigen. Was macht man mit all den Adaptern die nicht mehr gepflegt werden?
          O apollon77A 2 Antworten Letzte Antwort
          • cashC cash
            Das bekannte:
            O Abwesend
            O Abwesend
            oFbEQnpoLKKl6mbY5e13
            #186
            @cash sagte in js-controller 3.2 jetzt im STABLE!:
            Sonos Adapter.
            Siehe hier:
            https://forum.iobroker.net/topic/43138/sonos-adapter-workaround-für-no-existing-object
              Q Offline
              Q Offline
              quinti
              #187
              danke, hat so geklappt.
              Hab die Dateien semver und semver.bat gelöscht und nun läuft 3.2.16 bei mir!
              • cashC cash
                Das bekannte:
                #188
                @cash WIr versuchen hier aktuell zu bleiben und ich sage es mal so: Im Moment ist es nur ein Log. Setze das Debug Level auf Error und du siehst es nicht mehr.
                Ja es gibt recht viele Adapter (haben er vor kurzem die 400 überschritten) und die allermeisten funktionieren Problemlos. Das Hauptthema wenn eine Entwickler aufhört ist immer der Zugang zur nötigen Hardware für andere Entwickler.
                und dann kommt die interessante Frage: Soll man einen Adapter der noch gut funktioniert - auch wenn er nicht mehr aktiv weiterentwickelt wird - rausnehmen? Wenn es funktionale Gründe gibt werden wir dies tun. Das logging aktuell ist kein solcher Grund in meinen Augen. Und mit dem GitHub Issues haben wir immer noch einen guten Überblick und können entscheiden was wir tun bevor wir die "warnung" wahr werden lassen.
                cashC 1 Antwort Letzte Antwort
                • apollon77A apollon77
                  cashC Offline
                  cashC Offline
                  cash
                  #189
                  @apollon77 meine Meinung. Wenn ein Adapter noch funktioniert aber nicht mehr entwickelt wird sollte er abgekündigt werden z. B. deutlicher Hinweis über den Info Adapter. Der User kann den Adapter dann auf eigene Gefahr weiter nutzen. Ich würde ihn wahrscheinlich nicht weiter nutzen und mich nach Alternativen umgucken.
                  Was Hardware angeht kann der Entwickler nach Spenden aufrufen. Ich zahle gerne wenn ein Adapter entwickelt wird der wichtig ist. Als Beispiel Sonos 5.000 installierte Systeme. Wenn nur 1000 Personen 1 Euro spenden kann der Entwickler sein ganzes Haus mit Sonos ausstatten oder billiger mit den Ikeateilen... Als damals endlich shuffle Play bei Sonos ging habe ich gerne dafür gespendet. Alternativ kann man auch mit Lizenzschlüsseln arbeiten und so Geld zu sammeln für solche Fälle. Die Entwickler so wie Du opfern viel Zeit und ich bin Euch wirklich dankbar aber von dankbarkeit kann man halt nicht leben. Wieso sollte der Entwickler nicht ein paar Euro zusätzlich verdienen. Hebt auch ab und zu die Motivation :-)) Auf Abos stehe ich zwar nicht so sehr aber für einzelne Features die mir wichtig sind...
                  Iobroker ist für mich ein wichtiges System wo ich nach Möglichkeit 100% Verfügbar möchte. Deshalb bin ich sehr zurückhaltend was Updates von wichtigen Adaptern betrifft. Bei anderen Adaptern bin ich mutiger aber man lernt die Entwickler auch kennen und kann teilweise gut beurteilen ob man ein latest installieren kann oder das es danach zu Problemen kommt. Bei manchen Adaptern und Entwicklern bin ich deutlich vorsichtiger.
                  Und was das Thema log betrifft finde ich es eher ungünstig so etwas als warn auszugeben. Die Adapter haben doch sentry. Warum wird der Fehler nicht ausschließlich per sendry an den Entwickler geschickt. Ich für meinen Teil habe besseres zu tun als dritte, vierter oder zehnte Person den gleichen Fehler bei einen Adapter zu melden der eh nicht mehr gepflegt wird.
                  Das ist auch alles nicht so negativ gemeint wie man es lesen könnte. Ich nutze Github gerne aber nur bei Adaptern die auch von Entwicklern noch betreut werden...
                  Ein letztes zu der Anzahl der Adapter: 400 Adaptern eine stolze Zahl. Aber ich finde ioBroker sollteeher auf klasse statt masse setzen. Sorgt ggf auch für weniger frust bei den Usern. Aber es hapert hier halt ab und zu...Manche Adapter sind extrem gut und es gibt dort kein Feature was man noch hinzufügen könnte aber das ist halt eher doch die Ausnahme...
                  • cashC cash
                    #190
                    @cash Ich verstehe Deine Sichtweise ... einige andere User denken auch so ... aber etwas zu wenige (und das ist jetzt kein Vorwurf!). Die erfahrungen der letzten Zeit zeigen das bestimmte Dinge nicht so gut funktionieren.
                    Jeder Entwickler ist denke ich sehr dankbar über eine Spende weil das ich ein Zeichen der Wertschätzung. Also ich freue mich da riesig.
                    Sentry haben nur einige Adapter und auch hier erwarten wir einen aktiven Entwickler. Ist aktuell keine Option für die Problemadapter.
                    O 1 Antwort Letzte Antwort
                      O Abwesend
                      O Abwesend
                      #191
                      @apollon77
                      Der Sonos-Adpater ist dbzgl. kein großes Problem. Die Meldungen lassen sich in drei Probleme einteilen:
                      1. Fehlende Lautprecher in der Instanz (Datenpunkt "members")
                      2. Ein neuer Datenpunkt "queue", den der Adapter noch nicht kennt (kann man einfach selbst anlegen)
                      3. Weitere fehlende Datenpunkte aufgrund unvollständigen Objektbaums (einfach Adapter stoppen, Objektbaum löschen, Adapter wieder starten)
                      Die Frage ist, ob @Bluefox an dem Adapter noch was macht?
                      BluefoxB apollon77A 2 Antworten Letzte Antwort
                        sk0r
                        #192
                        Guten Tag,
                        Ich bin neueinsteiger bei iobroker und stehe jetzt vor folgenden Problem.
                        Ich habe mit die "iobroker-latest-windows-installer" datei herunter geladen und Installiert. Jetzt versuche ich ein upgrade vom js-controller vorzunehmen und bekomme jedes mal eine fehlermeldung.
                        Console
                        Zeile 351
                        ***               Welcome to ioBroker.                 ***
                        ***   Type 'iobroker help' for list of instructions.   ***
                        ***                For more help see                   ***
                        ***     https://github.com/ioBroker/ioBroker.docs      ***
                        Your environment has been set up for using Node.js 10.17.0 (x64) and npm.
                        D:\iobroker\SmartHome>iobroker update
                        Used repository: default
                        hash not changed, use actual sources
                        update done
                        Adapter    "admin"         : 4.2.1    , installed 3.6.12 [Updateable]
                        Adapter    "alarm"         : 1.9.0
                        Adapter    "alexa2"        : 3.8.1
                        Adapter    "alpha2"        : 1.0.0
                        Adapter    "amazon-dash"   : 1.1.0
                        Adapter    "artnet"        : 1.2.2
                        Adapter    "asterisk"      : 1.0.6
                        Adapter    "asuswrt"       : 1.0.1
                        Adapter    "b-control-em"  : 0.2.1
                        Adapter    "backitup"      : 1.7.0
                        Adapter    "beckhoff"      : 1.4.0
                        Adapter    "benq"          : 0.2.4
                        Adapter    "binance"       : 1.1.3
                        Adapter    "ble"           : 0.12.0
                        Adapter    "bmw"           : 1.3.3
                        Adapter    "bosesoundtouch": 0.9.3
                        Adapter    "botvac"        : 1.0.0
                        Adapter    "bring"         : 1.7.7
                        Adapter    "broadlink2"    : 2.0.3
                        Adapter    "bsblan"        : 0.2.0
                        Adapter    "bshb"          : 0.1.13
                        Adapter    "chromecast"    : 2.3.1
                        Adapter    "cloud"         : 4.0.4
                        Adapter    "comfoair"      : 1.1.3
                        Adapter    "contactid"     : 1.0.1
                        Adapter    "coronavirus-statistics": 0.6.3
                        Adapter    "countdown"     : 1.1.0
                        Adapter    "cul"           : 1.3.4
                        Adapter    "daikin"        : 1.3.0
                        Adapter    "daswetter"     : 3.0.4
                        Adapter    "deconz"        : 1.3.11
                        Adapter    "denon"         : 1.10.3
                        Adapter    "device-reminder": 1.0.6
                        Adapter    "devices"       : 0.3.15
                        Adapter    "digitalstrom"  : 2.0.5
                        Adapter    "discovergy"    : 0.5.0
                        Adapter    "discovery"     : 2.5.0    , installed 1.3.0 [Updateable]
                        Adapter    "divera247"     : 0.0.9
                        Adapter    "doorio"        : 1.1.2
                        Adapter    "ds18b20"       : 1.4.0
                        Adapter    "dwd"           : 2.7.5
                        Adapter    "ebus"          : 2.2.4
                        Adapter    "echarts"       : 0.4.9
                        Adapter    "ecovacs-deebot": 1.1.0
                        Adapter    "egigeozone"    : 0.1.2
                        Adapter    "ekey"          : 1.1.0
                        Adapter    "email"         : 1.0.9
                        Adapter    "emby"          : 1.0.2
                        Adapter    "energymanager" : 1.2.3
                        Adapter    "enet"          : 1.0.1
                        Adapter    "epson_stylus_px830": 0.2.1
                        Adapter    "exchangerates" : 0.0.14
                        Adapter    "fahrplan"      : 1.0.5
                        Adapter    "fakeroku"      : 0.2.1
                        Adapter    "fb-checkpresence": 1.1.0
                        Adapter    "feiertage"     : 1.0.17
                        Adapter    "fhem"          : 1.5.3
                        Adapter    "find-my-iphone": 0.2.15
                        Adapter    "firetv"        : 1.0.0
                        Adapter    "flot"          : 1.10.6
                        Adapter    "followthesun"  : 0.3.3
                        Adapter    "foobar2000"    : 2.0.4
                        Adapter    "fritzbox"      : 0.2.1
                        Adapter    "fritzdect"     : 2.1.11
                        Adapter    "fronius"       : 1.0.5
                        Adapter    "frontier_silicon": 0.0.10
                        Adapter    "fuelpricemonitor": 0.2.0
                        Adapter    "fullcalendar"  : 1.1.0
                        Adapter    "fullybrowser"  : 2.0.1
                        Adapter    "g-homa"        : 0.5.3
                        Adapter    "geofency"      : 0.3.2
                        Adapter    "go-e"          : 1.0.0
                        Adapter    "growatt"       : 1.0.1
                        Adapter    "gruenbeck"     : 0.0.28
                        Adapter    "haassohn"      : 1.0.3
                        Adapter    "habpanel"      : 0.4.3
                        Adapter    "haier"         : 1.0.4
                        Adapter    "ham"           : 3.0.2
                        Adapter    "ham-wemo"      : 1.1.0
                        Adapter    "harmony"       : 1.2.2
                        Adapter    "heatingcontrol": 2.2.0
                        Adapter    "heos"          : 1.7.7
                        Adapter    "heytech"       : 1.0.0
                        Adapter    "hid"           : 0.1.17
                        Adapter    "history"       : 1.9.12
                        Adapter    "hm-rega"       : 3.0.16
                        Adapter    "hm-rpc"        : 1.14.35
                        Adapter    "hmip"          : 1.9.0
                        Adapter    "homeconnect"   : 0.0.32
                        Adapter    "homee"         : 1.1.0
                        Adapter    "homepilot"     : 1.0.3
                        Adapter    "hp-ilo"        : 1.0.6
                        Adapter    "hs100"         : 2.0.1
                        Adapter    "hue"           : 3.4.0
                        Adapter    "hue-extended"  : 2.0.0
                        Adapter    "i2c"           : 1.1.1
                        Adapter    "ical"          : 1.7.4
                        Adapter    "icons-addictive-flavour-png": 0.1.0
                        Adapter    "icons-fatcow-hosting": 0.1.0
                        Adapter    "icons-icons8"  : 0.0.1
                        Adapter    "icons-material-png": 0.1.0
                        Adapter    "icons-material-svg": 0.1.0
                        Adapter    "icons-mfd-png" : 1.0.2
                        Adapter    "icons-mfd-svg" : 1.0.2
                        Adapter    "icons-open-icon-library-png": 0.1.2
                        Adapter    "icons-ultimate-png": 1.0.1
                        Adapter    "influxdb"      : 1.9.4
                        Adapter    "info"          : 1.7.14   , installed 1.5.6 [Updateable]
                        Adapter    "innogy-smarthome": 0.3.6
                        Adapter    "iogo"          : 0.6.5
                        Adapter    "iot"           : 1.8.13
                        Adapter    "iqontrol"      : 1.6.4
                        Adapter    "jarvis"        : 2.1.0
                        Adapter    "javascript"    : 5.0.14
                        Adapter    "jeelink"       : 0.1.0
                        Controller "js-controller" : 3.2.16   , installed 2.1.0 [Updateable]
                        Adapter    "kecontact"     : 1.1.1
                        Adapter    "klf200"        : 1.0.1
                        Adapter    "km200"         : 1.1.6
                        Adapter    "knmi-weather"  : 1.0.0
                        Adapter    "knx"           : 1.0.39
                        Adapter    "kodi"          : 2.0.5
                        Adapter    "kostal-piko-ba": 1.1.5
                        Adapter    "kress"         : 2.5.5
                        Adapter    "lametric"      : 1.2.0
                        Adapter    "landroid"      : 1.0.3
                        Adapter    "lcn"           : 1.0.2
                        Adapter    "legrand-ecocompteur": 1.0.0
                        Adapter    "letrika_comgw" : 0.0.5
                        Adapter    "lgtv"          : 1.1.10
                        Adapter    "lgtv-rs"       : 0.1.1
                        Adapter    "lgtv11"        : 1.0.5
                        Adapter    "lifx"          : 0.1.0
                        Adapter    "lightify"      : 0.2.16
                        Adapter    "link"          : 0.5.10
                        Adapter    "linkeddevices" : 1.4.2
                        Adapter    "linktap"       : 0.1.7
                        Adapter    "linux-control" : 1.1.2
                        Adapter    "logparser"     : 1.1.0
                        Adapter    "lovelace"      : 1.0.16
                        Adapter    "loxone"        : 2.1.0
                        Adapter    "luftdaten"     : 1.0.2
                        Adapter    "lupusec"       : 1.3.2
                        Adapter    "luxtronik1"    : 0.3.0
                        Adapter    "material"      : 0.13.9
                        Adapter    "maxcube"       : 1.0.2
                        Adapter    "maxcul"        : 1.3.1
                        Adapter    "mbus"          : 2.3.1
                        Adapter    "mclighting"    : 0.1.2
                        Adapter    "megad"         : 1.2.1
                        Adapter    "megadd"        : 0.2.0
                        Adapter    "megaesp"       : 0.1.0
                        Adapter    "melcloud"      : 1.0.6
                        Adapter    "mercedesme"    : 0.0.50
                        Adapter    "mercury"       : 0.1.4
                        Adapter    "meross"        : 1.5.1
                        Adapter    "meteoalarm"    : 1.0.9
                        Adapter    "midea"         : 0.0.6
                        Adapter    "miele"         : 0.1.5
                        Adapter    "mielecloudservice": 2.0.3
                        Adapter    "mihome"        : 1.3.7
                        Adapter    "mihome-lamp"   : 1.1.0
                        Adapter    "mihome-plug"   : 0.2.1
                        Adapter    "mihome-vacuum" : 2.1.1
                        Adapter    "mikrotik"      : 1.0.16
                        Adapter    "milight"       : 0.3.6
                        Adapter    "milight-smart-light": 1.2.0
                        Adapter    "minuvis"       : 1.3.1
                        Adapter    "mobile"        : 1.0.1
                        Adapter    "modbus"        : 3.2.4
                        Adapter    "moma"          : 1.2.7
                        Adapter    "mpd"           : 1.0.6
                        Adapter    "mqtt"          : 2.3.4
                        Adapter    "mqtt-client"   : 1.3.1
                        Adapter    "musiccast"     : 0.1.5
                        Adapter    "mydlink"       : 1.1.7
                        Adapter    "mysensors"     : 2.0.1
                        Adapter    "nanoleaf-lightpanels": 1.2.0
                        Adapter    "net-tools"     : 0.1.2
                        Adapter    "netatmo"       : 1.3.3
                        Adapter    "netatmo-crawler": 0.3.9
                        Adapter    "nibeuplink"    : 0.4.0
                        Adapter    "nina"          : 0.0.24
                        Adapter    "node-red"      : 2.1.0
                        Adapter    "nuki"          : 1.4.3
                        Adapter    "nuki-extended" : 2.3.0
                        Adapter    "nut"           : 1.4.3
                        Adapter    "octoprint"     : 1.0.8
                        Adapter    "odl"           : 1.1.4
                        Adapter    "oilfox"        : 0.0.5
                        Adapter    "omnicomm-lls"  : 0.0.7
                        Adapter    "onkyo"         : 2.0.3
                        Adapter    "onvif"         : 0.4.4
                        Adapter    "openhab"       : 1.1.0
                        Adapter    "openligadb"    : 1.1.0
                        Adapter    "openweathermap": 0.1.0
                        Adapter    "opi"           : 0.1.1
                        Adapter    "oppoplayer"    : 0.2.1
                        Adapter    "owfs"          : 0.6.4
                        Adapter    "owntracks"     : 1.0.0
                        Adapter    "panasonic-viera": 1.0.2
                        Adapter    "parser"        : 1.0.7
                        Adapter    "paw"           : 0.0.7
                        Adapter    "phantomjs"     : 1.1.2
                        Adapter    "pi-hole"       : 1.3.1
                        Adapter    "piface"        : 1.0.0
                        Adapter    "pimatic"       : 0.3.0
                        Adapter    "ping"          : 1.4.12
                        Adapter    "places"        : 1.0.0
                        Adapter    "plenticore"    : 2.1.6
                        Adapter    "plex"          : 0.8.11
                        Adapter    "plexconnect"   : 0.0.7
                        Adapter    "pollenflug"    : 1.0.6
                        Adapter    "proxmox"       : 1.2.0
                        Adapter    "proxy"         : 1.2.1
                        Adapter    "pushbullet"    : 0.0.11
                        Adapter    "pushover"      : 2.0.3
                        Adapter    "pushsafer"     : 1.0.3
                        Adapter    "radar2"        : 1.0.9
                        Adapter    "radiohead"     : 1.1.1
                        Adapter    "rflink"        : 2.1.6
                        Adapter    "rickshaw"      : 1.0.0
                        Adapter    "ring"          : 1.1.3
                        Adapter    "robonect"      : 0.1.3
                        Adapter    "roomba"        : 1.1.1
                        Adapter    "rpi2"          : 1.2.0
                        Adapter    "s7"            : 1.2.2
                        Adapter    "samsung"       : 0.2.9
                        Adapter    "sanext"        : 0.0.5
                        Adapter    "sayit"         : 1.12.2
                        Adapter    "sbfspot"       : 4.0.4
                        Adapter    "scenes"        : 2.3.6
                        Adapter    "schoolfree"    : 0.7.0
                        Adapter    "schwoerer-ventcube": 1.3.0
                        Adapter    "seq"           : 0.2.9
                        Adapter    "shelly"        : 4.0.6
                        Adapter    "shuttercontrol": 1.1.5
                        Adapter    "sia"           : 1.0.4
                        Adapter    "siegenia"      : 1.1.0
                        Adapter    "simple-api"    : 2.5.3
                        Adapter    "smappee"       : 0.2.3
                        Adapter    "smartcontrol"  : 1.2.1
                        Adapter    "smartgarden"   : 1.0.4
                        Adapter    "smartmeter"    : 3.2.0
                        Adapter    "snips"         : 1.5.1
                        Adapter    "snmp"          : 0.5.0
                        Adapter    "socketio"      : 3.1.4
                        Adapter    "solarlog"      : 2.0.1
                        Adapter    "solarviewdatareader": 0.2.1
                        Adapter    "solarwetter"   : 1.0.0
                        Adapter    "sonnen"        : 1.7.0
                        Adapter    "sonoff"        : 2.4.0
                        Adapter    "sonos"         : 2.1.1
                        Adapter    "sony-bravia"   : 1.0.1
                        Adapter    "spotify-premium": 1.0.0
                        Adapter    "sql"           : 1.15.5
                        Adapter    "squeezebox"    : 1.0.0
                        Adapter    "squeezeboxrpc" : 1.3.4
                        Adapter    "starline"      : 1.1.3
                        Adapter    "statistics"    : 1.0.2
                        Adapter    "stiebel-isg"   : 1.6.0
                        Adapter    "sunnyportal"   : 0.1.5
                        Adapter    "swiss-weather-api": 0.3.2
                        Adapter    "synology"      : 0.1.20
                        Adapter    "systeminfo"    : 0.3.1
                        Adapter    "tahoma"        : 0.3.2
                        Adapter    "tankerkoenig"  : 2.0.5
                        Adapter    "telegram"      : 1.8.0
                        Adapter    "terminal"      : 0.1.2
                        Adapter    "tesla-motors"  : 0.4.0
                        Adapter    "text2command"  : 2.0.7
                        Adapter    "tinker"        : 1.1.0
                        Adapter    "tr-064"        : 4.2.4
                        Adapter    "tradfri"       : 2.7.1
                        Adapter    "trashschedule" : 1.1.1
                        Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                        Adapter    "tuya"          : 3.5.6
                        Adapter    "tvspielfilm"   : 1.0.4
                        Adapter    "unifi"         : 0.5.8
                        Adapter    "upnp"          : 1.0.17
                        Adapter    "vaillant"      : 0.0.11
                        Adapter    "valloxmv"      : 1.1.2
                        Adapter    "vcard"         : 0.0.9
                        Adapter    "velux"         : 0.0.7
                        Adapter    "viessmann"     : 1.3.3
                        Adapter    "virtualpowermeter": 1.4.2
                        Adapter    "vis"           : 1.3.4
                        Adapter    "vis-bars"      : 0.1.4
                        Adapter    "vis-canvas-gauges": 0.1.5
                        Adapter    "vis-colorpicker": 1.2.0
                        Adapter    "vis-fancyswitch": 1.1.0
                        Adapter    "vis-google-fonts": 0.1.0
                        Adapter    "vis-history"   : 1.0.0
                        Adapter    "vis-hqwidgets" : 1.1.7
                        Adapter    "vis-icontwo"   : 0.45.0
                        Adapter    "vis-inventwo"  : 2.7.4
                        Adapter    "vis-jqui-mfd"  : 1.0.12
                        Adapter    "vis-justgage"  : 1.0.2
                        Adapter    "vis-keyboard"  : 0.0.2
                        Adapter    "vis-lcars"     : 1.0.4
                        Adapter    "vis-map"       : 1.0.4
                        Adapter    "vis-material-advanced": 1.3.0
                        Adapter    "vis-metro"     : 1.1.2
                        Adapter    "vis-players"   : 0.1.6
                        Adapter    "vis-plumb"     : 1.0.2
                        Adapter    "vis-rgraph"    : 0.0.2
                        Adapter    "vis-timeandweather": 1.1.7
                        Adapter    "vis-weather"   : 2.5.2
                        Adapter    "volumio"       : 0.1.2
                        Adapter    "volvo"         : 0.0.3
                        Adapter    "vr200"         : 1.0.0
                        Adapter    "vw-connect"    : 0.0.30
                        Adapter    "weatherunderground": 3.3.0
                        Adapter    "web"           : 3.3.0
                        Adapter    "weishaupt-wem" : 0.0.9
                        Adapter    "whatsapp-cmb"  : 0.1.6
                        Adapter    "wiffi-wz"      : 2.2.0
                        Adapter    "wifilight"     : 1.1.0
                        Adapter    "windows-control": 0.1.5
                        Adapter    "wled"          : 0.5.6
                        Adapter    "wm-bus"        : 0.1.12
                        Adapter    "wolf"          : 1.2.1
                        Adapter    "worx"          : 1.2.9
                        Adapter    "xbox"          : 0.7.3
                        Adapter    "xs1"           : 1.0.2
                        Adapter    "yahka"         : 0.12.0
                        Adapter    "yamaha"        : 0.4.0
                        Adapter    "yeelight-2"    : 1.0.3
                        Adapter    "youtube"       : 1.0.3
                        Adapter    "yr"            : 2.0.3
                        Adapter    "zigbee"        : 1.4.4
                        Adapter    "zont"          : 0.5.3
                        Adapter    "zwave2"        : 1.8.11
                        D:\iobroker\SmartHome>iobroker upgrade self
                        Update js-controller from @2.1.0 to @3.2.16
                        NPM version: 6.11.3
                        npm install iobroker.js-controller@3.2.16 --unsafe-perm --loglevel error --prefix "D:/iobroker/SmartHome" (System call)
                        npm ERR! code EINVAL
                        npm ERR! EINVAL: invalid argument, read
                        npm ERR!     D:\iobroker\SmartHome\env\npm-cache\_logs\2021-03-16T18_10_43_425Z-debug.log
                        Starting node restart.js
                        • K klassisch
                          @apollon77 sagte in js-controller 3.2 jetzt im STABLE!:
                          Windows
                          Auf Systemen, die mit dem neuen Windows Installer eingerichtet wurden weiss ich gerade nicht wie der aktuelle Prozess ist, da der Windows Installer nicht ganz aktuell ist. Bitte hier berichten dann kann ich ergänzen.
                          Für alle "alten manuellen" Installationen gilt
                          • ioBroker muss gestoppt sein.
                          • Vor dem Update bitte prüfen das keine Prozesse mehr laufen
                          • iobroker update
                          • iobroker upgrade self
                          • ioBroker starten
                          @sigi234 hat mich ermutigt es genau so wie oben beschrieben zu tun und auch bei mir hat es so funktioniert. Mein Win-System wurde mit dem Installer von @Stabilostick aufgesetzt und mit dem Workaround von @AlCalzone upgedatet.
                          Bin jetzt auf js-controller 3.2.16, node-js v10.17.0, npm v6.11.3 und soweit scheint alles zu funktionieren.
                          Q Offline
                          Q Offline
                          Qlink
                          #193
                          @klassisch said in js-controller 3.2 jetzt im STABLE!:
                          Windows
                          • iobroker update
                          • ioBroker starten
                          Kann ich bestätigen. Soeben das Update auf 3.2.16 ohne Probleme auf Windows Server 2019 durchgeführt ! :)
                          • O oFbEQnpoLKKl6mbY5e13
                            @apollon77
                            BluefoxB Offline
                            BluefoxB Offline
                            #194
                            @ofbeqnpolkkl6mby5e13 Nein ich mache an Sonos nichts
                            • BluefoxB Bluefox
                              O Abwesend
                              O Abwesend
                              #195
                              @bluefox
                              Okay. Danke, dass du dich gemeldet hast! 👍
                                @apollon77
                                #196
                                @ofbeqnpolkkl6mby5e13 am Ende trotzdem GitHub issues anlegen bzw „thumbs up“ machen. Vllt findet so ein anderer dev
                                  O Abwesend
                                  O Abwesend
                                  #197
                                  @apollon77
                                  Issues existieren bereits. Wie ich bereits schrieb, der Sonos-Adapter ist Prio niedrig. Der User kann sich selbst helfen.
                                    Michi68
                                    #198
                                    @apollon77
                                    Hallo,.
                                    ich wollte mal Rückmeldung geben, habe letzten Sonntag ein update von javascript 4.8.4 auf javascript 5.0.14 gemacht.
                                    Es ging bei mir ja um die Fehlermeldung die ich so 15-30 mal am Tag hatte.
                                    error: host.iobroker-Server Cannot save backup file /opt/iobroker/iobroker-data/objects.json.bak: ENOENT: no such file or directory, stat '/opt/iobroker/iobroker-data/objects.json'
                                    seit dem Update auf javascript 5.0.14 nur noch 2-4 mal am Tag.
                                    Jetzt hatte ich vor 3 Tagen noch den Speicherort der History Dateien geändert auf eine externe SSD, und siehe da keine Fehlermeldung dieser Art mehr seit 3 Tagen.
                                    Vielleicht hilft es den Fehler was einzugrenzen.
                                    Gruß Michael
                                    • V Offline
                                      V Offline
                                      Videonisse
                                      schrieb am zuletzt editiert von Videonisse
                                      #199
                                      Who kann ich Feature Flag "ALIAS_SEPARATE_READ_WRITE_ID" aktivieren?
                                      Reference: https://github.com/ioBroker/ioBroker.js-controller/blob/master/README.md#object-and-state-aliases
                                      ioBroker v3.3.18, Debian 10 Buster 64-bit (Vmware 6.5 VM), Node.js: v12.22.6, NPM: 6.14.15
                                      Most important Device Adapters: KNX, Trådfri, Homekit/Yahka
                                      • V Videonisse
                                        #200
                                        @videonisse Wie meinst Du die Frage? Die Feature Flags sind dazu da um zu erkennen b der js-controller in dem ein Adapter Läuft das Feature supported - vor allem also für Adapter. Wenn Du die entsprechende js-controller Version nutzt ist es da.
                                        V 1 Antwort Letzte Antwort
                                          V Offline
                                          V Offline
                                          Videonisse
                                          #201
                                          @apollon77 Ok, ich dachte es war ein Einstellung um experimentelle Funktionen zu aktivieren.
                                          Ich kriege ein Fehlermeldung (unten) wenn ich versuche von hand ein Alias ändern das ich separate ziel-ID haben. Aber beim speichern kriege ich den Fehler:
                                          "Parse error
                                          error_outlineSyntaxError: Unexpected string in JSON at position 454"
                                          Mein Alias sieht so aus:
                                            "user": "system.user.admin",
                                            "ts": 1616591695319,
                                            "common": {
                                              "name": "currentstate",
                                              "role": "state",
                                              "type": "boolean",
                                              "desc": "Manually created",
                                              "read": true,
                                              "write": true,
                                              "def": false,
                                              "alias": {
                                                "id": {
                                                    "read": "knx.0.VVS_och_VA.Ventilation.Köksfläkt_Status_Värde",
                                                    "write": "knx.0.VVS_och_VA.Ventilation.Köksfläkt_Värde"
                                                "read": "val > 40",
                                                "write": "val ? 80 : 40"
                                            "native": {},
                                            "acl": {
                                              "object": 1636,
                                              "owner": "system.user.admin",
                                              "state": 1636
                                            "_id": "alias.0.uuid-533453-334345.fan.currentstate",
                                            "type": "state"
                                          Wenn ich ein Issue öffnen soll, ist es in js.controller, Admin oder in ein anderen Adapter?
                                          EDIT: Ich habe den Fehler gefunden. In beispiel im Dokumentation fehlt ein komma hinter "}". Mit "}," funktionierts.
                                          I created an Issue in the Documentation for this: https://github.com/ioBroker/ioBroker.docs/issues/300
                                              alias: {
                                                      read: 'state.id.to.read.from',
                                                      write: 'state.id.to.write.to'
                                                  read: 'val * 10 + 1',
                                                  write: '(val - 1) / 10'
                                              }**Fettschrift**
