  4. IOBroker nicht mehr erreichbar nach Routertausch
    1.0k
    6.1k
58 Beiträge 4 Kommentatoren 25.1k Aufrufe 3 Beobachtet
  • Matze QuinM Matze Quin
    @thomas-braun said in IOBroker nicht mehr erreichbar nach Routertausch:
    iobroker status
    iobroker list adapters
    iobroker list instances
    iobroker status
    iobroker is not running on this host.
    Objects type: file
    States  type: file
    pi@raspberrypi:/opt/iobroker $ iobroker list adapters
    pi@raspberrypi:/opt/iobroker $ iobroker list instances
    + instance is alive
    @matze-quin
    iobroker host this
    iobroker add admin
    Matze QuinM 1 Antwort Letzte Antwort
      @matze-quin
      iobroker host this
      iobroker add admin
      Matze QuinM Offline
      Matze QuinM Offline
      Matze Quin
      pi@raspberrypi:/opt/iobroker $ iobroker add admin
      host.raspberrypi install adapter admin
      npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.admin"
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      host.raspberrypi object system.adapter.admin created/updated
      host.raspberrypi create instance admin
      host.raspberrypi object admin.0.info.newsETag created
      host.raspberrypi object admin.0.info.newsfeed created
      host.raspberrypi object admin.0.connected created
      host.raspberrypi object admin.0 created
      host.raspberrypi object admin.0.info created
      host.raspberrypi object system.adapter.admin.upload created
      host.raspberrypi object system.adapter.admin.0.logLevel created
      host.raspberrypi object system.adapter.admin.0.sigKill created
      host.raspberrypi object system.adapter.admin.0.eventLoopLag created
      host.raspberrypi object system.adapter.admin.0.outputCount created
      host.raspberrypi object system.adapter.admin.0.inputCount created
      host.raspberrypi object system.adapter.admin.0.uptime created
      host.raspberrypi object system.adapter.admin.0.memRss created
      host.raspberrypi object system.adapter.admin.0.memHeapTotal created
      host.raspberrypi object system.adapter.admin.0.memHeapUsed created
      host.raspberrypi object system.adapter.admin.0.cputime created
      host.raspberrypi object system.adapter.admin.0.cpu created
      host.raspberrypi object system.adapter.admin.0.compactMode created
      host.raspberrypi object system.adapter.admin.0.connected created
      host.raspberrypi object system.adapter.admin.0.alive created
      host.raspberrypi object system.adapter.admin.0 created
      pi@raspberrypi:/opt/iobroker $ iobroker host this
      A host with the name "raspberrypi" already exists!
      host.raspberrypi object admin.1.info.newsETag created
      host.raspberrypi object admin.1.info.newsfeed created
      host.raspberrypi object admin.1.connected created
      host.raspberrypi object admin.1 created
      host.raspberrypi object admin.1.info created
      host.raspberrypi object system.adapter.admin.1.logLevel created
      host.raspberrypi object system.adapter.admin.1.sigKill created
      host.raspberrypi object system.adapter.admin.1.eventLoopLag created
      host.raspberrypi object system.adapter.admin.1.outputCount created
      host.raspberrypi object system.adapter.admin.1.inputCount created
      host.raspberrypi object system.adapter.admin.1.uptime created
      host.raspberrypi object system.adapter.admin.1.memRss created
      host.raspberrypi object system.adapter.admin.1.memHeapTotal created
      host.raspberrypi object system.adapter.admin.1.memHeapUsed created
      host.raspberrypi object system.adapter.admin.1.cputime created
      host.raspberrypi object system.adapter.admin.1.cpu created
      host.raspberrypi object system.adapter.admin.1.compactMode created
      host.raspberrypi object system.adapter.admin.1.connected created
      host.raspberrypi object system.adapter.admin.1.alive created
      host.raspberrypi object system.adapter.admin.1 created
        @Matze-Quin
        Da ist aber doch nicht nur der Router getauscht worden!
        Was ist sonst noch "passiert"?
          @Matze-Quin
          Matze QuinM Offline
          Matze QuinM Offline
          Matze Quin
          schrieb am zuletzt editiert von Matze Quin
          Der Pi war direkt an den Router angeschlossen.
          Habe nen neuen Vodafone Vertrag.
          An den Router waren auch 2 wlan router angeschlossen, allerdings haben die meines Wissens nichts mit dem PI zu tun?!
          Der Router gehört mir, habe ihn Bei Vodafone angegeben, falls relevant.
            @matze-quin sagte in IOBroker nicht mehr erreichbar nach Routertausch:
            falls relevant.
            Nee, isses nich!
            Mich interessiert viel mehr, was am Pi sonst noch "gespielt" wurde
            • an der selben Steckdose und diese wurde ausgeschaltet?
            • Rettungsversuche irgendeiner Art?
            • Installationen von irgendetwas?
              falls relevant.
              Nee, isses nich!
              Matze QuinM Offline
              Matze QuinM Offline
              Matze Quin
              Ja jetzt wo du es sagst habe ich letzte Tage einmal eine "Reparatur" von dem iobroker tool von elzershark ausgeführt.
              Das habe ich allerdings schon öffter gemacht und noch nie war es bisher ein Problem. Sorry das hätte ich früher erwähnen sollen.
              Dieses Tool ist gemeint:
              https://www.elzershark.com/forum/index.php?thread/4-backup-reparatur-install-tool-iobroker/
                Das ist leider kein gutes Tool 😢
                  Matze QuinM Offline
                  Matze QuinM Offline
                  Matze Quin
                  ohha das ist unschön zu lesen. Hast du da eine alternative für mich?
                  Meinst du das diese Tatsache mit meinem Problem im Zusammenhang steht?
                  Vorher war definitiv alles in Funktion.
                    sieh dir mal die Links in der Signatur von @Thomas-Braun an
                      Dann bin ich auch raus. Das Ding ist aus meiner Sicht so windig, da mach ich dann nix mehr.
                        Matze QuinM Offline
                        Matze QuinM Offline
                        Matze Quin
                        In welcher Form windig? Mir war nicht bewusst das dieses Tool nicht vernünftig funktioniert.
                          Matze QuinM Offline
                          Matze QuinM Offline
                          Matze Quin
                          Danke das mache ich. Was ist nun geschehen nach der "Reparatur"?
                          Bin mir unsicher wie ich nun vorgehen soll...
                            @matze-quin
                            Wenn ich mir so anschaue, was der 'Kollege' wiederholt für (mit Verlaub) Schwachsinn empfiehlt brauch ich gar nicht weiter zu schauen. Wenn der den selben Murks in seinem supermegadollen Tool verbricht wird das unwartbar.
                              @matze-quin
                              Matze QuinM Offline
                              Matze QuinM Offline
                              Matze Quin
                              Ok ich verstehe...
                              wie kann ich nun am besten vorgehen? Bin echt aufgeschmissen, daher hoffe ich das ihr mir weiter helfen wollt.
                                Ok ich verstehe...
                                @matze-quin
                                Hast du ein Backup?
                                • backup extern sichern
                                • ioBroker Neu installieren
                                • backup zurückspielen
                                  @matze-quin
                                  Hast du ein Backup?
                                  Matze QuinM Offline
                                  Matze QuinM Offline
                                  Matze Quin
                                  Ja habe ich. Ok wie führe ich die Neuinstalation am besten aus?
                                    @matze-quin
                                    Versuch erstmal ein
                                    iobroker fix
                                    Vielleicht bekommen wir das Rumgemurkse da wieder gerade gebogen.
                                      • neuestes raspberry OS lite auf Karte
                                        • Datei ssh in der Boot-Partition anlegen
                                      • sudo raspi-config
                                        • Zeitzone und Sprachtreiber und ggf. Hostname einstellen
                                      • sudo apt update && sudo apt upgrade
                                      • curl -sLf https://iobroker.net/install.sh | bash -
                                      Backup einspielen
                                      iobroker host this
                                      iobroker start
                                        @matze-quin
                                        Versuch erstmal ein
                                        iobroker fix
                                        Matze QuinM Offline
                                        Matze QuinM Offline
                                        Matze Quin
                                        iobroker fix
                                        Super das wäre natürlich am besten.
                                        pi@raspberrypi:/opt/iobroker $ iobroker fix
                                        library: loaded
                                        Library version=2021-01-23
                                            Welcome to the ioBroker installation fixer!
                                            Script version: 2020-12-07
                                            You might need to enter your password a couple of times.
                                            Installing prerequisites (1/3)
                                        Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                                        Holen:2 http://archive.raspberrypi.org/debian buster InRelease [32,8 kB]
                                        OK:3 https://deb.nodesource.com/node_12.x buster InRelease
                                        Holen:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [367 kB]
                                        OK:5 https://phoscon.de/apt/deconz buster InRelease
                                        Es wurden 415 kB in 1 s geholt (287 kB/s).
                                        Installed gcc-c++
                                            Checking ioBroker user and directory permissions (2/3)
                                            Checking autostart (3/3)
                                        Enabling autostart...
                                        Autostart enabled!
                                            Your installation was fixed successfully
                                            Run iobroker start to start ioBroker again!
                                        Danke für eure Mühen!
                                          • sudo raspi-config
                                          Backup einspielen
                                          iobroker host this
                                          iobroker start
                                          Matze QuinM Offline
                                          Matze QuinM Offline
                                          Matze Quin
                                          Fals es nicht funktioniert, werde ich es so ausführen. Danke 👍
