  4. (?) ioBroker Restart ?
    5.4k
115 Beiträge 8 Kommentatoren 12.5k Aufrufe 7 Beobachtet
  • HumidorH Humidor
    @Thomas-Braun gerade wieder ein Restart, gestern Vormittag meine letzte Änderung im Script...
    Log ab dem ersten roten Eintrag (putty)
    [    6.199753] brcmfmac: F1 signature read @0x18000000=0x15264345
    [    6.213336] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [    6.217956] usbcore: registered new interface driver brcmfmac
    [    6.229254] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
    [    6.463189] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [    6.472543] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
    [    7.657064] random: crng init done
    [    7.657080] random: 7 urandom warning(s) missed due to ratelimiting
    [    8.328432] uart-pl011 fe201000.serial: no DMA platform data
    [    8.528777] 8021q: 802.1Q VLAN Support v1.8
    [    8.643547] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
    [    8.696698] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
    [    8.991957] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
    [    8.992311] bcmgenet fd580000.ethernet eth0: Link is Down
    [   13.998866] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    [   15.103223] Bluetooth: Core ver 2.22
    [   15.103331] NET: Registered protocol family 31
    [   15.103347] Bluetooth: HCI device and connection manager initialized
    [   15.103378] Bluetooth: HCI socket layer initialized
    [   15.103400] Bluetooth: L2CAP socket layer initialized
    [   15.103435] Bluetooth: SCO socket layer initialized
    [   15.112740] Bluetooth: HCI UART driver ver 2.3
    [   15.112762] Bluetooth: HCI UART protocol H4 registered
    [   15.112873] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [   15.114263] Bluetooth: HCI UART protocol Broadcom registered
    [   15.235681] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   15.235690] Bluetooth: BNEP filters: protocol multicast
    [   15.235703] Bluetooth: BNEP socket layer initialized
    [   31.833599] vcc-sd: disabling
    [   63.885706] FS-Cache: Netfs 'cifs' registered for caching
    [   63.894222] Key type cifs.spnego registered
    [   63.894236] Key type cifs.idmap registered
    [   63.895567] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
    [   63.895619] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
    [82303.059999] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
    [82303.060095] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
    [168704.428578] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
    [168704.428673] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
    [255105.912270] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
    [255105.912339] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
    [341507.341931] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
    [341507.341981] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
    [345505.634766] node invoked oom-killer: gfp_mask=0x400cc0(GFP_KERNEL_ACCOUNT), order=0, oom_score_adj=0
    [345505.634781] CPU: 2 PID: 23986 Comm: node Tainted: G         C        5.10.11-v7l+ #1399
    [345505.634785] Hardware name: BCM2711
    [345505.634790] Backtrace:
    [345505.634814] [<c0b58f24>] (dump_backtrace) from [<c0b592b8>] (show_stack+0x20/0x24)
    [345505.634820]  r7:ffffffff r6:00000000 r5:60000113 r4:c12e69bc
    [345505.634829] [<c0b59298>] (show_stack) from [<c0b5d644>] (dump_stack+0xcc/0xf8)
    [345505.634837] [<c0b5d578>] (dump_stack) from [<c0b5b8d4>] (dump_header+0x64/0x208)
    [345505.634843]  r10:c120518c r9:00400cc0 r8:00000000 r7:c0e35b18 r6:d6f97c00 r5:c3fbec80
    [345505.634847]  r4:ef461ce8 r3:70f18072
    [345505.634859] [<c0b5b870>] (dump_header) from [<c03b53d0>] (oom_kill_process+0x1b4/0x1c0)
    [345505.634864]  r7:c0e35b18 r6:ef461ce8 r5:c3fbf200 r4:c3fbec80
    [345505.634871] [<c03b521c>] (oom_kill_process) from [<c03b5f28>] (out_of_memory+0x2b8/0x390)
    [345505.634877]  r7:c1208580 r6:c1205048 r5:c3fbec80 r4:ef461ce8
    [345505.634884] [<c03b5c70>] (out_of_memory) from [<c0408d28>] (__alloc_pages_nodemask+0x7ec/0x1184)
    [345505.634890]  r7:c13356d0 r6:00001800 r5:000019b0 r4:00000000
    [345505.634899] [<c040853c>] (__alloc_pages_nodemask) from [<c09deb90>] (alloc_skb_with_frags+0xdc/0x1a4)
    [345505.634905]  r10:c5b586c0 r9:00008000 r8:004008c0 r7:00000000 r6:00000008 r5:00000008
    [345505.634909]  r4:00000003
    [345505.634917] [<c09deab4>] (alloc_skb_with_frags) from [<c09d63e8>] (sock_alloc_send_pskb+0x214/0x248)
    [345505.634922]  r10:ef461df8 r9:c1205048 r8:c026fee8 r7:ef461e60 r6:ffffe000 r5:00000000
    [345505.634926]  r4:d6f97900
    [345505.634936] [<c09d61d4>] (sock_alloc_send_pskb) from [<c0b02bd8>] (unix_stream_sendmsg+0x158/0x3c0)
    [345505.634942]  r10:d6f97900 r9:00000f00 r8:d6f97600 r7:ef461e60 r6:00000000 r5:00008f00
    [345505.634946]  r4:00008000
    [345505.634955] [<c0b02a80>] (unix_stream_sendmsg) from [<c09d0aa0>] (sock_sendmsg+0x44/0x54)
    [345505.634960]  r10:cc681b80 r9:ef67d6c0 r8:ef461ef8 r7:00000000 r6:00000000 r5:cc681b80
    [345505.634964]  r4:ef461e60
    [345505.634972] [<c09d0a5c>] (sock_sendmsg) from [<c09d0b54>] (sock_write_iter+0xa4/0xf8)
    [345505.634976]  r5:c1205048 r4:ef461ee0
    [345505.634987] [<c09d0ab0>] (sock_write_iter) from [<c0439c98>] (vfs_write+0x3ec/0x464)
    [345505.634992]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:c1205048 r5:0000b105
    [345505.634996]  r4:ef67d6c0
    [345505.635004] [<c04398ac>] (vfs_write) from [<c0439ed8>] (ksys_write+0xcc/0xe0)
    [345505.635010]  r10:0000b105 r9:b638a008 r8:ef67d6c0 r7:00000004 r6:00000003 r5:ef67d6c1
    [345505.635014]  r4:c1205048
    [345505.635022] [<c0439e0c>] (ksys_write) from [<c0439f04>] (sys_write+0x18/0x1c)
    [345505.635027]  r10:00000004 r9:ef460000 r8:c0200204 r7:00000004 r6:00000003 r5:b638a008
    [345505.635031]  r4:0000b105
    [345505.635042] [<c0439eec>] (sys_write) from [<c0200040>] (ret_fast_syscall+0x0/0x28)
    [345505.635047] Exception stack(0xef461fa8 to 0xef461ff0)
    [345505.635053] 1fa0:                   0000b105 b638a008 00000003 b638a008 0000b105 00000000
    [345505.635059] 1fc0: 0000b105 b638a008 00000003 00000004 00000001 be875048 be875030 be874fec
    [345505.635064] 1fe0: 00000002 be874f50 00000000 b6d0c1bc
    [345505.635069] Mem-Info:
    [345505.635081] active_anon:39564 inactive_anon:391574 isolated_anon:0
                     active_file:6349 inactive_file:6283 isolated_file:285
                     unevictable:4 dirty:11 writeback:0
                     slab_reclaimable:3095 slab_unreclaimable:5661
                     mapped:10599 shmem:700 pagetables:9012 bounce:0
                     free:8524 free_pcp:59 free_cma:898
    [345505.635092] Node 0 active_anon:158256kB inactive_anon:1566296kB active_file:25396kB inactive_file:25132kB unevictable:16kB isolated(anon):0kB isolated(file):1140kB mapped:42396kB dirty:44kB writeback:0kB shmem:2800kB writeback_tmp:0kB kernel_stack:7384kB all_unreclaimable? no
    [345505.635103] DMA free:25948kB min:24576kB low:28672kB high:32768kB reserved_highatomic:0KB active_anon:57204kB inactive_anon:525208kB active_file:424kB inactive_file:244kB unevictable:0kB writepending:32kB present:786432kB managed:678432kB mlocked:0kB pagetables:13108kB bounce:0kB free_pcp:232kB local_pcp:120kB free_cma:3592kB
    [345505.635109] lowmem_reserve[]: 0 0 1203 0
    [345505.635146] HighMem free:8148kB min:8704kB low:16140kB high:23576kB reserved_highatomic:0KB active_anon:100112kB inactive_anon:1039500kB active_file:24992kB inactive_file:24684kB unevictable:16kB writepending:384kB present:1231872kB managed:1231872kB mlocked:16kB pagetables:22940kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
    [345505.635152] lowmem_reserve[]: 0 0 0 0
    [345505.635184] DMA: 777*4kB (UMEC) 739*8kB (UMEC) 442*16kB (UMEC) 182*32kB (UMEC) 40*64kB (UEC) 12*128kB (E) 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 26012kB
    [345505.635289] HighMem: 104*4kB (UM) 385*8kB (UM) 118*16kB (UM) 46*32kB (UM) 8*64kB (UM) 3*128kB (U) 1*256kB (U) 1*512kB (U) 1*1024kB (U) 0*2048kB 0*4096kB = 9544kB
    [345505.635410] 12545 total pagecache pages
    [345505.635418] 1430 pages in swap cache
    [345505.635425] Swap cache stats: add 28769, delete 27339, find 2183/2924
    [345505.635431] Free swap  = 0kB
    [345505.635437] Total swap = 102396kB
    [345505.635443] 504576 pages RAM
    [345505.635449] 307968 pages HighMem/MovableOnly
    [345505.635455] 27000 pages reserved
    [345505.635461] 65536 pages cma reserved
    [345505.635467] Tasks state (memory values in pages):
    [345505.635473] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
    [345505.635493] [    112]     0   112     5311     1123   139264      131             0 systemd-journal
    [345505.635502] [    146]     0   146     4497      342    49152      153         -1000 systemd-udevd
    [345505.635513] [    291]   100   291     5604      417    61440      141             0 systemd-timesyn
    [345505.635523] [    326]   108   326     1476      426    36864       29             0 avahi-daemon
    [345505.635531] [    327]     0   327     6378      354    49152      101             0 rsyslogd
    [345505.635538] [    334]     0   334      923      215    28672       40             0 alsactl
    [345505.635546] [    336]     0   336     1987      254    36864       31             0 cron
    [345505.635554] [    344]     0   344     6914      214    40960       10             0 rngd
    [345505.635562] [    352]   104   352     1665      421    36864       46          -900 dbus-daemon
    [345505.635570] [    353]   108   353     1443       13    32768       50             0 avahi-daemon
    [345505.635578] [    361]     0   361     2686      286    45056       89             0 wpa_supplicant
    [345505.635586] [    362]     0   362     3283      462    53248      131             0 systemd-logind
    [345505.635594] [    367] 65534   367     1080      219    36864       39             0 thd
    [345505.635601] [    455]     0   455     2751      613    45056      102             0 wpa_supplicant
    [345505.635609] [    469]     0   469      535        0    28672       32             0 hciattach
    [345505.635617] [    473]     0   473     2384      127    45056       93             0 bluetoothd
    [345505.635624] [    538]     0   538      726      272    28672       50             0 dhcpcd
    [345505.635633] [    539]  1001   539    73874    33503  1077248    14438             0 node
    [345505.635641] [    544]   109   544   237909     3364   225280      964             0 grafana-server
    [345505.635649] [    546]     0   546     9677     1894    90112     1296             0 unattended-upgr
    [345505.635656] [    547]     0   547     1077      119    32768       25             0 agetty
    [345505.635664] [    548]     0   548     2682      267    49152      130         -1000 sshd
    [345505.635672] [    579]  1001   579    43527    19340   757760       43             0 node
    [345505.635680] [    594]  1001   594    39878    15292   618496      213             0 node
    [345505.635689] [    617]  1001   617    39189    14540   610304      352             0 node
    [345505.635697] [    647]  1001   647    52000    27662   901120      142             0 node
    [345505.635704] [    662]  1001   662    42967    17341   610304       33             0 node
    [345505.635713] [    680]  1001   680    38560    13466   548864      196             0 node
    [345505.635721] [    695]  1001   695    39489    14807   626688       75             0 node
    [345505.635729] [    712]  1001   712    42830    15734   643072      155             0 node
    [345505.635737] [    727]  1001   727    45224    20724   786432      251             0 node
    [345505.635746] [    785]  1001   785    52077    27639   802816      188             0 node
    [345505.635754] [    800]  1001   800    36749    11939   479232      115             0 node
    [345505.635762] [    822]  1001   822    38633    14169   577536      178             0 node
    [345505.635769] [    837]  1001   837    39767    15240   598016      140             0 node
    [345505.635777] [    852]  1001   852    39565    15187   593920       70             0 node
    [345505.635785] [   7741]     0  7741     9491      957    69632        4             0 polkitd
    [345505.635793] [   8166]  1001  8166    41727    15868   630784      956             0 node
    [345505.635801] [   8235]  1001  8235    46083    18920   688128     2818             0 node
    [345505.635812] [  23574]  1001 23574    23902     8644   323584        0             0 node
    [345505.635820] [  23580]  1001 23580    23470     8227   278528        0             0 node
    [345505.635828] [  23581]  1001 23581    26482    10632   397312        0             0 node
    [345505.635836] [  23584]  1001 23584    25555     9702   409600        0             0 node
    [345505.635844] [  23589]  1001 23589    23472     8339   286720        0             0 node
    [345505.635851] [  23596]  1001 23596    26403    10701   389120        0             0 node
    [345505.635859] [  23598]  1001 23598    25542     9875   413696        0             0 node
    [345505.635867] [  23612]  1001 23612    23472     8289   286720        0             0 node
    [345505.635875] [  23615]  1001 23615    26409    10609   385024        0             0 node
    [345505.635882] [  23622]  1001 23622    25475     9904   397312        0             0 node
    [345505.635891] [  23623]  1001 23623    23470     8272   290816        0             0 node
    [345505.635899] [  23636]  1001 23636    26549    10686   405504        0             0 node
    [345505.635907] [  23644]  1001 23644    25602     9727   413696        0             0 node
    [345505.635914] [  23651]  1001 23651    23476     8336   294912        0             0 node
    [345505.635922] [  23658]  1001 23658    26479    10664   393216        0             0 node
    [345505.635931] [  23659]  1001 23659    23840     8646   315392        0             0 node
    [345505.635938] [  23667]  1001 23667    23472     8293   286720        0             0 node
    [345505.635946] [  23678]  1001 23678    26384    10433   385024        0             0 node
    [345505.635954] [  23686]  1001 23686    23915     8548   339968        0             0 node
    [345505.635962] [  23693]  1001 23693    23609     8151   294912        0             0 node
    [345505.635970] [  23695]  1001 23695    26437    10479   401408        0             0 node
    [345505.635977] [  23708]  1001 23708    23906     8675   327680        0             0 node
    [345505.635985] [  23713]  1001 23713    23539     8017   294912        0             0 node
    [345505.635993] [  23715]  1001 23715    26374    10438   389120        0             0 node
    [345505.636000] [  23723]  1001 23723    23866     8570   335872        0             0 node
    [345505.636008] [  23738]  1001 23738    23613     8189   294912        0             0 node
    [345505.636016] [  23741]  1001 23741    26437    10546   385024        0             0 node
    [345505.636024] [  23747]  1001 23747    23866     8622   344064        0             0 node
    [345505.636031] [  23753]  1001 23753    23543     8188   286720        0             0 node
    [345505.636039] [  23759]  1001 23759    26446    10512   393216        0             0 node
    [345505.636047] [  23765]  1001 23765    27376    11680   409600        0             0 node
    [345505.636055] [  23770]  1001 23770    23548     8178   290816        0             0 node
    [345505.636063] [  23777]  1001 23777    25288    10388   323584        0             0 node
    [345505.636071] [  23789]  1001 23789    26880    10781   405504        0             0 node
    [345505.636079] [  23798]  1001 23798    23534     8158   290816        0             0 node
    [345505.636087] [  23801]  1001 23801    26388    10470   385024        0             0 node
    [345505.636094] [  23806]  1001 23806    26848    10794   417792        0             0 node
    [345505.636103] [  23815]  1001 23815    23564     8179   286720        0             0 node
    [345505.636110] [  23824]  1001 23824    24476     8854   299008        0             0 node
    [345505.636118] [  23827]  1001 23827    27438    11615   409600        0             0 node
    [345505.636126] [  23836]  1001 23836    23543     8202   299008        0             0 node
    [345505.636134] [  23851]  1001 23851    24299     8430   290816        0             0 node
    [345505.636142] [  23852]  1001 23852    25140     9299   294912        0             0 node
    [345505.636217] [  23853]  1001 23853    23600     8004   299008        0             0 node
    [345505.636225] [  23860]  1001 23860    24402     8633   299008        0             0 node
    [345505.636236] [  23871]  1001 23871    25142     9106   303104        0             0 node
    [345505.636245] [  23882]  1001 23882    23547     8269   294912        0             0 node
    [345505.636255] [  23883]  1001 23883    23647     8149   258048        0             0 node
    [345505.636264] [  23889]  1001 23889    24905     8888   290816        0             0 node
    [345505.636273] [  23897]  1001 23897    22772     7063   233472        0             0 node
    [345505.636282] [  23909]  1001 23909    24481     9077   299008        0             0 node
    [345505.636290] [  23915]  1001 23915    24227     8542   253952        0             0 node
    [345505.636298] [  23923]  1001 23923    22777     7103   233472        0             0 node
    [345505.636306] [  23925]  1001 23925    23586     7951   241664        0             0 node
    [345505.636314] [  23931]  1001 23931    23121     6682   241664        0             0 node
    [345505.636323] [  23935]  1001 23935    23570     8201   290816        0             0 node
    [345505.636330] [  23945]  1001 23945    22021     6155   221184        0             0 node
    [345505.636338] [  23946]  1001 23946    24163     8207   245760        0             0 node
    [345505.636346] [  23958]  1001 23958    21598     6038   196608        0             0 node
    [345505.636354] [  23976]  1001 23976    22079     6169   221184        0             0 node
    [345505.636362] [  23978]  1001 23978    24232     8600   253952        0             0 node
    [345505.636369] [  23979]  1001 23979    23482     7498   282624        0             0 node
    [345505.636377] [  23986]  1001 23986    22113     5990   221184        0             0 node
    [345505.636384] [  23990]  1001 23990    21662     6052   200704        0             0 node
    [345505.636392] [  24007]  1001 24007    22777     6915   245760        0             0 node
    [345505.636400] [  24015]  1001 24015    21618     6018   188416        0             0 node
    [345505.636408] [  24027]  1001 24027    21598     6020   196608        0             0 node
    [345505.636415] [  24029]  1001 24029    21564     5875   192512        0             0 node
    [345505.636423] [  24036]  1001 24036    21598     6019   196608        0             0 node
    [345505.636431] [  24042]  1001 24042    21586     6004   200704        0             0 node
    [345505.636439] [  24054]  1001 24054    22084     6344   225280        0             0 node
    [345505.636447] [  24061]  1001 24061    21598     6016   200704        0             0 node
    [345505.636455] [  24068]  1001 24068    21478     5844   196608        0             0 node
    [345505.636463] [  24081]  1001 24081    21500     5875   192512        0             0 node
    [345505.636471] [  24084]  1001 24084    21500     5971   188416        0             0 node
    [345505.636478] [  24086]  1001 24086    21564     5944   196608        0             0 node
    [345505.636486] [  24094]  1001 24094    21409     5688   188416        0             0 node
    [345505.636494] [  24105]  1001 24105    21474     5872   188416        0             0 node
    [345505.636502] [  24106]  1001 24106    21153     5526   176128        0             0 node
    [345505.636510] [  24107]  1001 24107    21410     5812   184320        0             0 node
    [345505.636518] [  24119]  1001 24119    21410     5751   192512        0             0 node
    [345505.636526] [  24132]  1001 24132    20344     5231   151552        0             0 node
    [345505.636533] [  24137]  1001 24137    20836     5375   176128        0             0 node
    [345505.636541] [  24139]  1001 24139    20059     4794   159744        0             0 node
    [345505.636549] [  24146]  1001 24146    20059     4748   155648        0             0 node
    [345505.636557] [  24152]  1001 24152     8597      137    32768        0             0 node
    [345505.636566] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/,task=node,pid=539,uid=1001
    [345505.636647] Out of memory: Killed process 539 (node) total-vm:295496kB, anon-rss:108868kB, file-rss:25144kB, shmem-rss:0kB, UID:1001 pgtables:1052kB oom_score_adj:0
    [345505.753989] oom_reaper: reaped process 539 (node), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
    [345608.547443] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
    [345608.547493] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
    out of memory, das muss von ioBroker oder einem Adapter kommen.
    @humidor
    Vermutlich ein unsauberes Skript.
    Was für eine Anfrage läuft denn da über cron im Sekundentakt?
    Den samba-mount würde ich mir an deiner Stelle aber auch mal ansehen.
    HumidorH 1 Antwort Letzte Antwort
      @humidor
      HumidorH Online
      HumidorH Online
      Humidor
      @thomas-braun Script, die sind so einfach und überschaubar, das glaube ich nicht.
      samba-mount ? hmm wer, wo was?
      BG
      • HumidorH Humidor
        @humidor
        Auch da kann man Mist machen.
          @humidor
          HumidorH Online
          HumidorH Online
          Humidor
          schrieb am zuletzt editiert von Humidor
          @thomas-braun das ist Backitup mit NAS und SMB1, sollte ich das auf SMB 2/ 3 umstellen?
          oder NFS?
          BG
          • HumidorH Humidor
            oder NFS?
            @humidor
            NFS ist immer die bessere Wahl.
            Und auch smb2/3 ist besser als 1
            • wendy2702W Online
              wendy2702W Online
              @humidor sagte in (?) ioBroker Restart ?:
              Deutet auf einen Adapter hin der den Memory erschöpft. Da musst du jetzt im iobroker log mal zu dem Zeitpunkt schauen.
              Ich vermute aber auch ein Script, auch wenn es überschaubar ist und wie @Thomas-Braun sagt.... sekündliche abfragen sind auch nicht sinnvoll.
              HumidorH 2 Antworten Letzte Antwort
              • wendy2702W wendy2702
                HumidorH Online
                HumidorH Online
                Humidor
                @wendy2702
                um 7:21 hat er einen Restart gemacht, 7:23 wieder online
                die sekündlichen Abfragen mache ich nur wenn der Zoe geladen wird, war zu diesem Zeitpunkt nicht der Fall.
                2021-03-08 07:21:58.974 - info: javascript.0 (647) Stop script script.js.common.AMIS
                2021-03-08 07:21:58.491 - error: shelly.0 (785) States database error: read ECONNRESET
                2021-03-08 07:21:58.968 - info: vis-inventwo.0 (800) cleaned everything up...
                2021-03-08 07:21:58.982 - info: javascript.0 (647) Stop script script.js.common.SE_Power
                2021-03-08 07:21:58.983 - info: javascript.0 (647) Stop script script.js.common.Sonnenstand
                2021-03-08 07:21:58.989 - info: javascript.0 (647) Stop script script.js.common.Grid-PV
                2021-03-08 07:21:58.997 - info: javascript.0 (647) Stop script script.js.common.SMA+SE
                2021-03-08 07:21:58.999 - info: javascript.0 (647) Stop script script.js.common.Zoe_Zielladung
                2021-03-08 07:21:59.000 - info: javascript.0 (647) Stop script script.js.common.PVÜberschuss
                2021-03-08 07:21:59.083 - info: javascript.0 (647) Stop script script.js.common.ZOE_Ladung
                2021-03-08 07:21:59.096 - info: javascript.0 (647) Stop script script.js.common.Powerbank
                2021-03-08 07:21:59.101 - info: javascript.0 (647) Stop script script.js.common.Garage
                2021-03-08 07:21:58.861 - error: mqtt.0 (617) Objects database error: read ECONNRESET
                2021-03-08 07:21:59.098 - error: shelly.0 (785) Objects database error: read ECONNRESET
                2021-03-08 07:21:59.143 - info: shelly.0 (785) Closing Adapter
                2021-03-08 07:21:58.971 - info: info.0 (852) cleaned everything up...
                2021-03-08 07:21:59.159 - info: life360.0 (8166) Disabled polling.
                2021-03-08 07:21:59.166 - info: iot.0 (695) Connection changed: disconnect
                2021-03-08 07:21:59.170 - info: iot.0 (695) Connection lost
                2021-03-08 07:21:59.182 - info: life360.0 (8166) cleaned everything up...
                2021-03-08 07:21:59.153 - info: backitup.0 (727) cleaned everything up...
                2021-03-08 07:21:58.976 - info: cloud.0 (680) Connection changed: io client disconnect
                2021-03-08 07:21:59.198 - info: cloud.0 (680) Connection lost
                2021-03-08 07:21:59.199 - info: cloud.0 (680) Restart adapter by disconnect
                2021-03-08 07:21:59.027 - info: admin.0 (579) terminating http server on port 8081
                2021-03-08 07:22:00.524 - info: iot.0 (695) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-03-08 07:22:00.614 - info: javascript.0 (647) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-03-08 07:22:00.623 - info: vis-inventwo.0 (800) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-03-08 07:22:00.630 - info: modbus.1 (837) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-03-08 07:22:00.640 - info: modbus.0 (822) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-03-08 07:22:00.648 - info: shelly.0 (785) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-03-08 07:22:00.664 - info: mqtt.0 (617) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-03-08 07:22:00.677 - info: info.0 (852) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-03-08 07:22:00.685 - info: life360.0 (8166) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-03-08 07:22:00.698 - info: backitup.0 (727) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-03-08 07:22:00.705 - info: cloud.0 (680) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-03-08 07:22:00.713 - info: admin.0 (579) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-03-08 07:22:00.675 - info: kecontact.0 (594) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-03-08 07:22:00.697 - info: telegram.0 (712) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-03-08 07:22:03.522 - error: admin.0 (579) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                2021-03-08 07:22:03.545 - error: kecontact.0 (594) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                2021-03-08 07:22:03.616 - error: telegram.0 (712) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                2021-03-08 07:22:03.618 - error: cloud.0 (680) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                2021-03-08 07:22:03.620 - error: info.0 (852) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                2021-03-08 07:22:03.627 - error: life360.0 (8166) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                2021-03-08 07:22:03.637 - error: backitup.0 (727) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                2021-03-08 07:22:03.630 - error: vis-inventwo.0 (800) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                2021-03-08 07:22:03.698 - error: iot.0 (695) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                2021-03-08 07:22:03.674 - error: javascript.0 (647) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                2021-03-08 07:22:03.738 - warn: life360.0 (8166) get state error: Connection is closed.
                2021-03-08 07:22:03.805 - warn: admin.0 (579) get state error: Connection is closed.
                2021-03-08 07:22:03.825 - warn: kecontact.0 (594) get state error: Connection is closed.
                2021-03-08 07:22:03.719 - warn: backitup.0 (727) get state error: Connection is closed.
                2021-03-08 07:22:03.913 - error: modbus.0 (822) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                2021-03-08 07:22:03.776 - warn: life360.0 (8166) get state error: DB closed
                2021-03-08 07:22:03.987 - error: modbus.1 (837) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                2021-03-08 07:22:04.114 - error: shelly.0 (785) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                2021-03-08 07:22:04.142 - error: mqtt.0 (617) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                2021-03-08 07:22:04.102 - warn: modbus.0 (822) get state error: Connection is closed.
                2021-03-08 07:22:04.186 - warn: modbus.0 (822) get state error: DB closed
                2021-03-08 07:22:03.716 - error: web.0 (8235) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                2021-03-08 07:22:04.338 - warn: mqtt.0 (617) get state error: Connection is closed.
                2021-03-08 07:22:08.632 - error: life360.0 (8166) Cannot check object existence of "life360.0.info.connection": Connection is closed.
                2021-03-08 07:22:08.917 - error: modbus.0 (822) Cannot check object existence of "modbus.0.inputRegisters.30769_DC_Strom_Eingang_1": Connection is closed.
                2021-03-08 07:22:09.147 - error: mqtt.0 (617) Cannot check object existence of "mqtt.0.AMIS": Connection is closed.
                2021-03-08 07:22:11.573 - error: history.0 (662) States database error: write EPIPE
                2021-03-08 07:22:12.256 - error: history.0 (662) uncaught exception: write EPIPE
                2021-03-08 07:22:12.256 - error: history.0 (662) Error: write EPIPE
                at ChildProcess.target._send (internal/child_process.js:807:20)
                at ChildProcess.target.send (internal/child_process.js:678:19)
                at /opt/iobroker/node_modules/iobroker.history/main.js:1061:28
                at getCachedData (/opt/iobroker/node_modules/iobroker.history/main.js:837:5)
                at ChildProcess. (/opt/iobroker/node_modules/iobroker.history/main.js:1060:21)
                at ChildProcess.emit (events.js:314:20)
                at ChildProcess.EventEmitter.emit (domain.js:483:12)
                at emit (internal/child_process.js:877:12)
                at processTicksAndRejections (internal/process/task_queues.js:85:21)
                2021-03-08 07:22:12.257 - error: history.0 (662) Exception-Code: EPIPE: write EPIPE
                2021-03-08 07:22:12.541 - error: history.0 (662) uncaught exception: write EPIPE
                2021-03-08 07:22:12.542 - error: history.0 (662) Error: write EPIPE
                2021-03-08 07:22:16.795 - error: history.0 (662) Exception-Code: EPIPE: write EPIPE
                2021-03-08 07:22:25.874 - info: host.raspi4iobrokerpv iobroker.js-controller version 3.2.16 js-controller starting
                2021-03-08 07:22:25.879 - info: host.raspi4iobrokerpv Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                2021-03-08 07:22:25.880 - info: host.raspi4iobrokerpv hostname: raspi4iobrokerpv, node: v12.21.0
                2021-03-08 07:22:25.881 - info: host.raspi4iobrokerpv ip addresses: 192.168.0.93 fe80::9a94:9b45:baab:4bdd
                2021-03-08 07:22:26.438 - info: host.raspi4iobrokerpv connected to Objects and States
                2021-03-08 07:22:26.483 - info: host.raspi4iobrokerpv added notifications configuration of host
                2021-03-08 07:22:26.950 - info: host.raspi4iobrokerpv 29 instances found
                2021-03-08 07:22:27.018 - info: host.raspi4iobrokerpv starting 20 instances
                2021-03-08 07:22:27.113 - info: host.raspi4iobrokerpv instance system.adapter.admin.0 started with pid 25039
                2021-03-08 07:22:28.761 - error: admin.0 (25039) admin.0 already running
                2021-03-08 07:22:28.764 - warn: admin.0 (25039) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-03-08 07:22:29.363 - error: host.raspi4iobrokerpv instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-03-08 07:22:29.364 - info: host.raspi4iobrokerpv Restart adapter system.adapter.admin.0 because enabled
                2021-03-08 07:22:31.065 - info: host.raspi4iobrokerpv instance system.adapter.kecontact.0 started with pid 25050
                2021-03-08 07:22:32.217 - error: kecontact.0 (25050) kecontact.0 already running
                2021-03-08 07:22:32.219 - warn: kecontact.0 (25050) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-03-08 07:22:32.791 - error: host.raspi4iobrokerpv instance system.adapter.kecontact.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-03-08 07:22:32.792 - info: host.raspi4iobrokerpv Restart adapter system.adapter.kecontact.0 because enabled
                2021-03-08 07:22:35.141 - info: host.raspi4iobrokerpv instance system.adapter.mqtt.0 started with pid 25061
                2021-03-08 07:22:36.185 - error: mqtt.0 (25061) mqtt.0 already running
                2021-03-08 07:22:36.188 - warn: mqtt.0 (25061) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-03-08 07:22:36.823 - error: host.raspi4iobrokerpv instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-03-08 07:22:36.824 - info: host.raspi4iobrokerpv Restart adapter system.adapter.mqtt.0 because enabled
                2021-03-08 07:22:39.144 - info: host.raspi4iobrokerpv instance system.adapter.web.0 started with pid 25072
                2021-03-08 07:22:40.330 - error: web.0 (25072) web.0 already running
                2021-03-08 07:22:40.942 - error: host.raspi4iobrokerpv instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-03-08 07:22:40.943 - info: host.raspi4iobrokerpv Restart adapter system.adapter.web.0 because enabled
                2021-03-08 07:22:43.093 - info: host.raspi4iobrokerpv instance system.adapter.javascript.0 started with pid 25083
                2021-03-08 07:22:45.301 - error: javascript.0 (25083) javascript.0 already running
                2021-03-08 07:22:45.304 - warn: javascript.0 (25083) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-03-08 07:22:45.950 - error: host.raspi4iobrokerpv instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-03-08 07:22:45.952 - info: host.raspi4iobrokerpv Restart adapter system.adapter.javascript.0 because enabled
                2021-03-08 07:22:47.141 - info: host.raspi4iobrokerpv instance system.adapter.history.0 started with pid 25094
                2021-03-08 07:22:48.171 - error: history.0 (25094) history.0 already running
                2021-03-08 07:22:48.174 - warn: history.0 (25094) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-03-08 07:22:48.809 - error: host.raspi4iobrokerpv instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-03-08 07:22:48.809 - info: host.raspi4iobrokerpv Restart adapter system.adapter.history.0 because enabled
                2021-03-08 07:22:51.126 - info: host.raspi4iobrokerpv instance system.adapter.cloud.0 started with pid 25106
                2021-03-08 07:22:52.449 - error: cloud.0 (25106) cloud.0 already running
                2021-03-08 07:22:52.451 - warn: cloud.0 (25106) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-03-08 07:22:53.030 - error: host.raspi4iobrokerpv instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-03-08 07:22:53.031 - info: host.raspi4iobrokerpv Restart adapter system.adapter.cloud.0 because enabled
                2021-03-08 07:22:55.124 - info: host.raspi4iobrokerpv instance system.adapter.iot.0 started with pid 25117
                2021-03-08 07:22:56.669 - error: iot.0 (25117) iot.0 already running
                2021-03-08 07:22:56.671 - warn: iot.0 (25117) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-03-08 07:22:57.255 - error: host.raspi4iobrokerpv instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-03-08 07:22:57.255 - info: host.raspi4iobrokerpv Restart adapter system.adapter.iot.0 because enabled
                2021-03-08 07:22:59.120 - info: host.raspi4iobrokerpv instance system.adapter.telegram.0 started with pid 25128
                2021-03-08 07:22:59.385 - info: host.raspi4iobrokerpv instance system.adapter.admin.0 started with pid 25135
                2021-03-08 07:23:01.099 - error: telegram.0 (25128) telegram.0 already running
                2021-03-08 07:23:01.102 - warn: telegram.0 (25128) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-03-08 07:23:01.400 - info: admin.0 (25135) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.21.0, js-controller: 3.2.16
                2021-03-08 07:23:01.451 - info: admin.0 (25135) requesting all states
                2021-03-08 07:23:01.451 - info: admin.0 (25135) requesting all objects
                2021-03-08 07:23:02.169 - error: host.raspi4iobrokerpv instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-03-08 07:23:02.170 - info: host.raspi4iobrokerpv Restart adapter system.adapter.telegram.0 because enabled
                2021-03-08 07:23:02.511 - info: admin.0 (25135) received all objects
                2021-03-08 07:23:02.656 - info: admin.0 (25135) http server listening on port 8081
                2021-03-08 07:23:02.815 - info: host.raspi4iobrokerpv instance system.adapter.kecontact.0 started with pid 25154
                2021-03-08 07:23:02.656 - info: admin.0 (25135) Use link "http://localhost:8081" to configure.
                2021-03-08 07:23:03.065 - info: host.raspi4iobrokerpv instance system.adapter.backitup.0 started with pid 25161
                2021-03-08 07:23:04.411 - info: kecontact.0 (25154) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.kecontact, node: v12.21.0, js-controller: 3.2.16
                2021-03-08 07:23:06.816 - error: backitup.0 (25161) backitup.0 already running
                2021-03-08 07:23:06.819 - warn: backitup.0 (25161) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-03-08 07:23:06.845 - info: host.raspi4iobrokerpv instance system.adapter.mqtt.0 started with pid 25180
                2021-03-08 07:23:07.411 - error: host.raspi4iobrokerpv instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-03-08 07:23:07.412 - info: host.raspi4iobrokerpv Restart adapter system.adapter.backitup.0 because enabled
                2021-03-08 07:23:08.428 - info: mqtt.0 (25180) starting. Version 2.3.4 in /opt/iobroker/node_modules/iobroker.mqtt, node: v12.21.0, js-controller: 3.2.16
                2021-03-08 07:23:08.454 - info: vis.0 (25187) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.vis, node: v12.21.0, js-controller: 3.2.16
                2021-03-08 07:23:08.650 - info: mqtt.0 (25180) Starting MQTT server on 0.0.0.0:1883
                2021-03-08 07:23:08.888 - info: vis.0 (25187) vis license is OK.
                2021-03-08 07:23:09.379 - info: mqtt.0 (25180) Client [AMIS] connected with secret 1615184589372_2795
                2021-03-08 07:23:09.482 - info: kecontact.0 (25154) starting charging station in passive mode
                2021-03-08 07:23:09.818 - info: vis.0 (25187) Terminated (NO_ERROR): Without reason
                2021-03-08 07:23:10.398 - info: host.raspi4iobrokerpv instance system.adapter.vis.0 terminated while should be started once
                2021-03-08 07:23:10.963 - info: host.raspi4iobrokerpv instance system.adapter.web.0 started with pid 25210
                2021-03-08 07:23:11.100 - info: host.raspi4iobrokerpv instance system.adapter.shelly.0 started with pid 25217
                2021-03-08 07:23:13.016 - error: shelly.0 (25217) shelly.0 already running
                2021-03-08 07:23:13.019 - warn: shelly.0 (25217) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-03-08 07:23:13.602 - error: host.raspi4iobrokerpv instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-03-08 07:23:13.603 - info: host.raspi4iobrokerpv Restart adapter system.adapter.shelly.0 because enabled
                2021-03-08 07:23:15.170 - info: host.raspi4iobrokerpv instance system.adapter.vis-inventwo.0 started with pid 25236
                2021-03-08 07:23:15.971 - info: host.raspi4iobrokerpv instance system.adapter.javascript.0 started with pid 25247
                2021-03-08 07:23:16.233 - error: vis-inventwo.0 (25236) vis-inventwo.0 already running
                2021-03-08 07:23:16.235 - warn: vis-inventwo.0 (25236) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-03-08 07:23:16.840 - error: host.raspi4iobrokerpv instance system.adapter.vis-inventwo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-03-08 07:23:16.841 - info: host.raspi4iobrokerpv Restart adapter system.adapter.vis-inventwo.0 because enabled
                2021-03-08 07:23:18.750 - info: javascript.0 (25247) starting. Version 4.8.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.21.0, js-controller: 3.2.16
                2021-03-08 07:23:18.831 - info: host.raspi4iobrokerpv instance system.adapter.history.0 started with pid 25262
                2021-03-08 07:23:18.909 - info: javascript.0 (25247) requesting all states
                2021-03-08 07:23:18.911 - info: javascript.0 (25247) requesting all objects
                2021-03-08 07:23:19.670 - info: host.raspi4iobrokerpv instance system.adapter.modbus.0 started with pid 25269
                2021-03-08 07:23:19.918 - info: javascript.0 (25247) received all states
                2021-03-08 07:23:19.943 - info: javascript.0 (25247) received all objects
                2021-03-08 07:23:20.184 - info: javascript.0 (25247) Start javascript script.js.common.AMIS
                2021-03-08 07:23:20.248 - info: javascript.0 (25247) script.js.common.AMIS: registered 1 subscription and 0 schedules
                2021-03-08 07:23:20.249 - info: javascript.0 (25247) Start javascript script.js.common.SE_Power
                2021-03-08 07:23:20.256 - info: javascript.0 (25247) script.js.common.SE_Power: registered 0 subscriptions and 0 schedules
                2021-03-08 07:23:20.257 - info: javascript.0 (25247) Start javascript script.js.common.Sonnenstand
                2021-03-08 07:23:20.266 - info: javascript.0 (25247) script.js.common.Sonnenstand: long: - lat:
                2021-03-08 07:23:20.283 - info: javascript.0 (25247) script.js.common.Sonnenstand: Script Sonnenstand; Erfolgreich gelaufen, Werte akzeptiert
                2021-03-08 07:23:20.286 - info: javascript.0 (25247) script.js.common.Sonnenstand: registered 0 subscriptions and 1 schedule
                2021-03-08 07:23:20.287 - info: javascript.0 (25247) Start javascript script.js.common.Powerbank
                2021-03-08 07:23:20.298 - info: javascript.0 (25247) script.js.common.Powerbank: registered 2 subscriptions and 1 schedule
                2021-03-08 07:23:20.299 - info: javascript.0 (25247) Start javascript script.js.common.Grid-PV
                2021-03-08 07:23:20.304 - info: javascript.0 (25247) script.js.common.Grid-PV: registered 1 subscription and 0 schedules
                2021-03-08 07:23:20.305 - info: javascript.0 (25247) Start javascript script.js.common.SMA+SE
                2021-03-08 07:23:20.311 - info: javascript.0 (25247) script.js.common.SMA+SE: registered 1 subscription and 0 schedules
                2021-03-08 07:23:20.312 - info: javascript.0 (25247) Start javascript script.js.common.Zoe_Zielladung
                2021-03-08 07:23:20.317 - info: javascript.0 (25247) script.js.common.Zoe_Zielladung: registered 1 subscription and 0 schedules
                2021-03-08 07:23:20.318 - info: javascript.0 (25247) Start javascript script.js.common.PVÜberschuss
                2021-03-08 07:23:20.323 - info: javascript.0 (25247) script.js.common.PVÜberschuss: registered 1 subscription and 0 schedules
                2021-03-08 07:23:20.324 - info: javascript.0 (25247) Start javascript script.js.common.ZOE_Ladung
                2021-03-08 07:23:20.345 - info: javascript.0 (25247) script.js.common.ZOE_Ladung: registered 5 subscriptions and 0 schedules
                2021-03-08 07:23:20.346 - info: javascript.0 (25247) Start javascript script.js.common.Garage
                2021-03-08 07:23:20.357 - info: javascript.0 (25247) script.js.common.Garage: registered 3 subscriptions and 1 schedule
                2021-03-08 07:23:20.909 - info: history.0 (25262) starting. Version 1.9.12 in /opt/iobroker/node_modules/iobroker.history, node: v12.21.0, js-controller: 3.2.16
                2021-03-08 07:23:21.017 - info: history.0 (25262) enabled logging of kecontact.0.pf (Count=1), Alias=false
                2021-03-08 07:23:21.018 - info: history.0 (25262) enabled logging of kecontact.0.p (Count=2), Alias=false
                2021-03-08 07:23:21.019 - info: history.0 (25262) enabled logging of kecontact.0.currentUser (Count=3), Alias=false
                2021-03-08 07:23:21.019 - info: history.0 (25262) enabled logging of mqtt.0.info.connection (Count=4), Alias=false
                2021-03-08 07:23:21.020 - info: history.0 (25262) enabled logging of 0_userdata.0.AMIS.170 (Count=5), Alias=false
                2021-03-08 07:23:21.021 - info: history.0 (25262) enabled logging of 0_userdata.0.AMIS.270 (Count=6), Alias=false
                2021-03-08 07:23:21.021 - info: history.0 (25262) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Switch (Count=7), Alias=false
                2021-03-08 07:23:21.022 - info: history.0 (25262) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Power (Count=8), Alias=false
                2021-03-08 07:23:21.023 - info: history.0 (25262) enabled logging of 0_userdata.0.AMIS.Power (Count=9), Alias=false
                2021-03-08 07:23:21.023 - info: history.0 (25262) enabled logging of kecontact.0.currentTimer (Count=10), Alias=false
                2021-03-08 07:23:21.024 - info: history.0 (25262) enabled logging of modbus.0.inputRegisters.30775_PVLeistung (Count=11), Alias=false
                2021-03-08 07:23:21.025 - info: history.0 (25262) enabled logging of javascript.0.Solar.Wechselrichter.PVLeistungAktuell (Count=12), Alias=false
                2021-03-08 07:23:21.026 - info: history.0 (25262) enabled logging of 0_userdata.0.AMIS.PVPower (Count=13), Alias=false
                2021-03-08 07:23:21.026 - info: history.0 (25262) enabled logging of 0_userdata.0.AMIS.PVÜberschuss (Count=14), Alias=false
                2021-03-08 07:23:21.045 - error: modbus.0 (25269) modbus.0 already running
                2021-03-08 07:23:21.049 - warn: modbus.0 (25269) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-03-08 07:23:21.631 - error: host.raspi4iobrokerpv instance system.adapter.modbus.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-03-08 07:23:21.631 - info: host.raspi4iobrokerpv Restart adapter system.adapter.modbus.0 because enabled
                2021-03-08 07:23:23.153 - info: host.raspi4iobrokerpv instance system.adapter.cloud.0 started with pid 25288
                2021-03-08 07:23:23.192 - info: host.raspi4iobrokerpv instance system.adapter.modbus.1 started with pid 25294
                2021-03-08 07:23:24.387 - error: modbus.1 (25294) modbus.1 already running
                2021-03-08 07:23:24.390 - warn: modbus.1 (25294) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-03-08 07:23:24.978 - error: host.raspi4iobrokerpv instance system.adapter.modbus.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-03-08 07:23:24.979 - info: host.raspi4iobrokerpv Restart adapter system.adapter.modbus.1 because enabled
                2021-03-08 07:23:25.214 - info: cloud.0 (25288) starting. Version 4.0.4 in /opt/iobroker/node_modules/iobroker.cloud, node: v12.21.0, js-controller: 3.2.16
                2021-03-08 07:23:25.281 - info: cloud.0 (25288) Connecting with https://iobroker.net:10555 with "richard.nussdorfer@gmail.com_65a2cba0-c435-11ea-b03c-2dda666d26a"
                2021-03-08 07:23:25.476 - info: cloud.0 (25288) Trying to connect as system.user.admin
                2021-03-08 07:23:25.837 - info: cloud.0 (25288) Adapter redirected temporally to "https://iobroker.net:10556" in one minute. Reason: command from server
                2021-03-08 07:23:25.839 - info: cloud.0 (25288) Connection changed: io client disconnect
                2021-03-08 07:23:27.035 - info: host.raspi4iobrokerpv instance scheduled system.adapter.zoe2.0 */10 * * * *
                2021-03-08 07:23:27.290 - info: host.raspi4iobrokerpv instance system.adapter.iot.0 started with pid 25314
                2021-03-08 07:23:29.392 - info: iot.0 (25314) starting. Version 1.8.13 in /opt/iobroker/node_modules/iobroker.iot, node: v12.21.0, js-controller: 3.2.16
                2021-03-08 07:23:29.452 - info: iot.0 (25314) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                2021-03-08 07:23:30.101 - info: iot.0 (25314) Connection changed: connect
                2021-03-08 07:23:31.111 - info: host.raspi4iobrokerpv instance system.adapter.info.0 started with pid 25336
                2021-03-08 07:23:32.197 - info: host.raspi4iobrokerpv instance system.adapter.telegram.0 started with pid 25351
                2021-03-08 07:23:33.268 - error: info.0 (25336) info.0 already running
                2021-03-08 07:23:33.272 - warn: info.0 (25336) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-03-08 07:23:33.855 - error: host.raspi4iobrokerpv instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-03-08 07:23:33.855 - info: host.raspi4iobrokerpv Restart adapter system.adapter.info.0 because enabled
                2021-03-08 07:23:34.340 - info: telegram.0 (25351) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.21.0, js-controller: 3.2.16
                2021-03-08 07:23:35.086 - info: host.raspi4iobrokerpv instance system.adapter.life360.0 started with pid 25370
                2021-03-08 07:23:36.629 - error: life360.0 (25370) life360.0 already running
                2021-03-08 07:23:36.631 - warn: life360.0 (25370) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-03-08 07:23:37.239 - error: host.raspi4iobrokerpv instance system.adapter.life360.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-03-08 07:23:37.239 - info: host.raspi4iobrokerpv Restart adapter system.adapter.life360.0 because enabled
                2021-03-08 07:23:37.434 - info: host.raspi4iobrokerpv instance system.adapter.backitup.0 started with pid 25381
                2021-03-08 07:23:40.972 - info: backitup.0 (25381) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.21.0, js-controller: 3.2.16
                2021-03-08 07:23:41.066 - info: backitup.0 (25381) [iobroker] backup was activated at 06:15 every 1 day(s)
                2021-03-08 07:23:43.636 - info: host.raspi4iobrokerpv instance system.adapter.shelly.0 started with pid 25403
                2021-03-08 07:23:46.147 - info: shelly.0 (25403) starting. Version 4.0.6 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.21.0, js-controller: 3.2.16
                2021-03-08 07:23:46.179 - info: shelly.0 (25403) Starting Adapter shelly.0 in version 4.0.6
                2021-03-08 07:23:46.180 - info: shelly.0 (25403) Polltime of the shelly devices: 5 sec.
                2021-03-08 07:23:46.215 - info: shelly.0 (25403) Starting Shelly adapter in CoAP modus.
                2021-03-08 07:23:46.318 - info: shelly.0 (25403) Listening for Shelly packets in the network
                2021-03-08 07:23:46.863 - info: host.raspi4iobrokerpv instance system.adapter.vis-inventwo.0 started with pid 25418
                2021-03-08 07:23:48.208 - info: vis-inventwo.0 (25418) starting. Version 2.7.10 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v12.21.0, js-controller: 3.2.16
                2021-03-08 07:23:51.669 - info: host.raspi4iobrokerpv instance system.adapter.modbus.0 started with pid 25436
                2021-03-08 07:23:53.223 - info: modbus.0 (25436) starting. Version 3.2.4 in /opt/iobroker/node_modules/iobroker.modbus, node: v12.21.0, js-controller: 3.2.16
                2021-03-08 07:23:53.750 - info: modbus.0 (25436) Connected to slave 192.168.0.9
                2021-03-08 07:23:55.000 - info: host.raspi4iobrokerpv instance system.adapter.modbus.1 started with pid 25455
                2021-03-08 07:23:56.569 - info: modbus.1 (25455) starting. Version 3.2.4 in /opt/iobroker/node_modules/iobroker.modbus, node: v12.21.0, js-controller: 3.2.16
                2021-03-08 07:23:57.222 - info: modbus.1 (25455) Connected to slave 192.168.0.98
                2021-03-08 07:23:59.816 - info: shelly.0 (25403) Shelly device 192.168.0.80 (shellyplug-s / shellyplug-s-EED8F9 / SHPLG-S#EED8F9#1) with CoAP connected!
                das Script Amis das zu Anfang steht:
                const idJson = 'mqtt.0.AMIS';
                const id180 = '0_userdata.0.AMIS.180';
                const id280 = '0_userdata.0.AMIS.280';
                const id381 = '0_userdata.0.AMIS.381';
                const id481 = '0_userdata.0.AMIS.481';
                const id170 = '0_userdata.0.AMIS.170';
                const id270 = '0_userdata.0.AMIS.270';
                const id370 = '0_userdata.0.AMIS.370';
                const id470 = '0_userdata.0.AMIS.470';
                const id11280 = '0_userdata.0.AMIS.11280';
                on(idJson, function(dp) {
                   let obj = JSON.parse(dp.state.val);
                   setState(id180, obj['1.8.0']/1000, true);
                   setState(id280, obj['2.8.0']/1000, true);
                   setState(id381, obj['3.8.1']/1000, true);
                   setState(id481, obj['4.8.1']/1000, true);
                   setState(id170, obj['1.7.0'], true);
                   setState(id270, obj['2.7.0'], true);
                   setState(id370, obj['3.7.0'], true);
                   setState(id470, obj['4.7.0'], true);
                   setState(id11280, obj['1.128.0'], true);
                vor 7:21 hat der Adapter Zoe2 seine Abfragen gemacht, wie immer.
                2021-03-08 07:20:03.853 - info: zoe2.0 (23557) getBatteryStatus-url:https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/45bacb45-017d-42f7-8bee-96edb6ceec2d/kamereon/kca/car-adapter/v2/cars/VF1AGxxxxxx/battery-status?country=DE
                2021-03-08 07:20:04.924 - info: zoe2.0 (23557) getBatteryStatus:{"data":{"type":"Car","id":"VF1AG00xxxxxxxx","attributes":{"timestamp":"2021-03-08T06:19:36Z","batteryLevel":100,"batteryTemperature":20,"batteryAutonomy":311,"batteryCapacity":0,"batteryAvailableEnergy":52,"plugStatus":0,"chargingStatus":0,"chargingRemainingTime":15,"chargingInstantaneousPower":0}}}
                2021-03-08 07:20:04.934 - info: zoe2.0 (23557) getCockpit-url:https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/45bacb45-017d-42f7-8bee-96edb6ceec2d/kamereon/kca/car-adapter/v2/cars/VF1AGxxxxx/cockpit?country=DE
                2021-03-08 07:20:05.996 - info: zoe2.0 (23557) getCockpit:{"data":{"type":"Car","id":"VF1AG0009xxxxxx","attributes":{"fuelAutonomy":0,"fuelQuantity":0,"totalMileage":xxxx}}}
                2021-03-08 07:20:05.997 - info: zoe2.0 (23557) getLocation-url:https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/45bacb45-017d-42f7-8bee-96edb6ceec2d/kamereon/kca/car-adapter/v1/cars/VF1AGxxxxxxxx/location?country=DE
                2021-03-08 07:20:07.017 - info: zoe2.0 (23557) getLocation:{"data":{"type":"Car","id":"VF1AG000xxxxxx","attributes":{"gpsLatitude":48.xxx,"gpsLongitude":14.xxx,"lastUpdateTime":"2021-03-04T12:47:53Z"}}}
                2021-03-08 07:20:07.018 - info: zoe2.0 (23557) gpsLatitude:48.xxxx
                2021-03-08 07:20:07.019 - info: zoe2.0 (23557) gpsLongitude:14.xxxx
                2021-03-08 07:20:07.020 - info: zoe2.0 (23557) getHVACStatus not enabled in config
                2021-03-08 07:20:17.027 - info: zoe2.0 (23557) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2021-03-08 07:20:17.588 - info: host.raspi4iobrokerpv instance system.adapter.zoe2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                danach war 1:30min nichts und dann siehe oben.
                dh. ich kann aus dem Log nichts erkennen, was in den 1:30 Min passiert ist und warum er angefangen hat einen Restart zu starten, begonnen mit dem Stop der Scripten.
                Kann es sein.... dass durch die unsaubere Terminiation des Zoe2 Adapter, der Speicher den für seine Abarbeitung belegt, nicht wieder frei gibt.
                Gibt es eine Möglichkei am Raspi ein Speicheraufzeichnungstool laufen zu lassen, dass die Verbraucher erkennt?
                um 6:00 sehe ich noch warnings.
                2021-03-08 06:01:46.210 - warn: javascript.0 (647) You are assigning a object to the state "javascript.0.Sonne.Sonnenaufgang" which expects a string. Please fix your code to use a string or change the state type to object. This warning might become an error in future versions.
                2021-03-08 06:01:46.215 - warn: javascript.0 (647) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1358:20)
                2021-03-08 06:01:46.215 - warn: javascript.0 (647) at Object. (script.js.common.Powerbank:42:3)
                2021-03-08 06:01:46.215 - warn: javascript.0 (647) at Object. (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1249:34)
                2021-03-08 06:01:46.216 - warn: javascript.0 (647) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                2021-03-08 06:01:46.216 - warn: javascript.0 (647) at listOnTimeout (internal/timers.js:554:17)
                2021-03-08 06:01:46.216 - warn: javascript.0 (647) at processTimers (internal/timers.js:497:7)
                2021-03-08 06:01:46.216 - info: javascript.0 (647) script.js.common.Powerbank: Mon Mar 08 2021 06:32:49 GMT+0100 (GMT+01:00)
                2021-03-08 06:01:46.216 - warn: javascript.0 (647) You are assigning a object to the state "javascript.0.Sonne.Sonnenuntergang" which expects a string. Please fix your code to use a string or change the state type to object. This warning might become an error in future versions.
                2021-03-08 06:01:46.217 - warn: javascript.0 (647) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1358:20)
                2021-03-08 06:01:46.218 - warn: javascript.0 (647) at Object. (script.js.common.Powerbank:44:3)
                2021-03-08 06:01:46.218 - warn: javascript.0 (647) at Object. (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1249:34)
                2021-03-08 06:01:46.218 - warn: javascript.0 (647) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                2021-03-08 06:01:46.218 - warn: javascript.0 (647) at listOnTimeout (internal/timers.js:554:17)
                2021-03-08 06:01:46.218 - warn: javascript.0 (647) at processTimers (internal/timers.js:497:7)
                2021-03-08 06:01:46.218 - info: javascript.0 (647) script.js.common.Powerbank: Mon Mar 08 2021 17:59:25 GMT+0100 (GMT+01:00)
                2021-03-08 06:10:00.006 - info: javascript.0 (647) script.js.common.Sonnenstand: Script Sonnenstand; Erfolgreich gelaufen, Werte akzeptiert
                2021-03-08 06:10:00.110 - info: host.raspi4iobrokerpv instance system.adapter.zoe2.0 started with pid 22827
                wenn ich richtig liege, passt ihm das da nicht:
                vor ca. 1 Std. die Script Engine upgedatet
                gerade wieder einen Hänger gehabt:
                cloud.0	2021-03-08 14:05:32.090	info	(25288) Connection changed: connect
                cloud.0	2021-03-08 14:05:31.693	info	(25288) Trying to connect as system.user.admin
                modbus.0	2021-03-08 14:05:12.551	info	(25436) Connected to slave 192.168.0.9
                modbus.1	2021-03-08 14:04:43.347	info	(25455) Connected to slave 192.168.0.98
                javascript.0	2021-03-08 14:04:43.158	info	(7815) script.js.common.Powerbank: Powerbank Ladung begonnen
                mqtt.0	2021-03-08 14:04:40.073	info	(6707) Client [AMIS] connected with secret 1615208680072_5666
                cloud.0	2021-03-08 14:04:31.676	info	(25288) Connection lost
                cloud.0	2021-03-08 14:04:31.676	info	(25288) Connection changed: Ping timeout
                cloud.0	2021-03-08 14:04:31.674	error	(25288) Ping timeout
                shelly.0	2021-03-08 14:04:27.283	error	(25403) Error in function state.coap.http_cmd for state SHPLG-S#EED8F9#1.Relay0.Switch and request{"url":"http://192.168.0.80/relay/0","timeout":5000,"qs":{"turn":"off","timer":0}} for 192.168.0.80 (
                mqtt.0	2021-03-08 14:04:25.027	info	(6707) Client [H,] connection closed: timeout
                shelly.0	2021-03-08 14:04:17.108	error	(25403) Error in function state.coap.http_cmd for state SHPLG-S#EED8F9#1.Relay0.Switch and request{"url":"http://192.168.0.80/relay/0","timeout":5000,"qs":{"turn":"off","timer":0}} for 192.168.0.80 (
                kecontact.0	2021-03-08 14:04:15.441	warn	(25154) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                kecontact.0	2021-03-08 14:04:15.140	warn	(25154) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                kecontact.0	2021-03-08 14:04:14.840	warn	(25154) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                life360.0	2021-03-08 14:04:14.804	warn	(25612) No data received from Life360 cloud services!
                life360.0	2021-03-08 14:04:14.791	error	(25612) Failed to retrieve members: Error: getaddrinfo EAI_AGAIN www.life360.com
                kecontact.0	2021-03-08 14:04:14.539	warn	(25154) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                kecontact.0	2021-03-08 14:04:14.239	warn	(25154) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                kecontact.0	2021-03-08 14:04:13.939	warn	(25154) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                kecontact.0	2021-03-08 14:04:13.639	warn	(25154) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                modbus.1	2021-03-08 14:04:13.141	info	(25455) Disconnected from slave 192.168.0.98
                modbus.0	2021-03-08 14:04:12.530	info	(25436) Disconnected from slave 192.168.0.9
                modbus.1	2021-03-08 14:04:12.140	warn	(25455) Poll error count: 1 code: {"err":"timeout","timeout":5000}
                modbus.1	2021-03-08 14:04:12.139	error	(25455) Client in error state.
                modbus.1	2021-03-08 14:04:12.137	error	(25455) Request timed out.
                modbus.1	2021-03-08 14:04:12.136	warn	(25455) Error: undefined
                modbus.0	2021-03-08 14:04:11.531	warn	(25436) Poll error count: 1 code: {"err":"timeout","timeout":5000}
                modbus.0	2021-03-08 14:04:11.529	error	(25436) Client in error state.
                modbus.0	2021-03-08 14:04:11.527	error	(25436) Request timed out.
                modbus.0	2021-03-08 14:04:11.525	warn	(25436) Error: undefined
                und aktuell wieder nicht erreichbar......???
                auch der Raspi ist nicht erreichbar
                jetzt wieder gekommen...
                [351956.430278] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
                [370209.514102] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
                [370209.514156] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                javascript.0	2021-03-08 14:14:52.987	info	(7815) script.js.common.Powerbank: Powerbank Ladung beendet
                cloud.0	2021-03-08 14:14:21.086	info	(10508) Connection changed: io client disconnect
                cloud.0	2021-03-08 14:14:21.083	info	(10508) Adapter redirected temporally to "https://iobroker.net:10556" in one minute. Reason: command from server
                cloud.0	2021-03-08 14:14:20.664	info	(10508) Trying to connect as system.user.admin
                life360.0	2021-03-08 14:14:10.699	info	(25612) Connected to Life360 cloud services.
                modbus.0	2021-03-08 14:14:00.462	info	(25436) Connected to slave 192.168.0.9
                iot.0	2021-03-08 14:13:51.498	info	(25314) Connection changed: connect
                modbus.1	2021-03-08 14:13:50.130	info	(25455) Connected to slave 192.168.0.98
                mqtt.0	2021-03-08 14:13:49.818	info	(6707) Client [H,] connected with secret 1615209229816_7093
                life360.0	2021-03-08 14:13:49.804	warn	(25612) No data received from Life360 cloud services!
                life360.0	2021-03-08 14:13:49.803	error	(25612) Error: Error: Unable to connect: Error: getaddrinfo EAI_AGAIN www.life360.com
                life360.0	2021-03-08 14:13:49.801	info	(25612) Waiting for online operations to finish ...
                iot.0	2021-03-08 14:13:45.886	info	(25314) Connection changed: disconnect
                iot.0	2021-03-08 14:13:45.885	error	(25314) Error by device connection: "premature close"
                cloud.0	2021-03-08 14:13:30.666	error	(10508) Error while connecting to cloud: Error: websocket error
                life360.0	2021-03-08 14:13:29.811	warn	(25612) No data received from Life360 cloud services!
                life360.0	2021-03-08 14:13:29.810	error	(25612) Error: Error: Unable to connect: Error: getaddrinfo EAI_AGAIN www.life360.com
                life360.0	2021-03-08 14:13:29.808	info	(25612) Waiting for online operations to finish ...
                cloud.0	2021-03-08 14:13:20.671	info	(10508) Trying to connect as system.user.admin
                modbus.1	2021-03-08 14:13:19.127	warn	(25455) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
                modbus.1	2021-03-08 14:13:19.126	error	(25455) Client in error state.
                modbus.1	2021-03-08 14:13:19.125	error	(25455) Socket Error
                iot.0	2021-03-08 14:13:15.873	info	(25314) Connection changed: disconnect
                iot.0	2021-03-08 14:13:15.873	warn	(25314) Looks like your connection certificates are invalid. Please renew them via configuration dialog.
                iot.0	2021-03-08 14:13:15.872	error	(25314) Error by device connection: "premature close"
                iot.0	2021-03-08 14:13:15.853	info	(25314) Connection changed: disconnect
                iot.0	2021-03-08 14:13:15.852	error	(25314) Error by device connection: "premature close"
                iot.0	2021-03-08 14:13:05.841	info	(25314) Connection changed: disconnect
                iot.0	2021-03-08 14:13:05.841	error	(25314) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
                iot.0	2021-03-08 14:13:05.840	error	(25314) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
                iot.0	2021-03-08 14:13:05.839	error	(25314) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
                iot.0	2021-03-08 14:13:05.838	error	(25314) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
                life360.0	2021-03-08 14:12:59.810	warn	(25612) No data received from Life360 cloud services!
                life360.0	2021-03-08 14:12:59.809	error	(25612) Error: Error: Unable to connect: Error: getaddrinfo EAI_AGAIN www.life360.com
                life360.0	2021-03-08 14:12:59.807	info	(25612) Waiting for online operations to finish ...
                modbus.0	2021-03-08 14:12:59.447	warn	(25436) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.9","port":502}
                modbus.0	2021-03-08 14:12:59.446	error	(25436) Client in error state.
                modbus.0	2021-03-08 14:12:59.445	error	(25436) Socket Error
                modbus.1	2021-03-08 14:12:44.967	warn	(25455) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
                modbus.1	2021-03-08 14:12:44.966	error	(25455) Client in error state.
                modbus.1	2021-03-08 14:12:44.966	error	(25455) Socket Error
                iot.0	2021-03-08 14:12:40.813	info	(25314) Connection changed: disconnect
                iot.0	2021-03-08 14:12:40.812	error	(25314) Error by device connection: "premature close"
                cloud.0	2021-03-08 14:12:30.664	error	(10508) Error while connecting to cloud: Error: websocket error
                life360.0	2021-03-08 14:12:29.810	warn	(25612) No data received from Life360 cloud services!
                life360.0	2021-03-08 14:12:29.809	error	(25612) Error: Error: Unable to connect: Error: getaddrinfo EAI_AGAIN www.life360.com
                life360.0	2021-03-08 14:12:29.807	info	(25612) Waiting for online operations to finish ...
                cloud.0	2021-03-08 14:12:20.674	info	(10508) Trying to connect as system.user.admin
                modbus.1	2021-03-08 14:12:10.817	warn	(25455) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
                modbus.1	2021-03-08 14:12:10.816	error	(25455) Client in error state.
                modbus.1	2021-03-08 14:12:10.816	error	(25455) Socket Error
                iot.0	2021-03-08 14:12:10.800	info	(25314) Connection changed: disconnect
                iot.0	2021-03-08 14:12:10.800	warn	(25314) Looks like your connection certificates are invalid. Please renew them via configuration dialog.
                iot.0	2021-03-08 14:12:10.799	error	(25314) Error by device connection: "premature close"
                iot.0	2021-03-08 14:12:10.779	info	(25314) Connection changed: disconnect
                iot.0	2021-03-08 14:12:10.778	error	(25314) Error by device connection: "premature close"
                iot.0	2021-03-08 14:12:00.769	info	(25314) Connection changed: disconnect
                iot.0	2021-03-08 14:12:00.768	error	(25314) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
                iot.0	2021-03-08 14:12:00.768	error	(25314) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
                iot.0	2021-03-08 14:12:00.766	error	(25314) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
                iot.0	2021-03-08 14:12:00.765	error	(25314) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
                life360.0	2021-03-08 14:11:59.808	warn	(25612) No data received from Life360 cloud services!
                life360.0	2021-03-08 14:11:59.807	error	(25612) Error: Error: Unable to connect: Error: getaddrinfo EAI_AGAIN www.life360.com
                life360.0	2021-03-08 14:11:59.805	info	(25612) Waiting for online operations to finish ...
                modbus.0	2021-03-08 14:11:55.287	warn	(25436) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.9","port":502}
                modbus.0	2021-03-08 14:11:55.286	error	(25436) Client in error state.
                modbus.0	2021-03-08 14:11:55.286	error	(25436) Socket Error
                modbus.1	2021-03-08 14:11:36.647	warn	(25455) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
                modbus.1	2021-03-08 14:11:36.647	error	(25455) Client in error state.
                modbus.1	2021-03-08 14:11:36.646	error	(25455) Socket Error
                iot.0	2021-03-08 14:11:35.740	info	(25314) Connection changed: disconnect
                iot.0	2021-03-08 14:11:35.739	error	(25314) Error by device connection: "premature close"
                cloud.0	2021-03-08 14:11:30.664	error	(10508) Error while connecting to cloud: Error: websocket error
                life360.0	2021-03-08 14:11:29.803	warn	(25612) No data received from Life360 cloud services!
                life360.0	2021-03-08 14:11:29.802	error	(25612) Error: Error: Unable to connect: Error: getaddrinfo EAI_AGAIN www.life360.com
                life360.0	2021-03-08 14:11:29.798	info	(25612) Waiting for online operations to finish ...
                cloud.0	2021-03-08 14:11:20.675	info	(10508) Trying to connect as system.user.admin
                iot.0	2021-03-08 14:11:05.728	info	(25314) Connection changed: disconnect
                iot.0	2021-03-08 14:11:05.727	warn	(25314) Looks like your connection certificates are invalid. Please renew them via configuration dialog.
                iot.0	2021-03-08 14:11:05.726	error	(25314) Error by device connection: "premature close"
                iot.0	2021-03-08 14:11:05.713	info	(25314) Connection changed: disconnect
                iot.0	2021-03-08 14:11:05.712	error	(25314) Error by device connection: "premature close"
                modbus.1	2021-03-08 14:11:02.487	warn	(25455) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
                modbus.1	2021-03-08 14:11:02.486	error	(25455) Client in error state.
                modbus.1	2021-03-08 14:11:02.486	error	(25455) Socket Error
                life360.0	2021-03-08 14:10:59.808	warn	(25612) No data received from Life360 cloud services!
                life360.0	2021-03-08 14:10:59.807	error	(25612) Error: Error: Unable to connect: Error: getaddrinfo EAI_AGAIN www.life360.com
                life360.0	2021-03-08 14:10:59.804	info	(25612) Waiting for online operations to finish ...
                iot.0	2021-03-08 14:10:55.684	info	(25314) Connection changed: disconnect
                iot.0	2021-03-08 14:10:55.683	error	(25314) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
                iot.0	2021-03-08 14:10:55.679	error	(25314) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
                iot.0	2021-03-08 14:10:55.677	error	(25314) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
                iot.0	2021-03-08 14:10:55.676	error	(25314) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
                modbus.0	2021-03-08 14:10:51.127	warn	(25436) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.9","port":502}
                modbus.0	2021-03-08 14:10:51.126	error	(25436) Client in error state.
                modbus.0	2021-03-08 14:10:51.125	error	(25436) Socket Error
                cloud.0	2021-03-08 14:10:30.669	error	(10508) Error while connecting to cloud: Error: websocket error
                iot.0	2021-03-08 14:10:30.653	info	(25314) Connection lost
                iot.0	2021-03-08 14:10:30.652	info	(25314) Connection changed: disconnect
                iot.0	2021-03-08 14:10:30.649	error	(25314) Error by device connection: "premature close"
                life360.0	2021-03-08 14:10:29.818	warn	(25612) No data received from Life360 cloud services!
                life360.0	2021-03-08 14:10:29.817	error	(25612) Error: Error: Unable to connect: Error: getaddrinfo EAI_AGAIN www.life360.com
                life360.0	2021-03-08 14:10:29.814	info	(25612) Waiting for online operations to finish ...
                life360.0	2021-03-08 14:10:29.807	info	(25612) Disconnected from Life360 cloud services.
                modbus.1	2021-03-08 14:10:28.327	warn	(25455) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
                modbus.1	2021-03-08 14:10:28.327	error	(25455) Client in error state.
                modbus.1	2021-03-08 14:10:28.326	error	(25455) Socket Error
                host.raspi4iobrokerpv	2021-03-08 14:10:22.273	error	instance system.adapter.zoe2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                zoe2.0	2021-03-08 14:10:21.693	warn	(10525) Terminated (JS_CONTROLLER_STOPPED): Without reason
                zoe2.0	2021-03-08 14:10:21.690	error	(10525) No valid response from Renault server
                cloud.0	2021-03-08 14:10:20.683	info	(10508) Trying to connect as system.user.admin
                zoe2.0	2021-03-08 14:10:01.603	info	(10525) URL: https://renault-wrd-prod-1-euw1-myrapp-one.s3-eu-west-1.amazonaws.com/configuration/android/config_de_DE.json
                zoe2.0	2021-03-08 14:10:01.603	info	(10525) ignoreApiError:true
                zoe2.0	2021-03-08 14:10:01.602	info	(10525) Country:DE
                zoe2.0	2021-03-08 14:10:01.602	info	(10525) VIN:VF1AG000966808321
                zoe2.0	2021-03-08 14:10:01.602	info	(10525) Locale:de_DE
                zoe2.0	2021-03-08 14:10:01.601	info	(10525) Username:richard.nussdorfer@gmail.com
                zoe2.0	2021-03-08 14:10:01.568	info	(10525) starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.zoe2, node: v12.21.0, js-controller: 3.2.16
                host.raspi4iobrokerpv	2021-03-08 14:10:00.079	info	instance system.adapter.zoe2.0 started with pid 10525
                life360.0	2021-03-08 14:09:59.806	warn	(25612) No data received from Life360 cloud services!
                life360.0	2021-03-08 14:09:59.804	error	(25612) Failed to retrieve members: Error: getaddrinfo EAI_AGAIN www.life360.com
                modbus.1	2021-03-08 14:09:54.167	warn	(25455) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
                modbus.1	2021-03-08 14:09:54.166	error	(25455) Client in error state.
                modbus.1	2021-03-08 14:09:54.165	error	(25455) Socket Error
                modbus.0	2021-03-08 14:09:46.969	warn	(25436) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.9","port":502}
                modbus.0	2021-03-08 14:09:46.968	error	(25436) Client in error state.
                modbus.0	2021-03-08 14:09:46.967	error	(25436) Socket Error
                cloud.0	2021-03-08 14:09:30.787	error	(10508) Error while connecting to cloud: Error: websocket error
                life360.0	2021-03-08 14:09:29.806	warn	(25612) No data received from Life360 cloud services!
                life360.0	2021-03-08 14:09:29.804	error	(25612) Failed to retrieve members: Error: getaddrinfo EAI_AGAIN www.life360.com
                cloud.0	2021-03-08 14:09:20.794	info	(10508) Trying to connect as system.user.admin
                cloud.0	2021-03-08 14:09:20.642	info	(10508) Connecting with https://iobroker.net:10555 with "richard.nussdorfer@gmail.com_65a2cba0-c435-11ea-b03c-2dda666d26a"
                cloud.0	2021-03-08 14:09:20.573	info	(10508) starting. Version 4.0.4 in /opt/iobroker/node_modules/iobroker.cloud, node: v12.21.0, js-controller: 3.2.16
                modbus.1	2021-03-08 14:09:20.007	warn	(25455) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
                modbus.1	2021-03-08 14:09:20.007	error	(25455) Client in error state.
                modbus.1	2021-03-08 14:09:20.006	error	(25455) Socket Error
                host.raspi4iobrokerpv	2021-03-08 14:09:18.837	info	instance system.adapter.cloud.0 started with pid 10508
                host.raspi4iobrokerpv	2021-03-08 14:09:17.766	info	Restart adapter system.adapter.cloud.0 because enabled
                host.raspi4iobrokerpv	2021-03-08 14:09:17.760	info	instance system.adapter.cloud.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                cloud.0	2021-03-08 14:09:17.643	info	(25288) Connection changed: io client disconnect
                cloud.0	2021-03-08 14:09:17.105	warn	(25288) Terminated (-100): Without reason
                cloud.0	2021-03-08 14:09:07.100	info	(25288) Restart adapter by disconnect
                cloud.0	2021-03-08 14:09:07.099	info	(25288) Connection lost
                cloud.0	2021-03-08 14:09:07.098	info	(25288) Connection changed: Ping timeout
                cloud.0	2021-03-08 14:09:07.097	error	(25288) Ping timeout
                life360.0	2021-03-08 14:08:59.806	warn	(25612) No data received from Life360 cloud services!
                life360.0	2021-03-08 14:08:59.804	error	(25612) Failed to retrieve members: Error: getaddrinfo EAI_AGAIN www.life360.com
                mqtt.0	2021-03-08 14:08:59.598	info	(6707) Client [AMIS] connection closed: timeout
                shelly.0	2021-03-08 14:08:48.562	error	(25403) Error in function state.coap.http_cmd for state SHPLG-S#EED8F9#1.Relay0.Switch and request{"url":"http://192.168.0.80/relay/0","timeout":5000,"qs":{"turn":"off","timer":0}} for 192.168.0.80 (
                modbus.1	2021-03-08 14:08:46.846	info	(25455) Disconnected from slave 192.168.0.98
                modbus.1	2021-03-08 14:08:45.847	warn	(25455) Poll error count: 1 code: {"err":"timeout","timeout":5000}
                modbus.1	2021-03-08 14:08:45.846	error	(25455) Client in error state.
                modbus.1	2021-03-08 14:08:45.845	error	(25455) Request timed out.
                modbus.1	2021-03-08 14:08:45.844	warn	(25455) Error: undefined
                modbus.0	2021-03-08 14:08:43.870	info	(25436) Disconnected from slave 192.168.0.9
                modbus.0	2021-03-08 14:08:42.870	warn	(25436) Poll error count: 1 code: {"err":"timeout","timeout":5000}
                modbus.0	2021-03-08 14:08:42.869	error	(25436) Client in error state.
                modbus.0	2021-03-08 14:08:42.868	error	(25436) Request timed out.
                modbus.0	2021-03-08 14:08:42.867	warn	(25436) Error: undefined
                habe jetzt von Wlan auf Lan umgestellt, mal sehen.
                BG
                • HumidorH Humidor
                  @wendy2702
                  [345505.635793] [   8166]  1001  8166    41727    15868   630784      956             0 node
                  [345505.635801] [   8235]  1001  8235    46083    18920   688128     2818             0 node
                  [345505.635812] [  23574]  1001 23574    23902     8644   323584        0             0 node
                  [345505.635820] [  23580]  1001 23580    23470     8227   278528        0             0 node
                  [345505.635828] [  23581]  1001 23581    26482    10632   397312        0             0 node
                  [345505.635836] [  23584]  1001 23584    25555     9702   409600        0             0 node
                  [345505.635844] [  23589]  1001 23589    23472     8339   286720        0             0 node
                  [345505.635851] [  23596]  1001 23596    26403    10701   389120        0             0 node
                  [345505.635859] [  23598]  1001 23598    25542     9875   413696        0             0 node
                  [345505.635867] [  23612]  1001 23612    23472     8289   286720        0             0 node
                  [345505.635875] [  23615]  1001 23615    26409    10609   385024        0             0 node
                  [345505.635882] [  23622]  1001 23622    25475     9904   397312        0             0 node
                  [345505.635891] [  23623]  1001 23623    23470     8272   290816        0             0 node
                  [345505.635899] [  23636]  1001 23636    26549    10686   405504        0             0 node
                  [345505.635907] [  23644]  1001 23644    25602     9727   413696        0             0 node
                  [345505.635914] [  23651]  1001 23651    23476     8336   294912        0             0 node
                  [345505.635922] [  23658]  1001 23658    26479    10664   393216        0             0 node
                  [345505.635931] [  23659]  1001 23659    23840     8646   315392        0             0 node
                  [345505.635938] [  23667]  1001 23667    23472     8293   286720        0             0 node
                  [345505.635946] [  23678]  1001 23678    26384    10433   385024        0             0 node
                  [345505.635954] [  23686]  1001 23686    23915     8548   339968        0             0 node
                  [345505.635962] [  23693]  1001 23693    23609     8151   294912        0             0 node
                  [345505.635970] [  23695]  1001 23695    26437    10479   401408        0             0 node
                  [345505.635977] [  23708]  1001 23708    23906     8675   327680        0             0 node
                  [345505.635985] [  23713]  1001 23713    23539     8017   294912        0             0 node
                  [345505.635993] [  23715]  1001 23715    26374    10438   389120        0             0 node
                  [345505.636000] [  23723]  1001 23723    23866     8570   335872        0             0 node
                  [345505.636008] [  23738]  1001 23738    23613     8189   294912        0             0 node
                  [345505.636016] [  23741]  1001 23741    26437    10546   385024        0             0 node
                  [345505.636024] [  23747]  1001 23747    23866     8622   344064        0             0 node
                  [345505.636031] [  23753]  1001 23753    23543     8188   286720        0             0 node
                  [345505.636039] [  23759]  1001 23759    26446    10512   393216        0             0 node
                  [345505.636047] [  23765]  1001 23765    27376    11680   409600        0             0 node
                  [345505.636055] [  23770]  1001 23770    23548     8178   290816        0             0 node
                  [345505.636063] [  23777]  1001 23777    25288    10388   323584        0             0 node
                  [345505.636071] [  23789]  1001 23789    26880    10781   405504        0             0 node
                  [345505.636079] [  23798]  1001 23798    23534     8158   290816        0             0 node
                  [345505.636087] [  23801]  1001 23801    26388    10470   385024        0             0 node
                  [345505.636094] [  23806]  1001 23806    26848    10794   417792        0             0 node
                  [345505.636103] [  23815]  1001 23815    23564     8179   286720        0             0 node
                  [345505.636110] [  23824]  1001 23824    24476     8854   299008        0             0 node
                  [345505.636118] [  23827]  1001 23827    27438    11615   409600        0             0 node
                  [345505.636126] [  23836]  1001 23836    23543     8202   299008        0             0 node
                  [345505.636134] [  23851]  1001 23851    24299     8430   290816        0             0 node
                  [345505.636142] [  23852]  1001 23852    25140     9299   294912        0             0 node
                  [345505.636217] [  23853]  1001 23853    23600     8004   299008        0             0 node
                  [345505.636225] [  23860]  1001 23860    24402     8633   299008        0             0 node
                  [345505.636236] [  23871]  1001 23871    25142     9106   303104        0             0 node
                  [345505.636245] [  23882]  1001 23882    23547     8269   294912        0             0 node
                  [345505.636255] [  23883]  1001 23883    23647     8149   258048        0             0 node
                  [345505.636264] [  23889]  1001 23889    24905     8888   290816        0             0 node
                  [345505.636273] [  23897]  1001 23897    22772     7063   233472        0             0 node
                  [345505.636282] [  23909]  1001 23909    24481     9077   299008        0             0 node
                  [345505.636290] [  23915]  1001 23915    24227     8542   253952        0             0 node
                  [345505.636298] [  23923]  1001 23923    22777     7103   233472        0             0 node
                  [345505.636306] [  23925]  1001 23925    23586     7951   241664        0             0 node
                  [345505.636314] [  23931]  1001 23931    23121     6682   241664        0             0 node
                  [345505.636323] [  23935]  1001 23935    23570     8201   290816        0             0 node
                  [345505.636330] [  23945]  1001 23945    22021     6155   221184        0             0 node
                  [345505.636338] [  23946]  1001 23946    24163     8207   245760        0             0 node
                  [345505.636346] [  23958]  1001 23958    21598     6038   196608        0             0 node
                  [345505.636354] [  23976]  1001 23976    22079     6169   221184        0             0 node
                  [345505.636362] [  23978]  1001 23978    24232     8600   253952        0             0 node
                  [345505.636369] [  23979]  1001 23979    23482     7498   282624        0             0 node
                  [345505.636377] [  23986]  1001 23986    22113     5990   221184        0             0 node
                  [345505.636384] [  23990]  1001 23990    21662     6052   200704        0             0 node
                  [345505.636392] [  24007]  1001 24007    22777     6915   245760        0             0 node
                  [345505.636400] [  24015]  1001 24015    21618     6018   188416        0             0 node
                  [345505.636408] [  24027]  1001 24027    21598     6020   196608        0             0 node
                  [345505.636415] [  24029]  1001 24029    21564     5875   192512        0             0 node
                  [345505.636423] [  24036]  1001 24036    21598     6019   196608        0             0 node
                  [345505.636431] [  24042]  1001 24042    21586     6004   200704        0             0 node
                  [345505.636439] [  24054]  1001 24054    22084     6344   225280        0             0 node
                  [345505.636447] [  24061]  1001 24061    21598     6016   200704        0             0 node
                  [345505.636455] [  24068]  1001 24068    21478     5844   196608        0             0 node
                  [345505.636463] [  24081]  1001 24081    21500     5875   192512        0             0 node
                  [345505.636471] [  24084]  1001 24084    21500     5971   188416        0             0 node
                  [345505.636478] [  24086]  1001 24086    21564     5944   196608        0             0 node
                  [345505.636486] [  24094]  1001 24094    21409     5688   188416        0             0 node
                  [345505.636494] [  24105]  1001 24105    21474     5872   188416        0             0 node
                  [345505.636502] [  24106]  1001 24106    21153     5526   176128        0             0 node
                  [345505.636510] [  24107]  1001 24107    21410     5812   184320        0             0 node
                  [345505.636518] [  24119]  1001 24119    21410     5751   192512        0             0 node
                  [345505.636526] [  24132]  1001 24132    20344     5231   151552        0             0 node
                  [345505.636533] [  24137]  1001 24137    20836     5375   176128        0             0 node
                  [345505.636541] [  24139]  1001 24139    20059     4794   159744        0             0 node
                  [345505.636549] [  24146]  1001 24146    20059     4748   155648        0             0 node
                  [345505.636557] [  24152]  1001 24152     8597      137    32768        0             0 node
                  [345505.636566] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/,task=node,pid=539,uid=1001
                  [345505.636647] Out of memory: Killed process 539 (node) total-vm:295496kB, anon-rss:108868kB, file-rss:25144kB, shmem-rss:0kB, UID:1001 pgtables:1052kB oom_score_adj:0
                  [345505.753989] oom_reaper: reaped process 539 (node), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
                  [345608.547443] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
                  [345608.547493] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
                  wendy2702W Online
                  wendy2702W Online
                  @humidor
                  Haettest ja zum testen auch mal ein Script nach dem anderen Stoppen koennen.
                  Aber mal abwarten was die Umstellung gebracht hat.
                  HumidorH 1 Antwort Letzte Antwort
                    @humidor
                    HumidorH Online
                    HumidorH Online
                    Humidor
                    @wendy2702 einzelne Scripte stoppen und undefinierte Zeit warten, ob was oder auch nicht passiert, sry aber das ist keine adäquate Herangehensweise. Da muss es doch bessere Instrumente geben.
                    Seit der Umstellung auf Lan ist er in keinen Fehler und Restart gelaufen.
                    BG
                    • HumidorH Online
                      HumidorH Online
                      Humidor
                      @wendy2702 was weiß ich besser ?
                      BG
                      • HumidorH Humidor
                        wendy2702W Online
                        wendy2702W Online
                        @humidor das scripte stoppen nicht die richtige oder keine gute Idee ist.
                          HumidorH Online
                          HumidorH Online
                          Humidor
                          @wendy2702 das habe ich nicht gesagt!
                          BG
                          • HumidorH Humidor
                            wendy2702W Online
                            wendy2702W Online
                            @humidor sagte in (?) ioBroker Restart ?:
                            Na, das liest sich für mich aber schon so.
                            Wenn du meinst es sei keine geeignete Herangehensweise einzelne mögliche Fehler Quellen vorübergehend durch deaktivieren zu beseitigen, klingt es für mich leider so als ob du es besser wüsstest.
                            HumidorH 2 Antworten Letzte Antwort
                            • wendy2702W wendy2702
                              HumidorH Online
                              HumidorH Online
                              Humidor
                              @wendy2702 Nein, ich bin der Meinung, dass es dazu (hoffentlich) eine bessere Herangehensweise gibt, scheint aber nicht so zu sein.
                              Egal, ich habe keine Scripte (Blockly) die einen Speicherverbrauch verursachen. Trigger und Cronjobs. Und kein Cronjobs die nicht beendet werden.
                              Einzeln de/aktivieren wäre ein Prozess, der weit über eine Woche dauern müsste und die entspr. Funktionen dann nicht laufen würden. Wobei dann noch immer nicht gewiss ist, ob ein Script nicht nach 3 Tagen erst einen Fehler verursacht, also nein, das sehe ich nicht als adäquate Herangehensweise.
                              Wäre nur das letzte Mittel und mit eurem Fachwissen hoff. nicht notwendig
                              Mal sehen, wann er das nächste Mal wieder abraucht.
                              BG
                                Deutet auf einen Adapter hin der den Memory erschöpft. Da musst du jetzt im iobroker log mal zu dem Zeitpunkt schauen.
                                Ich vermute aber auch ein Script, auch wenn es überschaubar ist und wie @Thomas-Braun sagt.... sekündliche abfragen sind auch nicht sinnvoll.
                                HumidorH Online
                                HumidorH Online
                                Humidor
                                @wendy2702
                                und wieder:
                                2021-03-10 16:20:14.979 - info: zoe2.0 (7357) getHVACStatus not enabled in config
                                2021-03-10 16:20:24.987 - info: zoe2.0 (7357) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2021-03-10 16:20:25.563 - info: host.raspi4iobrokerpv instance system.adapter.zoe2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2021-03-10 16:24:20.963 - info: javascript.0 (2556) script.js.common.Powerbank: Powerbank Ladung beendet
                                2021-03-10 16:26:30.914 - error: life360.0 (2851) States database error: read ECONNRESET
                                2021-03-10 16:26:30.931 - error: modbus.1 (2612) States database error: read ECONNRESET
                                2021-03-10 16:26:31.215 - error: info.0 (2642) States database error: write EPIPE
                                2021-03-10 16:26:31.893 - error: mqtt.0 (7438) States database error: read ECONNRESET
                                2021-03-10 16:26:31.886 - error: kecontact.0 (2448) States database error: read ECONNRESET
                                2021-03-10 16:26:31.929 - error: history.0 (5710) States database error: write ECONNRESET
                                2021-03-10 16:26:31.906 - error: mqtt.0 (7438) Objects database error: read ECONNRESET
                                2021-03-10 16:26:32.136 - info: backitup.0 (2455) cleaned everything up...
                                2021-03-10 16:26:32.287 - info: info.0 (2642) cleaned everything up...
                                2021-03-10 16:26:32.304 - info: cloud.0 (2613) Connection changed: io client disconnect
                                2021-03-10 16:26:32.034 - info: life360.0 (2851) Disabled polling.
                                2021-03-10 16:26:32.311 - info: life360.0 (2851) cleaned everything up...
                                2021-03-10 16:26:32.326 - info: iot.0 (2403) Connection changed: disconnect
                                2021-03-10 16:26:32.309 - info: cloud.0 (2613) Connection lost
                                2021-03-10 16:26:32.147 - info: vis-inventwo.0 (2545) cleaned everything up...
                                2021-03-10 16:26:32.330 - info: iot.0 (2403) Connection lost
                                2021-03-10 16:26:33.535 - info: mqtt.0 (7438) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                2021-03-10 16:26:33.618 - info: iot.0 (2403) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                2021-03-10 16:26:33.653 - info: backitup.0 (2455) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                2021-03-10 16:26:33.668 - info: modbus.0 (2581) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                2021-03-10 16:26:33.780 - info: modbus.1 (2612) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                2021-03-10 16:26:33.792 - info: info.0 (2642) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                2021-03-10 16:26:33.810 - info: kecontact.0 (2448) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                2021-03-10 16:26:33.817 - info: life360.0 (2851) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                2021-03-10 16:26:33.826 - info: cloud.0 (2613) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                2021-03-10 16:26:32.410 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.411 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:32.411 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.436 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.437 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:32.437 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.546 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.546 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:32.547 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.554 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.555 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:32.555 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.565 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.565 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:32.566 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.573 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.574 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:32.574 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.582 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.582 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:32.582 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.589 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.589 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:32.590 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.598 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.598 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:32.598 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.605 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.605 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:32.606 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.612 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.612 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:32.612 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.618 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.618 - error: history.0 (5710) Error: write EPIPE
                                at ChildProcess.target._send (internal/child_process.js:807:20)
                                at ChildProcess.target.send (internal/child_process.js:678:19)
                                at /opt/iobroker/node_modules/iobroker.history/main.js:1061:28
                                at getCachedData (/opt/iobroker/node_modules/iobroker.history/main.js:837:5)
                                at ChildProcess. (/opt/iobroker/node_modules/iobroker.history/main.js:1060:21)
                                at ChildProcess.emit (events.js:314:20)
                                at ChildProcess.EventEmitter.emit (domain.js:483:12)
                                at emit (internal/child_process.js:877:12)
                                at processTicksAndRejections (internal/process/task_queues.js:85:21)
                                2021-03-10 16:26:32.619 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.627 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.627 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:32.627 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.633 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.633 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:32.634 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.639 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.639 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:32.639 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.645 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.645 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:32.645 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.653 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.654 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:32.654 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.659 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.659 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:32.660 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.665 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.666 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:32.666 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.671 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.672 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:32.672 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.680 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.680 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:32.680 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.686 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.686 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:32.687 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:32.693 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:32.694 - error: history.0 (5710) Error: write EPIPE
                                ....1000 mal .....
                                2021-03-10 16:26:34.038 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:34.043 - error: history.0 (5710) uncaught exception: write EPIPE
                                2021-03-10 16:26:34.044 - error: history.0 (5710) Error: write EPIPE
                                2021-03-10 16:26:34.044 - error: history.0 (5710) Exception-Code: EPIPE: write EPIPE
                                2021-03-10 16:26:35.968 - error: life360.0 (2851) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                2021-03-10 16:26:35.981 - warn: life360.0 (2851) get state error: Connection is closed.
                                2021-03-10 16:26:35.983 - warn: life360.0 (2851) get state error: DB closed
                                2021-03-10 16:26:35.986 - warn: life360.0 (2851) get state error: DB closed
                                2021-03-10 16:26:35.991 - error: life360.0 (2851) Failed to set value "https://www.openstreetmap.org/?mlat=48.137782&mlon=14.102841#map=15/48.137782/14.102841" for datapoint id "myplaces.zuHause.urlMap": Error: DB closed
                                2021-03-10 16:26:36.007 - error: modbus.1 (2612) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                2021-03-10 16:26:36.018 - warn: modbus.1 (2612) get state error: Connection is closed.
                                2021-03-10 16:26:36.020 - warn: modbus.1 (2612) get state error: DB closed
                                2021-03-10 16:26:36.029 - error: cloud.0 (2613) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                2021-03-10 16:26:36.029 - error: modbus.1 (2612) Can not set state holdingRegisters.40100_I_DC_Leistung: Error: DB closed
                                2021-03-10 16:26:36.030 - error: modbus.1 (2612) Can not set state holdingRegisters.40071_I_AC_Strom: Error: DB closed
                                2021-03-10 16:26:36.031 - error: modbus.1 (2612) Can not set state holdingRegisters.40072_I_AC_StromA: Error: DB closed
                                2021-03-10 16:26:36.032 - error: modbus.1 (2612) Can not set state holdingRegisters.40073_I_AC_StromB: Error: DB closed
                                2021-03-10 16:26:36.033 - error: modbus.1 (2612) Can not set state holdingRegisters.40074_I_AC_StromC: Error: DB closed
                                2021-03-10 16:26:36.034 - error: modbus.1 (2612) Can not set state holdingRegisters.40083_I_AC_Leistung: Error: DB closed
                                2021-03-10 16:26:36.035 - error: modbus.1 (2612) Can not set state holdingRegisters.40087_I_AC_VA: Error: DB closed
                                2021-03-10 16:26:36.036 - error: modbus.1 (2612) Can not set state holdingRegisters.40089_I_AC_VAR: Error: DB closed
                                2021-03-10 16:26:36.037 - error: modbus.1 (2612) Can not set state holdingRegisters.40091_I_AC_PF: Error: DB closed
                                2021-03-10 16:26:36.038 - error: modbus.1 (2612) Can not set state holdingRegisters.40093_I_AC_Energie_WH: Error: DB closed
                                2021-03-10 16:26:36.038 - error: modbus.1 (2612) Can not set state holdingRegisters.40096_I_DC_Strom: Error: DB closed
                                2021-03-10 16:26:36.348 - error: info.0 (2642) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                2021-03-10 16:26:36.472 - error: modbus.0 (2581) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                2021-03-10 16:26:36.477 - warn: modbus.0 (2581) get state error: Connection is closed.
                                2021-03-10 16:26:36.478 - warn: modbus.0 (2581) get state error: DB closed
                                2021-03-10 16:26:36.479 - warn: modbus.0 (2581) get state error: DB closed
                                2021-03-10 16:26:36.482 - warn: modbus.0 (2581) get state error: DB closed
                                2021-03-10 16:26:36.483 - warn: modbus.0 (2581) get state error: DB closed
                                2021-03-10 16:26:36.484 - warn: modbus.0 (2581) get state error: DB closed
                                2021-03-10 16:26:36.903 - error: backitup.0 (2455) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                2021-03-10 16:26:36.905 - error: iot.0 (2403) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                2021-03-10 16:26:36.922 - error: mqtt.0 (7438) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                2021-03-10 16:26:36.950 - error: kecontact.0 (2448) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                2021-03-10 16:26:37.355 - error: vis-inventwo.0 (2545) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                2021-03-10 16:26:37.359 - warn: vis-inventwo.0 (2545) get state error: Connection is closed.
                                2021-03-10 16:26:37.392 - error: telegram.0 (2418) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                2021-03-10 16:26:37.397 - warn: telegram.0 (2418) get state error: Connection is closed.
                                2021-03-10 16:26:40.982 - error: life360.0 (2851) Cannot check object existence of "life360.0.info.connection": Connection is closed.
                                2021-03-10 16:26:41.020 - error: modbus.1 (2612) Cannot check object existence of "modbus.1.holdingRegisters.40071_I_AC_Strom": Connection is closed.
                                2021-03-10 16:26:41.476 - error: modbus.0 (2581) Cannot check object existence of "modbus.0.inputRegisters.30535_Tagesertrag_Wh": Connection is closed.
                                2021-03-10 16:26:42.396 - error: telegram.0 (2418) Cannot check object existence of "telegram.0.info.connection": Connection is closed.
                                2021-03-10 16:26:44.096 - info: host.raspi4iobrokerpv iobroker.js-controller version 3.2.16 js-controller starting
                                2021-03-10 16:26:44.102 - info: host.raspi4iobrokerpv Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                                2021-03-10 16:26:44.103 - info: host.raspi4iobrokerpv hostname: raspi4iobrokerpv, node: v12.21.0
                                2021-03-10 16:26:44.103 - info: host.raspi4iobrokerpv ip addresses: 192.168.0.92 fe80::ccf8:50de:636d:5c10 192.168.0.93 fe80::9a94:9b45:baab:4bdd
                                2021-03-10 16:26:44.659 - info: host.raspi4iobrokerpv connected to Objects and States
                                2021-03-10 16:26:44.704 - info: host.raspi4iobrokerpv added notifications configuration of host
                                2021-03-10 16:26:45.178 - info: host.raspi4iobrokerpv 29 instances found
                                2021-03-10 16:26:45.250 - info: host.raspi4iobrokerpv starting 20 instances
                                2021-03-10 16:26:45.340 - info: host.raspi4iobrokerpv instance system.adapter.admin.0 started with pid 12838
                                2021-03-10 16:26:47.014 - error: admin.0 (12838) admin.0 already running
                                2021-03-10 16:26:47.016 - warn: admin.0 (12838) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                2021-03-10 16:26:47.608 - error: host.raspi4iobrokerpv instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                2021-03-10 16:26:47.609 - info: host.raspi4iobrokerpv Restart adapter system.adapter.admin.0 because enabled
                                2021-03-10 16:26:49.295 - info: host.raspi4iobrokerpv instance system.adapter.kecontact.0 started with pid 12849
                                2021-03-10 16:26:50.443 - error: kecontact.0 (12849) kecontact.0 already running
                                2021-03-10 16:26:50.446 - warn: kecontact.0 (12849) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                2021-03-10 16:26:51.070 - error: host.raspi4iobrokerpv instance system.adapter.kecontact.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                2021-03-10 16:26:51.072 - info: host.raspi4iobrokerpv Restart adapter system.adapter.kecontact.0 because enabled
                                2021-03-10 16:26:53.370 - info: host.raspi4iobrokerpv instance system.adapter.mqtt.0 started with pid 12860
                                2021-03-10 16:26:54.395 - error: mqtt.0 (12860) mqtt.0 already running
                                2021-03-10 16:26:54.399 - warn: mqtt.0 (12860) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                2021-03-10 16:26:55.029 - error: host.raspi4iobrokerpv instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                2021-03-10 16:26:55.030 - info: host.raspi4iobrokerpv Restart adapter system.adapter.mqtt.0 because enabled
                                2021-03-10 16:26:57.318 - info: host.raspi4iobrokerpv instance system.adapter.web.0 started with pid 12871
                                2021-03-10 16:26:58.542 - error: web.0 (12871) web.0 already running
                                2021-03-10 16:26:59.128 - error: host.raspi4iobrokerpv instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                2021-03-10 16:26:59.128 - info: host.raspi4iobrokerpv Restart adapter system.adapter.web.0 because enabled
                                2021-03-10 16:27:01.373 - info: host.raspi4iobrokerpv instance system.adapter.javascript.0 started with pid 12882
                                2021-03-10 16:27:03.682 - error: javascript.0 (12882) javascript.0 already running
                                2021-03-10 16:27:03.685 - warn: javascript.0 (12882) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                2021-03-10 16:27:04.306 - error: host.raspi4iobrokerpv instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                2021-03-10 16:27:04.306 - info: host.raspi4iobrokerpv Restart adapter system.adapter.javascript.0 because enabled
                                2021-03-10 16:27:05.372 - info: host.raspi4iobrokerpv instance system.adapter.history.0 started with pid 12893
                                2021-03-10 16:27:06.391 - error: history.0 (12893) history.0 already running
                                2021-03-10 16:27:06.394 - warn: history.0 (12893) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                2021-03-10 16:27:06.999 - error: host.raspi4iobrokerpv instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                2021-03-10 16:27:07.000 - info: host.raspi4iobrokerpv Restart adapter system.adapter.history.0 because enabled
                                2021-03-10 16:27:09.355 - info: host.raspi4iobrokerpv instance system.adapter.cloud.0 started with pid 12904
                                2021-03-10 16:27:10.684 - error: cloud.0 (12904) cloud.0 already running
                                2021-03-10 16:27:10.687 - warn: cloud.0 (12904) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                2021-03-10 16:27:11.267 - error: host.raspi4iobrokerpv instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                2021-03-10 16:27:11.267 - info: host.raspi4iobrokerpv Restart adapter system.adapter.cloud.0 because enabled
                                2021-03-10 16:27:13.403 - info: host.raspi4iobrokerpv instance system.adapter.iot.0 started with pid 12915
                                2021-03-10 16:27:14.922 - error: iot.0 (12915) iot.0 already running
                                2021-03-10 16:27:14.925 - warn: iot.0 (12915) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                2021-03-10 16:27:15.518 - error: host.raspi4iobrokerpv instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                2021-03-10 16:27:15.519 - info: host.raspi4iobrokerpv Restart adapter system.adapter.iot.0 because enabled
                                2021-03-10 16:27:17.369 - info: host.raspi4iobrokerpv instance system.adapter.telegram.0 started with pid 12926
                                2021-03-10 16:27:17.632 - info: host.raspi4iobrokerpv instance system.adapter.admin.0 started with pid 12933
                                2021-03-10 16:27:19.308 - error: telegram.0 (12926) telegram.0 already running
                                2021-03-10 16:27:19.311 - warn: telegram.0 (12926) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                2021-03-10 16:27:19.639 - info: admin.0 (12933) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.21.0, js-controller: 3.2.16
                                2021-03-10 16:27:19.688 - info: admin.0 (12933) requesting all states
                                2021-03-10 16:27:19.689 - info: admin.0 (12933) requesting all objects
                                2021-03-10 16:27:20.427 - error: host.raspi4iobrokerpv instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                2021-03-10 16:27:20.429 - info: host.raspi4iobrokerpv Restart adapter system.adapter.telegram.0 because enabled
                                2021-03-10 16:27:20.719 - info: admin.0 (12933) received all objects
                                2021-03-10 16:27:20.862 - info: admin.0 (12933) http server listening on port 8081
                                2021-03-10 16:27:21.095 - info: host.raspi4iobrokerpv instance system.adapter.kecontact.0 started with pid 12952
                                2021-03-10 16:27:20.863 - info: admin.0 (12933) Use link "http://localhost:8081" to configure.
                                2021-03-10 16:27:21.275 - info: host.raspi4iobrokerpv instance system.adapter.backitup.0 started with pid 12959
                                2021-03-10 16:27:22.710 - info: kecontact.0 (12952) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.kecontact, node: v12.21.0, js-controller: 3.2.16
                                2021-03-10 16:27:24.950 - error: backitup.0 (12959) backitup.0 already running
                                2021-03-10 16:27:24.953 - warn: backitup.0 (12959) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                2021-03-10 16:27:25.054 - info: host.raspi4iobrokerpv instance system.adapter.mqtt.0 started with pid 12978
                                2021-03-10 16:27:25.548 - error: host.raspi4iobrokerpv instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                2021-03-10 16:27:25.549 - info: host.raspi4iobrokerpv Restart adapter system.adapter.backitup.0 because enabled
                                2021-03-10 16:27:26.577 - info: mqtt.0 (12978) starting. Version 2.3.4 in /opt/iobroker/node_modules/iobroker.mqtt, node: v12.21.0, js-controller: 3.2.16
                                2021-03-10 16:27:26.738 - info: vis.0 (12985) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.vis, node: v12.21.0, js-controller: 3.2.16
                                2021-03-10 16:27:26.809 - info: mqtt.0 (12978) Starting MQTT server on 0.0.0.0:1883
                                2021-03-10 16:27:27.144 - info: vis.0 (12985) vis license is OK.
                                2021-03-10 16:27:27.769 - info: kecontact.0 (12952) starting charging station in passive mode
                                2021-03-10 16:27:28.038 - info: vis.0 (12985) Terminated (NO_ERROR): Without reason
                                2021-03-10 16:27:28.644 - info: host.raspi4iobrokerpv instance system.adapter.vis.0 terminated while should be started once
                                2021-03-10 16:27:29.160 - info: host.raspi4iobrokerpv instance system.adapter.web.0 started with pid 13008
                                2021-03-10 16:27:29.325 - info: host.raspi4iobrokerpv instance system.adapter.shelly.0 started with pid 13015
                                2021-03-10 16:27:31.776 - error: shelly.0 (13015) shelly.0 already running
                                2021-03-10 16:27:31.779 - warn: shelly.0 (13015) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                2021-03-10 16:27:32.348 - error: host.raspi4iobrokerpv instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                2021-03-10 16:27:32.349 - info: host.raspi4iobrokerpv Restart adapter system.adapter.shelly.0 because enabled
                                2021-03-10 16:27:33.373 - info: host.raspi4iobrokerpv instance system.adapter.vis-inventwo.0 started with pid 13034
                                2021-03-10 16:27:34.472 - info: host.raspi4iobrokerpv instance system.adapter.javascript.0 started with pid 13053
                                2021-03-10 16:27:36.179 - error: vis-inventwo.0 (13034) vis-inventwo.0 already running
                                2021-03-10 16:27:36.183 - warn: vis-inventwo.0 (13034) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                2021-03-10 16:27:36.808 - error: host.raspi4iobrokerpv instance system.adapter.vis-inventwo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                2021-03-10 16:27:36.810 - info: host.raspi4iobrokerpv Restart adapter system.adapter.vis-inventwo.0 because enabled
                                2021-03-10 16:27:37.024 - info: host.raspi4iobrokerpv instance system.adapter.history.0 started with pid 13060
                                2021-03-10 16:27:37.174 - info: mqtt.0 (12978) Client [AMIS] connected with secret 1615390057158_2551
                                2021-03-10 16:27:37.431 - info: host.raspi4iobrokerpv instance system.adapter.modbus.0 started with pid 13071
                                2021-03-10 16:27:38.256 - info: javascript.0 (13053) starting. Version 5.0.12 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.21.0, js-controller: 3.2.16
                                2021-03-10 16:27:38.448 - info: javascript.0 (13053) requesting all states
                                2021-03-10 16:27:38.450 - info: javascript.0 (13053) requesting all objects
                                2021-03-10 16:27:39.090 - error: modbus.0 (13071) modbus.0 already running
                                2021-03-10 16:27:39.093 - warn: modbus.0 (13071) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                2021-03-10 16:27:39.389 - info: javascript.0 (13053) received all objects
                                2021-03-10 16:27:39.407 - info: history.0 (13060) starting. Version 1.9.12 in /opt/iobroker/node_modules/iobroker.history, node: v12.21.0, js-controller: 3.2.16
                                2021-03-10 16:27:39.459 - info: javascript.0 (13053) received all states
                                2021-03-10 16:27:39.531 - info: history.0 (13060) enabled logging of kecontact.0.pf (Count=1), Alias=false
                                2021-03-10 16:27:39.542 - info: javascript.0 (13053) Start javascript script.js.common.AMIS
                                2021-03-10 16:27:39.532 - info: history.0 (13060) enabled logging of kecontact.0.p (Count=2), Alias=false
                                2021-03-10 16:27:39.533 - info: history.0 (13060) enabled logging of kecontact.0.currentUser (Count=3), Alias=false
                                2021-03-10 16:27:39.534 - info: history.0 (13060) enabled logging of mqtt.0.info.connection (Count=4), Alias=false
                                2021-03-10 16:27:39.535 - info: history.0 (13060) enabled logging of 0_userdata.0.AMIS.170 (Count=5), Alias=false
                                2021-03-10 16:27:39.536 - info: history.0 (13060) enabled logging of 0_userdata.0.AMIS.270 (Count=6), Alias=false
                                2021-03-10 16:27:39.537 - info: history.0 (13060) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Switch (Count=7), Alias=false
                                2021-03-10 16:27:39.537 - info: history.0 (13060) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Power (Count=8), Alias=false
                                2021-03-10 16:27:39.538 - info: history.0 (13060) enabled logging of 0_userdata.0.AMIS.Power (Count=9), Alias=false
                                2021-03-10 16:27:39.539 - info: history.0 (13060) enabled logging of kecontact.0.currentTimer (Count=10), Alias=false
                                2021-03-10 16:27:39.540 - info: history.0 (13060) enabled logging of modbus.0.inputRegisters.30775_PVLeistung (Count=11), Alias=false
                                2021-03-10 16:27:39.541 - info: history.0 (13060) enabled logging of javascript.0.Solar.Wechselrichter.PVLeistungAktuell (Count=12), Alias=false
                                2021-03-10 16:27:39.542 - info: history.0 (13060) enabled logging of 0_userdata.0.AMIS.PVPower (Count=13), Alias=false
                                2021-03-10 16:27:39.542 - info: history.0 (13060) enabled logging of 0_userdata.0.AMIS.PVÜberschuss (Count=14), Alias=false
                                2021-03-10 16:27:39.611 - info: javascript.0 (13053) script.js.common.AMIS: registered 1 subscription and 0 schedules
                                2021-03-10 16:27:39.612 - info: javascript.0 (13053) Start javascript script.js.common.SE_Power
                                2021-03-10 16:27:39.632 - info: javascript.0 (13053) script.js.common.SE_Power: registered 0 subscriptions and 0 schedules
                                2021-03-10 16:27:39.668 - info: javascript.0 (13053) Start javascript script.js.common.Powerbank
                                2021-03-10 16:27:39.676 - info: javascript.0 (13053) script.js.common.Powerbank: registered 2 subscriptions and 1 schedule
                                2021-03-10 16:27:39.677 - info: javascript.0 (13053) Start javascript script.js.common.Grid-PV
                                2021-03-10 16:27:39.682 - info: javascript.0 (13053) script.js.common.Grid-PV: registered 1 subscription and 0 schedules
                                2021-03-10 16:27:39.683 - info: javascript.0 (13053) Start javascript script.js.common.SMA+SE
                                2021-03-10 16:27:39.689 - info: javascript.0 (13053) script.js.common.SMA+SE: registered 1 subscription and 0 schedules
                                2021-03-10 16:27:39.690 - info: javascript.0 (13053) Start javascript script.js.common.PVÜberschuss
                                2021-03-10 16:27:39.695 - info: javascript.0 (13053) script.js.common.PVÜberschuss: registered 1 subscription and 0 schedules
                                2021-03-10 16:27:39.696 - info: javascript.0 (13053) Start javascript script.js.common.ZOE_Ladung
                                2021-03-10 16:27:39.706 - info: javascript.0 (13053) script.js.common.ZOE_Ladung: registered 5 subscriptions and 0 schedules
                                2021-03-10 16:27:39.707 - info: javascript.0 (13053) Start javascript script.js.common.Garage
                                2021-03-10 16:27:39.726 - info: javascript.0 (13053) script.js.common.Garage: registered 3 subscriptions and 1 schedule
                                [28549.611311] [  12791]  1001 12791    21596     5141   200704        0             0 node
                                [28549.611320] [  12792]  1001 12792    21604     5346   196608        3             0 node
                                [28549.611329] [  12793]  1001 12793    21604     5300   200704        0             0 node
                                [28549.611337] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/,task=node,pid=2515,uid=1001
                                [28549.611418] Out of memory: Killed process 2515 (node) total-vm:168180kB, anon-rss:42080kB, file-rss:20252kB, shmem-rss:0kB, UID:1001 pgtables:592kB oom_score_adj:0
                                [28549.632244] oom_reaper: reaped process 2515 (node), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
                                [28637.209566] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
                                Out of memory. Warum.....
                                BG
                                • HumidorH Humidor
                                  @wendy2702
                                  und wieder:
                                  ....1000 mal .....
                                  HumidorH Online
                                  HumidorH Online
                                  Humidor
                                  schrieb am zuletzt editiert von Humidor
                                  Ich habe alle Scripte deaktiviert, die ich nicht zur Ladung vom Zoe benötige.
                                  Während der Ladung werden somit 4 Kurz-Scripte verwendet, um die Infos vom Zähler zu verarbeiten und entsprechende Objekte zu füttern. Trigger und steuere Objekt mit Wert 1 + Wert 2.
                                  Ein Script ist die Ladesteuerung, darin wird nach Trigger das Grundlegende aktiviert (Ladung Ja/Nein), mit Cronjob - der aktiv zeitlich geändert wird - die Ladung (A) gesteuert.
                                  in der Instanz und Anzeige der Ressource sehe ich null Veränderung
                                  Der Restart vom ioBroker erfolgt auch nicht während einer Ladung, damit bin ich überzeugt, dass es nicht von einem Script ausgelöst wird. Wenn nix passiert und er zu irgend einem Zeitpunkt (nicht nachvollziehbar) ein Problem hat, glaube ich eher an eine spontane Auslastung, verursacht zBsp. eines Hängers vom Netzwerk. Denn wenn das hängt und Modbus, Zoe2, Mqtt usw. dann wie wild drauf pollen??? das sehe ich als realistische Möglichkeit.
                                  BG
                                    HumidorH Online
                                    HumidorH Online
                                    Humidor
                                    @wendy2702
                                    habe den Speicher über längeren Zeitraum beobachtet, wenn ich aktiv bin, sprich Scripte (Blockly) mache, wird der Ram immer weniger (schon unter 30%) und wird nicht wieder freigeben.
                                    nun, wie meine PV-Regelung wieder losgelegt hat, bumm nicht mehr erreichbar und Restart - out of memory.
                                    wenn ich einen täglichen Restart mache, dann bereinigt sich der Ram und bleibt ca60% und alles läuft super.
                                    tja, ....
                                    BG
                                    • Basti97B Offline
                                      Basti97B Offline
                                      Basti97
                                      schrieb am zuletzt editiert von Basti97
                                      Ich habe ein ähnlichen Fall jedoch kommt er unregelmäßig vor. Könnte das auch am Ram liegen?
                                      Plattform: linux
                                      RAM: 1.9 GB
                                      Node.js: v14.19.1
                                      NPM: v6.14.16
                                      JS C 4.0.21
                                      2022-04-03 17:26:48.180 - error: admin.0 (835) States database error: write EPIPE
                                      2022-04-03 17:26:48.220 - info: info.0 (1526) cleaned everything up...
                                      2022-04-03 17:26:48.331 - error: sonoff.0 (1318) Objects database error: write EPIPE
                                      2022-04-03 17:26:48.061 - error: adguard.0 (125489) States database error: write ECONNRESET
                                      2022-04-03 17:26:48.002 - info: javascript.2 (1160) Stop script script.js.Wohnung.Zigbee.Xiaomi_aqara.Balkon_Temperatur_(T1)
                                      2022-04-03 17:26:48.034 - info: javascript.2 (1160) Stop script script.js.Wohnung.Wetterstation.Wettervorhersage
                                      2022-04-03 17:26:48.034 - info: javascript.2 (1160) Stop script script.js.Wohnung.Wetterstation.Unwetterwarnung
                                      2022-04-03 17:26:48.050 - info: javascript.2 (1160) Stop script script.js.Wohnung.Verbindung_zu_Clients.Logo_Deckenlicht
                                      2022-04-03 17:26:48.365 - error: javascript.2 (1160) States database error: write EPIPE
                                      2022-04-03 17:26:48.400 - error: javascript.2 (1160) Objects database error: write EPIPE
                                      2022-04-03 17:26:47.976 - info: node-red.0 (1017) kill node-red task
                                      2022-04-03 17:26:48.406 - error: node-red.0 (1017) States database error: write EPIPE
                                      2022-04-03 17:26:48.261 - error: s7.0 (1259) Objects database error: write ECONNRESET
                                      2022-04-03 17:26:48.267 - error: s7.1 (1276) Objects database error: write ECONNRESET
                                      2022-04-03 17:26:48.384 - error: web.0 (1355) States database error: write ECONNRESET
                                      Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
                                      • Basti97B Basti97
                                        Plattform: linux
                                        RAM: 1.9 GB
                                        Node.js: v14.19.1
                                        NPM: v6.14.16
                                        JS C 4.0.21
                                        @basti97 sagte in (?) ioBroker Restart ?:
                                        Könnte.
                                        Wie sieht's denn da aus?
                                        free -ht --mega
                                        Basti97B 2 Antworten Letzte Antwort
                                          Könnte.
                                          free -ht --mega
                                          Basti97B Offline
                                          Basti97B Offline
                                          Basti97
                                          @thomas-braun said in (?) ioBroker Restart ?:
                                          free -ht --mega
