  3. Entwicklung
  4. Galapara Thermostat / Zigbee / wird nicht konfiguriert
    5.4k
zigbee thermostat
25 Beiträge 4 Kommentatoren 3.4k Aufrufe 4 Beobachtet
  • arteckA arteck
    @flitze-fitz nein ich meine die JETZIGE Version vor 5 min... die ich gerade aktualisiert habe
    flitze-fitz
    schrieb am zuletzt editiert von flitze-fitz
    @arteck
    Jetzt geht gar nichts mehr. Adapter bleibt rot. Ist jetzt doch wieder grün, aber ich konnte deine neueste Version nicht installieren.
    2021-03-07 20:21:59.549 - info: host.NUC(SmartHome1) "system.adapter.zigbee.0" enabled
    2021-03-07 20:21:59.594 - info: host.NUC(SmartHome1) instance system.adapter.zigbee.0 started with pid 1448
    2021-03-07 20:22:01.187 - error: host.NUC(SmartHome1) Caught by controller[0]: C:\Program Files\iobroker\SmartHome1\node_modules\zigbee-herdsman\node_modules\bindings\bindings.js:121
    2021-03-07 20:22:01.188 - error: host.NUC(SmartHome1) Caught by controller[0]: throw e;
    2021-03-07 20:22:01.188 - error: host.NUC(SmartHome1) Caught by controller[0]: ^
    2021-03-07 20:22:01.188 - error: host.NUC(SmartHome1) Caught by controller[0]: Error: The module '\\?\C:\Program Files\iobroker\SmartHome1\node_modules\zigbee-herdsman\node_modules\@serialport\bindings\build\Release\bindings.node'
    2021-03-07 20:22:01.189 - error: host.NUC(SmartHome1) Caught by controller[0]: was compiled against a different Node.js version using
    2021-03-07 20:22:01.189 - error: host.NUC(SmartHome1) Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    2021-03-07 20:22:01.189 - error: host.NUC(SmartHome1) Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    2021-03-07 20:22:01.189 - error: host.NUC(SmartHome1) Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2021-03-07 20:22:01.189 - error: host.NUC(SmartHome1) Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1057:18)
    2021-03-07 20:22:01.189 - error: host.NUC(SmartHome1) Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    2021-03-07 20:22:01.189 - error: host.NUC(SmartHome1) Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    2021-03-07 20:22:01.190 - error: host.NUC(SmartHome1) Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    2021-03-07 20:22:01.190 - error: host.NUC(SmartHome1) Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    2021-03-07 20:22:01.190 - error: host.NUC(SmartHome1) Caught by controller[0]: at bindings (C:\Program Files\iobroker\SmartHome1\node_modules\zigbee-herdsman\node_modules\bindings\bindings.js:112:48)
    2021-03-07 20:22:01.190 - error: host.NUC(SmartHome1) Caught by controller[0]: at Object. (C:\Program Files\iobroker\SmartHome1\node_modules\zigbee-herdsman\node_modules\@serialport\bindings\lib\win32.js:1:36)
    2021-03-07 20:22:01.190 - error: host.NUC(SmartHome1) Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    2021-03-07 20:22:01.190 - error: host.NUC(SmartHome1) Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    2021-03-07 20:22:01.190 - error: host.NUC(SmartHome1) Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    2021-03-07 20:22:01.190 - error: host.NUC(SmartHome1) instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2021-03-07 20:22:01.191 - info: host.NUC(SmartHome1) Adapter system.adapter.zigbee.0 needs rebuild and will be restarted afterwards.
    2021-03-07 20:22:01.191 - info: host.NUC(SmartHome1) system.adapter.zigbee.0 will be rebuilt
    2021-03-07 20:22:01.192 - warn: host.NUC(SmartHome1) adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
    2021-03-07 20:22:01.192 - info: host.NUC(SmartHome1) iobroker rebuild zigbee
    2021-03-07 20:22:03.670 - info: host.NUC(SmartHome1) iobroker npm-rebuild: npm rebuild --loglevel error (System call) in "C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee"
    2021-03-07 20:22:07.820 - info: host.NUC(SmartHome1) iobroker npm-rebuild:
    2021-03-07 20:22:07.820 - info: host.NUC(SmartHome1) iobroker npm-rebuild: Rebuild zigbee done
    2021-03-07 20:22:08.840 - info: host.NUC(SmartHome1) iobroker npm-rebuild: exit 0
    2021-03-07 20:22:08.883 - info: host.NUC(SmartHome1) instance system.adapter.zigbee.0 started with pid 3108
    2021-03-07 20:22:09.917 - error: host.NUC(SmartHome1) Caught by controller[0]: C:\Program Files\iobroker\SmartHome1\node_modules\zigbee-herdsman\node_modules\bindings\bindings.js:121
    2021-03-07 20:22:09.917 - error: host.NUC(SmartHome1) Caught by controller[0]: throw e;
    2021-03-07 20:22:09.917 - error: host.NUC(SmartHome1) Caught by controller[0]: ^
    2021-03-07 20:22:09.917 - error: host.NUC(SmartHome1) Caught by controller[0]: Error: The module '\\?\C:\Program Files\iobroker\SmartHome1\node_modules\zigbee-herdsman\node_modules\@serialport\bindings\build\Release\bindings.node'
    2021-03-07 20:22:09.917 - error: host.NUC(SmartHome1) Caught by controller[0]: was compiled against a different Node.js version using
    2021-03-07 20:22:09.917 - error: host.NUC(SmartHome1) Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    2021-03-07 20:22:09.917 - error: host.NUC(SmartHome1) Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    2021-03-07 20:22:09.918 - error: host.NUC(SmartHome1) Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2021-03-07 20:22:09.918 - error: host.NUC(SmartHome1) Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1057:18)
    2021-03-07 20:22:09.918 - error: host.NUC(SmartHome1) Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    2021-03-07 20:22:09.918 - error: host.NUC(SmartHome1) Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    2021-03-07 20:22:09.918 - error: host.NUC(SmartHome1) Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    2021-03-07 20:22:09.918 - error: host.NUC(SmartHome1) Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    2021-03-07 20:22:09.918 - error: host.NUC(SmartHome1) Caught by controller[0]: at bindings (C:\Program Files\iobroker\SmartHome1\node_modules\zigbee-herdsman\node_modules\bindings\bindings.js:112:48)
    2021-03-07 20:22:09.918 - error: host.NUC(SmartHome1) Caught by controller[0]: at Object. (C:\Program Files\iobroker\SmartHome1\node_modules\zigbee-herdsman\node_modules\@serialport\bindings\lib\win32.js:1:36)
    2021-03-07 20:22:09.918 - error: host.NUC(SmartHome1) Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    2021-03-07 20:22:09.919 - error: host.NUC(SmartHome1) Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    2021-03-07 20:22:09.919 - error: host.NUC(SmartHome1) Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    2021-03-07 20:22:09.919 - error: host.NUC(SmartHome1) instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2021-03-07 20:22:09.919 - info: host.NUC(SmartHome1) Adapter system.adapter.zigbee.0 needs rebuild and will be restarted afterwards.
    2021-03-07 20:22:09.919 - info: host.NUC(SmartHome1) system.adapter.zigbee.0 will be rebuilt
    2021-03-07 20:22:09.919 - warn: host.NUC(SmartHome1) adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
    2021-03-07 20:22:09.919 - info: host.NUC(SmartHome1) iobroker rebuild zigbee --install
    2021-03-07 20:22:10.935 - info: host.NUC(SmartHome1) iobroker npm-rebuild: npm install --loglevel error --production (System call) in "C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee"
    2021-03-07 20:22:53.011 - info: host.NUC(SmartHome1) "system.adapter.zigbee.0" disabled
    2021-03-07 20:23:20.361 - info: host.NUC(SmartHome1) iobroker url "https://github.com/ioBroker/ioBroker.zigbee/tarball/master" zigbee
    2021-03-07 20:23:29.662 - info: host.NUC(SmartHome1) iobroker install ioBroker/ioBroker.zigbee#master
    2021-03-07 20:23:39.296 - info: host.NUC(SmartHome1) iobroker NPM version: 6.14.11
    2021-03-07 20:23:39.299 - info: host.NUC(SmartHome1) iobroker npm install ioBroker/ioBroker.zigbee#master --loglevel error (System call)
    2021-03-07 20:28:28.572 - info: host.NUC(SmartHome1) iobroker npm ERR! code EBUSY
    2021-03-07 20:28:28.573 - info: host.NUC(SmartHome1) iobroker npm ERR! syscall rmdir
    npm ERR! path C:\Program Files\iobroker\SmartHome1\node_modules\iobroker.zigbee
    npm ERR! errno -4082
    2021-03-07 20:28:28.576 - info: host.NUC(SmartHome1) iobroker npm ERR! EBUSY: resource busy or locked, rmdir 'C:\Program Files\iobroker\SmartHome1\node_modules\iobroker.zigbee'
    2021-03-07 20:28:28.649 - info: host.NUC(SmartHome1) iobroker
    2021-03-07 20:28:28.650 - info: host.NUC(SmartHome1) iobroker npm ERR! A complete log of this run can be found in:
    npm ERR! C:\Program Files\iobroker\SmartHome1\env\npm-cache\_logs\2021-03-07T19_28_28_593Z-debug.log
    2021-03-07 20:28:28.781 - error: host.NUC(SmartHome1) iobroker host.NUC(SmartHome1) Cannot install ioBroker/ioBroker.zigbee#master: 4294963214
    2021-03-07 20:28:29.821 - info: host.NUC(SmartHome1) iobroker exit 25
    • F flitze-fitz
      @arteck
      arteckA Offline
      arteckA Offline
      arteck
      @flitze-fitz du sollst nicht 5 sachen auf einmal machen und hoffen das wir das nicht sehen...
      warum installierst du neues node .. die Versionen passen nicht zueinander..
      ... und meckerst dass nix geht.. ist schon schwer genug das dein system auf windows läuft
      F 1 Antwort Letzte Antwort
      • arteckA arteck
        flitze-fitz
        @arteck
        außer über die Katze den Adapter von GIT zu installieren, hab ich gar nichts gemacht. Wirklich nicht. Ich hab keine Ahnung woher diese Logs kommen.
        Meine node version ist 12.21. Muss ich eine andere Version haben?
        Mir liegt es fern Leuten die mir helfen können/wollen die Arbeit zu erschweren und verstecken wollte ich auch nichts.
        • F flitze-fitz
          @arteck
          arteckA Offline
          arteckA Offline
          arteck
          @flitze-fitz wenn du auf die node 12 bist dann hast du ein update gemacht.. wann keine ahnung .. auf jeden fall hast du den adapter nicht neu generiert...
          also kein plan was da schief oder was weiss ich gelaufen ist...
          folgendes
          zigbee adapter stoppen
          dann löschen aus dem
          folgende Ordner
          serialport
          @serialport
          zigbee-herdsman
          zigbee-herdsman-converters
          iobroker.zigbee
          dann über die Katze den adapter neu installieren
          dann adapter starten...log posten
          • arteckA arteck
            folgendes
            folgende Ordner
            serialport
            @serialport
            zigbee-herdsman
            iobroker.zigbee
            flitze-fitz
            :@arteck vielen Dank. Jetzt ging es durch. Das Thermostat geht aber leider immer noch nicht.
            2021-03-07 21:03:50.354 - info: host.NUC(SmartHome1) "system.adapter.zigbee.0" disabled
            2021-03-07 21:03:50.356 - info: host.NUC(SmartHome1) stopInstance system.adapter.zigbee.0 (force=false, process=true)
            2021-03-07 21:03:50.350 - info: zigbee.0 (10728) Got terminate signal TERMINATE_YOURSELF
            2021-03-07 21:03:50.361 - info: host.NUC(SmartHome1) stopInstance system.adapter.zigbee.0 send kill signal
            2021-03-07 21:03:50.352 - info: zigbee.0 (10728) cleaned everything up...
            2021-03-07 21:03:50.354 - info: zigbee.0 (10728) Zigbee: disabling joining new devices.
            2021-03-07 21:03:50.877 - info: zigbee.0 (10728) terminating
            2021-03-07 21:03:50.877 - info: zigbee.0 (10728) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2021-03-07 21:03:51.390 - info: host.NUC(SmartHome1) stopInstance system.adapter.zigbee.0 killing pid 10728
            2021-03-07 21:03:51.444 - warn: host.NUC(SmartHome1) instance system.adapter.zigbee.0 terminated due to SIGTERM
            2021-03-07 21:03:51.445 - info: host.NUC(SmartHome1) instance system.adapter.zigbee.0 terminated with code null ()
            2021-03-07 21:08:24.034 - info: host.NUC(SmartHome1) iobroker url "https://github.com/ioBroker/ioBroker.zigbee/tarball/master" zigbee
            2021-03-07 21:08:29.334 - info: host.NUC(SmartHome1) iobroker install ioBroker/ioBroker.zigbee#master
            2021-03-07 21:08:34.423 - info: host.NUC(SmartHome1) iobroker NPM version: 6.14.11
            2021-03-07 21:08:34.426 - info: host.NUC(SmartHome1) iobroker npm install ioBroker/ioBroker.zigbee#master --loglevel error (System call)
            2021-03-07 21:17:53.521 - info: host.NUC(SmartHome1) iobroker upload [250] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/sylvania_rt.png img/sylvania_rt.png image/png
            2021-03-07 21:17:57.802 - info: host.NUC(SmartHome1) iobroker upload [200] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/philips_hue_e27_ambiance.png img/philips_hue_e27_ambiance.png image/png
            2021-03-07 21:18:01.968 - info: host.NUC(SmartHome1) iobroker upload [150] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/lumi_remote_b286opcn01.png img/lumi_remote_b286opcn01.png image/png
            2021-03-07 21:18:06.186 - info: host.NUC(SmartHome1) iobroker upload [100] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/ikea_open_close_switch.png img/ikea_open_close_switch.png image/png
            2021-03-07 21:18:06.967 - info: host.NUC(SmartHome1) iobroker upload [90] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/ikea_bulb_E27.png img/ikea_bulb_E27.png image/png
            2021-03-07 21:18:07.827 - info: host.NUC(SmartHome1) iobroker upload [80] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/hs1sa.png img/hs1sa.png image/png
            2021-03-07 21:18:08.639 - info: host.NUC(SmartHome1) iobroker upload [70] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/gq8b1uv.png img/gq8b1uv.png image/png
            2021-03-07 21:18:09.437 - info: host.NUC(SmartHome1) iobroker upload [60] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/fnb56zsw01.png img/fnb56zsw01.png image/png
            2021-03-07 21:18:10.374 - info: host.NUC(SmartHome1) iobroker upload [50] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/ewelink_DS01.png img/ewelink_DS01.png image/png
            2021-03-07 21:18:11.218 - info: host.NUC(SmartHome1) iobroker upload [40] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/DIYRuZ_CO2.png img/DIYRuZ_CO2.png image/png
            2021-03-07 21:18:12.062 - info: host.NUC(SmartHome1) iobroker upload [30] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/ctrl_neutral1.png img/ctrl_neutral1.png image/png
            2021-03-07 21:18:12.843 - info: host.NUC(SmartHome1) iobroker upload [20] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/bitron_motion_a.png img/bitron_motion_a.png image/png
            2021-03-07 21:18:12.922 - info: host.NUC(SmartHome1) iobroker upload [19] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/bitron_motion.png img/bitron_motion.png image/png
            2021-03-07 21:18:13.015 - info: host.NUC(SmartHome1) iobroker upload [18] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/bitron_AV2010_24A.png img/bitron_AV2010_24A.png image/png
            2021-03-07 21:18:13.093 - info: host.NUC(SmartHome1) iobroker upload [17] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
            2021-03-07 21:18:13.187 - info: host.NUC(SmartHome1) iobroker upload [16] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/bitron_902010_29.png img/bitron_902010_29.png image/png
            2021-03-07 21:18:13.281 - info: host.NUC(SmartHome1) iobroker upload [15] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/bitron_902010_24.png img/bitron_902010_24.png image/png
            2021-03-07 21:18:13.374 - info: host.NUC(SmartHome1) iobroker upload [14] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/battery_v.png img/battery_v.png image/png
            2021-03-07 21:18:13.468 - info: host.NUC(SmartHome1) iobroker upload [13] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/battery_p.png img/battery_p.png image/png
            2021-03-07 21:18:13.546 - info: host.NUC(SmartHome1) iobroker upload [12] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/basiczbr3.png img/basiczbr3.png image/png
            2021-03-07 21:18:13.624 - info: host.NUC(SmartHome1) iobroker upload [11] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
            2021-03-07 21:18:13.702 - info: host.NUC(SmartHome1) iobroker upload [10] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/aqara_temperature_sensor.png img/aqara_temperature_sensor.png image/png
            2021-03-07 21:18:13.780 - info: host.NUC(SmartHome1) iobroker upload [9] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/aqara_switch.png img/aqara_switch.png image/png
            2021-03-07 21:18:13.859 - info: host.NUC(SmartHome1) iobroker upload [8] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/aqara_numan_body_sensor.png img/aqara_numan_body_sensor.png image/png
            2021-03-07 21:18:13.937 - info: host.NUC(SmartHome1) iobroker upload [7] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/aqara_curtain.png img/aqara_curtain.png image/png
            2021-03-07 21:18:14.030 - info: host.NUC(SmartHome1) iobroker upload [6] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/aqara_bulb.png img/aqara_bulb.png image/png
            2021-03-07 21:18:14.109 - info: host.NUC(SmartHome1) iobroker upload [5] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
            2021-03-07 21:18:14.187 - info: host.NUC(SmartHome1) iobroker upload [4] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
            2021-03-07 21:18:14.265 - info: host.NUC(SmartHome1) iobroker upload [3] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
            2021-03-07 21:18:14.374 - info: host.NUC(SmartHome1) iobroker upload [2] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/img/14147206L.png img/14147206L.png image/png
            2021-03-07 21:18:14.468 - info: host.NUC(SmartHome1) iobroker upload [1] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
            2021-03-07 21:18:14.577 - info: host.NUC(SmartHome1) iobroker upload [0] zigbee.admin C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
            2021-03-07 21:18:15.752 - info: host.NUC(SmartHome1) iobroker exit 0
            2021-03-07 21:18:17.710 - info: host.NUC(SmartHome1) Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
            2021-03-07 21:20:17.886 - info: host.NUC(SmartHome1) "system.adapter.zigbee.0" enabled
            2021-03-07 21:20:17.919 - info: host.NUC(SmartHome1) instance system.adapter.zigbee.0 started with pid 1136
            2021-03-07 21:20:29.196 - info: zigbee.0 (1136) starting. Version 1.4.5 in C:/Program Files/iobroker/SmartHome1/node_modules/iobroker.zigbee, node: v12.21.0, js-controller: 3.2.16
            2021-03-07 21:20:30.002 - info: zigbee.0 (1136) Starting Zigbee npm ...
            2021-03-07 21:20:31.126 - info: zigbee.0 (1136) Installed Version: ioBroker/ioBroker.zigbee#master
            2021-03-07 21:20:32.927 - info: zigbee.0 (1136) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190608}}
            2021-03-07 21:20:32.936 - info: zigbee.0 (1136) --> transmitPower : normal
            2021-03-07 21:20:32.945 - info: zigbee.0 (1136) Currently 21 devices are joined:
            2021-03-07 21:20:32.983 - info: zigbee.0 (1136) 0x00124b0022265671 (addr 43125): SNZB-04 - SONOFF Contact sensor (EndDevice)
            2021-03-07 21:20:32.986 - info: zigbee.0 (1136) 0x00124b0022e8f6bd (addr 15727): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
            2021-03-07 21:20:32.987 - info: zigbee.0 (1136) 0x00124b00226b164e (addr 44423): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
            2021-03-07 21:20:32.989 - info: zigbee.0 (1136) 0x00124b00223628f7 (addr 56025): SNZB-04 - SONOFF Contact sensor (EndDevice)
            2021-03-07 21:20:32.990 - info: zigbee.0 (1136) 0x00124b002225ba8f (addr 17687): SNZB-04 - SONOFF Contact sensor (EndDevice)
            2021-03-07 21:20:32.991 - info: zigbee.0 (1136) 0x00124b0022cd55b2 (addr 10549): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
            2021-03-07 21:20:32.992 - info: zigbee.0 (1136) 0x00124b0022265dd7 (addr 24577): SNZB-04 - SONOFF Contact sensor (EndDevice)
            2021-03-07 21:20:32.992 - info: zigbee.0 (1136) 0x00124b002235e616 (addr 26415): SNZB-04 - SONOFF Contact sensor (EndDevice)
            2021-03-07 21:20:32.993 - info: zigbee.0 (1136) 0x00124b002267004f (addr 57958): SNZB-04 - SONOFF Contact sensor (EndDevice)
            2021-03-07 21:20:32.999 - info: zigbee.0 (1136) 0x00124b0022670bb3 (addr 40869): SNZB-04 - SONOFF Contact sensor (EndDevice)
            2021-03-07 21:20:33.000 - info: zigbee.0 (1136) 0x00124b0022697ab6 (addr 16500): SNZB-04 - SONOFF Contact sensor (EndDevice)
            2021-03-07 21:20:33.001 - info: zigbee.0 (1136) 0x00124b002266f956 (addr 25269): SNZB-04 - SONOFF Contact sensor (EndDevice)
            2021-03-07 21:20:33.001 - info: zigbee.0 (1136) 0x00124b00226705f5 (addr 7257): SNZB-04 - SONOFF Contact sensor (EndDevice)
            2021-03-07 21:20:33.002 - info: zigbee.0 (1136) 0x842e14fffe52ef2d (addr 62946): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
            2021-03-07 21:20:33.003 - info: zigbee.0 (1136) 0xec1bbdfffed3e561 (addr 23918): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
            2021-03-07 21:20:33.003 - info: zigbee.0 (1136) 0x00124b0022eb6fe7 (addr 62555): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
            2021-03-07 21:20:33.004 - info: zigbee.0 (1136) 0x00124b0022cf6d65 (addr 58236): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
            2021-03-07 21:20:33.004 - info: zigbee.0 (1136) 0x00124b0022cf77c1 (addr 3866): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
            2021-03-07 21:20:33.005 - info: zigbee.0 (1136) 0x00124b0022cd397d (addr 7782): SNZB-03 - SONOFF Motion sensor (EndDevice)
            2021-03-07 21:20:33.006 - info: zigbee.0 (1136) 0x000d6f0011b41cb0 (addr 55765): 4058075816459 - OSRAM Smart+ switch (EndDevice)
            2021-03-07 21:20:33.006 - info: zigbee.0 (1136) 0x5c0272fffec57d1e (addr 57018): Not supported (model TS0601)(EndDevice)
            2021-03-07 21:20:33.006 - info: zigbee.0 (1136) Zigbee started
            2021-03-07 21:20:33.130 - error: zigbee.0 (1136) Device 0x5c0272fffec57d1e "TS0601" not described in statesMapping.
            2021-03-07 21:21:10.084 - info: zigbee.0 (1136) Zigbee: allowing new devices to join.
            2021-03-07 21:21:11.165 - warn: zigbee.0 (1136) Device '0x5c0272fffec57d1e' announced itself
            • F flitze-fitz
              arteckA Offline
              arteckA Offline
              arteck
              @flitze-fitz einz nach dem anderen..
              du hast ein cc2531... jetzt ist die frage ob der tuya nicht zigbee3 ist.. wenn doch dann hast du ein Problem.. das wird nicht gehen mit deinem Stick
              hast mal ein Bild von dem Teil ... wo hast du es gekauft,, Link ??
              • arteckA arteck
                flitze-fitz
                @arteck
                Das Thermostat hab ich bei Amazon gekauft:
                https://www.amazon.de/gp/product/B08M3LBMYP/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
                Der Stick ist von ebay. Allerdings sind die Sonoff Geräte ja auch alle Zigbee 3 und die funktionieren ja, dann sollten andere Zigbee 3 Komponenten doch auch gehen oder sehe ich das falsch?
                https://www.ebay.de/itm/CC2531-ZigBee-USB-Stick-zigbee2mqtt-ioBroker-FHEM-Xiaomi-SMA-Antenne/372933930792?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
                arteckA AsgothianA 2 Antworten Letzte Antwort
                • F flitze-fitz
                  @arteck
                  arteckA Offline
                  arteckA Offline
                  arteck
                  @Asgothian ne idee ?? mir sind die gerade ausgegangen
                  • F flitze-fitz
                    @arteck
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @flitze-fitz sagte in Galapara Thermostat / Zigbee / wird nicht konfiguriert:
                    • Dieser Thermostat kann prinzipiell unterstützt werden.
                    • Er ist bei zigbee2mqtt.io nicht als unterstützt gelistet.
                    • Es handelt sich um ein Tuya rebranded Thermostat. Da ist alles möglich.
                    Der wird ohne eine explizite Implementierung im Zigbee-Herdsman-Converters nicht funktionieren.
                    Das Fehler auftreten wenn er mit einem falschen Typ (TS0601) verbunden wird ist nicht weiter verwunderlich.
                    Nebenbei: Eine Suche bei Zigbee2mqtt.io nach TS0601 liefert 28 Geräte. Nur wenige davon sind Thermostate.
                    A.
                    Nachtrag: siehe auch Hier:https://forum.iobroker.net/topic/41439/closed-moes-zigbee-radiator-thermostat-aka-tuya?_=1615152678120 - da gab es schon einmal Diskussionen zu. Dieser Thermostat verhält sich nicht so wie die 'neueren' TuYa Thermostate.
                    • AsgothianA Asgothian
                      A.
                      flitze-fitz
                      @asgothian @arteck
                      Vielen Dank für eure Hilfe. Das klingt nicht so als wäre das ne kleine Sache. Also wahrscheinlich eher zurück mit dem Ding!?
                      Wisst ihr zufällig ein anderes Zigbee Heizkörperthermostat, dass mit dem Adapter auf jeden Fall funktioniert?
                      • F flitze-fitz
                        @asgothian @arteck
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @asgothian @arteck
                        Ich empfehle die Lektüre von https://www.zigbee2mqtt.io/information/supported_devices.html
                        Die dort hinterlegten Thermostate werden gehen. Es kann sein das bei einzelnen Funktionen im ioBroker noch Arbeit notwendig ist, das ist aber machbar.
                        A.
