  4. (?) ioBroker Restart ?
    5.4k
115 Beiträge 8 Kommentatoren 12.5k Aufrufe 7 Beobachtet
  • HumidorH Humidor
    Hallo 👍
    heute hat ioBroker durchgestartet, warum ?
    2021-02-23 13:00:24.241 - error: web.0 (343) read ECONNRESET
    2021-02-23 13:00:24.246 - error: web.0 (343) read ECONNRESET
    2021-02-23 13:00:24.292 - error: kecontact.0 (28905) read ECONNRESET
    2021-02-23 13:00:24.373 - error: mqtt.0 (313) read ECONNRESET
    2021-02-23 13:00:23.521 - error: backitup.0 (443) read ECONNRESET
    2021-02-23 13:00:23.540 - error: modbus.0 (599) read ECONNRESET
    2021-02-23 13:00:24.412 - info: web.0 (343) terminated http server on port 8082
    2021-02-23 13:00:24.490 - error: javascript.0 (360) read ECONNRESET
    2021-02-23 13:00:24.519 - info: backitup.0 (443) cleaned everything up...
    2021-02-23 13:00:24.501 - info: shelly.0 (504) Closing Adapter
    2021-02-23 13:00:24.558 - info: admin.0 (32223) terminating http server on port 8081
    2021-02-23 13:00:24.422 - info: cloud.0 (396) Connection changed: io client disconnect
    2021-02-23 13:00:24.567 - info: cloud.0 (396) Connection lost
    2021-02-23 13:00:24.631 - info: javascript.0 (360) Stop script script.js.common.AMIS
    2021-02-23 13:00:24.632 - info: javascript.0 (360) Stop script script.js.common.SE_Power
    2021-02-23 13:00:24.632 - info: javascript.0 (360) Stop script script.js.common.Powerbank
    2021-02-23 13:00:24.633 - info: javascript.0 (360) Stop script script.js.common.Grid-PV
    2021-02-23 13:00:24.633 - info: javascript.0 (360) Stop script script.js.common.SMA+SE
    2021-02-23 13:00:24.633 - info: javascript.0 (360) Stop script script.js.common.Zoe_Zielladung
    2021-02-23 13:00:24.634 - info: javascript.0 (360) Stop script script.js.common.PVÜberschuss
    2021-02-23 13:00:24.635 - info: javascript.0 (360) Stop script script.js.common.ZOE_Ladung
    2021-02-23 13:00:24.415 - info: vis-inventwo.0 (562) cleaned everything up...
    2021-02-23 13:00:24.537 - info: info.0 (32253) cleaned everything up...
    2021-02-23 13:00:24.712 - info: iot.0 (411) Connection changed: disconnect
    2021-02-23 13:00:24.817 - info: iot.0 (411) Connection lost
    2021-02-23 13:00:24.972 - info: influxdb.0 (521) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-02-23 13:00:25.921 - info: modbus.1 (614) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-02-23 13:00:25.975 - info: web.0 (343) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-02-23 13:00:25.982 - info: modbus.0 (599) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-02-23 13:00:26.010 - info: kecontact.0 (28905) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-02-23 13:00:25.972 - info: telegram.0 (426) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-02-23 13:00:26.034 - info: backitup.0 (443) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-02-23 13:00:26.052 - info: shelly.0 (504) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-02-23 13:00:26.061 - info: iot.0 (411) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-02-23 13:00:26.066 - info: admin.0 (32223) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-02-23 13:00:26.072 - info: cloud.0 (396) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-02-23 13:00:26.147 - info: javascript.0 (360) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-02-23 13:00:26.153 - info: vis-inventwo.0 (562) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-02-23 13:00:26.228 - info: mqtt.0 (313) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-02-23 13:00:26.307 - info: info.0 (32253) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-02-23 13:00:26.347 - info: discovery.0 (32238) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-02-23 13:00:24.906 - error: history.0 (379) write EPIPE
    2021-02-23 13:00:25.376 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:25.377 - error: history.0 (379) Error: write EPIPE
    at ChildProcess.target._send (internal/child_process.js:762:20)
    at ChildProcess.target.send (internal/child_process.js:634:19)
    at cacheData (/opt/iobroker/node_modules/iobroker.history/main.js:1061:28)
    at getCachedData (/opt/iobroker/node_modules/iobroker.history/main.js:837:5)
    at ChildProcess.gh.on.data (/opt/iobroker/node_modules/iobroker.history/main.js:1060:21)
    at ChildProcess.emit (events.js:198:13)
    at ChildProcess.EventEmitter.emit (domain.js:448:20)
    at emit (internal/child_process.js:832:12)
    at process._tickCallback (internal/process/next_tick.js:63:19)
    2021-02-23 13:00:28.315 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.316 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.325 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.325 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.332 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.332 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.338 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.339 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.345 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.345 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.355 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.356 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.362 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.362 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.369 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.369 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.375 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.375 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.382 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.382 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.388 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.389 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.395 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.395 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.402 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.402 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.409 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.410 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.417 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.417 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.424 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.424 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.432 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.433 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.443 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.443 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.450 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.451 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.461 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.462 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.468 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.469 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.475 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.475 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.481 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.482 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.488 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.488 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.495 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.495 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.501 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.501 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.508 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.508 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.514 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.515 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.521 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.521 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.527 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.528 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.534 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.534 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.540 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.541 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.547 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.547 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.554 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.554 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.562 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.563 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.569 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.569 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.576 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.576 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.582 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.582 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.589 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.589 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.595 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.596 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.602 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.602 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.608 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.609 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.615 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.615 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.622 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.622 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:28.628 - error: history.0 (379) uncaught exception: write EPIPE
    2021-02-23 13:00:28.629 - error: history.0 (379) Error: write EPIPE
    2021-02-23 13:00:29.455 - warn: history.0 (379) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2021-02-23 13:00:31.888 - info: host.ioBrokerPV iobroker.js-controller version 3.1.6 js-controller starting
    2021-02-23 13:00:31.896 - info: host.ioBrokerPV Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
    2021-02-23 13:00:31.896 - info: host.ioBrokerPV hostname: ioBrokerPV, node: v10.23.2
    2021-02-23 13:00:31.898 - info: host.ioBrokerPV ip addresses: 192.168.0.90 fe80::fee:6909:ef35:4b7c 192.168.0.91 fe80::4c05:dc71:99cb:8ad5
    2021-02-23 13:00:32.569 - info: host.ioBrokerPV connected to Objects and States
    2021-02-23 13:00:33.068 - info: host.ioBrokerPV 28 instances found
    2021-02-23 13:00:33.123 - info: host.ioBrokerPV starting 22 instances
    2021-02-23 13:00:33.170 - info: host.ioBrokerPV instance system.adapter.admin.0 started with pid 14148
    2021-02-23 13:00:35.451 - info: admin.0 (14148) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v10.23.2, js-controller: 3.1.6
    2021-02-23 13:00:35.522 - info: admin.0 (14148) requesting all states
    2021-02-23 13:00:35.523 - info: admin.0 (14148) requesting all objects
    2021-02-23 13:00:36.957 - info: admin.0 (14148) received all objects
    2021-02-23 13:00:37.154 - info: host.ioBrokerPV instance system.adapter.discovery.0 started with pid 14165
    2021-02-23 13:00:37.218 - info: admin.0 (14148) http server listening on port 8081
    2021-02-23 13:00:37.218 - info: admin.0 (14148) Use link "http://localhost:8081" to configure.
    2021-02-23 13:00:38.834 - info: discovery.0 (14165) starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v10.23.2, js-controller: 3.1.6
    2021-02-23 13:00:41.168 - info: host.ioBrokerPV instance system.adapter.info.0 started with pid 14180
    2021-02-23 13:00:44.567 - info: info.0 (14180) starting. Version 1.7.14 in /opt/iobroker/node_modules/iobroker.info, node: v10.23.2, js-controller: 3.1.6
    2021-02-23 13:00:45.161 - info: host.ioBrokerPV instance system.adapter.kecontact.0 started with pid 14272
    2021-02-23 13:00:47.677 - info: kecontact.0 (14272) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.kecontact, node: v10.23.2, js-controller: 3.1.6
    2021-02-23 13:00:49.466 - info: host.ioBrokerPV instance system.adapter.mqtt.0 started with pid 14703
    2021-02-23 13:00:50.915 - info: mqtt.0 (14703) starting. Version 2.3.4 in /opt/iobroker/node_modules/iobroker.mqtt, node: v10.23.2, js-controller: 3.1.6
    2021-02-23 13:00:51.264 - info: mqtt.0 (14703) Starting MQTT server on 0.0.0.0:1883
    2021-02-23 13:00:52.978 - info: kecontact.0 (14272) starting charging station in passive mode
    2021-02-23 13:00:53.155 - info: host.ioBrokerPV instance system.adapter.web.0 started with pid 14718
    2021-02-23 13:00:53.349 - info: kecontact.0 (14272) vehicle plugged to wallbox
    2021-02-23 13:00:54.709 - info: web.0 (14718) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.web, node: v10.23.2, js-controller: 3.1.6
    2021-02-23 13:00:54.972 - info: web.0 (14718) socket.io server listening on port 8082
    2021-02-23 13:00:54.977 - info: web.0 (14718) http server listening on port 8082
    2021-02-23 13:00:57.025 - info: mqtt.0 (14703) Client [AMIS] connected with secret 1614081657016_9468
    2021-02-23 13:00:57.163 - info: host.ioBrokerPV instance system.adapter.javascript.0 started with pid 14735
    2021-02-23 13:00:57.379 - info: web.0 (14718) ==>Connected system.user.admin from 192.168.0.182
    2021-02-23 13:00:57.632 - info: web.0 (14718) <==Disconnect system.user.admin from 192.168.0.182 vis.0
    2021-02-23 13:00:58.886 - info: web.0 (14718) ==>Connected system.user.admin from 192.168.0.182
    2021-02-23 13:01:00.428 - info: javascript.0 (14735) starting. Version 4.8.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v10.23.2, js-controller: 3.1.6
    2021-02-23 13:01:00.585 - info: javascript.0 (14735) requesting all states
    2021-02-23 13:01:00.588 - info: javascript.0 (14735) requesting all objects
    2021-02-23 13:01:01.215 - info: host.ioBrokerPV instance system.adapter.history.0 started with pid 14750
    2021-02-23 13:01:01.724 - info: javascript.0 (14735) received all objects
    2021-02-23 13:01:01.753 - info: javascript.0 (14735) received all states
    2021-02-23 13:01:02.006 - info: javascript.0 (14735) Start javascript script.js.common.AMIS
    2021-02-23 13:01:02.095 - info: javascript.0 (14735) script.js.common.AMIS: registered 1 subscription and 0 schedules
    2021-02-23 13:01:02.096 - info: javascript.0 (14735) Start javascript script.js.common.SE_Power
    2021-02-23 13:01:02.110 - info: javascript.0 (14735) script.js.common.SE_Power: registered 0 subscriptions and 0 schedules
    2021-02-23 13:01:02.111 - info: javascript.0 (14735) Start javascript script.js.common.Powerbank
    2021-02-23 13:01:02.117 - info: javascript.0 (14735) script.js.common.Powerbank: registered 1 subscription and 0 schedules
    2021-02-23 13:01:02.118 - info: javascript.0 (14735) Start javascript script.js.common.Grid-PV
    2021-02-23 13:01:02.124 - info: javascript.0 (14735) script.js.common.Grid-PV: registered 1 subscription and 0 schedules
    2021-02-23 13:01:02.125 - info: javascript.0 (14735) Start javascript script.js.common.SMA+SE
    2021-02-23 13:01:02.130 - info: javascript.0 (14735) script.js.common.SMA+SE: registered 1 subscription and 0 schedules
    2021-02-23 13:01:02.131 - info: javascript.0 (14735) Start javascript script.js.common.Zoe_Zielladung
    2021-02-23 13:01:02.136 - info: javascript.0 (14735) script.js.common.Zoe_Zielladung: registered 1 subscription and 0 schedules
    2021-02-23 13:01:02.144 - info: javascript.0 (14735) Start javascript script.js.common.PVÜberschuss
    2021-02-23 13:01:02.150 - info: javascript.0 (14735) script.js.common.PVÜberschuss: registered 1 subscription and 0 schedules
    2021-02-23 13:01:02.151 - info: javascript.0 (14735) Start javascript script.js.common.ZOE_Ladung
    2021-02-23 13:01:02.176 - info: javascript.0 (14735) script.js.common.ZOE_Ladung: registered 3 subscriptions and 1 schedule
    2021-02-23 13:01:02.933 - info: history.0 (14750) starting. Version 1.9.12 in /opt/iobroker/node_modules/iobroker.history, node: v10.23.2, js-controller: 3.1.6
    2021-02-23 13:01:03.005 - info: history.0 (14750) enabled logging of kecontact.0.pf (Count=1), Alias=false
    2021-02-23 13:01:03.006 - info: history.0 (14750) enabled logging of kecontact.0.p (Count=2), Alias=false
    2021-02-23 13:01:03.006 - info: history.0 (14750) enabled logging of kecontact.0.currentUser (Count=3), Alias=false
    2021-02-23 13:01:03.007 - info: history.0 (14750) enabled logging of mqtt.0.info.connection (Count=4), Alias=false
    2021-02-23 13:01:03.007 - info: history.0 (14750) enabled logging of 0_userdata.0.AMIS.170 (Count=5), Alias=false
    2021-02-23 13:01:03.007 - info: history.0 (14750) enabled logging of 0_userdata.0.AMIS.270 (Count=6), Alias=false
    2021-02-23 13:01:03.008 - info: history.0 (14750) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Switch (Count=7), Alias=false
    2021-02-23 13:01:03.008 - info: history.0 (14750) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Power (Count=8), Alias=false
    2021-02-23 13:01:03.008 - info: history.0 (14750) enabled logging of 0_userdata.0.AMIS.Power (Count=9), Alias=false
    2021-02-23 13:01:03.009 - info: history.0 (14750) enabled logging of kecontact.0.currentTimer (Count=10), Alias=false
    2021-02-23 13:01:03.009 - info: history.0 (14750) enabled logging of modbus.0.inputRegisters.30775_PVLeistung (Count=11), Alias=false
    2021-02-23 13:01:03.009 - info: history.0 (14750) enabled logging of javascript.0.Solar.Wechselrichter.PVLeistungAktuell (Count=12), Alias=false
    2021-02-23 13:01:03.009 - info: history.0 (14750) enabled logging of 0_userdata.0.AMIS.PVPower (Count=13), Alias=false
    2021-02-23 13:01:03.021 - info: history.0 (14750) enabled logging of 0_userdata.0.AMIS.PVÜberschuss (Count=14), Alias=false
    2021-02-23 13:01:05.510 - info: host.ioBrokerPV instance system.adapter.cloud.0 started with pid 14765
    2021-02-23 13:01:07.383 - info: cloud.0 (14765) starting. Version 4.0.4 in /opt/iobroker/node_modules/iobroker.cloud, node: v10.23.2, js-controller: 3.1.6
    2021-02-23 13:01:07.461 - info: cloud.0 (14765) Connecting with https://iobroker.net:10555 with "richard.nussdorfer@gmail.com_65a2cba0-c435-11ea-b03c-2dda666d26a"
    2021-02-23 13:01:07.735 - info: cloud.0 (14765) Trying to connect as system.user.admin
    2021-02-23 13:01:08.103 - info: cloud.0 (14765) Adapter redirected temporally to "https://iobroker.net:10556" in one minute. Reason: command from server
    2021-02-23 13:01:08.109 - info: cloud.0 (14765) Connection changed: io client disconnect
    2021-02-23 13:01:09.145 - info: host.ioBrokerPV instance system.adapter.iot.0 started with pid 14782
    2021-02-23 13:01:10.003 - info: javascript.0 (14735) script.js.common.ZOE_Ladung: --- Regelzyklus PV beginnt ---
    2021-02-23 13:01:10.004 - info: javascript.0 (14735) script.js.common.ZOE_Ladung: PV / aktuelle Grid-Überschussleistung (W): 2205
    2021-02-23 13:01:10.004 - info: javascript.0 (14735) script.js.common.ZOE_Ladung: --- Regelzyklus beendet ---
    2021-02-23 13:01:11.516 - info: iot.0 (14782) starting. Version 1.8.9 in /opt/iobroker/node_modules/iobroker.iot, node: v10.23.2, js-controller: 3.1.6
    2021-02-23 13:01:11.584 - info: iot.0 (14782) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    2021-02-23 13:01:12.271 - info: iot.0 (14782) Connection changed: connect
    2021-02-23 13:01:13.159 - info: host.ioBrokerPV instance system.adapter.telegram.0 started with pid 14797
    2021-02-23 13:01:15.633 - info: telegram.0 (14797) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v10.23.2, js-controller: 3.1.6
    2021-02-23 13:01:17.152 - info: host.ioBrokerPV instance system.adapter.backitup.0 started with pid 14814
    2021-02-23 13:01:20.002 - info: javascript.0 (14735) script.js.common.ZOE_Ladung: --- Regelzyklus PV beginnt ---
    2021-02-23 13:01:20.003 - info: javascript.0 (14735) script.js.common.ZOE_Ladung: PV / aktuelle Grid-Überschussleistung (W): 2186
    2021-02-23 13:01:20.003 - info: javascript.0 (14735) script.js.common.ZOE_Ladung: --- Regelzyklus beendet ---
    2021-02-23 13:01:21.565 - info: backitup.0 (14814) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.23.2, js-controller: 3.1.6
    2021-02-23 13:01:21.623 - info: backitup.0 (14814) [iobroker] backup was activated at 06:15 every 1 day(s)
    2021-02-23 13:01:22.503 - info: vis.0 (14825) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.vis, node: v10.23.2, js-controller: 3.1.6
    2021-02-23 13:01:22.825 - info: vis.0 (14825) vis license is OK.
    2021-02-23 13:01:24.444 - info: vis.0 (14825) Terminated (NO_ERROR): Without reason
    2021-02-23 13:01:24.967 - info: host.ioBrokerPV instance system.adapter.vis.0 terminated while should be started once
    2021-02-23 13:01:25.145 - info: host.ioBrokerPV instance system.adapter.shelly.0 started with pid 14852
    2021-02-23 13:01:27.507 - info: shelly.0 (14852) starting. Version 4.0.6 in /opt/iobroker/node_modules/iobroker.shelly, node: v10.23.2, js-controller: 3.1.6
    2021-02-23 13:01:27.541 - info: shelly.0 (14852) Starting Adapter shelly.0 in version 4.0.6
    2021-02-23 13:01:27.541 - info: shelly.0 (14852) Polltime of the shelly devices: 5 sec.
    2021-02-23 13:01:27.583 - info: shelly.0 (14852) Starting Shelly adapter in CoAP modus.
    2021-02-23 13:01:27.752 - info: shelly.0 (14852) Listening for Shelly packets in the network
    2021-02-23 13:01:29.151 - info: host.ioBrokerPV instance system.adapter.influxdb.0 started with pid 14869
    2021-02-23 13:01:29.730 - info: shelly.0 (14852) Shelly device 192.168.0.80 (shellyplug-s / shellyplug-s-EED8F9 / SHPLG-S#EED8F9#1) with CoAP connected!
    2021-02-23 13:01:30.001 - info: javascript.0 (14735) script.js.common.ZOE_Ladung: --- Regelzyklus PV beginnt ---
    2021-02-23 13:01:30.002 - info: javascript.0 (14735) script.js.common.ZOE_Ladung: PV / aktuelle Grid-Überschussleistung (W): 2162
    2021-02-23 13:01:30.002 - info: javascript.0 (14735) script.js.common.ZOE_Ladung: --- Regelzyklus beendet ---
    2021-02-23 13:01:31.266 - info: influxdb.0 (14869) starting. Version 1.9.4 in /opt/iobroker/node_modules/iobroker.influxdb, node: v10.23.2, js-controller: 3.1.6
    2021-02-23 13:01:31.303 - info: influxdb.0 (14869) No stored data from last exit found
    2021-02-23 13:01:31.306 - info: influxdb.0 (14869) Connecting http://localhost:8086 ...
    2021-02-23 13:01:31.381 - info: influxdb.0 (14869) enabled logging of kecontact.0.pf, Alias=false, 1 points now activated
    2021-02-23 13:01:31.383 - info: influxdb.0 (14869) enabled logging of kecontact.0.p, Alias=false, 2 points now activated
    2021-02-23 13:01:31.384 - info: influxdb.0 (14869) enabled logging of kecontact.0.currentUser, Alias=false, 3 points now activated
    2021-02-23 13:01:31.385 - info: influxdb.0 (14869) enabled logging of 0_userdata.0.AMIS.170, Alias=false, 4 points now activated
    2021-02-23 13:01:31.387 - info: influxdb.0 (14869) enabled logging of 0_userdata.0.AMIS.270, Alias=false, 5 points now activated
    2021-02-23 13:01:31.389 - info: influxdb.0 (14869) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Switch, Alias=false, 6 points now activated
    2021-02-23 13:01:31.390 - info: influxdb.0 (14869) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Power, Alias=false, 7 points now activated
    2021-02-23 13:01:31.391 - info: influxdb.0 (14869) enabled logging of 0_userdata.0.AMIS.Power, Alias=false, 8 points now activated
    2021-02-23 13:01:31.392 - info: influxdb.0 (14869) enabled logging of kecontact.0.currentTimer, Alias=false, 9 points now activated
    2021-02-23 13:01:31.393 - info: influxdb.0 (14869) enabled logging of modbus.0.inputRegisters.30775_PVLeistung, Alias=false, 10 points now activated
    2021-02-23 13:01:31.394 - info: influxdb.0 (14869) enabled logging of javascript.0.Solar.Wechselrichter.PVLeistungAktuell, Alias=false, 11 points now activated
    2021-02-23 13:01:31.395 - info: influxdb.0 (14869) enabled logging of 0_userdata.0.AMIS.PVPower, Alias=false, 12 points now activated
    2021-02-23 13:01:31.396 - info: influxdb.0 (14869) enabled logging of 0_userdata.0.AMIS.PVÜberschuss, Alias=false, 13 points now activated
    2021-02-23 13:01:31.455 - info: influxdb.0 (14869) Connected!
    2021-02-23 13:01:33.178 - info: host.ioBrokerPV instance system.adapter.vis-inventwo.0 started with pid 14887
    @humidor
    dmesg
    sagt? Insbesondere der letzte / neueste Teil.
    HumidorH 1 Antwort Letzte Antwort
      @humidor
      dmesg
      HumidorH Online
      HumidorH Online
      Humidor
      schrieb am zuletzt editiert von Humidor
      @thomas-braun keine Ahnung....
      achso du meinst ich soll das am Pi eingeben. OK. Moment.
      pi@ioBrokerPV:~ $ dmesg
      [    0.000000] Booting Linux on physical CPU 0x0
      [    0.000000] Linux version 5.4.83-v7l+ (dom@buildbot) (gcc version 8.4.0 (Ubuntu/Linaro 8.4.0-3ubuntu1)) #1379 SMP Mon Dec 14 13:11:54 GMT 2020
      [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
      [    0.000000] CPU: div instructions available: patching division code
      [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
      [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
      [    0.000000] Memory policy: Data cache writealloc
      [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
      [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
      [    0.000000] On node 0 totalpages: 507648
      [    0.000000]   DMA zone: 2304 pages used for memmap
      [    0.000000]   DMA zone: 0 pages reserved
      [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
      [    0.000000]   HighMem zone: 311040 pages, LIFO batch:63
      [    0.000000] percpu: Embedded 20 pages/cpu s49804 r8192 d23924 u81920
      [    0.000000] pcpu-alloc: s49804 r8192 d23924 u81920 alloc=20*4096
      [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 505344
      [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:14:C2:9A vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=14523b9e-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
      [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
      [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
      [    0.000000] software IO TLB: mapped [mem 0x19400000-0x1d400000] (64MB)
      [    0.000000] Memory: 1658916K/2030592K available (10240K kernel code, 739K rwdata, 2816K rodata, 2048K init, 854K bss, 109532K reserved, 262144K cma-reserved, 1244160K highmem)
      [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [    0.000000] ftrace: allocating 31115 entries in 61 pages
      [    0.000000] rcu: Hierarchical RCU implementation.
      [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
      [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      [    0.000000] GIC: Using split EOI/Deactivate mode
      [    0.000000] random: get_random_bytes called from start_kernel+0x344/0x518 with crng_init=0
      [    0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
      [    0.000030] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
      [    0.000110] bcm2835: system timer (irq = 17)
      [    0.000757] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
      [    0.000777] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
      [    0.000797] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
      [    0.000813] Switching to timer-based delay loop, resolution 18ns
      [    0.001052] Console: colour dummy device 80x30
      [    0.001551] printk: console [tty1] enabled
      [    0.001615] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
      [    0.001658] pid_max: default: 32768 minimum: 301
      [    0.001818] LSM: Security Framework initializing
      [    0.002022] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      [    0.002064] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
      [    0.003428] Disabling memory control group subsystem
      [    0.003564] CPU: Testing write buffer coherency: ok
      [    0.004087] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.005011] Setting up static identity map for 0x200000 - 0x20003c
      [    0.005233] rcu: Hierarchical SRCU implementation.
      [    0.005925] smp: Bringing up secondary CPUs ...
      [    0.007122] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.008440] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
      [    0.009697] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
      [    0.009857] smp: Brought up 1 node, 4 CPUs
      [    0.009930] SMP: Total of 4 processors activated (432.00 BogoMIPS).
      [    0.009957] CPU: All CPU(s) started in HYP mode.
      [    0.009981] CPU: Virtualization extensions available.
      [    0.010815] devtmpfs: initialized
      [    0.024515] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
      [    0.024801] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.024851] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
      [    0.031665] pinctrl core: initialized pinctrl subsystem
      [    0.032669] NET: Registered protocol family 16
      [    0.036491] DMA: preallocated 1024 KiB pool for atomic coherent allocations
      [    0.037087] audit: initializing netlink subsys (disabled)
      [    0.037374] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
      [    0.038411] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
      [    0.038447] hw-breakpoint: maximum watchpoint size is 8 bytes.
      [    0.038783] Serial: AMBA PL011 UART driver
      [    0.042316] bcm2835-mbox fe00b880.mailbox: mailbox enabled
      [    0.060830] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-01-08 14:31, variant start
      [    0.070845] raspberrypi-firmware soc:firmware: Firmware hash is 194a85abd768c7334bbadc3f1911c10a7d18ed14
      [    0.125488] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
      [    0.129408] vgaarb: loaded
      [    0.129873] SCSI subsystem initialized
      [    0.130107] usbcore: registered new interface driver usbfs
      [    0.130180] usbcore: registered new interface driver hub
      [    0.130316] usbcore: registered new device driver usb
      [    0.130654] usb_phy_generic phy: phy supply vcc not found, using dummy regulator
      [    0.132462] clocksource: Switched to clocksource arch_sys_counter
      [    0.890673] VFS: Disk quotas dquot_6.6.0
      [    0.890797] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
      [    0.890978] FS-Cache: Loaded
      [    0.891185] CacheFiles: Loaded
      [    0.901454] thermal_sys: Registered thermal governor 'step_wise'
      [    0.901833] NET: Registered protocol family 2
      [    0.902902] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [    0.902956] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
      [    0.903037] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [    0.903124] TCP: Hash tables configured (established 8192 bind 8192)
      [    0.903290] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
      [    0.903342] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
      [    0.903616] NET: Registered protocol family 1
      [    0.904360] RPC: Registered named UNIX socket transport module.
      [    0.904390] RPC: Registered udp transport module.
      [    0.904416] RPC: Registered tcp transport module.
      [    0.904441] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    0.904476] PCI: CLS 0 bytes, default 64
      [    0.906323] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
      [    0.908574] Initialise system trusted keyrings
      [    0.908817] workingset: timestamp_bits=14 max_order=19 bucket_order=5
      [    0.919808] FS-Cache: Netfs 'nfs' registered for caching
      [    0.920553] NFS: Registering the id_resolver key type
      [    0.920614] Key type id_resolver registered
      [    0.920640] Key type id_legacy registered
      [    0.920676] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      [    0.921773] Key type asymmetric registered
      [    0.921803] Asymmetric key parser 'x509' registered
      [    0.922004] bounce: pool size: 64 pages
      [    0.922079] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
      [    0.922339] io scheduler mq-deadline registered
      [    0.922369] io scheduler kyber registered
      [    0.926446] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
      [    0.926490] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
      [    0.926582] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
      [    0.926673] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x007fffffff -> 0x0400000000
      [    0.984610] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
      [    0.984934] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
      [    0.984970] pci_bus 0000:00: root bus resource [bus 00-ff]
      [    0.985004] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
      [    0.985083] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
      [    0.985368] pci 0000:00:00.0: PME# supported from D0 D3hot
      [    0.988620] PCI: bus0: Fast back to back transfers disabled
      [    0.988877] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
      [    0.989040] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
      [    0.989491] pci 0000:01:00.0: PME# supported from D0 D3cold
      [    0.992761] PCI: bus1: Fast back to back transfers disabled
      [    0.992836] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
      [    0.992875] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
      [    0.992976] pci 0000:00:00.0: PCI bridge to [bus 01]
      [    0.993014] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
      [    0.993343] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
      [    0.993590] pcieport 0000:00:00.0: PME: Signaling with IRQ 56
      [    0.994007] pcieport 0000:00:00.0: AER: enabled with IRQ 56
      [    0.994360] pci 0000:01:00.0: enabling device (0140 -> 0142)
      [    1.001437] iproc-rng200 fe104000.rng: hwrng registered
      [    1.001798] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
      [    1.002535] vc-sm: Videocore shared memory driver
      [    1.003125] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
      [    1.015394] brd: module loaded
      [    1.027878] loop: module loaded
      [    1.029319] Loading iSCSI transport class v2.0-870.
      [    1.031338] libphy: Fixed MDIO Bus: probed
      [    1.031972] bcmgenet fd580000.ethernet: failed to get enet clock
      [    1.032008] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
      [    1.032045] bcmgenet fd580000.ethernet: failed to get enet-wol clock
      [    1.032082] bcmgenet fd580000.ethernet: failed to get enet-eee clock
      [    1.032123] bcmgenet: Skipping UMAC reset
      [    1.052545] libphy: bcmgenet MII bus: probed
      [    1.142663] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
      [    1.143822] usbcore: registered new interface driver r8152
      [    1.143905] usbcore: registered new interface driver lan78xx
      [    1.143979] usbcore: registered new interface driver smsc95xx
      [    1.144487] xhci_hcd 0000:01:00.0: xHCI Host Controller
      [    1.144537] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
      [    1.147808] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000003000000890
      [    1.149151] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
      [    1.149190] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    1.149225] usb usb1: Product: xHCI Host Controller
      [    1.149254] usb usb1: Manufacturer: Linux 5.4.83-v7l+ xhci-hcd
      [    1.149283] usb usb1: SerialNumber: 0000:01:00.0
      [    1.149907] hub 1-0:1.0: USB hub found
      [    1.150017] hub 1-0:1.0: 1 port detected
      [    1.150565] xhci_hcd 0000:01:00.0: xHCI Host Controller
      [    1.150606] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
      [    1.150649] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
      [    1.151149] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
      [    1.151186] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    1.151219] usb usb2: Product: xHCI Host Controller
      [    1.151247] usb usb2: Manufacturer: Linux 5.4.83-v7l+ xhci-hcd
      [    1.151276] usb usb2: SerialNumber: 0000:01:00.0
      [    1.151900] hub 2-0:1.0: USB hub found
      [    1.151997] hub 2-0:1.0: 4 ports detected
      [    1.153517] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
      [    1.153829] dwc_otg: FIQ enabled
      [    1.153841] dwc_otg: NAK holdoff enabled
      [    1.153854] dwc_otg: FIQ split-transaction FSM enabled
      [    1.153881] Module dwc_common_port init
      [    1.154390] usbcore: registered new interface driver uas
      [    1.154510] usbcore: registered new interface driver usb-storage
      [    1.154722] mousedev: PS/2 mouse device common for all mice
      [    1.156617] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
      [    1.160083] sdhci: Secure Digital Host Controller Interface driver
      [    1.160115] sdhci: Copyright(c) Pierre Ossman
      [    1.160767] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
      [    1.161383] sdhci-pltfm: SDHCI platform and OF driver helper
      [    1.165399] ledtrig-cpu: registered to indicate activity on CPUs
      [    1.165728] hidraw: raw HID events driver (C) Jiri Kosina
      [    1.165926] usbcore: registered new interface driver usbhid
      [    1.165953] usbhid: USB HID core driver
      [    1.167011] vchiq: vchiq_init_state: slot_zero = (ptrval)
      [    1.168967] [vc_sm_connected_init]: start
      [    1.177788] [vc_sm_connected_init]: end - returning 0
      [    1.180055] Initializing XFRM netlink socket
      [    1.180110] NET: Registered protocol family 17
      [    1.180250] Key type dns_resolver registered
      [    1.180592] Registering SWP/SWPB emulation handler
      [    1.180917] registered taskstats version 1
      [    1.180950] Loading compiled-in X.509 certificates
      [    1.181484] Key type ._fscrypt registered
      [    1.181512] Key type .fscrypt registered
      [    1.192336] uart-pl011 fe201000.serial: cts_event_workaround enabled
      [    1.192428] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
      [    1.198662] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
      [    1.199659] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
      [    1.199692] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
      [    1.247967] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
      [    1.249657] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    1.251342] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    1.254357] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
      [    1.256041] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    1.262903] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
      [    1.265849] of_cfs_init
      [    1.265983] of_cfs_init: OK
      [    1.267239] Waiting for root device PARTUUID=14523b9e-02...
      [    1.301935] random: fast init done
      [    1.326752] mmc1: new high speed SDIO card at address 0001
      [    1.512499] usb 1-1: new high-speed USB device number 2 using xhci_hcd
      [    1.695222] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
      [    1.695260] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
      [    1.695292] usb 1-1: Product: USB2.0 Hub
      [    1.697005] hub 1-1:1.0: USB hub found
      [    1.697323] hub 1-1:1.0: 4 ports detected
      [    1.842941] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
      [    1.874320] usb 2-2: New USB device found, idVendor=174c, idProduct=5136, bcdDevice= 0.01
      [    1.874358] usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
      [    1.874389] usb 2-2: Product: AS2105
      [    1.874416] usb 2-2: Manufacturer: ASMedia
      [    1.874443] usb 2-2: SerialNumber: 00000000000000000000
      [    1.877778] usb-storage 2-2:1.0: USB Mass Storage device detected
      [    1.878376] scsi host0: usb-storage 2-2:1.0
      [    2.953293] scsi 0:0:0:0: Direct-Access     ASMT     2105             0    PQ: 0 ANSI: 6
      [    2.954369] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
      [    2.955192] sd 0:0:0:0: [sda] Write Protect is off
      [    2.955226] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
      [    2.955927] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
      [    2.959124]  sda: sda1 sda2
      [    2.962323] sd 0:0:0:0: [sda] Attached SCSI disk
      [    2.985857] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
      [    2.985955] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [    2.992548] devtmpfs: mounted
      [    3.001232] Freeing unused kernel memory: 2048K
      [    3.032818] Run /sbin/init as init process
      [    3.270370] systemd[1]: System time before build time, advancing clock.
      [    3.363714] NET: Registered protocol family 10
      [    3.365066] Segment Routing with IPv6
      [    3.395253] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
      [    3.396065] systemd[1]: Detected architecture arm.
      [    3.447559] systemd[1]: Set hostname to <ioBrokerPV>.
      [    4.089030] random: systemd: uninitialized urandom read (16 bytes read)
      [    4.103067] random: systemd: uninitialized urandom read (16 bytes read)
      [    4.103805] systemd[1]: Listening on Syslog Socket.
      [    4.104706] random: systemd: uninitialized urandom read (16 bytes read)
      [    4.105293] systemd[1]: Listening on udev Kernel Socket.
      [    4.107872] systemd[1]: Created slice User and Session Slice.
      [    4.108446] systemd[1]: Reached target Slices.
      [    4.109928] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
      [    4.111459] systemd[1]: Listening on Journal Audit Socket.
      [    4.112355] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
      [    4.294782] i2c /dev entries driver
      [    4.789816] EXT4-fs (sda2): re-mounted. Opts: (null)
      [    4.879796] systemd-journald[115]: Received request to flush runtime journal from PID 1
      [    5.381756] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
      [    5.382507] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
      [    5.386480] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
      [    5.387029] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
      [    5.449035] mc: Linux media interface: v0.10
      [    5.490013] videodev: Linux video capture interface: v2.00
      [    5.494118] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.494643] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.496646] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
      [    5.496667] [vc_sm_connected_init]: start
      [    5.499868] [vc_sm_connected_init]: installed successfully
      [    5.511637] bcm2835_audio bcm2835_audio: card created with 8 channels
      [    5.527633] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.559826] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.568581] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.573774] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
      [    5.573824] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
      [    5.580299] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
      [    5.581586] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
      [    5.581625] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
      [    5.597004] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
      [    5.597062] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
      [    5.614210] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
      [    5.615575] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
      [    5.617972] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
      [    5.620690] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
      [    5.620719] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
      [    5.620742] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
      [    5.620762] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
      [    5.620782] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
      [    5.625189] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
      [    5.774398] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    5.910386] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
      [    5.918927] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    5.978552] [drm] No displays found. Consider forcing hotplug if HDMI is attached
      [    5.978672] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
      [    5.978699] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
      [    5.978712] [drm] No driver support for vblank timestamp query.
      [    5.978724] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
      [    5.985556] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
      [    5.985756] brcmfmac: F1 signature read @0x18000000=0x15264345
      [    6.002762] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      [    6.004462] usbcore: registered new interface driver brcmfmac
      [    6.043674] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
      [    6.051602] sd 0:0:0:0: Attached scsi generic sg0 type 0
      [    6.283705] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      [    6.295248] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
      [    7.428867] random: crng init done
      [    7.428883] random: 7 urandom warning(s) missed due to ratelimiting
      [    8.290679] uart-pl011 fe201000.serial: no DMA platform data
      [    8.470020] 8021q: 802.1Q VLAN Support v1.8
      [    8.672491] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
      [    8.776303] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
      [    9.003674] bcmgenet: Skipping UMAC reset
      [    9.005311] bcmgenet fd580000.ethernet: configuring instance for external RGMII
      [    9.005500] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
      [    9.832535] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      [   14.171497] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
      [   15.228215] Bluetooth: Core ver 2.22
      [   15.228274] NET: Registered protocol family 31
      [   15.228282] Bluetooth: HCI device and connection manager initialized
      [   15.228301] Bluetooth: HCI socket layer initialized
      [   15.228314] Bluetooth: L2CAP socket layer initialized
      [   15.228333] Bluetooth: SCO socket layer initialized
      [   15.264258] Bluetooth: HCI UART driver ver 2.3
      [   15.264270] Bluetooth: HCI UART protocol H4 registered
      [   15.264337] Bluetooth: HCI UART protocol Three-wire (H5) registered
      [   15.264581] Bluetooth: HCI UART protocol Broadcom registered
      [   15.910941] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      [   15.910948] Bluetooth: BNEP filters: protocol multicast
      [   15.910960] Bluetooth: BNEP socket layer initialized
      [   68.844770] FS-Cache: Netfs 'cifs' registered for caching
      [   68.858589] Key type cifs.spnego registered
      [   68.858609] Key type cifs.idmap registered
      [   68.859357] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
      [17832.749972] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
      [82325.779313] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
      [83225.012258] node invoked oom-killer: gfp_mask=0x400dc2(GFP_KERNEL_ACCOUNT|__GFP_HIGHMEM|__GFP_ZERO), order=0, oom_score_adj=0
      [83225.012268] CPU: 2 PID: 31776 Comm: node Tainted: G         C        5.4.83-v7l+ #1379
      [83225.012272] Hardware name: BCM2711
      [83225.012275] Backtrace:
      [83225.012289] [<c020dfb0>] (dump_backtrace) from [<c020e334>] (show_stack+0x20/0x24)
      [83225.012295]  r7:ffffffff r6:00000000 r5:60000113 r4:c129fab0
      [83225.012303] [<c020e314>] (show_stack) from [<c0a769b4>] (dump_stack+0xd8/0x11c)
      [83225.012311] [<c0a768dc>] (dump_stack) from [<c0391660>] (dump_header+0x64/0x1fc)
      [83225.012317]  r10:00000000 r9:00001400 r8:c12a1ed0 r7:c0ddcf08 r6:d5b60c00 r5:d82b4c40
      [83225.012320]  r4:d747fde8 r3:d9e2541a
      [83225.012326] [<c03915fc>] (dump_header) from [<c0390a1c>] (oom_kill_process+0x178/0x184)
      [83225.012331]  r7:c0ddcf08 r6:d747fde8 r5:00000558 r4:d82b4c40
      [83225.012337] [<c03908a4>] (oom_kill_process) from [<c03914b0>] (out_of_memory+0x27c/0x33c)
      [83225.012341]  r7:c12083c0 r6:d747fde8 r5:c1204fc8 r4:d82b4c40
      [83225.012349] [<c0391234>] (out_of_memory) from [<c03df634>] (__alloc_pages_nodemask+0xc14/0x1240)
      [83225.012353]  r7:00000000 r6:c12050cc r5:0000181b r4:00000000
      [83225.012360] [<c03dea20>] (__alloc_pages_nodemask) from [<c03c39e0>] (__pte_alloc+0x34/0x168)
      [83225.012365]  r10:d7aefc40 r9:ffffe000 r8:00000055 r7:c2585a28 r6:d8ce2bc0 r5:d7aefc00
      [83225.012368]  r4:c1204fc8
      [83225.012374] [<c03c39ac>] (__pte_alloc) from [<c03c6270>] (handle_mm_fault+0x370/0xde4)
      [83225.012378]  r7:c2585a28 r6:00000040 r5:00000000 r4:c1204fc8
      [83225.012385] [<c03c5f00>] (handle_mm_fault) from [<c0a962b0>] (do_page_fault+0x150/0x380)
      [83225.012390]  r10:d7aefc40 r9:c2585a28 r8:00000a06 r7:2f100008 r6:d7aefc00 r5:c2d8db80
      [83225.012393]  r4:d747ffb0
      [83225.012400] [<c0a96160>] (do_page_fault) from [<c0a965c0>] (do_translation_fault+0xe0/0x10c)
      [83225.012405]  r10:032a3978 r9:2f100010 r8:00000a06 r7:2f100008 r6:c0a964e0 r5:00000a06
      [83225.012408]  r4:c120ab84
      [83225.012414] [<c0a964e0>] (do_translation_fault) from [<c0216c0c>] (do_DataAbort+0x40/0xc0)
      [83225.012419]  r9:2f100010 r8:d747ffb0 r7:2f100008 r6:c0a964e0 r5:00000a06 r4:c120ab84
      [83225.012426] [<c0216bcc>] (do_DataAbort) from [<c0201d24>] (__dabt_usr+0x44/0x60)
      [83225.012429] Exception stack(0xd747ffb0 to 0xd747fff8)
      [83225.012434] ffa0:                                     032a3988 2f100000 00028000 2f106000
      [83225.012439] ffc0: 2f100000 2f106000 032d8f68 00000000 000204e0 2f100010 032a3978 bed9d77c
      [83225.012443] ffe0: 032cc874 bed9d758 00b14f74 00b0bc0c 00000010 ffffffff
      [83225.012448]  r8:30c5387d r7:30c5383d r6:ffffffff r5:00000010 r4:00b0bc0c
      [83225.012452] Mem-Info:
      [83225.012463] active_anon:338108 inactive_anon:112734 isolated_anon:0
                      active_file:621 inactive_file:714 isolated_file:0
                      unevictable:4 dirty:0 writeback:0 unstable:0
                      slab_reclaimable:2912 slab_unreclaimable:5248
                      mapped:3956 shmem:15186 pagetables:6932 bounce:0
                      free:6433 free_pcp:3 free_cma:37
      [83225.012472] Node 0 active_anon:1352432kB inactive_anon:450936kB active_file:2484kB inactive_file:2856kB unevictable:16kB isolated(anon):0kB isolated(file):0kB mapped:15824kB dirty:0kB writeback:0kB shmem:60744kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
      [83225.012483] DMA free:21892kB min:20480kB low:24576kB high:28672kB active_anon:462416kB inactive_anon:125216kB active_file:1476kB inactive_file:1884kB unevictable:0kB writepending:0kB present:786432kB managed:678948kB mlocked:0kB kernel_stack:7488kB pagetables:11848kB bounce:0kB free_pcp:12kB local_pcp:0kB free_cma:148kB
      [83225.012488] lowmem_reserve[]: 0 0 1215 1215
      [83225.012504] HighMem free:3840kB min:23792kB low:31296kB high:38800kB active_anon:890016kB inactive_anon:325720kB active_file:1484kB inactive_file:1364kB unevictable:16kB writepending:0kB present:1244160kB managed:1244160kB mlocked:16kB kernel_stack:0kB pagetables:15880kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
      [83225.012509] lowmem_reserve[]: 0 0 0 0
      [83225.012521] DMA: 810*4kB (UMEC) 590*8kB (UMEC) 320*16kB (UMEC) 58*32kB (UME) 47*64kB (UME) 31*128kB (UME) 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 21912kB
      [83225.012556] HighMem: 560*4kB (UM) 156*8kB (UM) 24*16kB (UM) 4*32kB (M) 2*64kB (UM) 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 4128kB
      [83225.012588] 26590 total pagecache pages
      [83225.012595] 10046 pages in swap cache
      [83225.012601] Swap cache stats: add 29828, delete 19782, find 827/1116
      [83225.012606] Free swap  = 0kB
      [83225.012611] Total swap = 102396kB
      [83225.012616] 507648 pages RAM
      [83225.012621] 311040 pages HighMem/MovableOnly
      [83225.012626] 26871 pages reserved
      [83225.012631] 65536 pages cma reserved
      [83225.012636] Tasks state (memory values in pages):
      [83225.012641] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
      [83225.012658] [    115]     0   115    13444     3861   184320      124             0 systemd-journal
      [83225.012666] [    143]     0   143     4528       55    49152      158         -1000 systemd-udevd
      [83225.012675] [    288]   100   288     5604       17    61440      146             0 systemd-timesyn
      [83225.012681] [    325]     0   325     6378      177    53248       64             0 rsyslogd
      [83225.012688] [    327]     0   327     1987       15    45056       31             0 cron
      [83225.012695] [    328]   104   328     1639       72    40960       48          -900 dbus-daemon
      [83225.012702] [    329] 65534   329     1080        4    36864       39             0 thd
      [83225.012709] [    330]     0   330      923       10    28672       40             0 alsactl
      [83225.012715] [    331]     0   331     6914       22    40960       10             0 rngd
      [83225.012722] [    338]   108   338     1509       99    36864       32             0 avahi-daemon
      [83225.012729] [    339]     0   339     2686       13    45056       89             0 wpa_supplicant
      [83225.012735] [    349]     0   349     3261       76    53248       91             0 systemd-logind
      [83225.012742] [    362]   108   362     1443       13    32768       50             0 avahi-daemon
      [83225.012748] [    451]     0   451     2751       47    45056      108             0 wpa_supplicant
      [83225.012755] [    516]     0   516      726       54    28672       48             0 dhcpcd
      [83225.012762] [    520]   999   520   231822    17651   454656      358             0 influxd
      [83225.012769] [    522]   109   522   243178     2715   229376      741             0 grafana-server
      [83225.012776] [    528]     0   528      535        0    28672       32             0 hciattach
      [83225.012783] [    535]     0   535     2384        0    45056       93             0 bluetoothd
      [83225.012790] [    536]     0   536     1077        0    32768       26             0 agetty
      [83225.012796] [    546]     0   546     2682       16    45056      130         -1000 sshd
      [83225.012804] [  11021]  1001 11021    56627    25307   737280     1396             0 iobroker.js-con
      [83225.012811] [  11040]  1001 11040    42935     9247   544768     2031             0 io.admin.0
      [83225.012818] [  11057]  1001 11057    38047     4451   425984     1741             0 io.discovery.0
      [83225.012824] [  11072]  1001 11072    40166     6611   462848     1281             0 io.info.0
      [83225.012831] [  11597]  1001 11597    40130     6109   495616     2189             0 io.mqtt.0
      [83225.012837] [  11616]  1001 11616    43373    10360   495616     1506             0 io.web.0
      [83225.012844] [  11631]  1001 11631    52946    15943   679936     4773             0 io.javascript.0
      [83225.012851] [  11646]  1001 11646    40265     8521   397312       10             0 io.history.0
      [83225.012857] [  11663]  1001 11663    39367     7035   458752        9             0 io.cloud.0
      [83225.012864] [  11706]  1001 11706    40070     7800   491520        6             0 io.iot.0
      [83225.012870] [  11737]  1001 11737    43250     9375   499712       40             0 io.telegram.0
      [83225.012877] [  11752]  1001 11752    48011    15572   618496        0             0 io.backitup.0
      [83225.012883] [  11807]  1001 11807    49305    17790   593920        0             0 io.shelly.0
      [83225.012890] [  11822]  1001 11822    45111    11571   532480       35             0 io.influxdb.0
      [83225.012897] [  11842]  1001 11842    37386     5208   425984        4             0 io.vis-inventwo
      [83225.012903] [  11861]  1001 11861    40658     9068   503808        1             0 io.modbus.0
      [83225.012910] [  11876]  1001 11876    41272     9062   491520       27             0 io.modbus.1
      [83225.012917] [  32389]  1001 32389    41843    10121   495616        0             0 io.kecontact.0
      [83225.012926] [  31611]  1001 31611    37111     6332   393216        0             0 io.zoe2.0
      [83225.012932] [  31628]  1001 31628    23159     2406   241664        0             0 node
      [83225.012939] [  31629]  1001 31629    26672     5595   307200        0             0 node
      [83225.012946] [  31635]  1001 31635    26909     5914   303104        0             0 node
      [83225.012952] [  31642]  1001 31642    23159     2470   233472        0             0 node
      [83225.012959] [  31649]  1001 31649    24997     4787   270336        0             0 node
      [83225.012966] [  31651]  1001 31651    26909     5437   323584        0             0 node
      [83225.012972] [  31662]  1001 31662    23156     2404   249856        0             0 node
      [83225.012979] [  31669]  1001 31669    24998     4858   270336        0             0 node
      [83225.012985] [  31672]  1001 31672    25105     4952   262144        0             0 node
      [83225.012992] [  31673]  1001 31673    23159     2433   241664        0             0 node
      [83225.012999] [  31679]  1001 31679    24996     4731   262144        0             0 node
      [83225.013005] [  31688]  1001 31688    25368     5221   266240        0             0 node
      [83225.013012] [  31694]  1001 31694    23158     2502   241664        0             0 node
      [83225.013018] [  31696]  1001 31696    25128     4229   270336        0             0 node
      [83225.013025] [  31699]  1001 31699    25240     4687   270336        0             0 node
      [83225.013031] [  31718]  1001 31718    23167     2481   241664        0             0 node
      [83225.013038] [  31728]  1001 31728    25002     4365   266240        0             0 node
      [83225.013044] [  31735]  1001 31735    25239     4523   266240        0             0 node
      [83225.013051] [  31737]  1001 31737    23164     2453   253952        0             0 node
      [83225.013057] [  31748]  1001 31748    24997     3904   270336        0             0 node
      [83225.013064] [  31751]  1001 31751    24746     4272   253952        0             0 node
      [83225.013070] [  31762]  1001 31762    23163     2483   245760        0             0 node
      [83225.013077] [  31769]  1001 31769    25125     5057   274432        0             0 node
      [83225.013084] [  31776]  1001 31776    25029     4440   262144        0             0 node
      [83225.013090] [  31782]  1001 31782    23159     2468   249856        0             0 node
      [83225.013097] [  31785]  1001 31785    25254     5013   270336        0             0 node
      [83225.013103] [  31787]  1001 31787    24618     4082   245760        0             0 node
      [83225.013110] [  31797]  1001 31797    23164     2440   237568        0             0 node
      [83225.013116] [  31801]  1001 31801    24544     3873   233472        0             0 node
      [83225.013123] [  31818]  1001 31818    24656     3886   245760        0             0 node
      [83225.013130] [  31823]  1001 31823    23164     2512   249856        0             0 node
      [83225.013136] [  31827]  1001 31827    24544     3674   237568        0             0 node
      [83225.013142] [  31829]  1001 31829    24656     4031   241664        0             0 node
      [83225.013149] [  31840]  1001 31840    23288     2676   253952        0             0 node
      [83225.013155] [  31842]  1001 31842    24531     3815   245760        0             0 node
      [83225.013162] [  31853]  1001 31853    24535     3717   241664        0             0 node
      [83225.013169] [  31856]  1001 31856    22997     2150   225280        0             0 node
      [83225.013175] [  31864]  1001 31864    23576     3130   225280        0             0 node
      [83225.013182] [  31876]  1001 31876    24656     4060   245760        0             0 node
      [83225.013188] [  31882]  1001 31882    23000     1878   229376        0             0 node
      [83225.013195] [  31890]  1001 31890    24423     3212   249856        0             0 node
      [83225.013202] [  31902]  1001 31902    22090     1653   200704        0             0 node
      [83225.013208] [  31907]  1001 31907    24378     3944   241664        0             0 node
      [83225.013215] [  31909]  1001 31909    24362     3349   233472        0             0 node
      [83225.013221] [  31914]  1001 31914    22892     1723   229376        0             0 node
      [83225.013228] [  31925]  1001 31925    23576     3130   225280        0             0 node
      [83225.013234] [  31932]  1001 31932    23688     3242   221184        0             0 node
      [83225.013241] [  31944]  1001 31944    22892     1915   229376        0             0 node
      [83225.013247] [  31945]  1001 31945    22587     1397   200704        0             0 node
      [83225.013253] [  31963]  1001 31963    21602     1082   204800        0             0 node
      [83225.013260] [  31965]  1001 31965    21602     1134   196608        0             0 node
      [83225.013267] [  31967]  1001 31967    24544     3834   237568        0             0 node
      [83225.013273] [  31973]  1001 31973    21602     1097   188416        0             0 node
      [83225.013280] [  31979]  1001 31979    21602     1145   200704        0             0 node
      [83225.013286] [  31982]  1001 31982    21602     1132   200704        0             0 node
      [83225.013293] [  31989]  1001 31989    21602     1254   192512        0             0 node
      [83225.013300] [  32002]  1001 32002    21602     1126   204800        0             0 node
      [83225.013306] [  32015]  1001 32015    21385     1105   192512        0             0 node
      [83225.013313] [  32026]  1001 32026    21346     1059   188416        0             0 node
      [83225.013319] [  32029]  1001 32029    21602     1092   192512        0             0 node
      [83225.013326] [  32035]  1001 32035    22587     1576   196608        0             0 node
      [83225.013332] [  32036]  1001 32036    21474     1131   196608        0             0 node
      [83225.013339] [  32044]  1001 32044    21346     1050   188416        0             0 node
      [83225.013345] [  32045]  1001 32045    21346     1041   192512        0             0 node
      [83225.013352] [  32057]  1001 32057    20950      805   180224        0             0 node
      [83225.013358] [  32069]  1001 32069    21346     1049   184320        0             0 node
      [83225.013365] [  32076]  1001 32076    20950      790   172032        0             0 node
      [83225.013372] [  32080]  1001 32080    21602     1081   204800        0             0 node
      [83225.013378] [  32087]  1001 32087    21474     1134   196608        0             0 node
      [83225.013385] [  32093]  1001 32093    21346     1060   184320        0             0 node
      [83225.013391] [  32094]  1001 32094    21218      842   184320        0             0 node
      [83225.013398] [  32113]  1001 32113    20951      718   180224        0             0 node
      [83225.013404] [  32126]  1001 32126    20688      689   172032        0             0 node
      [83225.013411] [  32127]  1001 32127    20946      652   184320        0             0 node
      [83225.013418] [  32134]  1001 32134    19918      411   172032        0             0 node
      [83225.013424] [  32140]  1001 32140    20942      639   176128        0             0 node
      [83225.013431] [  32141]  1001 32141    19918      481   163840        0             0 node
      [83225.013437] [  32143]  1001 32143    20174      534   167936        0             0 node
      [83225.013444] [  32148]  1001 32148    19888      373   159744        0             0 node
      [83225.013451] [  32149]  1001 32149    19918      462   167936        0             0 node
      [83225.013458] [  32168]  1001 32168    19888      384   163840        0             0 node
      [83225.013464] [  32185]  1001 32185    18891       65   102400        0             0 node
      [83225.013471] [  32201]     0 32201     1614       16    40960        0             0 sleep
      [83225.013478] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/,task=iobroker.js-con,pid=11021,uid=1001
      [83225.013530] Out of memory: Killed process 11021 (iobroker.js-con) total-vm:226508kB, anon-rss:101228kB, file-rss:0kB, shmem-rss:0kB, UID:1001 pgtables:720kB oom_score_adj:0
      [83225.033450] oom_reaper: reaped process 11021 (iobroker.js-con), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
      [83281.512676] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
      [168727.070010] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
      [193030.529656] node invoked oom-killer: gfp_mask=0xdc0(GFP_KERNEL|__GFP_ZERO), order=0, oom_score_adj=0
      [193030.529669] CPU: 2 PID: 13888 Comm: node Tainted: G         C        5.4.83-v7l+ #1379
      [193030.529673] Hardware name: BCM2711
      [193030.529677] Backtrace:
      [193030.529695] [<c020dfb0>] (dump_backtrace) from [<c020e334>] (show_stack+0x20/0x24)
      [193030.529701]  r7:ffffffff r6:00000000 r5:60000113 r4:c129fab0
      [193030.529710] [<c020e314>] (show_stack) from [<c0a769b4>] (dump_stack+0xd8/0x11c)
      [193030.529719] [<c0a768dc>] (dump_stack) from [<c0391660>] (dump_header+0x64/0x1fc)
      [193030.529726]  r10:00000000 r9:00001000 r8:c12a1ed0 r7:c0ddcf08 r6:d88cfc00 r5:d7bc5b80
      [193030.529729]  r4:d8155bd0 r3:d9e2541a
      [193030.529735] [<c03915fc>] (dump_header) from [<c0390a1c>] (oom_kill_process+0x178/0x184)
      [193030.529741]  r7:c0ddcf08 r6:d8155bd0 r5:00000558 r4:d7bc5b80
      [193030.529748] [<c03908a4>] (oom_kill_process) from [<c03914b0>] (out_of_memory+0x27c/0x33c)
      [193030.529753]  r7:c12083c0 r6:d8155bd0 r5:c1204fc8 r4:d7bc5b80
      [193030.529763] [<c0391234>] (out_of_memory) from [<c03df634>] (__alloc_pages_nodemask+0xc14/0x1240)
      [193030.529769]  r7:00000000 r6:c12050cc r5:0000db52 r4:00000000
      [193030.529777] [<c03dea20>] (__alloc_pages_nodemask) from [<c03dfc84>] (__get_free_pages+0x24/0x3c)
      [193030.529783]  r10:d8f2b840 r9:d8d70068 r8:00000015 r7:d8f55540 r6:00000000 r5:d8f55540
      [193030.529787]  r4:d8f2b800
      [193030.529794] [<c03dfc60>] (__get_free_pages) from [<c03dfcbc>] (get_zeroed_page+0x20/0x24)
      [193030.529805] [<c03dfc9c>] (get_zeroed_page) from [<c03c5e50>] (__pmd_alloc+0x24/0xd4)
      [193030.529812] [<c03c5e2c>] (__pmd_alloc) from [<c03c6490>] (handle_mm_fault+0x590/0xde4)
      [193030.529816]  r7:d8f55540 r6:00000000 r5:01cb9000 r4:c1204fc8
      [193030.529826] [<c03c5f00>] (handle_mm_fault) from [<c0a962b0>] (do_page_fault+0x150/0x380)
      [193030.529833]  r10:d8f2b840 r9:d8d70068 r8:00000a05 r7:01cb9464 r6:d8f2b800 r5:d5b03d00
      [193030.529836]  r4:d8155db8
      [193030.529843] [<c0a96160>] (do_page_fault) from [<c0a965c0>] (do_translation_fault+0xe0/0x10c)
      [193030.529848]  r10:01cb9464 r9:d8154000 r8:00000a05 r7:01cb9464 r6:c0a964e0 r5:00000a05
      [193030.529853]  r4:c120ab74
      [193030.529860] [<c0a964e0>] (do_translation_fault) from [<c0216c0c>] (do_DataAbort+0x40/0xc0)
      [193030.529867]  r9:d8154000 r8:d8155db8 r7:01cb9464 r6:c0a964e0 r5:00000a05 r4:c120ab74
      [193030.529874] [<c0216bcc>] (do_DataAbort) from [<c02019b4>] (__dabt_svc+0x54/0x80)
      [193030.529878] Exception stack(0xd8155db8 to 0xd8155e00)
      [193030.529883] 5da0:                                                       01cb9464 beffffff
      [193030.529889] 5dc0: 00000000 d8154000 ffffe000 01cb9464 00000000 00000b9c c1204fc8 00000000
      [193030.529894] 5de0: 01cb9464 d8155e3c 42cb9464 d8155e08 c06a2894 c0a752e4 00000113 ffffffff
      [193030.529898]  r8:c1204fc8 r7:d8155dec r6:ffffffff r5:00000113 r4:c0a752e4
      [193030.529909] [<c06a27f4>] (__clear_user_memset) from [<c06a2f5c>] (arm_clear_user+0x28/0x2c)
      [193030.529914]  r8:00000000 r7:d840c400 r6:d658bc00 r5:c1204fc8 r4:d7783a00
      [193030.529921] [<c06a2f34>] (arm_clear_user) from [<c047e9a8>] (clear_user+0x40/0x4c)
      [193030.529926] [<c047e968>] (clear_user) from [<c047fcd0>] (load_elf_binary+0x10b8/0x1338)
      [193030.529933] [<c047ec18>] (load_elf_binary) from [<c0415668>] (search_binary_handler+0xc4/0x250)
      [193030.529938]  r10:d658bc00 r9:c0de3608 r8:c1338758 r7:c1227048 r6:fffffff8 r5:c1338758
      [193030.529941]  r4:c122a854
      [193030.529947] [<c04155a4>] (search_binary_handler) from [<c0415d64>] (__do_execve_file+0x570/0x84c)
      [193030.529951]  r10:d658bc00 r9:00003640 r8:00003640 r7:ffffe000 r6:d5b03d00 r5:d80b5000
      [193030.529954]  r4:c1204fc8
      [193030.529960] [<c04157f4>] (__do_execve_file) from [<c0416434>] (sys_execve+0x44/0x4c)
      [193030.529965]  r10:0000000b r9:d8154000 r8:c02011c4 r7:0000000b r6:02e97f88 r5:02b981c8
      [193030.529968]  r4:02e97f88
      [193030.529974] [<c04163f0>] (sys_execve) from [<c0201000>] (ret_fast_syscall+0x0/0x28)
      [193030.529978] Exception stack(0xd8155fa8 to 0xd8155ff0)
      [193030.529983] 5fa0:                   b6fe4968 bea3b3c0 bea3b3c0 02e97f88 02b981c8 0000000f
      [193030.529988] 5fc0: b6fe4968 bea3b3c0 02e97f88 0000000b 00000001 00000060 02c96328 bea3b25c
      [193030.529992] 5fe0: 0000002f bea3b21c b6ca7038 b6ca69ac
      [193030.529995]  r5:bea3b3c0 r4:b6fe4968
      [193030.530000] Mem-Info:
      [193030.530012] active_anon:234383 inactive_anon:151364 isolated_anon:0
                       active_file:6336 inactive_file:3478 isolated_file:198
                       slab_reclaimable:2871 slab_unreclaimable:5185
                       mapped:12650 shmem:21823 pagetables:6236 bounce:0
                       free:63937 free_pcp:98 free_cma:52479
      [193030.530021] Node 0 active_anon:937532kB inactive_anon:605456kB active_file:25344kB inactive_file:13912kB unevictable:16kB isolated(anon):0kB isolated(file):792kB mapped:50600kB dirty:0kB writeback:0kB shmem:87292kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
      [193030.530031] DMA free:224520kB min:16384kB low:20480kB high:24576kB active_anon:253320kB inactive_anon:138800kB active_file:596kB inactive_file:488kB unevictable:0kB writepending:0kB present:786432kB managed:678948kB mlocked:0kB kernel_stack:6672kB pagetables:7192kB bounce:0kB free_pcp:392kB local_pcp:188kB free_cma:209916kB
      [193030.530036] lowmem_reserve[]: 0 0 1215 1215
      [193030.530053] HighMem free:31228kB min:23792kB low:31296kB high:38800kB active_anon:683356kB inactive_anon:466040kB active_file:24852kB inactive_file:13328kB unevictable:16kB writepending:0kB present:1244160kB managed:1244160kB mlocked:16kB kernel_stack:0kB pagetables:17752kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
      [193030.530058] lowmem_reserve[]: 0 0 0 0
      [193030.530070] DMA: 464*4kB (UE) 218*8kB (UE) 233*16kB (UEC) 80*32kB (UEC) 44*64kB (UEC) 218*128kB (UC) 148*256kB (UC) 88*512kB (C) 44*1024kB (C) 17*2048kB (C) 5*4096kB (C) = 223904kB
      [193030.530113] HighMem: 2026*4kB (UM) 1799*8kB (UM) 125*16kB (UM) 231*32kB (UM) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 31888kB
      [193030.530146] 36718 total pagecache pages
      [193030.530154] 5037 pages in swap cache
      [193030.530161] Swap cache stats: add 58696, delete 53658, find 31122/32297
      [193030.530166] Free swap  = 0kB
      [193030.530171] Total swap = 102396kB
      [193030.530177] 507648 pages RAM
      [193030.530183] 311040 pages HighMem/MovableOnly
      [193030.530188] 26871 pages reserved
      [193030.530194] 65536 pages cma reserved
      [193030.530200] Tasks state (memory values in pages):
      [193030.530206] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
      [193030.530226] [    115]     0   115    13438     5522   192512      121             0 systemd-journal
      [193030.530240] [    143]     0   143     4528      161    49152      157         -1000 systemd-udevd
      [193030.530251] [    288]   100   288     5604      242    61440      146             0 systemd-timesyn
      [193030.530260] [    325]     0   325     6378      358    53248       49             0 rsyslogd
      [193030.530268] [    327]     0   327     1987       95    45056       31             0 cron
      [193030.530277] [    328]   104   328     1639      167    40960       48          -900 dbus-daemon
      [193030.530285] [    329] 65534   329     1080        7    36864       39             0 thd
      [193030.530293] [    330]     0   330      923       29    28672       40             0 alsactl
      [193030.530299] [    331]     0   331     6914       93    40960       10             0 rngd
      [193030.530307] [    338]   108   338     1509      217    36864       29             0 avahi-daemon
      [193030.530315] [    339]     0   339     2686       23    45056       89             0 wpa_supplicant
      [193030.530322] [    349]     0   349     3261      269    53248       90             0 systemd-logind
      [193030.530330] [    362]   108   362     1443       13    32768       50             0 avahi-daemon
      [193030.530338] [    451]     0   451     2751      129    45056      107             0 wpa_supplicant
      [193030.530346] [    516]     0   516      726      207    28672       32             0 dhcpcd
      [193030.530354] [    520]   999   520   231931    24719   552960      349             0 influxd
      [193030.530366] [    522]   109   522   243178     4873   229376      799             0 grafana-server
      [193030.530375] [    528]     0   528      535        0    28672       32             0 hciattach
      [193030.530383] [    535]     0   535     2384        0    45056       93             0 bluetoothd
      [193030.530391] [    536]     0   536     1077        0    32768       26             0 agetty
      [193030.530399] [    546]     0   546     2682       16    45056      130         -1000 sshd
      [193030.530408] [  32203]  1001 32203    53354    27094   696320     1107             0 iobroker.js-con
      [193030.530420] [  32223]  1001 32223    44081    12870   565248     1589             0 io.admin.0
      [193030.530429] [  32238]  1001 32238    37938     6713   425984     1427             0 io.discovery.0
      [193030.530438] [  32253]  1001 32253    40412     9268   475136     1329             0 io.info.0
      [193030.530446] [    313]  1001   313    41307    10771   499712     1259             0 io.mqtt.0
      [193030.530453] [    343]  1001   343    45623    14511   507904     2042             0 io.web.0
      [193030.530462] [    360]  1001   360    52574    14878   692224     8030             0 io.javascript.0
      [193030.530470] [    379]  1001   379    38409     9750   401408     1280             0 io.history.0
      [193030.530477] [    396]  1001   396    40344     8992   483328     1249             0 io.cloud.0
      [193030.530484] [    411]  1001   411    41246    10054   528384     1445             0 io.iot.0
      [193030.530491] [    426]  1001   426    41283    10627   495616      849             0 io.telegram.0
      [193030.530498] [    443]  1001   443    47631    17409   630784        0             0 io.backitup.0
      [193030.530504] [    504]  1001   504    49329    20298   606208       37             0 io.shelly.0
      [193030.530511] [    521]  1001   521    42139    12588   507904        1             0 io.influxdb.0
      [193030.530518] [    562]  1001   562    37365     7839   413696       11             0 io.vis-inventwo
      [193030.530530] [    599]  1001   599    41827    11998   499712        1             0 io.modbus.0
      [193030.530540] [    614]  1001   614    41547    11896   499712       28             0 io.modbus.1
      [193030.530547] [  28905]  1001 28905    41543    14058   487424        0             0 io.kecontact.0
      [193030.530563] [  13411]     0 13411     1614       13    40960        0             0 sleep
      [193030.530570] [  13412]  1001 13412    23977     7480   249856        0             0 node
      [193030.530578] [  13413]  1001 13413    22811     6018   237568        0             0 node
      [193030.530586] [  13419]  1001 13419    23433     6640   245760        0             0 node
      [193030.530593] [  13425]  1001 13425    24013     7477   266240        0             0 node
      [193030.530606] [  13432]  1001 13432    22811     5995   241664        0             0 node
      [193030.530614] [  13434]  1001 13434    23420     6676   245760        0             0 node
      [193030.530621] [  13442]  1001 13442    24103     7479   270336        0             0 node
      [193030.530628] [  13448]  1001 13448    22812     5974   245760        0             0 node
      [193030.530634] [  13456]  1001 13456    23419     6765   253952        0             0 node
      [193030.530642] [  13462]  1001 13462    23981     7470   266240        0             0 node
      [193030.530652] [  13469]  1001 13469    22811     6035   241664        0             0 node
      [193030.530660] [  13480]  1001 13480    23529     6751   245760        0             0 node
      [193030.530667] [  13485]  1001 13485    23979     7354   262144        0             0 node
      [193030.530676] [  13490]  1001 13490    22811     6085   241664        0             0 node
      [193030.530684] [  13493]  1001 13493    23420     6705   249856        0             0 node
      [193030.530691] [  13509]  1001 13509    23978     7362   262144        0             0 node
      [193030.530699] [  13510]  1001 13510    22811     5969   233472        0             0 node
      [193030.530707] [  13513]  1001 13513    23417     6788   249856        0             0 node
      [193030.530713] [  13529]  1001 13529    23907     7380   262144        0             0 node
      [193030.530720] [  13532]  1001 13532    22812     5988   245760        0             0 node
      [193030.530726] [  13540]  1001 13540    23657     7004   245760        0             0 node
      [193030.530733] [  13545]  1001 13545    23770     7108   249856        0             0 node
      [193030.530740] [  13546]  1001 13546    22811     5996   237568        0             0 node
      [193030.530746] [  13554]  1001 13554    23415     6857   245760        0             0 node
      [193030.530753] [  13556]  1001 13556    23779     7181   258048        0             0 node
      [193030.530759] [  13563]  1001 13563    22811     6057   225280        0             0 node
      [193030.530766] [  13574]  1001 13574    23414     6757   249856        0             0 node
      [193030.530773] [  13582]  1001 13582    23771     7187   258048        0             0 node
      [193030.530780] [  13588]  1001 13588    22811     6023   237568        0             0 node
      [193030.530786] [  13597]  1001 13597    23530     6686   249856        0             0 node
      [193030.530793] [  13603]  1001 13603    23771     7101   253952        0             0 node
      [193030.530799] [  13605]  1001 13605    22811     6035   237568        0             0 node
      [193030.530806] [  13617]  1001 13617    23417     6705   245760        0             0 node
      [193030.530813] [  13630]  1001 13630    23901     7383   245760        0             0 node
      [193030.530819] [  13633]  1001 13633    22811     6157   241664        0             0 node
      [193030.530826] [  13639]  1001 13639    23414     6627   245760        0             0 node
      [193030.530832] [  13646]  1001 13646    23522     6795   241664        0             0 node
      [193030.530839] [  13652]  1001 13652    21602     4853   204800        0             0 node
      [193030.530845] [  13660]  1001 13660    23529     6652   249856        0             0 node
      [193030.530852] [  13666]  1001 13666    23567     6536   237568        0             0 node
      [193030.530859] [  13672]  1001 13672    21636     4875   196608        0             0 node
      [193030.530866] [  13675]  1001 13675    23166     6172   229376        0             0 node
      [193030.530872] [  13687]  1001 13687    21602     4879   200704        0             0 node
      [193030.530879] [  13693]  1001 13693    21602     4882   204800        0             0 node
      [193030.530886] [  13696]  1001 13696    21602     4855   204800        0             0 node
      [193030.530893] [  13708]  1001 13708    21602     4855   200704        0             0 node
      [193030.530900] [  13715]  1001 13715    21602     4839   204800        0             0 node
      [193030.530906] [  13718]  1001 13718    21602     4855   196608        0             0 node
      [193030.530913] [  13728]  1001 13728    21602     4861   200704        0             0 node
      [193030.530920] [  13742]  1001 13742    21602     4842   196608        0             0 node
      [193030.530927] [  13747]  1001 13747    21602     4850   200704        0             0 node
      [193030.530933] [  13756]  1001 13756    21602     4854   200704        0             0 node
      [193030.530940] [  13759]  1001 13759    21602     5123   192512        0             0 node
      [193030.530946] [  13770]  1001 13770    21602     4792   192512        0             0 node
      [193030.530953] [  13777]  1001 13777    21602     4785   200704        0             0 node
      [193030.530959] [  13779]  1001 13779    21602     4811   196608        0             0 node
      [193030.530966] [  13784]  1001 13784    21602     4778   196608        0             0 node
      [193030.530973] [  13791]  1001 13791    21602     4773   200704        0             0 node
      [193030.530980] [  13810]  1001 13810    21335     4711   184320        0             0 node
      [193030.530986] [  13811]  1001 13811    21346     4722   192512        0             0 node
      [193030.530993] [  13814]  1001 13814    21336     4777   184320        0             0 node
      [193030.530999] [  13820]  1001 13820    20987     4448   184320        0             0 node
      [193030.531006] [  13823]  1001 13823    21346     4782   192512        0             0 node
      [193030.531013] [  13841]  1001 13841    20950     4463   176128        0             0 node
      [193030.531020] [  13848]  1001 13848    20950     4483   180224        0             0 node
      [193030.531026] [  13849]  1001 13849    20950     4499   180224        0             0 node
      [193030.531033] [  13855]  1001 13855    20950     4484   188416        0             0 node
      [193030.531041] [  13858]  1001 13858    20946     4398   180224        0             0 node
      [193030.531047] [  13880]  1001 13880    12744      996    86016        0             0 node
      [193030.531054] [  13888]  1001 13888     7373        1     8192        0             0 node
      [193030.531061] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/,task=iobroker.js-con,pid=32203,uid=1001
      [193030.531131] Out of memory: Killed process 32203 (iobroker.js-con) total-vm:213416kB, anon-rss:96840kB, file-rss:11536kB, shmem-rss:0kB, UID:1001 pgtables:680kB oom_score_adj:0
      [193030.576239] oom_reaper: reaped process 32203 (iobroker.js-con), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
      [193088.974503] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
      pi@ioBrokerPV:~ $
      BG
      • HumidorH Humidor
        pi@ioBrokerPV:~ $
        @humidor
        Ich auch nicht. Glaskugel kaputt.
        • HumidorH Humidor
          pi@ioBrokerPV:~ $
          @humidor sagte in (?) ioBroker Restart ?:
          [83225.012258] node invoked oom-killer: gfp_mask=0x400dc2(GFP_KERNEL_ACCOUNT|__GFP_HIGHMEM|__GFP_ZERO), order=0, oom_score_adj=0 [83225.012268] CPU: 2 PID: 31776 Comm: node Tainted: G C 5.4.83-v7l+ #1379 [83225.012272] Hardware name: BCM2711
          Da ist dir der Speicher ausgegangen und der Kernel wirft dann 'entbehrliche' Programme raus. Hat dann die ioBroker-Prozesse (hier mit node bezeichnet) getroffen.
          Gründe? Kann alles mögliche sein. Ein Skript in einer Endlosschleife, defekte Hardware etc.
          Ich würde das System aber auch mal wieder 'auf Stand' bringen.
          Sowohl das Grundsystem wie auch nodeJS und den ioBroker.
            HumidorH Online
            HumidorH Online
            Humidor
            @thomas-braun "auf Stand", ja wenn ich ioBroker stoppen könnte....
            BG
            • HumidorH Humidor
              @humidor Was hindert dich?
                HumidorH Online
                HumidorH Online
                Humidor
                ach bitte, das weißt du ganz genau.
                ioBroker stoppt nicht...
                BG
                • HumidorH Humidor
                  @humidor Keine Ahnung worum es geht.
                    HumidorH Online
                    HumidorH Online
                    Humidor
                    https://forum.iobroker.net/post/585481
                    BG
                    • HumidorH Humidor
                      HumidorH Online
                      HumidorH Online
                      Humidor
                      war wieder soweit, einfach ein Restart...
                      mitten drin während ich an einem Script gebastelt hab:
                      2021-03-02 17:48:40.794 - warn: modbus.0 (879) Poll error count: 1 code: "App Timeout"
                      2021-03-02 17:48:41.288 - warn: modbus.0 (879) Error: undefined
                      2021-03-02 17:48:41.288 - error: modbus.0 (879) Request timed out.
                      2021-03-02 17:48:41.289 - error: modbus.0 (879) Client in error state.
                      2021-03-02 17:48:42.290 - info: modbus.0 (879) Disconnected from slave 192.168.0.9
                      2021-03-02 17:48:43.320 - warn: modbus.1 (979) Error: undefined
                      2021-03-02 17:48:43.322 - error: modbus.1 (979) Request timed out.
                      2021-03-02 17:48:43.324 - error: modbus.1 (979) Client in error state.
                      2021-03-02 17:48:43.326 - warn: modbus.1 (979) Poll error count: 1 code: {"err":"timeout","timeout":5000}
                      2021-03-02 17:48:44.325 - info: modbus.1 (979) Disconnected from slave 192.168.0.98
                      2021-03-02 17:48:47.412 - error: shelly.0 (843) Error in function state.coap.http_cmd for state SHPLG-S#EED8F9#1.Relay0.Switch and request{"url":"http://192.168.0.80/relay/0","timeout":5000,"qs":{"turn":"off","timer":0}} for 192.168.0.80 (shellyplug-s / shellyplug-s-EED8F9 / SHPLG-S#EED8F9#1) (Error: ETIMEDOUT)
                      2021-03-02 17:48:51.757 - error: cloud.0 (711) Ping timeout
                      2021-03-02 17:48:51.758 - info: cloud.0 (711) Connection changed: Ping timeout
                      2021-03-02 17:48:51.759 - info: cloud.0 (711) Connection lost
                      2021-03-02 17:48:59.683 - info: mqtt.0 (648) Client [AMIS] connection closed: timeout
                      2021-03-02 17:49:16.817 - info: cloud.0 (711) Connection changed: transport close
                      2021-03-02 17:49:20.848 - info: iot.0 (726) Connection changed: disconnect
                      2021-03-02 17:49:20.849 - info: iot.0 (726) Connection lost
                      2021-03-02 17:49:33.027 - error: modbus.1 (979) Socket Error
                      2021-03-02 17:49:33.027 - error: modbus.1 (979) Client in error state.
                      2021-03-02 17:49:33.028 - warn: modbus.1 (979) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
                      2021-03-02 17:49:45.424 - error: modbus.0 (879) Socket Error
                      2021-03-02 17:49:45.425 - error: modbus.0 (879) Client in error state.
                      2021-03-02 17:49:45.426 - warn: modbus.0 (879) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.9","port":502}
                      2021-03-02 17:49:45.880 - error: iot.0 (726) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
                      2021-03-02 17:49:45.881 - error: iot.0 (726) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
                      2021-03-02 17:49:45.882 - error: iot.0 (726) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
                      2021-03-02 17:49:45.883 - error: iot.0 (726) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
                      2021-03-02 17:49:45.884 - info: iot.0 (726) Connection changed: disconnect
                      2021-03-02 17:49:51.778 - info: cloud.0 (711) Trying to connect as system.user.admin
                      2021-03-02 17:49:55.902 - error: iot.0 (726) Error by device connection: "premature close"
                      2021-03-02 17:49:55.903 - info: iot.0 (726) Connection changed: disconnect
                      2021-03-02 17:49:55.934 - error: iot.0 (726) Error by device connection: "premature close"
                      2021-03-02 17:49:55.936 - warn: iot.0 (726) Looks like your connection certificates are invalid. Please renew them via configuration dialog.
                      2021-03-02 17:49:55.937 - info: iot.0 (726) Connection changed: disconnect
                      2021-03-02 17:50:01.771 - error: cloud.0 (711) Error while connecting to cloud: Error: websocket error
                      2021-03-02 17:50:07.182 - error: modbus.1 (979) Socket Error
                      2021-03-02 17:50:07.182 - error: modbus.1 (979) Client in error state.
                      2021-03-02 17:50:07.183 - warn: modbus.1 (979) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
                      2021-03-02 17:50:15.528 - info: mqtt.0 (648) Client [H,] connected with secret 1614703815524_5091
                      2021-03-02 17:50:17.742 - error: zoe2.0 (12630) No valid response from Renault server
                      2021-03-02 17:50:17.746 - warn: zoe2.0 (12630) Terminated (JS_CONTROLLER_STOPPED): Without reason
                      2021-03-02 17:50:18.278 - error: host.raspi4iobrokerpv instance system.adapter.zoe2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2021-03-02 17:50:25.952 - error: iot.0 (726) Error by device connection: "premature close"
                      2021-03-02 17:50:25.953 - info: iot.0 (726) Connection changed: disconnect
                      2021-03-02 17:50:26.906 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:27.206 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:27.506 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:27.807 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:28.107 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:28.408 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:28.707 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:29.008 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:29.308 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:29.608 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:29.909 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:30.209 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:30.509 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:30.808 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:30.957 - error: iot.0 (726) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
                      2021-03-02 17:50:30.958 - error: iot.0 (726) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
                      2021-03-02 17:50:30.959 - error: iot.0 (726) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
                      2021-03-02 17:50:30.960 - error: iot.0 (726) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
                      2021-03-02 17:50:30.960 - info: iot.0 (726) Connection changed: disconnect
                      2021-03-02 17:50:31.108 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:31.409 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:31.709 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:32.010 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:32.311 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:32.612 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:32.912 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:33.212 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:33.513 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:33.813 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:34.113 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:34.414 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:34.714 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:35.015 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:35.316 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:35.617 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:35.917 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:36.217 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:36.518 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:36.818 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:37.118 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:37.418 - warn: kecontact.0 (633) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                      2021-03-02 17:50:38.192 - info: modbus.1 (979) Connected to slave 192.168.0.98
                      2021-03-02 17:50:40.965 - error: iot.0 (726) Error by device connection: "premature close"
                      2021-03-02 17:50:40.966 - info: iot.0 (726) Connection changed: disconnect
                      2021-03-02 17:50:40.979 - error: iot.0 (726) Error by device connection: "premature close"
                      2021-03-02 17:50:40.980 - warn: iot.0 (726) Looks like your connection certificates are invalid. Please renew them via configuration dialog.
                      2021-03-02 17:50:40.980 - info: iot.0 (726) Connection changed: disconnect
                      2021-03-02 17:50:41.362 - info: iot.0 (726) Connection changed: connect
                      2021-03-02 17:50:46.443 - info: modbus.0 (879) Connected to slave 192.168.0.9
                      2021-03-02 17:50:51.769 - info: cloud.0 (711) Trying to connect as system.user.admin
                      2021-03-02 17:50:52.163 - info: cloud.0 (711) Connection changed: connect
                      2021-03-02 18:00:00.005 - info: javascript.0 (678) script.js.common.Sonnenstand: Script Sonnenstand; Erfolgreich gelaufen, Werte akzeptiert
                      2021-03-02 18:00:00.096 - info: host.raspi4iobrokerpv instance system.adapter.zoe2.0 started with pid 15636
                      2021-03-02 18:06:52.948 - error: iot.0 (726) States database error: read ECONNRESET
                      2021-03-02 18:06:52.908 - error: modbus.1 (979) States database error: read ECONNRESET
                      2021-03-02 18:06:52.909 - error: shelly.0 (843) States database error: read ECONNRESET
                      2021-03-02 18:06:52.967 - error: modbus.1 (979) Objects database error: read ECONNRESET
                      2021-03-02 18:06:53.165 - info: shelly.0 (843) Closing Adapter
                      2021-03-02 18:06:52.979 - error: kecontact.0 (633) States database error: read ECONNRESET
                      2021-03-02 18:06:52.973 - error: mqtt.0 (648) States database error: read ECONNRESET
                      2021-03-02 18:06:52.964 - error: web.0 (663) States database error: read ECONNRESET
                      2021-03-02 18:06:53.055 - error: javascript.0 (678) Objects database error: read ECONNRESET
                      2021-03-02 18:06:53.115 - info: vis-inventwo.0 (858) cleaned everything up...
                      2021-03-02 18:06:53.026 - error: mqtt.0 (648) Objects database error: read ECONNRESET
                      2021-03-02 18:06:53.174 - info: javascript.0 (678) Stop script script.js.common.AMIS
                      2021-03-02 18:06:53.178 - info: javascript.0 (678) Stop script script.js.common.SE_Power
                      2021-03-02 18:06:53.179 - info: javascript.0 (678) Stop script script.js.common.Sonnenstand
                      2021-03-02 18:06:53.180 - info: javascript.0 (678) Stop script script.js.common.Powerbank
                      2021-03-02 18:06:53.180 - info: javascript.0 (678) Stop script script.js.common.Grid-PV
                      2021-03-02 18:06:53.182 - info: javascript.0 (678) Stop script script.js.common.SMA+SE
                      2021-03-02 18:06:53.182 - info: javascript.0 (678) Stop script script.js.common.Zoe_Zielladung
                      2021-03-02 18:06:53.183 - info: javascript.0 (678) Stop script script.js.common.PVÜberschuss
                      2021-03-02 18:06:53.184 - info: javascript.0 (678) Stop script script.js.common.ZOE_Ladung
                      2021-03-02 18:06:53.154 - info: cloud.0 (711) Connection changed: io client disconnect
                      2021-03-02 18:06:53.235 - info: info.0 (1001) cleaned everything up...
                      2021-03-02 18:06:53.156 - info: cloud.0 (711) Connection lost
                      2021-03-02 18:06:53.246 - info: cloud.0 (711) Restart adapter by disconnect
                      2021-03-02 18:06:53.000 - error: kecontact.0 (633) Objects database error: read ECONNRESET
                      2021-03-02 18:06:53.249 - info: backitup.0 (758) cleaned everything up...
                      2021-03-02 18:06:53.335 - info: iot.0 (726) Connection changed: disconnect
                      2021-03-02 18:06:53.339 - info: iot.0 (726) Connection lost
                      2021-03-02 18:06:53.449 - error: history.0 (693) States database error: write EPIPE
                      2021-03-02 18:06:53.463 - error: admin.0 (618) States database error: write EPIPE
                      2021-03-02 18:06:53.481 - info: admin.0 (618) terminating http server on port 8081
                      2021-03-02 18:06:53.504 - error: history.0 (693) uncaught exception: write EPIPE
                      2021-03-02 18:06:53.506 - error: history.0 (693) Error: write EPIPE
                      at ChildProcess.target._send (internal/child_process.js:807:20)
                      at ChildProcess.target.send (internal/child_process.js:678:19)
                      at /opt/iobroker/node_modules/iobroker.history/main.js:1061:28
                      at getCachedData (/opt/iobroker/node_modules/iobroker.history/main.js:837:5)
                      at ChildProcess. (/opt/iobroker/node_modules/iobroker.history/main.js:1060:21)
                      at ChildProcess.emit (events.js:314:20)
                      at ChildProcess.EventEmitter.emit (domain.js:483:12)
                      at emit (internal/child_process.js:877:12)
                      at processTicksAndRejections (internal/process/task_queues.js:85:21)
                      2021-03-02 18:06:53.508 - error: history.0 (693) Exception-Code: EPIPE: write EPIPE
                      2021-03-02 18:06:53.548 - error: history.0 (693) uncaught exception: write EPIPE
                      2021-03-02 18:06:53.549 - error: history.0 (693) Error: write EPIPE
                      2021-03-02 18:06:53.549 - error: history.0 (693) Exception-Code: EPIPE: write EPIPE
                      2021-03-02 18:06:53.702 - error: history.0 (693) uncaught exception: write EPIPE
                      2021-03-02 18:06:53.703 - error: history.0 (693) Error: write EPIPE
                      2021-03-02 18:06:53.704 - error: history.0 (693) Exception-Code: EPIPE: write EPIPE
                      2021-03-02 18:06:53.712 - error: history.0 (693) uncaught exception: write EPIPE
                      2021-03-02 18:06:53.713 - error: history.0 (693) Error: write EPIPE
                      2021-03-02 18:06:53.857 - error: history.0 (693) Exception-Code: EPIPE: write EPIPE
                      2021-03-02 18:06:54.629 - info: vis-inventwo.0 (858) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2021-03-02 18:06:54.677 - info: modbus.1 (979) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2021-03-02 18:06:54.681 - info: shelly.0 (843) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2021-03-02 18:06:54.687 - info: javascript.0 (678) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2021-03-02 18:06:54.751 - info: cloud.0 (711) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2021-03-02 18:06:54.755 - info: iot.0 (726) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2021-03-02 18:06:54.801 - info: info.0 (1001) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2021-03-02 18:06:54.805 - info: kecontact.0 (633) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2021-03-02 18:06:54.822 - info: mqtt.0 (648) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2021-03-02 18:06:54.820 - info: telegram.0 (743) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2021-03-02 18:06:54.842 - info: backitup.0 (758) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2021-03-02 18:06:54.913 - info: modbus.0 (879) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2021-03-02 18:06:54.984 - info: admin.0 (618) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2021-03-02 18:06:53.871 - error: history.0 (693) uncaught exception: write EPIPE
                      2021-03-02 18:06:53.871 - error: history.0 (693) Error: write EPIPE
                      2021-03-02 18:06:53.872 - error: history.0 (693) Exception-Code: EPIPE: write EPIPE
                      2021-03-02 18:06:53.881 - error: history.0 (693) uncaught exception: write EPIPE
                      2021-03-02 18:06:53.882 - error: history.0 (693) Error: write EPIPE
                      2021-03-02 18:06:54.505 - error: history.0 (693) Exception-Code: EPIPE: write EPIPE
                      2021-03-02 18:06:57.923 - error: info.0 (1001) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2021-03-02 18:06:57.937 - error: vis-inventwo.0 (858) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2021-03-02 18:06:57.945 - error: cloud.0 (711) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2021-03-02 18:06:57.961 - error: backitup.0 (758) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2021-03-02 18:06:57.963 - warn: iot.0 (726) get state error: Connection is closed.
                      2021-03-02 18:06:57.975 - error: telegram.0 (743) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2021-03-02 18:06:57.964 - warn: iot.0 (726) get state error: DB closed
                      2021-03-02 18:06:57.966 - warn: iot.0 (726) get state error: DB closed
                      2021-03-02 18:06:57.967 - warn: iot.0 (726) get state error: DB closed
                      2021-03-02 18:06:57.968 - warn: iot.0 (726) get state error: DB closed
                      2021-03-02 18:06:57.969 - warn: iot.0 (726) get state error: DB closed
                      2021-03-02 18:06:57.970 - warn: iot.0 (726) get state error: DB closed
                      2021-03-02 18:06:57.971 - warn: iot.0 (726) get state error: DB closed
                      2021-03-02 18:06:57.972 - warn: iot.0 (726) get state error: DB closed
                      2021-03-02 18:06:57.987 - error: modbus.1 (979) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2021-03-02 18:06:58.000 - warn: backitup.0 (758) get state error: Connection is closed.
                      2021-03-02 18:06:58.008 - warn: info.0 (1001) get state error: Connection is closed.
                      2021-03-02 18:06:58.022 - warn: cloud.0 (711) get state error: Connection is closed.
                      2021-03-02 18:06:58.035 - error: mqtt.0 (648) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2021-03-02 18:06:58.023 - warn: cloud.0 (711) get state error: DB closed
                      2021-03-02 18:06:58.024 - warn: cloud.0 (711) get state error: DB closed
                      2021-03-02 18:06:58.025 - warn: cloud.0 (711) get state error: DB closed
                      2021-03-02 18:06:58.026 - warn: cloud.0 (711) get state error: DB closed
                      2021-03-02 18:06:58.034 - warn: cloud.0 (711) get state error: DB closed
                      2021-03-02 18:06:58.035 - warn: cloud.0 (711) get state error: DB closed
                      2021-03-02 18:06:58.036 - warn: cloud.0 (711) get state error: DB closed
                      2021-03-02 18:06:58.037 - warn: cloud.0 (711) get state error: DB closed
                      2021-03-02 18:06:58.038 - warn: cloud.0 (711) get state error: DB closed
                      2021-03-02 18:06:58.041 - error: shelly.0 (843) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2021-03-02 18:06:58.055 - warn: vis-inventwo.0 (858) get state error: Connection is closed.
                      2021-03-02 18:06:58.057 - error: kecontact.0 (633) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      2021-03-02 18:06:58.081 - warn: kecontact.0 (633) get state error: Connection is closed.
                      2021-03-02 18:06:58.082 - warn: kecontact.0 (633) get state error: DB closed
                      2021-03-02 18:06:58.085 - warn: kecontact.0 (633) get state error: DB closed
                      2021-03-02 18:06:58.086 - warn: kecontact.0 (633) get state error: DB closed
                      2021-03-02 18:07:02.954 - error: cloud.0 (711) Cannot check object existence of "cloud.0.info.connection": Connection is closed.
                      2021-03-02 18:07:03.068 - error: kecontact.0 (633) Cannot check object existence of "kecontact.0.Sessions.Session_25.json": Connection is closed.
                      2021-03-02 18:07:03.175 - error: javascript.0 (678) Cannot check object existence of "javascript.0.scriptEnabled.common.AMIS": Connection is closed.
                      2021-03-02 18:07:05.188 - info: host.raspi4iobrokerpv iobroker.js-controller version 3.2.16 js-controller starting
                      2021-03-02 18:07:05.194 - info: host.raspi4iobrokerpv Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                      2021-03-02 18:07:05.194 - info: host.raspi4iobrokerpv hostname: raspi4iobrokerpv, node: v12.21.0
                      2021-03-02 18:07:05.195 - info: host.raspi4iobrokerpv ip addresses: 192.168.0.93 fe80::9a94:9b45:baab:4bdd
                      2021-03-02 18:07:05.739 - info: host.raspi4iobrokerpv connected to Objects and States
                      2021-03-02 18:07:05.782 - info: host.raspi4iobrokerpv added notifications configuration of host
                      2021-03-02 18:07:06.289 - info: host.raspi4iobrokerpv 24 instances found
                      2021-03-02 18:07:06.351 - info: host.raspi4iobrokerpv starting 19 instances
                      2021-03-02 18:07:06.441 - info: host.raspi4iobrokerpv instance system.adapter.admin.0 started with pid 26950
                      2021-03-02 18:07:08.079 - error: admin.0 (26950) admin.0 already running
                      2021-03-02 18:07:08.082 - warn: admin.0 (26950) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2021-03-02 18:07:08.672 - error: host.raspi4iobrokerpv instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2021-03-02 18:07:08.673 - info: host.raspi4iobrokerpv Restart adapter system.adapter.admin.0 because enabled
                      2021-03-02 18:07:10.399 - info: host.raspi4iobrokerpv instance system.adapter.kecontact.0 started with pid 26961
                      2021-03-02 18:07:11.529 - error: kecontact.0 (26961) kecontact.0 already running
                      2021-03-02 18:07:11.532 - warn: kecontact.0 (26961) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2021-03-02 18:07:12.100 - error: host.raspi4iobrokerpv instance system.adapter.kecontact.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2021-03-02 18:07:12.102 - info: host.raspi4iobrokerpv Restart adapter system.adapter.kecontact.0 because enabled
                      2021-03-02 18:07:14.474 - info: host.raspi4iobrokerpv instance system.adapter.mqtt.0 started with pid 26973
                      2021-03-02 18:07:15.487 - error: mqtt.0 (26973) mqtt.0 already running
                      2021-03-02 18:07:15.490 - warn: mqtt.0 (26973) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2021-03-02 18:07:16.123 - error: host.raspi4iobrokerpv instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2021-03-02 18:07:16.124 - info: host.raspi4iobrokerpv Restart adapter system.adapter.mqtt.0 because enabled
                      2021-03-02 18:07:18.461 - info: host.raspi4iobrokerpv instance system.adapter.web.0 started with pid 26984
                      2021-03-02 18:07:19.648 - error: web.0 (26984) web.0 already running
                      2021-03-02 18:07:20.225 - error: host.raspi4iobrokerpv instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2021-03-02 18:07:20.226 - info: host.raspi4iobrokerpv Restart adapter system.adapter.web.0 because enabled
                      2021-03-02 18:07:22.470 - info: host.raspi4iobrokerpv instance system.adapter.javascript.0 started with pid 26995
                      2021-03-02 18:07:24.689 - error: javascript.0 (26995) javascript.0 already running
                      2021-03-02 18:07:24.692 - warn: javascript.0 (26995) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2021-03-02 18:07:25.270 - error: host.raspi4iobrokerpv instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2021-03-02 18:07:25.271 - info: host.raspi4iobrokerpv Restart adapter system.adapter.javascript.0 because enabled
                      2021-03-02 18:07:26.458 - info: host.raspi4iobrokerpv instance system.adapter.history.0 started with pid 27006
                      2021-03-02 18:07:27.506 - error: history.0 (27006) history.0 already running
                      2021-03-02 18:07:27.509 - warn: history.0 (27006) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2021-03-02 18:07:28.107 - error: host.raspi4iobrokerpv instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2021-03-02 18:07:28.108 - info: host.raspi4iobrokerpv Restart adapter system.adapter.history.0 because enabled
                      2021-03-02 18:07:30.445 - info: host.raspi4iobrokerpv instance system.adapter.cloud.0 started with pid 27017
                      2021-03-02 18:07:31.758 - error: cloud.0 (27017) cloud.0 already running
                      2021-03-02 18:07:31.761 - warn: cloud.0 (27017) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2021-03-02 18:07:32.331 - error: host.raspi4iobrokerpv instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2021-03-02 18:07:32.332 - info: host.raspi4iobrokerpv Restart adapter system.adapter.cloud.0 because enabled
                      2021-03-02 18:07:34.477 - info: host.raspi4iobrokerpv instance system.adapter.iot.0 started with pid 27029
                      2021-03-02 18:07:35.996 - error: iot.0 (27029) iot.0 already running
                      2021-03-02 18:07:35.999 - warn: iot.0 (27029) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2021-03-02 18:07:36.575 - error: host.raspi4iobrokerpv instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2021-03-02 18:07:36.575 - info: host.raspi4iobrokerpv Restart adapter system.adapter.iot.0 because enabled
                      2021-03-02 18:07:38.471 - info: host.raspi4iobrokerpv instance system.adapter.telegram.0 started with pid 27040
                      2021-03-02 18:07:38.695 - info: host.raspi4iobrokerpv instance system.adapter.admin.0 started with pid 27047
                      2021-03-02 18:07:40.431 - error: telegram.0 (27040) telegram.0 already running
                      2021-03-02 18:07:40.434 - warn: telegram.0 (27040) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2021-03-02 18:07:40.715 - info: admin.0 (27047) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.21.0, js-controller: 3.2.16
                      2021-03-02 18:07:40.765 - info: admin.0 (27047) requesting all states
                      2021-03-02 18:07:40.766 - info: admin.0 (27047) requesting all objects
                      2021-03-02 18:07:41.444 - error: host.raspi4iobrokerpv instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2021-03-02 18:07:41.445 - info: host.raspi4iobrokerpv Restart adapter system.adapter.telegram.0 because enabled
                      2021-03-02 18:07:41.715 - info: admin.0 (27047) received all objects
                      2021-03-02 18:07:41.859 - info: admin.0 (27047) http server listening on port 8081
                      2021-03-02 18:07:42.124 - info: host.raspi4iobrokerpv instance system.adapter.kecontact.0 started with pid 27066
                      2021-03-02 18:07:41.859 - info: admin.0 (27047) Use link "http://localhost:8081" to configure.
                      2021-03-02 18:07:42.375 - info: host.raspi4iobrokerpv instance system.adapter.backitup.0 started with pid 27073
                      2021-03-02 18:07:43.756 - info: kecontact.0 (27066) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.kecontact, node: v12.21.0, js-controller: 3.2.16
                      2021-03-02 18:07:46.149 - info: host.raspi4iobrokerpv instance system.adapter.mqtt.0 started with pid 27093
                      2021-03-02 18:07:46.176 - error: backitup.0 (27073) backitup.0 already running
                      2021-03-02 18:07:46.179 - warn: backitup.0 (27073) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2021-03-02 18:07:46.769 - error: host.raspi4iobrokerpv instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2021-03-02 18:07:46.771 - info: host.raspi4iobrokerpv Restart adapter system.adapter.backitup.0 because enabled
                      2021-03-02 18:07:47.713 - info: mqtt.0 (27093) starting. Version 2.3.4 in /opt/iobroker/node_modules/iobroker.mqtt, node: v12.21.0, js-controller: 3.2.16
                      2021-03-02 18:07:47.854 - info: vis.0 (27100) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.vis, node: v12.21.0, js-controller: 3.2.16
                      2021-03-02 18:07:47.944 - info: mqtt.0 (27093) Starting MQTT server on 0.0.0.0:1883
                      2021-03-02 18:07:48.266 - info: vis.0 (27100) vis license is OK.
                      2021-03-02 18:07:48.816 - info: kecontact.0 (27066) starting charging station in passive mode
                      2021-03-02 18:07:49.128 - info: vis.0 (27100) Terminated (NO_ERROR): Without reason
                      2021-03-02 18:07:49.732 - info: host.raspi4iobrokerpv instance system.adapter.vis.0 terminated while should be started once
                      2021-03-02 18:07:50.242 - info: host.raspi4iobrokerpv instance system.adapter.web.0 started with pid 27123
                      2021-03-02 18:07:50.423 - info: host.raspi4iobrokerpv instance system.adapter.shelly.0 started with pid 27130
                      2021-03-02 18:07:52.670 - error: shelly.0 (27130) shelly.0 already running
                      2021-03-02 18:07:52.673 - warn: shelly.0 (27130) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2021-03-02 18:07:53.273 - error: host.raspi4iobrokerpv instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2021-03-02 18:07:53.274 - info: host.raspi4iobrokerpv Restart adapter system.adapter.shelly.0 because enabled
                      2021-03-02 18:07:54.525 - info: host.raspi4iobrokerpv instance system.adapter.vis-inventwo.0 started with pid 27149
                      2021-03-02 18:07:55.290 - info: host.raspi4iobrokerpv instance system.adapter.javascript.0 started with pid 27156
                      2021-03-02 18:07:55.672 - error: vis-inventwo.0 (27149) vis-inventwo.0 already running
                      2021-03-02 18:07:55.676 - warn: vis-inventwo.0 (27149) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2021-03-02 18:07:56.441 - error: host.raspi4iobrokerpv instance system.adapter.vis-inventwo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2021-03-02 18:07:56.442 - info: host.raspi4iobrokerpv Restart adapter system.adapter.vis-inventwo.0 because enabled
                      2021-03-02 18:07:58.131 - info: host.raspi4iobrokerpv instance system.adapter.history.0 started with pid 27171
                      2021-03-02 18:07:58.254 - info: mqtt.0 (27093) Client [H,] connected with secret 1614704878245_712
                      2021-03-02 18:07:58.478 - info: host.raspi4iobrokerpv instance system.adapter.modbus.0 started with pid 27178
                      2021-03-02 18:07:58.625 - info: javascript.0 (27156) starting. Version 4.8.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.21.0, js-controller: 3.2.16
                      2021-03-02 18:07:58.807 - info: javascript.0 (27156) requesting all states
                      2021-03-02 18:07:58.809 - info: javascript.0 (27156) requesting all objects
                      2021-03-02 18:08:00.037 - info: javascript.0 (27156) received all states
                      2021-03-02 18:08:00.052 - info: javascript.0 (27156) received all objects
                      2021-03-02 18:08:00.404 - info: javascript.0 (27156) Start javascript script.js.common.AMIS
                      2021-03-02 18:08:00.493 - info: javascript.0 (27156) script.js.common.AMIS: registered 1 subscription and 0 schedules
                      2021-03-02 18:08:00.522 - error: modbus.0 (27178) modbus.0 already running
                      2021-03-02 18:08:00.527 - warn: modbus.0 (27178) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2021-03-02 18:08:00.587 - info: javascript.0 (27156) Start javascript script.js.common.SE_Power
                      2021-03-02 18:08:00.597 - info: javascript.0 (27156) script.js.common.SE_Power: registered 0 subscriptions and 0 schedules
                      2021-03-02 18:08:00.598 - info: javascript.0 (27156) Start javascript script.js.common.Sonnenstand
                      2021-03-02 18:08:00.606 - info: javascript.0 (27156) script.js.common.Sonnenstand: long: - lat:
                      2021-03-02 18:08:00.623 - info: javascript.0 (27156) script.js.common.Sonnenstand: Script Sonnenstand; Erfolgreich gelaufen, Werte akzeptiert
                      2021-03-02 18:08:00.630 - info: javascript.0 (27156) script.js.common.Sonnenstand: registered 0 subscriptions and 1 schedule
                      2021-03-02 18:08:00.632 - info: javascript.0 (27156) Start javascript script.js.common.Powerbank
                      2021-03-02 18:08:00.640 - info: javascript.0 (27156) script.js.common.Powerbank: registered 2 subscriptions and 1 schedule
                      2021-03-02 18:08:00.641 - info: javascript.0 (27156) Start javascript script.js.common.Grid-PV
                      2021-03-02 18:08:00.646 - info: javascript.0 (27156) script.js.common.Grid-PV: registered 1 subscription and 0 schedules
                      2021-03-02 18:08:00.647 - info: javascript.0 (27156) Start javascript script.js.common.SMA+SE
                      2021-03-02 18:08:00.655 - info: javascript.0 (27156) script.js.common.SMA+SE: registered 1 subscription and 0 schedules
                      2021-03-02 18:08:00.655 - info: javascript.0 (27156) Start javascript script.js.common.Zoe_Zielladung
                      2021-03-02 18:08:00.661 - info: javascript.0 (27156) script.js.common.Zoe_Zielladung: registered 1 subscription and 0 schedules
                      2021-03-02 18:08:00.662 - info: javascript.0 (27156) Start javascript script.js.common.PVÜberschuss
                      2021-03-02 18:08:00.667 - info: javascript.0 (27156) script.js.common.PVÜberschuss: registered 1 subscription and 0 schedules
                      2021-03-02 18:08:01.527 - info: javascript.0 (27156) Start javascript script.js.common.ZOE_Ladung
                      2021-03-02 18:08:01.535 - info: javascript.0 (27156) script.js.common.ZOE_Ladung: registered 5 subscriptions and 0 schedules
                      2021-03-02 18:08:01.777 - error: host.raspi4iobrokerpv instance system.adapter.modbus.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2021-03-02 18:08:01.778 - info: host.raspi4iobrokerpv Restart adapter system.adapter.modbus.0 because enabled
                      2021-03-02 18:08:02.226 - info: history.0 (27171) starting. Version 1.9.12 in /opt/iobroker/node_modules/iobroker.history, node: v12.21.0, js-controller: 3.2.16
                      2021-03-02 18:08:02.333 - info: history.0 (27171) enabled logging of kecontact.0.pf (Count=1), Alias=false
                      2021-03-02 18:08:02.334 - info: history.0 (27171) enabled logging of kecontact.0.p (Count=2), Alias=false
                      2021-03-02 18:08:02.335 - info: history.0 (27171) enabled logging of kecontact.0.currentUser (Count=3), Alias=false
                      2021-03-02 18:08:02.336 - info: history.0 (27171) enabled logging of mqtt.0.info.connection (Count=4), Alias=false
                      2021-03-02 18:08:02.337 - info: history.0 (27171) enabled logging of 0_userdata.0.AMIS.170 (Count=5), Alias=false
                      2021-03-02 18:08:02.338 - info: history.0 (27171) enabled logging of 0_userdata.0.AMIS.270 (Count=6), Alias=false
                      2021-03-02 18:08:02.339 - info: history.0 (27171) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Switch (Count=7), Alias=false
                      2021-03-02 18:08:02.339 - info: history.0 (27171) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Power (Count=8), Alias=false
                      2021-03-02 18:08:02.340 - info: history.0 (27171) enabled logging of 0_userdata.0.AMIS.Power (Count=9), Alias=false
                      2021-03-02 18:08:02.340 - info: history.0 (27171) enabled logging of kecontact.0.currentTimer (Count=10), Alias=false
                      2021-03-02 18:08:02.341 - info: history.0 (27171) enabled logging of modbus.0.inputRegisters.30775_PVLeistung (Count=11), Alias=false
                      2021-03-02 18:08:02.342 - info: history.0 (27171) enabled logging of javascript.0.Solar.Wechselrichter.PVLeistungAktuell (Count=12), Alias=false
                      2021-03-02 18:08:02.342 - info: history.0 (27171) enabled logging of 0_userdata.0.AMIS.PVPower (Count=13), Alias=false
                      2021-03-02 18:08:02.343 - info: history.0 (27171) enabled logging of 0_userdata.0.AMIS.PVÜberschuss (Count=14), Alias=false
                      2021-03-02 18:08:02.359 - info: host.raspi4iobrokerpv instance system.adapter.cloud.0 started with pid 27209
                      2021-03-02 18:08:02.728 - info: host.raspi4iobrokerpv instance system.adapter.modbus.1 started with pid 27216
                      2021-03-02 18:08:04.148 - error: modbus.1 (27216) modbus.1 already running
                      2021-03-02 18:08:04.151 - warn: modbus.1 (27216) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2021-03-02 18:08:04.584 - info: cloud.0 (27209) starting. Version 4.0.4 in /opt/iobroker/node_modules/iobroker.cloud, node: v12.21.0, js-controller: 3.2.16
                      2021-03-02 18:08:04.670 - info: cloud.0 (27209) Connecting with https://iobroker.net:10555 with "richard.nussdorfer@gmail.com_65a2cba0-c435-11ea-b03c-2dda666d26a"
                      2021-03-02 18:08:04.741 - error: host.raspi4iobrokerpv instance system.adapter.modbus.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2021-03-02 18:08:04.742 - info: host.raspi4iobrokerpv Restart adapter system.adapter.modbus.1 because enabled
                      2021-03-02 18:08:04.885 - info: cloud.0 (27209) Trying to connect as system.user.admin
                      2021-03-02 18:08:05.272 - info: cloud.0 (27209) Adapter redirected temporally to "https://iobroker.net:10556" in one minute. Reason: command from server
                      2021-03-02 18:08:05.277 - info: cloud.0 (27209) Connection changed: io client disconnect
                      2021-03-02 18:08:06.367 - info: host.raspi4iobrokerpv instance scheduled system.adapter.zoe2.0 */10 * * * *
                      2021-03-02 18:08:06.624 - info: host.raspi4iobrokerpv instance system.adapter.iot.0 started with pid 27235```
                      BG
                      • wendy2702W Online
                        wendy2702W Online
                        @humidor Möglicherweise liegt es am basteln.
                        Schleife eingebaut oder ähnliches.
                        Auslastung auf geschaukelt
                        HumidorH 1 Antwort Letzte Antwort
                        • wendy2702W wendy2702
                          HumidorH Online
                          HumidorH Online
                          Humidor
                          schrieb am zuletzt editiert von Humidor
                          @wendy2702
                          Datenträger verfügbar: 76.6 %, gesamte RAM-Nutzung: 1145 MB / Frei: 63% = 1.173 MB [Host: raspi4iobrokerpv - 16 Prozesse]
                          Wenn ein Script jede Sekunde ein Blockly durcharbeitet (Cronjob), darf das keine zu große Auslastung sein. Eine Endlosschleife würde den endgültigen Tod bedeuten nehme ich an, also auch nicht.
                          Wenn ich den Logeinträgen folge, verlieren Instanzen Ihre Verbindung und lösen dann einen Restart aus.
                          Der Absturtz bis nach Restart hat gut 20min gedauert.
                          BG
                          • HumidorH Humidor
                            @wendy2702
                            HumidorH Online
                            HumidorH Online
                            Humidor
                            @Thomas-Braun gerade wieder ein Restart, gestern Vormittag meine letzte Änderung im Script...
                            Log ab dem ersten roten Eintrag (putty)
                            [    6.199753] brcmfmac: F1 signature read @0x18000000=0x15264345
                            [    6.213336] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                            [    6.217956] usbcore: registered new interface driver brcmfmac
                            [    6.229254] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
                            [    6.463189] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                            [    6.472543] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
                            [    7.657064] random: crng init done
                            [    7.657080] random: 7 urandom warning(s) missed due to ratelimiting
                            [    8.328432] uart-pl011 fe201000.serial: no DMA platform data
                            [    8.528777] 8021q: 802.1Q VLAN Support v1.8
                            [    8.643547] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
                            [    8.696698] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                            [    8.991957] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                            [    8.992311] bcmgenet fd580000.ethernet eth0: Link is Down
                            [   13.998866] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
                            [   15.103223] Bluetooth: Core ver 2.22
                            [   15.103331] NET: Registered protocol family 31
                            [   15.103347] Bluetooth: HCI device and connection manager initialized
                            [   15.103378] Bluetooth: HCI socket layer initialized
                            [   15.103400] Bluetooth: L2CAP socket layer initialized
                            [   15.103435] Bluetooth: SCO socket layer initialized
                            [   15.112740] Bluetooth: HCI UART driver ver 2.3
                            [   15.112762] Bluetooth: HCI UART protocol H4 registered
                            [   15.112873] Bluetooth: HCI UART protocol Three-wire (H5) registered
                            [   15.114263] Bluetooth: HCI UART protocol Broadcom registered
                            [   15.235681] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                            [   15.235690] Bluetooth: BNEP filters: protocol multicast
                            [   15.235703] Bluetooth: BNEP socket layer initialized
                            [   31.833599] vcc-sd: disabling
                            [   63.885706] FS-Cache: Netfs 'cifs' registered for caching
                            [   63.894222] Key type cifs.spnego registered
                            [   63.894236] Key type cifs.idmap registered
                            [   63.895567] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
                            [   63.895619] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
                            [82303.059999] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
                            [82303.060095] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
                            [168704.428578] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
                            [168704.428673] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
                            [255105.912270] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
                            [255105.912339] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
                            [341507.341931] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
                            [341507.341981] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
                            [345505.634766] node invoked oom-killer: gfp_mask=0x400cc0(GFP_KERNEL_ACCOUNT), order=0, oom_score_adj=0
                            [345505.634781] CPU: 2 PID: 23986 Comm: node Tainted: G         C        5.10.11-v7l+ #1399
                            [345505.634785] Hardware name: BCM2711
                            [345505.634790] Backtrace:
                            [345505.634814] [<c0b58f24>] (dump_backtrace) from [<c0b592b8>] (show_stack+0x20/0x24)
                            [345505.634820]  r7:ffffffff r6:00000000 r5:60000113 r4:c12e69bc
                            [345505.634829] [<c0b59298>] (show_stack) from [<c0b5d644>] (dump_stack+0xcc/0xf8)
                            [345505.634837] [<c0b5d578>] (dump_stack) from [<c0b5b8d4>] (dump_header+0x64/0x208)
                            [345505.634843]  r10:c120518c r9:00400cc0 r8:00000000 r7:c0e35b18 r6:d6f97c00 r5:c3fbec80
                            [345505.634847]  r4:ef461ce8 r3:70f18072
                            [345505.634859] [<c0b5b870>] (dump_header) from [<c03b53d0>] (oom_kill_process+0x1b4/0x1c0)
                            [345505.634864]  r7:c0e35b18 r6:ef461ce8 r5:c3fbf200 r4:c3fbec80
                            [345505.634871] [<c03b521c>] (oom_kill_process) from [<c03b5f28>] (out_of_memory+0x2b8/0x390)
                            [345505.634877]  r7:c1208580 r6:c1205048 r5:c3fbec80 r4:ef461ce8
                            [345505.634884] [<c03b5c70>] (out_of_memory) from [<c0408d28>] (__alloc_pages_nodemask+0x7ec/0x1184)
                            [345505.634890]  r7:c13356d0 r6:00001800 r5:000019b0 r4:00000000
                            [345505.634899] [<c040853c>] (__alloc_pages_nodemask) from [<c09deb90>] (alloc_skb_with_frags+0xdc/0x1a4)
                            [345505.634905]  r10:c5b586c0 r9:00008000 r8:004008c0 r7:00000000 r6:00000008 r5:00000008
                            [345505.634909]  r4:00000003
                            [345505.634917] [<c09deab4>] (alloc_skb_with_frags) from [<c09d63e8>] (sock_alloc_send_pskb+0x214/0x248)
                            [345505.634922]  r10:ef461df8 r9:c1205048 r8:c026fee8 r7:ef461e60 r6:ffffe000 r5:00000000
                            [345505.634926]  r4:d6f97900
                            [345505.634936] [<c09d61d4>] (sock_alloc_send_pskb) from [<c0b02bd8>] (unix_stream_sendmsg+0x158/0x3c0)
                            [345505.634942]  r10:d6f97900 r9:00000f00 r8:d6f97600 r7:ef461e60 r6:00000000 r5:00008f00
                            [345505.634946]  r4:00008000
                            [345505.634955] [<c0b02a80>] (unix_stream_sendmsg) from [<c09d0aa0>] (sock_sendmsg+0x44/0x54)
                            [345505.634960]  r10:cc681b80 r9:ef67d6c0 r8:ef461ef8 r7:00000000 r6:00000000 r5:cc681b80
                            [345505.634964]  r4:ef461e60
                            [345505.634972] [<c09d0a5c>] (sock_sendmsg) from [<c09d0b54>] (sock_write_iter+0xa4/0xf8)
                            [345505.634976]  r5:c1205048 r4:ef461ee0
                            [345505.634987] [<c09d0ab0>] (sock_write_iter) from [<c0439c98>] (vfs_write+0x3ec/0x464)
                            [345505.634992]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:c1205048 r5:0000b105
                            [345505.634996]  r4:ef67d6c0
                            [345505.635004] [<c04398ac>] (vfs_write) from [<c0439ed8>] (ksys_write+0xcc/0xe0)
                            [345505.635010]  r10:0000b105 r9:b638a008 r8:ef67d6c0 r7:00000004 r6:00000003 r5:ef67d6c1
                            [345505.635014]  r4:c1205048
                            [345505.635022] [<c0439e0c>] (ksys_write) from [<c0439f04>] (sys_write+0x18/0x1c)
                            [345505.635027]  r10:00000004 r9:ef460000 r8:c0200204 r7:00000004 r6:00000003 r5:b638a008
                            [345505.635031]  r4:0000b105
                            [345505.635042] [<c0439eec>] (sys_write) from [<c0200040>] (ret_fast_syscall+0x0/0x28)
                            [345505.635047] Exception stack(0xef461fa8 to 0xef461ff0)
                            [345505.635053] 1fa0:                   0000b105 b638a008 00000003 b638a008 0000b105 00000000
                            [345505.635059] 1fc0: 0000b105 b638a008 00000003 00000004 00000001 be875048 be875030 be874fec
                            [345505.635064] 1fe0: 00000002 be874f50 00000000 b6d0c1bc
                            [345505.635069] Mem-Info:
                            [345505.635081] active_anon:39564 inactive_anon:391574 isolated_anon:0
                                             active_file:6349 inactive_file:6283 isolated_file:285
                                             unevictable:4 dirty:11 writeback:0
                                             slab_reclaimable:3095 slab_unreclaimable:5661
                                             mapped:10599 shmem:700 pagetables:9012 bounce:0
                                             free:8524 free_pcp:59 free_cma:898
                            [345505.635092] Node 0 active_anon:158256kB inactive_anon:1566296kB active_file:25396kB inactive_file:25132kB unevictable:16kB isolated(anon):0kB isolated(file):1140kB mapped:42396kB dirty:44kB writeback:0kB shmem:2800kB writeback_tmp:0kB kernel_stack:7384kB all_unreclaimable? no
                            [345505.635103] DMA free:25948kB min:24576kB low:28672kB high:32768kB reserved_highatomic:0KB active_anon:57204kB inactive_anon:525208kB active_file:424kB inactive_file:244kB unevictable:0kB writepending:32kB present:786432kB managed:678432kB mlocked:0kB pagetables:13108kB bounce:0kB free_pcp:232kB local_pcp:120kB free_cma:3592kB
                            [345505.635109] lowmem_reserve[]: 0 0 1203 0
                            [345505.635146] HighMem free:8148kB min:8704kB low:16140kB high:23576kB reserved_highatomic:0KB active_anon:100112kB inactive_anon:1039500kB active_file:24992kB inactive_file:24684kB unevictable:16kB writepending:384kB present:1231872kB managed:1231872kB mlocked:16kB pagetables:22940kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
                            [345505.635152] lowmem_reserve[]: 0 0 0 0
                            [345505.635184] DMA: 777*4kB (UMEC) 739*8kB (UMEC) 442*16kB (UMEC) 182*32kB (UMEC) 40*64kB (UEC) 12*128kB (E) 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 26012kB
                            [345505.635289] HighMem: 104*4kB (UM) 385*8kB (UM) 118*16kB (UM) 46*32kB (UM) 8*64kB (UM) 3*128kB (U) 1*256kB (U) 1*512kB (U) 1*1024kB (U) 0*2048kB 0*4096kB = 9544kB
                            [345505.635410] 12545 total pagecache pages
                            [345505.635418] 1430 pages in swap cache
                            [345505.635425] Swap cache stats: add 28769, delete 27339, find 2183/2924
                            [345505.635431] Free swap  = 0kB
                            [345505.635437] Total swap = 102396kB
                            [345505.635443] 504576 pages RAM
                            [345505.635449] 307968 pages HighMem/MovableOnly
                            [345505.635455] 27000 pages reserved
                            [345505.635461] 65536 pages cma reserved
                            [345505.635467] Tasks state (memory values in pages):
                            [345505.635473] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
                            [345505.635493] [    112]     0   112     5311     1123   139264      131             0 systemd-journal
                            [345505.635502] [    146]     0   146     4497      342    49152      153         -1000 systemd-udevd
                            [345505.635513] [    291]   100   291     5604      417    61440      141             0 systemd-timesyn
                            [345505.635523] [    326]   108   326     1476      426    36864       29             0 avahi-daemon
                            [345505.635531] [    327]     0   327     6378      354    49152      101             0 rsyslogd
                            [345505.635538] [    334]     0   334      923      215    28672       40             0 alsactl
                            [345505.635546] [    336]     0   336     1987      254    36864       31             0 cron
                            [345505.635554] [    344]     0   344     6914      214    40960       10             0 rngd
                            [345505.635562] [    352]   104   352     1665      421    36864       46          -900 dbus-daemon
                            [345505.635570] [    353]   108   353     1443       13    32768       50             0 avahi-daemon
                            [345505.635578] [    361]     0   361     2686      286    45056       89             0 wpa_supplicant
                            [345505.635586] [    362]     0   362     3283      462    53248      131             0 systemd-logind
                            [345505.635594] [    367] 65534   367     1080      219    36864       39             0 thd
                            [345505.635601] [    455]     0   455     2751      613    45056      102             0 wpa_supplicant
                            [345505.635609] [    469]     0   469      535        0    28672       32             0 hciattach
                            [345505.635617] [    473]     0   473     2384      127    45056       93             0 bluetoothd
                            [345505.635624] [    538]     0   538      726      272    28672       50             0 dhcpcd
                            [345505.635633] [    539]  1001   539    73874    33503  1077248    14438             0 node
                            [345505.635641] [    544]   109   544   237909     3364   225280      964             0 grafana-server
                            [345505.635649] [    546]     0   546     9677     1894    90112     1296             0 unattended-upgr
                            [345505.635656] [    547]     0   547     1077      119    32768       25             0 agetty
                            [345505.635664] [    548]     0   548     2682      267    49152      130         -1000 sshd
                            [345505.635672] [    579]  1001   579    43527    19340   757760       43             0 node
                            [345505.635680] [    594]  1001   594    39878    15292   618496      213             0 node
                            [345505.635689] [    617]  1001   617    39189    14540   610304      352             0 node
                            [345505.635697] [    647]  1001   647    52000    27662   901120      142             0 node
                            [345505.635704] [    662]  1001   662    42967    17341   610304       33             0 node
                            [345505.635713] [    680]  1001   680    38560    13466   548864      196             0 node
                            [345505.635721] [    695]  1001   695    39489    14807   626688       75             0 node
                            [345505.635729] [    712]  1001   712    42830    15734   643072      155             0 node
                            [345505.635737] [    727]  1001   727    45224    20724   786432      251             0 node
                            [345505.635746] [    785]  1001   785    52077    27639   802816      188             0 node
                            [345505.635754] [    800]  1001   800    36749    11939   479232      115             0 node
                            [345505.635762] [    822]  1001   822    38633    14169   577536      178             0 node
                            [345505.635769] [    837]  1001   837    39767    15240   598016      140             0 node
                            [345505.635777] [    852]  1001   852    39565    15187   593920       70             0 node
                            [345505.635785] [   7741]     0  7741     9491      957    69632        4             0 polkitd
                            [345505.635793] [   8166]  1001  8166    41727    15868   630784      956             0 node
                            [345505.635801] [   8235]  1001  8235    46083    18920   688128     2818             0 node
                            [345505.635812] [  23574]  1001 23574    23902     8644   323584        0             0 node
                            [345505.635820] [  23580]  1001 23580    23470     8227   278528        0             0 node
                            [345505.635828] [  23581]  1001 23581    26482    10632   397312        0             0 node
                            [345505.635836] [  23584]  1001 23584    25555     9702   409600        0             0 node
                            [345505.635844] [  23589]  1001 23589    23472     8339   286720        0             0 node
                            [345505.635851] [  23596]  1001 23596    26403    10701   389120        0             0 node
                            [345505.635859] [  23598]  1001 23598    25542     9875   413696        0             0 node
                            [345505.635867] [  23612]  1001 23612    23472     8289   286720        0             0 node
                            [345505.635875] [  23615]  1001 23615    26409    10609   385024        0             0 node
                            [345505.635882] [  23622]  1001 23622    25475     9904   397312        0             0 node
                            [345505.635891] [  23623]  1001 23623    23470     8272   290816        0             0 node
                            [345505.635899] [  23636]  1001 23636    26549    10686   405504        0             0 node
                            [345505.635907] [  23644]  1001 23644    25602     9727   413696        0             0 node
                            [345505.635914] [  23651]  1001 23651    23476     8336   294912        0             0 node
                            [345505.635922] [  23658]  1001 23658    26479    10664   393216        0             0 node
                            [345505.635931] [  23659]  1001 23659    23840     8646   315392        0             0 node
                            [345505.635938] [  23667]  1001 23667    23472     8293   286720        0             0 node
                            [345505.635946] [  23678]  1001 23678    26384    10433   385024        0             0 node
                            [345505.635954] [  23686]  1001 23686    23915     8548   339968        0             0 node
                            [345505.635962] [  23693]  1001 23693    23609     8151   294912        0             0 node
                            [345505.635970] [  23695]  1001 23695    26437    10479   401408        0             0 node
                            [345505.635977] [  23708]  1001 23708    23906     8675   327680        0             0 node
                            [345505.635985] [  23713]  1001 23713    23539     8017   294912        0             0 node
                            [345505.635993] [  23715]  1001 23715    26374    10438   389120        0             0 node
                            [345505.636000] [  23723]  1001 23723    23866     8570   335872        0             0 node
                            [345505.636008] [  23738]  1001 23738    23613     8189   294912        0             0 node
                            [345505.636016] [  23741]  1001 23741    26437    10546   385024        0             0 node
                            [345505.636024] [  23747]  1001 23747    23866     8622   344064        0             0 node
                            [345505.636031] [  23753]  1001 23753    23543     8188   286720        0             0 node
                            [345505.636039] [  23759]  1001 23759    26446    10512   393216        0             0 node
                            [345505.636047] [  23765]  1001 23765    27376    11680   409600        0             0 node
                            [345505.636055] [  23770]  1001 23770    23548     8178   290816        0             0 node
                            [345505.636063] [  23777]  1001 23777    25288    10388   323584        0             0 node
                            [345505.636071] [  23789]  1001 23789    26880    10781   405504        0             0 node
                            [345505.636079] [  23798]  1001 23798    23534     8158   290816        0             0 node
                            [345505.636087] [  23801]  1001 23801    26388    10470   385024        0             0 node
                            [345505.636094] [  23806]  1001 23806    26848    10794   417792        0             0 node
                            [345505.636103] [  23815]  1001 23815    23564     8179   286720        0             0 node
                            [345505.636110] [  23824]  1001 23824    24476     8854   299008        0             0 node
                            [345505.636118] [  23827]  1001 23827    27438    11615   409600        0             0 node
                            [345505.636126] [  23836]  1001 23836    23543     8202   299008        0             0 node
                            [345505.636134] [  23851]  1001 23851    24299     8430   290816        0             0 node
                            [345505.636142] [  23852]  1001 23852    25140     9299   294912        0             0 node
                            [345505.636217] [  23853]  1001 23853    23600     8004   299008        0             0 node
                            [345505.636225] [  23860]  1001 23860    24402     8633   299008        0             0 node
                            [345505.636236] [  23871]  1001 23871    25142     9106   303104        0             0 node
                            [345505.636245] [  23882]  1001 23882    23547     8269   294912        0             0 node
                            [345505.636255] [  23883]  1001 23883    23647     8149   258048        0             0 node
                            [345505.636264] [  23889]  1001 23889    24905     8888   290816        0             0 node
                            [345505.636273] [  23897]  1001 23897    22772     7063   233472        0             0 node
                            [345505.636282] [  23909]  1001 23909    24481     9077   299008        0             0 node
                            [345505.636290] [  23915]  1001 23915    24227     8542   253952        0             0 node
                            [345505.636298] [  23923]  1001 23923    22777     7103   233472        0             0 node
                            [345505.636306] [  23925]  1001 23925    23586     7951   241664        0             0 node
                            [345505.636314] [  23931]  1001 23931    23121     6682   241664        0             0 node
                            [345505.636323] [  23935]  1001 23935    23570     8201   290816        0             0 node
                            [345505.636330] [  23945]  1001 23945    22021     6155   221184        0             0 node
                            [345505.636338] [  23946]  1001 23946    24163     8207   245760        0             0 node
                            [345505.636346] [  23958]  1001 23958    21598     6038   196608        0             0 node
                            [345505.636354] [  23976]  1001 23976    22079     6169   221184        0             0 node
                            [345505.636362] [  23978]  1001 23978    24232     8600   253952        0             0 node
                            [345505.636369] [  23979]  1001 23979    23482     7498   282624        0             0 node
                            [345505.636377] [  23986]  1001 23986    22113     5990   221184        0             0 node
                            [345505.636384] [  23990]  1001 23990    21662     6052   200704        0             0 node
                            [345505.636392] [  24007]  1001 24007    22777     6915   245760        0             0 node
                            [345505.636400] [  24015]  1001 24015    21618     6018   188416        0             0 node
                            [345505.636408] [  24027]  1001 24027    21598     6020   196608        0             0 node
                            [345505.636415] [  24029]  1001 24029    21564     5875   192512        0             0 node
                            [345505.636423] [  24036]  1001 24036    21598     6019   196608        0             0 node
                            [345505.636431] [  24042]  1001 24042    21586     6004   200704        0             0 node
                            [345505.636439] [  24054]  1001 24054    22084     6344   225280        0             0 node
                            [345505.636447] [  24061]  1001 24061    21598     6016   200704        0             0 node
                            [345505.636455] [  24068]  1001 24068    21478     5844   196608        0             0 node
                            [345505.636463] [  24081]  1001 24081    21500     5875   192512        0             0 node
                            [345505.636471] [  24084]  1001 24084    21500     5971   188416        0             0 node
                            [345505.636478] [  24086]  1001 24086    21564     5944   196608        0             0 node
                            [345505.636486] [  24094]  1001 24094    21409     5688   188416        0             0 node
                            [345505.636494] [  24105]  1001 24105    21474     5872   188416        0             0 node
                            [345505.636502] [  24106]  1001 24106    21153     5526   176128        0             0 node
                            [345505.636510] [  24107]  1001 24107    21410     5812   184320        0             0 node
                            [345505.636518] [  24119]  1001 24119    21410     5751   192512        0             0 node
                            [345505.636526] [  24132]  1001 24132    20344     5231   151552        0             0 node
                            [345505.636533] [  24137]  1001 24137    20836     5375   176128        0             0 node
                            [345505.636541] [  24139]  1001 24139    20059     4794   159744        0             0 node
                            [345505.636549] [  24146]  1001 24146    20059     4748   155648        0             0 node
                            [345505.636557] [  24152]  1001 24152     8597      137    32768        0             0 node
                            [345505.636566] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/,task=node,pid=539,uid=1001
                            [345505.636647] Out of memory: Killed process 539 (node) total-vm:295496kB, anon-rss:108868kB, file-rss:25144kB, shmem-rss:0kB, UID:1001 pgtables:1052kB oom_score_adj:0
                            [345505.753989] oom_reaper: reaped process 539 (node), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
                            [345608.547443] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
                            [345608.547493] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
                            out of memory, das muss von ioBroker oder einem Adapter kommen.
                            BG
                            • HumidorH Humidor
                              @humidor
                              Vermutlich ein unsauberes Skript.
                              Was für eine Anfrage läuft denn da über cron im Sekundentakt?
                              Den samba-mount würde ich mir an deiner Stelle aber auch mal ansehen.
                                @humidor
                                HumidorH Online
                                HumidorH Online
                                Humidor
                                @thomas-braun Script, die sind so einfach und überschaubar, das glaube ich nicht.
                                samba-mount ? hmm wer, wo was?
                                BG
                                • HumidorH Humidor
                                  @humidor
                                  Auch da kann man Mist machen.
                                    @humidor
                                    HumidorH Online
                                    HumidorH Online
                                    Humidor
                                    @thomas-braun das ist Backitup mit NAS und SMB1, sollte ich das auf SMB 2/ 3 umstellen?
                                    oder NFS?
                                    BG
                                    • HumidorH Humidor
                                      oder NFS?
                                      @humidor
                                      NFS ist immer die bessere Wahl.
                                      Und auch smb2/3 ist besser als 1
                                      • wendy2702W Online
                                        wendy2702W Online
                                        Deutet auf einen Adapter hin der den Memory erschöpft. Da musst du jetzt im iobroker log mal zu dem Zeitpunkt schauen.
                                        Ich vermute aber auch ein Script, auch wenn es überschaubar ist und wie @Thomas-Braun sagt.... sekündliche abfragen sind auch nicht sinnvoll.
                                        HumidorH 2 Antworten Letzte Antwort
                                          HumidorH Online
                                          HumidorH Online
                                          Humidor
                                          @wendy2702
                                          um 7:21 hat er einen Restart gemacht, 7:23 wieder online
                                          die sekündlichen Abfragen mache ich nur wenn der Zoe geladen wird, war zu diesem Zeitpunkt nicht der Fall.
                                          2021-03-08 07:21:58.974 - info: javascript.0 (647) Stop script script.js.common.AMIS
                                          2021-03-08 07:21:58.491 - error: shelly.0 (785) States database error: read ECONNRESET
                                          2021-03-08 07:21:58.968 - info: vis-inventwo.0 (800) cleaned everything up...
                                          2021-03-08 07:21:58.982 - info: javascript.0 (647) Stop script script.js.common.SE_Power
                                          2021-03-08 07:21:58.983 - info: javascript.0 (647) Stop script script.js.common.Sonnenstand
                                          2021-03-08 07:21:58.989 - info: javascript.0 (647) Stop script script.js.common.Grid-PV
                                          2021-03-08 07:21:58.997 - info: javascript.0 (647) Stop script script.js.common.SMA+SE
                                          2021-03-08 07:21:58.999 - info: javascript.0 (647) Stop script script.js.common.Zoe_Zielladung
                                          2021-03-08 07:21:59.000 - info: javascript.0 (647) Stop script script.js.common.PVÜberschuss
                                          2021-03-08 07:21:59.083 - info: javascript.0 (647) Stop script script.js.common.ZOE_Ladung
                                          2021-03-08 07:21:59.096 - info: javascript.0 (647) Stop script script.js.common.Powerbank
                                          2021-03-08 07:21:59.101 - info: javascript.0 (647) Stop script script.js.common.Garage
                                          2021-03-08 07:21:58.861 - error: mqtt.0 (617) Objects database error: read ECONNRESET
                                          2021-03-08 07:21:59.098 - error: shelly.0 (785) Objects database error: read ECONNRESET
                                          2021-03-08 07:21:59.143 - info: shelly.0 (785) Closing Adapter
                                          2021-03-08 07:21:58.971 - info: info.0 (852) cleaned everything up...
                                          2021-03-08 07:21:59.159 - info: life360.0 (8166) Disabled polling.
                                          2021-03-08 07:21:59.166 - info: iot.0 (695) Connection changed: disconnect
                                          2021-03-08 07:21:59.170 - info: iot.0 (695) Connection lost
                                          2021-03-08 07:21:59.182 - info: life360.0 (8166) cleaned everything up...
                                          2021-03-08 07:21:59.153 - info: backitup.0 (727) cleaned everything up...
                                          2021-03-08 07:21:58.976 - info: cloud.0 (680) Connection changed: io client disconnect
                                          2021-03-08 07:21:59.198 - info: cloud.0 (680) Connection lost
                                          2021-03-08 07:21:59.199 - info: cloud.0 (680) Restart adapter by disconnect
                                          2021-03-08 07:21:59.027 - info: admin.0 (579) terminating http server on port 8081
                                          2021-03-08 07:22:00.524 - info: iot.0 (695) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-03-08 07:22:00.614 - info: javascript.0 (647) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-03-08 07:22:00.623 - info: vis-inventwo.0 (800) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-03-08 07:22:00.630 - info: modbus.1 (837) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-03-08 07:22:00.640 - info: modbus.0 (822) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-03-08 07:22:00.648 - info: shelly.0 (785) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-03-08 07:22:00.664 - info: mqtt.0 (617) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-03-08 07:22:00.677 - info: info.0 (852) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-03-08 07:22:00.685 - info: life360.0 (8166) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-03-08 07:22:00.698 - info: backitup.0 (727) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-03-08 07:22:00.705 - info: cloud.0 (680) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-03-08 07:22:00.713 - info: admin.0 (579) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-03-08 07:22:00.675 - info: kecontact.0 (594) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-03-08 07:22:00.697 - info: telegram.0 (712) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          2021-03-08 07:22:03.522 - error: admin.0 (579) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-03-08 07:22:03.545 - error: kecontact.0 (594) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-03-08 07:22:03.616 - error: telegram.0 (712) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-03-08 07:22:03.618 - error: cloud.0 (680) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-03-08 07:22:03.620 - error: info.0 (852) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-03-08 07:22:03.627 - error: life360.0 (8166) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-03-08 07:22:03.637 - error: backitup.0 (727) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-03-08 07:22:03.630 - error: vis-inventwo.0 (800) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-03-08 07:22:03.698 - error: iot.0 (695) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-03-08 07:22:03.674 - error: javascript.0 (647) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-03-08 07:22:03.738 - warn: life360.0 (8166) get state error: Connection is closed.
                                          2021-03-08 07:22:03.805 - warn: admin.0 (579) get state error: Connection is closed.
                                          2021-03-08 07:22:03.825 - warn: kecontact.0 (594) get state error: Connection is closed.
                                          2021-03-08 07:22:03.719 - warn: backitup.0 (727) get state error: Connection is closed.
                                          2021-03-08 07:22:03.913 - error: modbus.0 (822) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-03-08 07:22:03.776 - warn: life360.0 (8166) get state error: DB closed
                                          2021-03-08 07:22:03.987 - error: modbus.1 (837) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-03-08 07:22:04.114 - error: shelly.0 (785) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-03-08 07:22:04.142 - error: mqtt.0 (617) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-03-08 07:22:04.102 - warn: modbus.0 (822) get state error: Connection is closed.
                                          2021-03-08 07:22:04.186 - warn: modbus.0 (822) get state error: DB closed
                                          2021-03-08 07:22:03.716 - error: web.0 (8235) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                          2021-03-08 07:22:04.338 - warn: mqtt.0 (617) get state error: Connection is closed.
                                          2021-03-08 07:22:08.632 - error: life360.0 (8166) Cannot check object existence of "life360.0.info.connection": Connection is closed.
                                          2021-03-08 07:22:08.917 - error: modbus.0 (822) Cannot check object existence of "modbus.0.inputRegisters.30769_DC_Strom_Eingang_1": Connection is closed.
                                          2021-03-08 07:22:09.147 - error: mqtt.0 (617) Cannot check object existence of "mqtt.0.AMIS": Connection is closed.
                                          2021-03-08 07:22:11.573 - error: history.0 (662) States database error: write EPIPE
                                          2021-03-08 07:22:12.256 - error: history.0 (662) uncaught exception: write EPIPE
                                          2021-03-08 07:22:12.256 - error: history.0 (662) Error: write EPIPE
                                          2021-03-08 07:22:12.257 - error: history.0 (662) Exception-Code: EPIPE: write EPIPE
                                          2021-03-08 07:22:12.541 - error: history.0 (662) uncaught exception: write EPIPE
                                          2021-03-08 07:22:12.542 - error: history.0 (662) Error: write EPIPE
                                          2021-03-08 07:22:16.795 - error: history.0 (662) Exception-Code: EPIPE: write EPIPE
                                          2021-03-08 07:22:25.874 - info: host.raspi4iobrokerpv iobroker.js-controller version 3.2.16 js-controller starting
                                          2021-03-08 07:22:25.879 - info: host.raspi4iobrokerpv Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                                          2021-03-08 07:22:25.880 - info: host.raspi4iobrokerpv hostname: raspi4iobrokerpv, node: v12.21.0
                                          2021-03-08 07:22:25.881 - info: host.raspi4iobrokerpv ip addresses: 192.168.0.93 fe80::9a94:9b45:baab:4bdd
                                          2021-03-08 07:22:26.438 - info: host.raspi4iobrokerpv connected to Objects and States
                                          2021-03-08 07:22:26.483 - info: host.raspi4iobrokerpv added notifications configuration of host
                                          2021-03-08 07:22:26.950 - info: host.raspi4iobrokerpv 29 instances found
                                          2021-03-08 07:22:27.018 - info: host.raspi4iobrokerpv starting 20 instances
                                          2021-03-08 07:22:27.113 - info: host.raspi4iobrokerpv instance system.adapter.admin.0 started with pid 25039
                                          2021-03-08 07:22:28.761 - error: admin.0 (25039) admin.0 already running
                                          2021-03-08 07:22:28.764 - warn: admin.0 (25039) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-03-08 07:22:29.363 - error: host.raspi4iobrokerpv instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-03-08 07:22:29.364 - info: host.raspi4iobrokerpv Restart adapter system.adapter.admin.0 because enabled
                                          2021-03-08 07:22:31.065 - info: host.raspi4iobrokerpv instance system.adapter.kecontact.0 started with pid 25050
                                          2021-03-08 07:22:32.217 - error: kecontact.0 (25050) kecontact.0 already running
                                          2021-03-08 07:22:32.219 - warn: kecontact.0 (25050) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-03-08 07:22:32.791 - error: host.raspi4iobrokerpv instance system.adapter.kecontact.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-03-08 07:22:32.792 - info: host.raspi4iobrokerpv Restart adapter system.adapter.kecontact.0 because enabled
                                          2021-03-08 07:22:35.141 - info: host.raspi4iobrokerpv instance system.adapter.mqtt.0 started with pid 25061
                                          2021-03-08 07:22:36.185 - error: mqtt.0 (25061) mqtt.0 already running
                                          2021-03-08 07:22:36.188 - warn: mqtt.0 (25061) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-03-08 07:22:36.823 - error: host.raspi4iobrokerpv instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-03-08 07:22:36.824 - info: host.raspi4iobrokerpv Restart adapter system.adapter.mqtt.0 because enabled
                                          2021-03-08 07:22:39.144 - info: host.raspi4iobrokerpv instance system.adapter.web.0 started with pid 25072
                                          2021-03-08 07:22:40.330 - error: web.0 (25072) web.0 already running
                                          2021-03-08 07:22:40.942 - error: host.raspi4iobrokerpv instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-03-08 07:22:40.943 - info: host.raspi4iobrokerpv Restart adapter system.adapter.web.0 because enabled
                                          2021-03-08 07:22:43.093 - info: host.raspi4iobrokerpv instance system.adapter.javascript.0 started with pid 25083
                                          2021-03-08 07:22:45.301 - error: javascript.0 (25083) javascript.0 already running
                                          2021-03-08 07:22:45.304 - warn: javascript.0 (25083) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-03-08 07:22:45.950 - error: host.raspi4iobrokerpv instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-03-08 07:22:45.952 - info: host.raspi4iobrokerpv Restart adapter system.adapter.javascript.0 because enabled
                                          2021-03-08 07:22:47.141 - info: host.raspi4iobrokerpv instance system.adapter.history.0 started with pid 25094
                                          2021-03-08 07:22:48.171 - error: history.0 (25094) history.0 already running
                                          2021-03-08 07:22:48.174 - warn: history.0 (25094) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-03-08 07:22:48.809 - error: host.raspi4iobrokerpv instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-03-08 07:22:48.809 - info: host.raspi4iobrokerpv Restart adapter system.adapter.history.0 because enabled
                                          2021-03-08 07:22:51.126 - info: host.raspi4iobrokerpv instance system.adapter.cloud.0 started with pid 25106
                                          2021-03-08 07:22:52.449 - error: cloud.0 (25106) cloud.0 already running
                                          2021-03-08 07:22:52.451 - warn: cloud.0 (25106) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-03-08 07:22:53.030 - error: host.raspi4iobrokerpv instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-03-08 07:22:53.031 - info: host.raspi4iobrokerpv Restart adapter system.adapter.cloud.0 because enabled
                                          2021-03-08 07:22:55.124 - info: host.raspi4iobrokerpv instance system.adapter.iot.0 started with pid 25117
                                          2021-03-08 07:22:56.669 - error: iot.0 (25117) iot.0 already running
                                          2021-03-08 07:22:56.671 - warn: iot.0 (25117) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-03-08 07:22:57.255 - error: host.raspi4iobrokerpv instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-03-08 07:22:57.255 - info: host.raspi4iobrokerpv Restart adapter system.adapter.iot.0 because enabled
                                          2021-03-08 07:22:59.120 - info: host.raspi4iobrokerpv instance system.adapter.telegram.0 started with pid 25128
                                          2021-03-08 07:22:59.385 - info: host.raspi4iobrokerpv instance system.adapter.admin.0 started with pid 25135
                                          2021-03-08 07:23:01.099 - error: telegram.0 (25128) telegram.0 already running
                                          2021-03-08 07:23:01.102 - warn: telegram.0 (25128) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-03-08 07:23:01.400 - info: admin.0 (25135) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.21.0, js-controller: 3.2.16
                                          2021-03-08 07:23:01.451 - info: admin.0 (25135) requesting all states
                                          2021-03-08 07:23:01.451 - info: admin.0 (25135) requesting all objects
                                          2021-03-08 07:23:02.169 - error: host.raspi4iobrokerpv instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-03-08 07:23:02.170 - info: host.raspi4iobrokerpv Restart adapter system.adapter.telegram.0 because enabled
                                          2021-03-08 07:23:02.511 - info: admin.0 (25135) received all objects
                                          2021-03-08 07:23:02.656 - info: admin.0 (25135) http server listening on port 8081
                                          2021-03-08 07:23:02.815 - info: host.raspi4iobrokerpv instance system.adapter.kecontact.0 started with pid 25154
                                          2021-03-08 07:23:02.656 - info: admin.0 (25135) Use link "http://localhost:8081" to configure.
                                          2021-03-08 07:23:03.065 - info: host.raspi4iobrokerpv instance system.adapter.backitup.0 started with pid 25161
                                          2021-03-08 07:23:04.411 - info: kecontact.0 (25154) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.kecontact, node: v12.21.0, js-controller: 3.2.16
                                          2021-03-08 07:23:06.816 - error: backitup.0 (25161) backitup.0 already running
                                          2021-03-08 07:23:06.819 - warn: backitup.0 (25161) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-03-08 07:23:06.845 - info: host.raspi4iobrokerpv instance system.adapter.mqtt.0 started with pid 25180
                                          2021-03-08 07:23:07.411 - error: host.raspi4iobrokerpv instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-03-08 07:23:07.412 - info: host.raspi4iobrokerpv Restart adapter system.adapter.backitup.0 because enabled
                                          2021-03-08 07:23:08.428 - info: mqtt.0 (25180) starting. Version 2.3.4 in /opt/iobroker/node_modules/iobroker.mqtt, node: v12.21.0, js-controller: 3.2.16
                                          2021-03-08 07:23:08.454 - info: vis.0 (25187) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.vis, node: v12.21.0, js-controller: 3.2.16
                                          2021-03-08 07:23:08.650 - info: mqtt.0 (25180) Starting MQTT server on 0.0.0.0:1883
                                          2021-03-08 07:23:08.888 - info: vis.0 (25187) vis license is OK.
                                          2021-03-08 07:23:09.379 - info: mqtt.0 (25180) Client [AMIS] connected with secret 1615184589372_2795
                                          2021-03-08 07:23:09.482 - info: kecontact.0 (25154) starting charging station in passive mode
                                          2021-03-08 07:23:09.818 - info: vis.0 (25187) Terminated (NO_ERROR): Without reason
                                          2021-03-08 07:23:10.398 - info: host.raspi4iobrokerpv instance system.adapter.vis.0 terminated while should be started once
                                          2021-03-08 07:23:10.963 - info: host.raspi4iobrokerpv instance system.adapter.web.0 started with pid 25210
                                          2021-03-08 07:23:11.100 - info: host.raspi4iobrokerpv instance system.adapter.shelly.0 started with pid 25217
                                          2021-03-08 07:23:13.016 - error: shelly.0 (25217) shelly.0 already running
                                          2021-03-08 07:23:13.019 - warn: shelly.0 (25217) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-03-08 07:23:13.602 - error: host.raspi4iobrokerpv instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-03-08 07:23:13.603 - info: host.raspi4iobrokerpv Restart adapter system.adapter.shelly.0 because enabled
                                          2021-03-08 07:23:15.170 - info: host.raspi4iobrokerpv instance system.adapter.vis-inventwo.0 started with pid 25236
                                          2021-03-08 07:23:15.971 - info: host.raspi4iobrokerpv instance system.adapter.javascript.0 started with pid 25247
                                          2021-03-08 07:23:16.233 - error: vis-inventwo.0 (25236) vis-inventwo.0 already running
                                          2021-03-08 07:23:16.235 - warn: vis-inventwo.0 (25236) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-03-08 07:23:16.840 - error: host.raspi4iobrokerpv instance system.adapter.vis-inventwo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-03-08 07:23:16.841 - info: host.raspi4iobrokerpv Restart adapter system.adapter.vis-inventwo.0 because enabled
                                          2021-03-08 07:23:18.750 - info: javascript.0 (25247) starting. Version 4.8.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.21.0, js-controller: 3.2.16
                                          2021-03-08 07:23:18.831 - info: host.raspi4iobrokerpv instance system.adapter.history.0 started with pid 25262
                                          2021-03-08 07:23:18.909 - info: javascript.0 (25247) requesting all states
                                          2021-03-08 07:23:18.911 - info: javascript.0 (25247) requesting all objects
                                          2021-03-08 07:23:19.670 - info: host.raspi4iobrokerpv instance system.adapter.modbus.0 started with pid 25269
                                          2021-03-08 07:23:19.918 - info: javascript.0 (25247) received all states
                                          2021-03-08 07:23:19.943 - info: javascript.0 (25247) received all objects
                                          2021-03-08 07:23:20.184 - info: javascript.0 (25247) Start javascript script.js.common.AMIS
                                          2021-03-08 07:23:20.248 - info: javascript.0 (25247) script.js.common.AMIS: registered 1 subscription and 0 schedules
                                          2021-03-08 07:23:20.249 - info: javascript.0 (25247) Start javascript script.js.common.SE_Power
                                          2021-03-08 07:23:20.256 - info: javascript.0 (25247) script.js.common.SE_Power: registered 0 subscriptions and 0 schedules
                                          2021-03-08 07:23:20.257 - info: javascript.0 (25247) Start javascript script.js.common.Sonnenstand
                                          2021-03-08 07:23:20.266 - info: javascript.0 (25247) script.js.common.Sonnenstand: long: - lat:
                                          2021-03-08 07:23:20.283 - info: javascript.0 (25247) script.js.common.Sonnenstand: Script Sonnenstand; Erfolgreich gelaufen, Werte akzeptiert
                                          2021-03-08 07:23:20.286 - info: javascript.0 (25247) script.js.common.Sonnenstand: registered 0 subscriptions and 1 schedule
                                          2021-03-08 07:23:20.287 - info: javascript.0 (25247) Start javascript script.js.common.Powerbank
                                          2021-03-08 07:23:20.298 - info: javascript.0 (25247) script.js.common.Powerbank: registered 2 subscriptions and 1 schedule
                                          2021-03-08 07:23:20.299 - info: javascript.0 (25247) Start javascript script.js.common.Grid-PV
                                          2021-03-08 07:23:20.304 - info: javascript.0 (25247) script.js.common.Grid-PV: registered 1 subscription and 0 schedules
                                          2021-03-08 07:23:20.305 - info: javascript.0 (25247) Start javascript script.js.common.SMA+SE
                                          2021-03-08 07:23:20.311 - info: javascript.0 (25247) script.js.common.SMA+SE: registered 1 subscription and 0 schedules
                                          2021-03-08 07:23:20.312 - info: javascript.0 (25247) Start javascript script.js.common.Zoe_Zielladung
                                          2021-03-08 07:23:20.317 - info: javascript.0 (25247) script.js.common.Zoe_Zielladung: registered 1 subscription and 0 schedules
                                          2021-03-08 07:23:20.318 - info: javascript.0 (25247) Start javascript script.js.common.PVÜberschuss
                                          2021-03-08 07:23:20.323 - info: javascript.0 (25247) script.js.common.PVÜberschuss: registered 1 subscription and 0 schedules
                                          2021-03-08 07:23:20.324 - info: javascript.0 (25247) Start javascript script.js.common.ZOE_Ladung
                                          2021-03-08 07:23:20.345 - info: javascript.0 (25247) script.js.common.ZOE_Ladung: registered 5 subscriptions and 0 schedules
                                          2021-03-08 07:23:20.346 - info: javascript.0 (25247) Start javascript script.js.common.Garage
                                          2021-03-08 07:23:20.357 - info: javascript.0 (25247) script.js.common.Garage: registered 3 subscriptions and 1 schedule
                                          2021-03-08 07:23:20.909 - info: history.0 (25262) starting. Version 1.9.12 in /opt/iobroker/node_modules/iobroker.history, node: v12.21.0, js-controller: 3.2.16
                                          2021-03-08 07:23:21.017 - info: history.0 (25262) enabled logging of kecontact.0.pf (Count=1), Alias=false
                                          2021-03-08 07:23:21.018 - info: history.0 (25262) enabled logging of kecontact.0.p (Count=2), Alias=false
                                          2021-03-08 07:23:21.019 - info: history.0 (25262) enabled logging of kecontact.0.currentUser (Count=3), Alias=false
                                          2021-03-08 07:23:21.019 - info: history.0 (25262) enabled logging of mqtt.0.info.connection (Count=4), Alias=false
                                          2021-03-08 07:23:21.020 - info: history.0 (25262) enabled logging of 0_userdata.0.AMIS.170 (Count=5), Alias=false
                                          2021-03-08 07:23:21.021 - info: history.0 (25262) enabled logging of 0_userdata.0.AMIS.270 (Count=6), Alias=false
                                          2021-03-08 07:23:21.021 - info: history.0 (25262) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Switch (Count=7), Alias=false
                                          2021-03-08 07:23:21.022 - info: history.0 (25262) enabled logging of shelly.0.SHPLG-S#EED8F9#1.Relay0.Power (Count=8), Alias=false
                                          2021-03-08 07:23:21.023 - info: history.0 (25262) enabled logging of 0_userdata.0.AMIS.Power (Count=9), Alias=false
                                          2021-03-08 07:23:21.023 - info: history.0 (25262) enabled logging of kecontact.0.currentTimer (Count=10), Alias=false
                                          2021-03-08 07:23:21.024 - info: history.0 (25262) enabled logging of modbus.0.inputRegisters.30775_PVLeistung (Count=11), Alias=false
                                          2021-03-08 07:23:21.025 - info: history.0 (25262) enabled logging of javascript.0.Solar.Wechselrichter.PVLeistungAktuell (Count=12), Alias=false
                                          2021-03-08 07:23:21.026 - info: history.0 (25262) enabled logging of 0_userdata.0.AMIS.PVPower (Count=13), Alias=false
                                          2021-03-08 07:23:21.026 - info: history.0 (25262) enabled logging of 0_userdata.0.AMIS.PVÜberschuss (Count=14), Alias=false
                                          2021-03-08 07:23:21.045 - error: modbus.0 (25269) modbus.0 already running
                                          2021-03-08 07:23:21.049 - warn: modbus.0 (25269) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-03-08 07:23:21.631 - error: host.raspi4iobrokerpv instance system.adapter.modbus.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-03-08 07:23:21.631 - info: host.raspi4iobrokerpv Restart adapter system.adapter.modbus.0 because enabled
                                          2021-03-08 07:23:23.153 - info: host.raspi4iobrokerpv instance system.adapter.cloud.0 started with pid 25288
                                          2021-03-08 07:23:23.192 - info: host.raspi4iobrokerpv instance system.adapter.modbus.1 started with pid 25294
                                          2021-03-08 07:23:24.387 - error: modbus.1 (25294) modbus.1 already running
                                          2021-03-08 07:23:24.390 - warn: modbus.1 (25294) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-03-08 07:23:24.978 - error: host.raspi4iobrokerpv instance system.adapter.modbus.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-03-08 07:23:24.979 - info: host.raspi4iobrokerpv Restart adapter system.adapter.modbus.1 because enabled
                                          2021-03-08 07:23:25.214 - info: cloud.0 (25288) starting. Version 4.0.4 in /opt/iobroker/node_modules/iobroker.cloud, node: v12.21.0, js-controller: 3.2.16
                                          2021-03-08 07:23:25.281 - info: cloud.0 (25288) Connecting with https://iobroker.net:10555 with "richard.nussdorfer@gmail.com_65a2cba0-c435-11ea-b03c-2dda666d26a"
                                          2021-03-08 07:23:25.476 - info: cloud.0 (25288) Trying to connect as system.user.admin
                                          2021-03-08 07:23:25.837 - info: cloud.0 (25288) Adapter redirected temporally to "https://iobroker.net:10556" in one minute. Reason: command from server
                                          2021-03-08 07:23:25.839 - info: cloud.0 (25288) Connection changed: io client disconnect
                                          2021-03-08 07:23:27.035 - info: host.raspi4iobrokerpv instance scheduled system.adapter.zoe2.0 */10 * * * *
                                          2021-03-08 07:23:27.290 - info: host.raspi4iobrokerpv instance system.adapter.iot.0 started with pid 25314
                                          2021-03-08 07:23:29.392 - info: iot.0 (25314) starting. Version 1.8.13 in /opt/iobroker/node_modules/iobroker.iot, node: v12.21.0, js-controller: 3.2.16
                                          2021-03-08 07:23:29.452 - info: iot.0 (25314) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                                          2021-03-08 07:23:30.101 - info: iot.0 (25314) Connection changed: connect
                                          2021-03-08 07:23:31.111 - info: host.raspi4iobrokerpv instance system.adapter.info.0 started with pid 25336
                                          2021-03-08 07:23:32.197 - info: host.raspi4iobrokerpv instance system.adapter.telegram.0 started with pid 25351
                                          2021-03-08 07:23:33.268 - error: info.0 (25336) info.0 already running
                                          2021-03-08 07:23:33.272 - warn: info.0 (25336) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-03-08 07:23:33.855 - error: host.raspi4iobrokerpv instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-03-08 07:23:33.855 - info: host.raspi4iobrokerpv Restart adapter system.adapter.info.0 because enabled
                                          2021-03-08 07:23:34.340 - info: telegram.0 (25351) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.21.0, js-controller: 3.2.16
                                          2021-03-08 07:23:35.086 - info: host.raspi4iobrokerpv instance system.adapter.life360.0 started with pid 25370
                                          2021-03-08 07:23:36.629 - error: life360.0 (25370) life360.0 already running
                                          2021-03-08 07:23:36.631 - warn: life360.0 (25370) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                          2021-03-08 07:23:37.239 - error: host.raspi4iobrokerpv instance system.adapter.life360.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                          2021-03-08 07:23:37.239 - info: host.raspi4iobrokerpv Restart adapter system.adapter.life360.0 because enabled
                                          2021-03-08 07:23:37.434 - info: host.raspi4iobrokerpv instance system.adapter.backitup.0 started with pid 25381
                                          2021-03-08 07:23:40.972 - info: backitup.0 (25381) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.21.0, js-controller: 3.2.16
                                          2021-03-08 07:23:41.066 - info: backitup.0 (25381) [iobroker] backup was activated at 06:15 every 1 day(s)
                                          2021-03-08 07:23:43.636 - info: host.raspi4iobrokerpv instance system.adapter.shelly.0 started with pid 25403
                                          2021-03-08 07:23:46.147 - info: shelly.0 (25403) starting. Version 4.0.6 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.21.0, js-controller: 3.2.16
                                          2021-03-08 07:23:46.179 - info: shelly.0 (25403) Starting Adapter shelly.0 in version 4.0.6
                                          2021-03-08 07:23:46.180 - info: shelly.0 (25403) Polltime of the shelly devices: 5 sec.
                                          2021-03-08 07:23:46.215 - info: shelly.0 (25403) Starting Shelly adapter in CoAP modus.
                                          2021-03-08 07:23:46.318 - info: shelly.0 (25403) Listening for Shelly packets in the network
                                          2021-03-08 07:23:46.863 - info: host.raspi4iobrokerpv instance system.adapter.vis-inventwo.0 started with pid 25418
                                          2021-03-08 07:23:48.208 - info: vis-inventwo.0 (25418) starting. Version 2.7.10 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v12.21.0, js-controller: 3.2.16
                                          2021-03-08 07:23:51.669 - info: host.raspi4iobrokerpv instance system.adapter.modbus.0 started with pid 25436
                                          2021-03-08 07:23:53.223 - info: modbus.0 (25436) starting. Version 3.2.4 in /opt/iobroker/node_modules/iobroker.modbus, node: v12.21.0, js-controller: 3.2.16
                                          2021-03-08 07:23:53.750 - info: modbus.0 (25436) Connected to slave 192.168.0.9
                                          2021-03-08 07:23:55.000 - info: host.raspi4iobrokerpv instance system.adapter.modbus.1 started with pid 25455
                                          2021-03-08 07:23:56.569 - info: modbus.1 (25455) starting. Version 3.2.4 in /opt/iobroker/node_modules/iobroker.modbus, node: v12.21.0, js-controller: 3.2.16
                                          2021-03-08 07:23:57.222 - info: modbus.1 (25455) Connected to slave 192.168.0.98
                                          2021-03-08 07:23:59.816 - info: shelly.0 (25403) Shelly device 192.168.0.80 (shellyplug-s / shellyplug-s-EED8F9 / SHPLG-S#EED8F9#1) with CoAP connected!
                                          das Script Amis das zu Anfang steht:
                                          const idJson = 'mqtt.0.AMIS';
                                          const id180 = '0_userdata.0.AMIS.180';
                                          const id280 = '0_userdata.0.AMIS.280';
                                          const id381 = '0_userdata.0.AMIS.381';
                                          const id481 = '0_userdata.0.AMIS.481';
                                          const id170 = '0_userdata.0.AMIS.170';
                                          const id270 = '0_userdata.0.AMIS.270';
                                          const id370 = '0_userdata.0.AMIS.370';
                                          const id470 = '0_userdata.0.AMIS.470';
                                          const id11280 = '0_userdata.0.AMIS.11280';
                                          on(idJson, function(dp) {
                                             let obj = JSON.parse(dp.state.val);
                                             setState(id180, obj['1.8.0']/1000, true);
                                             setState(id280, obj['2.8.0']/1000, true);
                                             setState(id381, obj['3.8.1']/1000, true);
                                             setState(id481, obj['4.8.1']/1000, true);
                                             setState(id170, obj['1.7.0'], true);
                                             setState(id270, obj['2.7.0'], true);
                                             setState(id370, obj['3.7.0'], true);
                                             setState(id470, obj['4.7.0'], true);
                                             setState(id11280, obj['1.128.0'], true);
                                          vor 7:21 hat der Adapter Zoe2 seine Abfragen gemacht, wie immer.
                                          2021-03-08 07:20:03.853 - info: zoe2.0 (23557) getBatteryStatus-url:https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/45bacb45-017d-42f7-8bee-96edb6ceec2d/kamereon/kca/car-adapter/v2/cars/VF1AGxxxxxx/battery-status?country=DE
                                          2021-03-08 07:20:04.924 - info: zoe2.0 (23557) getBatteryStatus:{"data":{"type":"Car","id":"VF1AG00xxxxxxxx","attributes":{"timestamp":"2021-03-08T06:19:36Z","batteryLevel":100,"batteryTemperature":20,"batteryAutonomy":311,"batteryCapacity":0,"batteryAvailableEnergy":52,"plugStatus":0,"chargingStatus":0,"chargingRemainingTime":15,"chargingInstantaneousPower":0}}}
                                          2021-03-08 07:20:04.934 - info: zoe2.0 (23557) getCockpit-url:https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/45bacb45-017d-42f7-8bee-96edb6ceec2d/kamereon/kca/car-adapter/v2/cars/VF1AGxxxxx/cockpit?country=DE
                                          2021-03-08 07:20:05.996 - info: zoe2.0 (23557) getCockpit:{"data":{"type":"Car","id":"VF1AG0009xxxxxx","attributes":{"fuelAutonomy":0,"fuelQuantity":0,"totalMileage":xxxx}}}
                                          2021-03-08 07:20:05.997 - info: zoe2.0 (23557) getLocation-url:https://api-wired-prod-1-euw1.wrd-aws.com/commerce/v1/accounts/45bacb45-017d-42f7-8bee-96edb6ceec2d/kamereon/kca/car-adapter/v1/cars/VF1AGxxxxxxxx/location?country=DE
                                          2021-03-08 07:20:07.017 - info: zoe2.0 (23557) getLocation:{"data":{"type":"Car","id":"VF1AG000xxxxxx","attributes":{"gpsLatitude":48.xxx,"gpsLongitude":14.xxx,"lastUpdateTime":"2021-03-04T12:47:53Z"}}}
                                          2021-03-08 07:20:07.018 - info: zoe2.0 (23557) gpsLatitude:48.xxxx
                                          2021-03-08 07:20:07.019 - info: zoe2.0 (23557) gpsLongitude:14.xxxx
                                          2021-03-08 07:20:07.020 - info: zoe2.0 (23557) getHVACStatus not enabled in config
                                          2021-03-08 07:20:17.027 - info: zoe2.0 (23557) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          2021-03-08 07:20:17.588 - info: host.raspi4iobrokerpv instance system.adapter.zoe2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          danach war 1:30min nichts und dann siehe oben.
                                          dh. ich kann aus dem Log nichts erkennen, was in den 1:30 Min passiert ist und warum er angefangen hat einen Restart zu starten, begonnen mit dem Stop der Scripten.
                                          Kann es sein.... dass durch die unsaubere Terminiation des Zoe2 Adapter, der Speicher den für seine Abarbeitung belegt, nicht wieder frei gibt.
                                          Gibt es eine Möglichkei am Raspi ein Speicheraufzeichnungstool laufen zu lassen, dass die Verbraucher erkennt?
                                          um 6:00 sehe ich noch warnings.
                                          2021-03-08 06:01:46.210 - warn: javascript.0 (647) You are assigning a object to the state "javascript.0.Sonne.Sonnenaufgang" which expects a string. Please fix your code to use a string or change the state type to object. This warning might become an error in future versions.
                                          2021-03-08 06:01:46.215 - warn: javascript.0 (647) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1358:20)
                                          2021-03-08 06:01:46.215 - warn: javascript.0 (647) at Object. (script.js.common.Powerbank:42:3)
                                          2021-03-08 06:01:46.215 - warn: javascript.0 (647) at Object. (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1249:34)
                                          2021-03-08 06:01:46.216 - warn: javascript.0 (647) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                                          2021-03-08 06:01:46.216 - warn: javascript.0 (647) at listOnTimeout (internal/timers.js:554:17)
                                          2021-03-08 06:01:46.216 - warn: javascript.0 (647) at processTimers (internal/timers.js:497:7)
                                          2021-03-08 06:01:46.216 - info: javascript.0 (647) script.js.common.Powerbank: Mon Mar 08 2021 06:32:49 GMT+0100 (GMT+01:00)
                                          2021-03-08 06:01:46.216 - warn: javascript.0 (647) You are assigning a object to the state "javascript.0.Sonne.Sonnenuntergang" which expects a string. Please fix your code to use a string or change the state type to object. This warning might become an error in future versions.
                                          2021-03-08 06:01:46.217 - warn: javascript.0 (647) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1358:20)
                                          2021-03-08 06:01:46.218 - warn: javascript.0 (647) at Object. (script.js.common.Powerbank:44:3)
                                          2021-03-08 06:01:46.218 - warn: javascript.0 (647) at Object. (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1249:34)
                                          2021-03-08 06:01:46.218 - warn: javascript.0 (647) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2014:34)
                                          2021-03-08 06:01:46.218 - warn: javascript.0 (647) at listOnTimeout (internal/timers.js:554:17)
                                          2021-03-08 06:01:46.218 - warn: javascript.0 (647) at processTimers (internal/timers.js:497:7)
                                          2021-03-08 06:01:46.218 - info: javascript.0 (647) script.js.common.Powerbank: Mon Mar 08 2021 17:59:25 GMT+0100 (GMT+01:00)
                                          2021-03-08 06:10:00.006 - info: javascript.0 (647) script.js.common.Sonnenstand: Script Sonnenstand; Erfolgreich gelaufen, Werte akzeptiert
                                          2021-03-08 06:10:00.110 - info: host.raspi4iobrokerpv instance system.adapter.zoe2.0 started with pid 22827
                                          wenn ich richtig liege, passt ihm das da nicht:
                                          vor ca. 1 Std. die Script Engine upgedatet
                                          gerade wieder einen Hänger gehabt:
                                          cloud.0	2021-03-08 14:05:32.090	info	(25288) Connection changed: connect
                                          cloud.0	2021-03-08 14:05:31.693	info	(25288) Trying to connect as system.user.admin
                                          modbus.0	2021-03-08 14:05:12.551	info	(25436) Connected to slave 192.168.0.9
                                          modbus.1	2021-03-08 14:04:43.347	info	(25455) Connected to slave 192.168.0.98
                                          javascript.0	2021-03-08 14:04:43.158	info	(7815) script.js.common.Powerbank: Powerbank Ladung begonnen
                                          mqtt.0	2021-03-08 14:04:40.073	info	(6707) Client [AMIS] connected with secret 1615208680072_5666
                                          cloud.0	2021-03-08 14:04:31.676	info	(25288) Connection lost
                                          cloud.0	2021-03-08 14:04:31.676	info	(25288) Connection changed: Ping timeout
                                          cloud.0	2021-03-08 14:04:31.674	error	(25288) Ping timeout
                                          shelly.0	2021-03-08 14:04:27.283	error	(25403) Error in function state.coap.http_cmd for state SHPLG-S#EED8F9#1.Relay0.Switch and request{"url":"http://192.168.0.80/relay/0","timeout":5000,"qs":{"turn":"off","timer":0}} for 192.168.0.80 (
                                          mqtt.0	2021-03-08 14:04:25.027	info	(6707) Client [H,] connection closed: timeout
                                          shelly.0	2021-03-08 14:04:17.108	error	(25403) Error in function state.coap.http_cmd for state SHPLG-S#EED8F9#1.Relay0.Switch and request{"url":"http://192.168.0.80/relay/0","timeout":5000,"qs":{"turn":"off","timer":0}} for 192.168.0.80 (
                                          kecontact.0	2021-03-08 14:04:15.441	warn	(25154) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                                          kecontact.0	2021-03-08 14:04:15.140	warn	(25154) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                                          kecontact.0	2021-03-08 14:04:14.840	warn	(25154) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                                          life360.0	2021-03-08 14:04:14.804	warn	(25612) No data received from Life360 cloud services!
                                          life360.0	2021-03-08 14:04:14.791	error	(25612) Failed to retrieve members: Error: getaddrinfo EAI_AGAIN www.life360.com
                                          kecontact.0	2021-03-08 14:04:14.539	warn	(25154) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                                          kecontact.0	2021-03-08 14:04:14.239	warn	(25154) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                                          kecontact.0	2021-03-08 14:04:13.939	warn	(25154) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                                          kecontact.0	2021-03-08 14:04:13.639	warn	(25154) UDP send error for 192.168.0.97:7090: Error: send ENETUNREACH 192.168.0.97:7090
                                          modbus.1	2021-03-08 14:04:13.141	info	(25455) Disconnected from slave 192.168.0.98
                                          modbus.0	2021-03-08 14:04:12.530	info	(25436) Disconnected from slave 192.168.0.9
                                          modbus.1	2021-03-08 14:04:12.140	warn	(25455) Poll error count: 1 code: {"err":"timeout","timeout":5000}
                                          modbus.1	2021-03-08 14:04:12.139	error	(25455) Client in error state.
                                          modbus.1	2021-03-08 14:04:12.137	error	(25455) Request timed out.
                                          modbus.1	2021-03-08 14:04:12.136	warn	(25455) Error: undefined
                                          modbus.0	2021-03-08 14:04:11.531	warn	(25436) Poll error count: 1 code: {"err":"timeout","timeout":5000}
                                          modbus.0	2021-03-08 14:04:11.529	error	(25436) Client in error state.
                                          modbus.0	2021-03-08 14:04:11.527	error	(25436) Request timed out.
                                          modbus.0	2021-03-08 14:04:11.525	warn	(25436) Error: undefined
                                          und aktuell wieder nicht erreichbar......???
                                          auch der Raspi ist nicht erreichbar
                                          jetzt wieder gekommen...
                                          [351956.430278] CIFS: Attempting to mount //192.168.0.10/backup/iobroker
                                          [370209.514102] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
                                          [370209.514156] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                                          javascript.0	2021-03-08 14:14:52.987	info	(7815) script.js.common.Powerbank: Powerbank Ladung beendet
                                          cloud.0	2021-03-08 14:14:21.086	info	(10508) Connection changed: io client disconnect
                                          cloud.0	2021-03-08 14:14:21.083	info	(10508) Adapter redirected temporally to "https://iobroker.net:10556" in one minute. Reason: command from server
                                          cloud.0	2021-03-08 14:14:20.664	info	(10508) Trying to connect as system.user.admin
                                          life360.0	2021-03-08 14:14:10.699	info	(25612) Connected to Life360 cloud services.
                                          modbus.0	2021-03-08 14:14:00.462	info	(25436) Connected to slave 192.168.0.9
                                          iot.0	2021-03-08 14:13:51.498	info	(25314) Connection changed: connect
                                          modbus.1	2021-03-08 14:13:50.130	info	(25455) Connected to slave 192.168.0.98
                                          mqtt.0	2021-03-08 14:13:49.818	info	(6707) Client [H,] connected with secret 1615209229816_7093
                                          life360.0	2021-03-08 14:13:49.804	warn	(25612) No data received from Life360 cloud services!
                                          life360.0	2021-03-08 14:13:49.803	error	(25612) Error: Error: Unable to connect: Error: getaddrinfo EAI_AGAIN www.life360.com
                                          life360.0	2021-03-08 14:13:49.801	info	(25612) Waiting for online operations to finish ...
                                          iot.0	2021-03-08 14:13:45.886	info	(25314) Connection changed: disconnect
                                          iot.0	2021-03-08 14:13:45.885	error	(25314) Error by device connection: "premature close"
                                          cloud.0	2021-03-08 14:13:30.666	error	(10508) Error while connecting to cloud: Error: websocket error
                                          life360.0	2021-03-08 14:13:29.811	warn	(25612) No data received from Life360 cloud services!
                                          life360.0	2021-03-08 14:13:29.810	error	(25612) Error: Error: Unable to connect: Error: getaddrinfo EAI_AGAIN www.life360.com
                                          life360.0	2021-03-08 14:13:29.808	info	(25612) Waiting for online operations to finish ...
                                          cloud.0	2021-03-08 14:13:20.671	info	(10508) Trying to connect as system.user.admin
                                          modbus.1	2021-03-08 14:13:19.127	warn	(25455) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
                                          modbus.1	2021-03-08 14:13:19.126	error	(25455) Client in error state.
                                          modbus.1	2021-03-08 14:13:19.125	error	(25455) Socket Error
                                          iot.0	2021-03-08 14:13:15.873	info	(25314) Connection changed: disconnect
                                          iot.0	2021-03-08 14:13:15.873	warn	(25314) Looks like your connection certificates are invalid. Please renew them via configuration dialog.
                                          iot.0	2021-03-08 14:13:15.872	error	(25314) Error by device connection: "premature close"
                                          iot.0	2021-03-08 14:13:15.853	info	(25314) Connection changed: disconnect
                                          iot.0	2021-03-08 14:13:15.852	error	(25314) Error by device connection: "premature close"
                                          iot.0	2021-03-08 14:13:05.841	info	(25314) Connection changed: disconnect
                                          iot.0	2021-03-08 14:13:05.841	error	(25314) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
                                          iot.0	2021-03-08 14:13:05.840	error	(25314) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
                                          iot.0	2021-03-08 14:13:05.839	error	(25314) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
                                          iot.0	2021-03-08 14:13:05.838	error	(25314) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
                                          life360.0	2021-03-08 14:12:59.810	warn	(25612) No data received from Life360 cloud services!
                                          life360.0	2021-03-08 14:12:59.809	error	(25612) Error: Error: Unable to connect: Error: getaddrinfo EAI_AGAIN www.life360.com
                                          life360.0	2021-03-08 14:12:59.807	info	(25612) Waiting for online operations to finish ...
                                          modbus.0	2021-03-08 14:12:59.447	warn	(25436) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.9","port":502}
                                          modbus.0	2021-03-08 14:12:59.446	error	(25436) Client in error state.
                                          modbus.0	2021-03-08 14:12:59.445	error	(25436) Socket Error
                                          modbus.1	2021-03-08 14:12:44.967	warn	(25455) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
                                          modbus.1	2021-03-08 14:12:44.966	error	(25455) Client in error state.
                                          modbus.1	2021-03-08 14:12:44.966	error	(25455) Socket Error
                                          iot.0	2021-03-08 14:12:40.813	info	(25314) Connection changed: disconnect
                                          iot.0	2021-03-08 14:12:40.812	error	(25314) Error by device connection: "premature close"
                                          cloud.0	2021-03-08 14:12:30.664	error	(10508) Error while connecting to cloud: Error: websocket error
                                          life360.0	2021-03-08 14:12:29.810	warn	(25612) No data received from Life360 cloud services!
                                          life360.0	2021-03-08 14:12:29.809	error	(25612) Error: Error: Unable to connect: Error: getaddrinfo EAI_AGAIN www.life360.com
                                          life360.0	2021-03-08 14:12:29.807	info	(25612) Waiting for online operations to finish ...
                                          cloud.0	2021-03-08 14:12:20.674	info	(10508) Trying to connect as system.user.admin
                                          modbus.1	2021-03-08 14:12:10.817	warn	(25455) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
                                          modbus.1	2021-03-08 14:12:10.816	error	(25455) Client in error state.
                                          modbus.1	2021-03-08 14:12:10.816	error	(25455) Socket Error
                                          iot.0	2021-03-08 14:12:10.800	info	(25314) Connection changed: disconnect
                                          iot.0	2021-03-08 14:12:10.800	warn	(25314) Looks like your connection certificates are invalid. Please renew them via configuration dialog.
                                          iot.0	2021-03-08 14:12:10.799	error	(25314) Error by device connection: "premature close"
                                          iot.0	2021-03-08 14:12:10.779	info	(25314) Connection changed: disconnect
                                          iot.0	2021-03-08 14:12:10.778	error	(25314) Error by device connection: "premature close"
                                          iot.0	2021-03-08 14:12:00.769	info	(25314) Connection changed: disconnect
                                          iot.0	2021-03-08 14:12:00.768	error	(25314) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
                                          iot.0	2021-03-08 14:12:00.768	error	(25314) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
                                          iot.0	2021-03-08 14:12:00.766	error	(25314) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
                                          iot.0	2021-03-08 14:12:00.765	error	(25314) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
                                          life360.0	2021-03-08 14:11:59.808	warn	(25612) No data received from Life360 cloud services!
                                          life360.0	2021-03-08 14:11:59.807	error	(25612) Error: Error: Unable to connect: Error: getaddrinfo EAI_AGAIN www.life360.com
                                          life360.0	2021-03-08 14:11:59.805	info	(25612) Waiting for online operations to finish ...
                                          modbus.0	2021-03-08 14:11:55.287	warn	(25436) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.9","port":502}
                                          modbus.0	2021-03-08 14:11:55.286	error	(25436) Client in error state.
                                          modbus.0	2021-03-08 14:11:55.286	error	(25436) Socket Error
                                          modbus.1	2021-03-08 14:11:36.647	warn	(25455) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
                                          modbus.1	2021-03-08 14:11:36.647	error	(25455) Client in error state.
                                          modbus.1	2021-03-08 14:11:36.646	error	(25455) Socket Error
                                          iot.0	2021-03-08 14:11:35.740	info	(25314) Connection changed: disconnect
                                          iot.0	2021-03-08 14:11:35.739	error	(25314) Error by device connection: "premature close"
                                          cloud.0	2021-03-08 14:11:30.664	error	(10508) Error while connecting to cloud: Error: websocket error
                                          life360.0	2021-03-08 14:11:29.803	warn	(25612) No data received from Life360 cloud services!
                                          life360.0	2021-03-08 14:11:29.802	error	(25612) Error: Error: Unable to connect: Error: getaddrinfo EAI_AGAIN www.life360.com
                                          life360.0	2021-03-08 14:11:29.798	info	(25612) Waiting for online operations to finish ...
                                          cloud.0	2021-03-08 14:11:20.675	info	(10508) Trying to connect as system.user.admin
                                          iot.0	2021-03-08 14:11:05.728	info	(25314) Connection changed: disconnect
                                          iot.0	2021-03-08 14:11:05.727	warn	(25314) Looks like your connection certificates are invalid. Please renew them via configuration dialog.
                                          iot.0	2021-03-08 14:11:05.726	error	(25314) Error by device connection: "premature close"
                                          iot.0	2021-03-08 14:11:05.713	info	(25314) Connection changed: disconnect
                                          iot.0	2021-03-08 14:11:05.712	error	(25314) Error by device connection: "premature close"
                                          modbus.1	2021-03-08 14:11:02.487	warn	(25455) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
                                          modbus.1	2021-03-08 14:11:02.486	error	(25455) Client in error state.
                                          modbus.1	2021-03-08 14:11:02.486	error	(25455) Socket Error
                                          life360.0	2021-03-08 14:10:59.808	warn	(25612) No data received from Life360 cloud services!
                                          life360.0	2021-03-08 14:10:59.807	error	(25612) Error: Error: Unable to connect: Error: getaddrinfo EAI_AGAIN www.life360.com
                                          life360.0	2021-03-08 14:10:59.804	info	(25612) Waiting for online operations to finish ...
                                          iot.0	2021-03-08 14:10:55.684	info	(25314) Connection changed: disconnect
                                          iot.0	2021-03-08 14:10:55.683	error	(25314) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
                                          iot.0	2021-03-08 14:10:55.679	error	(25314) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
                                          iot.0	2021-03-08 14:10:55.677	error	(25314) DNS name of a18wym7vjdl22g.iot.eu-west-1.amazonaws.com cannot be resolved: connection will be retried in 10 seconds.
                                          iot.0	2021-03-08 14:10:55.676	error	(25314) Error by device connection: "getaddrinfo EAI_AGAIN a18wym7vjdl22g.iot.eu-west-1.amazonaws.com"
                                          modbus.0	2021-03-08 14:10:51.127	warn	(25436) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.9","port":502}
                                          modbus.0	2021-03-08 14:10:51.126	error	(25436) Client in error state.
                                          modbus.0	2021-03-08 14:10:51.125	error	(25436) Socket Error
                                          cloud.0	2021-03-08 14:10:30.669	error	(10508) Error while connecting to cloud: Error: websocket error
                                          iot.0	2021-03-08 14:10:30.653	info	(25314) Connection lost
                                          iot.0	2021-03-08 14:10:30.652	info	(25314) Connection changed: disconnect
                                          iot.0	2021-03-08 14:10:30.649	error	(25314) Error by device connection: "premature close"
                                          life360.0	2021-03-08 14:10:29.818	warn	(25612) No data received from Life360 cloud services!
                                          life360.0	2021-03-08 14:10:29.817	error	(25612) Error: Error: Unable to connect: Error: getaddrinfo EAI_AGAIN www.life360.com
                                          life360.0	2021-03-08 14:10:29.814	info	(25612) Waiting for online operations to finish ...
                                          life360.0	2021-03-08 14:10:29.807	info	(25612) Disconnected from Life360 cloud services.
                                          modbus.1	2021-03-08 14:10:28.327	warn	(25455) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
                                          modbus.1	2021-03-08 14:10:28.327	error	(25455) Client in error state.
                                          modbus.1	2021-03-08 14:10:28.326	error	(25455) Socket Error
                                          host.raspi4iobrokerpv	2021-03-08 14:10:22.273	error	instance system.adapter.zoe2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                          zoe2.0	2021-03-08 14:10:21.693	warn	(10525) Terminated (JS_CONTROLLER_STOPPED): Without reason
                                          zoe2.0	2021-03-08 14:10:21.690	error	(10525) No valid response from Renault server
                                          cloud.0	2021-03-08 14:10:20.683	info	(10508) Trying to connect as system.user.admin
                                          zoe2.0	2021-03-08 14:10:01.603	info	(10525) URL: https://renault-wrd-prod-1-euw1-myrapp-one.s3-eu-west-1.amazonaws.com/configuration/android/config_de_DE.json
                                          zoe2.0	2021-03-08 14:10:01.603	info	(10525) ignoreApiError:true
                                          zoe2.0	2021-03-08 14:10:01.602	info	(10525) Country:DE
                                          zoe2.0	2021-03-08 14:10:01.602	info	(10525) VIN:VF1AG000966808321
                                          zoe2.0	2021-03-08 14:10:01.602	info	(10525) Locale:de_DE
                                          zoe2.0	2021-03-08 14:10:01.601	info	(10525) Username:richard.nussdorfer@gmail.com
                                          zoe2.0	2021-03-08 14:10:01.568	info	(10525) starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.zoe2, node: v12.21.0, js-controller: 3.2.16
                                          host.raspi4iobrokerpv	2021-03-08 14:10:00.079	info	instance system.adapter.zoe2.0 started with pid 10525
                                          life360.0	2021-03-08 14:09:59.806	warn	(25612) No data received from Life360 cloud services!
                                          life360.0	2021-03-08 14:09:59.804	error	(25612) Failed to retrieve members: Error: getaddrinfo EAI_AGAIN www.life360.com
                                          modbus.1	2021-03-08 14:09:54.167	warn	(25455) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
                                          modbus.1	2021-03-08 14:09:54.166	error	(25455) Client in error state.
                                          modbus.1	2021-03-08 14:09:54.165	error	(25455) Socket Error
                                          modbus.0	2021-03-08 14:09:46.969	warn	(25436) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.9","port":502}
                                          modbus.0	2021-03-08 14:09:46.968	error	(25436) Client in error state.
                                          modbus.0	2021-03-08 14:09:46.967	error	(25436) Socket Error
                                          cloud.0	2021-03-08 14:09:30.787	error	(10508) Error while connecting to cloud: Error: websocket error
                                          life360.0	2021-03-08 14:09:29.806	warn	(25612) No data received from Life360 cloud services!
                                          life360.0	2021-03-08 14:09:29.804	error	(25612) Failed to retrieve members: Error: getaddrinfo EAI_AGAIN www.life360.com
                                          cloud.0	2021-03-08 14:09:20.794	info	(10508) Trying to connect as system.user.admin
                                          cloud.0	2021-03-08 14:09:20.642	info	(10508) Connecting with https://iobroker.net:10555 with "richard.nussdorfer@gmail.com_65a2cba0-c435-11ea-b03c-2dda666d26a"
                                          cloud.0	2021-03-08 14:09:20.573	info	(10508) starting. Version 4.0.4 in /opt/iobroker/node_modules/iobroker.cloud, node: v12.21.0, js-controller: 3.2.16
                                          modbus.1	2021-03-08 14:09:20.007	warn	(25455) On error: {"errno":"EHOSTUNREACH","code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.98","port":502}
                                          modbus.1	2021-03-08 14:09:20.007	error	(25455) Client in error state.
                                          modbus.1	2021-03-08 14:09:20.006	error	(25455) Socket Error
                                          host.raspi4iobrokerpv	2021-03-08 14:09:18.837	info	instance system.adapter.cloud.0 started with pid 10508
                                          host.raspi4iobrokerpv	2021-03-08 14:09:17.766	info	Restart adapter system.adapter.cloud.0 because enabled
                                          host.raspi4iobrokerpv	2021-03-08 14:09:17.760	info	instance system.adapter.cloud.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                          cloud.0	2021-03-08 14:09:17.643	info	(25288) Connection changed: io client disconnect
                                          cloud.0	2021-03-08 14:09:17.105	warn	(25288) Terminated (-100): Without reason
                                          cloud.0	2021-03-08 14:09:07.100	info	(25288) Restart adapter by disconnect
                                          cloud.0	2021-03-08 14:09:07.099	info	(25288) Connection lost
                                          cloud.0	2021-03-08 14:09:07.098	info	(25288) Connection changed: Ping timeout
                                          cloud.0	2021-03-08 14:09:07.097	error	(25288) Ping timeout
                                          life360.0	2021-03-08 14:08:59.806	warn	(25612) No data received from Life360 cloud services!
                                          life360.0	2021-03-08 14:08:59.804	error	(25612) Failed to retrieve members: Error: getaddrinfo EAI_AGAIN www.life360.com
                                          mqtt.0	2021-03-08 14:08:59.598	info	(6707) Client [AMIS] connection closed: timeout
                                          shelly.0	2021-03-08 14:08:48.562	error	(25403) Error in function state.coap.http_cmd for state SHPLG-S#EED8F9#1.Relay0.Switch and request{"url":"http://192.168.0.80/relay/0","timeout":5000,"qs":{"turn":"off","timer":0}} for 192.168.0.80 (
                                          modbus.1	2021-03-08 14:08:46.846	info	(25455) Disconnected from slave 192.168.0.98
                                          modbus.1	2021-03-08 14:08:45.847	warn	(25455) Poll error count: 1 code: {"err":"timeout","timeout":5000}
                                          modbus.1	2021-03-08 14:08:45.846	error	(25455) Client in error state.
                                          modbus.1	2021-03-08 14:08:45.845	error	(25455) Request timed out.
                                          modbus.1	2021-03-08 14:08:45.844	warn	(25455) Error: undefined
                                          modbus.0	2021-03-08 14:08:43.870	info	(25436) Disconnected from slave 192.168.0.9
                                          modbus.0	2021-03-08 14:08:42.870	warn	(25436) Poll error count: 1 code: {"err":"timeout","timeout":5000}
                                          modbus.0	2021-03-08 14:08:42.869	error	(25436) Client in error state.
                                          modbus.0	2021-03-08 14:08:42.868	error	(25436) Request timed out.
                                          modbus.0	2021-03-08 14:08:42.867	warn	(25436) Error: undefined
                                          habe jetzt von Wlan auf Lan umgestellt, mal sehen.
                                          BG
