  4. Test Adapter MercedesMe v0.0.x
mercedes
1.0k Beiträge 122 Kommentatoren 363.2k Aufrufe 107 Beobachtet
  • schmerenkoS schmerenko
    @tombox OK, ich habe den selben Fehler wie Marten Frieske
    JayRJ Offline
    JayRJ Offline
    JayR
    #427
    Ich bekomme folgenden Log mit der aktuellen Version:
    mercedesme.0	2021-01-12 16:17:39.307	info	(10523) terminating with timeout
    mercedesme.0	2021-01-12 16:17:38.807	warn	(10523) Terminated (UNCAUGHT_EXCEPTION): Without reason
    mercedesme.0	2021-01-12 16:17:37.854	warn	(10523) Commands not found
    mercedesme.0	2021-01-12 16:17:37.852	error	(10523) 403
    mercedesme.0	2021-01-12 16:17:37.804	error	(10523) unhandled promise rejection: undefined
    mercedesme.0	2021-01-12 16:17:37.801	warn	(10523) Commands not found
    mercedesme.0	2021-01-12 16:17:37.799	error	(10523) 403
    mercedesme.0	2021-01-12 16:17:34.751	info	(10523) starting. Version 0.0.43 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v12.20.1, js-controller: 3.1.6
    mercedesme.0	2021-01-12 16:17:34.674	info	(10523) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    mercedesme.0	2021-01-12 16:16:59.368	info	(10458) terminating with timeout
    mercedesme.0	2021-01-12 16:16:58.419	info	(10458) Terminated (NO_ERROR): Without reason
    mercedesme.0	2021-01-12 16:16:58.417	info	(10458) terminating
    mercedesme.0	2021-01-12 16:16:57.663	warn	(10458) Commands not found
    mercedesme.0	2021-01-12 16:16:57.662	error	(10458) 403
    mercedesme.0	2021-01-12 16:16:57.620	error	(10458) unhandled promise rejection: undefined
    mercedesme.0	2021-01-12 16:16:57.617	warn	(10458) Commands not found
    mercedesme.0	2021-01-12 16:16:57.615	error	(10458) 403
    mercedesme.0	2021-01-12 16:16:55.589	info	(10458) starting
    • JayRJ JayR
      tombox
      #428
      @jayr said in Test Adapter MercedesMe v0.0.x:
      Commands not found
      Kannst den Adapter in Debug setzen und mir die komplette log file per privat nachricht senden bzw die aktuellste version via github installieren?
      O 1 Antwort Letzte Antwort
      • T tombox
        Commands not found
        O Offline
        O Offline
        OlafK
        #429
        @tombox
        ich hatte diesen tollen Adapter schon seit Oktober oder so im Betrieb - lief alles problemlos. Ein großes Danke dafür :-)
        Nun bin ich mit dem ioBroker auf eine Pi4 umgezogen und hatte ein Backup eingespielt. Was ich auch gemacht hatte - der Adapter blieb rot und eine Mail kam nicht an. Dann alle Objekte gelöscht, Adapter deinstalliert - und vorsichtshalber Rechte gefixt. ioBroker neu gestartet und Adapter + Instanz installiert. Wieder alles eingetragen - gleiches Ergebnis Adapter bleibt rot und es kommt keine Mail (auch nicht im Spam-Ordner).
        host.KOKSmartHome 2021-01-18 16:31:52.801 error instance system.adapter.mercedesme.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.KOKSmartHome 2021-01-18 16:31:52.800 error Caught by controller[0]: }
        host.KOKSmartHome 2021-01-18 16:31:52.800 error Caught by controller[0]: ]
        host.KOKSmartHome 2021-01-18 16:31:52.800 error Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.mercedesme/main.js'
        host.KOKSmartHome 2021-01-18 16:31:52.800 error Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.mercedesme/node_modules/jsdom/lib/api.js',
        host.KOKSmartHome 2021-01-18 16:31:52.799 error Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.mercedesme/node_modules/jsdom/lib/jsdom/browser/Window.js',
        host.KOKSmartHome 2021-01-18 16:31:52.799 error Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.mercedesme/node_modules/jsdom/lib/jsdom/utils.js',
        host.KOKSmartHome 2021-01-18 16:31:52.796 error Caught by controller[0]: '/opt/iobroker/node_modules/canvas/index.js',
        host.KOKSmartHome 2021-01-18 16:31:52.796 error Caught by controller[0]: '/opt/iobroker/node_modules/canvas/lib/canvas.js',
        host.KOKSmartHome 2021-01-18 16:31:52.795 error Caught by controller[0]: '/opt/iobroker/node_modules/canvas/lib/bindings.js',
        host.KOKSmartHome 2021-01-18 16:31:52.795 error Caught by controller[0]: requireStack: [
        host.KOKSmartHome 2021-01-18 16:31:52.795 error Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        host.KOKSmartHome 2021-01-18 16:31:52.795 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19) {
        host.KOKSmartHome 2021-01-18 16:31:52.795 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
        host.KOKSmartHome 2021-01-18 16:31:52.794 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
        host.KOKSmartHome 2021-01-18 16:31:52.794 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
        host.KOKSmartHome 2021-01-18 16:31:52.794 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
        host.KOKSmartHome 2021-01-18 16:31:52.794 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
        host.KOKSmartHome 2021-01-18 16:31:52.793 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
        host.KOKSmartHome 2021-01-18 16:31:52.793 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
        host.KOKSmartHome 2021-01-18 16:31:52.793 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
        host.KOKSmartHome 2021-01-18 16:31:52.793 error Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
        host.KOKSmartHome 2021-01-18 16:31:52.793 error Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.mercedesme/main.js
        host.KOKSmartHome 2021-01-18 16:31:52.792 error Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.mercedesme/node_modules/jsdom/lib/api.js
        host.KOKSmartHome 2021-01-18 16:31:52.792 error Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.mercedesme/node_modules/jsdom/lib/jsdom/browser/Window.js
        host.KOKSmartHome 2021-01-18 16:31:52.792 error Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.mercedesme/node_modules/jsdom/lib/jsdom/utils.js
        host.KOKSmartHome 2021-01-18 16:31:52.792 error Caught by controller[0]: - /opt/iobroker/node_modules/canvas/index.js
        host.KOKSmartHome 2021-01-18 16:31:52.792 error Caught by controller[0]: - /opt/iobroker/node_modules/canvas/lib/canvas.js
        host.KOKSmartHome 2021-01-18 16:31:52.791 error Caught by controller[0]: - /opt/iobroker/node_modules/canvas/lib/bindings.js
        host.KOKSmartHome 2021-01-18 16:31:52.791 error Caught by controller[0]: Require stack:
        host.KOKSmartHome 2021-01-18 16:31:52.791 error Caught by controller[0]: Error: Cannot find module '../build/Release/canvas.node'
        host.KOKSmartHome 2021-01-18 16:31:52.790 error Caught by controller[0]: ^
        host.KOKSmartHome 2021-01-18 16:31:52.790 error Caught by controller[0]: throw err;
        host.KOKSmartHome 2021-01-18 16:31:52.790 error Caught by controller[0]: internal/modules/cjs/loader.js:818
        host.KOKSmartHome 2021-01-18 16:31:51.387 info instance system.adapter.mercedesme.0 started with pid 32369
        Irgendeine Idee, was ich noch machen könnte ?
        • O OlafK
          @tombox
          tombox
          #430
          @olafk
          cd /opt/iobroker
          npm install canvas
          • T tombox
            @olafk
            cd /opt/iobroker
            npm install canvas
            O Offline
            O Offline
            OlafK
            #431
            @tombox
            super - hat nun auf Anhieb funktioniert :-)
              Tony H.
              #432
              Mahlzeit, nach einem Neustart des iobrokers bringt mir der Adapter den fehler, neu installieren brachte nix. Ein key bekomme ich per mail aber immer wider der fehler. Hat einer ne idee?
              2021-02-17 18:29:03.366 error (1664) TypeError: Cannot assign to read only property '4' of string '70176 Stuttgart' at objectKeys.forEach (C:\iobroker\node_modules\iobroker.mercedesme\main.js:991:34) at Array.forEach (<ano
              mercedesme.0 2021-02-17 18:29:03.366 error (1664) unhandled promise rejection: Cannot assign to read only property '4' of string '70176 Stuttgart'
              mercedesme.0 2021-02-17 18:29:03.366 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              mercedesme.0 2021-02-17 18:29:03.366 error (1664) TypeError: Cannot assign to read only property '3' of string '70176 Stuttgart' at objectKeys.forEach (C:\iobroker\node_modules\iobroker.mercedesme\main.js:991:34) at Array.forEach (<ano
              mercedesme.0 2021-02-17 18:29:03.366 error (1664) unhandled promise rejection: Cannot assign to read only property '3' of string '70176 Stuttgart'
              mercedesme.0 2021-02-17 18:29:03.366 error (1664) TypeError: Cannot assign to read only property '2' of string '70176 Stuttgart' at objectKeys.forEach (C:\iobroker\node_modules\iobroker.mercedesme\main.js:991:34) at Array.forEach (<ano
              mercedesme.0 2021-02-17 18:29:03.366 error (1664) unhandled promise rejection: Cannot assign to read only property '2' of string '70176 Stuttgart'
              mercedesme.0 2021-02-17 18:29:03.366 error (1664) TypeError: Cannot assign to read only property '1' of string '70176 Stuttgart' at objectKeys.forEach (C:\iobroker\node_modules\iobroker.mercedesme\main.js:991:34) at Array.forEach (<ano
              mercedesme.0 2021-02-17 18:29:03.366 error (1664) unhandled promise rejection: Cannot assign to read only property '1' of string '70176 Stuttgart'
              mercedesme.0 2021-02-17 18:29:03.366 error (1664) TypeError: Cannot assign to read only property '0' of string '70176 Stuttgart' at objectKeys.forEach (C:\iobroker\node_modules\iobroker.mercedesme\main.js:991:34) at Array.forEach (<ano
              mercedesme.0 2021-02-17 18:29:03.366 error (1664) unhandled promise rejection: Cannot assign to read only property '0' of string '70176 Stuttgart'
              mercedesme.0 2021-02-17 18:29:03.366 error (1664) TypeError: Cannot assign to read only property '11' of string 'Königstr. 42' at objectKeys.forEach (C:\iobroker\node_modules\iobroker.mercedesme\main.js:991:34) at Array.forEach (<anony
              mercedesme.0 2021-02-17 18:29:03.366 error (1664) unhandled promise rejection: Cannot assign to read only property '11' of string 'Königstr. 42'
              mercedesme.0 2021-02-17 18:29:03.366 error (1664) TypeError: Cannot assign to read only property '10' of string 'Königstr. 42' at objectKeys.forEach (C:\iobroker\node_modules\iobroker.mercedesme\main.js:991:34) at Array.forEach (<anony
              mercedesme.0 2021-02-17 18:29:03.350 error (1664) unhandled promise rejection: Cannot assign to read only property '10' of string 'Königstr. 42'
              mercedesme.0 2021-02-17 18:29:03.350 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              'address':{'city':'XXX','countryCode':'DE','street':'yyy','zipCode':'12345'},
              'addressLines':['Königstr. 42','70176 Stuttgart','Deutschland'],
              • T Tony H.
                tombox
                #433
                @tony-h kommt gleich ein update
                • T tombox
                  Tony H.
                  #434
                  @tombox
                  Top! Vielen Dank.
                  • T Tony H.
                    @tombox
                    Top! Vielen Dank.
                    tombox
                    #435
                    @tony-h Fix ist in github
                    • T tombox
                      amg_666A Offline
                      amg_666A Offline
                      amg_666
                      schrieb am zuletzt editiert von amg_666
                      #436
                      @tombox irgendwie hat github grade "gekleemt", habe jetzt die 0.0.45 installiert und der Adapter läuft wieder fehlerfrei, danke!
                      V 1 Antwort Letzte Antwort
                      • amg_666A amg_666
                        V Offline
                        V Offline
                        V_Stefan
                        #437
                        vielleicht kann mir jemand einen kleine Tipp geben, was ich falsch machen. Ich bekomme die Anmeldung nicht hin.
                        Ich habe das me Konto angelegt, authentifiziert und auch die App auf dem Handy installiert. Dort funktioniert auch alles super.
                        Den Adapter habe ich installiert und die Mailadresse eingetragen.
                        Wenn ich das jetzt richtig verstehe, muss ich den Adapter jetzt starten und erhalte, wie bei der App einen Code, den ich dann wieder im Adapter eintragen muss.
                        Was mache ich aber, wenn ich keine Mail bekommen? Mailadresse habe ich schon x Mal überprüft und im Spam ist auch nichts.
                        Stefan
                        • V V_Stefan
                          Stefan
                          tombox
                          #438
                          @v_stefan Wie lange hast du gewartet kann manchml ein wenig länger dauern
                          • T tombox
                            V Offline
                            V Offline
                            V_Stefan
                            #439
                            @tombox
                            Dank für die schnelle Rückmeldung.
                            Ich habe es das erste mal gestern probiert, heute Morgen und kurz vor 12.
                            Stefan
                            • V V_Stefan
                              @tombox
                              Stefan
                              V Offline
                              V Offline
                              V_Stefan
                              #440
                              Wenn ich mich von der App ab- und wieder anmelde, ist die Mail innerhalb von 1 min. da.
                              Ich habe auch schon den Code ausprobiert, den ich über die App angefordert habe, hat auch nicht funktioniert.
                              Stefan
                              T 2 2 Antworten Letzte Antwort
                              • V V_Stefan
                                Stefan
                                tombox
                                #441
                                @v_stefan Der login prozess wurde geändert wenn du via github installierst und nochmal probierst sollte es gehen
                                • T tombox
                                  V Offline
                                  V Offline
                                  V_Stefan
                                  #442
                                  Super, vielen Dank. Funktioniert! Habe schon gedacht, das ich wieder mal zu dumm dafür bin.
                                  Ich habe gerade nur kurz in die Objekte geschaut. Ist es über den Adapter möglich die Batterieladung eines Hybrids zu starten? Bei Remote habe ich zu mindestens nichts gefunden. Über die App ist das möglich.
                                  Stefan
                                  • V V_Stefan
                                    Stefan
                                    tombox
                                    #443
                                    @v_stefan Die remote sachen sind nur überbleibsel aus alten versionen. Du solltest unter commands gucken ob da was dabei ist was du starten kannst
                                    • V V_Stefan
                                      Stefan
                                      2 Offline
                                      2 Offline
                                      2hot4you
                                      #444
                                      Moin,
                                      habe auch auf die Version .45 geändert.
                                      Der erste Start klappt, dann geht der Adapter auf
                                      gelb und ich bekomme zig Mails mit einen Code
                                      • 2 2hot4you
                                        Moin,
                                        tombox
                                        #445
                                        @2hot4you welche Fehler kommen im log
                                        • T tombox
                                          Markus Frankl
                                          schrieb am zuletzt editiert von Markus Frankl
                                          #446
                                          @tombox
                                          Bei mir ist das bei der Version 0.0.47 immernoch so. Der Start klappt und Adapter geht auf grün. Nach ungefähr 3 Std springt er auf Gelb zurück und es kommt automatisch wieder die Mail mit dem Code zur Abfrage.
                                          Im Log steht dann nur: Error to login
