  4. Installation auf RasPI1 mit Raspbian
    5.5k
22 Beiträge 4 Kommentatoren 3.2k Aufrufe
  • lobomauL Offline
    lobomauL Offline
    lobomau
    @JERKBALL:
    Jetzt gehts! Danke :) `
    Wie denn nun genau?
    Ich habe das Raspi 1 Image genommen mit js-controller 0.12.2 und versuche es upzudaten auf 0.13.2.
    node ist dabei noch auf 0.12.6. node updaten habe ich vorher bei anderen Versuchen nicht hinbekommen.
    pi@ioBroker-Pi1:~ $ sudo su
    root@ioBroker-Pi1:/home/pi# node -v
    v0.12.6
    root@ioBroker-Pi1:/home/pi# cd /opt/iobroker
    root@ioBroker-Pi1:/opt/iobroker# iobroker stop
    Stopping iobroker controller daemon...
    iobroker controller daemon stopped.
    Exit code for "killall.sh": 0
    root@ioBroker-Pi1:/opt/iobroker# npm install iobroker.js-controller --production
    npm WARN engine request@2.78.0: wanted: {"node":">= 4"} (current: {"node":"0.12.6","npm":"2.11.2"})
    > ursa@0.9.4 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa
    > node-gyp rebuild
    gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/0.12.6"
    gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa/.node-gyp"
    make: Entering directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa/build'
      CXX(target) Release/obj.target/ursaNative/src/ursaNative.o
      SOLINK_MODULE(target) Release/obj.target/ursaNative.node
      COPY Release/ursaNative.node
    make: Leaving directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa/build'
    > iobroker.js-controller@0.13.2 install /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/setup.js setup first
    fs.js:500
      return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
    Error: EACCES, permission denied '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh'
        at Error (native)
        at Object.fs.openSync (fs.js:500:18)
        at Object.fs.writeFileSync (fs.js:1099:15)
        at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:88:24)
        at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:552:23
        at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:573:11)
        at Module._compile (module.js:460:26)
        at Object.Module._extensions..js (module.js:478:10)
        at Module.load (module.js:355:32)
        at Function.Module._load (module.js:310:12)
    npm ERR! Linux 4.4.11+
    npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.js-controller" "--production"
    npm ERR! node v0.12.6
    npm ERR! npm  v2.11.2
    npm ERR! code ELIFECYCLE
    npm ERR! iobroker.js-controller@0.13.2 install: `node lib/setup.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@0.13.2 install script 'node lib/setup.js setup first'.
    npm ERR! This is most likely a problem with the iobroker.js-controller package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR!     node lib/setup.js setup first
    npm ERR! You can get their info via:
    npm ERR!     npm owner ls iobroker.js-controller
    npm ERR! There is likely additional logging output above.
    npm ERR! Please include the following file with any support request:
    npm ERR!     /opt/iobroker/npm-debug.log
    root@ioBroker-Pi1:/opt/iobroker#</anonymous>
    Nach diesem Versuch funktioniert dann auch kein "iobroker" mehr:
    module.js:338
        throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (module.js:336:15)
        at Function.Module._load (module.js:278:25)
        at Function.Module.runMain (module.js:501:10)
        at startup (node.js:129:16)
        at node.js:814:3
    Host: NUC8i3 mit Proxmox:
    • Slave: Pi4
    • BluefoxB Offline
      BluefoxB Offline
      @lobomau:
      @JERKBALL:
      Wie denn nun genau?
      v0.12.6
      > node-gyp rebuild
      fs.js:500
          at Error (native)
      npm ERR!
      module.js:338
          throw err;
          at node.js:814:3
      Ein mal schreiben:
      cd /opt/iobroker
      sudo chmod 777 * -R
      sudo chmod 700 /root
      sudo chmod 777 /root/.node-gyp
      sudo chmod 777 /root/.node-gyp/* -R
      sudo npm install iobroker.js-controller --production
      • lobomauL Offline
        lobomauL Offline
        lobomau
        @Bluefox:
        Ein mal schreiben:
        cd /opt/iobroker
        sudo chmod 777 * -R
        sudo npm install iobroker.js-controller –production `
        Leider bei der vorletzten Zeile:
        pi@ioBroker-Pi1:~ $ cd /opt/iobroker
        pi@ioBroker-Pi1:/opt/iobroker $ sudo chmod 777 * -R
        pi@ioBroker-Pi1:/opt/iobroker $ sudo chmod 700 /root
        pi@ioBroker-Pi1:/opt/iobroker $ sudo chmod 777 /root/.node-gyp
        pi@ioBroker-Pi1:/opt/iobroker $ sudo chmod 777 /root/.node-gyp/* -R
        chmod: Zugriff auf „/root/.node-gyp/*“ nicht möglich: Datei oder Verzeichnis nicht gefunden
        • Slave: Pi4
        • BluefoxB Offline
          BluefoxB Offline
          @lobomau:
          @Bluefox:
          Ein mal schreiben:
          cd /opt/iobroker
          sudo chmod 777 * -R
          hm… /root/.node-gyp/
          WTF… ;)
          • lobomauL Offline
            lobomauL Offline
            lobomau
            ich probiere jetzt lieber nicht die letzte Zeile
            Das hat vorher nicht funktioniert und alles "zerschossen".
            Oder sollte ich es probieren? :roll:
            • Slave: Pi4
              Mach auf jeden Fall vorher ein
              sudo npm cache clean
              sudo iobroker stop
              • lobomauL Offline
                lobomauL Offline
                lobomau
                @Homoran:
                sudo iobroker stop
                Rainer `
                Davon geht jedenfalls die folgende Fehlermeldung nicht weg:
                Es ist ja weiterhin node 0.12.6 drauf.
                Hauptfrage: muss ich node updaten, um auch js-controller auf 0.13.2 updaten zu können?
                Jerkball schein es ja geschafft zu haben: aktueller js-controller mit node 4.x.x. auf raspi1.
                • Slave: Pi4
                  @lobomau:
                  Es ist ja weiterhin node 0.12.6 drauf. ` Ich werde langsam alt und vergesslich :(
                  Du hattest geschrieben:
                  @lobomau:
                  Ich habe das Raspi 1 Image genommen `
                  Ich meine das aktuelle Image http://www.iobroker.net/?page_id=2563&lang=de in der Liste ganz oben, wäre mit jessie und nodejs 4.x.
                  Kann mich aber nicht mehr erinnern und ausgerechnet dazu habe ich eine mangelhafte Doku abgegeben :oops:
                  Das ganze geht mir jetzt etwas zu sehr in die (bei mir nicht vorhandene) Tiefe.
                  Die Fehlermeldung:
                  @lobomau:
                  chmod: Zugriff auf „/root/.node-gyp/*“ nicht möglich: Datei oder Verzeichnis nicht gefunden `
                  kann evtl. auch mit fehlenden Rechten zusammenhängen.
                  mach mal vorher ein
                  sudo su
                  um dich als echter root vorübergehend anzumelden und probiere den chmod dann noch einmal.
                  • lobomauL Offline
                    lobomauL Offline
                    lobomau
                    @Homoran:
                    @lobomau:
                    @lobomau:
                    mach mal vorher ein
                    sudo su
                    Das eine Raspi1 Image ist mit node 0.12.6. :-(
                    Ich glaube sudo su hatte ich schon getestet. Mach ich nochmal.
                    • Slave: Pi4
                      @lobomau:
                      Das eine Raspi1 Image ist mit node 0.12.6. :-( `
                      Ja das von vor weit über einem Jahr, da gab es nichts anderes und auch nur wheezy und kein Jessie.
