  4. Installation auf RasPI1 mit Raspbian
    5.5k
22 Beiträge 4 Kommentatoren 3.2k Aufrufe
  • J Offline
    JERKBALL
    root@fhem:/opt/iobroker#  npm install iobroker.js-controller --production
    > iobroker.js-controller@0.13.2 install /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/setup.js setup first
    iobroker.js-controller@0.13.2 node_modules/iobroker.js-controller
    └── yargs@6.3.0 (yargs-parser@4.0.2)
    root@fhem:/opt/iobroker# /usr/bin/node node_modules/iobroker.js-controller/iobroker.js setup
    object system.certificates created
    object system.repositories created
    object system.config created
    object enum.rooms created
    object system.group.user created
    object system.group.administrator created
    object _design/system created
    Jetzt gehts! Danke :)
    • lobomauL Offline
      lobomauL Offline
      lobomau
      @JERKBALL:
      Jetzt gehts! Danke :) `
      Wie denn nun genau?
      Ich habe das Raspi 1 Image genommen mit js-controller 0.12.2 und versuche es upzudaten auf 0.13.2.
      node ist dabei noch auf 0.12.6. node updaten habe ich vorher bei anderen Versuchen nicht hinbekommen.
      pi@ioBroker-Pi1:~ $ sudo su
      root@ioBroker-Pi1:/home/pi# node -v
      v0.12.6
      root@ioBroker-Pi1:/home/pi# cd /opt/iobroker
      root@ioBroker-Pi1:/opt/iobroker# iobroker stop
      Stopping iobroker controller daemon...
      iobroker controller daemon stopped.
      Exit code for "killall.sh": 0
      root@ioBroker-Pi1:/opt/iobroker# npm install iobroker.js-controller --production
      npm WARN engine request@2.78.0: wanted: {"node":">= 4"} (current: {"node":"0.12.6","npm":"2.11.2"})
      > ursa@0.9.4 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa
      > node-gyp rebuild
      gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/0.12.6"
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa/.node-gyp"
      make: Entering directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa/build'
        CXX(target) Release/obj.target/ursaNative/src/ursaNative.o
        SOLINK_MODULE(target) Release/obj.target/ursaNative.node
        COPY Release/ursaNative.node
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa/build'
      fs.js:500
        return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
      Error: EACCES, permission denied '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh'
          at Error (native)
          at Object.fs.openSync (fs.js:500:18)
          at Object.fs.writeFileSync (fs.js:1099:15)
          at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:88:24)
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:552:23
          at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:573:11)
          at Module._compile (module.js:460:26)
          at Object.Module._extensions..js (module.js:478:10)
          at Module.load (module.js:355:32)
          at Function.Module._load (module.js:310:12)
      npm ERR! Linux 4.4.11+
      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.js-controller" "--production"
      npm ERR! node v0.12.6
      npm ERR! npm  v2.11.2
      npm ERR! code ELIFECYCLE
      npm ERR! iobroker.js-controller@0.13.2 install: `node lib/setup.js setup first`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@0.13.2 install script 'node lib/setup.js setup first'.
      npm ERR! This is most likely a problem with the iobroker.js-controller package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR!     node lib/setup.js setup first
      npm ERR! You can get their info via:
      npm ERR!     npm owner ls iobroker.js-controller
      npm ERR! There is likely additional logging output above.
      npm ERR! Please include the following file with any support request:
      npm ERR!     /opt/iobroker/npm-debug.log
      root@ioBroker-Pi1:/opt/iobroker#</anonymous>
      Nach diesem Versuch funktioniert dann auch kein "iobroker" mehr:
      module.js:338
          throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Function.Module._resolveFilename (module.js:336:15)
          at Function.Module._load (module.js:278:25)
          at Function.Module.runMain (module.js:501:10)
          at startup (node.js:129:16)
          at node.js:814:3
      Host: NUC8i3 mit Proxmox:
      • Slave: Pi4
      • BluefoxB Offline
        BluefoxB Offline
        @lobomau:
        @JERKBALL:
        Wie denn nun genau?
        v0.12.6
        > node-gyp rebuild
        fs.js:500
            at Error (native)
        npm ERR!
        module.js:338
            throw err;
            at node.js:814:3
        Ein mal schreiben:
        cd /opt/iobroker
        sudo chmod 777 * -R
        sudo chmod 700 /root
        sudo chmod 777 /root/.node-gyp
        sudo chmod 777 /root/.node-gyp/* -R
        sudo npm install iobroker.js-controller --production
        • lobomauL Offline
          lobomauL Offline
          lobomau
          @Bluefox:
          Ein mal schreiben:
          cd /opt/iobroker
          sudo chmod 777 * -R
          sudo npm install iobroker.js-controller –production `
          Leider bei der vorletzten Zeile:
          pi@ioBroker-Pi1:~ $ cd /opt/iobroker
          pi@ioBroker-Pi1:/opt/iobroker $ sudo chmod 777 * -R
          pi@ioBroker-Pi1:/opt/iobroker $ sudo chmod 700 /root
          pi@ioBroker-Pi1:/opt/iobroker $ sudo chmod 777 /root/.node-gyp
          pi@ioBroker-Pi1:/opt/iobroker $ sudo chmod 777 /root/.node-gyp/* -R
          chmod: Zugriff auf „/root/.node-gyp/*“ nicht möglich: Datei oder Verzeichnis nicht gefunden
          • Slave: Pi4
          • BluefoxB Offline
            BluefoxB Offline
            @lobomau:
            @Bluefox:
            Ein mal schreiben:
            cd /opt/iobroker
            sudo chmod 777 * -R
            hm… /root/.node-gyp/
            WTF… ;)
            • lobomauL Offline
              lobomauL Offline
              lobomau
              ich probiere jetzt lieber nicht die letzte Zeile
              Das hat vorher nicht funktioniert und alles "zerschossen".
              Oder sollte ich es probieren? :roll:
              • Slave: Pi4
                Mach auf jeden Fall vorher ein
                sudo npm cache clean
                sudo iobroker stop
                • lobomauL Offline
                  lobomauL Offline
                  lobomau
                  @Homoran:
                  sudo iobroker stop
                  Rainer `
                  Davon geht jedenfalls die folgende Fehlermeldung nicht weg:
                  Es ist ja weiterhin node 0.12.6 drauf.
                  Hauptfrage: muss ich node updaten, um auch js-controller auf 0.13.2 updaten zu können?
                  Jerkball schein es ja geschafft zu haben: aktueller js-controller mit node 4.x.x. auf raspi1.
                  • Slave: Pi4
                    @lobomau:
                    Es ist ja weiterhin node 0.12.6 drauf. ` Ich werde langsam alt und vergesslich :(
                    Du hattest geschrieben:
                    @lobomau:
                    Ich habe das Raspi 1 Image genommen `
                    Ich meine das aktuelle Image http://www.iobroker.net/?page_id=2563&lang=de in der Liste ganz oben, wäre mit jessie und nodejs 4.x.
                    Kann mich aber nicht mehr erinnern und ausgerechnet dazu habe ich eine mangelhafte Doku abgegeben :oops:
                    Das ganze geht mir jetzt etwas zu sehr in die (bei mir nicht vorhandene) Tiefe.
                    Die Fehlermeldung:
                    @lobomau:
                    chmod: Zugriff auf „/root/.node-gyp/*“ nicht möglich: Datei oder Verzeichnis nicht gefunden `
                    kann evtl. auch mit fehlenden Rechten zusammenhängen.
                    mach mal vorher ein
                    sudo su
                    um dich als echter root vorübergehend anzumelden und probiere den chmod dann noch einmal.
                    • lobomauL Offline
                      lobomauL Offline
                      lobomau
                      @Homoran:
                      @lobomau:
                      @lobomau:
                      mach mal vorher ein
                      sudo su
                      Das eine Raspi1 Image ist mit node 0.12.6. :-(
                      Ich glaube sudo su hatte ich schon getestet. Mach ich nochmal.
                      • Slave: Pi4
                        @lobomau:
                        Das eine Raspi1 Image ist mit node 0.12.6. :-( `
                        Ja das von vor weit über einem Jahr, da gab es nichts anderes und auch nur wheezy und kein Jessie.
