  5. Fehlermeldung You are assigning a undefined to the state
    5.3k
blockly
4 Beiträge 4 Kommentatoren 456 Aufrufe 1 Beobachtet
  • JB_SullivanJ Offline
    JB_Sullivan
    Was will mir die folgende Fehlermeldung sagen? Ich bin der Meinung das da alles mit rechten Dingen zu geht - oder etwa nicht?
    2021-01-15 09:20:30.241 - warn: javascript.0 (1460) You are assigning a undefined to the state "innogy-smarthome.0.Küche.Heizkörper-Küche.PointTemperature" which expects a number. Please fix your code to use a number or change the state type to undefined. This warning might become an error in future versions.
    2021-01-15 09:20:30.246 - warn: javascript.0 (1460) at setState (C:\iobroker\GLT\node_modules\iobroker.javascript\lib\sandbox.js:1417:20)
    2021-01-15 09:20:30.246 - warn: javascript.0 (1460) at Object. (script.js.Aktiv.Heizung_Steuerung_Kueche:23:5)
    2021-01-15 09:20:30.246 - warn: javascript.0 (1460) at Object.callback (C:\iobroker\GLT\node_modules\iobroker.javascript\lib\sandbox.js:1071:38)
    2021-01-15 09:20:30.246 - warn: javascript.0 (1460) at Object.stateChange (C:\iobroker\GLT\node_modules\iobroker.javascript\main.js:487:29)
    2021-01-15 09:20:30.247 - warn: javascript.0 (1460) at Immediate.setImmediate (C:\iobroker\GLT\node_modules\iobroker.js-controller\lib\adapter.js:5384:37)
    2021-01-15 09:20:30.247 - warn: javascript.0 (1460) at runCallback (timers.js:705:18)
    2021-01-15 09:20:30.247 - warn: javascript.0 (1460) at tryOnImmediate (timers.js:676:5)
    2021-01-15 09:20:30.247 - warn: javascript.0 (1460) at processImmediate (timers.js:658:5)
    2021-01-15 09:20:30.247 - warn: javascript.0 (1460) at process.topLevelDomainCallback (domain.js:126:23)
    2021-01-15 09:20:30.247 - error: javascript.0 (1460) script.js.Aktiv.Heizung_Steuerung_Kueche: setForeignState: undefined is not a valid state value
      "from": "system.adapter.innogy-smarthome.0",
      "user": "system.user.admin",
      "ts": 1610544924078,
      "common": {
        "name": "PointTemperature",
        "type": "number",
        "role": "level.temperature",
        "unit": "°C",
        "read": true,
        "write": true
      "native": {
        "id": "a46d491038104f29a0b4b1e1ae6506ba"
      "acl": {
        "object": 1636,
        "owner": "system.user.admin",
        "state": 1636
      "_id": "innogy-smarthome.0.Küche.Heizkörper-Küche.PointTemperature",
      "type": "state"
    haselchenH HomoranH 2 Antworten Letzte Antwort
    • JB_SullivanJ JB_Sullivan
        "common": {
          "type": "number",
          "unit": "°C",
          "read": true,
          "write": true
        "native": {
        "acl": {
          "object": 1636,
          "state": 1636
        "type": "state"
      haselchenH Offline
      haselchenH Offline
      haselchen
      @jb_sullivan
      Wenn das dein Script ist ( was oben abgebildet ist)
      dann ist in Zeile 23 ein Fehler (so würde ich das interpretieren)
      Bei meinen Thermostaten steht dort "device"
      Ich denke , dass @paul53 vermutlich weiss , was wirklich da reinkommt :)
      • haselchenH haselchen
        @jb_sullivan
        @haselchen said: Ich denke , dass paul53 vermutlich weiss , was wirklich da reinkommt
        Nein, denn ich weiß nicht, was in Zeile 23 (und davor) steht und kenne auch nicht "innogy-smarthome".
            "common": {
              "type": "number",
              "unit": "°C",
              "read": true,
              "write": true
            "native": {
            "acl": {
              "object": 1636,
              "state": 1636
            "type": "state"
          @haselchen said in Fehlermeldung You are assigning a undefined to the state:
          und zwar an Position 5
          Dort wird anscheinend der Datenpunkt
          @jb_sullivan said in Fehlermeldung You are assigning a undefined to the state:
          mit einem undefinierten Wert beschrieben, während der DP
          expects a number
