  4. backitup meldet Cannot find module 'fs-constants'
    6.7k
backitup fs-constants
36 Beiträge 4 Kommentatoren 3.9k Aufrufe 3 Beobachtet
  • B Bernd1971
    @Thomas-Braun Danke für eure Hilfe. Ich bin nun auf 12.x
    /usr/bin/nodejs
    v12.20.1
    /usr/bin/node
    v12.20.1
    /usr/bin/npm
    6.14.10
    nodejs:
      Installed: 12.20.1-1nodesource1
      Candidate: 12.20.1-1nodesource1
      Version table:
     *** 12.20.1-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x buster/main arm64 Packages
         10.23.1~dfsg-1~deb10u1 500
            500 http://security.debian.org buster/updates/main arm64 Packages
         10.21.0~dfsg-1~deb10u1 500
            500 http://httpredir.debian.org/debian buster/main arm64 Packages
    Aber es funktioniert leider noch nicht...
    backitup.0	2021-01-11 19:09:04.411	error	- /opt/iobroker/node_modules/iobroker.backitup/main.js Please run "iobroker fix" and reinstall backitup
    backitup.0	2021-01-11 19:09:04.411	error	- /opt/iobroker/node_modules/iobroker.backitup/lib/execute.js
    backitup.0	2021-01-11 19:09:04.411	error	- /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/12-influxDB.js
    backitup.0	2021-01-11 19:09:04.411	error	- /opt/iobroker/node_modules/targz/index.js
    backitup.0	2021-01-11 19:09:04.411	error	- /opt/iobroker/node_modules/targz/lib/targz.js
    backitup.0	2021-01-11 19:09:04.411	error	- /opt/iobroker/node_modules/targz/node_modules/tar-fs/index.js
    backitup.0	2021-01-11 19:09:04.411	error	- /opt/iobroker/node_modules/targz/node_modules/tar-stream/index.js
    backitup.0	2021-01-11 19:09:04.411	error	- /opt/iobroker/node_modules/targz/node_modules/tar-stream/pack.js
    backitup.0	2021-01-11 19:09:04.411	error	Require stack:
    backitup.0	2021-01-11 19:09:04.411	error	(8863) [iobroker] error on backup: Error: Cannot find module 'fs-constants'
    MOD-Edit: Code in code-tags gesetzt!
    ich habe nochmals backitup neu installiert und auch schon den Fix laufen lassen. Noch weitere Ideen?
    @Bernd1971 sagte in backitup meldet Cannot find module 'fs-constants':
    Bitte Konsolentext in CodeTags </> packen.
    cd /opt/iobroker
    npm list fs-constants
      cd /opt/iobroker
      Bernd1971
      @Thomas-Braun
      Ich hoffe das klappt...
      +-- iobroker.backitup@1.8.4
      | `-- targz@1.0.1
      |   `-- tar-fs@1.16.3
      |     `-- tar-stream@1.6.2
      |       `-- fs-constants@1.0.0
      +-- iobroker.discovery@2.4.1
      | `-- serialport@9.0.4
      |   `-- @serialport/bindings@9.0.4
      |     `-- prebuild-install@6.0.0
      |       `-- tar-fs@2.1.1
      |         `-- tar-stream@2.1.4
      |           `-- fs-constants@1.0.0  deduped
      +-- node-red-node-serialport@0.8.8
      | `-- serialport@7.1.5
      |   `-- @serialport/bindings@2.0.8
      |     `-- prebuild-install@5.3.3
      |       `-- tar-fs@2.0.0
      |         `-- tar-stream@2.1.0
      `-- serialport@8.0.5
        `-- @serialport/bindings@8.0.4
            `-- tar-fs@2.0.0
      • B Bernd1971
        @Thomas-Braun
        | `-- targz@1.0.1
        |   `-- tar-fs@1.16.3
        |       `-- tar-fs@2.1.1
        |       `-- tar-fs@2.0.0
              `-- tar-fs@2.0.0
        @Bernd1971 Eigentlich passt das...
        ls -la /opt/iobroker/node_modules/fs-constants/
          Bernd1971
          @Thomas-Braun
          total 28
          drwxrwxrwx+   2 iobroker iobroker  4096 Nov  9  2019 .
          drwxrwxrwx+ 695 iobroker iobroker 20480 Jan 11 19:05 ..
          -rwxrwxrwx+   1 iobroker iobroker  1011 Nov  9  2019 package.json
          MOD-Edit: Code-tags gefixt!
          • B Bernd1971
            @Thomas-Braun
            total 28
            @Bernd1971
            Da ist der Fehler.
            Das muss so aussehen:
            pi@raspberrypi:/opt/iobroker $ ls -la /opt/iobroker/node_modules/fs-constants/
            insgesamt 52
            drwxrwxr-x+   2 iobroker iobroker  4096 Aug 28 22:25 .
            drwxrwxr-x+ 656 iobroker iobroker 28672 Jan 11 00:10 ..
            -rw-rwxr--+   1 iobroker iobroker    38 Apr 26  2018 browser.js
            -rw-rwxr--+   1 iobroker iobroker    65 Apr 26  2018 index.js
            -rw-rwxr--+   1 iobroker iobroker  1079 Jan  1  2018 LICENSE
            -rw-rwxr--+   1 iobroker iobroker  1366 Aug 28 22:25 package.json
            -rw-rwxr--+   1 iobroker iobroker   528 Apr 26  2018 README.md
              @Bernd1971
              Da ist der Fehler.
              insgesamt 52
              Bernd1971
              @Thomas-Braun cool, gibt es dazu ein fixer-fix? soweit ich das verstehe, habe ich gar keinen iobroker user....
              • B Bernd1971
                @Thomas-Braun
                total 28
                @Bernd1971
                dmesg | grep -i ext4
                dann mal
                iobroker del iobroker.backitup
                cd /opt/iobroker
                npm prune
                npm cache clean --force
                iobroker add backitup
                • B Bernd1971
                  Klar...
                  sudo -u iobroker whoami && sudo -u iobroker id
                  Allerdings sind bei dir auch die Rechte verfummelt. Wie haste das denn hinbekommen? Als root rekursiv irgendwelchen Blödsinn auf das System gegossen? Da kommt das nämlich meistens her.
                  Gibt da u. a. so bestimmte Super-Youtuber mit irgendwelchen Blödsinns-Tools, die das empfehlen, sonst würde ihr SuperMEGA-Tool nicht funktionieren.
                    Klar...
                    Bernd1971
                    @Thomas-Braun ich sag mal so, man fängt am Anfang mit wenig Ahnung an und arbeitet sich dann die Leiter der Kompetenz hoch.
                    B Thomas BraunT 2 Antworten Letzte Antwort
                    • B Bernd1971
                      Bernd1971
                      @Bernd1971 also ... alle befehle abgearbeitet .. allerdings gleiches ergebnis
                      total 28
                      drwxrwxrwx+ 680 iobroker iobroker 20480 Jan 11 19:50 ..
                      • B Bernd1971
                        total 28
                        Bernd1971
                        iobroker
                        uid=1000(iobroker) gid=1000(iobroker) groups=1000(iobroker),5(tty),20(dialout),29(audio),44(video)
                        • B Bernd1971
                          @Bernd1971 Man sollte aber bei der Auswahl der Leiterhalter vorsichtig sein. Manche Sprossen sind da etwas morsch.
                          whoami
                          • B Bernd1971
                            iobroker
                            Bernd1971
                            su iobroker
                            This account is currently not available.
                            • B Bernd1971
                              su iobroker
                              @Bernd1971
                              Du bist permanent als root unterwegs, oder?
                                whoami
                                Bernd1971
                                @Thomas-Braun Ja, ich hatte NULL Ahnung am Anfang, aber Hilfe von jemand mit unendlich mal mehr Ahnung...
                                  @Bernd1971
                                  Bernd1971
                                  @Thomas-Braun auf der kiste, leider ja
                                  • B Bernd1971
                                    @Bernd1971 Dann brauchen wir gar nicht weiter machen.
                                    Du legst dir jetzt einen user mit einer Mitgliedschaft in der Gruppe 'sudo' an. Und dann meldest du dich nie mehr als root an.
                                    Am besten machst du das System ohnehin komplett neu, wer weiß was du dir da sonst noch zerschossen hast.
                                      Bernd1971
                                      @Thomas-Braun tut mir leid, dass ich das falsch gemacht habe
                                      • B Bernd1971
                                        @Bernd1971
                                        Bei mir musst du dich nicht entschuldigen.
                                        Wie gesagt, ICH würde das System jetzt neuaufsetzen und mich bei dem "jemand mit unendlich mal mehr Ahnung" bedanken.
                                          @Bernd1971
                                          Bernd1971
                                          @Thomas-Braun Okay, danke Dir. Das mache ich dann mal - allerdings nicht mehr heute. Wie sollte ich deiner Meinung nach genau vorgehen? Das komplette Linux neu installieren? gibt es da ein Hau-to? .... damit ich nicht wieder was falsch mache?
