  4. Test Adapter HeatingControl v3.xx
    1.0k
    6.1k
heating
3.3k Beiträge 239 Kommentatoren 2.4m Aufrufe 201 Beobachtet
  • Dominik F.D Dominik F.
    @Rene_HM
    V2 funktioniert soweit gut, kann nix feststellen, danke dafür! Auch das mit den Fenstern geht nun.
    Mir wird nun das Log voll gehauen mit folgendem:
    Das ganze kommt minütlich
    heatingcontrol.0	2021-01-09 16:02:12.436	info	(29345) UpdateDPs for OG_Bad auto
    heatingcontrol.0	2021-01-09 16:02:12.435	info	(29345) OG_Bad ### ChangeStatus Thermostats_Target to {"val":20,"ack":true,"ts":1610204532432,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1610196301810} in auto
    heatingcontrol.0	2021-01-09 16:01:49.072	info	(29345) UpdateDPs for OG_Schlazimmer auto
    heatingcontrol.0	2021-01-09 16:01:49.072	info	(29345) OG_Schlazimmer ### ChangeStatus Thermostats_Target to {"val":19,"ack":true,"ts":1610204509068,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1610196234782} in auto
    heatingcontrol.0	2021-01-09 16:01:14.999	info	(29345) UpdateDPs for EG_Diele auto
    heatingcontrol.0	2021-01-09 16:01:14.998	info	(29345) EG_Diele ### ChangeStatus Thermostats_Target to {"val":20,"ack":true,"ts":1610204474994,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1610195824062} in auto
    heatingcontrol.0	2021-01-09 16:01:12.942	info	(29345) UpdateDPs for EG_Wohnzimmer auto
    heatingcontrol.0	2021-01-09 16:01:12.941	info	(29345) EG_Wohnzimmer ### ChangeStatus Thermostats_Target to {"val":20,"ack":true,"ts":1610204472939,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1610203547086} in auto
    heatingcontrol.0	2021-01-09 16:00:25.887	info	(29345) UpdateDPs for EG_Küche auto
    heatingcontrol.0	2021-01-09 16:00:25.887	info	(29345) EG_Küche ### ChangeStatus Thermostats_Target to {"val":20,"ack":true,"ts":1610204425868,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1610198770714} in auto
    heatingcontrol.0	2021-01-09 16:00:15.860	info	(29345) UpdateDPs for EG_Küche auto
    heatingcontrol.0	2021-01-09 16:00:15.860	info	(29345) EG_Küche ### ChangeStatus Thermostats_Target to {"val":20,"ack":true,"ts":1610204415857,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1610198770714} in auto
    heatingcontrol.0	2021-01-09 15:59:21.687	info	(29345) UpdateDPs for OG_Bad auto
    heatingcontrol.0	2021-01-09 15:59:21.687	info	(29345) OG_Bad ### ChangeStatus Thermostats_Target to {"val":20,"ack":true,"ts":1610204361682,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1610196301810} in auto
    heatingcontrol.0	2021-01-09 15:59:18.073	info	(29345) UpdateDPs for OG_Schlazimmer auto
    heatingcontrol.0	2021-01-09 15:59:18.073	info	(29345) OG_Schlazimmer ### ChangeStatus Thermostats_Target to {"val":19,"ack":true,"ts":1610204358068,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1610196234782} in auto
    heatingcontrol.0	2021-01-09 15:59:10.194	info	(29345) UpdateDPs for EG_Wohnzimmer auto
    heatingcontrol.0	2021-01-09 15:59:10.194	info	(29345) EG_Wohnzimmer ### ChangeStatus Thermostats_Target to {"val":20,"ack":true,"ts":1610204350191,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1610203547086} in auto
    heatingcontrol.0	2021-01-09 15:58:45.750	info	(29345) UpdateDPs for EG_Diele auto
    heatingcontrol.0	2021-01-09 15:58:45.749	info	(29345) EG_Diele ### ChangeStatus Thermostats_Target to {"val":20,"ack":true,"ts":1610204325744,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1610195824062} in auto
    heatingcontrol.0	2021-01-09 15:58:11.858	info	(29345) UpdateDPs for EG_Küche auto
    heatingcontrol.0	2021-01-09 15:58:11.858	info	(29345) EG_Küche ### ChangeStatus Thermostats_Target to {"val":20,"ack":true,"ts":1610204291856,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1610198770714} in auto
    Rene_HMR Offline
    Rene_HMR Offline
    Rene_HM
    #1731
    @Dominik-F Ich mache die info-Meldungen zu debug-Meldungen... Grund für die Meldung ist, dass dein Thermostat regelmässig die aktuelle Zieltemperatur schickt...
    • Rene_HMR Offline
      Rene_HMR Offline
      Rene_HM
      #1732
      Es gibt bereits die Planung für Release 2.1
      • Rene_HMR Rene_HM
        Dominik F.D Offline
        Dominik F.D Offline
        Dominik F.
        #1733
        @Rene_HM
        Okay, also kann ich davon ausgehen, dass dies abgestellt wird wenn die Version ins latest kommt?
        Ich habe mal etwas gebastelt mit einer View für einen Raum, vielleicht ist diese ja interessant für dich, dann stelle ich sie gerne bereit.
        Bis auf den Batteriestatus, den ich so nicht brauche, hab ich alles reingebracht denke ich.
        Mit Plus/Minus lässt sich die Temperatur um 0,5 Grad verstellen.
        Rene_HMR F 3 Antworten Letzte Antwort
          @Rene_HM
          Rene_HMR Offline
          Rene_HMR Offline
          Rene_HM
          #1734
          @Dominik-F sagte in Test Adapter HeatingControl v2.0.x:
          ist schon auf github...
          • Rene_HMR Rene_HM
            Tschaeens
            schrieb am zuletzt editiert von Tschaeens
            #1735
            eine Frage habe die 2.0 heute installiert und was mir bei Mo-Fr und Sa-So aufgefallen ist, dass die currentTimePeriod heute immer am Mo-Fr angezeigt wird. Das heißt bei Adapterneustart ist sie immer richtig und bei >5. Wenn aber eine neue Periode startet geht sie immer auf Mo–Fr.? Vis von Pittini wird verwendet. Upload Adapter gemacht. Jmd. eine Idee? Temp. wird auch korrekt gesetzt!
            Ansonsten sehr geiler Adapter!
            Rene_HMR 1 Antwort Letzte Antwort
            • ChaotC Offline
              ChaotC Offline
              Chaot
              #1736
              @Dominik-F Ich hätte Interesse.
              • T Tschaeens
                Rene_HMR Offline
                Rene_HMR Offline
                Rene_HM
                #1737
                @Tschaeens Welche vis-Version? 3.1 von hier?
                • Rene_HMR Rene_HM
                  Tschaeens
                  #1738
                  @Rene_HM
                  Job habe alle Datenpunkte nach deiner Anleitung verändert! Auch unter Objekte vis ist die currentimeperiod aktuell 5. Sie müsste aber 10 sein.
                  • T Tschaeens
                    @Rene_HM
                    Rene_HMR Offline
                    Rene_HMR Offline
                    Rene_HM
                    #1739
                    @Tschaeens passen diese Datenpunkte?
                    heatingcontrol.0.Rooms.Wohnzimmer.CurrentTimePeriodFull
                    heatingcontrol.0.Rooms.Wohnzimmer.CurrentTimePeriodTime
                    heatingcontrol.0.Rooms.Wohnzimmer.ActiveTimeSlot
                    wenn nicht, was steht dort und was sollte dort stehen?
                    Wie sieht dein Profil aus? evtl. Profilpunkte nicht in der richtigen Reihenfolge?
                    Hast du ein debug log von dem Zeitpunkt, wo das Profil umschaltet?
                    • Rene_HMR Rene_HM
                      Tschaeens
                      #1740
                      @Rene_HM erstmal danke für die Hilfe!
                      heatingcontrol.0.Rooms.Ankleide groß.CurrentTimePeriodFull       Period 5 21:00
                      heatingcontrol.0.Rooms.Ankleide groß.CurrentTimePeriodTime     21:00
                      heatingcontrol.0.Rooms.Ankleide groß.ActiveTimeSlot                   5
                      debug log könnte ich morgen früh mal machen?
                      • ChaotC Chaot
                        Dominik F.D Offline
                        Dominik F.D Offline
                        Dominik F.
                        #1741
                        @Chaot
                        Hier die View.
                          "settings": {
                            "style": {
                              "background_class": ""
                            "theme": "redmond",
                            "sizex": "",
                            "sizey": "",
                            "gridSize": "8",
                            "useBackground": false,
                            "snapType": 2
                          "widgets": {
                            "e00001": {
                              "tpl": "tplHtml",
                              "data": {
                                "g_fixed": true,
                                "g_visibility": false,
                                "g_css_font_text": false,
                                "g_css_background": false,
                                "g_css_shadow_padding": false,
                                "g_css_border": false,
                                "g_gestures": false,
                                "g_signals": false,
                                "g_last_change": false,
                                "visibility-cond": "==",
                                "visibility-val": 1,
                                "visibility-groups-action": "hide",
                                "refreshInterval": "0",
                                "signals-cond-0": "==",
                                "signals-val-0": true,
                                "signals-icon-0": "/vis/signals/lowbattery.png",
                                "signals-icon-size-0": 0,
                                "signals-blink-0": false,
                                "signals-horz-0": 0,
                                "signals-vert-0": 0,
                                "signals-hide-edit-0": false,
                                "signals-cond-1": "==",
                                "signals-val-1": true,
                                "signals-icon-1": "/vis/signals/lowbattery.png",
                                "signals-icon-size-1": 0,
                                "signals-blink-1": false,
                                "signals-horz-1": 0,
                                "signals-vert-1": 0,
                                "signals-hide-edit-1": false,
                                "signals-cond-2": "==",
                                "signals-val-2": true,
                                "signals-icon-2": "/vis/signals/lowbattery.png",
                                "signals-icon-size-2": 0,
                                "signals-blink-2": false,
                                "signals-horz-2": 0,
                                "signals-vert-2": 0,
                                "signals-hide-edit-2": false,
                                "lc-type": "last-change",
                                "lc-is-interval": true,
                                "lc-is-moment": false,
                                "lc-format": "",
                                "lc-position-vert": "top",
                                "lc-position-horz": "right",
                                "lc-offset-vert": 0,
                                "lc-offset-horz": 0,
                                "lc-font-size": "12px",
                                "lc-font-family": "",
                                "lc-font-style": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-border-width": "0",
                                "lc-border-style": "",
                                "lc-border-color": "",
                                "lc-border-radius": 10,
                                "lc-zindex": 0,
                                "html": "<i class=\"material-icons\">expand_less</i>",
                                "class": "mdui-button mdui-center mdui-expand  mdui-{0_userdata.0.mdui.vis.card_title_color}"
                              "style": {
                                "left": "calc(100% - 56px)",
                                "top": "16px",
                                "width": "40px",
                                "height": "40px"
                              "widgetSet": "basic"
                            "e00002": {
                              "tpl": "tplHtml",
                              "data": {
                                "g_fixed": true,
                                "g_signals": false,
                                "signals-icon-0": "/vis.0/Handy/lowbattery.png",
                                "signals-icon-1": "/vis.0/Handy/lowbattery.png",
                                "signals-icon-2": "/vis.0/Handy/lowbattery.png",
                                "html": "Küche",
                                "class": "mdui-title  mdui-{0_userdata.0.mdui.vis.card_title_color}",
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0
                              "style": {
                                "left": "16px",
                                "top": "16px",
                                "width": "auto",
                                "height": "auto",
                                "z-index": 1
                            "e00003": {
                              "tpl": "tplHtml",
                              "data": {
                                "g_fixed": true,
                                "g_signals": false,
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0,
                              "style": {
                                "top": "16px",
                                "width": "40px",
                                "height": "40px"
                            "e00004": {
                              "tpl": "tplIconInc",
                              "data": {
                                "oid": "hm-rpc.0.NEQ1802941.2.SET_TEMPERATURE",
                                "repeat_delay": "800",
                                "repeat_interval": "800",
                                "src": "/vis.0/Handy/images/ic_remove_white_48dp.png",
                                "step": "-0.5",
                                "minmax": "17",
                                "signals-icon-0": "/vis.0/Inspiration/lowbattery.png",
                                "signals-icon-1": "/vis.0/Inspiration/lowbattery.png",
                                "signals-icon-2": "/vis.0/Inspiration/lowbattery.png",
                                "text": "",
                                "invert_icon": false,
                                "imageHeight": "100",
                                "name": "Wohnzimmer HK2",
                                "locked": false,
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0,
                                "class": "mdui-button-raised mdui-red-bg"
                              "style": {
                                "left": "calc(10% - 23px)",
                                "top": "84px",
                                "background": "transparent",
                                "width": "46px",
                                "height": "46px",
                                "z-index": 5,
                                "border-style": "none",
                                "border-radius": ""
                              "widgetSet": "jqui"
                            "e00005": {
                              "data": {
                                "src": "/vis.0/Handy/images/ic_add_white_48dp.png",
                                "step": "+0.5",
                                "minmax": "24",
                                "text": "",
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0,
                                "class": "mdui-button-raised mdui-green-bg",
                              "style": {
                                "left": "calc(90% - 23px)",
                                "top": "84px",
                                "width": "46px",
                                "height": "46px",
                                "z-index": 5,
                                "font-weight": "bold",
                                "font-size": "large"
                              "widgetSet": "jqui"
                            "e00006": {
                              "tpl": "tplValueFloat",
                              "data": {
                                "oid": "hm-rpc.0.NEQ1802941.2.ACTUAL_HUMIDITY",
                                "g_fixed": true,
                                "g_css_font_text": true,
                                "g_signals": false,
                                "is_comma": "true",
                                "factor": "1",
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0,
                                "html_append_plural": " %",
                                "class": "mdui-value",
                                "html_prepend": ""
                              "style": {
                                "left": "calc(60% - 30px)",
                                "top": "128px",
                                "font-size": "medium",
                                "width": "60px",
                                "height": "25px",
                                "text-align": "left"
                            "e00007": {
                              "tpl": "tplHtml",
                              "data": {
                                "g_fixed": true,
                                "g_signals": false,
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0,
                                "html": "Luftfeuchte:",
                                "class": "mdui-label"
                              "style": {
                                "left": "calc(40% - 45px)",
                                "top": "128px",
                                "width": "90px",
                                "height": "25px"
                            "e00008": {
                              "data": {
                                "oid": "hm-rpc.0.NEQ1802941.2.ACTUAL_TEMPERATURE",
                                "g_fixed": true,
                                "g_signals": false,
                                "is_comma": "true",
                                "factor": "1",
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0,
                                "html_append_plural": "° C",
                                "html_prepend": ""
                              "style": {
                                "top": "72px",
                                "width": "60px",
                                "height": "25px",
                            "e00009": {
                              "tpl": "tplHtml",
                              "data": {
                                "g_fixed": true,
                                "g_signals": false,
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0,
                                "html": "Ist-Temp:",
                              "style": {
                                "top": "72px",
                                "width": "90px",
                                "height": "25px"
                            "e00010": {
                              "tpl": "tplHtml",
                              "data": {
                                "g_fixed": true,
                                "g_signals": false,
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0,
                                "html": "Soll-Temp:",
                              "style": {
                                "top": "100px",
                                "width": "90px",
                                "height": "25px"
                            "e00011": {
                              "data": {
                                "g_fixed": true,
                                "g_signals": false,
                                "is_comma": "true",
                                "factor": "1",
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0,
                                "html_prepend": ""
                              "style": {
                                "top": "100px",
                                "width": "60px",
                                "height": "25px",
                            "e00012": {
                              "tpl": "tplValueBoolCtrl",
                              "data": {
                                "oid": "hm-rpc.0.info.connection",
                                "g_fixed": true,
                                "g_signals": false,
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0,
                                "html_false": "<img class=\"mdui-red-blink\" height=32px src='/vis.0/HeatingControl/images/it_wifi.svg'>",
                                "html_true": "<img class=\"mdui-green-glow\" height=32px src='/vis.0/HeatingControl/images/it_wifi.svg'>",
                                "class": "{val:hm-rpc.0.info.connection;val==\"true\"? \"mdui-green mdui-green-ol \":  \"mdui-red-ol mdui-red\"} mdui-button-outlined",
                                "locked": false,
                                "min": "",
                                "max": ""
                              "style": {
                                "left": "calc(100% - 110px)",
                                "top": "16px",
                                "width": "32px",
                                "height": "36px",
                                "cursor": "",
                                "z-index": "0"
                            "e00013": {
                              "tpl": "tplValueFloatBar",
                              "data": {
                                "oid": "hm-rpc.0.NEQ1802941.0.RSSI_PEER",
                                "g_fixed": true,
                                "g_signals": false,
                                "min": "300",
                                "max": "0",
                                "orientation": "vertical",
                                "color": "{v:hm-rpc.0.PEQ1315641.0.RSSI_PEER;v < 30 ? \"red\" :: \"green\"}",
                                "reverse": true,
                                "class": "mdui-v-bargraph mdui-segment-10 ",
                                "border": "",
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0
                              "style": {
                                "left": "calc(100% - 71px)",
                                "top": "16px",
                                "width": "10px",
                                "height": "36px",
                                "z-index": "0"
                            "e00014": {
                              "tpl": "tplHtml",
                              "data": {
                                "g_fixed": true,
                                "g_signals": false,
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0,
                                "html": "Ventilstellung Küche Rechts",
                                "class": "mdui-label mdui-{0_userdata.0.mdui.vis.card_title_color}"
                              "style": {
                                "left": "16px",
                                "top": "212px",
                                "width": "300px",
                                "height": "25px"
                            "e00015": {
                              "tpl": "tplHtml",
                              "data": {
                                "g_fixed": true,
                                "g_signals": false,
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0,
                                "html": "Ventilstellung Küche Links",
                              "style": {
                                "left": "16px",
                                "top": "184px",
                                "width": "300px",
                                "height": "25px"
                            "e00016": {
                              "data": {
                                "oid": "hm-rpc.0.NEQ1411734.4.VALVE_STATE",
                                "g_fixed": true,
                                "g_signals": false,
                                "is_comma": "true",
                                "factor": "1",
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0,
                                "class": "mdui-value mdui-center-h",
                                "html_append_singular": " %",
                                "html_prepend": " "
                              "style": {
                                "left": "calc(85% - 40px)",
                                "top": "212px",
                                "width": "80px",
                                "text-align": "",
                                "height": "20px",
                                "z-index": "2",
                                "font-size": ""
                            "e00017": {
                              "data": {
                                "oid": "hm-rpc.0.NEQ1411673.4.VALVE_STATE",
                                "g_fixed": true,
                                "g_signals": false,
                                "is_comma": "true",
                                "factor": "1",
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0,
                                "html_prepend": ""
                              "style": {
                                "top": "184px",
                                "width": "80px",
                                "text-align": "",
                                "height": "20px",
                                "z-index": "2",
                                "font-size": ""
                            "e00018": {
                              "tpl": "tplHtml",
                              "data": {
                                "g_fixed": true,
                                "g_signals": false,
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0,
                                "html": "Heizungsmodus",
                              "style": {
                                "left": "16px",
                                "top": "156px",
                                "width": "300px",
                                "height": "25px"
                            "e00019": {
                              "tpl": "tplValueString",
                              "data": {
                                "oid": "heatingcontrol.0.Rooms.EG_Küche.State",
                                "g_fixed": true,
                                "g_signals": false,
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0,
                                "html_prepend": "",
                              "style": {
                                "top": "156px",
                                "width": "80px",
                                "height": "20px"
                            "e00020": {
                              "tpl": "tplHtml",
                              "data": {
                                "g_fixed": true,
                                "g_signals": false,
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0,
                                "html": "{heatingcontrol.0.Rooms.EG_Küche.StatusLog}",
                                "class": "mdui-list mdui-divided"
                              "style": {
                                "left": "118px",
                                "top": "268px",
                                "width": "calc(100% - 32px)",
                                "height": "110px",
                                "color": "white",
                                "font-size": "small"
                            "e00021": {
                              "tpl": "tplHtml",
                              "data": {
                                "g_fixed": true,
                                "g_signals": false,
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0,
                                "html": "Status Log:",
                              "style": {
                                "left": "16px",
                                "top": "268px",
                                "width": "300px",
                                "height": "25px"
                            "e00022": {
                              "data": {
                                "oid": "heatingcontrol.0.Rooms.EG_Küche.ResetManual",
                                "g_fixed": true,
                                "g_css_border": true,
                                "g_signals": false,
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0,
                                "html_false": "<img src='/icons-mfd-png/time_automatic.png' width=\"36\" height=\"36\"</i>",
                                "html_true": "<img src='/icons-mfd-png/time_automatic.png' width=\"36\" height=\"36\"</i>",
                                "class": "mdui-button-outlined {val:heatingcontrol.0.Rooms.EG_Küche.State;val==\"auto\"?'mdui-green-glow':''} ",
                                "html_append": ""
                              "style": {
                                "left": "calc(50% - 18px)",
                                "top": "16px",
                                "width": "36px",
                                "height": "36px",
                                "z-index": "",
                                "transform": "",
                                "border-radius": "2em"
                            "e00023": {
                              "tpl": "tplValueLastchange",
                              "data": {
                                "g_fixed": true,
                                "g_signals": false,
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0,
                                "format_date": "DD.MM.YYYY hh:mm:ss",
                                "class": "mdui-subtitle",
                                "show_interval": true,
                                "html_prepend": ""
                              "style": {
                                "left": "16px",
                                "top": "40px",
                                "width": "300px",
                                "height": "18px",
                                "z-index": "2"
                            "e00024": {
                              "data": {
                                "oid": "heatingcontrol.0.Rooms.EG_Küche.WindowIsOpen",
                                "g_fixed": true,
                                "g_signals": false,
                                "lc-format": "",
                                "lc-bkg-color": "",
                                "lc-color": "",
                                "lc-zindex": 0,
                                "html_false": "<img src='/icons-mfd-png/fts_window_1w.png' width=\"36\" height=\"36\"</i>",
                                "html_true": "<img src='/icons-mfd-png/fts_window_1w_open.png' width=\"36\" height=\"36\"</i>",
                                "class": "mdui-button-outlined {val:heatingcontrol.0.Rooms.EG_Küche.WindowIsOpen;val==\"false\"?'mdui-green mdui-green-glow':'mdui-red-glow mdui-red'}",
                                "locked": false,
                                "min": "",
                                "max": "",
                                "html_append": ""
                              "style": {
                                "left": "calc(100% - 150px)",
                                "top": "16px",
                                "width": "36px",
                                "height": "36px",
                                "cursor": "",
                                "z-index": "0"
                          "name": "_cardTest",
                          "filterList": []
                        ChaotC Rene_HMR 2 Antworten Letzte Antwort
                          @Chaot
                          Hier die View.
                            "settings": {
                              "style": {
                              "theme": "redmond",
                              "sizex": "",
                              "sizey": "",
                              "gridSize": "8",
                              "snapType": 2
                            "widgets": {
                              "e00001": {
                                "tpl": "tplHtml",
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                "style": {
                                  "top": "16px",
                                  "width": "40px",
                                  "height": "40px"
                              "e00002": {
                                "tpl": "tplHtml",
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "html": "Küche",
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0
                                "style": {
                                  "left": "16px",
                                  "top": "16px",
                                  "width": "auto",
                                  "height": "auto",
                                  "z-index": 1
                              "e00003": {
                                "tpl": "tplHtml",
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                "style": {
                                  "top": "16px",
                                  "width": "40px",
                                  "height": "40px"
                              "e00004": {
                                "data": {
                                  "step": "-0.5",
                                  "minmax": "17",
                                  "text": "",
                                  "locked": false,
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                "style": {
                                  "top": "84px",
                                  "width": "46px",
                                  "height": "46px",
                                  "z-index": 5,
                                  "border-radius": ""
                                "widgetSet": "jqui"
                              "e00005": {
                                "data": {
                                  "step": "+0.5",
                                  "minmax": "24",
                                  "text": "",
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                "style": {
                                  "top": "84px",
                                  "width": "46px",
                                  "height": "46px",
                                  "z-index": 5,
                                "widgetSet": "jqui"
                              "e00006": {
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "is_comma": "true",
                                  "factor": "1",
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                  "html_prepend": ""
                                "style": {
                                  "top": "128px",
                                  "width": "60px",
                                  "height": "25px",
                              "e00007": {
                                "tpl": "tplHtml",
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                "style": {
                                  "top": "128px",
                                  "width": "90px",
                                  "height": "25px"
                              "e00008": {
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "is_comma": "true",
                                  "factor": "1",
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                  "html_prepend": ""
                                "style": {
                                  "top": "72px",
                                  "width": "60px",
                                  "height": "25px",
                              "e00009": {
                                "tpl": "tplHtml",
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                "style": {
                                  "top": "72px",
                                  "width": "90px",
                                  "height": "25px"
                              "e00010": {
                                "tpl": "tplHtml",
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                "style": {
                                  "top": "100px",
                                  "width": "90px",
                                  "height": "25px"
                              "e00011": {
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "is_comma": "true",
                                  "factor": "1",
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                  "html_prepend": ""
                                "style": {
                                  "top": "100px",
                                  "width": "60px",
                                  "height": "25px",
                              "e00012": {
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                  "locked": false,
                                  "min": "",
                                  "max": ""
                                "style": {
                                  "top": "16px",
                                  "width": "32px",
                                  "height": "36px",
                                  "cursor": "",
                                  "z-index": "0"
                              "e00013": {
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "min": "300",
                                  "max": "0",
                                  "reverse": true,
                                  "border": "",
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0
                                "style": {
                                  "top": "16px",
                                  "width": "10px",
                                  "height": "36px",
                                  "z-index": "0"
                              "e00014": {
                                "tpl": "tplHtml",
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                "style": {
                                  "left": "16px",
                                  "top": "212px",
                                  "width": "300px",
                                  "height": "25px"
                              "e00015": {
                                "tpl": "tplHtml",
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                "style": {
                                  "left": "16px",
                                  "top": "184px",
                                  "width": "300px",
                                  "height": "25px"
                              "e00016": {
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "is_comma": "true",
                                  "factor": "1",
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                  "html_prepend": " "
                                "style": {
                                  "top": "212px",
                                  "width": "80px",
                                  "text-align": "",
                                  "height": "20px",
                                  "z-index": "2",
                                  "font-size": ""
                              "e00017": {
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "is_comma": "true",
                                  "factor": "1",
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                  "html_prepend": ""
                                "style": {
                                  "top": "184px",
                                  "width": "80px",
                                  "text-align": "",
                                  "height": "20px",
                                  "z-index": "2",
                                  "font-size": ""
                              "e00018": {
                                "tpl": "tplHtml",
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                "style": {
                                  "left": "16px",
                                  "top": "156px",
                                  "width": "300px",
                                  "height": "25px"
                              "e00019": {
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                  "html_prepend": "",
                                "style": {
                                  "top": "156px",
                                  "width": "80px",
                                  "height": "20px"
                              "e00020": {
                                "tpl": "tplHtml",
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                "style": {
                                  "left": "118px",
                                  "top": "268px",
                                  "height": "110px",
                                  "color": "white",
                              "e00021": {
                                "tpl": "tplHtml",
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                "style": {
                                  "left": "16px",
                                  "top": "268px",
                                  "width": "300px",
                                  "height": "25px"
                              "e00022": {
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                  "html_append": ""
                                "style": {
                                  "top": "16px",
                                  "width": "36px",
                                  "height": "36px",
                                  "z-index": "",
                                  "transform": "",
                              "e00023": {
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                  "html_prepend": ""
                                "style": {
                                  "left": "16px",
                                  "top": "40px",
                                  "width": "300px",
                                  "height": "18px",
                                  "z-index": "2"
                              "e00024": {
                                "data": {
                                  "g_fixed": true,
                                  "g_signals": false,
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                  "locked": false,
                                  "min": "",
                                  "max": "",
                                  "html_append": ""
                                "style": {
                                  "top": "16px",
                                  "width": "36px",
                                  "height": "36px",
                                  "cursor": "",
                                  "z-index": "0"
                            "filterList": []
                          ChaotC Offline
                          ChaotC Offline
                          Chaot
                          schrieb am zuletzt editiert von Chaot
                          #1742
                          @Dominik-F Danke. Noch eine Frage. Wie schreibst du den Status Log?
                          Oh, und du hast unter Vis.o/Handy und Vis.0/Heating control noch Bilder die ich auch benötigen würde.
                          Bei Handy liegt scheinbar + und - Symbol und bei Heating Control liegt scheinbar das Antennnesymbol für die Verbindung.
                            @Rene_HM
                            FI_84
                            #1743
                            @Dominik-F kannst das vielielleicht hier zur Verfügung stellen?
                            Gefällt mit sehr gut
                            • F FI_84
                              ChaotC Offline
                              ChaotC Offline
                              Chaot
                              #1744
                              @FI_84 Hat er doch. Direkt zwei Beiträge weiter oben.
                              • ChaotC Chaot
                                Dominik F.D Offline
                                Dominik F.D Offline
                                Dominik F.
                                #1745
                                @Chaot
                                Du kannst dir Icon set Google material design unter den Adaptern ziehen, da sind die Symbole drin. Weiß gar nicht warum ich das damals da rein gepackt hab :D
                                Hier sind dann noch die Symbole, hoffe ich hab die richtig hochgeladen:
                                ic_add_white_48dp.png ic_remove_white_48dp.png it_wifi.svg
                                Das Status Log ist aus der aktuellen Vis für Heatingcontrol V2, daher hab ich auch das Antennensymbol. Wenn du die V2 installiert hast, müsstes der Log bei dir auch funktionieren, wenn du den richtigen Raum einstellst.
                                  @Chaot
                                  ChaotC Offline
                                  ChaotC Offline
                                  Chaot
                                  #1746
                                  @Dominik-F Danke dir. Die V2 habe ich noch nicht installiert. Das werde ich unter der Woche in Angriff nehmen.
                                  Zumal ja scheinbar auch die Vis geändert werden muss will ich mir das erst in aller Ruhe anschauen.
                                  • ChaotC Chaot
                                    Dominik F.D Offline
                                    Dominik F.D Offline
                                    Dominik F.
                                    #1747
                                    @Chaot
                                    Ich hab sie heute installiert, funktioniert wunderbar.
                                    Du kannst wenn du z.B. das Plus Symbol nicht hochladen möchtest, anstatt unter Quelle dann unter Text <i class="material-icons">add</i> einfügen, dann hast du ein ähnliches Symbol.
                                    Für das Minus stellst du dann <i class="material-icons">remove</i> ein
                                    Die Symbole hast du automatisch, wenn du das CSS von Uhula nutzt bzw. Pittinis Vis
                                    • G Online
                                      G Online
                                      grizzlyco
                                      #1748
                                      ich habe leider ein großes Problem mit der 2.0
                                      Ich war etwas voreilig mit dem Update und habe auf 2.0 geupdatet.
                                      Anschließend lief nichts mehr.
                                      Ich dachte es liegt an den änderungen der Profile (0 -> 1, usw. ) Deswegen habe ich alle Profile neu eingetragen ( 6 Räume / 2 Profile / 4 Perioden ). Hat leider nicht geholfen.
                                      Der Adapter schaltet nicht mehr.
                                      Als ich mein Backup einspielen wollte musste ich feststellen, dass dieses nicht OK ist.
                                      Was habe ich falsch gemacht? Kann mir bitte jemand helfen.
                                      Log Error:
                                      heatingcontrol.0 2021-01-10 00:59:09.138 error (6326) exception in StartStatemachine [Error: The id is empty! Please provide a valid id.]
                                      heatingcontrol.0.Rooms.Badezimmer.ActiveTimeSlot =-1
                                      heatingcontrol.0.Rooms.Badezimmer.CurrentTarget=-99°C
                                      heatingcontrol.0.Rooms.Badezimmer.CurrentTimePeriod=-1
                                      state=starting
                                      Was kann ich machen?
                                      Ich würde auch wieder auf die alte Version gehen, aber dann müsste ich nochmal alle Profile anpassen
                                      • G grizzlyco
                                        Log Error:
                                        state=starting
                                        Rene_HMR Offline
                                        Rene_HMR Offline
                                        Rene_HM
                                        #1749
                                        @grizzlyco sagte in Test Adapter HeatingControl v2.0.x:
                                        Da diese Meldung nur ganz allgemein ist (und auch nicht aus dem Adapter selbst kommt) benötige ich weitere Infos. Du musst den Adapter auf debug stellen und dann die logs vor dieser exception posten.
                                        Irgendwo hast du eine ObjectID nicht eingestellt.
                                        G 1 Antwort Letzte Antwort
                                          @Chaot
                                          Hier die View.
                                            "settings": {
                                              "style": {
                                              "theme": "redmond",
                                              "sizex": "",
                                              "sizey": "",
                                              "gridSize": "8",
                                              "snapType": 2
                                            "widgets": {
                                              "e00001": {
                                                "tpl": "tplHtml",
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                "style": {
                                                  "top": "16px",
                                                  "width": "40px",
                                                  "height": "40px"
                                              "e00002": {
                                                "tpl": "tplHtml",
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "html": "Küche",
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0
                                                "style": {
                                                  "left": "16px",
                                                  "top": "16px",
                                                  "width": "auto",
                                                  "height": "auto",
                                                  "z-index": 1
                                              "e00003": {
                                                "tpl": "tplHtml",
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                "style": {
                                                  "top": "16px",
                                                  "width": "40px",
                                                  "height": "40px"
                                              "e00004": {
                                                "data": {
                                                  "step": "-0.5",
                                                  "minmax": "17",
                                                  "text": "",
                                                  "locked": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                "style": {
                                                  "top": "84px",
                                                  "width": "46px",
                                                  "height": "46px",
                                                  "z-index": 5,
                                                  "border-radius": ""
                                                "widgetSet": "jqui"
                                              "e00005": {
                                                "data": {
                                                  "step": "+0.5",
                                                  "minmax": "24",
                                                  "text": "",
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                "style": {
                                                  "top": "84px",
                                                  "width": "46px",
                                                  "height": "46px",
                                                  "z-index": 5,
                                                "widgetSet": "jqui"
                                              "e00006": {
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "is_comma": "true",
                                                  "factor": "1",
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                  "html_prepend": ""
                                                "style": {
                                                  "top": "128px",
                                                  "width": "60px",
                                                  "height": "25px",
                                              "e00007": {
                                                "tpl": "tplHtml",
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                "style": {
                                                  "top": "128px",
                                                  "width": "90px",
                                                  "height": "25px"
                                              "e00008": {
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "is_comma": "true",
                                                  "factor": "1",
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                  "html_prepend": ""
                                                "style": {
                                                  "top": "72px",
                                                  "width": "60px",
                                                  "height": "25px",
                                              "e00009": {
                                                "tpl": "tplHtml",
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                "style": {
                                                  "top": "72px",
                                                  "width": "90px",
                                                  "height": "25px"
                                              "e00010": {
                                                "tpl": "tplHtml",
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                "style": {
                                                  "top": "100px",
                                                  "width": "90px",
                                                  "height": "25px"
                                              "e00011": {
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "is_comma": "true",
                                                  "factor": "1",
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                  "html_prepend": ""
                                                "style": {
                                                  "top": "100px",
                                                  "width": "60px",
                                                  "height": "25px",
                                              "e00012": {
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                  "locked": false,
                                                  "min": "",
                                                  "max": ""
                                                "style": {
                                                  "top": "16px",
                                                  "width": "32px",
                                                  "height": "36px",
                                                  "cursor": "",
                                                  "z-index": "0"
                                              "e00013": {
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "min": "300",
                                                  "max": "0",
                                                  "reverse": true,
                                                  "border": "",
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0
                                                "style": {
                                                  "top": "16px",
                                                  "width": "10px",
                                                  "height": "36px",
                                                  "z-index": "0"
                                              "e00014": {
                                                "tpl": "tplHtml",
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                "style": {
                                                  "left": "16px",
                                                  "top": "212px",
                                                  "width": "300px",
                                                  "height": "25px"
                                              "e00015": {
                                                "tpl": "tplHtml",
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                "style": {
                                                  "left": "16px",
                                                  "top": "184px",
                                                  "width": "300px",
                                                  "height": "25px"
                                              "e00016": {
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "is_comma": "true",
                                                  "factor": "1",
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                  "html_prepend": " "
                                                "style": {
                                                  "top": "212px",
                                                  "width": "80px",
                                                  "text-align": "",
                                                  "height": "20px",
                                                  "z-index": "2",
                                                  "font-size": ""
                                              "e00017": {
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "is_comma": "true",
                                                  "factor": "1",
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                  "html_prepend": ""
                                                "style": {
                                                  "top": "184px",
                                                  "width": "80px",
                                                  "text-align": "",
                                                  "height": "20px",
                                                  "z-index": "2",
                                                  "font-size": ""
                                              "e00018": {
                                                "tpl": "tplHtml",
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                "style": {
                                                  "left": "16px",
                                                  "top": "156px",
                                                  "width": "300px",
                                                  "height": "25px"
                                              "e00019": {
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                  "html_prepend": "",
                                                "style": {
                                                  "top": "156px",
                                                  "width": "80px",
                                                  "height": "20px"
                                              "e00020": {
                                                "tpl": "tplHtml",
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                "style": {
                                                  "left": "118px",
                                                  "top": "268px",
                                                  "height": "110px",
                                                  "color": "white",
                                              "e00021": {
                                                "tpl": "tplHtml",
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                "style": {
                                                  "left": "16px",
                                                  "top": "268px",
                                                  "width": "300px",
                                                  "height": "25px"
                                              "e00022": {
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                  "html_append": ""
                                                "style": {
                                                  "top": "16px",
                                                  "width": "36px",
                                                  "height": "36px",
                                                  "z-index": "",
                                                  "transform": "",
                                              "e00023": {
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                  "html_prepend": ""
                                                "style": {
                                                  "left": "16px",
                                                  "top": "40px",
                                                  "width": "300px",
                                                  "height": "18px",
                                                  "z-index": "2"
                                              "e00024": {
                                                "data": {
                                                  "g_fixed": true,
                                                  "g_signals": false,
                                                  "lc-format": "",
                                                  "lc-bkg-color": "",
                                                  "lc-color": "",
                                                  "lc-zindex": 0,
                                                  "locked": false,
                                                  "min": "",
                                                  "max": "",
                                                  "html_append": ""
                                                "style": {
                                                  "top": "16px",
                                                  "width": "36px",
                                                  "height": "36px",
                                                  "cursor": "",
                                                  "z-index": "0"
                                            "filterList": []
                                          Rene_HMR Offline
                                          Rene_HMR Offline
                                          Rene_HM
                                          #1750
                                          @Dominik-F Ich schau mal, ob ich diese view als dritte Kopiervorlage in die vis einbauen kann...
