  4. String in Tabelle darstellen
35 Beiträge 4 Kommentatoren 8.1k Aufrufe
    Brati
    @ruhr70:
    So würde die Tabelle dann im JSON-Widget aussehen:
    KDienst ist einmal bei Kind 1 drin, bei Kind 2 nicht und dann wieder unter Optionen.
    Welcher Punkt ist denn gemeint? `
    Das sieht schon mal sehr genial aus. KDienst ist unter Optionen gemeint und hatte folgende Bedeutung
    (wer bringt die Kinder weg, also "KinderDienst")
    0 = M(uddi)
    1 = V(addi)
    2 = n(iemand)
    Bei Kind1 ist noch ein Fehler aus der Findungsphase :).
    Danke.
    • ruhr70R Offline
      ruhr70R Offline
      ruhr70
      @Brati:
      0 = M(uddi)
      1 = V(addi)
      2 = n(iemand)
      Danke. `
      Anbei Deine umgebaute Tabelle:
      Und das Skript dazu:
      ! var myJson = {"1":{"Kind1":{"wecken":true,"nachricht":0,"stunde":"6","minute":"25","KDienst":0},"Kind2":{"wecken":true,"nachricht":"","stunde":"6","minute":"25"},"Optionen":{"KDienst":1,"Licht":"25","Option1":"","Option2":"","Option3":""}},"2":{"Kind1":{"wecken":true,"nachricht":1,"stunde":"6","minute":"25","KDienst":0},"Kind2":{"wecken":true,"nachricht":"","stunde":"6","minute":"25"},"Optionen":{"KDienst":1,"Licht":"25","Option1":"","Option2":"","Option3":""}},"3":{"Kind1":{"wecken":true,"nachricht":1,"stunde":"6","minute":"30","KDienst":0},"Kind2":{"wecken":true,"nachricht":"","stunde":"6","minute":"30"},"Optionen":{"KDienst":0,"Licht":"25","Option1":"","Option2":"","Option3":""}},"4":{"Kind1":{"wecken":true,"nachricht":0,"stunde":"6","minute":"25","KDienst":0},"Kind2":{"wecken":true,"nachricht":"","stunde":"6","minute":"25"},"Optionen":{"KDienst":1,"Licht":"25","Option1":"","Option2":"","Option3":""}},"5":{"Kind1":{"wecken":false,"nachricht":0,"stunde":"9","minute":"30"},"Kind2":{"wecken":false,"nachricht":"","stunde":"9","minute":"30"},"Optionen":{"KDienst":2,"Licht":"25","Option1":"","Option2":"","Option3":""}},"6":{"Kind1":{"wecken":false,"nachricht":2,"stunde":"9","minute":"30"},"Kind2":{"wecken":false,"nachricht":"","stunde":"9","minute":"30"},"Optionen":{"KDienst":2,"Licht":"25","Option1":"","Option2":"","Option3":""}},"7":{"Kind1":{"wecken":true,"nachricht":2,"stunde":"6","minute":"30"},"Kind2":{"wecken":true,"nachricht":"","stunde":"6","minute":"30"},"Optionen":{"KDienst":0,"Licht":"25","Option1":"","Option2":"","Option3":""}}}; ! var idKdienst = "Kinderdienst"; ! createState(idKdienst, "", { name: 'Kinderdienst JSON für VIS Widget', desc: 'Kinderdienst JSON für VIS Widget', type: 'string', role: 'value', unit: '' }); ! function setX (aktivBool) { return (aktivBool) ? "x" : ""; } ! function setKDienst (str) { var kDienst = {"0":"Muddi","1":"Vaddi","2":"---"}; return kDienst[str]; } ! function fillStr(n, str) { // liefere Anzahl n nbsp in utf-8, wenn str nicht angegeben oder n-mal str var fill = ""; for (var i = 0; i < n; ++i) { fill += ((!str) ? " " : str); //   als utf-8 Code (Mac: alt+Leerzeichen) } return fill; } ! function fillTime(stundeStr,minuteStr) { // baut den Zeitstring und füllt Stunde und Minute auf zweistellig auf return fillStr(2 - stundeStr.length,"0") + stundeStr + ":" + fillStr(2 - minuteStr.length,"0") + minuteStr; } ! function buildJson() { var tabelle = []; var tempJson ={}; var woTag = ["Mo","Di","Mi","Do","Fr","Sa","So"]; for (var i = 1; i <= 7; i++) { tempJson = myJson[(i).toString()]; tabelle.push({ "Tag" : woTag[i-1], "Kind1" : fillTime(tempJson.Kind1.stunde,tempJson.Kind1.minute), "aktiv1" : setX(tempJson.Kind1.wecken), "Kind2" : fillTime(tempJson.Kind2.stunde,tempJson.Kind2.minute), "aktiv2" : setX(tempJson.Kind2.wecken), "KDienst" : setKDienst(tempJson.Optionen.KDienst) }); } return tabelle; } ! function main () { log(JSON.stringify(buildJson())); setState("javascript." + instance + "." + idKdienst,JSON.stringify(buildJson())); } ! // Beim Skriptstart JSON-Tabelle für VIS Widget erstellen setTimeout(main,2000); !
        Brati
        @Ruhr70
        Tausend Dank, so sieht es aus:
        Brati
        • ruhr70R Offline
          ruhr70R Offline
          ruhr70
          @Barti: super! Sieht gut aus. Danke für die Rückmeldung.
          Ich hatte mir schon gedacht, dass die Tage mit 09:30 Samstag und Sonntag sind.
          Ich konnte dem JSON diese Logik allerdings nicht entlocken ;-)
          Denkfeher mit 1-7 = Mo-So oder war im Skript ein Fehler?
            Brati
            Na weil ich ja heute immer für morgen einlese ist 7= Montag und 1= Dienstag. Aber ein bisschen muss ich ja auch noch denken, hab eine Hilfsvariable eingebaut ;). Ich werde in einer ruhigen Minute auch mal versuchen zu verstehen, wie das mit den Json Tabellen funktioniert, sieht eigentlich logisch aus.
            Gesendet von iPad mit Tapatalk
              dtp
              So,
              habe mich zwischenzeitlich etwas versucht und bin auch weiter gekommen. Allerdings noch nicht so richtig. Hier der status quo:
              `// Beispiel-Format Timer: "1:An:05:00 Aus:12:00 2:An:15:00 Aus:21:00 3:An:-- Aus:-- 4:An:-- Aus:--"
              var list = ['TimerMoHeizen','TimerDiHeizen','TimerMiHeizen','TimerDoHeizen','TimerFrHeizen','TimerSaHeizen','TimerSoHeizen'];
              var idTable = "vis.VitotronicTimer"; // Pfad des Datenpunkts
              // Datenpunktanlegen
              createState(idTable, "", {
              desc: 'Vitotronic Timer-Tabelle als JSON-Objekt für vis Widget',
              type: 'string',
              unit: '',
              role: 'value'
              function strToJson(str){
              str = str.split(/\d:An:| Aus:/);
              var table = [];
              for(i=1; i<=str.length-1; i=i+2){
              table.push({
              "Nr" : Math.floor((i+2)/2),
              "An" : str[i],
              "Aus": str[i+1],
              return JSON.stringify(table);
              function main(list){
              str = '';
              for(var i=0; i<list.length; 20/i++)/str="str+getState("javascript."+instance+".Vitotronic."+list[i]).val;" setstate(idtable,strtojson(str));/}/setinterval(function(){/main(list);/},/*/1000);<e=""></list.length;>`
              ! Und hier die zugehörige Tabelle im Widget:
              ! Fragen:
              ! 1. Wie erreiche ich eine Modulo-4-Zählweise der Zeilen?
              ! 2. Wie binde ich jetzt noch die übrigen Timer-Spalten ein?
              ! 3. Kann ich auch über mehrere Zeilen bzw. Spalten verbundene Zeilen bzw. Spalten erstellen für die Wochentage und die Timerbeschreibungen?
              ! Gruß,
              ! Thorsten[/i][/i]
              • ruhr70R Offline
                ruhr70R Offline
                ruhr70
                @dtp:
                So,
                habe mich zwischenzeitlich etwas versucht und bin auch weiter gekommen. Allerdings noch nicht so richtig. Hier der status quo: `
                Mal eine Alternative für Dich:
                Code:
                `var list4 = ['TimerMoHeizen','TimerDiHeizen','TimerMiHeizen','TimerDoHeizen','TimerFrHeizen','TimerSaHeizen','TimerSoHeizen',
                'TimerMoWW','TimerDiWW','TimerMiWW','TimerDoWW','TimerFrWW','TimerSaWW','TimerSoWW',
                'TimerMoPumpeZirku','TimerDiPumpeZirku','TimerMiPumpeZirku','TimerDoPumpeZirku','TimerFrPumpeZirku','TimerSaPumpeZirku','TimerSoPumpeZirku'];
                ! var pfadStr = "javascript." + instance + ".Vitotronic."; // Pfad der String-Datenpunkte aus Liste 4
                ! var idTabelle = "vis.VitotronicTimer"; // Pfad des Datenpunkts für das VIS JSON
                ! // Datenpunktanlegen
                createState(idTabelle, "", {
                desc: 'Vitotronic Timer-Tabelle als JSON-Objekt',
                type: 'string',
                unit: '',
                role: 'value'
                ! function strToJson(str,tag){
                str = str.split(/\d:An:| Aus:|#/);
                var tabelle = [];
                var nr = 1;
                var woTag = ["Montag","Dienstag","Mittwoch","Donnerstag","Freitag","Samstag","Sonntag"];
                for(i=0; i < 7; i=i+2){
                    tabelle.push({
                        "Wochentag" : ((nr == 1) ? (woTag[tag]) : ""),
                        "Nr"        : nr++,
                        "An_Heizen" : str[i+0].replace(" ",""),
                        "Aus_Heizen": str[i+1].replace(" ",""),
                        "An_WW"     : str[i+8].replace(" ",""),
                        "Aus_WW"    : str[i+9].replace(" ",""),
                        "An_Zirku"  : str[i+16].replace(" ",""),
                        "Aus_Zirku" : str[i+17].replace(" ",""),
                 return tabelle;
                ! function buildBigStr (i) {
                var str = getState(pfadStr + list4[i]).val.replace("1:An:","") + "#"
                + getState(pfadStr + list4[i+7]).val.replace("1:An:","") + "#"
                + getState(pfadStr + list4[i+14]).val.replace("1:An:","");
                return str;
                ! function zeilenJson() {
                tabelle = [];
                for (j = 0; j < 7; j++) {
                tabelle = tabelle.concat(strToJson(buildBigStr(j),j));
                return tabelle;
                ! function main(){
                var str = JSON.stringify(zeilenJson());
                log("Ergebnis: " + str);
                setState(idTabelle,str);
                ! setTimeout(main, 2000); ! Widget: ! >! ~~[spoiler]~~[code][{"tpl":"tplTableBody","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","static_value":"[{"Title": "first", "Value": 1, "_Description": "Value1"}, {"Title": "second", "Value": 2, "_Description": "Value2"}]","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"table_oid":"javascript.0.vis.VitotronicTimer","max_rows":"","colCount":"8","colWidth1":"120px","colWidth3":"15%","colWidth4":"15%","colWidth5":"15%","colWidth6":"15%","colWidth7":"15%","colWidth8":"15%","colWidth2":"40px","colName3":"Heizen
                an","colName4":"Heizen
                aus","colName5":"Warmwasser
                an","colName6":"Warmwasser
                aus","colName7":"Zirkulation
                an","colName8":"Zirkulation
                aus"},"style":{"left":"103px","top":"37px","cursor":"","width":"926px","height":"660px","text-align":"center"},"widgetSet":"basic"}][/code]`[/spoiler]
                ! Vielleicht hilft das ja.
                ! Ich schau mir mal Deinen Code und Deine fragen an.
                ! [EDIT]:
                ! Müsste eigentlich ohne Anpassungen mit Deinen Datenpunkten funktionieren.[/i]
                • ruhr70R Offline
                  ruhr70R Offline
                  ruhr70
                  Den Code noch um die Möglichkeit erweitert, die Wochentage auszuwählen, die ausgegeben werden sollen.
                  Hier im Beispiel von 1 (Dienstag) bis 3 (Donnerstag)
                  var vonTag = 1; // Standard = 0 (Montag)
                  var bisTag = 3; // Standard = 6 (Sonntag)
                  Skript:
                  `// Welche Tage sollen ausgegeben werden ( 0=Montag bis 6=Sonntag)
                  type: 'string',
                  unit: '',
                  role: 'value'
                  ! var list4 = ['TimerMoHeizen','TimerDiHeizen','TimerMiHeizen','TimerDoHeizen','TimerFrHeizen','TimerSaHeizen','TimerSoHeizen',
                  ! function strToJson(str,wotag){
                  var tabelle = [];
                  var nr = 1;
                  for(i = 0; i < 7; i = i + 2){
                      tabelle.push({
                          "Wochentag" : ((nr == 1) ? (woTag[wotag]) : ""),
                          "Nr"        : nr++,
                   return tabelle;
                  return str;
                  ! function zeilenJson(von,bis) {
                  tabelle = [];
                  for (j = von; j < bis + 1; j++) {
                  tabelle = tabelle.concat(strToJson(buildBigStr(j),j,von,bis));
                  return tabelle;
                  ! function main(){
                  var str = JSON.stringify(zeilenJson(vonTag,bisTag));
                  ! setTimeout(main, 2000);! ![327_victronic_oder_so_2.jpg](/assets/uploads/files/327_victronic_oder_so_2.jpg) ! [EDIT: 05.11.2016, 09:45] ! ups, ... gerade noch einen Fehler entdeckt bei der "von bis" Funktion. ! Die Zeile:[code] tabelle = tabelle.concat(strToJson(buildBigStr(j),j,2,4));
                  [/code]! musste noch angepasst werden. ! Richtig ist: ![code] tabelle = tabelle.concat(strToJson(buildBigStr(j),j,von,bis));
                  [/code]`
                  ! Ist oben im Code korrigiert.[/i]
                  • ruhr70R Offline
                    ruhr70R Offline
                    ruhr70
                    Und noch eine Variante mit einer Leerzeile zwischen den Tagen.
                    Skript:
                    var vonTag = 0; // Standard = 0 (Montag)
                    var bisTag = 6; // Standard = 6 (Sonntag)
                    var leerzBool = true; // Leerzeile nach den Datensätzen
                    type: 'string',
                    unit: '',
                    role: 'value'
                    var tabelle = [];
                    var nr = 1;
                        tabelle.push({
                            "Nr"        : nr++,
                     return tabelle;
                    return str;
                    tabelle = [];
                    if (leerzBool && j < bis) tabelle = tabelle.concat(leerzeile());
                    return tabelle;
                    ! function leerzeile() {
                    return [{
                    "Wochentag" : " ",
                    "Nr" : "",
                    "An_Heizen" : "",
                    "Aus_Heizen": "",
                    "An_WW" : "",
                    "Aus_WW" : "",
                    "An_Zirku" : "",
                    "Aus_Zirku" : ""
                    ! function main(){
                    ! setTimeout(main, 2000);`
                    ! 327_victronic_oder_so_4.jpg [/i]
                      dtp
                      Hi ruhr70,
                      ganz, ganz lieben Dank für Deinen Support. Das hat mir wirklich toll geholfen. Hier mal meine aktuelle Umsetzung.
                      `// Welche Tage sollen ausgegeben werden (0=Montag bis 6=Sonntag)
                      var startDay = 0; // Standard = 0 (Montag)
                      var endDay = 6; // Standard = 6 (Sonntag)
                      ! var path = "javascript."+instance+".Vitotronic."; // Pfad der String-Datenpunkte aus Liste 4
                      ! var idTable = "vis.VitotronicTimer"; // Pfad des Datenpunkts für das VIS JSON
                      type: 'string',
                      unit: '',
                      role: 'value'
                      ! var list = ['TimerMoHeizen','TimerDiHeizen','TimerMiHeizen','TimerDoHeizen','TimerFrHeizen','TimerSaHeizen','TimerSoHeizen',
                      ! function strToJson(str,dayIndex){
                      var table = [];
                      var no = 1;
                      //var weekDay = ["Montag","Dienstag","Mittwoch","Donnerstag","Freitag","Samstag","Sonntag"];
                      for(i=0; i<7; i=i+2){
                      table.push({
                      //"Wochentag" : ((no == 1) ? (weekDay[dayIndex]) : ""),
                      "Nr" : no++,
                      "Heizen_an" : str[i+0].replace(" ",""),
                      "Heizen_aus": str[i+1].replace(" ",""),
                      "WW_an" : str[i+8].replace(" ",""),
                      "WW_aus" : str[i+9].replace(" ",""),
                      "Pumpe_an" : str[i+16].replace(" ",""),
                      "Pumpe_aus" : str[i+17].replace(" ",""),
                      return table;
                      ! function buildBigStr(i){
                      var str = getState(path+list[i]).val.replace("1:An:","")+"#"
                      +getState(path+list[i+7]).val.replace("1:An:","")+"#"
                      +getState(path+list[i+14]).val.replace("1:An:","");
                      return str;
                      ! function rowsJson(start,end) {
                      table = [];
                      for (j=start; j`
                      ! Und so sieht der zugehörigen View aus:
                      ! Hab das jetzt einfach mit ein paar HTML-Views ergänzt, um das Erscheinungsbild zu erhalten, was ich möchte. Eine größere Tabelle mit weißen Zwischenzeilen ist bei mir wegen der Auflösung meines Wandtablets von 1024 x 768 Pixel leider nicht möglich. Aber so geht's auch ganz gut, wie ich finde.
                      ! Eine Frage noch. Gibt es ggf. eine einfachere Möglichkeit zum Triggern des Skripts, als die, die ich gewählt habe? Ich möchte, dass das Skript nur aufgerufen wird, wenn sich einer der Timer-Datenpunkte ändert.
                      ! Nochmals Danke für Deine Unterstützung und liebe Grüße,
                      ! Thorsten[/i]
                        Brati
                        @dtp
                        Du kannst doch mit on auf die Änderung deines Datenpunkt reagieren und legst da das ganze Script rein. Dann wird das Json immer bei Änderungen neu erstellt.
                        Grüße Brati
                        von unterwegs gesendet.
                          dtp
                          Hi Brati,
                          hab ich ja getan. Sind nur insgesamt 21 Datenpunkte, die ich abfrage. Daher sieht's ein bisschen "wüst" aus.
                          Gruß,
                          Thorsten
                          • ruhr70R Offline
                            ruhr70R Offline
                            ruhr70
                            @dtp:
                            Eine Frage noch. Gibt es ggf. eine einfachere Möglichkeit zum Triggern des Skripts, als die, die ich gewählt habe? Ich möchte, dass das Skript nur aufgerufen wird, wenn sich einer der Timer-Datenpunkte ändert. `
                            Das sollte ausreichen:
                            var x = new RegExp("\javascript\." +instance+ "\.Vitotronic\.Timer.+");
                            on({id:x,change:'ne',chance:'ne'}, function (obj) {
                              log("##########: " + obj.state.val);
                            Statt dem Log dann die Funktion, die Du aufrufen willst (main).
                              Brati
                              Cool, hab ich auch wieder was gelernt und kann die vielen RegEx in meinem Editor Script deutlich vereinfachen.
                              • ruhr70R Offline
                                ruhr70R Offline
                                ruhr70
                                @ruhr70:
                                @dtp:
                                Statt dem Log dann die Funktion, die Du aufrufen willst (main). `
                                Hi Thorsten (dtp),
                                hattest Du die gekürzte Variante mal ausprobiert?
                                Michael
                                  Brati
                                  @Ruhr70
                                  Ich habe es gerade mal getestet, es funktioniert leider nicht:
                                  var x = new RegExp("\javascript\.0\.Wecker\.Editor.+");
                                  so läuft es gerade
                                  on(/^javascript.0.Timer.Wecker.Editor.KDienst|javascript.0.Timer.Wecker.Editor.Kind1_Stunde|javascript.0.Timer.Wecker.Editor.Kind1_Minute|javascript.0.Timer.Wecker.Editor.Kind1_Aktiv|javascript.0.Timer.Wecker.Editor.Kind2_Stunde|javascript.0.Timer.Wecker.Editor.Kind2_Minute|javascript.0.Timer.Wecker.Editor.Kind2_Aktiv/, function (obj) {
                                  Brati
                                    Brati
                                    @Ruhr70
                                    Bin selber doof :(. Der Pfad war nicht richtig, jetzt läuft es
                                    var x = new RegExp("\javascript." +instance+ ".*Timer*.Wecker.Editor.+");
                                    Sorry und Danke
                                    Brati
                                      dtp
                                      Sorry,
                                      war die letzten Tage etwas verhindert. Skript funktioniert wunderbar. Vielen Dank.
                                      Gruß,
                                      Thorsten
                                        dtp
                                        So sieht's aktuell bei mir aus:
                                        Hier das zugehörige Javaskript:
                                        `var path = "javascript."+instance+".Vitotronic."; // Pfad der String-Datenpunkte aus "list"
                                        var idTable = "vis.getVitoTimer"; // Pfad des Datenpunkts für das vis-Json
                                        desc: 'Vitotronic Timer-Tabelle als Json-Objekt',
                                        type: 'string',
                                        unit: '',
                                        role: 'value'
                                        var table = [];
                                        var no = 1;
                                        table.push({
                                        "Nr" : no++,
                                        return table;
                                        return str;
                                        function rowsJson() {
                                        table = [];
                                        for (j=0; j<7; j++) {
                                        table = table.concat(strToJson(buildBigStr(j),j,0,6));
                                        return table;
                                        function main(){
                                        var str = JSON.stringify(rowsJson());
                                        //log("Output: "+str);
                                        setState(idTable, str);
                                        var trigger = new RegExp(path+"Timer.+");
                                        on({id:trigger, change:'ne', chance:'ne'}, function(){
                                        main();
                                        ! Und hier das exportierte Json-Tabellen-Widget (basic - Table):
                                        ! >! [spoiler]~~[code]~~[{"tpl":"tplJquiDialog","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"html_dialog":"","title":"Timer-Einstellung","dialog_width":"600px","dialog_height":"300px","dialog_top":"150px","dialog_left":"200px"},"style":{"left":"124px","top":"0px","background":"transparent","width":"898px","height":"692px","z-index":"2","border-width":"1px","border-style":"none","border-radius":"0px"},"widgetSet":"jqui"},{"tpl":"tplTableBody","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"static_value":"[{\"Title\": \"first\", \"Value\": 1, \"_Description\": \"Value1\"}, {\"Title\": \"second\", \"Value\": 2, \"_Description\": \"Value2\"}]","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"table_oid":"javascript.0.vis.getVitoTimer","detailed_wid":"","colCount":"7","new_on_top":false,"g_header_§0":true,"g_header_§1":true,"g_header_§2":true,"hide_header":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","colName1":"Nr.","colWidth1":"50px","colWidth2":"130px","colWidth3":"130px","colWidth4":"130px","colWidth5":"130px","colWidth6":"130px","colWidth7":"130px","colWidth8":"100px","colName2":"Heizen an","colName3":"Heizen aus","colName4":"Warmwasser an","colName5":"Warmwasser aus","colName6":"Zirku-Pumpe an","colName7":"Zirku-Pumpe aus","colName8":"Zirku-Pumpe aus","max_rows":"28","show_scroll":false},"style":{"left":"124px","top":"48px","width":"898px","height":"646px","font-size":"","text-align":"center","z-index":"1","position":"","line-height":"19px","font-variant":""},"widgetSet":"basic"}][/code][/spoiler]
                                        ! Aufrufen tue ich die Seite über meinen Heizungs-View durch klick auf das Widget "jqui - navigation - Icon", das einen Link auf den Timer-View enthält und das mit transparentem Hintergrund über "Aktuelle Betriebsart Heizkreis" liegt.
                                        ! Ein entsprechendes Widget auf der obigen Timer-Seite führt dann wieder zurück zum Heizungs-View.[/i]
                                          dtp
                                          Als nächstes würde ich nun noch gerne die Timer-Werte über den View einstellen können. Dazu habe ich mir das Widget "jqui - HTML - Dialog" über die gesamte Tabelle mit transparentem Hintergrund gelegt. Wenn man es anklickt, öffnet sich ein Dialog-Fenster.
                                          Mein Problem ist nur, dass ich in dieses Fenster wohl keine weiteren Widgets für die Einstellung der Timer-Werte integriert bekomme. Oder geht das irgendwie? Falls nicht, muss ich wohl doch eher einen weiteren View erstellen, auf den ich dann in oben beschriebener Weise navigiere. Das ist aber mein kleineres Problem.
                                          Eine größere Herausforderung stellt die Umwandlung der im View eingestellten Timer-Werte auf das für die Vitodens erforderliche Format dar.
                                          Wie bereits am Anfang dieses Threads erwähnt, sieht das für jeden Timer folgendermaßen aus:
                                          Gruß,
                                          Thorsten
