  4. Test Adapter repetierserver v0.0.3
    6.6k
adapter3d druckerrepetierrepetierserver3d printing
50 Beiträge 11 Kommentatoren 7.1k Aufrufe 9 Beobachtet
    @Michael-Dolp
    Bitte die Rückmeldung aus der Konsole zeigen. Vollständig.
    Michael DolpM Offline
    Michael Dolp
    @Thomas-Braun
    Ich hab 6 Maschinen im Repetier - vielleicht ist das ein Problem?
    "So lange es nicht Heizen muss, geht es am besten mit Shelly`s"
    1x IOBroker on QNAP Ts253A - ( Docker/buanet )
    1x FHEM on QNAP ( VM 1 Core / 2GB RAM )
    1x Raspberymatic / ELV-Charly ( RPI 3 )
    1x Raspbee ( RPI 2 )
    1x Repetier Server - 6 Drucker ( RPI 4 )
    • Michael DolpM Michael Dolp
      @Thomas-Braun
      Konsole? Das Log?
      repetierserver.0	2020-12-19 20:20:42.679	info	(2178) Terminated (NO_ERROR): Without reason
      repetierserver.0	2020-12-19 20:20:42.678	info	(2178) terminating
      repetierserver.0	2020-12-19 20:20:42.647	error	(2178) TypeError: Cannot read property 'val' of null at /opt/iobroker/node_modules/iobroker.repetierserver/main.js:1003:63 at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/state
      repetierserver.0	2020-12-19 20:20:42.644	error	(2178) uncaught exception: Cannot read property 'val' of null
      repetierserver.0	2020-12-19 20:20:42.643	error	(2178) TypeError: Cannot read property 'val' of null at /opt/iobroker/node_modules/iobroker.repetierserver/main.js:1003:63 at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/state
      repetierserver.0	2020-12-19 20:20:42.642	error	(2178) uncaught exception: Cannot read property 'val' of null
      repetierserver.0	2020-12-19 20:20:42.426	error	(2178) TypeError: Cannot read property 'val' of null at /opt/iobroker/node_modules/iobroker.repetierserver/main.js:1003:63 at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/state
      repetierserver.0	2020-12-19 20:20:42.424	error	(2178) uncaught exception: Cannot read property 'val' of null
      repetierserver.0	2020-12-19 20:20:42.324	error	(2178) TypeError: Cannot read property 'val' of null at /opt/iobroker/node_modules/iobroker.repetierserver/main.js:1003:63 at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/state
      repetierserver.0	2020-12-19 20:20:42.323	error	(2178) uncaught exception: Cannot read property 'val' of null
      repetierserver.0	2020-12-19 20:20:42.322	error	(2178) TypeError: Cannot read property 'val' of null at /opt/iobroker/node_modules/iobroker.repetierserver/main.js:1003:63 at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/state
      repetierserver.0	2020-12-19 20:20:42.321	error	(2178) uncaught exception: Cannot read property 'val' of null
      repetierserver.0	2020-12-19 20:20:42.319	info	(2178) Repetier-Server Service gestoppt...
      repetierserver.0	2020-12-19 20:20:42.318	info	(2178) Repetier-Server Verbindungsaufbau gestoppt...
      repetierserver.0	2020-12-19 20:20:42.315	info	(2178) Repetier-Server Service bereinigt...
      repetierserver.0	2020-12-19 20:20:42.312	error	(2178) TypeError: Cannot read property 'val' of null at /opt/iobroker/node_modules/iobroker.repetierserver/main.js:1003:63 at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/state
      repetierserver.0	2020-12-19 20:20:42.306	error	(2178) uncaught exception: Cannot read property 'val' of null
      repetierserver.0	2020-12-19 20:20:39.601	debug	(2178) RepetierServer states subscribed
      repetierserver.0	2020-12-19 20:20:39.599	info	(2178) Repetier Port: 3344
      repetierserver.0	2020-12-19 20:20:39.599	info	(2178) Repetier ApiKey: 3c8860f2-zensiert-f8370a239eef
      repetierserver.0	2020-12-19 20:20:39.598	info	(2178) Repetier IP: 192.168.1.225
      repetierserver.0	2020-12-19 20:20:39.597	info	(2178) RepetierServer verbunden
      repetierserver.0	2020-12-19 20:20:39.551	info	(2178) starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.repetierserver, node: v12.20.0, js-controller: 3.1.6
      @Michael-Dolp
      Nein, ich möchte sehen, was dein System auf jetzt auf
      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs && who -r && whoami
      und
      sudo apt update
      jeweils zurückliefert.
      Michael DolpM 1 Antwort Letzte Antwort
        @Michael-Dolp
        und
        sudo apt update
        Michael Dolp
        @Thomas-Braun
        # which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs && who -r && whoami
        /usr/bin/nodejs
        v12.20.0
        /usr/bin/node
        v12.20.0
        /usr/bin/npm
        6.14.10
        nodejs:
          Installiert:           12.20.0-1nodesource1
          Installationskandidat: 12.20.0-1nodesource1
          Versionstabelle:
         *** 12.20.0-1nodesource1 500
                500 https://deb.nodesource.com/node_12.x buster/main amd64 Packages
             10.21.0~dfsg-1~deb10u1 500
                500 http://deb.debian.org/debian buster/main amd64 Packages
                500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
        root
        # sudo apt update
        OK:1 http://security.debian.org/debian-security buster/updates InRelease
        OK:2 http://deb.debian.org/debian buster InRelease
        OK:3 http://deb.debian.org/debian buster-updates InRelease
        OK:4 https://deb.nodesource.com/node_12.x buster InRelease
        Alle Pakete sind aktuell.
          @Thomas-Braun
          /usr/bin/nodejs
          v12.20.0
          /usr/bin/node
          v12.20.0
          /usr/bin/npm
          6.14.10
          nodejs:
            Versionstabelle:
          root
          # sudo apt update
          @Michael-Dolp Das passt soweit.
          Bis auf den root login. Das passt nicht. Leg dir einen user an und gib dem sudo-Rechte.
            Michael Dolp
            @Thomas-Braun
            Ist in der "Docker" konsolo /bin/sh
            Da gibts so keinen direkten User denk ich.
              @Thomas-Braun
              @Michael-Dolp
              Sollte es aber geben. Auf der synology geht das wohl aus systemseitigen Gründen nicht.
                @Michael-Dolp
                Michael Dolp
                @Thomas-Braun
                Vielleicht sollte ich mal das neuste Docker Image probieren: https://hub.docker.com/r/buanet/iobroker/ und nur zum Testen diesen Adapter installieren?
                  @Thomas-Braun
                  @Michael-Dolp
                  Ich habe von Docker-Gedöns keine Ahnung. Und auch keine gute Meinung (für den Verwendungszweck, für den der Kram hier missbraucht verwendet wird)
                  Da dürfte es aber einen Bug im Adapter geben. Mach ein Issue auf github dazu auf. Mit 6 Druckern wird das vermutlich nicht getestet worden sein.
                    @Michael-Dolp
                    Michael Dolp
                    @Thomas-Braun
                    Nächstes Jahr möchte ich den IO auf nen RPI4 aufsetzen, sind 4GB ausreichend für "sehr viel Zeug" oder sollten es 8GB sein - was meinst Du?
                      @Thomas-Braun
                      @Michael-Dolp Für die paar Euro Unterschied im Preis würde ich auf die 8 GB gehen.
                        DominikW
                        schrieb am zuletzt editiert von DominikW
                        LÖSUNGSANSATZ für das Problem mit den nicht gefüllten/erstellten Datenpunkten:
                        Moin Zusammen 🌱
                        ich habe eine reproduzierbare Lösung entwickelt für (hoffentlich alle) diejenigen, bei denen der Adapter bei mehr als einem Drucker mit "Status/Drucker_druckt" Probleme bereitet. Ich habe die Problemursache / das Problemverhalten jetzt zwei Tage lang ergründet und ausgetestet und möchte mit euch meinen "Workaround" teilen.
                        Zudem ist gibt dieser Ansatz vielleicht auch einen Einblick in die Ursache des Problems sowie eine Möglichkeit dies in zukünftigen Versionen zu beheben.
                        Anscheinend verhindert die nicht über den Adapter erfolgte Anlage und Zuweisung des Datenpunktes zum Druckernamen (bei mehr als einem Drucker) ebenso die Erstellung aller weiteren Datenpunkte - warum dies nur beim ersten Drucker klappt, warum selbsterstellte Datenpunkte nicht anerkannt werden und warum dies anscheinend nicht bei jedem Nutzer auftritt bleibt mir ein Rätsel.
                        Rahmenbedingungen/Mein System:
                        RaspberryPi 4 (4GB)
                        ioBroker Admin = 4.1.12
                        js-controller = 3.1.6
                        node.js = 12.20.0
                        npm = 6.14.8
                        repetierserver = 0.0.3
                        Wen es interessiert wie ich das Problem gelöst habe bzw. die Problembeschreibung findet ihr hier im Spoiler:
                        Kurz zum bei mir auftretenden Problem.
                        Bei meinen zwei Druckern stiegt der Adapter mit dem oben beschriebenen "val = null" Problem aus. Der Quickfix mit den selbstständig angelegten Datenpunkten in "Status/Drucker_druckt" brachte den Adapter zwar zum laufen jedoch wurden die relevanten Daten für die/den betroffenen Drucker nicht erstellt. Die Daten vom 1. erkannten Drucker, bei dem auch der "Status/Drucker_druckt" vom Adapter hinzugefügt wurde erstellte die Datensätze unter "Printjob" problemlos.
                        Dabei fiel mir auf, dass die selbstständig erstellen Datensätze von "admin.0" aktualisiert wurden (einmalig) während der vom Adapter erstellte und zugewiesene Datenpunkt von "repetierserver.0/admin" ständig aktualisiert wurde. Etliche Versuche diesen Datensatz vom Adapter erkennbar / beschreibbar zu machen schlugen fehl.
                        Verschiedene Kombinationen von aktivieren und deaktivieren der Drucker in Kombination mit Neuinstallation des Adapters / der Instanzen brachte alles keinen Erfolg. Ebenso nicht mit neu hinzufügen von Druckern.
                        Schlussendlich erinnerte ich mich an ein Problem mit dem anderen Repetieradapter, dass die Namensreihenfolge alphabetisch erfolgen müsse, wobei bei mir die alphabetische Reihenfolge genau umgedreht war wie die Reihenfolge mit der die Drucker im Adapter aufgeführt waren. Auch dies war eine Sackgasse.
                        Schlussendlich löschte ich den funktionierenden Drucker im Repetierserver Interface, sodass der nicht funktionierende Drucker der erste und einzige Drucker war und hoffte auf eine Besserung, da anscheinend ja nur ein Drucker ordentlich erkannt wurde. Das funktionierte ebenso nicht. Der Datenpunkt wurde nicht zu den bereits bestehenden Datenpunkten hinzugefügt und ich dachte vielleicht gibt es ein Problem mit dem Namen.
                        Ich löschte beide Drucker, erstellte zwei neue Drucker mit dem Namen "1" und "2" in der korrekten Reihenfolge und versuchte es erneut - gleiches Ergebnis:
                        Drucker 1 funktionierte - Drucker 2 nicht, Datenpunkt "Status/Drucker_druckt" wurde nicht angelegt und dementsprechend auch nicht die entsprechenden "Printjob" Datenpunkte. Mir fiel dabei schon des öfteren auf, dass die Datenpunkte auch nach dem löschen der Drucker erhalten blieben. Zudem, dass manche erneut erstellten Drucker auf einmal eine laufende Nummer im Namen erhielten.
                        Neuer Ansatz, wenn es möglich ist für jeden Druckernamen einzeln (Drucker für Drucker) den Datenpunkt vom Adapter generieren zu lassen, sodass diese bereits vorhanden sind und anschließend die Drucker unter gleichem Namen erneut in Repetier anzulegen, könnte eine Integration aller Drucker klappen.
                        Kurz gefasst, dies hat nach mehreren Anläufen funktioniert.
                        Die folgende Anleitung ist bereits so gehalten, dass ihr voraussichtlich kein Problem haben solltet mit der "Laufenden Nummer" im Druckernamen.
                        Hier die Schritt für Schritt Anleitung:
                        RS bedeutet folgendes im Repetierserver Interface
                        IO bedeutet im ioBroker Interface
                        OPTIONAL bedeutet: empfohlen zur Prüfung ob alles geklappt hat
                        🚩 SCHRITT 0
                        EMPFEHLUNG/WARNUNG
                        Ich empfehle euch die Schritte der Reihenfolge nach auszuführen und keinen zu überspringen/wegzulassen. Besonders nicht die Neustarts!
                        Zudem ist es wichtig die Namen der jeweiligen Drucker gleich zu schreiben und auf Groß- und Kleinschreibung zu achten.
                        Ebenso empfehle ich euch im RS alle Daten eurer Drucker zu notieren/speichern ( EEPROM, CustomGCode, Verbindungseinstellungen, etc. ) außerdem werden ALLE für den jeweiligen Drucker hochgeladenen GCodes gelöscht - also auch hier bitte sichern was ihr noch braucht! ( Dies betrifft nicht die in "Projekte" hochgeladenen Dateien ).
                        Dies verhindert Frust und macht die Wiedereinbindung später schneller, besonders die Verbindungsdaten direkt einzutragen ( Baudrate, RTS, DTR, Buffer & PingPong Modus ) statt automatischer Erkennung beschleunigt die ganze Sache enorm!
                        Ihr braucht auch nicht alle Druckerwerte direkt korrekt Einpflegen sondern könnt dies wenn der Adapter endgültig läuft nachholen.
                        🚩 SCHRITT 1
                        Im IO alle Datenpunkte der repetierserver.x Instanz löschen, die Instanz entfernen und den Adapter löschen.
                        Im RS alle Drucker löschen ( ⚠ s. SCHRITT 0 )
                        Anschließend IO & RS neustarten.
                        🚩 SCHRITT 2
                        Im RS ersten Drucker anlegen (es darf nur ein Drucker im RS sein!).
                        Drucker deaktivieren! ( RS Home - Rädchen oben-rechts am Drucker - Deaktivieren ).
                        🚩 SCHRITT 3
                        Im IO repetierserver Adapter installieren ( wenn nicht bereits installiert ).
                        repetierserver.0 Instanz anlegen.
                        In der Instanz: IP, Port und API Key eingeben.
                        Instanz starten ( Drucker muss deaktiviert sein um Probleme zu vermeiden ).
                        -kurz warten- ( delay 5000ms 😊 )
                        Im RS Drucker aktivieren.
                        Im IO sollten die Werte nun alle erstellt, angezeigt und aktualisiert werden.
                        ( relevant sind hier "Status/Drucker_druckt" und alle Werte aus dem Ordner "PrintJob" )
                        Falls nicht:
                        Im IO LOG prüfen ob der "val = null" Fehler auftritt.
                        ( dann -> Drucker erneut deaktivieren - aktivieren )
                        🚩 SCHRITT 4
                        Im IO Instanz stoppen.
                        Im RS Drucker löschen.
                        ( NICHT DIE DATENPUNKTE IM IO LÖSCHEN! )
                        Im RS zweiten Drucker installieren.
                        Zweiten Drucker deaktivieren ( nicht vergessen - es darf aktuell nur ein Drucker insgesamt im RS vorhanden sein ).
                        Im IO Instanz starten ( Drucker muss deaktiviert sein um Probleme zu vermeiden ).
                        -kurz warten-
                        -kurz warten-
                        Datenpunkte prüfen.
                        ( relevant sind auch hier wieder "Status/Drucker_druckt" und alle Werte aus dem Ordner "PrintJob", ob der Drucker unter dem richten Namen angelegt wurde sowie unter "info" der korrekte Name eingetragen ist )
                        🚩 SCHRITT 5
                        Wiederhole "SCHRITT 4" für alle Drucker die du in die Instanz einfügen willst.
                        🚩 SCHRITT 6
                        Am besten erste den vollständigen S
                        Im RS ALLE Drucker löschen ( es sollte sich nach dem vorherigen Schritt sowieso nur ein Drucker im RS befinden - es darf anschließend KEIN Drucker mehr im RS enthalten sein ).
                        RS neustarten. ( WICHTIG! )
                        Im RS bei ( ausgeschalteter Instanz ) alle Drucker wieder anlegen und alle deaktivieren ( Die Druckernamen müssen dabei identisch zu den vorher angelegten sein - auch Groß- & Kleinschreibung ).
                        OPTIONAL
                        Per SSH auf den RepetierServer einwählen:
                        cd /var/lib/Repetier-Server/printer/
                        ls
                        hier sollte alle Drucker als Ordner mit den korrekten Namen aufgeführt sein.
                        Falls nicht:
                        Entweder alles von SCHRITT 0 an nochmal durchführen.
                        -oder-
                        versuchen mit folgenden Befehlen die Namen der Drucker zu ändern:
                        sudo mv /var/lib/Repetier-Server/printer/oldname  /var/lib/Repetier-Server/printer/newname
                        Bsp.:
                        Der ursprüngliche Name piVinci wurde als piVinci1 angelegt.
                        sudo mv /var/lib/Repetier-Server/printer/piVinci1  /var/lib/Repetier-Server/printer/piVinci
                        ( wichtig ohne / am Ende und „/var/lib/Repetier-Server/printer/old name“ - in "" setzen - wenn der Name ein Leerzeichen beinhalten sollte )
                        Anschließend:
                        cd /var/lib/Repetier-Server/configs/
                        ls
                        auch hier schauen, dass die Dateien "druckername.xml" korrekt bezeichnet sind.
                        falls nicht:
                        sudo nano druckername.xml
                        Den Namen zwischen <name> sowie <slug> ändern.
                        Anschließend mit ctrl+x die unter korrektem druckername.xml speichern.
                        Zu guter letzt die falschen Druckernamen löschen (xml und bak):
                        sudo rm falscherdruckername.xml
                        sudo rm falscherdruckername.xml.bak
                        Anschließend RP neustarten und erneut prüfen.
                        Im IO Instanz starten.
                        Im RS dann alle Drucker aktivieren.
                        🚩 SCHRITT 7
                        Abschließend im IO prüfen ob:
                        • unter "info/activeprinter" alle Drucker aufgelistet sind und die Namen mit den ursprünglichen übereinstimmen.
                        • keine neuen Druckernamen aufgetaucht sind.
                        • unter jedem Drucker die Datenpunkte "Status/Drucker_druckt" sowie alle Datenpunkte unter "PrintJob/" aktualisiert werden ( sollten alle im unregelmäßigen Sekundentakt grün aufleuchten - in der Statusansicht sollte auch überall bei "geändert von" "repetierserver.0/admin" stehen ).
                        • das LOG keine Fehler mehr auswirft.
                        Herzlichen Glückwunsch!
                        Der Adapter sollte nun laufen 🏁
                        Hier noch ein Bild wie es aussehen sollte/könnte:
                        Ich hoffe wirklich, dass dieser Workaround und meine investierte Zeit mehr als nur mir Abhilfe schaffen.
                        Es wäre schön ein wenig zurückzugeben zu können von dem was ich bisher aus diesem Forum an Lösungen und Erklärungen, durch die Zeit und Mühe der anderen Teilnehmer hier, mitgenommen habe.
                        Ich wünsche euch viel Erfolg und einen guten Start in 2021.
                        hananH 1 Antwort Letzte Antwort
                        • D DominikW
                          Moin Zusammen 🌱
                          RaspberryPi 4 (4GB)
                          node.js = 12.20.0
                          npm = 6.14.8
                          🚩 SCHRITT 0
                          EMPFEHLUNG/WARNUNG
                          🚩 SCHRITT 1
                          🚩 SCHRITT 2
                          🚩 SCHRITT 3
                          Falls nicht:
                          🚩 SCHRITT 4
                          -kurz warten-
                          -kurz warten-
                          Datenpunkte prüfen.
                          🚩 SCHRITT 5
                          🚩 SCHRITT 6
                          OPTIONAL
                          ls
                          Falls nicht:
                          -oder-
                          Bsp.:
                          Anschließend:
                          ls
                          falls nicht:
                          🚩 SCHRITT 7
                          hananH Offline
                          hananH Offline
                          hanan
                          schrieb am zuletzt editiert von hanan
                          Hallo zusammen
                          Ich habe den Adapter installiert und erhalte keine Verbindung zum RepetierServer Pro 1.0.4.
                          Habe auch die Abfolge von DominikW durchgeführt, doch es wurden nie Datenpunkte angelegt, geschweige der Adapter wurde grün.
                          Kann mir bitte jemand einen Tipp geben?
                          Hier meine Installationen und Logs:
                          repetierserver.0	2021-04-16 07:16:36.844	warn	(24574) State "repetierserver.0.info.printjob" has no existing object, this might lead to an error in future versions
                          repetierserver.0	2021-04-16 07:16:36.844	warn	(24574) State "repetierserver.0.info.active" has no existing object, this might lead to an error in future versions
                          repetierserver.0	2021-04-16 07:16:36.826	warn	(24574) Terminated (UNCAUGHT_EXCEPTION): Without reason
                          repetierserver.0	2021-04-16 07:16:36.826	info	(24574) terminating
                          repetierserver.0	2021-04-16 07:16:36.826	info	(24574) Repetier-Server-Verbindung beendet ...
                          repetierserver.0	2021-04-16 07:16:36.825	info	(24574) Repetier-Server-Service bereinigt ...
                          repetierserver.0	2021-04-16 07:16:36.801	error	(24574) The id is empty! Please provide a valid id.
                          repetierserver.0	2021-04-16 07:16:36.801	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12)
                          repetierserver.0	2021-04-16 07:16:36.801	error	at Request.emit (events.js:314:20)
                          repetierserver.0	2021-04-16 07:16:36.801	error	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
                          repetierserver.0	2021-04-16 07:16:36.801	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                          repetierserver.0	2021-04-16 07:16:36.801	error	at Request._callback (/opt/iobroker/node_modules/iobroker.repetierserver/main.js:644:29)
                          repetierserver.0	2021-04-16 07:16:36.801	error	at PrinterKanaele (/opt/iobroker/node_modules/iobroker.repetierserver/main.js:1630:5)
                          repetierserver.0	2021-04-16 07:16:36.801	error	at SetKanal (/opt/iobroker/node_modules/iobroker.repetierserver/main.js:1863:14)
                          repetierserver.0	2021-04-16 07:16:36.801	error	at Template.extendObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2062:17)
                          repetierserver.0	2021-04-16 07:16:36.801	error	at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:496:19)
                          repetierserver.0	2021-04-16 07:16:36.801	error	(24574) Error: The id is empty! Please provide a valid id.
                          repetierserver.0	2021-04-16 07:16:36.801	error	(24574) unhandled promise rejection: The id is empty! Please provide a valid id.
                          repetierserver.0	2021-04-16 07:16:36.801	error	(24574) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          repetierserver.0	2021-04-16 07:16:36.800	error	(24574) The id is empty! Please provide a valid id.
                          repetierserver.0	2021-04-16 07:16:36.800	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12)
                          repetierserver.0	2021-04-16 07:16:36.800	error	at Request.emit (events.js:314:20)
                          repetierserver.0	2021-04-16 07:16:36.800	error	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
                          repetierserver.0	2021-04-16 07:16:36.800	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                          repetierserver.0	2021-04-16 07:16:36.800	error	at Request._callback (/opt/iobroker/node_modules/iobroker.repetierserver/main.js:644:29)
                          repetierserver.0	2021-04-16 07:16:36.800	error	at PrinterKanaele (/opt/iobroker/node_modules/iobroker.repetierserver/main.js:1630:5)
                          repetierserver.0	2021-04-16 07:16:36.800	error	at SetKanal (/opt/iobroker/node_modules/iobroker.repetierserver/main.js:1854:14)
                          repetierserver.0	2021-04-16 07:16:36.800	error	at Template.setObjectNotExists (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3298:17)
                          repetierserver.0	2021-04-16 07:16:36.800	error	at validateId (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:496:19)
                          repetierserver.0	2021-04-16 07:16:36.800	error	(24574) Error: The id is empty! Please provide a valid id.
                          repetierserver.0	2021-04-16 07:16:36.799	error	(24574) unhandled promise rejection: The id is empty! Please provide a valid id.
                          repetierserver.0	2021-04-16 07:16:36.799	error	(24574) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          repetierserver.0	2021-04-16 07:16:36.777	debug	(24574) RepetierServer states subscribed
                          repetierserver.0	2021-04-16 07:16:36.777	info	(24574) undefined 3344
                          repetierserver.0	2021-04-16 07:16:36.777	info	(24574) undefined 5cd75448-438d-41e5-9785-f5e8df558d76
                          repetierserver.0	2021-04-16 07:16:36.777	info	(24574) undefined 192.168.1.65
                          repetierserver.0	2021-04-16 07:16:36.776	info	(24574) undefined
                          repetierserver.0	2021-04-16 07:16:36.767	info	(24574) starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.repetierserver, node: v12.22.1, js-controller: 3.2.16
                          repetierserver.0	2021-04-16 07:16:36.547	debug	(24574) statesDB connected
                          repetierserver.0	2021-04-16 07:16:36.547	debug	(24574) States connected to redis: 127.0.0.1:9000
                          repetierserver.0	2021-04-16 07:16:36.498	debug	(24574) States create User PubSub Client
                          repetierserver.0	2021-04-16 07:16:36.498	debug	(24574) States create System PubSub Client
                          repetierserver.0	2021-04-16 07:16:36.493	debug	(24574) Redis States: Use Redis connection: 127.0.0.1:9000
                          repetierserver.0	2021-04-16 07:16:36.492	debug	(24574) objectDB connected
                          repetierserver.0	2021-04-16 07:16:36.490	debug	(24574) Objects connected to redis: 127.0.0.1:9001
                          repetierserver.0	2021-04-16 07:16:36.484	debug	(24574) Objects client initialize lua scripts
                          repetierserver.0	2021-04-16 07:16:36.481	debug	(24574) Objects create User PubSub Client
                          repetierserver.0	2021-04-16 07:16:36.481	debug	(24574) Objects create System PubSub Client
                          repetierserver.0	2021-04-16 07:16:36.480	debug	(24574) Objects client ready ... initialize now
                          repetierserver.0	2021-04-16 07:16:36.462	debug	(24574) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          Liebe Grüsse aus der Schweiz
                          Andy
                          ioBroker auf NUC unter Proxmox, Raspberrymatic-CCU auf NUC unter Proxmox mit RPI-RF-MOD Funkmodul und Omnidiraktional Antenne
                          W 1 Antwort Letzte Antwort
                          • hananH hanan
                            Hallo zusammen
                            W Offline
                            W Offline
                            Wuti
                            @hanan ich hatte das selbe Problem und habe mich daraufhin mit Javascript auseinander gesetzt und mir ein passendes Javascript gebastelt. Kann dir dies gerne hier teilen und du kannst testen, ob es bei dir ebenfalls funktioniert. Benutzung erfolgt auf eigene Gefahr! Bei mie läuft es jedenfalls erfolgreich und ich bekomme die wichtigsten Daten vom Repetier-Server zum Io-Broker.
                            Hier ist der Github-Link: https://github.com/Wuti94/RepetierScript.Iobroker/blob/main/RepetierConnect.js
                            BaumertB 1 Antwort Letzte Antwort
                            • W Wuti
                              BaumertB Offline
                              BaumertB Offline
                              Baumert
                              entschuldigt bitte, dass ich mich erst jetzt wieder melde - leider hat es andere Prioritäten gegeben, die erst erledigt werden mussten.
                              Ich werde mich jetzt wieder um den Adapter kümmern und dafür sorgen, dass es eine lauffähige Version gibt. Aktuell habe ich das Problem, das es der Adapter seit dem Update auf js-controller 3.2 nicht mehr läuft.
                              Ich bin bereits dran, das Problem zu lösen, so dass der Adapter erst mal läuft und die Daten der Drucker zur Verfügung stellt.
                              Baumert
                              • BaumertB Baumert
                                Baumert
                                BaumertB Offline
                                BaumertB Offline
                                Baumert
                                schrieb am zuletzt editiert von Baumert
                                ich habe jetzt eine neue Version 0.0.6 zum testen auf GITHUB. Soweit sieht es gut aus und bei mir läuft der Adapter jetzt wieder. Beim Start des Adapters gibt es noch einen Schönheitsfehler, bei dem eine Warnung beim Anlegen der Datenpunkte ausgegeben wird. Dies wird aber zur nächsten Version bearbeitet.
                                Hier der Github-Link: https://github.com/Baumert7269/ioBroker.repetierserver.git
                                Hauptfocus lag erst einmal darauf, dass der Adapter wieder läuft.
                                SoundyS 1 Antwort Letzte Antwort
                                • BaumertB Baumert
                                  SoundyS Offline
                                  SoundyS Offline
                                  Soundy
                                  @baumert
                                  Ich habe nun auch endlich den Repetierserver am Laufen und sofort diesen Adapter installiert. Allerdings fällt mir etwas ganz eigenartiges auf:
                                  Beim Eintragen der IP-Adresse des Servers wird ein API-Schlüssel eingetragen, der jedenfalls nicht mit meinem Key im Server übereinstimmt. Trage ich aber den korrekten API-Key aus meinem Server ein, dann wird der Adapter nie GRÜN.
                                  Wo ist da der Fehler und woher kommt der "für mich fast zufällige" Key, der anscheinend auch funktioniert?
