  4. Restore schlägt fehl
    6.7k
restore backup
178 Beiträge 5 Kommentatoren 18.9k Aufrufe 2 Beobachtet
  • L Offline
    LJSven
    schrieb am zuletzt editiert von LJSven
    Systemdata Bitte Ausfüllen
    Hardwaresystem: tinkerboard
    Arbeitsspeicher: 2GB
    Festplattenart: SD-Karte
    Betriebssystem: Ubuntu
    Node-Version: 12.20.0
    Nodejs-Version: 12.20.0
    NPM-Version: 6.x.x
    Ich möchte meinen ioBroker aus restore wiederherstellen. Aber es kommt eine Meldung. Was mache ich falsch?
    pi@tinkerboardmaster:/opt/iobroker$ iobroker restore iobroker_2020_12_15-02_00_10_ioBrokerMini_backupiobroker.tar.gz
     Objects 192.168.178.228:45120 Error from InMemDB: Error: Unknown Script f920e95b4d029e06ed62ab6885f33d4fbfacdb20
    iobroker controller daemon is not running
    host.tinkerboardmaster OK.
    <--- Last few GCs --->
    [17199:0x3e35b60]    19144 ms: Mark-sweep 499.7 (501.7) -> 499.7 (501.7) MB, 169.0 / 0.0 ms  (average mu = 0.303, current mu = 0.000) last resort GC in old space requested
    [17199:0x3e35b60]    19377 ms: Mark-sweep 499.7 (501.7) -> 499.7 (501.7) MB, 232.5 / 0.0 ms  (average mu = 0.182, current mu = 0.000) last resort GC in old space requested
    <--- JS stacktrace --->
    ==== JS stack trace =========================================
    Security context: 0x4378ea21 <JSObject>
        0: builtin exit frame: parse(this=0x437865a9 <Object map = 0x45e40a15>,0x39c4008d <Very long string[108752834]>,0x437865a9 <Object map = 0x45e40a15>)
        1: restoreAfterStop [0x37af6111] [/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:627] [bytecode=0x50afd42d offset=168](this=0x34842395 <BackupRestore map = 0x494cf885>,0x317c03c1 <false>,0x34842aa5 <JSFunction (sfi ...
    FATAL ERROR: CALL_AND_RETRY_LAST Allocation failed - JavaScript heap out of memory
    /usr/bin/iobroker: Zeile 8: 17198 Abgebrochen             sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
    pi@tinkerboardmaster:/opt/iobroker$ iobroker restore iobroker_2020_12_14-02_00_10_ioBrokerMini_backupiobroker.tar.gz
    [17369:0x2e6bb60]    36581 ms: Mark-sweep 506.8 (508.0) -> 507.0 (508.8) MB, 438.3 / 0.0 ms  (average mu = 0.105, current mu = 0.052) allocation failure scavenge might not succeed
    Cannot get stack trace in GC.
    FATAL ERROR: MarkCompactCollector: semi-space copy, fallback in old gen Allocation failed - JavaScript heap out of memory
    /usr/bin/iobroker: Zeile 8: 17368 Abgebrochen             sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
    UncleSamU 1 Antwort Letzte Antwort
    • L LJSven
      NPM-Version: 6.x.x
      UncleSamU Offline
      UncleSamU Offline
      UncleSam
      @LJSven sagte in Restore schlägt fehl:
      Scheinbar hast du nicht mehr genug RAM. Was läuft sonst noch auf dem Pi? Hast du einen Desktop am laufen? Ist das System neu aufgesetzt?
      Ein Tipp: wenn nicht unbedingt nötig, würde ich auf Raspberry OS gehen und nicht Ubuntu. Meines Wissens braucht Ubuntu einiges mehr an Platz als Raspberry OS, das extra für den Raspi erstellt wurde.
      Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
      ♡-lichen Dank an meine Sponsoren
      L 1 Antwort Letzte Antwort
      • UncleSamU UncleSam
        LJSven
        @UncleSam Das ist ein Tinkerboard / das System läuft eigentlich seit einem Jahr. Gestern habe ich ein System Update gemacht. Vermutlich nimmt sich da einer Resourcen. Wie kann ich vorgehen? Selbst wenn der Tinkerboard neu gestartet wurde, lässt sich das Update nicht installieren. Der Iobroker läuft, aber nach dem Neustart fehlen Werte in Datenpunkten. Deshalb wollte ich ein Backup einspielen. Oder gibt es eine andere Möglichkeit die Werte wieder zu bekommen. Habe das Problem gelegentlich, wenn nicht ordentlich neu gestartet wird.
        UncleSamU J HomoranH 3 Antworten Letzte Antwort
        • L LJSven
          UncleSamU Offline
          UncleSamU Offline
          UncleSam
          Hast du es mal mit einer neuen SD-Karte versucht? Die könnte beschädigt sein.
          Um zu schauen, was viel RAM/CPU braucht, kannst du mal den Befehl top ausführen und hier hin kopieren.
          • L LJSven
            Jan1
            @LJSven
            Wie spielst denn ein Backup ein, mit dem Backitup Adapter?
            • J Jan1
              @LJSven
              LJSven
              @Jan1 sagte in Restore schlägt fehl:
              @LJSven
              Nein - manuell über iobroker restore „filename“
              • L LJSven
                @LJSven
                Jan1
                @LJSven
                Das ist schon mal möglich, wenn man weiß was man tut.
                Warum nimmst nicht den Adapter dafür der für genau das gemacht wurde und einige Vorteile gegenüber einem "normalen" Backup mit bringt?
                • J Jan1
                  @LJSven
                  UncleSamU Offline
                  UncleSamU Offline
                  UncleSam
                  Er benutzt ja iobroker restore auf der Kommandozeile mit einem Backup das wohl von BackItUp gemacht wurde.
                  L J 2 Antworten Letzte Antwort
                    LJSven
                    @UncleSam sagte in Restore schlägt fehl:
                    Genau! Macht es dann Sinn über den Adapter?
                      Jan1
                      @UncleSam
                      Das ist eben der falsche Weg und ich glaube, dass da IOBroker noch irgendwie im Hintergrund läuft, was dazu führt, dass sein RAM voll läuft.
                      • L LJSven
                        Jan1
                        @LJSven
                        Das macht nicht nur Sinn, sondern sollte so gemacht werden.
                        Und wenn das wirklich sauber sein soll, dann vorher IOBroker Ordner komplett löschen, IOBroker und Backitup Adapter installieren, das Backup in den "Backups" Ordner schieben und über den Adapter restoren.
                        Je nach Umfang des Restor, mal ne Stunde Pause einlegen und freuen, dass das Ding wieder läuft.
                        • J Jan1
                          @UncleSam
                          UncleSamU Offline
                          UncleSamU Offline
                          UncleSam
                          @Jan1 Das wäre mir neu, aber so oft habe ich Restore noch nicht verwendet.
                          Von https://github.com/simatec/ioBroker.backitup/blob/master/docs/en/backitup.md#4-restore :
                          For all backup types iobroker is stopped during the restore and then automatically restarted.
                          Einzig CCU geht noch nicht.
                            Jan1
                            @UncleSam
                            Wenn Du das mit dem Adapter machst auf alle Fälle, nur bei ihm wohl nicht, sonst wäre der RAM nicht voll ;)
                              LJSven
                              top - 08:47:00 up  1:03,  2 users,  load average: 0,67, 0,67, 0,87
                              Tasks: 198 total,   3 running, 138 sleeping,   0 stopped,   0 zombie
                              %Cpu(s): 12,1 us,  2,0 sy,  0,0 ni, 85,5 id,  0,0 wa,  0,0 hi,  0,3 si,  0,0 st
                              KiB Mem :  2050804 total,   318224 free,  1332388 used,   400192 buff/cache
                              KiB Swap:  1025400 total,  1011576 free,    13824 used.   781764 avail Mem
                                PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
                               7272 iobroker  20   0  259616 174584  27400 S  24,6  8,5  19:14.77 node
                               8429 iobroker  20   0  155476  67448  27184 S   9,8  3,3   3:36.63 node
                               7573 iobroker  20   0  305680 221256  28464 S   7,9 10,8   6:15.76 node
                               7333 iobroker  20   0  206284 122936  28580 S   4,6  6,0   0:36.18 node
                                750 pi        20   0  119672  35412  23832 S   2,6  1,7   1:41.38 deCONZ
                              17654 pi        20   0    8796   2940   2444 R   1,3  0,1   0:00.24 top
                               1458 asterisk  20   0  230008  58996  31320 S   1,0  2,9   0:58.40 asterisk
                               7398 iobroker  20   0  146304  54680  27664 S   1,0  2,7   0:36.67 node
                               7498 iobroker  20   0  148596  58988  27516 S   1,0  2,9   1:53.69 node
                               8855 iobroker  20   0  146080  61000  27084 S   1,0  3,0   0:43.21 node
                                355 root      20   0    7204    992    992 S   0,3  0,0   0:12.23 haveged
                               1554 ntp       20   0    6772   2704   2292 S   0,3  0,1   0:00.53 ntpd
                               1564 root      20   0  123120  43988  25484 S   0,3  2,1   0:01.31 Xorg
                               7391 iobroker  20   0  137188  43900  27660 S   0,3  2,1   0:07.14 node
                               8408 iobroker  20   0  136784  43928  26924 S   0,3  2,1   0:10.76 node
                               8707 iobroker  20   0  144048  51420  26968 R   0,3  2,5   0:40.09 node
                               8903 root      20   0       0      0      0 I   0,3  0,0   0:00.36 kworker/2:+
                              J UncleSamU 3 Antworten Letzte Antwort
                              • L LJSven
                                Jan1
                                @LJSven
                                Nur IOBroker frisst hier RAM, wobei das Ding bei 2GB RAM schon SWAPt und das ist früher oder später eh der Tod der SD Karte.
                                • L LJSven
                                  UncleSamU Offline
                                  UncleSamU Offline
                                  UncleSam
                                  schrieb am zuletzt editiert von UncleSam
                                  @LJSven Asterisk und XOrg (der Desktop) fressen viel RAM. Ich würde mal auf reine Konsole wechseln (oder brauchst du den Desktop wirklich?) und vor dem Restore Asterisk beenden.
                                    LJSven
                                    @LJSven Asterisk und XOrg (der Desktop) fressen sehr viel RAM. Ich würde mal auf reine Konsole wechseln (oder brauchst du den Desktop wirklich?) und vor dem Restore Asterisk beenden.
                                    Nein, den Desktop brauche ich gar nicht - wie bekomme ich das weg?
                                    J UncleSamU 2 Antworten Letzte Antwort
                                      Jan1
                                      @UncleSam
                                      Warte mal wenn Thomas einsteigt und was zum Thema Desktop auf nem Linux Server sagt ;)
                                      Wenn da nur IOBroker drauf laufen soll, hat das nix drauf verloren und frisst nur, wobei beim Restor der nicht in die höhe gehen sollte , wenn man alles über die Konsole erledigt, egal wie der Restor durchgeführt wird.
                                      • L LJSven
                                        Jan1
                                        @LJSven
                                        Auf Runlevle 3 wechseln und das nächste Mal beim Ubuntu installieren erst gar nicht aus wählen ;)
                                        • L LJSven
                                          UncleSamU Offline
                                          UncleSamU Offline
                                          UncleSam
                                          @LJSven Ja, hast Glück, dass Thomas noch nicht wach ist :-P
                                          Bei Ubuntu kannst du es scheinbar so machen:
                                          https://linuxconfig.org/how-to-disable-enable-gui-on-boot-in-ubuntu-20-04-focal-fossa-linux-desktop
                                          sudo systemctl set-default multi-user
                                          L Thomas BraunT 2 Antworten Letzte Antwort
