  4. MQTT-Instanz(en) gehen auf gelb
    6.7k
mqtt problem
36 Beiträge 5 Kommentatoren 3.2k Aufrufe 3 Beobachtet
  • M MeinhardRisch
    Also ...
    neu aufgesetzt, Data-Ordner zurückkopiert, Berechtigungen gechecked, ... gleiches Ergebnis. Daher hier mal der Log-Auszug mit der Instanz auf Debug:
    2020-12-12 16:54:37.457 - info: host.raspberrypi "system.adapter.mqtt.0" disabled
    2020-12-12 16:54:37.459 - info: host.raspberrypi stopInstance system.adapter.mqtt.0 (force=false, process=true)
    2020-12-12 16:54:37.461 - info: host.raspberrypi stopInstance system.adapter.mqtt.0 send kill signal
    2020-12-12 16:54:37.465 - debug: mqtt.0 (32737) stateChange system.adapter.mqtt.0.sigKill: {"val":-1,"ack":false,"ts":1607788477460,"q":0,"from":"system.host.raspberrypi","lc":1607788477460}
    2020-12-12 16:54:37.467 - debug: mqtt.0 (32737) onStateChange system.adapter.mqtt.0.sigKill: {"val":-1,"ack":false,"ts":1607788477460,"q":0,"from":"system.host.raspberrypi","lc":1607788477460}
    2020-12-12 16:54:37.467 - info: mqtt.0 (32737) Got terminate signal TERMINATE_YOURSELF
    2020-12-12 16:54:37.801 - debug: mqtt.0 (32737) stateChange system.adapter.shelly.0.alive: {"val":true,"ack":true,"ts":1607788477796,"q":0,"from":"system.adapter.shelly.0","lc":1607776807557,"expire":true}
    2020-12-12 16:54:37.808 - debug: mqtt.0 (32737) stateChange system.adapter.shelly.0.connected: {"val":true,"ack":true,"ts":1607788477796,"q":0,"from":"system.adapter.shelly.0","lc":1607776807560,"expire":true}
    2020-12-12 16:54:37.811 - debug: mqtt.0 (32737) stateChange system.adapter.shelly.0.memRss: {"val":108.37,"ack":true,"ts":1607788477797,"q":0,"from":"system.adapter.shelly.0","lc":1607788477797}
    2020-12-12 16:54:37.815 - debug: mqtt.0 (32737) stateChange system.adapter.shelly.0.memHeapTotal: {"val":26.18,"ack":true,"ts":1607788477797,"q":0,"from":"system.adapter.shelly.0","lc":1607788432799}
    2020-12-12 16:54:37.826 - debug: mqtt.0 (32737) stateChange system.adapter.shelly.0.memHeapUsed: {"val":24.35,"ack":true,"ts":1607788477797,"q":0,"from":"system.adapter.shelly.0","lc":1607788477797}
    2020-12-12 16:54:37.831 - debug: mqtt.0 (32737) stateChange system.adapter.shelly.0.eventLoopLag: {"val":1,"ack":true,"ts":1607788477797,"q":0,"from":"system.adapter.shelly.0","lc":1607786362755}
    2020-12-12 16:54:37.844 - debug: mqtt.0 (32737) stateChange system.adapter.shelly.0.uptime: {"val":11673,"ack":true,"ts":1607788477797,"q":0,"from":"system.adapter.shelly.0","lc":1607788477797}
    2020-12-12 16:54:37.860 - debug: mqtt.0 (32737) stateChange system.adapter.shelly.0.inputCount: {"val":19,"ack":true,"ts":1607788477798,"q":0,"from":"system.adapter.shelly.0","lc":1607788477798}
    2020-12-12 16:54:37.867 - debug: mqtt.0 (32737) stateChange system.adapter.shelly.0.outputCount: {"val":30,"ack":true,"ts":1607788477798,"q":0,"from":"system.adapter.shelly.0","lc":1607788477798}
    2020-12-12 16:54:37.874 - debug: mqtt.0 (32737) stateChange system.adapter.shelly.0.cpu: {"val":1.27,"ack":true,"ts":1607788477838,"q":0,"from":"system.adapter.shelly.0","lc":1607788477838}
    2020-12-12 16:54:37.875 - debug: mqtt.0 (32737) stateChange system.adapter.shelly.0.cputime: {"val":182.44,"ack":true,"ts":1607788477838,"q":0,"from":"system.adapter.shelly.0","lc":1607788477838}
    2020-12-12 16:54:37.903 - debug: mqtt.0 (32737) stateChange info.0.sysinfo.memory.info.free: {"val":135516160,"ack":true,"ts":1607788477899,"q":0,"from":"system.adapter.info.0","user":"system.user.admin","lc":1607788477899}
    2020-12-12 16:54:37.905 - debug: mqtt.0 (32737) stateChange info.0.sysinfo.memory.info.used: {"val":1898143744,"ack":true,"ts":1607788477900,"q":0,"from":"system.adapter.info.0","user":"system.user.admin","lc":1607788477900}
    2020-12-12 16:54:37.907 - debug: mqtt.0 (32737) stateChange info.0.sysinfo.memory.info.active: {"val":795451392,"ack":true,"ts":1607788477900,"q":0,"from":"system.adapter.info.0","user":"system.user.admin","lc":1607788477900}
    2020-12-12 16:54:37.909 - debug: mqtt.0 (32737) stateChange info.0.sysinfo.memory.info.used_hist: {"val":"0.809705472,0.773623808,0.777711616,0.777486336,0.77774848,0.77697024,0.776421376,0.77555712,0.775593984,0.777007104,0.776462336,0.7770112,0.779333632,0.779972608,0.779964416,0.779522048,0.778809344,0.778842112,0.777670656,0.789848064,0.806653952,0.8312832,0.831442944,0.829882368,0.799346688,0.798523392,0.797433856,0.797433856,0.794140672,0.795451392","ack":true,"ts":1607788477900,"q":0,"from":"system.adapter.info.0","user":"system.user.admin","lc":1607788477900}
    2020-12-12 16:54:37.910 - debug: mqtt.0 (32737) stateChange info.0.sysinfo.memory.info.available: {"val":1238208512,"ack":true,"ts":1607788477900,"q":0,"from":"system.adapter.info.0","user":"system.user.admin","lc":1607788477900}
    2020-12-12 16:54:37.912 - debug: mqtt.0 (32737) stateChange info.0.sysinfo.memory.info.buffcache: {"val":1136525312,"ack":true,"ts":1607788477900,"q":0,"from":"system.adapter.info.0","user":"system.user.admin","lc":1607788477900}
    2020-12-12 16:54:37.914 - debug: mqtt.0 (32737) stateChange info.0.sysinfo.memory.info.swapused: {"val":1048576,"ack":true,"ts":1607788477900,"q":0,"from":"system.adapter.info.0","user":"system.user.admin","lc":1607776609695}
    2020-12-12 16:54:37.915 - debug: mqtt.0 (32737) stateChange info.0.sysinfo.memory.info.swapfree: {"val":103804928,"ack":true,"ts":1607788477900,"q":0,"from":"system.adapter.info.0","user":"system.user.admin","lc":1607776609696}
    2020-12-12 16:54:37.923 - debug: mqtt.0 (32737) stateChange info.0.sysinfo.cpu.temperature.main: {"val":42.355,"ack":true,"ts":1607788477919,"q":0,"from":"system.adapter.info.0","user":"system.user.admin","lc":1607788477919}
    2020-12-12 16:54:37.925 - debug: mqtt.0 (32737) stateChange info.0.sysinfo.cpu.temperature.main_hist: {"val":"42.842,41.868,42.842,41.868,42.842,41.868,41.868,42.842,42.355,42.355,41.868,41.868,42.842,41.868,42.355,41.868,42.355,40.894,42.355,43.816,42.355,42.842,43.329,41.868,42.842,43.329,42.842,43.329,42.842,42.355","ack":true,"ts":1607788477919,"q":0,"from":"system.adapter.info.0","user":"system.user.admin","lc":1607788477919}
    2020-12-12 16:54:37.929 - debug: mqtt.0 (32737) stateChange info.0.sysinfo.cpu.temperature.cores: {"val":[],"ack":true,"ts":1607788477920,"q":0,"from":"system.adapter.info.0","user":"system.user.admin","lc":1559630510377}
    2020-12-12 16:54:37.933 - debug: mqtt.0 (32737) stateChange info.0.sysinfo.cpu.temperature.max: {"val":42.355,"ack":true,"ts":1607788477920,"q":0,"from":"system.adapter.info.0","user":"system.user.admin","lc":1607788477920}
    2020-12-12 16:54:38.005 - info: mqtt.0 (32737) terminating
    2020-12-12 16:54:38.006 - debug: mqtt.0 (32737) Plugin sentry destroyed
    2020-12-12 16:54:38.007 - info: mqtt.0 (32737) Terminated (NO_ERROR): Without reason
    2020-12-12 16:54:38.008 - debug: mqtt.0 (32737) stateChange system.adapter.mqtt.0.alive: {"val":false,"ack":true,"ts":1607788478002,"q":0,"from":"system.adapter.mqtt.0","lc":1607788478002}
    2020-12-12 16:54:38.341 - debug: mqtt.0 (32737) stateChange shelly.0.SHSW-1#E09806967F58#1.uptime: {"val":"14D02:19:00","ack":true,"ts":1607788478339,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1607788478339}
    2020-12-12 16:54:38.463 - info: host.raspberrypi stopInstance system.adapter.mqtt.0 killing pid 32737
    2020-12-12 16:54:38.532 - info: host.raspberrypi instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
    MOD-Edit: Code in code-tags gesetzt!
    Sieht jemand hier einen Grund für Anzeige Gelb ?
    Danke Euch für die Ratschläge ;-)
    @MeinhardRisch Was sagt top und iobroker list instances?
    M 2 Antworten Letzte Antwort
    • M MeinhardRisch
      Also ...
      MeinhardRisch
      @MeinhardRisch hier list instances:
      pi@raspberrypi:/opt/iobroker $
      pi@raspberrypi:/opt/iobroker $ iobroker list instances
      + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                : alexa2                -  enabled
      + system.adapter.backitup.0              : backitup              -  enabled
      + system.adapter.discovery.0             : discovery             -  enabled
        system.adapter.flot.0                  : flot                  -  enabled
        system.adapter.fritzdect.0             : fritzdect             - disabled
      + system.adapter.history.0               : history               -  enabled
      + system.adapter.info.0                  : info                  -  enabled
      + system.adapter.iot.0                   : iot                   -  enabled
      + system.adapter.javascript.0            : javascript            -  enabled
      + system.adapter.javascript.1            : javascript            -  enabled
      + system.adapter.mihome-vacuum.0         : mihome-vacuum         -  enabled, port: 54321
        system.adapter.mobile.0                : mobile                - disabled
        system.adapter.mqtt.0                  : mqtt                  - disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.shelly.0                : shelly                -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.vis-history.0           : vis-history           - disabled
        system.adapter.vis-timeandweather.0    : vis-timeandweather    -  enabled
        system.adapter.vis.0                   : vis                   -  enabled
      + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
        MeinhardRisch
        @Homoran und hier kommt top:
          MeinhardRisch
          @Homoran und noch kurz ein Screenshot... ich hoffe, er hilft Dir weiter...
          G HomoranH 2 Antworten Letzte Antwort
          • M MeinhardRisch
            guergen
            @MeinhardRisch Der MQTT-Host geht auf gelb, wenn er keine Clients mehr hat, sind die evtuell weg?
            • M MeinhardRisch
              @MeinhardRisch sagte in MQTT-Instanz(en) gehen auf gelb:
              nichts so wirklich.
              Ich habe nichts gefunden, was die Beendigung der Instanz begründen könnte.
              Bleibt eigentlich wirklich nur der Kontaktverlust, wie @guergen schreibt.
              Was hast du denn für Clients?
              G 1 Antwort Letzte Antwort
                nichts so wirklich.
                guergen
                @MeinhardRisch Installiere doch spasseshalber mal den MQTT-Client, wenn der es dann schafft, dass der Broker grün wird, liegt es definitiv an den Clients.
                Richtiges Passwort und IP vorausgesetzt!
                • G guergen
                  Jan1
                  @guergen
                  Hat sich da die IP des Host geändert und die Clients laufen ins Leere und warum das Backup nicht mit dem Adapter eingespielt und schon wieder Ordner kopiert?
                  G M 2 Antworten Letzte Antwort
                  • G guergen
                    MeinhardRisch
                    @guergen gerade getest, client kommt auch nicht hoch, :-(
                    • J Jan1
                      @guergen
                      guergen
                      @MeinhardRisch Was ich mich auch noch frage ist, warum hat man shellys im MQTT-Adapter, sonoffs im sonoff-Adapter?
                      Gehen doch auch alle in einem MQTT-Broker.
                      Oder stringent getrennt:
                      Sonoff-->Sonoff-Adapter
                      Shelly-->Shelly-Adapter
                      Rest-->MQTT-Adapter
                      • J Jan1
                        @guergen
                        MeinhardRisch
                        @Jan1 IP und MAC ist identisch, Clients sind unterschiedlich, Raspi mit Phyton, ESP8266, ...
                        • M MeinhardRisch
                          guergen
                          @MeinhardRisch Aber IP, User und Passwort stimmen überein? Nochmal neu eingegeben? So testweise mal ein neues?
                          • G guergen
                            Rest-->MQTT-Adapter
                            MeinhardRisch
                            @guergen genau wie Du schreibst, alles schön getrennt :
                            Sonoff zu Sonoff,
                            Shelly zu Shelly (kein MQTT),
                            Rest zu MQTT
                            J G 2 Antworten Letzte Antwort
                            • G guergen
                              MeinhardRisch
                              @guergen Hat sich ja nichts geändert.... ging gestern um 10:58 auf gelb, ich habe es erst abends bemerkt
                              • M MeinhardRisch
                                Sonoff zu Sonoff,
                                Rest zu MQTT
                                Jan1
                                @MeinhardRisch
                                Ok, wen die Clients down sind, ist der Adapter gelb. Bleibt die Frage warum die Clients down sind.
                                • M MeinhardRisch
                                  Sonoff zu Sonoff,
                                  Rest zu MQTT
                                  guergen
                                  @MeinhardRisch Das sieht mir aber nicht so aus:
                                  Warum ist denn im mqtt.0 ein shelly.0?
                                  M J 2 Antworten Letzte Antwort
                                  • G guergen
                                    MeinhardRisch
                                    @guergen stimmt, sehe ich auch gerade, ....
                                    • G guergen
                                      Jan1
                                      @guergen
                                      Auch ein Grund warum bei mir überall Tasmota drauf ist. Ein Adapter und keine Chance für Konflikte, geht auch anders ohne, aber ich mag das eben so.
                                      • M MeinhardRisch
                                        guergen
                                        @MeinhardRisch Ich denke hier liegt ein Problem mit den Ports vor, da würde ich anfangen zu suchen!
                                        • J Jan1
                                          @guergen
                                          guergen
                                          @Jan1 Tasmota habe ich nur auf den Sonoff-Geräten, auf den Shellys läuft die originale FW
                                          -OT hast Du evtl auch nen Shelly1PM mit Tasmota laufen? suche da noch das ultimative Template für....
