  3. Entwicklung
  4. ZigBee neue Version 1.4.0
    6.3k
zigbeeneugitalpha
393 Beiträge 62 Kommentatoren 125.9k Aufrufe 68 Beobachtet
  • M Mr.X
    @Asgothian Ja, kann ich beim nächsten mal machen.
    ich habe mehrmals den Adapter gestartet und auf einmal e voila:
    zigbee.0
    2020-12-08 19:01:14.339
    error
    (4455) Device 0x90fd9ffffe8a09d4 "undefined" not described in statesMapping.
    zigbee.0
    2020-12-08 19:01:14.139
    info
    (4455) Zigbee started
    zigbee.0
    2020-12-08 19:01:14.138
    info
    (4455) 0xbc33acfffe0ebcf2 (addr 65202): HG06337 - Lidl Silvercrest smart plug (Router)
    zigbee.0
    2020-12-08 19:01:14.135
    info
    (4455) 0xbc33acfffe0ebd34 (addr 45265): HG06337 - Lidl Silvercrest smart plug (Router)
    zigbee.0
    2020-12-08 19:01:14.132
    info
    (4455) 0x842e14fffe556652 (addr 44502): HG06338 - Lidl Silvercrest 3 gang switch, possibly with USB (Router)
    zigbee.0
    2020-12-08 19:01:14.129
    info
    (4455) 0x842e14fffee1bb8f (addr 63253): HG06338 - Lidl Silvercrest 3 gang switch, possibly with USB (Router)
    zigbee.0
    2020-12-08 19:01:14.127
    info
    (4455) 0x0017880108b7ba14 (addr 55123): 8718699673147 - Philips Hue white A60 bulb E27 bluetooth (Router)
    zigbee.0
    2020-12-08 19:01:14.125
    info
    (4455) 0x90fd9ffffe8a09d4 (addr 21330): Not supported (model undefined)(Unknown)
    zigbee.0
    2020-12-08 19:01:14.124
    info
    (4455) 0x000b57fffec367c3 (addr 26913): LED1545G12 - IKEA TRADFRI LED bulb E26/E27 980 lumen, dimmable, white spectrum, opal white (Router)
    zigbee.0
    2020-12-08 19:01:14.122
    info
    (4455) 0x00158d0004041f71 (addr 53371): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    zigbee.0
    2020-12-08 19:01:14.120
    info
    (4455) 0x005043c903241a3e (addr 47918): HS1SA - HEIMAN Smoke detector (EndDevice)
    zigbee.0
    2020-12-08 19:01:14.118
    info
    (4455) 0x005043c9032455a3 (addr 41038): HS1SA - HEIMAN Smoke detector (EndDevice)
    zigbee.0
    2020-12-08 19:01:14.117
    info
    (4455) 0x005043c90324538e (addr 39166): HS1SA - HEIMAN Smoke detector (EndDevice)
    zigbee.0
    2020-12-08 19:01:14.115
    info
    (4455) 0x005043c903245474 (addr 6269): HS1SA - HEIMAN Smoke detector (EndDevice)
    zigbee.0
    2020-12-08 19:01:14.113
    info
    (4455) 0x005043c903386694 (addr 44701): HS1SA - HEIMAN Smoke detector (EndDevice)
    zigbee.0
    2020-12-08 19:01:14.111
    info
    (4455) 0x00158d0004042192 (addr 65354): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    zigbee.0
    2020-12-08 19:01:14.110
    info
    (4455) 0x000b57fffec1f6ec (addr 28034): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
    zigbee.0
    2020-12-08 19:01:14.108
    info
    (4455) 0x000b57fffe9e650d (addr 38936): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
    zigbee.0
    2020-12-08 19:01:14.105
    info
    (4455) 0x000b57fffe2b7dea (addr 5574): ICTC-G-1 - IKEA TRADFRI wireless dimmer (EndDevice)
    zigbee.0
    2020-12-08 19:01:14.103
    info
    (4455) 0x84182600000f74b5 (addr 9139): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
    zigbee.0
    2020-12-08 19:01:14.101
    info
    (4455) 0x90fd9ffffe6d32bc (addr 34524): LED1546G12 - IKEA TRADFRI LED bulb E26/E27 950 lumen, dimmable, white spectrum, clear (Router)
    zigbee.0
    2020-12-08 19:01:14.099
    info
    (4455) 0x00158d0003f045f4 (addr 42828): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
    zigbee.0
    2020-12-08 19:01:14.097
    info
    (4455) 0x00158d0004252ae8 (addr 42379): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
    zigbee.0
    2020-12-08 19:01:14.095
    info
    (4455) 0x00158d000425298b (addr 62172): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (Unknown)
    zigbee.0
    2020-12-08 19:01:14.093
    info
    (4455) 0x00158d0002a374e8 (addr 51270): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
    zigbee.0
    2020-12-08 19:01:14.076
    info
    (4455) 0x00158d00041cd4e6 (addr 37917): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
    zigbee.0
    2020-12-08 19:01:14.063
    info
    (4455) Currently 24 devices are joined:
    zigbee.0
    2020-12-08 19:01:14.053
    info
    (4455) --> transmitPower : high
    zigbee.0
    2020-12-08 19:01:14.042
    info
    (4455) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190223}}
    statistics.0
    2020-12-08 19:01:13.032
    debug
    (1743) system.adapter.admin.0: logging true
    zigbee.0
    2020-12-08 19:01:05.280
    info
    (4455) Installed Version: iobroker.zigbee@1.4.0
    zigbee.0
    2020-12-08 19:01:05.131
    info
    (4455) Starting Zigbee npm ...
    zigbee.0
    2020-12-08 19:01:05.006
    info
    (4455) starting. Version 1.4.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.0, js-controller: 3.1.6
    Ziehe den nachher mal ab, und probiere es.
    Wirklich ALLES läuft bei mir sauber, es ist aber immer nur der verkackte Zigbee Adapter...…..
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @Mr-X Ich geb Dir einen Hinweis was da Probleme macht:
    • Du bist weil du brand neue Geräte nutzen willst im latest unterwegs - da sind Effekte vorhanden
    • Du nutzt den cc2531- der ist einfach ein wenig schwach auf der Brust. Insbesondere macht es beim update Sinn das du zuerst den Adapter beendest, dann etwas wartest und dann den neuen Adapter installierst.
    Seit ich vom cc2531 weg bin sind auch die Probleme Geschichte.
    A.
    p.s. ausser den Problemen die ich beim Basteln selber ein baue. Davon gibts genug.
    • F Frank579
      @arteck
      @arteck sagte in ZigBee neue Version 1.4.0:
      @Frank579 welcher Router ??
      der Ikea Tradfri repeater, sorry hätte ich erwähnen sollen ....
      Frank579
      @Frank579 sagte in ZigBee neue Version 1.4.0:
      @arteck
      Benötigst du noch mehr Daten bin jetzt wieder Zuhause ....
      • AsgothianA Asgothian
        A.
        Mr.X
        @Asgothian sorry, habe mich vertan, die 1.4 ist doch stable.
        Und zu meiner Schande hang doch noch der deconz am USB, alles abgesteckt, reboot.
        Alles lief für ein paar Minuten und nun wieder gelb.
        Habe aber nun 24 Geräte dran, liegt es vielleicht daran?
        • M Mr.X
          @Mr-X
          zigbee Versions:
          github:	1.4.0
          latest:	1.4.0 for 3 days
          stable:	1.3.1 for 39 days
          • H hoktar
            Ich glaube die RGB-Lampe vom Lidl wird nicht richtig unterstützt. Ich kann sie zwar anlernen, aber außer An/Aus und die RGB Farben kann ich nichts machen. Habe sie heute auch schon umgetauscht , aber auch mit der neuen keine Veränderung. Eigentlich sollte sie doch auch in Weiß leuchten und die Farbtemperatur einstellen können. Dimmen kann ich gar nicht genau sagen ob das funktioniert oder nicht.
            MfG Bastian
            RGB zigbee lampe.JPG RGB zigbee lampe restart.JPG RGB zigbee lampe Lidl.JPG RGB zigbee lampe Geräteinfo.JPG RGB zigbee lampe Bild.JPG
            Scavi
            @hoktar Hab heute den Lidl Light Strip in Betrieb genommen.
            Soweit so gut. Bei mir funktioniert "effect" nicht. Color_temp hat sich zwischen werten von 50 - 600 nichts geändert.
            Transition in Sekunden hat auch nicht funktioniert.
            Ansosten Top Leistung dafür das die Geräte quasi noch neu sind.
            Achja Adapter ist auf 1.4.0 mit Node.js v10.21.0. Werd ich mal die Tage updaten.. :)
            H 1 Antwort Letzte Antwort
              @Mr-X
              zigbee Versions:
              github:	1.4.0
              Mr.X
              @Thomas-Braun puuh, danke.
              Dann werde ich das mal beobachten und hoffe dass ich downgraden kann, wenn es weiterhin so bleibt.
              • M Mr.X
                Mr.X
                Danke an alle, offenbar läuft 1.4 bei mir nicht. ist mehr gelb als grün.
                Gibts einen empfehlenswerten weg zum downgraden?
                • M Mr.X
                  @Mr-X Verwahrort auf stable ändern, dann die Version von dort picken.
                  M 2 Antworten Letzte Antwort
                  • S Scavi
                    hoktar
                    @Scavi said in ZigBee neue Version 1.4.0:
                    Ja, bei mir genauso. Mal abwarten wird bestimmt bald gehen
                      Mr.X
                      @Thomas-Braun DANKE SEHR
                        Mr.X
                        schrieb am zuletzt editiert von Mr.X
                        Guten morgen, also auch auf die Gefahr hin, dass ich nerve.
                        Ich kann Verwahrungsort nicht auf stable stellen, der schlägt nur default und latest vor.
                        auf default zeigt er mir Zigbee 0.10.2 an.
                        Würde aber gerne auf die 1.3.1 zurück gehen.
                        Wie meintest du das mit "picken"? Mit Plus macht er eine neue Instanz, Wenn ich die alte Lösche, werden dann alle Daten (angelernte Devices), auch gelöscht?!
                        Würde natürlich gerne downgraden und dann alles behalten wollen.
                        • M Mr.X
                          @Mr-X
                          default ist stable.
                          Stell das mal darauf ein und dann sollte man im Reiter Adapter (ggf. die Experten-Ansicht einstellen) zusätzlich ein Icon mit Pluszeichen sehen. Da kann man dann eine bestimmte Version auswählen.
                            @Mr-X
                            default ist stable.
                            Mr.X
                            @Thomas-Braun Yap, der Expertenmodus war de richtige Hinweis.
                            Das Pluszeichen zeigt mir aber leider nur 1.2 an. meine 1.3.x gehabt zu haben vor dem updgrade auf 1.4.
                            Leider bin ich mir trotz gerade gelesener Doku unsicher:
                            ich belasse die eine und einzige Instanz, so wie sie ist, und drücke dann auf das eckige Pluszeichen (Bestimmte Version installieren).
                            Somit wird dann statt der 1.4 auf die 1.(was auch immer ich wähle) downgegradet und alle Devices sind wie beim upgrade weiterhin drin?
                            Kann ich es so versuchen, um auf die 1.3.x zu kommen:
                            cd /opt/iobroker
                            npm install iobroker.zigbee@1.3.1 --production
                            Vielen Dank nochmals.
                            • M Mr.X
                              cd /opt/iobroker
                              @Mr-X
                              Sollte auch gehen.
                              Aber statt npm besser den wrapper iobroker verwenden.
                              Also
                              iobroker update
                              iobroker upgrade
                              iobroker install iobroker.zigbee@1.3.1
                              Die genaue Syntax habe ich aber nicht im Kopf.
                                @Slowman
                                Die Meldung Ist abgehackt. Das wichtige (das Ende) fehlt. Bitte das log herunter laden, die zeile(n) finden, dann neu posten.
                                A.
                                SlowmanS Offline
                                SlowmanS Offline
                                Slowman
                                @Asgothian
                                wie gesagt aktuelle 1.4 Version.
                                2020-12-09 11:50:07.111 - error: zigbee.0 (11139) Error on send command to 0x7cb03eaa0a0082cd. Error: Error: Command 0x7cb03eaa0a0082cd/3 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (Timeout - 60035 - 3 - 209 - 6 - 11 after 10000ms)
                                at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:46:35)
                                at listOnTimeout (internal/timers.js:554:17)
                                at processTimers (internal/timers.js:497:7)
                                2020-12-09 11:51:35.803 - error: zigbee.0 (11139) Error on send command to 0x7cb03eaa0a0082cd. Error: Error: Command 0x7cb03eaa0a0082cd/3 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (Timeout - 60035 - 3 - 211 - 6 - 11 after 10000ms)
                                • SlowmanS Slowman
                                  @Asgothian
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  #66
                                  @Slowman
                                  Diese Meldung deutet darauf hin das es keine Funkverbindung zum Gerät gibt. Es bestätigt die gesendete Nachricht nicht. Du solltest also die üblichen Verdächtigen zum Thema Funkverbindungen prüfen:
                                  • Zigbee Kanal
                                  • WLan Kanal
                                  • DECT Telefone
                                  • Lage des Koordinators relativ zu WLan clients und Access points
                                  A.
                                    @Mr-X
                                    Sollte auch gehen.
                                    Also
                                    iobroker update
                                    iobroker upgrade
                                    Mr.X
                                    #67
                                    @Thomas-Braun Thomas, ich danke dir tausendfach für deine Unterstützung.
                                    interessanterweise läuft der Adapter heute schon mehrere Stunden ohne Probleme.
                                    sollte das wieder spinnen werde ich down graden.
                                    Ich habe hier noch einen Conbee, wäre es möglich den mit 1.4 laufen zu lassen, also direkt im Zigbee Adapter, und den anderen Stick mit 1.3.1?
                                    • M Mr.X
                                      #68
                                      @Mr-X Du kannst mehrere Instanzen haben, aber nicht mehrere Versionen der Adapter.
                                        Mr.X
                                        #69
                                        @Thomas-Braun Das habe ich befürchtet. Schade eigentlich. so könnte man ein Produktiv System haben und mit zusätzlicher HW ein Testsystem...
                                        • M Mr.X
                                          #70
                                          @Mr-X Zwei unabhängige Systeme kannst du natürlich aufsetzen.
                                          Insbesondere bei Zigbee müsstest du halt nur die Geräte immer neu anlernen, das will man aber ja auch nicht.
