  4. Pushsafer
    6.8k
Pushsafer
32 Beiträge 6 Kommentatoren 6.6k Aufrufe 1 Beobachtet
  • P Offline
    pix
    alte Instanz gelöscht,
    Update von Github gemacht
    Neue Instanz gebaut
    Neuer Fehler beim Senden der Testnachricht aus Einstellungen:
    2016-10-15 18:40:53.905 - [32minfo[39m: pushsafer.0 starting. Version 0.1.5 in /Users/pix/Documents/iobroker/node_modules/iobroker.pushsafer
    2016-10-15 18:40:53.922 - [31merror[39m: uncaught exception: Cannot read property 'toString' of undefined
    2016-10-15 18:40:53.925 - [31merror[39m: TypeError: Cannot read property 'toString' of undefined
    at sendNotification (/Users/pix/Documents/iobroker/node_modules/iobroker.pushsafer/pushsafer.js:172:26)
    at processMessage (/Users/pix/Documents/iobroker/node_modules/iobroker.pushsafer/pushsafer.js:62:5)
    at /Users/pix/Documents/iobroker/node_modules/iobroker.pushsafer/pushsafer.js:70:13
    at Command.callback (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:438:21)
    at normal_reply (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:714:21)
    at RedisClient.return_reply (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:816:9)
    at JavascriptRedisParser.Parser.returnReply (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:188:18)
    at JavascriptRedisParser.execute (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/node_modules/redis-parser/lib/parser.js:415:12)
    at Socket. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:267:27)
    at emitOne (events.js:77:13)
    2016-10-15 18:40:54.430 - [32minfo[39m: pushsafer.0 terminating
    2016-10-15 18:40:54.436 - [31merror[39m: host.MacMini-Ethernet.fritz.box instance system.adapter.pushsafer.0 terminated with code 0 (OK)</anonymous>
    • BluefoxB Offline
      BluefoxB Offline
      Noch mal vom git updaten bitte.
      • P Offline
        pix
        Hallo Bluefox,
        Versand von Text funktioniert wieder. Vielen Dank. Habe meinen altern Änderungen über Bord geworfen :lol:
        Beim Bildversand komme ich noch nicht weiter.
        Was ist mit "absolute path to picture" gemeint? Ein URL zum Bild? Der Dateipfad auf meinem Server reicht nicht (zumindest nicht der Pfad, der in anderen Skripten zum Speichern von Logs und ähnlichem reicht).
        Habe mal http://www.fastix.org/test/Data-URL-Generator.php eine Grafik codiert, aber den ganzen String kann man ja auch nicht speichern (der Ace-Editor mag das gar nicht). Ausserdem soll das ja auch on the fly passieren.
        Kannst du mal ein Beispiel für den Grafikversand geben?
        Danke!
        Pix
        EDIT: Testnachrichten vom Einstellungsfenster gehen immer noch nicht raus.
        • BluefoxB Offline
          BluefoxB Offline
          Alles gefixt.
          sendTo("pushsafer.0", "send", {
             message: 'Hallo',
             sound: "",
             vibration: "",
             picture: 'C:\\pWork\\iobroker-data\\files\\vis\\img\\bulb_on.png'
          Wieder vom git.
          • P Offline
            pix
            Hallo Bluefox,
            jetzt klappt es. Allerdings musste ich bei meinem System den Pfad etwas anders schreiben:````
            var pfadlokal = "/Users/pix/Documents/airsonosstarten.png";
            sendTo('pushsafer.0', {
            message: 'Test text', // mandatory - your text message
            title: 'Foto Test', // optional - your message's title, otherwise your app's name is used
            device: '322', // optional - a device id or device group id (empty or a = all devices)
            sound: '5', // optional - a number betwenn 0-28 (see pushsafers API description)
            icon: '2', // optional - a number betwenn 1-98 (see pushsafers API description)
            vibration: '3', // optional - a number betwenn 0-3 (see pushsafers API description)
            picture: pfadlokal, // optional - absolute path to picture or base64 coded image URL
            //picture2: 'absolutePathToPicture2', // optional - absolute path to picture or base64 coded image URL
            //picture3: 'absolutePathToPicture3', // optional - absolute path to picture or base64 coded image URL
            url: yrno,// optional - URL in the link
            urlTitle: 'YR.no Wettervorhersage' // optional - title of URL
            Vielen Dank!
            Pix
            • BluefoxB Offline
              BluefoxB Offline
              Es geht auch so:
              • R Offline
                rascal
                Hey, ich habe das Problem, dass der Adapter nur ein Mal funktioniert, danach muss ich ihn neu starten, sonst sendet er nichts mehr.
                Gesendet von meinem HUAWEI CRR-L09 mit Tapatalk
                • P Offline
                  pix
                  Ich glaub, ich hab das gleiche Problem. Muss immer wieder Adapter neu starten.
                  Ist mir vorher nicht aufgefallen.
                  Pix
                  • BluefoxB Offline
                    BluefoxB Offline
                    @rascal:
                    Gesendet von meinem HUAWEI CRR-L09 mit Tapatalk `
                    Logs? Im debug?
                    • P Offline
                      pix
                      Adapter neu gestartet (debug-log) und mit hm-Aktor dreimal Pushsafer Versand ausgelöst.
                      Marker - 19.10.2016, 22:55:09
                      2016-10-19 22:55:12.399 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.alive {"val":true,"ack":true,"ts":1476910512399,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910422393}
                      2016-10-19 22:55:12.400 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.connected {"val":true,"ack":true,"ts":1476910512400,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910422394}
                      2016-10-19 22:55:12.400 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memRss {"val":41.61,"ack":true,"ts":1476910512400,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910512400}
                      2016-10-19 22:55:12.401 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memHeapTotal {"val":15.96,"ack":true,"ts":1476910512400,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910437391}
                      2016-10-19 22:55:12.401 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memHeapUsed {"val":14.38,"ack":true,"ts":1476910512401,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910512401}
                      2016-10-19 22:55:12.401 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.uptime {"val":91,"ack":true,"ts":1476910512401,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910512401}
                      2016-10-19 22:55:12.519 - [32minfo[39m: host.MacMini-Ethernet.fritz.box object change system.adapter.pushsafer.0
                      2016-10-19 22:55:12.519 - [32minfo[39m: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushsafer.0
                      2016-10-19 22:55:12.519 - [32minfo[39m: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushsafer.0 killing pid 6594
                      2016-10-19 22:55:13.022 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.alive {"val":false,"ack":true,"ts":1476910513022,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910513022}
                      2016-10-19 22:55:13.024 - [32minfo[39m: pushsafer.0 terminating
                      2016-10-19 22:55:13.032 - [32minfo[39m: host.MacMini-Ethernet.fritz.box instance system.adapter.pushsafer.0 terminated with code 0 (OK)
                      2016-10-19 22:55:15.028 - [32minfo[39m: host.MacMini-Ethernet.fritz.box instance system.adapter.pushsafer.0 started with pid 6608
                      2016-10-19 22:55:15.485 - [34mdebug[39m: pushsafer.0 objectDB connected
                      2016-10-19 22:55:15.496 - [34mdebug[39m: pushsafer.0 statesDB connected
                      2016-10-19 22:55:15.506 - [32minfo[39m: host. States connected to redis 127.0.0.1:6379
                      2016-10-19 22:55:15.510 - [34mdebug[39m: host. redis get system.adapter.pushsafer.0.alive ok: {"val":false,"ack":true,"ts":1476910513033,"q":0,"from":"system.host.MacMini-Ethernet.fritz.box","lc":1476910513022}
                      2016-10-19 22:55:15.556 - [32minfo[39m: pushsafer.0 starting. Version 0.1.6 in /Users/pix/Documents/iobroker/node_modules/iobroker.pushsafer
                      2016-10-19 22:55:15.560 - [34mdebug[39m: host. redis keys 1 *.logging
                      2016-10-19 22:55:15.561 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.alive {"val":true,"ack":true,"ts":1476910515561,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515561}
                      2016-10-19 22:55:15.562 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.connected {"val":true,"ack":true,"ts":1476910515561,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515561}
                      2016-10-19 22:55:15.563 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memRss {"val":36.59,"ack":true,"ts":1476910515562,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515562}
                      2016-10-19 22:55:15.563 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memHeapTotal {"val":18.85,"ack":true,"ts":1476910515563,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515563}
                      2016-10-19 22:55:15.564 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memHeapUsed {"val":12.43,"ack":true,"ts":1476910515564,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515564}
                      2016-10-19 22:55:15.564 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.uptime {"val":1,"ack":true,"ts":1476910515564,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515564}
                      2016-10-19 22:55:15.568 - [34mdebug[39m: host. redis mget 1 1
                      2016-10-19 22:55:17.981 - [32minfo[39m: javascript.0 script.js.common.Status.Status_Geraete: Status Heizung auf DIY Fernbedienung eingeschaltet
                      2016-10-19 22:55:17.981 - [32minfo[39m: javascript.2 script.js.Test.DIY_Schalter: Aktion ausgelöst
                      2016-10-19 22:55:17.984 - [34mdebug[39m: host. redis pmessage messagebox.system.adapter.pushsafer.0 messagebox.system.adapter.pushsafer.0 {"command":"send","message":{"message":"Test text","title":"Foto Test","device":"322","sound":"5","icon":"2","vibration":"3","picture":"/Users/pix/Documents/airsonosstarten.png"},"from":"system.adapter.javascript.2","_id":55262909}
                      2016-10-19 22:55:17.988 - [34mdebug[39m: pushsafer.0 Send pushsafer notification: Test text
                      2016-10-19 22:55:18.026 - [34mdebug[39m: pushsafer.0 Filter out double message [first was for 40ms]: {"message":"Test text","title":"Foto Test","device":"322","sound":"5","icon":"2","vibration":"3","picture":"/Users/pix/Documents/airsonosstarten.png"}
                      2016-10-19 22:55:24.728 - [32minfo[39m: javascript.2 script.js.Test.DIY_Schalter: Aktion ausgelöst
                      2016-10-19 22:55:24.728 - [32minfo[39m: javascript.0 script.js.common.Status.Status_Geraete: Status Heizung auf DIY Fernbedienung ausgeschaltet
                      2016-10-19 22:55:24.730 - [34mdebug[39m: host. redis pmessage messagebox.system.adapter.pushsafer.0 messagebox.system.adapter.pushsafer.0 {"command":"send","message":{"message":"Test text","title":"Foto Test","device":"322","sound":"5","icon":"2","vibration":"3","picture":"/Users/pix/Documents/airsonosstarten.png"},"from":"system.adapter.javascript.2","_id":55262910}
                      2016-10-19 22:55:24.732 - [34mdebug[39m: pushsafer.0 Filter out double message [first was for 1ms]: {"message":"Test text","title":"Foto Test","device":"322","sound":"5","icon":"2","vibration":"3","picture":"/Users/pix/Documents/airsonosstarten.png"}
                      2016-10-19 22:55:30.559 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.alive {"val":true,"ack":true,"ts":1476910530559,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515561}
                      2016-10-19 22:55:30.560 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.connected {"val":true,"ack":true,"ts":1476910530560,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515561}
                      2016-10-19 22:55:30.561 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memRss {"val":40.67,"ack":true,"ts":1476910530561,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910530561}
                      2016-10-19 22:55:30.561 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memHeapTotal {"val":19.84,"ack":true,"ts":1476910530561,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910530561}
                      2016-10-19 22:55:30.561 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memHeapUsed {"val":13.31,"ack":true,"ts":1476910530561,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910530561}
                      2016-10-19 22:55:30.562 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.uptime {"val":16,"ack":true,"ts":1476910530562,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910530562}
                      2016-10-19 22:55:37.776 - [32minfo[39m: javascript.2 script.js.Test.DIY_Schalter: Aktion ausgelöst
                      2016-10-19 22:55:37.776 - [32minfo[39m: javascript.0 script.js.common.Status.Status_Geraete: Status Heizung auf DIY Fernbedienung eingeschaltet
                      2016-10-19 22:55:37.777 - [34mdebug[39m: host. redis pmessage messagebox.system.adapter.pushsafer.0 messagebox.system.adapter.pushsafer.0 {"command":"send","message":{"message":"Test text","title":"Foto Test","device":"322","sound":"5","icon":"2","vibration":"3","picture":"/Users/pix/Documents/airsonosstarten.png"},"from":"system.adapter.javascript.2","_id":55262911}
                      2016-10-19 22:55:37.782 - [34mdebug[39m: pushsafer.0 Filter out double message [first was for 4ms]: {"message":"Test text","title":"Foto Test","device":"322","sound":"5","icon":"2","vibration":"3","picture":"/Users/pix/Documents/airsonosstarten.png"}
                      Definitiv nur Versand beim ersten Auslösen nach Restart. Abstand zwischen den Sendungen siehe log, aber groß genug.
                      Hoffe, das hilft.
                      Pix
                      • BluefoxB Offline
                        BluefoxB Offline
                        @pix:
                        Hoffe, das hilft.
                        Pix `
                        Habe den Fehler gefunden. Bitte updaten.
                        • P Offline
                          pix
                          Läuft wieder, danke!
                            starfish
                            was kosten eigentlich die Nachrichtenkontingente? Es schimmert immer irgerndwie durch, dass Pushsafer was kostet, aber weder auf der Homepage, noch in Foren gibts Transparenz. Einzig, dass man sich erst registrieren muss, und dann sieht man was bei den Geräten ? Ich will aber den Preis vorher wissen, bevor ich mich irgendwo registriere. Habe ich irgendwas auf der HP übersehen?
                            • eric2905E Offline
                              eric2905E Offline
                              eric2905
                              Im HowTo auf der Webseite sind Preise aufgeführt
                              ==> https://www.pushsafer.com/de/howto
                              Gruß,
                              Eric
                              Von unterwegs getippert
                                starfish
                                @eric2905:
                                Gruß,
                                Eric `
                                danke, hatte ich auch grad gefunden, aber Du warst schneller … :D
                                geht noch mit den Preisen - v.a. so ab 200K api calls.
