  4. Pushsafer
    6.8k
Pushsafer
32 Beiträge 6 Kommentatoren 6.6k Aufrufe 1 Beobachtet
  • P Offline
    pix
    Hallo Bluefox,
    ich habe das Update von Github geladen und ein Testskript gebaut:
    sendTo("pushsafer", {
            message:   'Test text',   // mandatory - your text message
            title:     'SweetHome',   // optional  - your message's title, otherwise your app's name is used
            device:    '322',          // optional  - a device id or device group id (empty or a = all devices)
            sound:     '2',           // optional  - a number betwenn 0-28 (see pushsafers API description)
            icon:      '2',           // optional  - a number betwenn 1-98 (see pushsafers API description)
            vibration: '3'           // optional  - a number betwenn 0-3 (see pushsafers API description)
            //picture:   '/Users/pix/Documents/iobroker/node_modules/iobroker.phantomjs/picture.png'  // optional - absolute path to picture or base64 coded image URL
            //picture2:  'absolutePathToPicture2', // optional - absolute path to picture or base64 coded image URL
            //picture3:  'absolutePathToPicture3', // optional - absolute path to picture or base64 coded image URL
            //url:       'http://blabla',// optional - URL in the link
            //urlTitle:  'Link to BLA'  // optional - title of URL
    Leider kommt nun immer dieser Fehler:
    2016-10-14 22:54:26.201  - [31merror[39m: host. pmessage messagebox.system.adapter.pushsafer.0 {"command":"send","message":{"message":"Test text","title":"SweetHome","device":"322","sound":"2","icon":"2","vibration":"3"},"from":"system.adapter.javascript.2","_id":22791782} Cannot read property 'log' of undefined
    2016-10-14 22:54:26.201  - [31merror[39m: host. TypeError: Cannot read property 'log' of undefined
        at sendNotification (/Users/pix/Documents/iobroker/node_modules/iobroker.pushsafer/pushsafer.js:89:44)
        at processMessage (/Users/pix/Documents/iobroker/node_modules/iobroker.pushsafer/pushsafer.js:62:5)
        at Adapter. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.pushsafer/pushsafer.js:20:40)
        at emitOne (events.js:77:13)
        at Adapter.emit (events.js:169:7)
        at that.states.States.change (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2103:34)
        at RedisClient. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:90:25)
        at emitThree (events.js:97:13)
        at RedisClient.emit (events.js:175:7)
        at return_pub_sub (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:782:18)</anonymous></anonymous>
    Der Adapter wurde in dieser Verison also nicht von mir verändert.
    Zum Testen des Bildversands komme ich nicht, wenn der Text schon nicht durchgeht. 322 für Device ist korrekt.
    Pix
    • P Offline
      pix
      Test in den Adapter Einstellungen funktioniert leider nicht (auch nicht nach Neustart ioBroker):
      2016-10-15 00:10:33.322 - [31merror[39m: host. pmessage messagebox.system.adapter.pushsafer.0 {"command":"send","message":"This is test notification!","from":"system.adapter.admin.0","callback":{"message":"This is test notification!","id":6,"ack":false,"time":1476483033321},"_id":31033365} Cannot read property 'log' of undefined
      2016-10-15 00:10:33.322 - [31merror[39m: host. TypeError: Cannot read property 'log' of undefined
      Eingestellter Schlüssel ist natürlich korrekt!
      Pix
      • P Offline
        pix
        alte Instanz gelöscht,
        Update von Github gemacht
        Neue Instanz gebaut
        Neuer Fehler beim Senden der Testnachricht aus Einstellungen:
        2016-10-15 18:40:53.905 - [32minfo[39m: pushsafer.0 starting. Version 0.1.5 in /Users/pix/Documents/iobroker/node_modules/iobroker.pushsafer
        2016-10-15 18:40:53.922 - [31merror[39m: uncaught exception: Cannot read property 'toString' of undefined
        2016-10-15 18:40:53.925 - [31merror[39m: TypeError: Cannot read property 'toString' of undefined
        at sendNotification (/Users/pix/Documents/iobroker/node_modules/iobroker.pushsafer/pushsafer.js:172:26)
        at /Users/pix/Documents/iobroker/node_modules/iobroker.pushsafer/pushsafer.js:70:13
        at Command.callback (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:438:21)
        at normal_reply (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:714:21)
        at RedisClient.return_reply (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:816:9)
        at JavascriptRedisParser.Parser.returnReply (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:188:18)
        at JavascriptRedisParser.execute (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/node_modules/redis-parser/lib/parser.js:415:12)
        at Socket. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:267:27)
        2016-10-15 18:40:54.430 - [32minfo[39m: pushsafer.0 terminating
        2016-10-15 18:40:54.436 - [31merror[39m: host.MacMini-Ethernet.fritz.box instance system.adapter.pushsafer.0 terminated with code 0 (OK)</anonymous>
        • BluefoxB Offline
          BluefoxB Offline
          Noch mal vom git updaten bitte.
          • P Offline
            pix
            Hallo Bluefox,
            Versand von Text funktioniert wieder. Vielen Dank. Habe meinen altern Änderungen über Bord geworfen :lol:
            Beim Bildversand komme ich noch nicht weiter.
            Was ist mit "absolute path to picture" gemeint? Ein URL zum Bild? Der Dateipfad auf meinem Server reicht nicht (zumindest nicht der Pfad, der in anderen Skripten zum Speichern von Logs und ähnlichem reicht).
            Habe mal http://www.fastix.org/test/Data-URL-Generator.php eine Grafik codiert, aber den ganzen String kann man ja auch nicht speichern (der Ace-Editor mag das gar nicht). Ausserdem soll das ja auch on the fly passieren.
            Kannst du mal ein Beispiel für den Grafikversand geben?
            Danke!
            Pix
            EDIT: Testnachrichten vom Einstellungsfenster gehen immer noch nicht raus.
            • BluefoxB Offline
              BluefoxB Offline
              Alles gefixt.
              sendTo("pushsafer.0", "send", {
                 message: 'Hallo',
                 sound: "",
                 vibration: "",
                 picture: 'C:\\pWork\\iobroker-data\\files\\vis\\img\\bulb_on.png'
              Wieder vom git.
              • P Offline
                pix
                Hallo Bluefox,
                jetzt klappt es. Allerdings musste ich bei meinem System den Pfad etwas anders schreiben:````
                var pfadlokal = "/Users/pix/Documents/airsonosstarten.png";
                sendTo('pushsafer.0', {
                title: 'Foto Test', // optional - your message's title, otherwise your app's name is used
                sound: '5', // optional - a number betwenn 0-28 (see pushsafers API description)
                vibration: '3', // optional - a number betwenn 0-3 (see pushsafers API description)
                picture: pfadlokal, // optional - absolute path to picture or base64 coded image URL
                url: yrno,// optional - URL in the link
                urlTitle: 'YR.no Wettervorhersage' // optional - title of URL
                Vielen Dank!
                Pix
                • BluefoxB Offline
                  BluefoxB Offline
                  Es geht auch so:
                  • R Offline
                    rascal
                    Hey, ich habe das Problem, dass der Adapter nur ein Mal funktioniert, danach muss ich ihn neu starten, sonst sendet er nichts mehr.
                    Gesendet von meinem HUAWEI CRR-L09 mit Tapatalk
                    • P Offline
                      pix
                      Ich glaub, ich hab das gleiche Problem. Muss immer wieder Adapter neu starten.
                      Ist mir vorher nicht aufgefallen.
                      Pix
                      • BluefoxB Offline
                        BluefoxB Offline
                        @rascal:
                        Gesendet von meinem HUAWEI CRR-L09 mit Tapatalk `
                        Logs? Im debug?
                        • P Offline
                          pix
                          Adapter neu gestartet (debug-log) und mit hm-Aktor dreimal Pushsafer Versand ausgelöst.
                          Marker - 19.10.2016, 22:55:09
                          2016-10-19 22:55:12.399 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.alive {"val":true,"ack":true,"ts":1476910512399,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910422393}
                          2016-10-19 22:55:12.400 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.connected {"val":true,"ack":true,"ts":1476910512400,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910422394}
                          2016-10-19 22:55:12.400 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memRss {"val":41.61,"ack":true,"ts":1476910512400,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910512400}
                          2016-10-19 22:55:12.401 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memHeapTotal {"val":15.96,"ack":true,"ts":1476910512400,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910437391}
                          2016-10-19 22:55:12.401 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memHeapUsed {"val":14.38,"ack":true,"ts":1476910512401,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910512401}
                          2016-10-19 22:55:12.401 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.uptime {"val":91,"ack":true,"ts":1476910512401,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910512401}
                          2016-10-19 22:55:12.519 - [32minfo[39m: host.MacMini-Ethernet.fritz.box object change system.adapter.pushsafer.0
                          2016-10-19 22:55:12.519 - [32minfo[39m: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushsafer.0
                          2016-10-19 22:55:12.519 - [32minfo[39m: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushsafer.0 killing pid 6594
                          2016-10-19 22:55:13.022 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.alive {"val":false,"ack":true,"ts":1476910513022,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910513022}
                          2016-10-19 22:55:13.024 - [32minfo[39m: pushsafer.0 terminating
                          2016-10-19 22:55:13.032 - [32minfo[39m: host.MacMini-Ethernet.fritz.box instance system.adapter.pushsafer.0 terminated with code 0 (OK)
                          2016-10-19 22:55:15.028 - [32minfo[39m: host.MacMini-Ethernet.fritz.box instance system.adapter.pushsafer.0 started with pid 6608
                          2016-10-19 22:55:15.485 - [34mdebug[39m: pushsafer.0 objectDB connected
                          2016-10-19 22:55:15.496 - [34mdebug[39m: pushsafer.0 statesDB connected
                          2016-10-19 22:55:15.506 - [32minfo[39m: host. States connected to redis 127.0.0.1:6379
                          2016-10-19 22:55:15.510 - [34mdebug[39m: host. redis get system.adapter.pushsafer.0.alive ok: {"val":false,"ack":true,"ts":1476910513033,"q":0,"from":"system.host.MacMini-Ethernet.fritz.box","lc":1476910513022}
                          2016-10-19 22:55:15.556 - [32minfo[39m: pushsafer.0 starting. Version 0.1.6 in /Users/pix/Documents/iobroker/node_modules/iobroker.pushsafer
                          2016-10-19 22:55:15.560 - [34mdebug[39m: host. redis keys 1 *.logging
                          2016-10-19 22:55:15.561 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.alive {"val":true,"ack":true,"ts":1476910515561,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515561}
                          2016-10-19 22:55:15.562 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.connected {"val":true,"ack":true,"ts":1476910515561,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515561}
                          2016-10-19 22:55:15.563 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memRss {"val":36.59,"ack":true,"ts":1476910515562,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515562}
                          2016-10-19 22:55:15.563 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memHeapTotal {"val":18.85,"ack":true,"ts":1476910515563,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515563}
                          2016-10-19 22:55:15.564 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memHeapUsed {"val":12.43,"ack":true,"ts":1476910515564,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515564}
                          2016-10-19 22:55:15.564 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.uptime {"val":1,"ack":true,"ts":1476910515564,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515564}
                          2016-10-19 22:55:15.568 - [34mdebug[39m: host. redis mget 1 1
                          2016-10-19 22:55:17.981 - [32minfo[39m: javascript.0 script.js.common.Status.Status_Geraete: Status Heizung auf DIY Fernbedienung eingeschaltet
                          2016-10-19 22:55:17.981 - [32minfo[39m: javascript.2 script.js.Test.DIY_Schalter: Aktion ausgelöst
                          2016-10-19 22:55:17.984 - [34mdebug[39m: host. redis pmessage messagebox.system.adapter.pushsafer.0 messagebox.system.adapter.pushsafer.0 {"command":"send","message":{"message":"Test text","title":"Foto Test","device":"322","sound":"5","icon":"2","vibration":"3","picture":"/Users/pix/Documents/airsonosstarten.png"},"from":"system.adapter.javascript.2","_id":55262909}
                          2016-10-19 22:55:17.988 - [34mdebug[39m: pushsafer.0 Send pushsafer notification: Test text
                          2016-10-19 22:55:18.026 - [34mdebug[39m: pushsafer.0 Filter out double message [first was for 40ms]: {"message":"Test text","title":"Foto Test","device":"322","sound":"5","icon":"2","vibration":"3","picture":"/Users/pix/Documents/airsonosstarten.png"}
                          2016-10-19 22:55:24.728 - [32minfo[39m: javascript.2 script.js.Test.DIY_Schalter: Aktion ausgelöst
                          2016-10-19 22:55:24.728 - [32minfo[39m: javascript.0 script.js.common.Status.Status_Geraete: Status Heizung auf DIY Fernbedienung ausgeschaltet
                          2016-10-19 22:55:24.730 - [34mdebug[39m: host. redis pmessage messagebox.system.adapter.pushsafer.0 messagebox.system.adapter.pushsafer.0 {"command":"send","message":{"message":"Test text","title":"Foto Test","device":"322","sound":"5","icon":"2","vibration":"3","picture":"/Users/pix/Documents/airsonosstarten.png"},"from":"system.adapter.javascript.2","_id":55262910}
                          2016-10-19 22:55:24.732 - [34mdebug[39m: pushsafer.0 Filter out double message [first was for 1ms]: {"message":"Test text","title":"Foto Test","device":"322","sound":"5","icon":"2","vibration":"3","picture":"/Users/pix/Documents/airsonosstarten.png"}
                          2016-10-19 22:55:30.559 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.alive {"val":true,"ack":true,"ts":1476910530559,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515561}
                          2016-10-19 22:55:30.560 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.connected {"val":true,"ack":true,"ts":1476910530560,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910515561}
                          2016-10-19 22:55:30.561 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memRss {"val":40.67,"ack":true,"ts":1476910530561,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910530561}
                          2016-10-19 22:55:30.561 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memHeapTotal {"val":19.84,"ack":true,"ts":1476910530561,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910530561}
                          2016-10-19 22:55:30.561 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.memHeapUsed {"val":13.31,"ack":true,"ts":1476910530561,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910530561}
                          2016-10-19 22:55:30.562 - [34mdebug[39m: host. redis publish io.system.adapter.pushsafer.0.uptime {"val":16,"ack":true,"ts":1476910530562,"q":0,"from":"system.adapter.pushsafer.0","lc":1476910530562}
                          2016-10-19 22:55:37.776 - [32minfo[39m: javascript.2 script.js.Test.DIY_Schalter: Aktion ausgelöst
                          2016-10-19 22:55:37.776 - [32minfo[39m: javascript.0 script.js.common.Status.Status_Geraete: Status Heizung auf DIY Fernbedienung eingeschaltet
                          2016-10-19 22:55:37.777 - [34mdebug[39m: host. redis pmessage messagebox.system.adapter.pushsafer.0 messagebox.system.adapter.pushsafer.0 {"command":"send","message":{"message":"Test text","title":"Foto Test","device":"322","sound":"5","icon":"2","vibration":"3","picture":"/Users/pix/Documents/airsonosstarten.png"},"from":"system.adapter.javascript.2","_id":55262911}
                          2016-10-19 22:55:37.782 - [34mdebug[39m: pushsafer.0 Filter out double message [first was for 4ms]: {"message":"Test text","title":"Foto Test","device":"322","sound":"5","icon":"2","vibration":"3","picture":"/Users/pix/Documents/airsonosstarten.png"}
                          Definitiv nur Versand beim ersten Auslösen nach Restart. Abstand zwischen den Sendungen siehe log, aber groß genug.
                          Hoffe, das hilft.
                          Pix
                          • BluefoxB Offline
                            BluefoxB Offline
                            @pix:
                            Hoffe, das hilft.
                            Pix `
                            Habe den Fehler gefunden. Bitte updaten.
                            • P Offline
                              pix
                              Läuft wieder, danke!
                                starfish
                                was kosten eigentlich die Nachrichtenkontingente? Es schimmert immer irgerndwie durch, dass Pushsafer was kostet, aber weder auf der Homepage, noch in Foren gibts Transparenz. Einzig, dass man sich erst registrieren muss, und dann sieht man was bei den Geräten ? Ich will aber den Preis vorher wissen, bevor ich mich irgendwo registriere. Habe ich irgendwas auf der HP übersehen?
                                • eric2905E Offline
                                  eric2905E Offline
                                  eric2905
                                  Im HowTo auf der Webseite sind Preise aufgeführt
                                  ==> https://www.pushsafer.com/de/howto
                                  Gruß,
                                  Eric
                                  Von unterwegs getippert
                                    starfish
                                    @eric2905:
                                    Gruß,
                                    Eric `
                                    danke, hatte ich auch grad gefunden, aber Du warst schneller … :D
                                    geht noch mit den Preisen - v.a. so ab 200K api calls.
