  4. Adapter lassen sich nicht aktualisieren
    5.8k
iobroker update
55 Beiträge 6 Kommentatoren 10.2k Aufrufe 5 Beobachtet
    @Karacho
    iobroker list adapters
    iobroker list instances
    Karacho
    @Thomas-Braun said in Adapter lassen sich nicht aktualisieren:
    pi@raspberrypi4-iob:~ $ iobroker list adapters
    system.adapter.accuweather             : accuweather    - v1.1.4
    system.adapter.admin                   : admin          - v4.1.11
    system.adapter.backitup                : backitup       - v1.8.0-beta.2
    system.adapter.broadlink2              : broadlink2     - v2.1.5
    system.adapter.cloud                   : cloud          - v3.1.0
    system.adapter.coronavirus-statistics  : coronavirus-statistics - v0.6.3
    system.adapter.daswetter               : daswetter      - v3.0.4
    system.adapter.devices                 : devices        - v0.3.13
    system.adapter.discovery               : discovery      - v2.4.0
    system.adapter.dwd                     : dwd            - v2.5.1
    system.adapter.flot                    : flot           - v1.10.4
    system.adapter.harmony                 : harmony        - v1.2.2
    system.adapter.history                 : history        - v1.9.10
    system.adapter.hmip                    : hmip           - v1.5.0
    system.adapter.homeconnect             : homeconnect    - v0.0.30
    system.adapter.hs100                   : hs100          - v2.0.1
    system.adapter.info                    : info           - v1.7.10
    system.adapter.iot                     : iot            - v1.8.5
    system.adapter.javascript              : javascript     - v4.10.7
    system.adapter.km200                   : km200          - v2.0.3
    system.adapter.maxcube                 : maxcube        - v1.0.2
    system.adapter.mercedesme              : mercedesme     - v0.0.34
    system.adapter.mihome-vacuum           : mihome-vacuum  - v2.1.1
    system.adapter.nuki-extended           : nuki-extended  - v2.3.0
    system.adapter.openweathermap          : openweathermap - v0.1.0
    system.adapter.pushover                : pushover       - v2.0.3
    system.adapter.rpi2                    : rpi2           - v1.2.0
    system.adapter.shuttercontrol          : shuttercontrol - v1.0.4
    system.adapter.simple-api              : simple-api     - v2.4.8
    system.adapter.smartgarden             : smartgarden    - v1.0.2
    system.adapter.socketio                : socketio       - v3.0.13
    system.adapter.solarlog                : solarlog       - v2.0.0
    system.adapter.statistics              : statistics     - v0.2.2
    system.adapter.terminal                : terminal       - v0.1.2
    system.adapter.vis                     : vis            - v1.3.4
    system.adapter.vis-icontwo             : vis-icontwo    - v0.34.0
    system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
    system.adapter.vis-material            : vis-material   - v0.1.3
    system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
    system.adapter.web                     : web            - v3.1.0
    system.adapter.worx                    : worx           - v1.2.7
    system.adapter.zigbee                  : zigbee         - v1.4.0
      @Karacho
      Karacho
      @Thomas-Braun
      pi@raspberrypi4-iob:~ $ iobroker list instances
        system.adapter.admin.0                 : admin                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0              : backitup              -  enabled
      + system.adapter.broadlink2.0            : broadlink2            -  enabled
      + system.adapter.cloud.0                 : cloud                 -  enabled
        system.adapter.daswetter.0             : daswetter             - disabled
        system.adapter.devices.0               : devices               -  enabled
      + system.adapter.discovery.0             : discovery             -  enabled
        system.adapter.dwd.0                   : dwd                   -  enabled
        system.adapter.flot.0                  : flot                  -  enabled
        system.adapter.harmony.0               : harmony               - disabled
      + system.adapter.history.0               : history               -  enabled
      + system.adapter.hmip.0                  : hmip                  -  enabled
      + system.adapter.homeconnect.0           : homeconnect           -  enabled
      + system.adapter.hs100.0                 : hs100                 -  enabled
      + system.adapter.info.0                  : info                  -  enabled
      + system.adapter.javascript.0            : javascript            -  enabled
      + system.adapter.km200.0                 : km200                 -  enabled
      + system.adapter.mihome-vacuum.0         : mihome-vacuum         -  enabled, port: 54321
      + system.adapter.nuki-extended.0         : nuki-extended         -  enabled
      + system.adapter.pushover.0              : pushover              -  enabled
      + system.adapter.rpi2.0                  : rpi2                  -  enabled
        system.adapter.smartgarden.0           : smartgarden           - disabled
      + system.adapter.solarlog.0              : solarlog              -  enabled, port: 80
        system.adapter.vis-icontwo.0           : vis-icontwo           -  enabled
        system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd          -  enabled
        system.adapter.vis-material.0          : vis-material          -  enabled
        system.adapter.vis-timeandweather.0    : vis-timeandweather    -  enabled
        system.adapter.vis.0                   : vis                   -  enabled
      + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.worx.0                  : worx                  -  enabled
      + system.adapter.zigbee.0                : zigbee                -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E28E39-if00
      + instance is alive
      • K Karacho
        @Thomas-Braun
        + instance is alive
        @Karacho
        iobroker start admin
        Die Adapter sind aber jetzt alle auf dem Stand der 'Beta'-Versionen.
        Frage ist: Willst du das/brauchst du das?
          @Karacho
          Karacho
          @Thomas-Braun
          Zugriff habe ich wieder
          Habe jetzt 17 nicht aktuelle Adapter
          Beispiel Zigbee Adapter:
          IST 1.3.1
          Aktuell 1.4.0
          1.4.0 ist doch nicht Beta?
          • K Karacho
            @Thomas-Braun
            IST 1.3.1
            Aktuell 1.4.0
            @Karacho Wenn 1.4.0 aus dem Verwahrort (BETA/Latest) kommt dann ist es qua Definion BETA.
            In (STABLE/Default) ist der Zweig 1.4. noch nicht drin.
            • K Karacho
              @Thomas-Braun
              IST 1.3.1
              Aktuell 1.4.0
              @Karacho
              iobroker update
              iobroker upgrade
              Beide Ausgaben hier rein.
                Karacho
                @Thomas-Braun
                Zigbee mit 1.4.0 (IST 1.3.1)
                und
                Flot Charts 1.10.4 (IST 1.10.2)
                sind doch als stable markiert?
                • K Karacho
                  @Thomas-Braun
                  und
                  @Karacho
                  zigbee:
                  github:	1.4.0
                  latest:	1.4.0 for 0 days
                  stable:	1.3.1 for 36 days
                  flot:
                  github:	1.10.4
                  latest:	1.10.4 for 21 days
                  stable:	1.10.4 for 21 days
                  • K Karacho
                    @Thomas-Braun
                    und
                    @Karacho
                    Aus deinem System:
                    Du fährst also auf dem BETA-Kanal.
                      @Karacho
                      Aus deinem System:
                      Karacho
                      @Thomas-Braun
                      Was heisst das "Beta Kanal"?
                      Möchte eigentlich nur stabile Adapter haben...
                      Was muss ich wo einstellen?
                      • K Karacho
                        @Thomas-Braun
                        @Karacho
                        In den Admin-Einstellungen:
                        K 2 Antworten Letzte Antwort
                          @Karacho
                          Karacho
                          @Thomas-Braun
                          Vielleicht bin ich zu blöd, aber ich habe dort nur zur Auswahl
                          default
                          latest
                          Aktiviert ist default
                          kein stable.....
                            @Karacho
                            Karacho
                            @Thomas-Braun
                            source für default
                            http://download.iobroker.net/sources-dist.json
                            • K Karacho
                              @Thomas-Braun
                              source für default
                              @Karacho
                              Bitte mal die vollständige Ausgabe (inkl. Login prompt)
                              von
                              iobroker update
                              Müsste eigentlich zu zigbee dann das drin stehen:
                              Adapter    "zigbee"        : 1.3.1    , installed 1.4.0
                              K 3 Antworten Letzte Antwort
                                @Karacho
                                von
                                iobroker update
                                Karacho
                                @Thomas-Braun
                                Linux raspberrypi4-iob 5.4.79-v7l+ #1373 SMP Mon Nov 23 13:27:40 GMT 2020 armv7l
                                permitted by applicable law.
                                Last login: Sat Dec  5 14:15:48 2020 from 192.168.178.81
                                Wi-Fi is currently blocked by rfkill.
                                Use raspi-config to set the country before use.
                                  @Karacho
                                  von
                                  iobroker update
                                  Karacho
                                  @Thomas-Braun
                                  pi@raspberrypi4-iob:~ $ iobroker update
                                  Used repository: default
                                  hash unchanged, use cached sources
                                  update done
                                  Adapter    "admin"         : 4.1.10   , installed 4.1.8 [Updateable]
                                  Adapter    "alarm"         : 1.8.1
                                  Adapter    "alexa2"        : 3.3.5
                                  Adapter    "alpha2"        : 1.0.0
                                  Adapter    "amazon-dash"   : 1.1.0
                                  Adapter    "artnet"        : 1.2.2
                                  Adapter    "asterisk"      : 1.0.6
                                  Adapter    "asuswrt"       : 1.0.1
                                  Adapter    "b-control-em"  : 0.2.1
                                  Adapter    "backitup"      : 1.7.0    , installed 1.6.9 [Updateable]
                                  Adapter    "beckhoff"      : 1.2.2
                                  Adapter    "benq"          : 0.2.0
                                  Adapter    "binance"       : 1.1.3
                                  Adapter    "ble"           : 0.12.0
                                  Adapter    "bmw"           : 1.3.3
                                  Adapter    "bosesoundtouch": 0.2.4
                                  Adapter    "botvac"        : 1.0.0
                                  Adapter    "bring"         : 1.7.3
                                  Adapter    "broadlink2"    : 2.0.3    , installed 2.1.5
                                  Adapter    "bsblan"        : 0.2.0
                                  Adapter    "bshb"          : 0.1.10
                                  Adapter    "chromecast"    : 2.3.1
                                  Adapter    "cloud"         : 3.1.0    , installed 3.0.4 [Updateable]
                                  Adapter    "comfoair"      : 0.3.2
                                  Adapter    "contactid"     : 1.0.1
                                  Adapter    "coronavirus-statistics": 0.6.3   , installed 0.6.1 [Updateable]
                                  Adapter    "countdown"     : 1.1.0
                                  Adapter    "cul"           : 1.3.3
                                  Adapter    "daikin"        : 1.1.3
                                  Adapter    "daswetter"     : 3.0.4    , installed 3.0.3 [Updateable]
                                  Adapter    "deconz"        : 1.3.11
                                  Adapter    "denon"         : 1.7.7
                                  Adapter    "device-reminder": 0.5.4
                                  Adapter    "devices"       : 0.3.13   , installed 0.3.13
                                  Adapter    "digitalstrom"  : 0.5.5
                                  Adapter    "discovergy"    : 0.5.0
                                  Adapter    "discovery"     : 2.3.11   , installed 2.3.11
                                  Adapter    "doorio"        : 1.1.1
                                  Adapter    "ds18b20"       : 1.1.5
                                  Adapter    "dwd"           : 2.5.1    , installed 2.4.10 [Updateable]
                                  Adapter    "ebus"          : 2.1.1
                                  Adapter    "ecovacs-deebot": 1.0.3
                                  Adapter    "egigeozone"    : 0.1.2
                                  Adapter    "ekey"          : 1.1.0
                                  Adapter    "email"         : 1.0.7
                                  Adapter    "emby"          : 1.0.2
                                  Adapter    "energymanager" : 1.2.3
                                  Adapter    "enet"          : 1.0.1
                                  Adapter    "epson_stylus_px830": 0.2.1
                                  Adapter    "exchangerates" : 0.0.13
                                  Adapter    "fakeroku"      : 0.2.1
                                  Adapter    "fb-checkpresence": 1.1.0
                                  Adapter    "feiertage"     : 1.0.17
                                  Adapter    "fhem"          : 1.5.3
                                  Adapter    "find-my-iphone": 0.2.15
                                  Adapter    "firetv"        : 0.0.27
                                  Adapter    "flot"          : 1.10.4   , installed 1.10.2 [Updateable]
                                  Adapter    "foobar2000"    : 2.0.3
                                  Adapter    "fritzbox"      : 0.2.1
                                  Adapter    "fritzdect"     : 0.2.4
                                  Adapter    "fronius"       : 1.0.5
                                  Adapter    "frontier_silicon": 0.0.10
                                  Adapter    "fullcalendar"  : 1.1.0
                                  Adapter    "fullybrowser"  : 2.0.1
                                  Adapter    "g-homa"        : 0.5.3
                                  Adapter    "geofency"      : 0.3.2
                                  Adapter    "growatt"       : 0.0.14
                                  Adapter    "gruenbeck"     : 0.0.18
                                  Adapter    "habpanel"      : 0.4.3
                                  Adapter    "haier"         : 1.0.2
                                  Adapter    "ham"           : 1.1.2
                                  Adapter    "ham-wemo"      : 1.1.0
                                  Adapter    "harmony"       : 1.2.2    , installed 1.2.2
                                  Adapter    "heatingcontrol": 1.0.0
                                  Adapter    "heos"          : 1.6.1
                                  Adapter    "heytech"       : 1.0.0
                                  Adapter    "hid"           : 0.1.17
                                  Adapter    "history"       : 1.9.10   , installed 1.9.10
                                  Adapter    "hm-rega"       : 2.6.24
                                  Adapter    "hm-rpc"        : 1.14.24
                                  Adapter    "hmip"          : 1.5.0
                                  Adapter    "homeconnect"   : 0.0.30   , installed 0.0.30
                                  Adapter    "homee"         : 1.0.7
                                  Adapter    "homepilot"     : 1.0.3
                                  Adapter    "hp-ilo"        : 1.0.6
                                  Adapter    "hs100"         : 2.0.1    , installed 2.0.1
                                  Adapter    "hue"           : 3.3.8
                                  Adapter    "hue-extended"  : 2.0.0
                                  Adapter    "i2c"           : 1.1.1
                                  Adapter    "ical"          : 1.7.4
                                  Adapter    "icons-addictive-flavour-png": 0.1.0
                                  Adapter    "icons-fatcow-hosting": 0.1.0
                                  Adapter    "icons-icons8"  : 0.0.1
                                  Adapter    "icons-material-png": 0.1.0
                                  Adapter    "icons-material-svg": 0.1.0
                                  Adapter    "icons-mfd-png" : 1.0.2
                                  Adapter    "icons-mfd-svg" : 1.0.2
                                  Adapter    "icons-open-icon-library-png": 0.1.2
                                  Adapter    "icons-ultimate-png": 1.0.1
                                  Adapter    "influxdb"      : 1.9.1
                                  Adapter    "info"          : 1.7.10   , installed 1.7.7 [Updateable]
                                  Adapter    "innogy-smarthome": 0.3.6
                                  Adapter    "iogo"          : 0.5.10
                                  Adapter    "iot"           : 1.5.3    , installed 1.7.11
                                  Adapter    "iqontrol"      : 1.5.0
                                  Adapter    "jarvis"        : 1.0.9
                                  Adapter    "javascript"    : 4.8.4    , installed 4.8.4
                                  Adapter    "jeelink"       : 0.1.0
                                  Controller "js-controller" : 3.1.6    , installed 3.1.6
                                  Adapter    "kecontact"     : 1.0.1
                                  Adapter    "klf200"        : 1.0.1
                                  Adapter    "km200"         : 1.1.6    , installed 2.0.3
                                  Adapter    "knmi-weather"  : 1.0.0
                                  Adapter    "knx"           : 1.0.39
                                  Adapter    "kodi"          : 2.0.4
                                  Adapter    "kostal-piko-ba": 1.1.3
                                  Adapter    "kress"         : 2.5.5
                                  Adapter    "lametric"      : 0.0.9
                                  Adapter    "landroid"      : 1.0.3
                                  Adapter    "lcn"           : 1.0.2
                                  Adapter    "legrand-ecocompteur": 1.0.0
                                  Adapter    "letrika_comgw" : 0.0.5
                                  Adapter    "lgtv"          : 1.1.10
                                  Adapter    "lgtv-rs"       : 0.1.0
                                  Adapter    "lgtv11"        : 1.0.5
                                  Adapter    "lifx"          : 0.1.0
                                  Adapter    "lightify"      : 0.2.16
                                  Adapter    "link"          : 0.5.9
                                  Adapter    "linkeddevices" : 1.2.2
                                  Adapter    "linux-control" : 1.0.1
                                  Adapter    "logparser"     : 1.1.0
                                  Adapter    "lovelace"      : 1.0.16
                                  Adapter    "loxone"        : 2.0.2
                                  Adapter    "luftdaten"     : 1.0.1
                                  Adapter    "lupusec"       : 1.2.9
                                  Adapter    "luxtronik1"    : 0.2.2
                                  Adapter    "material"      : 0.13.9
                                  Adapter    "maxcube"       : 1.0.2    , installed 1.0.2
                                  Adapter    "maxcul"        : 1.3.1
                                  Adapter    "mbus"          : 2.3.1
                                  Adapter    "mclighting"    : 0.1.1
                                  Adapter    "megad"         : 1.2.1
                                  Adapter    "megadd"        : 0.2.0
                                  Adapter    "megaesp"       : 0.1.0
                                  Adapter    "melcloud"      : 1.0.6
                                  Adapter    "mercedesme"    : 0.0.21   , installed 0.0.21
                                  Adapter    "mercury"       : 0.1.1
                                  Adapter    "meross"        : 1.5.0
                                  Adapter    "meteoalarm"    : 1.0.9
                                  Adapter    "midea"         : 0.0.6
                                  Adapter    "miele"         : 0.1.5
                                  Adapter    "mielecloudservice": 2.0.0
                                  Adapter    "mihome"        : 1.3.5
                                  Adapter    "mihome-lamp"   : 1.1.0
                                  Adapter    "mihome-plug"   : 0.2.1
                                  Adapter    "mihome-vacuum" : 2.1.1    , installed 2.1.1
                                  Adapter    "mikrotik"      : 1.0.11
                                  Adapter    "milight"       : 0.3.6
                                  Adapter    "milight-smart-light": 0.2.7
                                  Adapter    "minuvis"       : 1.0.0
                                  Adapter    "mobile"        : 1.0.1
                                  Adapter    "modbus"        : 3.1.10
                                  Adapter    "moma"          : 1.2.7
                                  Adapter    "mpd"           : 1.0.5
                                  Adapter    "mqtt"          : 2.1.9
                                  Adapter    "mqtt-client"   : 1.3.1
                                  Adapter    "musiccast"     : 0.1.3
                                  Adapter    "mydlink"       : 1.1.7
                                  Adapter    "mysensors"     : 2.0.1
                                  Adapter    "nanoleaf-lightpanels": 1.0.6
                                  Adapter    "nello"         : 2.0.6
                                  Adapter    "netatmo"       : 1.3.3
                                  Adapter    "netatmo-crawler": 0.3.8
                                  Adapter    "nibeuplink"    : 0.3.0
                                  Adapter    "nina"          : 0.0.22
                                  Adapter    "node-red"      : 2.0.1
                                  Adapter    "nuki"          : 1.4.2
                                  Adapter    "nuki-extended" : 2.3.0
                                  Adapter    "nut"           : 1.1.3
                                  Adapter    "octoprint"     : 1.0.1
                                  Adapter    "odl"           : 1.0.7
                                  Adapter    "oilfox"        : 0.0.5
                                  Adapter    "onkyo"         : 2.0.3
                                  Adapter    "onvif"         : 0.4.4
                                  Adapter    "openhab"       : 1.1.0
                                  Adapter    "openligadb"    : 1.1.0
                                  Adapter    "openweathermap": 0.1.0    , installed 0.1.0
                                  Adapter    "opi"           : 0.1.1
                                  Adapter    "oppoplayer"    : 0.2.1
                                  Adapter    "owfs"          : 0.6.4
                                  Adapter    "owntracks"     : 0.6.3
                                  Adapter    "panasonic-viera": 1.0.2
                                  Adapter    "parser"        : 1.0.7
                                  Adapter    "paw"           : 0.0.7
                                  Adapter    "phantomjs"     : 1.1.2
                                  Adapter    "pi-hole"       : 1.3.1
                                  Adapter    "piface"        : 1.0.0
                                  Adapter    "pimatic"       : 0.3.0
                                  Adapter    "ping"          : 1.4.12
                                  Adapter    "places"        : 1.0.0
                                  Adapter    "plex"          : 0.8.11
                                  Adapter    "plexconnect"   : 0.0.7
                                  Adapter    "pollenflug"    : 1.0.6
                                  Adapter    "proxmox"       : 1.0.1
                                  Adapter    "proxy"         : 1.2.1
                                  Adapter    "pushbullet"    : 0.0.11
                                  Adapter    "pushover"      : 2.0.3    , installed 2.0.3
                                  Adapter    "pushsafer"     : 0.1.8
                                  Adapter    "radar2"        : 1.0.9
                                  Adapter    "radiohead"     : 1.0.7
                                  Adapter    "rflink"        : 2.1.6
                                  Adapter    "rickshaw"      : 1.0.0
                                  Adapter    "ring"          : 1.1.3
                                  Adapter    "robonect"      : 0.1.3
                                  Adapter    "roomba"        : 1.1.1
                                  Adapter    "rpi2"          : 1.2.0    , installed 1.2.0
                                  Adapter    "s7"            : 1.1.9
                                  Adapter    "samsung"       : 0.2.9
                                  Adapter    "sayit"         : 1.12.2
                                  Adapter    "sbfspot"       : 4.0.2
                                  Adapter    "scenes"        : 2.3.0
                                  Adapter    "schoolfree"    : 0.7.0
                                  Adapter    "schwoerer-ventcube": 1.3.0
                                  Adapter    "shelly"        : 4.0.3
                                  Adapter    "shuttercontrol": 1.0.4    , installed 0.8.6 [Updateable]
                                  Adapter    "sia"           : 1.0.4
                                  Adapter    "siegenia"      : 1.0.0
                                  Adapter    "simple-api"    : 2.4.8    , installed 2.4.8
                                  Adapter    "smappee"       : 0.2.2
                                  Adapter    "smartcontrol"  : 1.2.1
                                  Adapter    "smartgarden"   : 1.0.1    , installed 1.0.2
                                  Adapter    "smartmeter"    : 3.1.6
                                  Adapter    "snips"         : 1.5.1
                                  Adapter    "snmp"          : 0.5.0
                                  Adapter    "socketio"      : 3.0.13   , installed 3.0.13
                                  Adapter    "solarlog"      : 2.0.0    , installed 2.0.0
                                  Adapter    "solarviewdatareader": 0.2.1
                                  Adapter    "solarwetter"   : 1.0.0
                                  Adapter    "sonnen"        : 1.7.0
                                  Adapter    "sonoff"        : 2.3.3
                                  Adapter    "sonos"         : 2.1.1
                                  Adapter    "sony-bravia"   : 1.0.1
                                  Adapter    "spotify-premium": 1.0.0
                                  Adapter    "sql"           : 1.15.3
                                  Adapter    "squeezebox"    : 1.0.0
                                  Adapter    "squeezeboxrpc" : 1.0.0
                                  Adapter    "starline"      : 1.0.0
                                  Adapter    "statistics"    : 0.2.2    , installed 0.2.2
                                  Adapter    "stiebel-isg"   : 1.5.1
                                  Adapter    "sunnyportal"   : 0.1.5
                                  Adapter    "swiss-weather-api": 0.3.2
                                  Adapter    "synology"      : 0.1.18
                                  Adapter    "systeminfo"    : 0.3.1
                                  Adapter    "tahoma"        : 0.3.2
                                  Adapter    "tankerkoenig"  : 2.0.5
                                  Adapter    "telegram"      : 1.6.0
                                  Adapter    "terminal"      : 0.1.2    , installed 0.1.2
                                  Adapter    "tesla-motors"  : 0.2.3
                                  Adapter    "text2command"  : 2.0.5
                                  Adapter    "tinker"        : 1.1.0
                                  Adapter    "tr-064"        : 4.2.1
                                  Adapter    "tradfri"       : 2.6.3
                                  Adapter    "trashschedule" : 1.0.3
                                  Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                                  Adapter    "tuya"          : 3.4.1
                                  Adapter    "tvspielfilm"   : 1.0.4
                                  Adapter    "unifi"         : 0.5.8
                                  Adapter    "upnp"          : 1.0.16
                                  Adapter    "vaillant"      : 0.0.10
                                  Adapter    "valloxmv"      : 1.1.1
                                  Adapter    "vcard"         : 0.0.9
                                  Adapter    "velux"         : 0.0.5
                                  Adapter    "viessmann"     : 1.3.2
                                  Adapter    "virtualpowermeter": 1.2.1
                                  Adapter    "vis"           : 1.3.4    , installed 1.3.4
                                  Adapter    "vis-bars"      : 0.1.4
                                  Adapter    "vis-canvas-gauges": 0.1.5
                                  Adapter    "vis-colorpicker": 1.2.0
                                  Adapter    "vis-fancyswitch": 1.1.0
                                  Adapter    "vis-google-fonts": 0.1.0
                                  Adapter    "vis-history"   : 1.0.0
                                  Adapter    "vis-hqwidgets" : 1.1.7
                                  Adapter    "vis-icontwo"   : 0.34.0   , installed 0.34.0
                                  Adapter    "vis-inventwo"  : 2.5.11
                                  Adapter    "vis-jqui-mfd"  : 1.0.12
                                  Adapter    "vis-justgage"  : 1.0.2
                                  Adapter    "vis-keyboard"  : 0.0.2
                                  Adapter    "vis-lcars"     : 1.0.4
                                  Adapter    "vis-map"       : 1.0.4
                                  Adapter    "vis-material-advanced": 1.3.0
                                  Adapter    "vis-metro"     : 1.1.2
                                  Adapter    "vis-players"   : 0.1.6
                                  Adapter    "vis-plumb"     : 1.0.2
                                  Adapter    "vis-rgraph"    : 0.0.2
                                  Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
                                  Adapter    "vis-weather"   : 2.5.2
                                  Adapter    "vr200"         : 1.0.0
                                  Adapter    "vw-connect"    : 0.0.15
                                  Adapter    "weatherunderground": 3.2.1
                                  Adapter    "web"           : 3.0.14   , installed 3.0.13 [Updateable]
                                  Adapter    "weishaupt-wem" : 0.0.8
                                  Adapter    "whatsapp-cmb"  : 0.1.6
                                  Adapter    "wiffi-wz"      : 2.2.0
                                  Adapter    "wifilight"     : 1.1.0
                                  Adapter    "windows-control": 0.1.5
                                  Adapter    "wled"          : 0.5.2
                                  Adapter    "wm-bus"        : 0.1.12
                                  Adapter    "wolf"          : 1.2.1
                                  Adapter    "worx"          : 1.2.3    , installed 1.2.3
                                  Adapter    "xbox"          : 0.6.8
                                  Adapter    "xs1"           : 1.0.2
                                  Adapter    "yahka"         : 0.11.0
                                  Adapter    "yamaha"        : 0.3.19
                                  Adapter    "yeelight-2"    : 1.0.3
                                  Adapter    "youtube"       : 1.0.0
                                  Adapter    "yr"            : 2.0.3
                                  Adapter    "zigbee"        : 1.3.1    , installed 1.3.1
                                  Adapter    "zont"          : 0.5.3
                                  Adapter    "zwave"         : 2.0.1
                                  Adapter    "zwave2"        : 1.7.10
                                    @Karacho
                                    von
                                    iobroker update
                                    Karacho
                                    @Thomas-Braun
                                    eben nicht
                                    • K Karacho
                                      @Thomas-Braun
                                      eben nicht
                                      @Karacho
                                      Das passt doch. In Stable/Default ist V 1.3.1 aktuell.
                                      Die anderen Adapter kannst du aber mal nach oben ziehen:
                                      iobroker upgrade
                                      Du musst aber mal BETA/Latest aktiv gehabt haben, denn du hast da einige Versionen in höheren Versionen laufen als in Stable vorgesehen sind.
                                      Aber lass den Verwahrort jetzt so, das wächst sich aus.
                                        @Karacho
                                        iobroker upgrade
                                        Karacho
                                        @Thomas-Braun
                                        Super Danke.
                                        Lasse jetzt
                                        iobroker upgrade
                                        laufen.
                                        Heute wieder viel gelernt. Danke. Vor allem </> 😊
                                          @Karacho
                                          iobroker upgrade
                                          Karacho
                                          @Thomas-Braun
                                          ich habe immer noch Probleme. Bei mir lassen sich diverse Adapter nicht aktualisieren,, die als "stable" gekennzeichnet sind.
                                          Beispiel
                                          DWD
                                          Installiert: 2.4.10
                                          Aktuell (stable): 2.5.1
                                          Beim Aktualisieren über
                                          iobroker upgrade
                                          bei diversen Adapter (hier Beispiel DWD) der Log mit ERR - ist das normal?
                                          Update dwd from @2.4.10 to @2.5.1
                                          NPM version: 6.14.8
                                          npm install iobroker.dwd@2.5.1 --loglevel error --prefix "/opt/iobroker" (System call)
                                          In file included from ../src/./serialport.h:6,
                                                           from ../src/serialport.cpp:1:
                                          ../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                                          ../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                               , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                                          ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                             uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
                                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                                          ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                             uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
                                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                                          ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                             uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
                                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                                          ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                             uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
                                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                                          ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                             uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
                                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                                          ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                             uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
                                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                                          ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                             uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
                                          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                                          ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                             uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
                                          ../src/serialport.cpp: At global scope:
                                          ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
                                           SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                                          ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
                                           SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
                                          In file included from ../../../nan/nan.h:54,
                                          /home/iobroker/.cache/node-gyp/12.20.0/include/node/node.h:737:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                                 (node::addon_register_func) (regfunc),                          \
                                          /home/iobroker/.cache/node-gyp/12.20.0/include/node/node.h:771:3: note: in expansion of macro ‘NODE_MODULE_X’
                                             NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                                          ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
                                           NODE_MODULE(serialport, init);
                                          In file included from ../src/serialport.h:6,
                                                           from ../src/serialport_unix.cpp:2:
                                          ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
                                          ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
                                               snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
                                          ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
                                          ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
                                          ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
                                               snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
                                          ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
                                          In file included from ../src/poller.cpp:1:
                                          Package pixman-1 was not found in the pkg-config search path.
                                          Perhaps you should add the directory containing `pixman-1.pc'
                                          to the PKG_CONFIG_PATH environment variable
                                          No package 'pixman-1' found
                                          gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
                                          gyp ERR! configure error
                                          gyp ERR! stack Error: `gyp` failed with exit code: 1
                                          gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
                                          gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
                                          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
                                          gyp ERR! System Linux 5.4.79-v7l+
                                          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
                                          gyp ERR! cwd /opt/iobroker/node_modules/canvas
                                          gyp ERR! node -v v12.20.0
                                          gyp ERR! node-gyp -v v5.1.0
                                          gyp ERR! not ok
                                          node-pre-gyp ERR! build error
                                          node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
                                          node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                          node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
                                          node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1022:16)
                                          node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
                                          node-pre-gyp ERR! System Linux 5.4.79-v7l+
                                          node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                                          node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                                          node-pre-gyp ERR! node -v v12.20.0
                                          node-pre-gyp ERR! node-pre-gyp -v v0.11.0
                                          node-pre-gyp ERR! not ok
                                          npm ERR! code ELIFECYCLE
                                          npm ERR! errno 1
                                          npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
                                          npm ERR! Exit status 1
                                          npm ERR!
                                          npm ERR! Failed at the canvas@2.6.1 install script.
                                          npm ERR!     /home/iobroker/.npm/_logs/2020-12-07T16_13_15_664Z-debug.log
                                          upload [4] dwd.admin /opt/iobroker/node_modules/iobroker.dwd/admin/words.js words.js application/javascript
                                          Update "system.adapter.dwd.0"
