  4. Welcher Adapter für Klimaanlage(mitsubishi2MQTT)
    6.3k
mqttklimaanlageadapter
74 Beiträge 7 Kommentatoren 17.4k Aufrufe 9 Beobachtet
  • smartboartS smartboart
    @pi_noob15
    hier mein Script dazu...
    Visualisierung und Rückmeldung der Mitsubishi2mqtt strings
    Breitstellung einzelner Rückmelde States aus den mqtt Strings.
    Skripterstellung: Smartboart
    https://forum.iobroker.net/topic/37332/welcher-adapter-f%C3%BCr-klimaanlage-mitsubishi2mqtt/38
    // Erstellung der States für KlimaGeräte
    // State Example {"roomTemperature":25,"temperature":31,"fan":"2","vane":"2","action":"heating","mode":"heat"}
    // Setting Example {"temperature":31,"fan":"2","vane":"2","mode":"heat"}
    var logging = true;
    var debug = true;
    const fC = true; // nach 1. Skriptstart auf false setzen
    const Statepfad = 'javascript.' + instance + '.Raumklima.Mitsubishi.';
    // Trigger
    const idEGSettings = 'mqtt.0.Mitsubishi.Klima-EG.settings'/*Mitsubishi/Klima-EG/settings*/;
    const idEGState = 'mqtt.0.Mitsubishi.Klima-EG.state'/*Mitsubishi/Klima-EG/state*/;
    const idOGSettings = 'mqtt.0.Mitsubishi.Klima-OG.settings'/*Mitsubishi/Klima-OG/settings*/;
    const idOGState = 'mqtt.0.Mitsubishi.Klima-OG.state'/*Mitsubishi/Klima-OG/state*/;
    const idConnection = 'mqtt.0.info.connection'/*List of connected clients*/;
    const idStoerung = 'javascript.0.Vis.KlimaStoerung'/*Klima Stoerung*/;
    //const id0 = Statepfad + 'Klima-EG.State.Connection';
    const id1 = Statepfad + 'Klima-EG.Settings.Temperature';
    const id2 = Statepfad + 'Klima-EG.Settings.Fan';
    const id3 = Statepfad + 'Klima-EG.Settings.Vane';
    const id4 = Statepfad + 'Klima-EG.Settings.Mode';
    const id5 = Statepfad + 'Klima-EG.State.RoomTemperature';
    const id6 = Statepfad + 'Klima-EG.State.Temperature';
    const id7 = Statepfad + 'Klima-EG.State.Fan';
    const id8 = Statepfad + 'Klima-EG.State.Vane';
    const id9 = Statepfad + 'Klima-EG.State.Action';
    const id10 = Statepfad + 'Klima-EG.State.Mode';
    const id11 = Statepfad + 'Klima-OG.Settings.Temperature';
    const id12 = Statepfad + 'Klima-OG.Settings.Fan';
    const id13 = Statepfad + 'Klima-OG.Settings.Vane';
    const id14 = Statepfad + 'Klima-OG.Settings.Mode';
    const id15 = Statepfad + 'Klima-OG.State.RoomTemperature';
    const id16 = Statepfad + 'Klima-OG.State.Temperature';
    const id17 = Statepfad + 'Klima-OG.State.Fan';
    const id18 = Statepfad + 'Klima-OG.State.Vane';
    const id19 = Statepfad + 'Klima-OG.State.Action';
    const id20 = Statepfad + 'Klima-OG.State.Mode';
    createState(id1, null, fC, { type: 'number', name: 'KlimaEG Temperatur Vorwahl',role:'value'});
    createState(id2, null, fC, { type: 'string', name: 'KlimaEG Luefter Vorwahl'});
    createState(id3, null, fC, { type: 'string', name: 'KlimaEG Luftstromstellung Vorwahl'});
    createState(id4, null, fC, { type: 'string', name: 'Klima EG Modus Vorwahl'});
    createState(id5, null, fC, { type: 'number', name: 'KlimaEG Raumtemperatur',role:'value'});
    createState(id6, null, fC, { type: 'number', name: 'KlimaEG Geraetestatus Temperatur',role:'value'});
    createState(id7, null, fC, { type: 'string', name: 'KlimaEG Geraetestatus Luefter'});
    createState(id8, null, fC, { type: 'string', name: 'KlimaEG Geraetestatus Luftstromstellung '});
    createState(id9, null, fC, { type: 'string', name: 'KlimaEG Geraetestatus Aktion'});
    createState(id10, null, fC, { type: 'string', name: 'KlimaEG Geraetestatus Modus'});
    createState(id11, null, fC, { type: 'number', name: 'KlimaOG Temperatur Vorwahl',role:'value'});
    createState(id12, null, fC, { type: 'string', name: 'KlimaOG Luefter Vorwahl'});
    createState(id13, null, fC, { type: 'string', name: 'KlimaOG Luftstromstellung Vorwahl'});
    createState(id14, null, fC, { type: 'string', name: 'KlimaOG Modus Vorwahl'});
    createState(id15, null, fC, { type: 'number', name: 'KlimaOG Raumtemperatur',role:'value'});
    createState(id16, null, fC, { type: 'number', name: 'KlimaOG Geraetestatus Temperatur',role:'value'});
    createState(id17, null, fC, { type: 'string', name: 'KlimaOG Geraetestatus Luefter'});
    createState(id18, null, fC, { type: 'string', name: 'KlimaOG Geraetestatus Luftstromstellung '});
    createState(id19, null, fC, { type: 'string', name: 'KlimaOG Geraetestatus Aktion'});
    createState(id20, null, fC, { type: 'string', name: 'KlimaOG Geraetestatus Modus'});
    on(idEGSettings, function(dp) {
    var EGSettings = getState(idEGSettings).val;
    if(debug)log(['Klima EG: Einstellungen geändert. ' , getState(idEGSettings).val,''].join('') );
    let stringsetEG = JSON.parse(dp.state.val);
    var EGtemperaturesetting = toFloat(stringsetEG.temperature);
    setState(id1 , EGtemperaturesetting, true);
    setState(id2 , stringsetEG.fan, true);
    setState(id3 , stringsetEG.vane, true);
    setState(id4 , stringsetEG.mode, true);
    if(logging)log('Klimaanlage EG: Setting: '+ EGtemperaturesetting +' °C Temperatureinstellung, '+stringsetEG.fan+ ' Fan, '+ stringsetEG.vane + ' vane, '+stringsetEG.mode+ ' Mode.');
    on(idEGState, function(dp) {
    var EGState = getState(idEGState).val;
    if(debug)log(['Klima EG: Status geändert.' , getState(idEGState).val,''].join('') );
    let stringstateEG = JSON.parse(dp.state.val);
    var EGtemperaturestate = toFloat(stringstateEG.temperature);
    setState(id5 , stringstateEG.roomTemperature, true);
    setState(id6 , EGtemperaturestate, true);
    setState(id7 , stringstateEG.fan, true);
    setState(id8 , stringstateEG.vane, true);
    setState(id9 , stringstateEG.action, true);
    setState(id10, stringstateEG.mode, true);
    if(debug)log('Klimaanlage EG: Status: ' + stringstateEG.roomTemperature + ' °C Raumtemperatur, '+ EGtemperaturestate +' °C Tempstate, '+ stringstateEG.fan +' Fansetting, '+stringstateEG.vane+ ' Vanesetting, '+stringstateEG.action +' Action, '+stringstateEG.mode + ' Mode. ');
    on(idOGSettings, function(dp) {
    var OGSettings = getState(idOGSettings).val;
    if(debug)log(['Klima OG: Einstellungen geändert.' , getState(idOGSettings).val,''].join('') );
    let stringsetOG = JSON.parse(dp.state.val);
    var OGtemperaturesetting = toFloat(stringsetOG.temperature);
    setState(id11 , OGtemperaturesetting, true);;
    setState(id12 , stringsetOG.fan, true);
    setState(id13 , stringsetOG.vane, true);
    setState(id14 , stringsetOG.mode, true);
    if (logging) log('Klimaanlage OG: Setting: '+ OGtemperaturesetting +' °C Temperatureinstellung, '+stringsetOG.fan+ ' Fan, '+ stringsetOG.vane + ' vane, '+stringsetOG.mode+ ' Mode.');
    on(idOGState, function(dp) {
    var OGState = getState(idOGState).val;
    if(debug)log(['Klima OG: Status geändert.:' , getState(idOGState).val,''].join('') );
    let stringstateOG = JSON.parse(dp.state.val);
    var OGtemperaturestate = toFloat(stringstateOG.temperature);
    setState(id15 , stringstateOG.roomTemperature, true);
    setState(id16 , OGtemperaturestate, true);
    setState(id17 , stringstateOG.fan, true);
    setState(id18 , stringstateOG.vane, true);
    setState(id19 , stringstateOG.action, true);
    setState(id20 , stringstateOG.mode, true);
    if(debug)log('Klimaanlage OG: Status: ' + stringstateOG.roomTemperature + ' °C Raumtemperatur, '+ OGtemperaturestate +' °C Tempstate, '+ stringstateOG.fan +' Fansetting, '+stringstateOG.vane+ ' Vanesetting, '+stringstateOG.action +' Action, '+stringstateOG.mode + ' Mode. ');
    pi_noob15
    @smartboart ok vielen Dank 👍
    Nur wo "packe" ich das jetzt rein, hatte mit dem Thema bisher noch nichts gemacht, daher frag ich.
    • P pi_noob15
      smartboartS Offline
      smartboartS Offline
      smartboart
      schrieb am zuletzt editiert von smartboart
      @pi_noob15 installiere den javascriptadapter und lese dir die Dokumentation dazu durch.
      Das Script must du im javascript Adapter anlegen...Wahrscheinlich musst du noch die Pfadangabe zu deinem mqqt Namen / Pfad in meinem Script anpassen.
      Beim mir ist der Name wie folgt. für EG und OG.
      const idEGSettings = 'mqtt.0.Mitsubishi.Klima-EG.settings'/Mitsubishi/Klima-EG/settings/;
      const idEGState = 'mqtt.0.Mitsubishi.Klima-EG.state'/Mitsubishi/Klima-EG/state/;
      const idOGSettings = 'mqtt.0.Mitsubishi.Klima-OG.settings'/Mitsubishi/Klima-OG/settings/;
      const idOGState = 'mqtt.0.Mitsubishi.Klima-OG.state'/Mitsubishi/Klima-OG/state/;
      Wenn du nur ein Splitgerät hast, kannst das script noch um mein 2. Gerät einkürzen.
      P 1 Antwort Letzte Antwort
        pi_noob15
        schrieb am zuletzt editiert von pi_noob15
        @smartboart Danke für die Info, habe das mal soweit auf mich angepasst. Aber irgendwie werden keine states angelegt.
        Blöderweise kommt auch keine Fehlermeldung.
        {1}
        {1}
        var logging = true;
        var debug = true;
        // Trigger
        const idKISettings = 'mqtt.0.mitsubishi2mqtt.Klima_kinder.settings'/*mitsubishi2mqtt/Klima_kinder/settings*/;
        const idKIState = 'mqtt.0.mitsubishi2mqtt.Klima_kinder.state'/*mitsubishi2mqtt/Klima_kinder/state*/;
        //const idOGSettings = 'mqtt.0.Mitsubishi.Klima-OG.settings'/*Mitsubishi/Klima-OG/settings*/;
        //const idOGState = 'mqtt.0.Mitsubishi.Klima-OG.state'/*Mitsubishi/Klima-OG/state*/;
        const id1 = Statepfad + 'Klima_kinder.Settings.Temperature';
        const id2 = Statepfad + 'Klima_kinder.Settings.Fan';
        const id3 = Statepfad + 'Klima_kinder.Settings.Vane';
        const id4 = Statepfad + 'Klima_kinder.Settings.Mode';
        const id5 = Statepfad + 'Klima_kinder.State.RoomTemperature';
        const id6 = Statepfad + 'Klima_kinder.State.Temperature';
        const id7 = Statepfad + 'Klima_kinder.State.Fan';
        const id8 = Statepfad + 'Klima_kinder.State.Vane';
        const id9 = Statepfad + 'Klima_kinder.State.Action';
        const id10 = Statepfad + 'Klima_kinder.State.Mode';
        //const id11 = Statepfad + 'Klima-OG.Settings.Temperature';
        //const id12 = Statepfad + 'Klima-OG.Settings.Fan';
        //const id13 = Statepfad + 'Klima-OG.Settings.Vane';
        //const id14 = Statepfad + 'Klima-OG.Settings.Mode';
        //const id15 = Statepfad + 'Klima-OG.State.RoomTemperature';
        //const id16 = Statepfad + 'Klima-OG.State.Temperature';
        //const id17 = Statepfad + 'Klima-OG.State.Fan';
        //const id18 = Statepfad + 'Klima-OG.State.Vane';
        //const id19 = Statepfad + 'Klima-OG.State.Action';
        //const id20 = Statepfad + 'Klima-OG.State.Mode';
        createState(id1, null, fC, { type: 'number', name: 'Klima_kinder Temperatur Vorwahl',role:'value'});
        createState(id2, null, fC, { type: 'string', name: 'Klima_kinder Luefter Vorwahl'});
        createState(id3, null, fC, { type: 'string', name: 'Klima_kinder Luftstromstellung Vorwahl'});
        createState(id4, null, fC, { type: 'string', name: 'Klima_kinder Modus Vorwahl'});
        createState(id5, null, fC, { type: 'number', name: 'Klima_kinder Raumtemperatur',role:'value'});
        createState(id6, null, fC, { type: 'number', name: 'Klima_kinder Geraetestatus Temperatur',role:'value'});
        createState(id7, null, fC, { type: 'string', name: 'Klima_kinder Geraetestatus Luefter'});
        createState(id8, null, fC, { type: 'string', name: 'Klima_kinder Geraetestatus Luftstromstellung '});
        createState(id9, null, fC, { type: 'string', name: 'Klima_kinder Geraetestatus Aktion'});
        createState(id10, null, fC, { type: 'string', name: 'Klima_kinder Geraetestatus Modus'});
        //createState(id11, null, fC, { type: 'number', name: 'KlimaOG Temperatur Vorwahl',role:'value'});
        //createState(id12, null, fC, { type: 'string', name: 'KlimaOG Luefter Vorwahl'});
        //createState(id13, null, fC, { type: 'string', name: 'KlimaOG Luftstromstellung Vorwahl'});
        //createState(id14, null, fC, { type: 'string', name: 'KlimaOG Modus Vorwahl'});
        //createState(id15, null, fC, { type: 'number', name: 'KlimaOG Raumtemperatur',role:'value'});
        //createState(id16, null, fC, { type: 'number', name: 'KlimaOG Geraetestatus Temperatur',role:'value'});
        //createState(id17, null, fC, { type: 'string', name: 'KlimaOG Geraetestatus Luefter'});
        //createState(id18, null, fC, { type: 'string', name: 'KlimaOG Geraetestatus Luftstromstellung '});
        //createState(id19, null, fC, { type: 'string', name: 'KlimaOG Geraetestatus Aktion'});
        //createState(id20, null, fC, { type: 'string', name: 'KlimaOG Geraetestatus Modus'});
        on(idKISettings, function(dp) {
        var KISettings = getState(idKISettings).val;
        if(debug)log(['Klima_kinder: Einstellungen geändert. ' , getState(idKISettings).val,''].join('') );
        let stringsetKI = JSON.parse(dp.state.val);
        var KItemperaturesetting = toFloat(stringsetKI.temperature);
        setState(id1 , KItemperaturesetting, true);
        setState(id2 , stringsetKI.fan, true);
        setState(id3 , stringsetKI.vane, true);
        setState(id4 , stringsetKI.mode, true);
        if(logging)log('Klimaanlage Kinder: Setting: '+ KItemperaturesetting +' °C Temperatureinstellung, '+stringsetKI.fan+ ' Fan, '+ stringsetKI.vane + ' vane, '+stringsetKI.mode+ ' Mode.');
        on(idKIState, function(dp) {
        var KIState = getState(idKIState).val;
        if(debug)log(['Klima Kinder: Status geändert.' , getState(idKIState).val,''].join('') );
        let stringstateKI = JSON.parse(dp.state.val);
        var KItemperaturestate = toFloat(stringstateKI.temperature);
        setState(id5 , stringstateKI.roomTemperature, true);
        setState(id6 , KItemperaturestate, true);
        setState(id7 , stringstateKI.fan, true);
        setState(id8 , stringstateKI.vane, true);
        setState(id9 , stringstateKI.action, true);
        setState(id10, stringstateKI.mode, true);
        if(debug)log('Klimaanlage Kinder: Status: ' + stringstateKI.roomTemperature + ' °C Raumtemperatur, '+ KItemperaturestate +' °C Tempstate, '+ stringstateKI.fan +' Fansetting, '+stringstateKI.vane+ ' Vanesetting, '+stringstateKI.action +' Action, '+stringstateKI.mode + ' Mode. ');
        //on(idOGSettings, function(dp) {
        //var OGSettings = getState(idOGSettings).val;
        //if(debug)log(['Klima OG: Einstellungen geändert.' , getState(idOGSettings).val,''].join('') );
        //let stringsetOG = JSON.parse(dp.state.val);
        //var OGtemperaturesetting = toFloat(stringsetOG.temperature);
        //setState(id11 , OGtemperaturesetting, true);;
        //setState(id12 , stringsetOG.fan, true);
        //setState(id13 , stringsetOG.vane, true);
        //setState(id14 , stringsetOG.mode, true);
        //if (logging) log('Klimaanlage OG: Setting: '+ OGtemperaturesetting +' °C Temperatureinstellung, '+stringsetOG.fan+ ' Fan, '+ stringsetOG.vane + ' vane, '+stringsetOG.mode+ ' Mode.');
        //on(idOGState, function(dp) {
        //var OGState = getState(idOGState).val;
        //if(debug)log(['Klima OG: Status geändert.:' , getState(idOGState).val,''].join('') );
        //let stringstateOG = JSON.parse(dp.state.val);
        //var OGtemperaturestate = toFloat(stringstateOG.temperature);
        //setState(id15 , stringstateOG.roomTemperature, true);
        //setState(id16 , OGtemperaturestate, true);
        //setState(id17 , stringstateOG.fan, true);
        //setState(id18 , stringstateOG.vane, true);
        //setState(id19 , stringstateOG.action, true);
        //setState(id20 , stringstateOG.mode, true);
        //if(debug)log('Klimaanlage OG: Status: ' + stringstateOG.roomTemperature + ' °C Raumtemperatur, '+ OGtemperaturestate +' °C Tempstate, '+ stringstateOG.fan +' Fansetting, '+stringstateOG.vane+ ' Vanesetting, '+stringstateOG.action +' Action, '+stringstateOG.mode + ' Mode. ');
        Klima läuft soweit:
        • P pi_noob15
          {1}
          {1}
          var logging = true;
          var debug = true;
          // Trigger
          Klima läuft soweit:
          smartboartS Offline
          smartboartS Offline
          smartboart
          @pi_noob15 ohne lange zu schauen...mal den browser aktualisiert und oder browser cache gelöscht?
            pi_noob15
            @smartboart oh man... hattest recht... sind nun da....👍
            Aber ohne werte
            smartboartS 2 Antworten Letzte Antwort
            • P pi_noob15
              Aber ohne werte
              smartboartS Offline
              smartboartS Offline
              smartboart
              @pi_noob15 werden erst geschrieben wenn sich der status des KlimaGerät ändert....und mach forcecreation fC = false nachdem sie nun angelegt sind ...sonst sind die werte immer weg nach einem neustart..
              • P pi_noob15
                Aber ohne werte
                smartboartS Offline
                smartboartS Offline
                smartboart
                @pi_noob15 Wenn du alles richtig abgeändert hast muss es gehen. Wenn was nicht geht überprüfe deine Änderungen...
                  pi_noob15
                  @smartboart ok mittlerweile sind die states da....
                  aber blöde Frage für was sind die "settings"
                  • P pi_noob15
                    smartboartS Offline
                    smartboartS Offline
                    smartboart
                    @pi_noob15 sagte in Welcher Adapter für Klimaanlage(mitsubishi2MQTT):
                    Settings sind das was du einstellst Also Info von dem was du per mqtt als Befehle an die Anlage schickst und State ist das was die Anlage macht. Also die Rückmeldung...
                    Die Settings folgen also den MqTT Befehlen an die Anlage und die Settings folgen dann der Rückmeldung der Anlage.
                    Wenn beides dann nach kurzer Zeit gleich ist, hat die Anlage den Befehl angenommen und umgesetzt.
                      pi_noob15
                      @smartboart danke für die Info 👍
                      aber die setzen tue ich ja die Parameter per MQTT.
                      Sobald ich per MQTT was schicke ändert sich das "setting" sobald die Anlage es dann übernommen hat der "State" quasi die Rückmeldung der Anlage dann. Wenn ich das so richtig verstanden habe.
                      Wie hast du eigentlicht die Vis Oberfläche zu steuerung der Klima umgesetzt, ich hab da im Moment noch keine Richtige Vorstellung....
                      • P pi_noob15
                        smartboartS Offline
                        smartboartS Offline
                        smartboart
                        ja ...das script stellt dir nur die Rückmeldungen als einzelnen states aus den beiden mqtt strings zur Verfügung. Damit kann man dann eine vernünftige Vis erstellen ...
                          pi_noob15
                          @smartboart ich habe dein Skript mal noch um den "wideVane" Status ergänzt, sowie um die Kompressorfrequenz. Beim zweiteren habe ich jedoch probleme da die Frequenz im StateString nicht wie die anderen Werte in "0" steht sonder so.
                          {"roomTemperature":29.5,"temperature":23,"fan":"1","vane":"SWING","wideVane":"|","mode":"off","action":"off","compressorFrequency":0}
                          Der Variabentyp ist ja theoretisch egal, da ich den Werte ja nur anzeigen möchte, oder ?
                          Mein angepasstes Skript sieht im Moment so aus:
                          {1}
                          {1}
                          // Erstellung der States für KlimaGeräte Bsp. Gerät MSZ-AP25VGK
                          // State Example {"roomTemperature":27,"temperature":23,"fan":"1","vane":"SWING","wideVane":"|","mode":"fan_only","action":"fan","compressorFrequency":0}
                          // Setting Example {"temperature":23,"fan":"1","vane":"SWING","wideVane":"|","mode":"fan_only"}
                          var logging = true;
                          var debug = true;
                          const fC = false; // nach 1. Skriptstart auf false setzen
                          // Trigger
                          const id5 = Statepfad + 'Klima_kinder.Settings.wideVane';
                          const id6 = Statepfad + 'Klima_kinder.State.RoomTemperature';
                          const id7 = Statepfad + 'Klima_kinder.State.Temperature';
                          const id8 = Statepfad + 'Klima_kinder.State.Fan';
                          const id9 = Statepfad + 'Klima_kinder.State.Vane';
                          const id10 = Statepfad + 'Klima_kinder.State.wideVane';
                          const id11 = Statepfad + 'Klima_kinder.State.Action';
                          const id12 = Statepfad + 'Klima_kinder.State.Mode';
                          const id13 = Statepfad + 'Klima_kinder.State.Compressor';
                          createState(id3, null, fC, { type: 'string', name: 'Klima_kinder Luftstromstellung vertikal Vorwahl'});
                          createState(id5, null, fC, { type: 'string', name: 'Klima_kinder Luftstromstellung horizontal Vorwahl'});
                          createState(id6, null, fC, { type: 'number', name: 'Klima_kinder Raumtemperatur',role:'value'});
                          createState(id7, null, fC, { type: 'number', name: 'Klima_kinder Geraetestatus Temperatur',role:'value'});
                          createState(id8, null, fC, { type: 'string', name: 'Klima_kinder Geraetestatus Luefter'});
                          createState(id9, null, fC, { type: 'string', name: 'Klima_kinder Geraetestatus vertikal Luftstromstellung '});
                          createState(id10, null, fC, { type: 'string', name: 'Klima_kinder Geraetestatus horizontal Luftstromstellung '});
                          createState(id11, null, fC, { type: 'string', name: 'Klima_kinder Geraetestatus Aktion'});
                          createState(id12, null, fC, { type: 'string', name: 'Klima_kinder Geraetestatus Modus'});
                          createState(id13, null, fC, { type: 'string', name: 'Klima_kinder Kompressor Frequenz'});
                          setState(id5 , stringsetKI.wideVane, true);
                          if(logging)log('Klimaanlage Kinder: Setting: '+ KItemperaturesetting +' °C Temperatureinstellung, '+stringsetKI.fan+ ' Fan, '+ stringsetKI.vane + ' vane, '+ stringsetKI.wideVane + ' wideVane,'+stringsetKI.mode+ ' Mode.');
                          setState(id6 , stringstateKI.roomTemperature, true);
                          setState(id7 , KItemperaturestate, true);
                          setState(id8 , stringstateKI.fan, true);
                          setState(id9 , stringstateKI.vane, true);
                          setState(id10 , stringstateKI.wideVane, true);
                          setState(id11 , stringstateKI.mode, true);
                          setState(id12, stringstateKI.action, true);
                          setState(id13, stringstateKI.compressor, true);
                          if(debug)log('Klimaanlage Kinder: Status: ' + stringstateKI.roomTemperature + ' °C Raumtemperatur, '+ KItemperaturestate +' °C Tempstate, '+ stringstateKI.fan +' Fansetting, '+ stringstateKI.vane + ' Vanesetting, '+stringstateKI.wideVane+ ' wideVanesetting, '+stringstateKI.mode +' Mode, '+stringstateKI.action + ' Action,'+ stringstateKI.compressor +' Compressor, ');
                          Und die Objektansicht:
                          • smartboartS Offline
                            smartboartS Offline
                            smartboart
                            ch habe dein Skript mal noch um den "wideVane" Status ergänzt, sowie um die Kompressorfrequenz. Beim zweiteren habe ich jedoch probleme da die Frequenz im StateString nicht wie die anderen Werte in "0" steht sonder so. Der Variabentyp ist ja theoretisch egal, da ich den Werte ja nur anzeigen möchte, oder ?
                            ohne "" ist es kein string sonder typ number...
                            Ich würde den Kompressor Typ number nehmen.
                            Aber mal zu der neuen Firmware mitsubishi2mqtt, die liefert bei mir teilweise Müll zurück, deshalb hatte ich ein issue auf github aufgemacht. Ist das bereits gelöst?
                            • P pi_noob15
                              {1}
                              {1}
                              var logging = true;
                              var debug = true;
                              // Trigger
                              smartboartS Offline
                              smartboartS Offline
                              smartboart
                              @pi_noob15
                              und den type number state musst du so füllen
                              setState(id13, stringstateKI.compressorFrequency, true);
                                pi_noob15
                                @smartboart ok habe Typ numer gesetzt
                                createState(id13, null, fC, { type: 'number', name: 'Klima_kinder Kompressor Frequenz'});
                                befüllt wird das ja dann so oder ?
                                if(debug)log('Klimaanlage Kinder: Status: ' + stringstateKI.roomTemperature + ' °C Raumtemperatur, '+ KItemperaturestate +' °C Tempstate, '+ stringstateKI.fan +' Fansetting, '+ stringstateKI.vane + ' Vanesetting, '+stringstateKI.wideVane+ ' wideVanesetting, '+stringstateKI.mode +' Mode, '+stringstateKI.action + ' Action,'+ stringstateKI.compressor +' compressorFrequency, ');
                                also ich kann mich bisher nicht beklagen bezgl. der Firmware.
                                Skript läuft jetzt 👍
                                Hier das aktuelle Skript:
                                Verwendetes Gerät MSZ-AP25VGK
                                {1}
                                Aktualisierung: pi_noob15
                                Version: 1.0
                                {1}
                                var logging = true;
                                var debug = true;
                                // Trigger
                                • P pi_noob15
                                  {1}
                                  Version: 1.0
                                  {1}
                                  var logging = true;
                                  var debug = true;
                                  // Trigger
                                  smartboartS Offline
                                  smartboartS Offline
                                  smartboart
                                  ok benutz du noch die bin die ich dir erstellt hatte, da hatte ich es ja anders gelöst...Aber heute ist hier wohl was passiert..
                                  • P pi_noob15
                                    {1}
                                    Version: 1.0
                                    {1}
                                    var logging = true;
                                    var debug = true;
                                    // Trigger
                                    smartboartS Offline
                                    smartboartS Offline
                                    smartboart
                                    ja genau so..
                                      pi_noob15
                                      @smartboart ich hatte ja versucht die per OTA Update zu laden, ging dann aber nicht, vielleicht da ich den Huzzah von Adafruit verwende. Werde bei der nächsten Klima dann den Wemos D1 Mini nehmen, da ich ja ein anderes Problem hatte, und einfach alle Fehlerquellen ausschließen wollte.
                                        ja genau so..
                                        pi_noob15
                                        @smartboart sagte in Welcher Adapter für Klimaanlage(mitsubishi2MQTT):
                                        ja genau so..
                                        läuft super 👍🏻 Danke nochmal für die Hilfe 😎
                                        • P pi_noob15
                                          ja genau so..
                                          smartboartS Offline
                                          smartboartS Offline
                                          smartboart
                                          @pi_noob15
                                          schau mal was ich heute gesehen habe...
                                          tasmota release 9.1.0
                                          Optional support for Mitsubishi Electric HVAC by David Gwynne (#9237)
                                          P C 2 Antworten Letzte Antwort
