  4. HTTP request verarbeiten
requesthttp
3 Beiträge 2 Kommentatoren 1.0k Aufrufe 3 Beobachtet
    thesnoopy
    Hi Community,
    ich programmiere gerade meinen ersten Adapter und verzweifel gerade an einem einfachen HTTP Request. Um mich mit der Materie vertraut zu machen wollte ich erst einmal einen einfachen request, in diesem Fall "http://api.ipify.org/?format=json" auslesen. Leider bekomme ich immer eine Fehlermeldung, wenn ich mir nur die Ausgabe anzeigen lassen möchte. Gleiches Problem, wenn ich über setState einen Status ändern möchte. Hier meine main.js:
    "use strict";
     * Created with @iobroker/create-adapter v1.29.1
    // The adapter-core module gives you access to the core ioBroker functions
    // you need to create an adapter
    const utils = require("@iobroker/adapter-core");
    var request = require('request');
    // Load your modules here, e.g.:
    // const fs = require("fs");
    class Amadeus extends utils.Adapter {
    	 * @param {Partial<utils.AdapterOptions>} [options={}]
    	constructor(options) {
    		super({
    			...options,
    		this.on("ready", this.onReady.bind(this));
    		this.on("stateChange", this.onStateChange.bind(this));
    		// this.on("objectChange", this.onObjectChange.bind(this));
    		// this.on("message", this.onMessage.bind(this));
    		this.on("unload", this.onUnload.bind(this));
    	 * Is called when databases are connected and adapter received configuration.
    	async onReady() {
    		// Initialize your adapter here
    		// The adapters config (in the instance object everything under the attribute "native") is accessible via
    		// this.config:
    		this.log.info("config option1: " + this.config.option1);
    		this.log.info("config option2: " + this.config.option2);
    		this.log.info("config option3: " + this.config.option3);
    		For every state in the system there has to be also an object of type state
    		Here a simple template for a boolean variable named "testVariable"
    		Because every adapter instance uses its own unique namespace variable names can't collide with other adapters variables
    		await this.setObjectNotExistsAsync("testVariable", {
    			type: "state",
    			common: {
    				type: "boolean",
    				role: "indicator",
    				read: true,
    				write: true,
    			native: {},
    		// In order to get state updates, you need to subscribe to them. The following line adds a subscription for our variable we have created above.
    		this.subscribeStates("testVariable");
    		// You can also add a subscription for multiple states. The following line watches all states starting with "lights."
    		// this.subscribeStates("lights.*");
    		// Or, if you really must, you can also watch all states. Don't do this if you don't need to. Otherwise this will cause a lot of unnecessary load on the system:
    		// this.subscribeStates("*");
    			setState examples
    			you will notice that each setState will cause the stateChange event to fire (because of above subscribeStates cmd)
    		// the variable testVariable is set to true as command (ack=false)
    		await this.setStateAsync("testVariable", true);
    		// same thing, but the value is flagged "ack"
    		// ack should be always set to true if the value is received from or acknowledged from the target system
    		await this.setStateAsync("testVariable", { val: true, ack: true });
    		// same thing, but the state is deleted after 30s (getState will return null afterwards)
    		await this.setStateAsync("testVariable", { val: true, ack: true, expire: 30 });
    		// examples for the checkPassword/checkGroup functions
    		let result = await this.checkPasswordAsync("admin", "iobroker");
    		this.log.info("check user admin pw iobroker: " + result);
    		result = await this.checkGroupAsync("admin", "admin");
    		this.log.info("check group user admin group admin: " + result);
    //		var data = this.readData();
    		await this.main();
    	readData(){
    		var page = this.config.option3;
    		var options = {url: page, method: 'GET'};
    		request(options,function(error, response, body)
    				this.log.info(this.error);
    				this.log.info(this.response);
    				this.log.info(this.body);
    	main(){
    		try{
    		}catch(e) {
    			this.log.error("Error while readData: " + e);
    	 * Is called when adapter shuts down - callback has to be called under any circumstances!
    	 * @param {() => void} callback
    	onUnload(callback) {
    		try {
    			// Here you must clear all timeouts or intervals that may still be active
    			// clearTimeout(timeout1);
    			// clearTimeout(timeout2);
    			// clearInterval(interval1);
    			callback();
    		} catch (e) {
    			callback();
    	// If you need to react to object changes, uncomment the following block and the corresponding line in the constructor.
    	// You also need to subscribe to the objects with `this.subscribeObjects`, similar to `this.subscribeStates`.
    	//  * Is called if a subscribed object changes
    	//  * @param {string} id
    	//  * @param {ioBroker.Object | null | undefined} obj
    	// onObjectChange(id, obj) {
    	// 	if (obj) {
    	// 		// The object was changed
    	// 		this.log.info(`object ${id} changed: ${JSON.stringify(obj)}`);
    	// 	} else {
    	// 		// The object was deleted
    	// 		this.log.info(`object ${id} deleted`);
    	 * Is called if a subscribed state changes
    	 * @param {ioBroker.State | null | undefined} state
    	onStateChange(id, state) {
    		if (state) {
    			// The state was changed
    			this.log.info(`state ${id} changed: ${state.val} (ack = ${state.ack})`);
    		} else {
    			// The state was deleted
    			this.log.info(`state ${id} deleted`);
    	// If you need to accept messages in your adapter, uncomment the following block and the corresponding line in the constructor.
    	//  * Some message was sent to this instance over message box. Used by email, pushover, text2speech, ...
    	//  * Using this method requires "common.message" property to be set to true in io-package.json
    	//  * @param {ioBroker.Message} obj
    	// onMessage(obj) {
    	// 	if (typeof obj === "object" && obj.message) {
    	// 		if (obj.command === "send") {
    	// 			// e.g. send email or pushover or whatever
    	// 			this.log.info("send command");
    	// 			// Send response in callback if required
    	// 			if (obj.callback) this.sendTo(obj.from, obj.command, "Message received", obj.callback);
    // @ts-ignore parent is a valid property on module
    if (module.parent) {
    	// Export the constructor in compact mode
    	module.exports = (options) => new Amadeus(options);
    } else {
    	// otherwise start the instance directly
    	new Amadeus();
    Die Fehlermeldung lautet:
    (32115) TypeError: Cannot read property 'info' of undefined at Request._callback (/opt/iobroker/node_modules/iobroker.amadeus/main.js:97:14) at Request.self.callback (/opt/iobroker/node_module
    Ich denke es ist nur eine Kleinigkeit, die ich logisch falsch mache, allerdings komme ich da nicht drauf.
    Gruß,
    Carsten
    • T thesnoopy
      Hi Community,
      "use strict";
      		super({
      			...options,
      	async onReady() {
      		// this.config:
      			type: "state",
      			common: {
      				type: "boolean",
      				role: "indicator",
      				read: true,
      				write: true,
      			native: {},
      			setState examples
      		await this.main();
      	readData(){
      	main(){
      		try{
      		}catch(e) {
      		try {
      			callback();
      		} catch (e) {
      			callback();
      	// 	if (obj) {
      	// 	} else {
      		if (state) {
      		} else {
      	// onMessage(obj) {
      } else {
      	new Amadeus();
      Gruß,
      Carsten
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      @thesnoopy
      Mehrere Fehler:
      1. Zeile 95
        Du verwendest einen function () callback, versuchst aber auf das this von außerhalb zuzugreifen. Das ist eine JavaScript-Eigenheit, dass this in manchen Funktionen keinen Wert hat. Zu diesem Zweck gibt es Arrow-Funktionen:
      request(options, (error, response, body) => {
        // hier ist mit `this.` auch wirklich die Adapter-Instanz gemeint.
      1. Zeile 97-99:
        this.error, this.response und this.body gibt es nicht. Lass hier das this. weg, du willst ja die Parameter der Funktion nutzen.
      • AlCalzoneA AlCalzone
        @thesnoopy
        Mehrere Fehler:
        1. Zeile 95
        1. Zeile 97-99:
        thesnoopy
        @AlCalzone Vielen dank, das war es.
