  4. [neuer Adapter] smartgarden adapter for Gardena smart system
gardena smart systemsmartgarden
1.1k Beiträge 108 Kommentatoren 437.8k Aufrufe 101 Beobachtet
  • JohGreJ Offline
    JohGreJ Offline
    JohGre
    #551
    Habe seit heute folgende Fehlermeldungen im Log. Hängt das mit dem 401-er Problem zusammen?
    2020-10-24 10:27:00.087 - debug: smartgarden.0 (3910) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2020-10-24 10:27:00.105 - debug: smartgarden.0 (3910) Objects client ready ... initialize now
    2020-10-24 10:27:00.107 - debug: smartgarden.0 (3910) Objects create System PubSub Client
    2020-10-24 10:27:00.108 - debug: smartgarden.0 (3910) Objects create User PubSub Client
    2020-10-24 10:27:00.109 - debug: smartgarden.0 (3910) Objects client initialize lua scripts
    2020-10-24 10:27:00.122 - debug: smartgarden.0 (3910) Objects connected to redis: 0.0.0.0:9001
    2020-10-24 10:27:00.125 - debug: smartgarden.0 (3910) objectDB connected
    2020-10-24 10:27:00.126 - debug: smartgarden.0 (3910) Redis States: Use Redis connection: 0.0.0.0:9000
    2020-10-24 10:27:00.131 - debug: smartgarden.0 (3910) States create User PubSub Client
    2020-10-24 10:27:00.132 - debug: smartgarden.0 (3910) States create System PubSub Client
    2020-10-24 10:27:00.140 - debug: smartgarden.0 (3910) States connected to redis: 0.0.0.0:9000
    2020-10-24 10:27:00.141 - debug: smartgarden.0 (3910) statesDB connected
    2020-10-24 10:27:00.871 - info: smartgarden.0 (3910) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v12.19.0, js-controller: 3.1.6
    2020-10-24 10:27:00.898 - info: smartgarden.0 (3910) 3/ sgSetState: info.revision value=Main: 2160 / API: 2250 ack=true
    2020-10-24 10:27:00.899 - info: smartgarden.0 (3910) 3/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
    2020-10-24 10:27:00.951 - info: smartgarden.0 (3910) 3/ state smartgarden.0.info.connection changed: false (ack = true)
    2020-10-24 10:27:00.951 - info: smartgarden.0 (3910) 3/ ---> State change by device
    2020-10-24 10:27:00.952 - info: smartgarden.0 (3910) 3/ state smartgarden.0.info.revision changed: Main: 2160 / API: 2250 (ack = true)
    2020-10-24 10:27:00.952 - info: smartgarden.0 (3910) 3/ ---> State change by device
    2020-10-24 10:27:00.965 - info: smartgarden.0 (3910) 3/ state smartgarden.0.testVariable changed: true (ack = false)
    2020-10-24 10:27:00.965 - info: smartgarden.0 (3910) 3/ ---> Command should be sent to device
    2020-10-24 10:27:01.239 - info: smartgarden.0 (3910) 3/ Connection: successful: response.statusCode / statusMessage=200 / OK
    2020-10-24 10:27:01.240 - info: smartgarden.0 (3910) 3/ sgSetState: info.connection value=true ack=true
    2020-10-24 10:27:01.241 - info: smartgarden.0 (3910) 3/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXX-XXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XX-XXXXXXXXXXXXXXXXXXXXXXXXXXXX-X
    2020-10-24 10:27:01.242 - info: smartgarden.0 (3910) 3/ get_locations ...
    2020-10-24 10:27:01.253 - info: smartgarden.0 (3910) 3/ state smartgarden.0.info.connection changed: true (ack = true)
    2020-10-24 10:27:01.256 - info: smartgarden.0 (3910) 3/ ---> State change by device
    2020-10-24 10:27:01.261 - info: smartgarden.0 (3910) 3/ state smartgarden.0.info.connection changed: true (ack = true)
    2020-10-24 10:27:01.262 - info: smartgarden.0 (3910) 3/ ---> State change by device
    2020-10-24 10:27:01.556 - error: smartgarden.0 (3910) uncaught exception: Unexpected end of JSON input
    2020-10-24 10:27:01.557 - error: smartgarden.0 (3910) SyntaxError: Unexpected end of JSON input
    at JSON.parse ()
    at Request._callback (/opt/iobroker/node_modules/iobroker.smartgarden/lib/api.js:2830:29)
    at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    at Request.emit (events.js:314:20)
    at Request. (/opt/iobroker/node_modules/request/request.js:1154:10)
    at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1076:12)
    at Object.onceWrapper (events.js:420:28)
    at IncomingMessage.emit (events.js:326:22)
    at endReadableNT (_stream_readable.js:1223:12)
    2020-10-24 10:27:01.558 - info: smartgarden.0 (3910) 3/ cleaned everything up...
    2020-10-24 10:27:01.602 - info: smartgarden.0 (3910) terminating
    2020-10-24 10:27:01.603 - info: smartgarden.0 (3910) Terminated (NO_ERROR): Without reason
    2020-10-24 10:27:02.123 - info: host.vm-iobroker instance system.adapter.smartgarden.0 terminated with code 0 (NO_ERROR)
    2020-10-24 10:27:02.123 - info: host.vm-iobroker Restart adapter system.adapter.smartgarden.0 because enabled
    2020-10-24 10:27:12.727 - info: host.vm-iobroker "system.adapter.smartgarden.0" disabled
    2020-10-24 10:27:33.317 - error: smartgarden.0 (4056) adapter disabled
    nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
    jpgorganizerJ 1 Antwort Letzte Antwort
    • JohGreJ JohGre
      at JSON.parse ()
      jpgorganizerJ Offline
      jpgorganizer
      #552
      @JohGre sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
      yes, das sieht genau so aus wie bei mir. Ich habe die Chance genutzt und hab das Fehlerhandling an der Stelle verbessert. Kommt dann mit der nächsten Version. Aber ich warte erst mal noch ab mit der Veröffentlichung.
      VG jpgorganizer
      smartgarden Adapter für GARDENA smart system
      Plattform: Raspberry Pi OS Linux 12 (bookworm), Node.js: v18.18.2, NPM: 9.8.1
      • chucky666C chucky666
        Hallo
        Ich habe seit heute den Fehler error 429 . Adapter bleibt gelb
        Woran könnte es liegen ?
        jpgorganizer
        #553
        @chucky666 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
        ich muss doch nochmals auf deinen Fehler 429 zurück kommen. Du hast geschrieben, dein Mäher sei im Winterschlaf. War der Mäher schon im Winterschlaf als du den Fehler 429 bekommen hast oder hast du ihn erst darauf hin in den Winterschlaf versetzt? Hast du noch andere smarte Gardena Geräte und wenn ja, sind die bzw. waren die zum Zeitpunkt des Auftretens des Fehlers 429 noch in Betrieb?
        Hintergrund meiner Frage ist: Fehler 429 zeigt das Überschreiten von Limits an. Dies kann ich mir nur mit aktiven Geräten vorstellen. Wenn aber gar kein Gerät mehr aktiv ist (weil z.B. im Winterschlaf), dann frage ich mich, wie der Fehler entstehen kann.
        Ich habe Gardena gestern bereits gesagt, dass einer meiner Adapter-User einen Fehler 429 reported hat, habe dies aber auf eine andere Ursache geschoben. Heute habe ich im openhab Thread ebenfalls von einem Fehler 429 gelesen. Evtl. kann der Gardena Support sich da einen Reim drauf machen.
        VG jpgorganizer
        S chucky666C 2 Antworten Letzte Antwort
        • jpgorganizerJ jpgorganizer
          VG jpgorganizer
          SirHenri
          #554
          Fehlermeldungen auch bei mir - nur der Rasenmäher, zur Zeit geparkt
          ne 400er Fehlernummer habe ich noch nicht entdecken können - Fehlerquelle trotzdem die gleiche?
          VG Andreas
          smartgarden.0	2020-10-24 12:54:47.106	error	(15283) SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at Request._callback (/opt/iobroker/node_modules/iobroker.smartgarden/lib/api.js:2690:29) at Request.self.call
          smartgarden.0	2020-10-24 12:54:47.102	error	(15283) uncaught exception: Unexpected end of JSON input
          smartgarden.0	2020-10-24 12:54:46.018	info	(15283) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v12.19.0, js-controller: 3.1.6
          host.rockpro64	2020-10-24 12:54:44.450	info	instance system.adapter.smartgarden.0 started with pid 15283
          host.rockpro64	2020-10-24 12:54:14.373	info	Restart adapter system.adapter.smartgarden.0 because enabled
          host.rockpro64	2020-10-24 12:54:14.372	info	instance system.adapter.smartgarden.0 terminated with code 0 (NO_ERROR)
          smartgarden.0	2020-10-24 12:54:13.837	info	(15155) Terminated (NO_ERROR): Without reason
          smartgarden.0	2020-10-24 12:54:13.835	info	(15155) terminating
          smartgarden.0	2020-10-24 12:54:13.786	error	at endReadableNT (_stream_readable.js:1223:12)
          smartgarden.0	2020-10-24 12:54:13.786	error	at IncomingMessage.emit (events.js:326:22)
          smartgarden.0	2020-10-24 12:54:13.786	error	at Object.onceWrapper (events.js:420:28)
          smartgarden.0	2020-10-24 12:54:13.786	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12)
          smartgarden.0	2020-10-24 12:54:13.786	error	at Request.emit (events.js:314:20)
          smartgarden.0	2020-10-24 12:54:13.786	error	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10)
          smartgarden.0	2020-10-24 12:54:13.786	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
          smartgarden.0	2020-10-24 12:54:13.786	error	at Request._callback (/opt/iobroker/node_modules/iobroker.smartgarden/lib/api.js:2690:29)
          smartgarden.0	2020-10-24 12:54:13.786	error	at JSON.parse (<anonymous>)
          smartgarden.0	2020-10-24 12:54:13.786	error	(15155) SyntaxError: Unexpected end of JSON input
          smartgarden.0	2020-10-24 12:54:13.782	error	(15155) uncaught exception: Unexpected end of JSON input
          smartgarden.0	2020-10-24 12:54:13.196	info	(15155) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v12.19.0, js-controller: 3.1.6
          smartgarden.0	2020-10-24 12:54:12.922	debug	(15155) statesDB connected
          smartgarden.0	2020-10-24 12:54:12.921	debug	(15155) States connected to redis: 127.0.0.1:9000
          smartgarden.0	2020-10-24 12:54:12.911	debug	(15155) States create System PubSub Client
          smartgarden.0	2020-10-24 12:54:12.908	debug	(15155) States create User PubSub Client
          smartgarden.0	2020-10-24 12:54:12.901	debug	(15155) Redis States: Use Redis connection: 127.0.0.1:9000
          smartgarden.0	2020-10-24 12:54:12.898	debug	(15155) objectDB connected
          smartgarden.0	2020-10-24 12:54:12.892	debug	(15155) Objects connected to redis: 127.0.0.1:9001
          smartgarden.0	2020-10-24 12:54:12.870	debug	(15155) Objects client initialize lua scripts
          smartgarden.0	2020-10-24 12:54:12.868	debug	(15155) Objects create User PubSub Client
          smartgarden.0	2020-10-24 12:54:12.867	debug	(15155) Objects create System PubSub Client
          smartgarden.0	2020-10-24 12:54:12.862	debug	(15155) Objects client ready ... initialize now
          smartgarden.0	2020-10-24 12:54:12.825	debug	(15155) Redis Objects: Use Redis connection: 127.0.0.1:9001
            VG jpgorganizer
            chucky666C Online
            chucky666C Online
            chucky666
            #555
            @jpgorganizer
            Danke für deine Mühe
            Erst kam der Fehler und der Adapter wurde nicht mehr grün .
            Jetzt ist 429 error weg , aber ich bekomme diesen Fehler
            smartgarden.0	2020-10-24 13:12:11.684	error	at endReadableNT (_stream_readable.js:1220:12)
            smartgarden.0	2020-10-24 13:12:11.684	error	at IncomingMessage.emit (events.js:327:22)
            smartgarden.0	2020-10-24 13:12:11.684	error	at Object.onceWrapper (events.js:421:28)
            smartgarden.0	2020-10-24 13:12:11.684	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12)
            smartgarden.0	2020-10-24 13:12:11.684	error	at Request.emit (events.js:315:20)
            smartgarden.0	2020-10-24 13:12:11.684	error	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10)
            smartgarden.0	2020-10-24 13:12:11.684	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
            smartgarden.0	2020-10-24 13:12:11.684	error	at Request._callback (/opt/iobroker/node_modules/iobroker.smartgarden/lib/api.js:2690:29)
            smartgarden.0	2020-10-24 13:12:11.684	error	at JSON.parse (<anonymous>)
            smartgarden.0	2020-10-24 13:12:11.684	error	(25564) SyntaxError: Unexpected end of JSON input
            smartgarden.0	2020-10-24 13:12:11.683	error	(25564) uncaught exception: Unexpected end of JSON input
              @jpgorganizer
              jpgorganizer
              #556
              @chucky666
              danke
              @SirHenri
              das ist das gleiche Fehlerbild wie bei mir mit Fehler 401. Wir müssen abwarten, bis Gardena sagt, dass der Fehler behoben ist. Erfahrungsgemäß geht das recht flott. Sobald ich Infos erhalten, gebe ich euch bescheid.
              VG jpgorganizer
              chucky666C S 2 Antworten Letzte Antwort
                @chucky666
                danke
                @SirHenri
                VG jpgorganizer
                chucky666C Online
                chucky666C Online
                chucky666
                #557
                @jpgorganizer
                Danke dir .
                Schönes Wochenende
                  @chucky666
                  danke
                  @SirHenri
                  VG jpgorganizer
                  SirHenri
                  #558
                  @jpgorganizer
                  besten Dank 👍
                    Hallo liebe ioBroker Gemeinde,
                    da Gardena in 2019 eine Websocket Schnittstelle für die Smart Geräte wie Mähroboter, Bewässerungsanlage (smart irrigation control) veröffentlicht hat und es m.W. noch keinen Adapter dafür gibt, habe ich in den vergangenen Wochen einen Adapter dafür entwickelt.
                    Ich bitte euch nun diesen zu testen. Für Fragen, Fehler etc. bitte diesen Thread nutzen. Ich werde versuchen die Fragen zu beantworten und auch Fehler zu beheben.
                    Der Adapter liegt in github unter https://github.com/jpgorganizer/ioBroker.smartgarden.
                    Viele Grüße
                    jpgorganizer
                    stevie77
                    #559
                    @jpgorganizer Hmm, das ist jetzt eine gefährliche Situation. Mein Adapter führt jetzt ca. alle halbe Minute eine "kostenpflichtige" Aktion aus, die den Count nach oben setzt. Ich musste ihn nun manuell stoppen.
                    (27811) 2/ state smartgarden.0.info.RateLimitCounter changed: {"2020":{"2020-10":{"count":1306,"2020-10-10":{"16":{"count":12},"17":{"count":10},"18":{"count":8},"19":{"count":6},"20":{"count":5},"21"
                    Wenn ich im Urlaub bin oder es nicht merke und der Adapter mal auf rot geht, dann kann ich nicht eingreifen und bekomme durch Gardena die Steuerungsfähigkeit genommen bis ich diesen Schlüssel da wieder ändere. Ich weiß jetzt ja nicht, was das für eine Fehlersituation ist (und du womöglich auch nicht wenn das von Gardena kommt), aber könnte man ein parametrierbares Minutenintervall einbauen, das im Fehlerfall nicht so häufig erneut probiert? Mir würden 60 min völlig ausreichen bis der Adapter nach einem Fehler wieder versucht sich zu verbinden...
                    • S stevie77
                      jpgorganizer
                      #560
                      @stevie77 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                      kannst du mal einen Ausschnitt mit 2,3 solchen Wiederholungen aus deinem Log zeigen? Ich habe einen Verdacht :-)
                      Ansonsten habe ich bereits oben geschrieben, dass dich die Gunst der Stunde nutze um das Fehlerhandling zu verbessern.
                      VG jpgorganizer
                        VG jpgorganizer
                        stevie77
                        #561
                        @jpgorganizer Gerne, kommt hier:
                        smartgarden.0	2020-10-25 12:18:23.677	info	(13004) Terminated (NO_ERROR): Without reason
                        smartgarden.0	2020-10-25 12:18:23.676	info	(13004) terminating
                        smartgarden.0	2020-10-25 12:18:23.626	info	(13004) 2/ cleaned everything up...
                        smartgarden.0	2020-10-25 12:18:23.625	error	(13004) SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at Request._callback (/opt/iobroker/node_modules/iobroker.smartgarden/lib/api.js:2830:29) at Request.self.call
                        smartgarden.0	2020-10-25 12:18:23.623	error	(13004) uncaught exception: Unexpected end of JSON input
                        smartgarden.0	2020-10-25 12:18:23.371	info	(13004) 2/ state smartgarden.0.info.RateLimitCounter changed: {"2020":{"2020-10":{"count":1316,"2020-10-10":{"16":{"count":12},"17":{"count":10},"18":{"count":8},"19":{"count":6},"20":{"count":5},"21"
                        smartgarden.0	2020-10-25 12:18:23.367	info	(13004) 2/ state smartgarden.0.info.connection changed: true (ack = true)
                        smartgarden.0	2020-10-25 12:18:23.364	info	(13004) 2/ state smartgarden.0.info.connection changed: true (ack = true)
                        smartgarden.0	2020-10-25 12:18:23.346	info	(13004) 2/ get_locations ...
                        smartgarden.0	2020-10-25 12:18:23.345	info	(13004) 2/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
                        smartgarden.0	2020-10-25 12:18:23.343	info	(13004) 2/ Connection: successful: response.statusCode / statusMessage=200 / OK
                        smartgarden.0	2020-10-25 12:18:23.002	info	(13004) 2/ state smartgarden.0.info.RateLimitCounter changed: {"2020":{"2020-10":{"count":1315,"2020-10-10":{"16":{"count":12},"17":{"count":10},"18":{"count":8},"19":{"count":6},"20":{"count":5},"21"
                        smartgarden.0	2020-10-25 12:18:22.994	info	(13004) 2/ state smartgarden.0.info.revision changed: Main: 2160 / API: 2250 (ack = true)
                        smartgarden.0	2020-10-25 12:18:22.993	info	(13004) 2/ state smartgarden.0.info.connection changed: false (ack = true)
                        smartgarden.0	2020-10-25 12:18:22.857	info	(13004) 2/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
                        smartgarden.0	2020-10-25 12:18:22.819	info	(13004) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v10.21.0, js-controller: 3.1.6
                        smartgarden.0	2020-10-25 12:17:49.927	info	(12950) Terminated (NO_ERROR): Without reason
                        smartgarden.0	2020-10-25 12:17:49.926	info	(12950) terminating
                        smartgarden.0	2020-10-25 12:17:49.878	info	(12950) 2/ cleaned everything up...
                        smartgarden.0	2020-10-25 12:17:49.876	error	(12950) SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at Request._callback (/opt/iobroker/node_modules/iobroker.smartgarden/lib/api.js:2830:29) at Request.self.call
                        smartgarden.0	2020-10-25 12:17:49.874	error	(12950) uncaught exception: Unexpected end of JSON input
                        smartgarden.0	2020-10-25 12:17:49.748	info	(12950) 2/ state smartgarden.0.info.RateLimitCounter changed: {"2020":{"2020-10":{"count":1314,"2020-10-10":{"16":{"count":12},"17":{"count":10},"18":{"count":8},"19":{"count":6},"20":{"count":5},"21"
                        smartgarden.0	2020-10-25 12:17:49.741	info	(12950) 2/ state smartgarden.0.info.connection changed: true (ack = true)
                        smartgarden.0	2020-10-25 12:17:49.737	info	(12950) 2/ state smartgarden.0.info.connection changed: true (ack = true)
                        smartgarden.0	2020-10-25 12:17:49.697	info	(12950) 2/ get_locations ...
                        smartgarden.0	2020-10-25 12:17:49.694	info	(12950) 2/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
                        smartgarden.0	2020-10-25 12:17:49.691	info	(12950) 2/ Connection: successful: response.statusCode / statusMessage=200 / OK
                        smartgarden.0	2020-10-25 12:17:49.398	info	(12950) 2/ state smartgarden.0.info.RateLimitCounter changed: {"2020":{"2020-10":{"count":1313,"2020-10-10":{"16":{"count":12},"17":{"count":10},"18":{"count":8},"19":{"count":6},"20":{"count":5},"21"
                        smartgarden.0	2020-10-25 12:17:49.391	info	(12950) 2/ state smartgarden.0.info.revision changed: Main: 2160 / API: 2250 (ack = true)
                        smartgarden.0	2020-10-25 12:17:49.389	info	(12950) 2/ state smartgarden.0.info.connection changed: false (ack = true)
                        smartgarden.0	2020-10-25 12:17:49.284	info	(12950) 2/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
                        smartgarden.0	2020-10-25 12:17:49.245	info	(12950) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v10.21.0, js-controller: 3.1.6
                        smartgarden.0	2020-10-25 12:17:16.629	info	(12935) Terminated (NO_ERROR): Without reason
                        smartgarden.0	2020-10-25 12:17:16.626	info	(12935) terminating
                        smartgarden.0	2020-10-25 12:17:16.576	info	(12935) 2/ cleaned everything up...
                        smartgarden.0	2020-10-25 12:17:16.574	error	(12935) SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at Request._callback (/opt/iobroker/node_modules/iobroker.smartgarden/lib/api.js:2830:29) at Request.self.call
                        smartgarden.0	2020-10-25 12:17:16.572	error	(12935) uncaught exception: Unexpected end of JSON input
                        smartgarden.0	2020-10-25 12:17:16.410	info	(12935) 2/ state smartgarden.0.info.RateLimitCounter changed: {"2020":{"2020-10":{"count":1312,"2020-10-10":{"16":{"count":12},"17":{"count":10},"18":{"count":8},"19":{"count":6},"20":{"count":5},"21"
                        smartgarden.0	2020-10-25 12:17:16.407	info	(12935) 2/ state smartgarden.0.info.connection changed: true (ack = true)
                        smartgarden.0	2020-10-25 12:17:16.404	info	(12935) 2/ state smartgarden.0.info.connection changed: true (ack = true)
                        smartgarden.0	2020-10-25 12:17:16.385	info	(12935) 2/ get_locations ...
                        smartgarden.0	2020-10-25 12:17:16.384	info	(12935) 2/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
                        smartgarden.0	2020-10-25 12:17:16.382	info	(12935) 2/ Connection: successful: response.statusCode / statusMessage=200 / OK
                        smartgarden.0	2020-10-25 12:17:15.991	info	(12935) 2/ state smartgarden.0.info.RateLimitCounter changed: {"2020":{"2020-10":{"count":1311,"2020-10-10":{"16":{"count":12},"17":{"count":10},"18":{"count":8},"19":{"count":6},"20":{"count":5},"21"
                        smartgarden.0	2020-10-25 12:17:15.981	info	(12935) 2/ state smartgarden.0.info.revision changed: Main: 2160 / API: 2250 (ack = true)
                        smartgarden.0	2020-10-25 12:17:15.981	info	(12935) 2/ state smartgarden.0.info.connection changed: false (ack = true)
                        smartgarden.0	2020-10-25 12:17:15.886	info	(12935) 2/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
                        smartgarden.0	2020-10-25 12:17:15.807	info	(12935) starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v10.21.0, js-controller: 3.1.6
                        • S stevie77
                          jpgorganizer
                          #562
                          @stevie77
                          danke
                          das dachte ich mir. Diese Art von Wiederholung kann ich nicht 100%-ig ausschließen, denn im Code sind/können immer Fehler enthalten sein. Hier gibt es einen uncaught exception: Unexpected end of JSON input. Daraufhin beendet sich der Adapter und wird duch ioBroker immer wieder neu gestartet. Keine Ahnung, ob man ioBroker diesen Neustart abgewöhnen kann (oder auch will).
                          Diese o.a. uncaught exception ist in der nächsten Version dann aber auch behoben.
                          Zu deiner Sorge, dass das nun Limit kostet: kann sein, glaube ich aber eher nicht, denn der Login geht schief. Auf wessen Limit sollte dies nun einzahlen. Um es aber genauer herauszufinden, müsste man auch die Gardena-Seite anschauen können - was ich aber nicht kann. Der Adapter zählt natürlich erst mal eins hoch; das ist in dem Fall dann vmtl. nicht korrekt; aber ich werde das auch nicht anpassen, denn die Überwachung soll ja dem Zweck dienen, dass man im Normalbetrieb sehen kann, ob die Limits gefährdet sind. Und egal wie man es macht, es kann trotz allem wieder nicht korrekt sein.
                          VG jpgorganizer
                            @stevie77
                            danke
                            VG jpgorganizer
                            stevie77
                            #563
                            @jpgorganizer sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                            ann aber auch beho
                            Okay, dann stimmt zwar also später, wenn es wieder läuft, der Counter nicht mehr (da der Counter des Adapters dann deutlich höher ist als der von Gardena, da dieser wegen fehlendem Login nicht inkrementiert wird), aber wenigstens beeinträchtigt das dann den weiteren Betrieb an den verbleibenden Tagen des Monats nicht. Das ist ja auch schon was... ;-)
                            • S stevie77
                              ann aber auch beho
                              jpgorganizer
                              schrieb am zuletzt editiert von jpgorganizer
                              #564
                              Monat muss man wohl auch eher als 30 (evtl. 31) Tage Zeitraum ansehen .... ich habe oben irgendwo einen Link zu AWS, wo die Limits erklärt werden gepostet. Kannst ja mal lesen
                              https://forum.iobroker.net/topic/31289/neuer-adapter-smartgarden-adapter-for-gardena-smart-system/539
                              oberfraggerO 1 Antwort Letzte Antwort
                                oberfraggerO Offline
                                oberfragger
                                #565
                                Vielen Dank in die Runde. Hatte auch nen 400er. Dann habe ich eine neu Applikation angelegt und das funktionierte bis heute Nachmittag 14.00 Uhr.
                                Bei Github natürlich nicht in die geschlossenen Issues geschaut. Warten wir mal ab...
                                • JohGreJ Offline
                                  JohGreJ Offline
                                  JohGre
                                  #566
                                  Seit heute 9:48 ist der Adapter bei mir wieder grün.
                                  • JohGreJ JohGre
                                    jpgorganizer
                                    #567
                                    @All
                                    Gardena hat das Problem gelöst. Man sollte sich somit wieder einloggen können.
                                    Dank an das Gardena Support Team!
                                    Viel Spass
                                    jpgorganizer
                                    oberfraggerO S 2 Antworten Letzte Antwort
                                      @All
                                      Viel Spass
                                      jpgorganizer
                                      oberfragger
                                      #568
                                      Sehr schön. Bei mir löppts auch wieder.
                                        @All
                                        Viel Spass
                                        jpgorganizer
                                        stevie77
                                        schrieb am zuletzt editiert von stevie77
                                        #569
                                        @jpgorganizer Hallo, nachdem die Gartenpumpe ein paar Tage funktioniert hat, hat sie heute Vormittag ihren Dienst versagt. Ausgelöst hat ioBroker, aber ich habe eine Fehlermeldung Unauthorized. Der Adapter stand heute Abend auf gelb. Nach einem einfachen Reload ist er nun wieder grün und ich vermute, dass morgen alles läuft. Nun habe ich solche Aussetzer schon öfters gehabt. Es scheint ja kein permanenter Fehler zu sein (mein Limit scheint auch nicht überschritten zu sein). Der Fehler ist mit einem Reload des Adapters behoben.
                                        Frage: Wenn ich länger im Urlaub bin, kann und will ich nicht alle paar Tage kontrollieren, ob der Adapter/die Instanz noch läuft. Wäre es möglich eine Art Auto-Refresh-Funktion einzubauen, sozusagen als Selbstheilungsfunktion? Oder kann man in ioBroker evtl. einstellen, dass eine Instanz alle n Tage aktualisiert wird?
                                        2020-11-05 10:02:00.023  - info: smartgarden.0 (1155) 2/ state smartgarden.0.LOCATION_5feeadcd-xyz.DEVICE_ceb387e1-xyz.SERVICE_VALVE_ceb387e1-xyz.duration_value changed: 300 (ack = false)
                                        2020-11-05 10:02:00.041  - info: smartgarden.0 (1155) 2/ state smartgarden.0.info.RateLimitCounter changed: {"2020":{"2020-10":{"count":1525,"2020-10-10":{"16":{"count":12},"17":{"count":10},"18":{"count":8},"19":{"count":6},"20":{"count":5},"21":{"count":8},"22":{"count":1},"23":{"count":2},"count":52},"2020-10-11":{"12":{"count":6},"13":{"count":4},"14":{"count":2},"15":{"count":2},"23":{"count":2},"count":33,"02":{"count":6},"03":{"count":8},"08":{"count":3}},"2020-10-12":{"13":{"count":9},"23":{"count":2},"count":16,"01":{"count":3},"08":{"count":2}},"2020-10-13":{"23":{"count":5},"count":8,"01":{"count":1},"08":{"count":2}},"2020-10-14":{"17":{"count":5},"18":{"count":21},"19":{"count":13},"20":{"count":8},"21":{"count":8},"22":{"count":4},"23":{"count":13},"count":75,"08":{"count":3}},"2020-10-15":{"11":{"count":4},"20":{"count":2},"21":{"count":2},"23":{"count":2},"count":45,"00":{"count":10},"01":{"count":6},"02":{"count":6},"03":{"count":4},"04":{"count":2},"05":{"count":2},"06":{"count":2},"08":{"count":3}},"2020-10-16":{"23":{"count":2},"count":5,"08":{"count":3}},"2020-10-17":{"11":{"count":2},"14":{"count":2},"23":{"count":2},"count":7,"08":{"count":1}},"2020-10-18":{"10":{"count":2},"11":{"count":2},"20":{"count":2},"23":{"count":2},"count":15,"02":{"count":2},"08":{"count":3},"09":{"count":2}},"2020-10-19":{"11":{"count":4},"23":{"count":4},"count":13,"01":{"count":3},"08":{"count":2}},"2020-10-20":{"15":{"count":9},"16":{"count":8},"18":{"count":2},"19":{"count":10},"20":{"count":4},"22":{"count":2},"23":{"count":2},"count":40,"08":{"count":3}},"2020-10-21":{"11":{"count":4},"13":{"count":2},"22":{"count":2},"23":{"count":2},"count":49,"02":{"count":2},"03":{"count":4},"04":{"count":6},"05":{"count":2},"06":{"count":4},"07":{"count":8},"08":{"count":9},"09":{"count":4}},"2020-10-22":{"17":{"count":9},"18":{"count":2},"19":{"count":2},"21":{"count":2},"23":{"count":2},"count":20,"08":{"count":3}},"2020-10-23":{"15":{"count":1},"23":{"count":13},"count":17,"08":{"count":3}},"2020-10-24":{"12":{"count":31},"count":891,"00":{"count":211},"01":{"count":212},"02":{"count":210},"03":{"count":212},"04":{"count":14},"08":{"count":1}},"2020-10-25":{"11":{"count":6},"count":30,"03":{"count":24}},"2020-10-26":{"10":{"count":8},"11":{"count":8},"12":{"count":4},"13":{"count":6},"count":31,"09":{"count":5}},"2020-10-27":{"18":{"count":2},"count":6,"00":{"count":2},"09":{"count":2}},"2020-10-28":{"15":{"count":1},"20":{"count":2},"count":8,"00":{"count":2},"09":{"count":3}},"2020-10-29":{"10":{"count":3},"11":{"count":2},"17":{"count":2},"21":{"count":6},"22":{"count":6},"23":{"count":4},"count":55,"00":{"count":4},"01":{"count":9},"02":{"count":4},"03":{"count":10},"04":{"count":2},"09":{"count":3}},"2020-10-30":{"11":{"count":2},"12":{"count":2},"13":{"count":2},"15":{"count":4},"17":{"count":4},"19":{"count":2},"22":{"count":4},"count":104,"00":{"count":14},"01":{"count":8},"02":{"count":6},"03":{"count":10},"04":{"count":12},"05":{"count":12},"06":{"count":2},"07":{"count":10},"08":{"count":6},"09":{"count":4}},"2020-10-31":{"22":{"count":1},"count":5,"00":{"count":2},"09":{"count":2}}},"2020-11":{"count":74,"2020-11-01":{"21":{"count":2},"22":{"count":3},"count":12,"00":{"count":2},"01":{"count":2},"09":{"count":3}},"2020-11-02":{"18":{"count":4},"19":{"count":6},"20":{"count":10},"22":{"count":1},"count":41,"00":{"count":2},"02":{"count":3},"03":{"count":10},"04":{"count":2},"09":{"count":3}},"2020-11-03":{"22":{"count":1},"count":6,"00":{"count":2},"09":{"count":3}},"2020-11-04":{"22":{"count":1},"count":13,"00":{"count":2},"08":{"count":9},"09":{"count":1}},"2020-11-05":{"count":2,"09":{"count":2}}}},"last30days":{"count":79},"last31days":{"count":79}} (ack = true)
                                        2020-11-05 10:02:00.187  - info: smartgarden.0 (1155) 2/ Valve Command failure.
                                        2020-11-05 10:02:00.187  - info: smartgarden.0 (1155) 2/ command: options_valve_control={"url":"https://api.smart.gardena.dev/v1/command/ceb387xyz:0","method":"PUT","json":{"data":{"id":"cmdid_START_SECONDS_TO_OVERRIDE","type":"VALVE_CONTROL","attributes":{"command":"START_SECONDS_TO_OVERRIDE","seconds":300}}},"headers":{"accept":"*/*","Content-Type":"application/vnd.api+json","Authorization":"Bearer ","Authorization-Provider":"husqvarna","X-Api-Key":"xyz"}}
                                        2020-11-05 10:02:00.188  - info: smartgarden.0 (1155) 2/ Valve command failure: response.statusCode/Message=401/Unauthorized
                                        JohGreJ 1 Antwort Letzte Antwort
                                        • S stevie77
                                          JohGreJ Offline
                                          JohGreJ Offline
                                          JohGre
                                          #570
                                          @stevie77 Ich hab mir da ein Reconnect-script gebastelt
                                          var timeout;
                                          on ('smartgarden.0.info.connection', function (obj) {
                                              if (obj.state.val) {
                                                  (function () {if (timeout) {clearTimeout(timeout); timeout = null;}})();//löschen des vorherigen Aufrufs
                                                  //log('SmartGarden Adapter Connection WIEDER VERBUNDEN!!!','warn');
                                              } else {
                                                  //log('SmartGarden Adapter Connection VERLOREN!!!','warn');
                                                  timeout = setTimeout(function () {
                                                      const instanceObj = getObject("system.adapter.smartgarden.0");
                                                      instanceObj.common.enabled = false;                               // Adapter ausschalten
                                                      setObject('system.adapter.smartgarden.0', instanceObj, function (err) {
        if (err) log('Cannot write object: ' + err, 'error');
                                                      log('SmartGarden Adapter ausgeschaltet ', 'warn');
                                                      setTimeout(function() {
                                                          instanceObj.common.enabled = true;                               // Adapter anschalten
        if (err) log('Cannot write object: ' + err);
                                                          log('SmartGarden Adapter eingeschaltet ', 'warn');
                                                          getStatus();
                                                      },  120*1000  );
                                                  }, 60*1000);// x minuten Wartezeit ob Connection wieder selbst hergestellt wird
