  4. Ladezyklen Stromspeicher berechnen, wie?
blockly scriptjavascriptladezyklusstromspeicher
32 Beiträge 3 Kommentatoren 6.4k Aufrufe 1 Beobachtet
    @babl sagte:
    das einigermaßen zu verstehen.
     <variables>
       <variable id="/g,:nd6=sKPn,]JSfrua">ladezyklen</variable>
       <variable id="]!MEA36|p#,3f{Ib=S1.">zyklusstand</variable>
     </variables>
     <block type="variables_set" id="U@8=CwrckLeKOt]iD}Lv" x="63" y="88">
       <field name="VAR" id="/g,:nd6=sKPn,]JSfrua">ladezyklen</field>
       <value name="VALUE">
         <block type="get_value" id="{YRjN`Nx=BEx3R/LDF4+">
           <field name="OID">0_userdata.0.Stromspeicher.Vollzyklen.Anzahl</field>
         </block>
       </value>
       <next>
         <block type="variables_set" id="o.|.m{:;0.0cY^4+eni(">
           <field name="VAR" id="]!MEA36|p#,3f{Ib=S1.">zyklusstand</field>
             <block type="get_value" id="^bB|fQUnfqz^f]r1Qvu1">
               <field name="OID">0_userdata.0.Stromspeicher.Vollzyklen.Zyklusstand</field>
             </block>
           </value>
           <next>
             <block type="on_ext" id="`(wlgoz]jsa80Nq,#_e?">
               <value name="OID0">
                 <shadow type="field_oid" id=")#VRho?5rkxAtApcNu)r">
                 </shadow>
               </value>
               <statement name="STATEMENT">
                 <block type="controls_if" id="Fi_q7rn|saH-bzJ9($A^">
                   <value name="IF0">
                     <block type="get_value" id="6Z`4]I}G?sWO77Wmrta|">
                       <field name="OID">ID auswählen</field>
                     </block>
                   </value>
                   <statement name="DO0">
                     <block type="math_change" id="8WjQf)YmQ3vQ;^G)7B]G">
                       <value name="DELTA">
                         <shadow type="math_number" id="Vifqka:H.5{:*M7]Bc{W">
                           <field name="NUM">1</field>
                         </shadow>
                         <block type="math_arithmetic" id="ZpFHQ#NR!jiV~gw!j{jG">
                           <value name="A">
                             <shadow type="math_number" id="Q/G-2MtZ-GI)!Ar+qks_">
                             </shadow>
                             <block type="on_source" id="GNfmJHKAM#n[VOh{ffPk">
                             </block>
                           </value>
                           <value name="B">
                             <shadow type="math_number" id="gVz;[H5fPq40@-[R6N[N">
                             </shadow>
                             <block type="on_source" id="y@k~Z[13[n:(sj|+XMuk">
                               <field name="ATTR">oldState.val</field>
                             </block>
                           </value>
                         </block>
                       </value>
                       <next>
                         <block type="controls_if" id="sxk@msUzgs8p*9N%t:7p">
                           <value name="IF0">
                             <block type="logic_compare" id="t3CnNEq}CmUCU-tm6YQp">
                               <field name="OP">GTE</field>
                               <value name="A">
                                 <block type="variables_get" id="2-eirE3@48R?ieh|bSXC">
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="math_number" id=".CT*v=bH`vt#,G0kwZ{}">
                                   <field name="NUM">100</field>
                                 </block>
                               </value>
                             </block>
                           </value>
                             <block type="variables_set" id="eNc2wv?]F/o8muo/AnY[">
                                 <block type="math_number" id="/(B2|8R{%3B/0?fhIO]U">
                                   <field name="NUM">0</field>
                                 </block>
                               </value>
                               <next>
                                 <block type="math_change" id="60}*yym(zZukxz/IWZ^i">
                                     <shadow type="math_number" id="0uk=V(+d04OdxwmBb+%3">
                                     </shadow>
                                   </value>
                                   <next>
                                     <block type="update" id="`D3$u0Q|2(23`RRP|%^A">
                                         <block type="variables_get" id="T389$@H2,@S%b{~-MR[#">
                                         </block>
                                       </value>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </statement>
                           <next>
                             <block type="update" id="!E1ULcC.zeMcJH~b).6i">
                                 <block type="variables_get" id="p|Z}yGB64*xixOV)bKVD">
                                 </block>
                               </value>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </statement>
                 </block>
               </statement>
             </block>
           </next>
         </block>
       </next>
     </block>
     <block type="comment" id="xMhMBGiV$PvGORZY6/5G" x="313" y="163">
       <field name="COMMENT">SOC (%)</field>
       <next>
         <block type="comment" id="36)m^TFmBWk}]cH:I)?C">
           <field name="COMMENT">status.batteryCharging</field>
         </block>
       </next>
     </block>
    </xml>
    babl
    @paul53 danke dir es funktioniert👍 , so ist es mir um vieles klarer, noch eine frage für das entladen kann ich ja dann das gleiche script hernehmen und nur die datenpunkte ändern, oder kann ich das eventuell noch hinzu machen daß das ein script ist?
    • B babl
      @babl sagte:
      Wozu das Entladen betrachten ? Das Laden um 100 % erfasst den gesamten Vollzyklus, denn wenn nicht geladen wird, wird entladen (im Grenzfall mit 0 A).
      B HomoranH 3 Antworten Letzte Antwort
        @babl sagte:
        babl
        @paul53 ok da hast du eigentlich auch wieder recht das entladen spielt ja bei dem ladezyklus keine rolle.
          @babl sagte:
          @paul53 sagte in Ladezyklen Stromspeicher berechnen, wie?:
          @babl sagte in Ladezyklen Stromspeicher berechnen, wie?:
          Die dabei erreichte Entladungstiefe ist entscheidend für die Berechnung.
          Ich habe zwar keine Ahnung mit welcher Formel die Entladetiefe in die Lebensdauer des Akkus eingeht, aber diese ist entscheidend.
          Bei meinen Yttrium-Batterien im Wohnmobil heisst es z.B. ausschnittsweise:
          Lebensdauer in Ladungszyklen
          > 3.000 x bei 80% DOD
          > 5.000 x bei 70% DOD
          da ist eine deutlich kürzere Lebensdauer bei tieferer Entladung
            > 3.000 x bei 80% DOD
            > 5.000 x bei 70% DOD
            babl
            schrieb am zuletzt editiert von babl
            @Homoran ja, da gebe ich dir recht, daß die entladetiefe schon auch eine rolle spielt, aber ich will das nur vergleichen, denn die ladezyklen stimmen vom hersteller sowieso nicht. Im August hatte ich eine maximale Entladung der Batterie von 50% über Nacht, sie wurde dann am nächsten Tag wieder zu 100% aufgeladen, aktuell komme ich auf ca. 40% und hier werden teilweise bis zu 2 ladezyklen dann am tag verbraucht um bis auf 100% zu kommen, obwohl nur 60% Energie verbraucht wurden.
            Andere Frage was denkt ihr spielen die Erhaltungsladungen hierzu auch eine Rolle? Denn ca. jede Stunde muß die Batterie 1% nachladen.
            • B babl
              wenn der diese gewichteten Ladezyklen rechnet um bei unterschiedlicher Entladetiefe auf die gleiche Anzahl zu kommen, ergäbe das schon einen Sinn.
              Also nicht 3000/5000 Zyklen sondern 5000 gewichtete Zyklen und tiefer als 50% entladene Zyklen zählen vielleicht das anderthalbfache.
              Was hast du denn für Batterien? Blei sollte NIE unter 50% abfallen
                babl
                @Homoran Sonnenbatterie 10 mit Lithium-Eisen-Phosphat
                • B babl
                  @babl für LiFePO4 Zellen habe ich gerade das gefunden:
                  > 2.000 bei 80% DOD,
                  > 4.000 bei 70% DOD
                  Arbeitstemperatur -20°C - + 55°C
                  Da schlägt die Entladetiefe (DOD [Depth of Discharge]) noch schlimmer zu.
                  eine optimale Lebensdauer, die dann deutlich über den genannten Zyklen liegt, erhältst du bei einem Ladelevel zwischen 50 und 90 %
                  Was natürlich bedeutet, dass man eine doppelt so große Batterie benötigt ;-)
                    > 2.000 bei 80% DOD,
                    > 4.000 bei 70% DOD
                    babl
                    @Homoran ok danke, das erklärt natürlich auch einiges an der ladezyklen anzahl.
                      @babl sagte:
                      babl
                      @paul53 kann das sein, daß der nun wieder zurückzählt.
                      ich hatte als ich das script aktiviert habe 67% Batteriekapazität, die Batterie wurde dann auf 100% aufgefüllt, also 33, aktuell wird die Batterie wieder entladen wir sind hier jetzt bei 98% und der zyklusstand ist jetzt bei 31. Das sollte aber nicht sein. oder habe ich etwas falsch eingestellt.
                      • B babl
                        @babl sagte:
                        Das kann sein, wenn gleichzeitig geladen und entladen wird, der Entladestrom aber größer ist als der Ladestrom.
                          @babl sagte:
                          babl
                          @paul53 aktuell sieht mein script so aus
                            <variables>
                              <variable id="5o@2goY9||Jrz,20if;2">ladezyklen</variable>
                              <variable id="5Cp4BapwLI_BfQvN:hN:">Zyklusstand</variable>
                            </variables>
                              <field name="VAR" id="5o@2goY9||Jrz,20if;2">ladezyklen</field>
                                  <field name="OID">0_userdata.0.Sonnenbatterie_Zyklen_Anzahl</field>
                                </block>
                              </value>
                              <next>
                                  <field name="VAR" id="5Cp4BapwLI_BfQvN:hN:">Zyklusstand</field>
                                      <field name="OID">0_userdata.0.Sonnenbatterie_Zyklus_Stand</field>
                                    </block>
                                  </value>
                                  <next>
                                      <value name="OID0">
                                          <field name="oid">sonnen.0.status.userSoc</field>
                                        </shadow>
                                      </value>
                                          <value name="IF0">
                                              <field name="OID">sonnen.0.status.userSoc</field>
                                            </block>
                                          </value>
                                                </shadow>
                                                  <value name="A">
                                                    </shadow>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </shadow>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <next>
                                                  <value name="IF0">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                        </block>
                                                      </value>
                                                      <next>
                                                            </shadow>
                                                          </value>
                                                          <next>
        </block>
                                                              </value>
                                                            </block>
                                                          </next>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </statement>
                                                  <next>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </statement>
                                        </block>
                                      </statement>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                              <next>
                                </block>
                              </next>
                            </block>
                          </xml>
                          ich müßte dann ja eigentlich nur sagen daß wenn die batterie geladen wird nur gezählt wird. also müßte da noch ein wahr mit rein, denn diesen wert habe ich ja im datenpunkt batterycharging entweder true oder false
                          • B babl
                              <variables>
                              </variables>
                                  </block>
                                </value>
                                <next>
                                      </block>
                                    </value>
                                    <next>
                                        <value name="OID0">
                                          </shadow>
                                        </value>
                                            <value name="IF0">
                                              </block>
                                            </value>
                                                  </shadow>
                                                    <value name="A">
                                                      </shadow>
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      </shadow>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <next>
                                                    <value name="IF0">
                                                        <value name="A">
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                          </block>
                                                        </value>
                                                        <next>
                                                              </shadow>
                                                            </value>
                                                            <next>
        </block>
        </value>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </statement>
                                                    <next>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </statement>
                                          </block>
                                        </statement>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                                <next>
                                  </block>
                                </next>
                              </block>
                            </xml>
                            @babl sagte:
                            Die Abfrage "falls Wert vom Objekt ID sonnen.0.status.userSoc" ist falsch. Es muss hier der Datenpunkt "sonnen.0.status.batteryCharging" abgefragt werden.
                              @babl sagte:
                              babl
                              @paul53 genau, ist mir auch gerade aufgefallen, aber hier war ich mir nicht sicher wie das hier genau heißen soll,
                              falls wert von battery charging aber hier habe ich ja nur true oder false wie kennt das script das dann?
                              • B babl
                                @babl sagte in:
                                Falls verarbeitet nur true und false. Alles andere wird implizit gewandelt.
                                  @babl sagte in:
                                  babl
                                  @paul53 ok verstanden, aber dann muß ich doch trotzdem angeben daß es daß nur bei wahr machen soll, oder nicht?
                                  paul53P HomoranH 2 Antworten Letzte Antwort
                                  • B babl
                                    @babl sagte:
                                    Der Datenpunkt liefert doch schon wahr oder falsch. Du musst nur den richtigen Datenpunkt zuweisen.
                                    • B babl
                                      oder nicht!
                                      Diese verkürzte Version bedeutet (= true)
                                      Analog dazu bedeutet die Form FALLS NICHT Wert von... dass der Wert false sein muss
                                        @babl sagte:
                                        babl
                                        @paul53 dieser datenpunkte liefert wahr oder falsch in einem datenpunkt das stimmt. Darum frage ich ja wie weiss dann das Script ob der datenpunkte wahr oder falsch ist
                                        • B babl
                                          @babl sagte:
                                          Mit "falls" wird der Wert geprüft und nur bei "wahr" der "mache"-Zweig ausgeführt.
