  4. Zigbee-Adapter 1.0.2 Danalock
    6.5k
zigbee adapterdanalock
191 Beiträge 13 Kommentatoren 36.1k Aufrufe 15 Beobachtet
  • P patrick039212
    @Asgothian leider wieder ein Fehler
    zigbee.0	2020-10-01 09:55:29.263	debug	(4321) system.adapter.cloud.0: logging true
    zigbee.0	2020-10-01 09:52:44.553	debug	(4321) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '752.122' seconds ago.
    zigbee.0	2020-10-01 09:52:44.549	debug	(4321) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '3073.56' seconds ago.
    zigbee.0	2020-10-01 09:52:44.541	debug	(4321) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '137.817' seconds ago.
    zigbee.0	2020-10-01 09:51:20.935	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    zigbee.0	2020-10-01 09:51:20.935	error	at /opt/iobroker/node_modules/iobroker.zigbee/main.js:373:48
    zigbee.0	2020-10-01 09:51:20.935	error	at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/converters/toZigbee.js:1532:26)
    zigbee.0	2020-10-01 09:51:20.935	error	at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:396:16)
    zigbee.0	2020-10-01 09:51:20.935	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:23:12)
    zigbee.0	2020-10-01 09:51:20.935	error	at new Promise (<anonymous>)
    zigbee.0	2020-10-01 09:51:20.935	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:27:71
    zigbee.0	2020-10-01 09:51:20.935	error	at Generator.next (<anonymous>)
    zigbee.0	2020-10-01 09:51:20.935	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:398:37)
    zigbee.0	2020-10-01 09:51:20.935	error	at Object.getCommand (/opt/iobroker/node_modules/zigbee-herdsman/dist/zcl/utils.js:107:19)
    zigbee.0	2020-10-01 09:51:20.935	error	(4321) Error on send command to 0x000b57fffe59e779. Error: Error: Cluster 'closuresDoorLock' has no command 'unlockedDoor'
    zigbee.0	2020-10-01 09:51:20.927	debug	(4321) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","cluster
    zigbee.0	2020-10-01 09:51:20.920	debug	(4321) convert state, unlocked, {}
    zigbee.0	2020-10-01 09:51:20.918	debug	(4321) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":1
    zigbee.0	2020-10-01 09:51:20.914	debug	(4321) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value
    zigbee.0	2020-10-01 09:51:20.911	debug	(4321) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
    zigbee.0	2020-10-01 09:51:20.895	debug	(4321) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"unlocked","ack":false,"ts":1601538680887,"q":0,"from":"system.adapter.cloud.0","user":"system.user.admin","lc":1601538680887}
    zigbee.0	2020-10-01 09:51:08.806	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    zigbee.0	2020-10-01 09:51:08.806	error	at /opt/iobroker/node_modules/iobroker.zigbee/main.js:373:48
    zigbee.0	2020-10-01 09:51:08.806	error	at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/converters/toZigbee.js:1532:26)
    zigbee.0	2020-10-01 09:51:08.806	error	at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:396:16)
    zigbee.0	2020-10-01 09:51:08.806	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:23:12)
    zigbee.0	2020-10-01 09:51:08.806	error	at new Promise (<anonymous>)
    zigbee.0	2020-10-01 09:51:08.806	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:27:71
    zigbee.0	2020-10-01 09:51:08.806	error	at Generator.next (<anonymous>)
    zigbee.0	2020-10-01 09:51:08.806	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:398:37)
    zigbee.0	2020-10-01 09:51:08.806	error	at Object.getCommand (/opt/iobroker/node_modules/zigbee-herdsman/dist/zcl/utils.js:107:19)
    zigbee.0	2020-10-01 09:51:08.806	error	(4321) Error on send command to 0x000b57fffe59e779. Error: Error: Cluster 'closuresDoorLock' has no command 'lockedDoor'
    zigbee.0	2020-10-01 09:51:08.804	debug	(4321) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","cluster
    zigbee.0	2020-10-01 09:51:08.803	debug	(4321) convert state, locked, {}
    zigbee.0	2020-10-01 09:51:08.802	debug	(4321) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":1
    zigbee.0	2020-10-01 09:51:08.801	debug	(4321) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value
    zigbee.0	2020-10-01 09:51:08.799	debug	(4321) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
    zigbee.0	2020-10-01 09:51:08.796	debug	(4321) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"locked","ack":false,"ts":1601538668792,"q":0,"from":"system.adapter.cloud.0","user":"system.user.admin","lc":1601538620765}
    zigbee.0	2020-10-01 09:50:26.745	debug	(4321) Publish {"state":"LOCK","lock_state":"locked"}
    zigbee.0	2020-10-01 09:50:26.738	debug	(4321) Type attributeReport device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profile
    zigbee.0	2020-10-01 09:50:26.735	debug	(4321) Received Zigbee message from '0x000b57fffe59e779', type 'attributeReport', cluster 'closuresDoorLock', data '{"lockState":1}' from endpoint 1 with groupID null
    zigbee.0	2020-10-01 09:50:26.728	debug	(4321) handleMessage. {"type":"attributeReport","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":
    zigbee.0	2020-10-01 09:50:20.710	debug	(4321) Publish {"state":"LOCK","lock_state":"locked"}
    zigbee.0	2020-10-01 09:50:20.699	debug	(4321) Type attributeReport device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profile
    zigbee.0	2020-10-01 09:50:20.696	debug	(4321) Received Zigbee message from '0x000b57fffe59e779', type 'attributeReport', cluster 'closuresDoorLock', data '{"lockState":1}' from endpoint 1 with groupID null
    zigbee.0	2020-10-01 09:50:20.671	debug	(4321) handleMessage. {"type":"attributeReport","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":
    zigbee.0	2020-10-01 09:47:44.553	debug	(4321) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '452.122' seconds ago.
    zigbee.0	2020-10-01 09:47:44.549	debug	(4321) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '2773.56' seconds ago.
    zigbee.0	2020-10-01 09:47:44.541	debug	(4321) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '3438.69' seconds ago.
    zigbee.0	2020-10-01 09:45:17.018	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    zigbee.0	2020-10-01 09:45:17.018	error	at /opt/iobroker/node_modules/iobroker.zigbee/main.js:373:48
    zigbee.0	2020-10-01 09:45:17.018	error	at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/converters/toZigbee.js:1532:26)
    zigbee.0	2020-10-01 09:45:17.018	error	at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:396:16)
    zigbee.0	2020-10-01 09:45:17.018	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:23:12)
    zigbee.0	2020-10-01 09:45:17.018	error	at new Promise (<anonymous>)
    zigbee.0	2020-10-01 09:45:17.018	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:27:71
    zigbee.0	2020-10-01 09:45:17.018	error	at Generator.next (<anonymous>)
    zigbee.0	2020-10-01 09:45:17.018	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:398:37)
    zigbee.0	2020-10-01 09:45:17.018	error	at Object.getCommand (/opt/iobroker/node_modules/zigbee-herdsman/dist/zcl/utils.js:107:19)
    zigbee.0	2020-10-01 09:45:17.018	error	(4321) Error on send command to 0x000b57fffe59e779. Error: Error: Cluster 'closuresDoorLock' has no command 'unlockedDoor'
    zigbee.0	2020-10-01 09:45:17.005	debug	(4321) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","cluster
    zigbee.0	2020-10-01 09:45:17.001	debug	(4321) convert state, unlocked, {}
    zigbee.0	2020-10-01 09:45:16.999	debug	(4321) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":1
    zigbee.0	2020-10-01 09:45:16.994	debug	(4321) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value
    zigbee.0	2020-10-01 09:45:16.990	debug	(4321) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
    zigbee.0	2020-10-01 09:45:16.983	debug	(4321) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"unlocked","ack":false,"ts":1601538316977,"q":0,"from":"system.adapter.cloud.0","user":"system.user.admin","lc":1601538316977}
    zigbee.0	2020-10-01 09:44:45.715	debug	(4321) system.adapter.cloud.0: logging false
    zigbee.0	2020-10-01 09:42:44.553	debug	(4321) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '152.122' seconds ago.
    zigbee.0	2020-10-01 09:42:44.549	debug	(4321) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '2473.56' seconds ago.
    zigbee.0	2020-10-01 09:42:44.541	debug	(4321) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '3138.69' seconds ago.
    zigbee.0	2020-10-01 09:40:12.494	debug	(4321) Publish {"voltage":3005,"battery":100}
    zigbee.0	2020-10-01 09:40:12.459	debug	(4321) Type attributeReport device {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputCl
    unlock via iobroker
    zigbee.0	2020-10-01 10:00:23.937	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    zigbee.0	2020-10-01 10:00:23.937	error	at /opt/iobroker/node_modules/iobroker.zigbee/main.js:373:48
    zigbee.0	2020-10-01 10:00:23.937	error	at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/converters/toZigbee.js:1532:26)
    zigbee.0	2020-10-01 10:00:23.937	error	at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:396:16)
    zigbee.0	2020-10-01 10:00:23.937	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:23:12)
    zigbee.0	2020-10-01 10:00:23.937	error	at new Promise (<anonymous>)
    zigbee.0	2020-10-01 10:00:23.937	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:27:71
    zigbee.0	2020-10-01 10:00:23.937	error	at Generator.next (<anonymous>)
    zigbee.0	2020-10-01 10:00:23.937	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:398:37)
    zigbee.0	2020-10-01 10:00:23.937	error	at Object.getCommand (/opt/iobroker/node_modules/zigbee-herdsman/dist/zcl/utils.js:107:19)
    zigbee.0	2020-10-01 10:00:23.937	error	(4321) Error on send command to 0x000b57fffe59e779. Error: Error: Cluster 'closuresDoorLock' has no command 'unlockedDoor'
    zigbee.0	2020-10-01 10:00:23.930	debug	(4321) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","cluster
    zigbee.0	2020-10-01 10:00:23.928	debug	(4321) convert state, unlocked, {}
    zigbee.0	2020-10-01 10:00:23.926	debug	(4321) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":1
    zigbee.0	2020-10-01 10:00:23.923	debug	(4321) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value
    zigbee.0	2020-10-01 10:00:23.913	debug	(4321) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
    zigbee.0	2020-10-01 10:00:23.908	debug	(4321) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"unlocked","ack":false,"ts":1601539223900,"q":0,"from":"system.adapter.cloud.0","user":"system.user.admin","lc":1601539223900}
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #79
    @patrick039212
    Dieser Fehler tritt nur sporadisch auf, oder jedes mal wenn du versuchst das Schloss vom ioBroker zu schalten oder ist der immer da ?
    Stürzt der ioBroker bei diesem Fehler ab oder bleibt er grün ?
    P 1 Antwort Letzte Antwort
    • AsgothianA Asgothian
      @patrick039212
      patrick039212
      schrieb am zuletzt editiert von patrick039212
      #80
      @Asgothian
      kommt leider immer, Iobroker stürtzt dabei nicht ab ... kann es damit zusammen hängen das ich heute auf die Pro version gewechselt habe ?
      • P patrick039212
        @Asgothian
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        #81
        @patrick039212 sagte in Zigbee-Adapter 1.0.2 Danalock:
        die "Pro version" von was ?
          patrick039212
          #82
          @Asgothian iobroker.pro
          • P patrick039212
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            #83
            @patrick039212 Nein
            P AsgothianA 2 Antworten Letzte Antwort
              @patrick039212 Nein
              patrick039212
              #84
              @Asgothian mhmm oke... an was kann das aufeinmal liegen ? ...
              Händisch öffnen funktioniert mit status anzeige ...
                @patrick039212 Nein
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                #85
                Ich habe die Vermutung das da im Herdsman etwas geaendert wurde wie die Schlösser angesprochen werden. Die Fehlermeldung
                deutet darauf hin das ein Befehl intern falsch zusammen gebaut wird. Ich wuerde da als command 'unlockDoor', nicht 'unlockedDoor' erwarten.
                Das kann ich mir anschauen, wird aber bis zum Wochenende dauern bis ich da etwas bereit stellen kann
                A.
                  A.
                  patrick039212
                  #86
                  @Asgothian
                  oke, also
                  Tür händisch öffnen / schließen funktioniert bekomme ich auch die Rückmeldung im Iobroker
                  Tür via Iobroker öffnen / schließen leider nicht
                  • P patrick039212
                    @Asgothian
                    oke, also
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    #87
                    @patrick039212
                    Aktuell ja.
                    falls ich finde was es sein kann kann ich versuchen das bei Dir auf dem iobroker zu patchen - geht aber nur via anydesk + discord oder anydesk + teamspeak. Sonst ist mir das Risiko zu hoch.
                      @patrick039212
                      Aktuell ja.
                      patrick039212
                      #88
                      @Asgothian musst mir nur sagen wann :) mich wundert es nur, ich habe keine Updates oder sonst was gemacht und auf einmal funktioniert es nicht mehr ...
                      • P patrick039212
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        #89
                        @patrick039212 Frage - was schreibst du rein um das schloss zu öffnen / zu schliessen ?
                          patrick039212
                          #90
                          @Asgothian habe
                          lock und locked
                          unlock und unlocked probiert...
                          • P patrick039212
                            @Asgothian habe
                            lock und locked
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            #91
                            @patrick039212
                            probier das bitte nochmal und nimm ein Log davon auf. Insbesondere interessiert mich der unterschied zwischen "unlocked" und "unlock"
                            Bei "unlocked" erwarte ich einen Fehler, bei "unlock" nicht.
                              @patrick039212
                              patrick039212
                              #92
                              @Asgothian
                              wenn ich unlock eingebe müsste der Status dann ja automatisch und "unlocked" umgestellt werden oder ? das passiert nämlich nicht...
                              anbei die logs
                              unlock
                              zigbee.0	2020-10-01 11:07:06.018	debug	(10321) system.adapter.cloud.0: logging true
                              zigbee.0	2020-10-01 11:06:56.853	debug	(10321) system.adapter.cloud.0: logging false
                              zigbee.0	2020-10-01 11:06:31.904	debug	(10321) system.adapter.cloud.0: logging true
                              zigbee.0	2020-10-01 11:06:31.345	error	at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:25:65)
                              zigbee.0	2020-10-01 11:06:31.345	error	at Generator.throw (<anonymous>)
                              zigbee.0	2020-10-01 11:06:31.345	error	at DeconzAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:552:23)
                              zigbee.0	2020-10-01 11:06:31.345	error	(10321) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.unlockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecov
                              zigbee.0	2020-10-01 11:06:30.705	debug	(10321) system.adapter.cloud.0: logging false
                              zigbee.0	2020-10-01 11:05:37.298	debug	(10321) system.adapter.cloud.0: logging true
                              zigbee.0	2020-10-01 11:05:36.550	debug	(10321) system.adapter.cloud.0: logging false
                              zigbee.0	2020-10-01 11:05:30.934	debug	(10321) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","cluste
                              zigbee.0	2020-10-01 11:05:30.931	debug	(10321) convert state, unlock, {}
                              zigbee.0	2020-10-01 11:05:30.930	debug	(10321) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":
                              zigbee.0	2020-10-01 11:05:30.927	debug	(10321) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"valu
                              zigbee.0	2020-10-01 11:05:30.924	debug	(10321) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
                              zigbee.0	2020-10-01 11:05:30.911	debug	(10321) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"unlock","ack":false,"ts":1601543130901,"q":0,"from":"system.adapter.cloud.0","user":"system.user.admin","lc":1601543130901}
                              unlocked
                              zigbee.0	2020-10-01 11:08:22.139	error	at runMicrotasks (<anonymous>)
                              zigbee.0	2020-10-01 11:08:22.139	error	at /opt/iobroker/node_modules/iobroker.zigbee/main.js:373:48
                              zigbee.0	2020-10-01 11:08:22.139	error	at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/converters/toZigbee.js:1532:26)
                              zigbee.0	2020-10-01 11:08:22.139	error	at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:396:16)
                              zigbee.0	2020-10-01 11:08:22.139	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:23:12)
                              zigbee.0	2020-10-01 11:08:22.139	error	at new Promise (<anonymous>)
                              zigbee.0	2020-10-01 11:08:22.139	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:27:71
                              zigbee.0	2020-10-01 11:08:22.139	error	at Generator.next (<anonymous>)
                              zigbee.0	2020-10-01 11:08:22.139	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:398:37)
                              zigbee.0	2020-10-01 11:08:22.139	error	at Object.getCommand (/opt/iobroker/node_modules/zigbee-herdsman/dist/zcl/utils.js:107:19)
                              zigbee.0	2020-10-01 11:08:22.139	error	(10321) Error on send command to 0x000b57fffe59e779. Error: Error: Cluster 'closuresDoorLock' has no command 'unlockedDoor'
                              zigbee.0	2020-10-01 11:08:22.131	debug	(10321) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","cluste
                              zigbee.0	2020-10-01 11:08:22.129	debug	(10321) convert state, unlocked, {}
                              zigbee.0	2020-10-01 11:08:22.128	debug	(10321) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":
                              zigbee.0	2020-10-01 11:08:22.123	debug	(10321) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"valu
                              zigbee.0	2020-10-01 11:08:22.119	debug	(10321) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
                              zigbee.0	2020-10-01 11:08:22.083	debug	(10321) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"unlocked","ack":false,"ts":1601543302071,"q":0,"from":"system.adapter.cloud.0","user":"system.user.admin","lc":1601543302071}
                              locked
                              zigbee.0	2020-10-01 11:10:47.674	error	at runMicrotasks (<anonymous>)
                              zigbee.0	2020-10-01 11:10:47.674	error	at /opt/iobroker/node_modules/iobroker.zigbee/main.js:373:48
                              zigbee.0	2020-10-01 11:10:47.674	error	at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/converters/toZigbee.js:1532:26)
                              zigbee.0	2020-10-01 11:10:47.674	error	at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:396:16)
                              zigbee.0	2020-10-01 11:10:47.674	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:23:12)
                              zigbee.0	2020-10-01 11:10:47.674	error	at new Promise (<anonymous>)
                              zigbee.0	2020-10-01 11:10:47.674	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:27:71
                              zigbee.0	2020-10-01 11:10:47.674	error	at Generator.next (<anonymous>)
                              zigbee.0	2020-10-01 11:10:47.674	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:398:37)
                              zigbee.0	2020-10-01 11:10:47.674	error	at Object.getCommand (/opt/iobroker/node_modules/zigbee-herdsman/dist/zcl/utils.js:107:19)
                              zigbee.0	2020-10-01 11:10:47.674	error	(10321) Error on send command to 0x000b57fffe59e779. Error: Error: Cluster 'closuresDoorLock' has no command 'lockedDoor'
                              zigbee.0	2020-10-01 11:10:47.669	debug	(10321) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","cluste
                              zigbee.0	2020-10-01 11:10:47.667	debug	(10321) convert state, locked, {}
                              zigbee.0	2020-10-01 11:10:47.665	debug	(10321) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":
                              zigbee.0	2020-10-01 11:10:47.662	debug	(10321) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"valu
                              zigbee.0	2020-10-01 11:10:47.657	debug	(10321) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
                              zigbee.0	2020-10-01 11:10:47.649	debug	(10321) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"locked","ack":false,"ts":1601543447641,"q":0,"from":"system.adapter.cloud.0","user":"system.user.admin","lc":1601543447641}
                              lock
                              zigbee.0	2020-10-01 11:13:06.630	debug	(10321) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '1952.014' seconds ago.
                              zigbee.0	2020-10-01 11:13:06.626	debug	(10321) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '562.866' seconds ago.
                              zigbee.0	2020-10-01 11:13:06.617	debug	(10321) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '1126.696' seconds ago.
                              zigbee.0	2020-10-01 11:12:18.558	error	at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:25:65)
                              zigbee.0	2020-10-01 11:12:18.558	error	at Generator.throw (<anonymous>)
                              zigbee.0	2020-10-01 11:12:18.558	error	at DeconzAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:552:23)
                              zigbee.0	2020-10-01 11:12:18.558	error	(10321) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.lockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecover
                              zigbee.0	2020-10-01 11:12:01.253	debug	(10321) system.adapter.cloud.0: logging false
                              zigbee.0	2020-10-01 11:11:18.343	debug	(10321) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","cluste
                              zigbee.0	2020-10-01 11:11:18.342	debug	(10321) convert state, lock, {}
                              zigbee.0	2020-10-01 11:11:18.340	debug	(10321) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":
                              zigbee.0	2020-10-01 11:11:18.338	debug	(10321) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"valu
                              zigbee.0	2020-10-01 11:11:18.336	debug	(10321) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
                              zigbee.0	2020-10-01 11:11:18.328	debug	(10321) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"lock","ack":false,"ts":1601543478320,"q":0,"from":"system.adapter.cloud.0","user":"system.user.admin","lc":1601543478320}```
                              • P patrick039212
                                @Asgothian
                                anbei die logs
                                unlock
                                unlocked
                                locked
                                lock
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                #93
                                @patrick039212 Das erste log ist leider abgeschnitten. Du hast es wahrscheinlich aus dem Admin kopiert. Ich brauche aber die vollständige Zeile. Insbesondere die Zeile
                                geht noch weiter. Ich muss wissen was da noch kommt.
                                A.
                                  A.
                                  patrick039212
                                  #94
                                  @Asgothian
                                  (10321) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.unlockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecovery':false,'disableDefaultResponse':true,'direction':0,'srcEndpoint':null,'reservedBits':0,'manufacturerCode':null,'transactionSequenceNumber':null)) failed (no response received)
                                  habe leider keinen SSH zugriff, bin im Büro aber das ist die ganze Zeile
                                  Kannst du damit etwas anfangen ?
                                  soll ich evtl. mal die neue Version installieren die du am Wochenende gepostet hast ?
                                  • P patrick039212
                                    @Asgothian
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    #95
                                    @patrick039212
                                    Bitte ja.
                                    Bitte beschreib auch mal wo das Schloss liegt und wo der Zigbee-Stick angeschlossen ist. Es scheint als ob das Schloss die Nachrichten vom Adapter nicht erhält, während die Nachrichten vom Schloss an den Adapter durch kommen.
                                    Das deutet meiner Meinung nach auf ein Problem bei der Funkstreife hin. Die Fehlermeldungen wenn du "locked" und "unlocked" einträgst sind normal - die korrekten Befehle sind "lock" und "unlock"
                                    A.
                                      @patrick039212
                                      Bitte ja.
                                      A.
                                      patrick039212
                                      #96
                                      @Asgothian
                                      Mein Pi liegt ca 2m vom schloss entfernt, also glaube nicht das es wegen der entfernung ist ...
                                      Kann ich den Adapter link einfach installieren oder muss ich die jetzige version zuerst lösachen ?
                                      • P patrick039212
                                        @Asgothian
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        #97
                                        @patrick039212 du solltest den direkt installieren können.
                                          patrick039212
                                          #98
                                          @Asgothian
                                          leider keine besserung ...
                                          zigbee.0	2020-10-03 19:18:19.216	debug	(25834) system.adapter.admin.0: logging true
                                          zigbee.0	2020-10-03 19:17:55.232	error	at processTimers (internal/timers.js:489:9)
                                          zigbee.0	2020-10-03 19:17:55.232	error	at runNextTicks (internal/process/task_queues.js:62:5)
                                          zigbee.0	2020-10-03 19:17:55.232	error	at runMicrotasks (<anonymous>)
                                          zigbee.0	2020-10-03 19:17:55.232	error	at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:25:65)
                                          zigbee.0	2020-10-03 19:17:55.232	error	at Generator.throw (<anonymous>)
                                          zigbee.0	2020-10-03 19:17:55.232	error	at DeconzAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:552:23)
                                          zigbee.0	2020-10-03 19:17:55.232	error	(25834) Error on send command to 0x000b57fffe59e779. Error: Error: Command 0x000b57fffe59e779/1 closuresDoorLock.unlockDoor({"pincodevalue":""}, {"timeout":10000,"disableResponse":false,"disableRecov
                                          zigbee.0	2020-10-03 19:17:51.127	debug	(25834) system.adapter.admin.0: logging false
                                          zigbee.0	2020-10-03 19:17:06.515	debug	(25834) system.adapter.admin.0: logging true
                                          zigbee.0	2020-10-03 19:16:57.121	debug	(25834) system.adapter.admin.0: logging false
                                          zigbee.0	2020-10-03 19:16:54.677	debug	(25834) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","cluste
                                          zigbee.0	2020-10-03 19:16:54.675	debug	(25834) convert state, unlock, {}
                                          zigbee.0	2020-10-03 19:16:54.671	debug	(25834) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":
                                          zigbee.0	2020-10-03 19:16:54.666	debug	(25834) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"valu
                                          zigbee.0	2020-10-03 19:16:54.661	debug	(25834) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
                                          zigbee.0	2020-10-03 19:16:54.644	debug	(25834) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"unlock","ack":false,"ts":1601745414628,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1601745414628}
                                          zigbee.0	2020-10-03 19:16:32.006	debug	(25834) system.adapter.admin.0: logging true
                                          zigbee.0	2020-10-03 19:16:23.611	debug	(25834) Publish available for 0x00158d00042e3307 = true
                                          zigbee.0	2020-10-03 19:16:23.604	debug	(25834) Publish available for 0x00158d000358efeb = true
                                          zigbee.0	2020-10-03 19:16:23.582	debug	(25834) Publish available for 0x000b57fffe59e779 = true
                                          zigbee.0	2020-10-03 19:16:22.617	info	(25834) Zigbee started
