  4. Zigbee-Adapter 1.0.2 Danalock
    6.5k
zigbee adapterdanalock
191 Beiträge 13 Kommentatoren 36.1k Aufrufe 15 Beobachtet
  • P patrick039212
    gibt es schon eine Lösung ? habe den neuen Adapter installiert 1.2, leider kann ich den stat garnicht mehr ändern und der Status wird nicht korrekt angezeigt...
    3573) system.adapter.admin.0: logging true
    falsezigbee.0	2020-09-22 19:03:43.477	debug	(3573) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":52903,"deviceIeeeAddress":"0x000b57fffe59e779","cluster
    falsezigbee.0	2020-09-22 19:03:43.474	debug	(3573) convert state, unlock, {}
    falsezigbee.0	2020-09-22 19:03:43.472	debug	(3573) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":52903,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":1
    falsezigbee.0	2020-09-22 19:03:43.464	debug	(3573) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value
    falsezigbee.0	2020-09-22 19:03:43.461	debug	(3573) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
    falsezigbee.0	2020-09-22 19:03:43.454	debug	(3573) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"unlock","ack":false,"ts":1600794223445,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1600794214614}
    falsezigbee.0	2020-09-22 19:03:36.225	debug	(3573) system.adapter.admin.0: logging false
    falsezigbee.0	2020-09-22 19:03:34.648	debug	(3573) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":52903,"deviceIeeeAddress":"0x000b57fffe59e779","cluster
    falsezigbee.0	2020-09-22 19:03:34.645	debug	(3573) convert state, unlock, {}
    falsezigbee.0	2020-09-22 19:03:34.643	debug	(3573) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":52903,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":1
    falsezigbee.0	2020-09-22 19:03:34.637	debug	(3573) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value
    falsezigbee.0	2020-09-22 19:03:34.633	debug	(3573) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
    falsezigbee.0	2020-09-22 19:03:34.625	debug	(3573) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"unlock","ack":false,"ts":1600794214614,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1600794214614}
    falsezigbee.0
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @patrick039212
    Ich brauche noch mal ein paar Details. Kannst Du bitte den folgenden Test machen ?
    • Danalock aus dem Adapter entfernen (unpair)
    • Danalock neu pairen
    Wenn ich das richtig erinnere sollte das Schloss jetzt sauber funktionieren und auch den Status melden.
    Jetzt kommt das entscheidende:
    • Adapter auf Debug stellen
    • Adapter neu starten. Ich erwarte Zeilen wie diese:
    DeviceConfigure 0x90fd9ffffe6de22b TRADFRI transformer 10W not needed
    für das Danalock. Wenn diese Zeilen kommen, und das Schloss in der Folge nicht reagiert habe kann ich kurzfristig eine Adapterversion zur Verfügung stellen die eine chance hat das Problem zu beseitigen.
    A.
    P 1 Antwort Letzte Antwort
    • AsgothianA Asgothian
      @patrick039212
      A.
      patrick039212
      schrieb am zuletzt editiert von patrick039212
      @Asgothian
      leider kann ich das Schloss nicht entfernen ... es lässt sich einfach nicht löschen ...
      Failed to remove TypeError: Cannot read property 'stack' of undefined at ZigbeeController.remove (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:358:65)
      • P patrick039212
        @Asgothian
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        #66
        @patrick039212
        Auch mit "force" für lost devices nicht ?
          @patrick039212
          patrick039212
          #67
          @Asgothian
          nein es wird immer als Aktiv angezeigt... ohne force kommt diese Meldung
          • P patrick039212
            @Asgothian
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            #68
            @patrick039212
            können wir uns per TS/Discord und Anydesk zusammen hängen, dann kann ich das Schloss 'raus patchen'
              @patrick039212
              patrick039212
              #69
              @Asgothian
              LOG inkl. versuch über iobroker zusperren
              zigbee.0	2020-09-22 23:34:29.375	debug	(5369) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '255.353' seconds ago.
              zigbee.0	2020-09-22 23:34:16.935	debug	(5369) system.adapter.admin.0: logging true
              zigbee.0	2020-09-22 23:34:09.348	debug	(5369) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":58277,"deviceIeeeAddress":"0x000b57fffe59e779","cluster
              zigbee.0	2020-09-22 23:34:09.346	debug	(5369) convert state, unlock, {}
              zigbee.0	2020-09-22 23:34:09.345	debug	(5369) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":58277,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":1
              zigbee.0	2020-09-22 23:34:09.339	debug	(5369) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value
              zigbee.0	2020-09-22 23:34:09.336	debug	(5369) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
              zigbee.0	2020-09-22 23:34:09.331	debug	(5369) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"unlock","ack":false,"ts":1600810449323,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1600810449323}
              zigbee.0	2020-09-22 23:33:57.847	debug	(5369) system.adapter.admin.0: logging false
              zigbee.0	2020-09-22 23:32:29.285	error	at runMicrotasks (<anonymous>)
              zigbee.0	2020-09-22 23:32:29.285	error	at /opt/iobroker/node_modules/iobroker.zigbee/main.js:369:48
              zigbee.0	2020-09-22 23:32:29.285	error	at Object.convertSet (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/converters/toZigbee.js:1459:26)
              zigbee.0	2020-09-22 23:32:29.285	error	at Endpoint.command (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:360:16)
              zigbee.0	2020-09-22 23:32:29.285	error	at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:23:12)
              zigbee.0	2020-09-22 23:32:29.285	error	at new Promise (<anonymous>)
              zigbee.0	2020-09-22 23:32:29.285	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:27:71
              zigbee.0	2020-09-22 23:32:29.285	error	at Generator.next (<anonymous>)
              zigbee.0	2020-09-22 23:32:29.285	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:362:37)
              zigbee.0	2020-09-22 23:32:29.285	error	at Object.getCommand (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/zcl/utils.js:107:19)
              zigbee.0	2020-09-22 23:32:29.285	error	(5369) Error on send command to 0x000b57fffe59e779. Error: Error: Cluster 'closuresDoorLock' has no command 'lockedDoor'
              zigbee.0	2020-09-22 23:32:29.266	debug	(5369) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":58277,"deviceIeeeAddress":"0x000b57fffe59e779","cluster
              zigbee.0	2020-09-22 23:32:29.265	debug	(5369) convert state, locked, {}
              zigbee.0	2020-09-22 23:32:29.261	debug	(5369) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":58277,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":1
              zigbee.0	2020-09-22 23:32:29.253	debug	(5369) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value
              zigbee.0	2020-09-22 23:32:29.249	debug	(5369) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
              zigbee.0	2020-09-22 23:32:29.227	debug	(5369) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"locked","ack":false,"ts":1600810349220,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1600799408406}
              zigbee.0	2020-09-22 23:30:14.097	debug	(5369) Publish {"state":"LOCK","lock_state":"locked"}
              zigbee.0	2020-09-22 23:30:14.063	debug	(5369) Type attributeReport device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":58277,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profile
              zigbee.0	2020-09-22 23:30:14.054	debug	(5369) Received Zigbee message from '0x000b57fffe59e779', type 'attributeReport', cluster 'closuresDoorLock', data '{"lockState":1}' from endpoint 1 with groupID null
              zigbee.0	2020-09-22 23:30:14.032	debug	(5369) handleMessage. {"type":"attributeReport","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":58277,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":
              zigbee.0	2020-09-22 23:30:08.301	debug	(5369) Publish {"state":"LOCK","lock_state":"locked"}
              zigbee.0	2020-09-22 23:30:07.983	debug	(5369) Type attributeReport device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":58277,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profile
              zigbee.0	2020-09-22 23:30:07.979	debug	(5369) Received Zigbee message from '0x000b57fffe59e779', type 'attributeReport', cluster 'closuresDoorLock', data '{"lockState":1}' from endpoint 1 with groupID null
              zigbee.0	2020-09-22 23:30:07.938	debug	(5369) handleMessage. {"type":"attributeReport","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":58277,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":
              zigbee.0	2020-09-22 23:29:29.375	debug	(5369) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '3555.098' seconds ago.
              zigbee.0	2020-09-22 23:24:29.375	debug	(5369) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '3255.098' seconds ago.
              • P patrick039212
                @Asgothian
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                #70
                @patrick039212 sagte in Zigbee-Adapter 1.0.2 Danalock:
                Installier mal bitte den Adapter von meinem GitHub. Ich hab da nen Hack eingebaut das das Schloss bei jedem Start zwangsweise ein Configure durchläuft. (https://github.com/asgothian/ioBroker.zigbee)
                Vielleicht sind die Fehler dann weg.
                Ansonsten scheint das Problem mit dem nicht löschen können vom experimentellen Support für den Conbee zu stammen. Die Meldungen die du hattest kommen tief aus dem Zigbee-Herdsman. Wenn ich das mit nem conbee 1 nachstellen kann kann ich mal schauen was da im Argen ist.
                A.
                  A.
                  patrick039212
                  #71
                  @Asgothian said in Zigbee-Adapter 1.0.2 Danalock:
                  Danke werde ich sofort testen,
                  heute habe ich leider wieder die verbindung verloren, habe nun meinen PI in der nähe vom Schloss angeschlossen, nachdem ich in der Danalock APP das pairing gestartet habe konnte ich ohne probleme das Schloss im Adapter löschen.
                  Ed:
                  Leider ändert sich bei mir der Status nicht mehr von locked / unlocked... öffnen schließen ist über den Adapter möglich
                  Adapter start
                  zigbee.0	2020-09-25 13:01:54.397	debug	(2647) Publish available for 0x00158d00042e3307 = true
                  zigbee.0	2020-09-25 13:01:54.385	debug	(2647) Publish available for 0x00158d000358efeb = true
                  zigbee.0	2020-09-25 13:01:54.355	debug	(2647) Publish available for 0x000b57fffe59e779 = true
                  zigbee.0	2020-09-25 13:01:53.405	info	(2647) Zigbee started
                  zigbee.0	2020-09-25 13:01:53.400	info	(2647) 0x00158d00042e3307 (addr 10193): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                  zigbee.0	2020-09-25 13:01:53.396	debug	(2647) New device event: {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],
                  zigbee.0	2020-09-25 13:01:53.392	info	(2647) 0x00158d000358efeb (addr 9532): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                  zigbee.0	2020-09-25 13:01:53.386	debug	(2647) New device event: {"type":"device","device":{"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d000358efeb","_networkAddress":9532,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputClusters":[],"
                  zigbee.0	2020-09-25 13:01:53.374	info	(2647) 0x000b57fffe59e779 (addr 23663): V3-BTZB - Danalock BT/ZB smartlock (EndDevice)
                  zigbee.0	2020-09-25 13:01:53.360	debug	(2647) New device event: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":23663,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"de
                  zigbee.0	2020-09-25 13:01:53.352	debug	(2647) DeviceConfigure 0x00158d00042e3307 lumi.sensor_magnet not needed
                  zigbee.0	2020-09-25 13:01:53.350	debug	(2647) DeviceConfigure 0x00158d000358efeb lumi.sensor_magnet not needed
                  zigbee.0	2020-09-25 13:01:53.348	debug	(2647) DeviceConfigure 0x000b57fffe59e779 V3-BTZB not needed
                  zigbee.0	2020-09-25 13:01:53.345	debug	(2647) Publish available for 0x00158d00042e3307 = true
                  zigbee.0	2020-09-25 13:01:53.343	debug	(2647) Publish available for 0x00158d000358efeb = true
                  zigbee.0	2020-09-25 13:01:53.336	debug	(2647) Publish available for 0x000b57fffe59e779 = true
                  zigbee.0	2020-09-25 13:01:53.333	info	(2647) Currently 3 devices are joined:
                  zigbee.0	2020-09-25 13:01:53.316	info	(2647) Unable to set transmit power, unsupported function.
                  zigbee.0	2020-09-25 13:01:53.307	info	(2647) --> transmitPower : normal
                  zigbee.0	2020-09-25 13:01:53.305	info	(2647) Unable to disable LED, unsupported function.
                  zigbee.0	2020-09-25 13:01:53.301	debug	(2647) Zigbee network parameters: {"panID":6754,"extendedPanID":"0xdddddddddddddddd","channel":11}
                  zigbee.0	2020-09-25 13:01:53.117	info	(2647) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}}
                  zigbee.0	2020-09-25 13:01:53.062	debug	(2647) zigbee-herdsman started
                  zigbee.0	2020-09-25 13:01:52.435	debug	(2647) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_09_25-13_01_51.tar.gz success
                  zigbee.0	2020-09-25 13:01:51.910	debug	(2647) Starting zigbee-herdsman...
                  zigbee.0	2020-09-25 13:01:51.905	info	(2647) Starting Zigbee...
                  zigbee.0	2020-09-25 13:01:51.747	debug	(2647) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databas
                  zigbee.0	2020-09-25 13:01:51.740	error	(2647) Serial port not selected! Go to settings page.
                  zigbee.0	2020-09-25 13:01:51.653	info	(2647) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                  öffnen / schließen über iobroker
                  zigbee.0	2020-09-25 13:11:14.755	debug	(2647) system.adapter.admin.0: logging true
                  zigbee.0	2020-09-25 13:11:05.310	debug	(2647) convert result {"readAfterWriteTime":200}
                  zigbee.0	2020-09-25 13:11:03.680	debug	(2647) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":23663,"deviceIeeeAddress":"0x000b57fffe59e779","cluster
                  zigbee.0	2020-09-25 13:11:03.678	debug	(2647) convert state, lock, {}
                  zigbee.0	2020-09-25 13:11:03.676	debug	(2647) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":23663,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":1
                  zigbee.0	2020-09-25 13:11:03.674	debug	(2647) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value
                  zigbee.0	2020-09-25 13:11:03.671	debug	(2647) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
                  zigbee.0	2020-09-25 13:11:03.645	debug	(2647) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"lock","ack":false,"ts":1601032263636,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1601032263636}
                  zigbee.0	2020-09-25 13:10:52.276	debug	(2647) convert result {"readAfterWriteTime":200}
                  zigbee.0	2020-09-25 13:10:52.035	debug	(2647) system.adapter.admin.0: logging false
                  zigbee.0	2020-09-25 13:10:48.088	debug	(2647) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":23663,"deviceIeeeAddress":"0x000b57fffe59e779","cluster
                  zigbee.0	2020-09-25 13:10:48.085	debug	(2647) convert state, unlock, {}
                  zigbee.0	2020-09-25 13:10:48.084	debug	(2647) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":23663,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":1
                  zigbee.0	2020-09-25 13:10:48.079	debug	(2647) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value
                  zigbee.0	2020-09-25 13:10:48.076	debug	(2647) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
                  Wenn ich das Schloss mit der Hand öffne / schließe bleibt der LOG komplett leer ...
                  Löschen war jetzt kein Problem mehr - nach update
                  Nach neu pairing zeigt er mir wieder den Status an ...
                  • P patrick039212
                    Ed:
                    Adapter start
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    #72
                    @patrick039212 das sieht so aus als ob mein Hack nicht wirkt. Da muss ich noch mal schauen.
                    Kannst du noch einmal von github (github.com/asgothian/ioBroker.zigbee) installieren, den Adapter mit debug an neu starten und dann ein log Posten ?
                    Ggf. Geht es mit dem Statusupdate jetzt.
                    A.
                      A.
                      patrick039212
                      #73
                      @Asgothian
                      sry das ich erst jetzt mich Rückmelde, ich habe bis jetzt leider noch nicht die Zeit gefunden den Adapter nochmals Upzudaten, eines kann ich bis jetzt aber sagen, auch ohne das neue Update von dir (dein letzter Post) hatte ich bis heute keine weiteren Probleme mehr.
                      Sobald das Schloss geöffnet bzw. geschlossen wird bekomme ich über Telegramm eine Rückmeldung, somit müsste der Status theoretisch im Iobroker geändert werden, aber ich sehe mir das am Abend nochmals alles und gebe dann Bescheid.
                      Danke jedenfalls für deine Hilfe :)
                      • P patrick039212
                        @Asgothian
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        #74
                        @patrick039212
                        Hallo Patrick,
                        bleibt das auch so wenn du den Zigbee Adapter neu startest ? Wenn nein, dann müsstest Du bitte noch den Test machen.
                        A.
                        P 2 Antworten Letzte Antwort
                          @patrick039212
                          Hallo Patrick,
                          A.
                          patrick039212
                          #75
                          @Asgothian
                          werde ich heute Abend nochmal alles testen, bin leider noch in der Firma... Gebe dir aber jedenfalls Bescheid :)
                            @patrick039212
                            Hallo Patrick,
                            A.
                            patrick039212
                            #76
                            @Asgothian
                            Funktioniert trotz neustart alles :)
                            zigbee.0	2020-09-30 14:23:39.521	debug	(1205) system.adapter.admin.0: logging true
                            zigbee.0	2020-09-30 14:23:37.063	debug	(1205) Publish {"state":"LOCK","lock_state":"locked"}
                            zigbee.0	2020-09-30 14:23:37.051	debug	(1205) Type attributeReport device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profile
                            zigbee.0	2020-09-30 14:23:37.047	debug	(1205) Received Zigbee message from '0x000b57fffe59e779', type 'attributeReport', cluster 'closuresDoorLock', data '{"lockState":1}' from endpoint 1 with groupID null
                            zigbee.0	2020-09-30 14:23:37.036	debug	(1205) handleMessage. {"type":"attributeReport","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":
                            zigbee.0	2020-09-30 14:23:36.543	debug	(1205) Publish {"action":"lock","action_user":65535,"action_source":1,"action_source_name":"rf"}
                            zigbee.0	2020-09-30 14:23:36.534	debug	(1205) Type commandOperationEventNotification device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints"
                            zigbee.0	2020-09-30 14:23:36.529	debug	(1205) Received Zigbee message from '0x000b57fffe59e779', type 'commandOperationEventNotification', cluster 'closuresDoorLock', data '{"opereventsrc":1,"opereventcode":1,"userid":65535,"pin":0,"zigbe
                            zigbee.0	2020-09-30 14:23:36.516	debug	(1205) handleMessage. {"type":"commandOperationEventNotification","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"
                            zigbee.0	2020-09-30 14:23:33.993	debug	(1205) convert result {"readAfterWriteTime":200}
                            zigbee.0	2020-09-30 14:23:29.951	debug	(1205) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","cluster
                            zigbee.0	2020-09-30 14:23:29.948	debug	(1205) convert state, lock, {}
                            zigbee.0	2020-09-30 14:23:29.946	debug	(1205) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":1
                            zigbee.0	2020-09-30 14:23:29.942	debug	(1205) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value
                            zigbee.0	2020-09-30 14:23:29.939	debug	(1205) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
                            zigbee.0	2020-09-30 14:23:29.929	debug	(1205) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"lock","ack":false,"ts":1601468609921,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1601468609921}
                            zigbee.0	2020-09-30 14:23:26.003	debug	(1205) Publish {"state":"UNLOCK","lock_state":"unlocked"}
                            zigbee.0	2020-09-30 14:23:25.994	debug	(1205) Type attributeReport device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profile
                            zigbee.0	2020-09-30 14:23:25.990	debug	(1205) Received Zigbee message from '0x000b57fffe59e779', type 'attributeReport', cluster 'closuresDoorLock', data '{"lockState":2}' from endpoint 1 with groupID null
                            zigbee.0	2020-09-30 14:23:25.981	debug	(1205) handleMessage. {"type":"attributeReport","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":
                            zigbee.0	2020-09-30 14:23:25.573	debug	(1205) Publish {"action":"unlock","action_user":65535,"action_source":1,"action_source_name":"rf"}
                            zigbee.0	2020-09-30 14:23:25.528	debug	(1205) Type commandOperationEventNotification device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints"
                            zigbee.0	2020-09-30 14:23:25.520	debug	(1205) Received Zigbee message from '0x000b57fffe59e779', type 'commandOperationEventNotification', cluster 'closuresDoorLock', data '{"opereventsrc":1,"opereventcode":2,"userid":65535,"pin":0,"zigbe
                            zigbee.0	2020-09-30 14:23:25.503	debug	(1205) handleMessage. {"type":"commandOperationEventNotification","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"
                            zigbee.0	2020-09-30 14:23:23.020	debug	(1205) convert result {"readAfterWriteTime":200}
                            zigbee.0	2020-09-30 14:23:18.021	debug	(1205) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","cluster
                            zigbee.0	2020-09-30 14:23:18.018	debug	(1205) convert state, unlock, {}
                            • P patrick039212
                              @Asgothian
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              #77
                              @patrick039212
                              Dann sollten wir das weiter beobachten. Wenn das so bleibt dann nehm ich das mit in den Hauptzweck, aber mit einer etwas weniger rabiaten Anpassung zum konfigurieren
                              A.
                                @patrick039212
                                A.
                                patrick039212
                                #78
                                @Asgothian leider wieder ein Fehler
                                zigbee.0	2020-10-01 09:55:29.263	debug	(4321) system.adapter.cloud.0: logging true
                                zigbee.0	2020-10-01 09:52:44.553	debug	(4321) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '752.122' seconds ago.
                                zigbee.0	2020-10-01 09:52:44.549	debug	(4321) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '3073.56' seconds ago.
                                zigbee.0	2020-10-01 09:52:44.541	debug	(4321) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '137.817' seconds ago.
                                zigbee.0	2020-10-01 09:51:20.935	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                zigbee.0	2020-10-01 09:51:20.935	error	at /opt/iobroker/node_modules/iobroker.zigbee/main.js:373:48
                                zigbee.0	2020-10-01 09:51:20.935	error	at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/converters/toZigbee.js:1532:26)
                                zigbee.0	2020-10-01 09:51:20.935	error	at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:396:16)
                                zigbee.0	2020-10-01 09:51:20.935	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:23:12)
                                zigbee.0	2020-10-01 09:51:20.935	error	at new Promise (<anonymous>)
                                zigbee.0	2020-10-01 09:51:20.935	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:27:71
                                zigbee.0	2020-10-01 09:51:20.935	error	at Generator.next (<anonymous>)
                                zigbee.0	2020-10-01 09:51:20.935	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:398:37)
                                zigbee.0	2020-10-01 09:51:20.935	error	at Object.getCommand (/opt/iobroker/node_modules/zigbee-herdsman/dist/zcl/utils.js:107:19)
                                zigbee.0	2020-10-01 09:51:20.935	error	(4321) Error on send command to 0x000b57fffe59e779. Error: Error: Cluster 'closuresDoorLock' has no command 'unlockedDoor'
                                zigbee.0	2020-10-01 09:51:20.927	debug	(4321) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","cluster
                                zigbee.0	2020-10-01 09:51:20.920	debug	(4321) convert state, unlocked, {}
                                zigbee.0	2020-10-01 09:51:20.918	debug	(4321) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":1
                                zigbee.0	2020-10-01 09:51:20.914	debug	(4321) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value
                                zigbee.0	2020-10-01 09:51:20.911	debug	(4321) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
                                zigbee.0	2020-10-01 09:51:20.895	debug	(4321) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"unlocked","ack":false,"ts":1601538680887,"q":0,"from":"system.adapter.cloud.0","user":"system.user.admin","lc":1601538680887}
                                zigbee.0	2020-10-01 09:51:08.806	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                zigbee.0	2020-10-01 09:51:08.806	error	at /opt/iobroker/node_modules/iobroker.zigbee/main.js:373:48
                                zigbee.0	2020-10-01 09:51:08.806	error	at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/converters/toZigbee.js:1532:26)
                                zigbee.0	2020-10-01 09:51:08.806	error	at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:396:16)
                                zigbee.0	2020-10-01 09:51:08.806	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:23:12)
                                zigbee.0	2020-10-01 09:51:08.806	error	at new Promise (<anonymous>)
                                zigbee.0	2020-10-01 09:51:08.806	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:27:71
                                zigbee.0	2020-10-01 09:51:08.806	error	at Generator.next (<anonymous>)
                                zigbee.0	2020-10-01 09:51:08.806	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:398:37)
                                zigbee.0	2020-10-01 09:51:08.806	error	at Object.getCommand (/opt/iobroker/node_modules/zigbee-herdsman/dist/zcl/utils.js:107:19)
                                zigbee.0	2020-10-01 09:51:08.806	error	(4321) Error on send command to 0x000b57fffe59e779. Error: Error: Cluster 'closuresDoorLock' has no command 'lockedDoor'
                                zigbee.0	2020-10-01 09:51:08.804	debug	(4321) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","cluster
                                zigbee.0	2020-10-01 09:51:08.803	debug	(4321) convert state, locked, {}
                                zigbee.0	2020-10-01 09:51:08.802	debug	(4321) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":1
                                zigbee.0	2020-10-01 09:51:08.801	debug	(4321) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value
                                zigbee.0	2020-10-01 09:51:08.799	debug	(4321) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
                                zigbee.0	2020-10-01 09:51:08.796	debug	(4321) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"locked","ack":false,"ts":1601538668792,"q":0,"from":"system.adapter.cloud.0","user":"system.user.admin","lc":1601538620765}
                                zigbee.0	2020-10-01 09:50:26.745	debug	(4321) Publish {"state":"LOCK","lock_state":"locked"}
                                zigbee.0	2020-10-01 09:50:26.738	debug	(4321) Type attributeReport device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profile
                                zigbee.0	2020-10-01 09:50:26.735	debug	(4321) Received Zigbee message from '0x000b57fffe59e779', type 'attributeReport', cluster 'closuresDoorLock', data '{"lockState":1}' from endpoint 1 with groupID null
                                zigbee.0	2020-10-01 09:50:26.728	debug	(4321) handleMessage. {"type":"attributeReport","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":
                                zigbee.0	2020-10-01 09:50:20.710	debug	(4321) Publish {"state":"LOCK","lock_state":"locked"}
                                zigbee.0	2020-10-01 09:50:20.699	debug	(4321) Type attributeReport device {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profile
                                zigbee.0	2020-10-01 09:50:20.696	debug	(4321) Received Zigbee message from '0x000b57fffe59e779', type 'attributeReport', cluster 'closuresDoorLock', data '{"lockState":1}' from endpoint 1 with groupID null
                                zigbee.0	2020-10-01 09:50:20.671	debug	(4321) handleMessage. {"type":"attributeReport","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":
                                zigbee.0	2020-10-01 09:47:44.553	debug	(4321) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '452.122' seconds ago.
                                zigbee.0	2020-10-01 09:47:44.549	debug	(4321) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '2773.56' seconds ago.
                                zigbee.0	2020-10-01 09:47:44.541	debug	(4321) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '3438.69' seconds ago.
                                zigbee.0	2020-10-01 09:45:17.018	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                zigbee.0	2020-10-01 09:45:17.018	error	at /opt/iobroker/node_modules/iobroker.zigbee/main.js:373:48
                                zigbee.0	2020-10-01 09:45:17.018	error	at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/converters/toZigbee.js:1532:26)
                                zigbee.0	2020-10-01 09:45:17.018	error	at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:396:16)
                                zigbee.0	2020-10-01 09:45:17.018	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:23:12)
                                zigbee.0	2020-10-01 09:45:17.018	error	at new Promise (<anonymous>)
                                zigbee.0	2020-10-01 09:45:17.018	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:27:71
                                zigbee.0	2020-10-01 09:45:17.018	error	at Generator.next (<anonymous>)
                                zigbee.0	2020-10-01 09:45:17.018	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:398:37)
                                zigbee.0	2020-10-01 09:45:17.018	error	at Object.getCommand (/opt/iobroker/node_modules/zigbee-herdsman/dist/zcl/utils.js:107:19)
                                zigbee.0	2020-10-01 09:45:17.018	error	(4321) Error on send command to 0x000b57fffe59e779. Error: Error: Cluster 'closuresDoorLock' has no command 'unlockedDoor'
                                zigbee.0	2020-10-01 09:45:17.005	debug	(4321) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","cluster
                                zigbee.0	2020-10-01 09:45:17.001	debug	(4321) convert state, unlocked, {}
                                zigbee.0	2020-10-01 09:45:16.999	debug	(4321) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":1
                                zigbee.0	2020-10-01 09:45:16.994	debug	(4321) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value
                                zigbee.0	2020-10-01 09:45:16.990	debug	(4321) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
                                zigbee.0	2020-10-01 09:45:16.983	debug	(4321) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"unlocked","ack":false,"ts":1601538316977,"q":0,"from":"system.adapter.cloud.0","user":"system.user.admin","lc":1601538316977}
                                zigbee.0	2020-10-01 09:44:45.715	debug	(4321) system.adapter.cloud.0: logging false
                                zigbee.0	2020-10-01 09:42:44.553	debug	(4321) Non-pingable device 0x00158d00042e3307 lumi.sensor_magnet was last seen '152.122' seconds ago.
                                zigbee.0	2020-10-01 09:42:44.549	debug	(4321) Non-pingable device 0x00158d000358efeb lumi.sensor_magnet was last seen '2473.56' seconds ago.
                                zigbee.0	2020-10-01 09:42:44.541	debug	(4321) Non-pingable device 0x000b57fffe59e779 V3-BTZB was last seen '3138.69' seconds ago.
                                zigbee.0	2020-10-01 09:40:12.494	debug	(4321) Publish {"voltage":3005,"battery":100}
                                zigbee.0	2020-10-01 09:40:12.459	debug	(4321) Type attributeReport device {"type":"device","device":{"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00158d00042e3307","_networkAddress":10193,"_manufacturerID":4151,"_endpoints":[{"ID":1,"inputCl
                                unlock via iobroker
                                zigbee.0	2020-10-01 10:00:23.937	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                zigbee.0	2020-10-01 10:00:23.937	error	at /opt/iobroker/node_modules/iobroker.zigbee/main.js:373:48
                                zigbee.0	2020-10-01 10:00:23.937	error	at Object.convertSet (/opt/iobroker/node_modules/zigbee-herdsman-converters/converters/toZigbee.js:1532:26)
                                zigbee.0	2020-10-01 10:00:23.937	error	at Endpoint.command (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:396:16)
                                zigbee.0	2020-10-01 10:00:23.937	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:23:12)
                                zigbee.0	2020-10-01 10:00:23.937	error	at new Promise (<anonymous>)
                                zigbee.0	2020-10-01 10:00:23.937	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:27:71
                                zigbee.0	2020-10-01 10:00:23.937	error	at Generator.next (<anonymous>)
                                zigbee.0	2020-10-01 10:00:23.937	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:398:37)
                                zigbee.0	2020-10-01 10:00:23.937	error	at Object.getCommand (/opt/iobroker/node_modules/zigbee-herdsman/dist/zcl/utils.js:107:19)
                                zigbee.0	2020-10-01 10:00:23.937	error	(4321) Error on send command to 0x000b57fffe59e779. Error: Error: Cluster 'closuresDoorLock' has no command 'unlockedDoor'
                                zigbee.0	2020-10-01 10:00:23.930	debug	(4321) target: {"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,1,3,9,32,257,2821],"outputClusters":[10,25,2821],"deviceNetworkAddress":22061,"deviceIeeeAddress":"0x000b57fffe59e779","cluster
                                zigbee.0	2020-10-01 10:00:23.928	debug	(4321) convert state, unlocked, {}
                                zigbee.0	2020-10-01 10:00:23.926	debug	(4321) entity: {"type":"device","device":{"ID":2,"_type":"EndDevice","_ieeeAddr":"0x000b57fffe59e779","_networkAddress":22061,"_manufacturerID":4444,"_endpoints":[{"ID":1,"profileID":260,"deviceID":1
                                zigbee.0	2020-10-01 10:00:23.923	debug	(4321) State changes. dev: 0x000b57fffe59e779 model: V3-BTZB states: [{"stateDesc":{"id":"lockState","prop":"state","name":"Lock state","role":"state","write":true,"read":true,"type":"string"},"value
                                zigbee.0	2020-10-01 10:00:23.913	debug	(4321) Change state 'lockState' at device 0x000b57fffe59e779 type 'V3-BTZB'
                                zigbee.0	2020-10-01 10:00:23.908	debug	(4321) User stateChange zigbee.0.000b57fffe59e779.lockState {"val":"unlocked","ack":false,"ts":1601539223900,"q":0,"from":"system.adapter.cloud.0","user":"system.user.admin","lc":1601539223900}
                                • P patrick039212
                                  unlock via iobroker
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  #79
                                  @patrick039212
                                  Dieser Fehler tritt nur sporadisch auf, oder jedes mal wenn du versuchst das Schloss vom ioBroker zu schalten oder ist der immer da ?
                                  Stürzt der ioBroker bei diesem Fehler ab oder bleibt er grün ?
                                    @patrick039212
                                    patrick039212
                                    #80
                                    @Asgothian
                                    kommt leider immer, Iobroker stürtzt dabei nicht ab ... kann es damit zusammen hängen das ich heute auf die Pro version gewechselt habe ?
                                    • P patrick039212
                                      @Asgothian
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      #81
                                      die "Pro version" von was ?
                                        patrick039212
                                        #82
                                        @Asgothian iobroker.pro
                                        • P patrick039212
                                          AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          #83
                                          @patrick039212 Nein
                                          P AsgothianA 2 Antworten Letzte Antwort
