  4. Fehler: host.raspberrypi Cannot install iobroker.i2
    1.5k
i2cadapter
81 Beiträge 5 Kommentatoren 4.3k Aufrufe 4 Beobachtet
  • HumidorH Online
    HumidorH Online
    Humidor
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi3B+
    Arbeitsspeicher: 1GB
    Festplattenart: SD-Karte
    Betriebssystem: RaspiOS
    Node-Version: 12.18.3
    Nodejs-Version: 12.18.3
    NPM-Version: 6.14.6
    Installationsart: Skript
    Image genutzt: Ja
    Ort/Name der Imagedatei: iobroker HP
    Fehlermeldung bei der Installation des I2C Adapters:
    Fertig mit Fehler: host.raspberrypi Cannot install iobroker.i2c@0.0.6: 1
    $ ./iobroker add i2c  --host raspberrypi
    NPM version: 6.14.6
    npm install iobroker.i2c@0.0.6 --loglevel error --prefix "/opt/iobroker" (System call)
    In file included from ../node_modules/nan/nan_converters.h:67,                 from ../node_modules/nan/nan.h:202,                 from ../src/i2c.cc:2:../node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase<v8::Boolean>::return_t Nan::imp::ToFactory<v8::Boolean>::convert(v8::Local<v8::Value>)’:../node_modules/nan/nan_converters_43_inl.h:18:69: warning: ‘v8::MaybeLocal<v8::Boolean> v8::Value::ToBoolean(v8::Local<v8::Context>) const’ is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations]       val->To ## TYPE(v8::Isolate::GetCurrent()->GetCurrentContext())          \        ^../node_modules/nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’ X(Boolean) ^
    In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2664:59: note: declared here                 V8_WARN_UNUSED_RESULT MaybeLocal<Boolean> ToBoolean(                                                           ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    In file included from ../node_modules/nan/nan_converters.h:67,                 from ../node_modules/nan/nan.h:202,                 from ../src/i2c.cc:2:../node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase<bool>::return_t Nan::imp::ToFactory<bool>::convert(v8::Local<v8::Value>)’:../node_modules/nan/nan_converters_43_inl.h:37:57: warning: ‘v8::Maybe<bool> v8::Value::BooleanValue(v8::Local<v8::Context>) const’ is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations]   return val->NAME ## Value(isolate->GetCurrentContext());                     \                                                         ^../node_modules/nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’ X(bool, Boolean) ^
    In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: declared here                 V8_WARN_UNUSED_RESULT Maybe<bool> BooleanValue(                                                   ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    In file included from ../node_modules/nan/nan_new.h:189,                 from ../node_modules/nan/nan.h:203,                 from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::Function>::return_t Nan::imp::Factory<v8::Function>::New(Nan::FunctionCallback, v8::Local<v8::Value>)’:../node_modules/nan/nan_implementation_12_inl.h:105:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfo<v8::Value>&), v8::Local<v8::Object>&)’                           , obj));                                ^
    In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:4275:31: note: candidate: ‘static v8::MaybeLocal<v8::Function> v8::Function::New(v8::Local<v8::Context>, v8::FunctionCallback, v8::Local<v8::Value>, int, v8::ConstructorBehavior, v8::SideEffectType)’   static MaybeLocal<Function> New(                               ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:4275:31: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
    In file included from ../node_modules/nan/nan_new.h:189,                 from ../node_modules/nan/nan.h:203,                 from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::StringObject>::return_t Nan::imp::Factory<v8::StringObject>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:337:37: error: no matching function for call to ‘v8::StringObject::New(v8::Local<v8::String>&)’   return v8::StringObject::New(value).As<v8::StringObject>();                                     ^
    In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:5531:23: note: candidate: ‘static v8::Local<v8::Value> v8::StringObject::New(v8::Isolate*, v8::Local<v8::String>)’   static Local<Value> New(Isolate* isolate, Local<String> value);                       ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:5531:23: note:   candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189,                 from ../node_modules/nan/nan.h:203,                 from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h:337:58: error: expected primary-expression before ‘>’ token   return v8::StringObject::New(value).As<v8::StringObject>();                                                          ^../node_modules/nan/nan_implementation_12_inl.h:337:60: error: expected primary-expression before ‘)’ token   return v8::StringObject::New(value).As<v8::StringObject>();                                                            ^
    In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:../node_modules/nan/nan.h:840:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, func, argc, argv);                                                            ^
    In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:840:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, func, argc, argv);                                                            ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:../node_modules/nan/nan.h:855:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, symbol, argc, argv);                                                              ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:175:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:855:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, symbol, argc, argv);                                                              ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:175:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
    In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’:../node_modules/nan/nan.h:870:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, method, argc, argv);                                                              ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:168:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:870:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, method, argc, argv);                                                              ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:168:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
    In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local<v8::Value>)’:../node_modules/nan/nan.h:916:53: error: no matching function for call to ‘v8::Value::ToString()’       v8::Local<v8::String> string = from->ToString();                                                     ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2668:44: note: candidate: ‘v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2668:44: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2684:31: note: candidate: ‘v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const’                 Local<String> ToString(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2684:31: note:   candidate expects 1 argument, 0 provided                 Local<String> ToString(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:926:74: error: no matching function for call to ‘v8::String::WriteUtf8(char*&, int, int, const int&)’         length_ = string->WriteUtf8(str_, static_cast<int>(len), 0, flags);        ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char*’ to ‘v8::Isolate*’
    In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’:../node_modules/nan/nan.h:1484:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]     ));     ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
    In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:1484:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]     ));     ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
    In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local<v8::Value>&)’:../node_modules/nan/nan.h:1538:64: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     New(persistentHandle)->Set(New(key).ToLocalChecked(), value);        ^
    In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’:../node_modules/nan/nan.h:1544:42: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     New(persistentHandle)->Set(key, value);                                          ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local<v8::Value>&)’:../node_modules/nan/nan.h:1550:44: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     New(persistentHandle)->Set(index, value);                                            ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3508:22: note: declared here                 bool Set(uint32_t index, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const char*) const’:../node_modules/nan/nan.h:1556:61: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]         New(persistentHandle)->Get(New(key).ToLocalChecked()));                                                             ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const v8::Local<v8::String>&) const’:../node_modules/nan/nan.h:1562:55: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return scope.Escape(New(persistentHandle)->Get(key));                                                       ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(uint32_t) const’:../node_modules/nan/nan.h:1567:57: warning: ‘v8::Local<v8::Value> v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return scope.Escape(New(persistentHandle)->Get(index));                                                         ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3557:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(uint32_t index));                                                   ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../node_modules/nan/nan.h:1875:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
    In file included from /usr/include/c++/8/cassert:44,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node_object_wrap.h:26,                 from ../node_modules/nan/nan.h:53,                 from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In destructor ‘virtual Nan::ObjectWrap::~ObjectWrap()’:../node_modules/nan/nan_object_wrap.h:24:25: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’     assert(persistent().IsNearDeath());                         ^~~~~~~~~~~
    In file included from ../node_modules/nan/nan.h:2365,                 from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:../node_modules/nan/nan_object_wrap.h:67:34: warning: ‘void v8::PersistentBase<T>::MarkIndependent() [with T = v8::Object]’ is deprecated: Weak objects are always considered independent. Use TracedGlobal when trying to use EmbedderHeapTracer. Use a strong handle when trying to keep an object alive. [-Wdeprecated-declarations]     persistent().MarkIndependent();                                  ^
    In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:570:22: note: declared here       V8_INLINE void MarkIndependent());                      ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    In file included from /usr/include/c++/8/cassert:44,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node_object_wrap.h:26,                 from ../node_modules/nan/nan.h:53,                 from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In static member function ‘static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’:../node_modules/nan/nan_object_wrap.h:124:26: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’     assert(wrap->handle_.IsNearDeath());                          ^~~~~~~~~~~
    In file included from ../src/i2c.cc:1:../src/i2c.cc: At global scope:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/i2c.cc:88:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(i2c, InitAll) ^~~~~~~~~~~
    In file included from ../src/i2c.cc:95:../src/./i2cfuncs.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE I2cFuncsAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./i2cfuncs.cc:48:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
    In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
    In file included from ../src/i2c.cc:95:../src/./i2cfuncs.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE I2cFuncsSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./i2cfuncs.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
    In file included from ../src/i2c.cc:96:../src/./readbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readbyte.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
    In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:96:../src/./readbyte.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
    In file included from ../src/i2c.cc:96:../src/./readbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readbyte.cc:62:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:96:../src/./readbyte.cc:63:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
    In file included from ../src/i2c.cc:97:../src/./readword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readword.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:97:../src/./readword.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:97:../src/./readword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readword.cc:62:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:97:../src/./readword.cc:63:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
    In file included from ../src/i2c.cc:98:../src/./readblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readblock.cc:66:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
    In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:98:../src/./readblock.cc:67:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
    In file included from ../src/i2c.cc:98:../src/./readblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readblock.cc:98:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:98:../src/./readblock.cc:99:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^
    In file included from ../src/i2c.cc:99:../src/./readi2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readi2cblock.cc:69:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
    In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:70:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:71:39: error: no matching function for call to ‘v8::Value::Uint32Value()’   __u32 length = info[2]->Uint32Value();                                       ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe<unsigned int> v8::Value::Uint32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<uint32_t> Uint32Value(                                         ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note:   candidate expects 1 argument, 0 provided
    In file included from ../src/i2c.cc:99:../src/./readi2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readi2cblock.cc:109:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:110:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:111:39: error: no matching function for call to ‘v8::Value::Uint32Value()’   __u32 length = info[2]->Uint32Value();                                       ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe<unsigned int> v8::Value::Uint32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<uint32_t> Uint32Value(                                         ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note:   candidate expects 1 argument, 0 provided
    In file included from ../src/i2c.cc:100:../src/./receivebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReceiveByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./receivebyte.cc:48:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
    In file included from ../src/i2c.cc:100:../src/./receivebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReceiveByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./receivebyte.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
    In file included from ../src/i2c.cc:101:../src/./sendbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SendByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./sendbyte.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
    In file included from ../src/i2c.cc:101:../src/./sendbyte.cc:48:35: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 byte = info[1]->Int32Value();                                   ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
    In file included from ../src/i2c.cc:101:../src/./sendbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SendByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./sendbyte.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:101:../src/./sendbyte.cc:61:35: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 byte = info[1]->Int32Value();                                   ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
    In file included from ../src/i2c.cc:102:../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./setaddr.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
    In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:48:34: error: no matching function for call to ‘v8::Value::Int32Value()’   int addr = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:49:44: error: no matching function for call to ‘v8::Value::BooleanValue()’   bool forceAccess = info[2]->BooleanValue();                                            ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate: ‘bool v8::Value::BooleanValue(v8::Isolate*) const’   bool BooleanValue(Isolate* isolate) const;        ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate: ‘v8::Maybe<bool> v8::Value::BooleanValue(v8::Local<v8::Context>) const’                 V8_WARN_UNUSED_RESULT Maybe<bool> BooleanValue(                                                   ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note:   candidate expects 1 argument, 0 provided                 V8_WARN_UNUSED_RESULT Maybe<bool> BooleanValue(                                                   ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    In file included from ../src/i2c.cc:102:../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./setaddr.cc:61:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:62:34: error: no matching function for call to ‘v8::Value::Int32Value()’   int addr = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:63:44: error: no matching function for call to ‘v8::Value::BooleanValue()’   bool forceAccess = info[2]->BooleanValue();                                            ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate: ‘bool v8::Value::BooleanValue(v8::Isolate*) const’   bool BooleanValue(Isolate* isolate) const;        ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate: ‘v8::Maybe<bool> v8::Value::BooleanValue(v8::Local<v8::Context>) const’                 V8_WARN_UNUSED_RESULT Maybe<bool> BooleanValue(                                                   ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note:   candidate expects 1 argument, 0 provided                 V8_WARN_UNUSED_RESULT Maybe<bool> BooleanValue(                                                   ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
    In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:51:35: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 byte = info[2]->Int32Value();                                   ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
    In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:63:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:64:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^
    In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:65:35: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 byte = info[2]->Int32Value();                                   ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
    In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
    In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:51:36: error: no matching function for call to ‘v8::Value::Int32Value()’   __u16 word = info[2]->Int32Value();                                    ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
    In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:64:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:65:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:66:36: error: no matching function for call to ‘v8::Value::Int32Value()’   __u16 word = info[2]->Int32Value();                                    ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
    In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:70:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
    In file included from ../src/i2c.cc:105:../src/./writeblock.cc:71:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:72:39: error: no matching function for call to ‘v8::Value::Uint32Value()’   __u32 length = info[2]->Uint32Value();                                       ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe<unsigned int> v8::Value::Uint32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<uint32_t> Uint32Value(                                         ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note:   candidate expects 1 argument, 0 provided
    In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:110:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
    In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:111:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:112:39: error: no matching function for call to ‘v8::Value::Uint32Value()’   __u32 length = info[2]->Uint32Value();                                       ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe<unsigned int> v8::Value::Uint32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<uint32_t> Uint32Value(                                         ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note:   candidate expects 1 argument, 0 provided
    In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:68:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
    In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:69:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:70:39: error: no matching function for call to ‘v8::Value::Uint32Value()’   __u32 length = info[2]->Uint32Value();                                       ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe<unsigned int> v8::Value::Uint32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<uint32_t> Uint32Value(                                         ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note:   candidate expects 1 argument, 0 provided
    In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:108:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
    In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:109:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:110:39: error: no matching function for call to ‘v8::Value::Uint32Value()’   __u32 length = info[2]->Uint32Value();                                       ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe<unsigned int> v8::Value::Uint32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<uint32_t> Uint32Value(                                         ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note:   candidate expects 1 argument, 0 provided
    In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
    In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:107:../src/./writequick.cc:48:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 bit = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
    In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:107:../src/./writequick.cc:61:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 bit = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
    make: *** [i2c.target.mk:111: Release/obj.target/i2c/src/i2c.o] Fehler 1
    gyp
     ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:315:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 5.4.51-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/i2c-busgyp ERR! node -v v12.18.3gyp ERR! node-gyp -v v5.1.0gyp
     ERR! not ok
    npm
     ERR! code ELIFECYCLEnpm ERR! errno 1
    npm
     ERR! i2c-bus@1.2.5 install: `node-gyp rebuild`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the i2c-bus@1.2.5 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm
     ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-08-30T11_57_50_262Z-debug.log
    ERROR: host.raspberrypi Cannot install iobroker.i2c@0.0.6: 1
    BG
    • HumidorH Humidor
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi3B+
      Arbeitsspeicher: 1GB
      Festplattenart: SD-Karte
      Betriebssystem: RaspiOS
      Node-Version: 12.18.3
      Nodejs-Version: 12.18.3
      NPM-Version: 6.14.6
      Installationsart: Skript
      Image genutzt: Ja
      Ort/Name der Imagedatei: iobroker HP
      Fehlermeldung bei der Installation des I2C Adapters:
      Fertig mit Fehler: host.raspberrypi Cannot install iobroker.i2c@0.0.6: 1
      $ ./iobroker add i2c  --host raspberrypi
      NPM version: 6.14.6
      npm install iobroker.i2c@0.0.6 --loglevel error --prefix "/opt/iobroker" (System call)
      In file included from ../node_modules/nan/nan_converters.h:67,                 from ../node_modules/nan/nan.h:202,                 from ../src/i2c.cc:2:../node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase<v8::Boolean>::return_t Nan::imp::ToFactory<v8::Boolean>::convert(v8::Local<v8::Value>)’:../node_modules/nan/nan_converters_43_inl.h:18:69: warning: ‘v8::MaybeLocal<v8::Boolean> v8::Value::ToBoolean(v8::Local<v8::Context>) const’ is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations]       val->To ## TYPE(v8::Isolate::GetCurrent()->GetCurrentContext())          \        ^../node_modules/nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’ X(Boolean) ^
      In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2664:59: note: declared here                 V8_WARN_UNUSED_RESULT MaybeLocal<Boolean> ToBoolean(                                                           ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../node_modules/nan/nan_converters.h:67,                 from ../node_modules/nan/nan.h:202,                 from ../src/i2c.cc:2:../node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase<bool>::return_t Nan::imp::ToFactory<bool>::convert(v8::Local<v8::Value>)’:../node_modules/nan/nan_converters_43_inl.h:37:57: warning: ‘v8::Maybe<bool> v8::Value::BooleanValue(v8::Local<v8::Context>) const’ is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations]   return val->NAME ## Value(isolate->GetCurrentContext());                     \                                                         ^../node_modules/nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’ X(bool, Boolean) ^
      In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: declared here                 V8_WARN_UNUSED_RESULT Maybe<bool> BooleanValue(                                                   ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../node_modules/nan/nan_new.h:189,                 from ../node_modules/nan/nan.h:203,                 from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::Function>::return_t Nan::imp::Factory<v8::Function>::New(Nan::FunctionCallback, v8::Local<v8::Value>)’:../node_modules/nan/nan_implementation_12_inl.h:105:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfo<v8::Value>&), v8::Local<v8::Object>&)’                           , obj));                                ^
      In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:4275:31: note: candidate: ‘static v8::MaybeLocal<v8::Function> v8::Function::New(v8::Local<v8::Context>, v8::FunctionCallback, v8::Local<v8::Value>, int, v8::ConstructorBehavior, v8::SideEffectType)’   static MaybeLocal<Function> New(                               ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:4275:31: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
      In file included from ../node_modules/nan/nan_new.h:189,                 from ../node_modules/nan/nan.h:203,                 from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase<v8::StringObject>::return_t Nan::imp::Factory<v8::StringObject>::New(v8::Local<v8::String>)’:../node_modules/nan/nan_implementation_12_inl.h:337:37: error: no matching function for call to ‘v8::StringObject::New(v8::Local<v8::String>&)’   return v8::StringObject::New(value).As<v8::StringObject>();                                     ^
      In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:5531:23: note: candidate: ‘static v8::Local<v8::Value> v8::StringObject::New(v8::Isolate*, v8::Local<v8::String>)’   static Local<Value> New(Isolate* isolate, Local<String> value);                       ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:5531:23: note:   candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189,                 from ../node_modules/nan/nan.h:203,                 from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h:337:58: error: expected primary-expression before ‘>’ token   return v8::StringObject::New(value).As<v8::StringObject>();                                                          ^../node_modules/nan/nan_implementation_12_inl.h:337:60: error: expected primary-expression before ‘)’ token   return v8::StringObject::New(value).As<v8::StringObject>();                                                            ^
      In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:../node_modules/nan/nan.h:840:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, func, argc, argv);                                                            ^
      In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:840:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, func, argc, argv);                                                            ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:../node_modules/nan/nan.h:855:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, symbol, argc, argv);                                                              ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:175:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:855:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, symbol, argc, argv);                                                              ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:175:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
      In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’:../node_modules/nan/nan.h:870:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, method, argc, argv);                                                              ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:168:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:870:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]         v8::Isolate::GetCurrent(), target, method, argc, argv);                                                              ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:168:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
      In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local<v8::Value>)’:../node_modules/nan/nan.h:916:53: error: no matching function for call to ‘v8::Value::ToString()’       v8::Local<v8::String> string = from->ToString();                                                     ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2668:44: note: candidate: ‘v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2668:44: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2684:31: note: candidate: ‘v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const’                 Local<String> ToString(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2684:31: note:   candidate expects 1 argument, 0 provided                 Local<String> ToString(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:926:74: error: no matching function for call to ‘v8::String::WriteUtf8(char*&, int, int, const int&)’         length_ = string->WriteUtf8(str_, static_cast<int>(len), 0, flags);        ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char*’ to ‘v8::Isolate*’
      In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’:../node_modules/nan/nan.h:1484:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]     ));     ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
      In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:1484:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]     ));     ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here                 NODE_EXTERN v8::Local<v8::Value> MakeCallback(                                                  ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
      In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local<v8::Value>&)’:../node_modules/nan/nan.h:1538:64: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     New(persistentHandle)->Set(New(key).ToLocalChecked(), value);        ^
      In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local<v8::String>&, const v8::Local<v8::Value>&)’:../node_modules/nan/nan.h:1544:42: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     New(persistentHandle)->Set(key, value);                                          ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local<v8::Value>&)’:../node_modules/nan/nan.h:1550:44: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     New(persistentHandle)->Set(index, value);                                            ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3508:22: note: declared here                 bool Set(uint32_t index, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const char*) const’:../node_modules/nan/nan.h:1556:61: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]         New(persistentHandle)->Get(New(key).ToLocalChecked()));                                                             ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const v8::Local<v8::String>&) const’:../node_modules/nan/nan.h:1562:55: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return scope.Escape(New(persistentHandle)->Get(key));                                                       ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(uint32_t) const’:../node_modules/nan/nan.h:1567:57: warning: ‘v8::Local<v8::Value> v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     return scope.Escape(New(persistentHandle)->Get(index));                                                         ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3557:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(uint32_t index));                                                   ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../node_modules/nan/nan.h:1875:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
      In file included from /usr/include/c++/8/cassert:44,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node_object_wrap.h:26,                 from ../node_modules/nan/nan.h:53,                 from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In destructor ‘virtual Nan::ObjectWrap::~ObjectWrap()’:../node_modules/nan/nan_object_wrap.h:24:25: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’     assert(persistent().IsNearDeath());                         ^~~~~~~~~~~
      In file included from ../node_modules/nan/nan.h:2365,                 from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:../node_modules/nan/nan_object_wrap.h:67:34: warning: ‘void v8::PersistentBase<T>::MarkIndependent() [with T = v8::Object]’ is deprecated: Weak objects are always considered independent. Use TracedGlobal when trying to use EmbedderHeapTracer. Use a strong handle when trying to keep an object alive. [-Wdeprecated-declarations]     persistent().MarkIndependent();                                  ^
      In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:570:22: note: declared here       V8_INLINE void MarkIndependent());                      ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from /usr/include/c++/8/cassert:44,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node_object_wrap.h:26,                 from ../node_modules/nan/nan.h:53,                 from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In static member function ‘static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’:../node_modules/nan/nan_object_wrap.h:124:26: error: ‘class Nan::Persistent<v8::Object>’ has no member named ‘IsNearDeath’     assert(wrap->handle_.IsNearDeath());                          ^~~~~~~~~~~
      In file included from ../src/i2c.cc:1:../src/i2c.cc: At global scope:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/i2c.cc:88:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(i2c, InitAll) ^~~~~~~~~~~
      In file included from ../src/i2c.cc:95:../src/./i2cfuncs.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE I2cFuncsAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./i2cfuncs.cc:48:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
      In file included from ../src/i2c.cc:95:../src/./i2cfuncs.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE I2cFuncsSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./i2cfuncs.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
      In file included from ../src/i2c.cc:96:../src/./readbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readbyte.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
      In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:96:../src/./readbyte.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
      In file included from ../src/i2c.cc:96:../src/./readbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readbyte.cc:62:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:96:../src/./readbyte.cc:63:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
      In file included from ../src/i2c.cc:97:../src/./readword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readword.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:97:../src/./readword.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:97:../src/./readword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readword.cc:62:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:97:../src/./readword.cc:63:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
      In file included from ../src/i2c.cc:98:../src/./readblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readblock.cc:66:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
      In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:98:../src/./readblock.cc:67:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
      In file included from ../src/i2c.cc:98:../src/./readblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readblock.cc:98:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:98:../src/./readblock.cc:99:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^
      In file included from ../src/i2c.cc:99:../src/./readi2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readi2cblock.cc:69:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
      In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:70:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:71:39: error: no matching function for call to ‘v8::Value::Uint32Value()’   __u32 length = info[2]->Uint32Value();                                       ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe<unsigned int> v8::Value::Uint32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<uint32_t> Uint32Value(                                         ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note:   candidate expects 1 argument, 0 provided
      In file included from ../src/i2c.cc:99:../src/./readi2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readi2cblock.cc:109:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:110:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:111:39: error: no matching function for call to ‘v8::Value::Uint32Value()’   __u32 length = info[2]->Uint32Value();                                       ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe<unsigned int> v8::Value::Uint32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<uint32_t> Uint32Value(                                         ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note:   candidate expects 1 argument, 0 provided
      In file included from ../src/i2c.cc:100:../src/./receivebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReceiveByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./receivebyte.cc:48:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
      In file included from ../src/i2c.cc:100:../src/./receivebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReceiveByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./receivebyte.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
      In file included from ../src/i2c.cc:101:../src/./sendbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SendByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./sendbyte.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
      In file included from ../src/i2c.cc:101:../src/./sendbyte.cc:48:35: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 byte = info[1]->Int32Value();                                   ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
      In file included from ../src/i2c.cc:101:../src/./sendbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SendByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./sendbyte.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:101:../src/./sendbyte.cc:61:35: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 byte = info[1]->Int32Value();                                   ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
      In file included from ../src/i2c.cc:102:../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./setaddr.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
      In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:48:34: error: no matching function for call to ‘v8::Value::Int32Value()’   int addr = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:49:44: error: no matching function for call to ‘v8::Value::BooleanValue()’   bool forceAccess = info[2]->BooleanValue();                                            ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate: ‘bool v8::Value::BooleanValue(v8::Isolate*) const’   bool BooleanValue(Isolate* isolate) const;        ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate: ‘v8::Maybe<bool> v8::Value::BooleanValue(v8::Local<v8::Context>) const’                 V8_WARN_UNUSED_RESULT Maybe<bool> BooleanValue(                                                   ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note:   candidate expects 1 argument, 0 provided                 V8_WARN_UNUSED_RESULT Maybe<bool> BooleanValue(                                                   ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../src/i2c.cc:102:../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./setaddr.cc:61:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:62:34: error: no matching function for call to ‘v8::Value::Int32Value()’   int addr = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:63:44: error: no matching function for call to ‘v8::Value::BooleanValue()’   bool forceAccess = info[2]->BooleanValue();                                            ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate: ‘bool v8::Value::BooleanValue(v8::Isolate*) const’   bool BooleanValue(Isolate* isolate) const;        ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate: ‘v8::Maybe<bool> v8::Value::BooleanValue(v8::Local<v8::Context>) const’                 V8_WARN_UNUSED_RESULT Maybe<bool> BooleanValue(                                                   ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note:   candidate expects 1 argument, 0 provided                 V8_WARN_UNUSED_RESULT Maybe<bool> BooleanValue(                                                   ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
      In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:51:35: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 byte = info[2]->Int32Value();                                   ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
      In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:63:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:64:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^
      In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:65:35: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 byte = info[2]->Int32Value();                                   ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
      In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
      In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:51:36: error: no matching function for call to ‘v8::Value::Int32Value()’   __u16 word = info[2]->Int32Value();                                    ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
      In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:64:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:65:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:66:36: error: no matching function for call to ‘v8::Value::Int32Value()’   __u16 word = info[2]->Int32Value();                                    ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
      In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:70:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
      In file included from ../src/i2c.cc:105:../src/./writeblock.cc:71:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:72:39: error: no matching function for call to ‘v8::Value::Uint32Value()’   __u32 length = info[2]->Uint32Value();                                       ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe<unsigned int> v8::Value::Uint32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<uint32_t> Uint32Value(                                         ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note:   candidate expects 1 argument, 0 provided
      In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:110:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
      In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:111:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:112:39: error: no matching function for call to ‘v8::Value::Uint32Value()’   __u32 length = info[2]->Uint32Value();                                       ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe<unsigned int> v8::Value::Uint32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<uint32_t> Uint32Value(                                         ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note:   candidate expects 1 argument, 0 provided
      In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:68:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
      In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:69:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:70:39: error: no matching function for call to ‘v8::Value::Uint32Value()’   __u32 length = info[2]->Uint32Value();                                       ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe<unsigned int> v8::Value::Uint32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<uint32_t> Uint32Value(                                         ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note:   candidate expects 1 argument, 0 provided
      In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:108:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
      In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:109:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 cmd = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:110:39: error: no matching function for call to ‘v8::Value::Uint32Value()’   __u32 length = info[2]->Uint32Value();                                       ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe<unsigned int> v8::Value::Uint32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<uint32_t> Uint32Value(                                         ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note:   candidate expects 1 argument, 0 provided
      In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^
      In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:107:../src/./writequick.cc:48:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 bit = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
      In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’   int fd = info[0]->Int32Value();                                ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:107:../src/./writequick.cc:61:34: error: no matching function for call to ‘v8::Value::Int32Value()’   __u8 bit = info[1]->Int32Value();                                  ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
      make: *** [i2c.target.mk:111: Release/obj.target/i2c/src/i2c.o] Fehler 1
      gyp
       ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:315:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
      gyp ERR! System Linux 5.4.51-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/i2c-busgyp ERR! node -v v12.18.3gyp ERR! node-gyp -v v5.1.0gyp
       ERR! not ok
      npm
       ERR! code ELIFECYCLEnpm ERR! errno 1
      npm
       ERR! i2c-bus@1.2.5 install: `node-gyp rebuild`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the i2c-bus@1.2.5 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm
       ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-08-30T11_57_50_262Z-debug.log
      ERROR: host.raspberrypi Cannot install iobroker.i2c@0.0.6: 1
      @Humidor was hast du da genau gemacht?
      Wo kommt das log her?
      HumidorH ? 2 Antworten Letzte Antwort
        HumidorH Online
        HumidorH Online
        Humidor
        schrieb am zuletzt editiert von Humidor
        @Homoran sagte in Fehler: host.raspberrypi Cannot install iobroker.i2:
        direkt von der Installation
        ein anderer Adapter rpi-monitor wurde ohne Fehler installiert
        BG
        • HumidorH Humidor
          @Humidor sagte in Fehler: host.raspberrypi Cannot install iobroker.i2:
          tatsächlich?
          Konsole - oder Admin?????
          i2c ist kein rpi-Monitor
          HumidorH 1 Antwort Letzte Antwort
            tatsächlich?
            HumidorH Online
            HumidorH Online
            Humidor
            tatsächlich?
            Bild Text
            hab ich auch nicht gesagt
            BG
            • HumidorH Humidor
              tatsächlich?
              Bild Text
              @Humidor du hast Fehler im log!
              Hast du die schon gelesen?
                HumidorH Online
                HumidorH Online
                Humidor
                host.raspberrypi	2020-08-30 14:20:21.853	info	iobroker exit 25
                host.raspberrypi	2020-08-30 14:20:20.813	error	iobroker host.raspberrypi Cannot install iobroker.i2c@0.0.6: 1
                host.raspberrypi	2020-08-30 14:20:20.770	info	iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-08-30T12_20_20_712Z-debug.log
                host.raspberrypi	2020-08-30 14:20:20.695	info	iobroker npm ERR! i2c-bus@1.2.5 install: `node-gyp rebuild`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the i2c-bus@1.2.5 install script.npm ERR! This is probably not a problem with npm. There i
                host.raspberrypi	2020-08-30 14:20:20.680	info	iobroker npm ERR! code ELIFECYCLEnpm ERR! errno 1
                host.raspberrypi	2020-08-30 14:20:18.274	info	iobroker gyp ERR! System Linux 5.4.51-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/i2c-busgyp
                host.raspberrypi	2020-08-30 14:20:18.267	info	iobroker ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildPr
                host.raspberrypi	2020-08-30 14:20:18.264	info	iobroker gyp
                host.raspberrypi	2020-08-30 14:20:18.260	info	iobroker ERR! build error
                host.raspberrypi	2020-08-30 14:20:18.257	info	iobroker gyp
                host.raspberrypi	2020-08-30 14:20:18.248	info	iobroker make: *** [i2c.target.mk:111: Release/obj.target/i2c/src/i2c.o] Fehler 1
                host.raspberrypi	2020-08-30 14:20:17.460	info	iobroker In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:60:32: error: no ma
                host.raspberrypi	2020-08-30 14:20:17.454	info	iobroker In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:47:32: error: no m
                host.raspberrypi	2020-08-30 14:20:17.439	info	iobroker In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:108:32: er
                host.raspberrypi	2020-08-30 14:20:17.426	info	iobroker In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:68:32: er
                host.raspberrypi	2020-08-30 14:20:17.407	info	iobroker In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:110:32: error: no m
                host.raspberrypi	2020-08-30 14:20:17.395	info	iobroker In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:70:32: error: no m
                host.raspberrypi	2020-08-30 14:20:17.377	info	iobroker In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:64:32: error: no match
                host.raspberrypi	2020-08-30 14:20:17.370	info	iobroker In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:49:32: error: no matc
                host.raspberrypi	2020-08-30 14:20:17.355	info	iobroker In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:63:32: error: no match
                host.raspberrypi	2020-08-30 14:20:17.348	info	iobroker In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:49:32: error: no matc
                host.raspberrypi	2020-08-30 14:20:17.336	info	iobroker In file included from ../src/i2c.cc:102:../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./setaddr.cc:61:32: error: no matching fu
                BG
                • HumidorH Humidor
                  @Humidor da fehlt einiges
                  die "frühesten" Meldungen fangen mit "in file...."
                  an, aber die Ursache was sich in diesen files befinden soll fehlt
                    HumidorH Online
                    HumidorH Online
                    Humidor
                    und was soll ich da jetzt tun??
                    BG
                    • HumidorH Humidor
                      oben auf log herunterladen klicken, den gesamten Zusammenhang kopieren und hier wieder in code-tags posten
                      Dann sind die Zeilen auch nicht am Ende abgeschnitten
                        HumidorH Online
                        HumidorH Online
                        Humidor
                        2020-08-30 14:19:30.900 - info: host.raspberrypi iobroker add i2c --host raspberrypi
                        2020-08-30 14:19:37.560 - info: host.raspberrypi iobroker NPM version: 6.14.6
                        2020-08-30 14:19:37.566 - info: host.raspberrypi iobroker npm install iobroker.i2c@0.0.6 --loglevel error --prefix "/opt/iobroker" (System call)
                        2020-08-30 14:20:16.594 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_converters.h:67, from ../node_modules/nan/nan.h:202, from ../src/i2c.cc:2:../node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase::return_t Nan::imp::ToFactory::convert(v8::Local)’:../node_modules/nan/nan_converters_43_inl.h:18:69: warning: ‘v8::MaybeLocal v8::Value::ToBoolean(v8::Local) const’ is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations] val->To ## TYPE(v8::Isolate::GetCurrent()->GetCurrentContext()) \ ^../node_modules/nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’ X(Boolean) ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2664:59: note: declared here V8_WARN_UNUSED_RESULT MaybeLocal ToBoolean( ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                        2020-08-30 14:20:16.621 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_converters.h:67, from ../node_modules/nan/nan.h:202, from ../src/i2c.cc:2:../node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase::return_t Nan::imp::ToFactory::convert(v8::Local)’:../node_modules/nan/nan_converters_43_inl.h:37:57: warning: ‘v8::Maybe v8::Value::BooleanValue(v8::Local) const’ is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations] return val->NAME ## Value(isolate->GetCurrentContext()); \ ^../node_modules/nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’ X(bool, Boolean) ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: declared here V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                        2020-08-30 14:20:16.675 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_new.h:189, from ../node_modules/nan/nan.h:203, from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase::return_t Nan::imp::Factory::New(Nan::FunctionCallback, v8::Local)’:../node_modules/nan/nan_implementation_12_inl.h:105:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfo&), v8::Local&)’ , obj)); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:4275:31: note: candidate: ‘static v8::MaybeLocal v8::Function::New(v8::Local, v8::FunctionCallback, v8::Local, int, v8::ConstructorBehavior, v8::SideEffectType)’ static MaybeLocal New( ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:4275:31: note: no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local’
                        2020-08-30 14:20:16.717 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_new.h:189, from ../node_modules/nan/nan.h:203, from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase::return_t Nan::imp::Factory::New(v8::Local)’:../node_modules/nan/nan_implementation_12_inl.h:337:37: error: no matching function for call to ‘v8::StringObject::New(v8::Local&)’ return v8::StringObject::New(value).As(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:5531:23: note: candidate: ‘static v8::Local v8::StringObject::New(v8::Isolate*, v8::Local)’ static Local New(Isolate* isolate, Local value); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:5531:23: note: candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189, from ../node_modules/nan/nan.h:203, from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h:337:58: error: expected primary-expression before ‘>’ token return v8::StringObject::New(value).As(); ^../node_modules/nan/nan_implementation_12_inl.h:337:60: error: expected primary-expression before ‘)’ token return v8::StringObject::New(value).As(); ^
                        2020-08-30 14:20:16.811 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local Nan::MakeCallback(v8::Local, v8::Local, int, v8::Local*)’:../node_modules/nan/nan.h:840:60: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, func, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:840:60: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, func, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~
                        2020-08-30 14:20:16.820 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local Nan::MakeCallback(v8::Local, v8::Local, int, v8::Local*)’:../node_modules/nan/nan.h:855:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, symbol, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:175:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:855:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, symbol, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:175:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local Nan::MakeCallback(v8::Local, const char*, int, v8::Local*)’:../node_modules/nan/nan.h:870:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, const char*, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, method, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:168:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:870:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, const char*, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, method, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:168:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~
                        2020-08-30 14:20:16.827 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local)’:../node_modules/nan/nan.h:916:53: error: no matching function for call to ‘v8::Value::ToString()’ v8::Local string = from->ToString(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2668:44: note: candidate: ‘v8::MaybeLocal v8::Value::ToString(v8::Local) const’ V8_WARN_UNUSED_RESULT MaybeLocal ToString( ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2668:44: note: candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2684:31: note: candidate: ‘v8::Local v8::Value::ToString(v8::Isolate*) const’ Local ToString(Isolate* isolate) const); ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2684:31: note: candidate expects 1 argument, 0 provided Local ToString(Isolate* isolate) const); ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                        2020-08-30 14:20:16.833 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:926:74: error: no matching function for call to ‘v8::String::WriteUtf8(char*&, int, int, const int&)’ length_ = string->WriteUtf8(str_, static_cast(len), 0, flags); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note: no known conversion for argument 1 from ‘char*’ to ‘v8::Isolate*’
                        2020-08-30 14:20:16.860 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::Callback::Call_(v8::Isolate*, v8::Local, int, v8::Local*) const’:../node_modules/nan/nan.h:1484:5: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] )); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:1484:5: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] )); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~
                        2020-08-30 14:20:16.880 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local&)’:../node_modules/nan/nan.h:1538:64: warning: ‘bool v8::Object::Set(v8::Local, v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Set(New(key).ToLocalChecked(), value); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3499:22: note: declared here bool Set(Local key, Local value)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                        2020-08-30 14:20:16.894 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local&, const v8::Local&)’:../node_modules/nan/nan.h:1544:42: warning: ‘bool v8::Object::Set(v8::Local, v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Set(key, value); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3499:22: note: declared here bool Set(Local key, Local value)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local&)’:../node_modules/nan/nan.h:1550:44: warning: ‘bool v8::Object::Set(uint32_t, v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Set(index, value); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3508:22: note: declared here bool Set(uint32_t index, Local value)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::AsyncWorker::GetFromPersistent(const char*) const’:../node_modules/nan/nan.h:1556:61: warning: ‘v8::Local v8::Object::Get(v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Get(New(key).ToLocalChecked())); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3553:51: note: declared here V8_DEPRECATED("Use maybe version", Local Get(Local key)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::AsyncWorker::GetFromPersistent(const v8::Local&) const’:../node_modules/nan/nan.h:1562:55: warning: ‘v8::Local v8::Object::Get(v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] return scope.Escape(New(persistentHandle)->Get(key)); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3553:51: note: declared here V8_DEPRECATED("Use maybe version", Local Get(Local key)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::AsyncWorker::GetFromPersistent(uint32_t) const’:../node_modules/nan/nan.h:1567:57: warning: ‘v8::Local v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations] return scope.Escape(New(persistentHandle)->Get(index)); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3557:51: note: declared here V8_DEPRECATED("Use maybe version", Local Get(uint32_t index)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                        2020-08-30 14:20:16.925 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../node_modules/nan/nan.h:1875:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast(AsyncExecuteComplete) ^
                        2020-08-30 14:20:17.017 - info: host.raspberrypi iobroker In file included from /usr/include/c++/8/cassert:44, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node_object_wrap.h:26, from ../node_modules/nan/nan.h:53, from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In destructor ‘virtual Nan::ObjectWrap::~ObjectWrap()’:../node_modules/nan/nan_object_wrap.h:24:25: error: ‘class Nan::Persistent’ has no member named ‘IsNearDeath’ assert(persistent().IsNearDeath()); ^~~~~~~~~~~
                        2020-08-30 14:20:17.027 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan.h:2365, from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:../node_modules/nan/nan_object_wrap.h:67:34: warning: ‘void v8::PersistentBase::MarkIndependent() [with T = v8::Object]’ is deprecated: Weak objects are always considered independent. Use TracedGlobal when trying to use EmbedderHeapTracer. Use a strong handle when trying to keep an object alive. [-Wdeprecated-declarations] persistent().MarkIndependent(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:570:22: note: declared here V8_INLINE void MarkIndependent()); ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                        2020-08-30 14:20:17.033 - info: host.raspberrypi iobroker In file included from /usr/include/c++/8/cassert:44, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node_object_wrap.h:26, from ../node_modules/nan/nan.h:53, from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In static member function ‘static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo&)’:../node_modules/nan/nan_object_wrap.h:124:26: error: ‘class Nan::Persistent’ has no member named ‘IsNearDeath’ assert(wrap->handle_.IsNearDeath()); ^~~~~~~~~~~
                        2020-08-30 14:20:17.118 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:1:../src/i2c.cc: At global scope:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/i2c.cc:88:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(i2c, InitAll) ^~~~~~~~~~~
                        2020-08-30 14:20:17.143 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:95:../src/./i2cfuncs.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE I2cFuncsAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./i2cfuncs.cc:48:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.149 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:95:../src/./i2cfuncs.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE I2cFuncsSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./i2cfuncs.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.166 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:96:../src/./readbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readbyte.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:96:../src/./readbyte.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.172 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:96:../src/./readbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readbyte.cc:62:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:96:../src/./readbyte.cc:63:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.187 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:97:../src/./readword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readword.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^
                        2020-08-30 14:20:17.193 - info: host.raspberrypi iobroker In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:97:../src/./readword.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.202 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:97:../src/./readword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readword.cc:62:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:97:../src/./readword.cc:63:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.217 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:98:../src/./readblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readblock.cc:66:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:98:../src/./readblock.cc:67:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.227 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:98:../src/./readblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readblock.cc:98:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:98:../src/./readblock.cc:99:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.248 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:99:../src/./readi2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readi2cblock.cc:69:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:70:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:71:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.262 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:99:../src/./readi2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readi2cblock.cc:109:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:110:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:111:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.283 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:100:../src/./receivebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReceiveByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./receivebyte.cc:48:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.289 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:100:../src/./receivebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReceiveByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./receivebyte.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.304 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:101:../src/./sendbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SendByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./sendbyte.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:101:../src/./sendbyte.cc:48:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.311 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:101:../src/./sendbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SendByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./sendbyte.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:101:../src/./sendbyte.cc:61:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.326 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:102:../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./setaddr.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:48:34: error: no matching function for call to ‘v8::Value::Int32Value()’ int addr = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:49:44: error: no matching function for call to ‘v8::Value::BooleanValue()’ bool forceAccess = info[2]->BooleanValue(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate: ‘bool v8::Value::BooleanValue(v8::Isolate*) const’ bool BooleanValue(Isolate* isolate) const; ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate: ‘v8::Maybe v8::Value::BooleanValue(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate expects 1 argument, 0 provided V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                        2020-08-30 14:20:17.336 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:102:../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./setaddr.cc:61:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:62:34: error: no matching function for call to ‘v8::Value::Int32Value()’ int addr = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:63:44: error: no matching function for call to ‘v8::Value::BooleanValue()’ bool forceAccess = info[2]->BooleanValue(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate: ‘bool v8::Value::BooleanValue(v8::Isolate*) const’ bool BooleanValue(Isolate* isolate) const; ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate: ‘v8::Maybe v8::Value::BooleanValue(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate expects 1 argument, 0 provided V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                        2020-08-30 14:20:17.348 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:51:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.355 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:63:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:64:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:65:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.370 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:51:36: error: no matching function for call to ‘v8::Value::Int32Value()’ __u16 word = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.377 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:64:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:65:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:66:36: error: no matching function for call to ‘v8::Value::Int32Value()’ __u16 word = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.395 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:70:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:71:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:72:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.407 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:110:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:111:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:112:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.426 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:68:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:69:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:70:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.439 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:108:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:109:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:110:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.454 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:107:../src/./writequick.cc:48:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 bit = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:17.460 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:107:../src/./writequick.cc:61:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 bit = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                        2020-08-30 14:20:18.248 - info: host.raspberrypi iobroker make: *** [i2c.target.mk:111: Release/obj.target/i2c/src/i2c.o] Fehler 1
                        2020-08-30 14:20:18.257 - info: host.raspberrypi iobroker gyp
                        2020-08-30 14:20:18.260 - info: host.raspberrypi iobroker ERR! build error
                        2020-08-30 14:20:18.264 - info: host.raspberrypi iobroker gyp
                        2020-08-30 14:20:18.267 - info: host.raspberrypi iobroker ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:315:20)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                        2020-08-30 14:20:18.274 - info: host.raspberrypi iobroker gyp ERR! System Linux 5.4.51-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/i2c-busgyp ERR! node -v v12.18.3gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                        2020-08-30 14:20:20.680 - info: host.raspberrypi iobroker npm ERR! code ELIFECYCLEnpm ERR! errno 1
                        2020-08-30 14:20:20.695 - info: host.raspberrypi iobroker npm ERR! i2c-bus@1.2.5 install: `node-gyp rebuild`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the i2c-bus@1.2.5 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                        2020-08-30 14:20:20.770 - info: host.raspberrypi iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-08-30T12_20_20_712Z-debug.log
                        2020-08-30 14:20:20.813 - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker.i2c@0.0.6: 1
                        2020-08-30 14:20:21.853 - info: host.raspberrypi iobroker exit 25
                        BG
                        • HumidorH Humidor
                          @Homoran sagte in Fehler: host.raspberrypi Cannot install iobroker.i2:
                          @Humidor sagte in Fehler: host.raspberrypi Cannot install iobroker.i2:
                          und was soll ich da jetzt tun??
                          oben auf log herunterladen klicken, den gesamten Zusammenhang kopieren und hier wieder in code-tags posten
                          Dann sind die Zeilen auch nicht am Ende abgeschnitten
                          2020-08-30 14:19:30.900 - info: host.raspberrypi iobroker add i2c --host raspberrypi
                          2020-08-30 14:19:37.560 - info: host.raspberrypi iobroker NPM version: 6.14.6
                          2020-08-30 14:19:37.566 - info: host.raspberrypi iobroker npm install iobroker.i2c@0.0.6 --loglevel error --prefix "/opt/iobroker" (System call)
                          2020-08-30 14:20:16.594 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_converters.h:67, from ../node_modules/nan/nan.h:202, from ../src/i2c.cc:2:../node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase::return_t Nan::imp::ToFactory::convert(v8::Local)’:../node_modules/nan/nan_converters_43_inl.h:18:69: warning: ‘v8::MaybeLocal v8::Value::ToBoolean(v8::Local) const’ is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations] val->To ## TYPE(v8::Isolate::GetCurrent()->GetCurrentContext()) \ ^../node_modules/nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’ X(Boolean) ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2664:59: note: declared here V8_WARN_UNUSED_RESULT MaybeLocal ToBoolean( ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                          2020-08-30 14:20:16.621 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_converters.h:67, from ../node_modules/nan/nan.h:202, from ../src/i2c.cc:2:../node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase::return_t Nan::imp::ToFactory::convert(v8::Local)’:../node_modules/nan/nan_converters_43_inl.h:37:57: warning: ‘v8::Maybe v8::Value::BooleanValue(v8::Local) const’ is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations] return val->NAME ## Value(isolate->GetCurrentContext()); \ ^../node_modules/nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’ X(bool, Boolean) ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: declared here V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                          2020-08-30 14:20:16.675 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_new.h:189, from ../node_modules/nan/nan.h:203, from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase::return_t Nan::imp::Factory::New(Nan::FunctionCallback, v8::Local)’:../node_modules/nan/nan_implementation_12_inl.h:105:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfo&), v8::Local&)’ , obj)); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:4275:31: note: candidate: ‘static v8::MaybeLocal v8::Function::New(v8::Local, v8::FunctionCallback, v8::Local, int, v8::ConstructorBehavior, v8::SideEffectType)’ static MaybeLocal New( ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:4275:31: note: no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local’
                          2020-08-30 14:20:16.717 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_new.h:189, from ../node_modules/nan/nan.h:203, from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase::return_t Nan::imp::Factory::New(v8::Local)’:../node_modules/nan/nan_implementation_12_inl.h:337:37: error: no matching function for call to ‘v8::StringObject::New(v8::Local&)’ return v8::StringObject::New(value).As(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:5531:23: note: candidate: ‘static v8::Local v8::StringObject::New(v8::Isolate*, v8::Local)’ static Local New(Isolate* isolate, Local value); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:5531:23: note: candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189, from ../node_modules/nan/nan.h:203, from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h:337:58: error: expected primary-expression before ‘>’ token return v8::StringObject::New(value).As(); ^../node_modules/nan/nan_implementation_12_inl.h:337:60: error: expected primary-expression before ‘)’ token return v8::StringObject::New(value).As(); ^
                          2020-08-30 14:20:16.811 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local Nan::MakeCallback(v8::Local, v8::Local, int, v8::Local*)’:../node_modules/nan/nan.h:840:60: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, func, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:840:60: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, func, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~
                          2020-08-30 14:20:16.820 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local Nan::MakeCallback(v8::Local, v8::Local, int, v8::Local*)’:../node_modules/nan/nan.h:855:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, symbol, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:175:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:855:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, symbol, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:175:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local Nan::MakeCallback(v8::Local, const char*, int, v8::Local*)’:../node_modules/nan/nan.h:870:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, const char*, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, method, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:168:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:870:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, const char*, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, method, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:168:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~
                          2020-08-30 14:20:16.827 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local)’:../node_modules/nan/nan.h:916:53: error: no matching function for call to ‘v8::Value::ToString()’ v8::Local string = from->ToString(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2668:44: note: candidate: ‘v8::MaybeLocal v8::Value::ToString(v8::Local) const’ V8_WARN_UNUSED_RESULT MaybeLocal ToString( ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2668:44: note: candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2684:31: note: candidate: ‘v8::Local v8::Value::ToString(v8::Isolate*) const’ Local ToString(Isolate* isolate) const); ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2684:31: note: candidate expects 1 argument, 0 provided Local ToString(Isolate* isolate) const); ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                          2020-08-30 14:20:16.833 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:926:74: error: no matching function for call to ‘v8::String::WriteUtf8(char*&, int, int, const int&)’ length_ = string->WriteUtf8(str_, static_cast(len), 0, flags); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note: no known conversion for argument 1 from ‘char*’ to ‘v8::Isolate*’
                          2020-08-30 14:20:16.860 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::Callback::Call_(v8::Isolate*, v8::Local, int, v8::Local*) const’:../node_modules/nan/nan.h:1484:5: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] )); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:1484:5: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] )); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~
                          2020-08-30 14:20:16.880 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local&)’:../node_modules/nan/nan.h:1538:64: warning: ‘bool v8::Object::Set(v8::Local, v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Set(New(key).ToLocalChecked(), value); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3499:22: note: declared here bool Set(Local key, Local value)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                          2020-08-30 14:20:16.894 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local&, const v8::Local&)’:../node_modules/nan/nan.h:1544:42: warning: ‘bool v8::Object::Set(v8::Local, v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Set(key, value); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3499:22: note: declared here bool Set(Local key, Local value)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local&)’:../node_modules/nan/nan.h:1550:44: warning: ‘bool v8::Object::Set(uint32_t, v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Set(index, value); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3508:22: note: declared here bool Set(uint32_t index, Local value)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::AsyncWorker::GetFromPersistent(const char*) const’:../node_modules/nan/nan.h:1556:61: warning: ‘v8::Local v8::Object::Get(v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Get(New(key).ToLocalChecked())); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3553:51: note: declared here V8_DEPRECATED("Use maybe version", Local Get(Local key)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::AsyncWorker::GetFromPersistent(const v8::Local&) const’:../node_modules/nan/nan.h:1562:55: warning: ‘v8::Local v8::Object::Get(v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] return scope.Escape(New(persistentHandle)->Get(key)); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3553:51: note: declared here V8_DEPRECATED("Use maybe version", Local Get(Local key)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::AsyncWorker::GetFromPersistent(uint32_t) const’:../node_modules/nan/nan.h:1567:57: warning: ‘v8::Local v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations] return scope.Escape(New(persistentHandle)->Get(index)); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3557:51: note: declared here V8_DEPRECATED("Use maybe version", Local Get(uint32_t index)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                          2020-08-30 14:20:16.925 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../node_modules/nan/nan.h:1875:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast(AsyncExecuteComplete) ^
                          2020-08-30 14:20:17.017 - info: host.raspberrypi iobroker In file included from /usr/include/c++/8/cassert:44, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node_object_wrap.h:26, from ../node_modules/nan/nan.h:53, from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In destructor ‘virtual Nan::ObjectWrap::~ObjectWrap()’:../node_modules/nan/nan_object_wrap.h:24:25: error: ‘class Nan::Persistent’ has no member named ‘IsNearDeath’ assert(persistent().IsNearDeath()); ^~~~~~~~~~~
                          2020-08-30 14:20:17.027 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan.h:2365, from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:../node_modules/nan/nan_object_wrap.h:67:34: warning: ‘void v8::PersistentBase::MarkIndependent() [with T = v8::Object]’ is deprecated: Weak objects are always considered independent. Use TracedGlobal when trying to use EmbedderHeapTracer. Use a strong handle when trying to keep an object alive. [-Wdeprecated-declarations] persistent().MarkIndependent(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:570:22: note: declared here V8_INLINE void MarkIndependent()); ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                          2020-08-30 14:20:17.033 - info: host.raspberrypi iobroker In file included from /usr/include/c++/8/cassert:44, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node_object_wrap.h:26, from ../node_modules/nan/nan.h:53, from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In static member function ‘static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo&)’:../node_modules/nan/nan_object_wrap.h:124:26: error: ‘class Nan::Persistent’ has no member named ‘IsNearDeath’ assert(wrap->handle_.IsNearDeath()); ^~~~~~~~~~~
                          2020-08-30 14:20:17.118 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:1:../src/i2c.cc: At global scope:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/i2c.cc:88:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(i2c, InitAll) ^~~~~~~~~~~
                          2020-08-30 14:20:17.143 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:95:../src/./i2cfuncs.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE I2cFuncsAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./i2cfuncs.cc:48:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.149 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:95:../src/./i2cfuncs.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE I2cFuncsSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./i2cfuncs.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.166 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:96:../src/./readbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readbyte.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:96:../src/./readbyte.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.172 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:96:../src/./readbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readbyte.cc:62:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:96:../src/./readbyte.cc:63:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.187 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:97:../src/./readword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readword.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^
                          2020-08-30 14:20:17.193 - info: host.raspberrypi iobroker In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:97:../src/./readword.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.202 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:97:../src/./readword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readword.cc:62:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:97:../src/./readword.cc:63:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.217 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:98:../src/./readblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readblock.cc:66:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:98:../src/./readblock.cc:67:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.227 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:98:../src/./readblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readblock.cc:98:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:98:../src/./readblock.cc:99:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.248 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:99:../src/./readi2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readi2cblock.cc:69:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:70:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:71:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.262 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:99:../src/./readi2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readi2cblock.cc:109:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:110:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:111:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.283 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:100:../src/./receivebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReceiveByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./receivebyte.cc:48:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.289 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:100:../src/./receivebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReceiveByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./receivebyte.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.304 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:101:../src/./sendbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SendByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./sendbyte.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:101:../src/./sendbyte.cc:48:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.311 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:101:../src/./sendbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SendByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./sendbyte.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:101:../src/./sendbyte.cc:61:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.326 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:102:../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./setaddr.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:48:34: error: no matching function for call to ‘v8::Value::Int32Value()’ int addr = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:49:44: error: no matching function for call to ‘v8::Value::BooleanValue()’ bool forceAccess = info[2]->BooleanValue(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate: ‘bool v8::Value::BooleanValue(v8::Isolate*) const’ bool BooleanValue(Isolate* isolate) const; ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate: ‘v8::Maybe v8::Value::BooleanValue(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate expects 1 argument, 0 provided V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                          2020-08-30 14:20:17.336 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:102:../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./setaddr.cc:61:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:62:34: error: no matching function for call to ‘v8::Value::Int32Value()’ int addr = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:63:44: error: no matching function for call to ‘v8::Value::BooleanValue()’ bool forceAccess = info[2]->BooleanValue(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate: ‘bool v8::Value::BooleanValue(v8::Isolate*) const’ bool BooleanValue(Isolate* isolate) const; ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate: ‘v8::Maybe v8::Value::BooleanValue(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate expects 1 argument, 0 provided V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                          2020-08-30 14:20:17.348 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:51:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.355 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:63:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:64:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:65:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.370 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:51:36: error: no matching function for call to ‘v8::Value::Int32Value()’ __u16 word = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.377 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:64:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:65:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:66:36: error: no matching function for call to ‘v8::Value::Int32Value()’ __u16 word = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.395 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:70:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:71:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:72:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.407 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:110:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:111:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:112:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.426 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:68:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:69:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:70:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.439 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:108:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:109:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:110:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.454 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:107:../src/./writequick.cc:48:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 bit = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:17.460 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:107:../src/./writequick.cc:61:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 bit = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                          2020-08-30 14:20:18.248 - info: host.raspberrypi iobroker make: *** [i2c.target.mk:111: Release/obj.target/i2c/src/i2c.o] Fehler 1
                          2020-08-30 14:20:18.257 - info: host.raspberrypi iobroker gyp
                          2020-08-30 14:20:18.260 - info: host.raspberrypi iobroker ERR! build error
                          2020-08-30 14:20:18.264 - info: host.raspberrypi iobroker gyp
                          2020-08-30 14:20:18.267 - info: host.raspberrypi iobroker ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:315:20)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                          2020-08-30 14:20:18.274 - info: host.raspberrypi iobroker gyp ERR! System Linux 5.4.51-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/i2c-busgyp ERR! node -v v12.18.3gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                          2020-08-30 14:20:20.680 - info: host.raspberrypi iobroker npm ERR! code ELIFECYCLEnpm ERR! errno 1
                          2020-08-30 14:20:20.695 - info: host.raspberrypi iobroker npm ERR! i2c-bus@1.2.5 install: `node-gyp rebuild`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the i2c-bus@1.2.5 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                          2020-08-30 14:20:20.770 - info: host.raspberrypi iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-08-30T12_20_20_712Z-debug.log
                          2020-08-30 14:20:20.813 - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker.i2c@0.0.6: 1
                          2020-08-30 14:20:21.853 - info: host.raspberrypi iobroker exit 25
                          @Humidor Da dürften ein paar dev-files fehlen.
                          sudo apt install build-essential libi2c-dev
                          mal probieren.
                          • HumidorH Humidor
                            @Homoran sagte in Fehler: host.raspberrypi Cannot install iobroker.i2:
                            @Humidor sagte in Fehler: host.raspberrypi Cannot install iobroker.i2:
                            und was soll ich da jetzt tun??
                            oben auf log herunterladen klicken, den gesamten Zusammenhang kopieren und hier wieder in code-tags posten
                            Dann sind die Zeilen auch nicht am Ende abgeschnitten
                            2020-08-30 14:19:30.900 - info: host.raspberrypi iobroker add i2c --host raspberrypi
                            2020-08-30 14:19:37.560 - info: host.raspberrypi iobroker NPM version: 6.14.6
                            2020-08-30 14:19:37.566 - info: host.raspberrypi iobroker npm install iobroker.i2c@0.0.6 --loglevel error --prefix "/opt/iobroker" (System call)
                            2020-08-30 14:20:16.594 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_converters.h:67, from ../node_modules/nan/nan.h:202, from ../src/i2c.cc:2:../node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase::return_t Nan::imp::ToFactory::convert(v8::Local)’:../node_modules/nan/nan_converters_43_inl.h:18:69: warning: ‘v8::MaybeLocal v8::Value::ToBoolean(v8::Local) const’ is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations] val->To ## TYPE(v8::Isolate::GetCurrent()->GetCurrentContext()) \ ^../node_modules/nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’ X(Boolean) ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2664:59: note: declared here V8_WARN_UNUSED_RESULT MaybeLocal ToBoolean( ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                            2020-08-30 14:20:16.621 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_converters.h:67, from ../node_modules/nan/nan.h:202, from ../src/i2c.cc:2:../node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase::return_t Nan::imp::ToFactory::convert(v8::Local)’:../node_modules/nan/nan_converters_43_inl.h:37:57: warning: ‘v8::Maybe v8::Value::BooleanValue(v8::Local) const’ is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations] return val->NAME ## Value(isolate->GetCurrentContext()); \ ^../node_modules/nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’ X(bool, Boolean) ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: declared here V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                            2020-08-30 14:20:16.675 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_new.h:189, from ../node_modules/nan/nan.h:203, from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase::return_t Nan::imp::Factory::New(Nan::FunctionCallback, v8::Local)’:../node_modules/nan/nan_implementation_12_inl.h:105:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfo&), v8::Local&)’ , obj)); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:4275:31: note: candidate: ‘static v8::MaybeLocal v8::Function::New(v8::Local, v8::FunctionCallback, v8::Local, int, v8::ConstructorBehavior, v8::SideEffectType)’ static MaybeLocal New( ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:4275:31: note: no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local’
                            2020-08-30 14:20:16.717 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_new.h:189, from ../node_modules/nan/nan.h:203, from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase::return_t Nan::imp::Factory::New(v8::Local)’:../node_modules/nan/nan_implementation_12_inl.h:337:37: error: no matching function for call to ‘v8::StringObject::New(v8::Local&)’ return v8::StringObject::New(value).As(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:5531:23: note: candidate: ‘static v8::Local v8::StringObject::New(v8::Isolate*, v8::Local)’ static Local New(Isolate* isolate, Local value); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:5531:23: note: candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189, from ../node_modules/nan/nan.h:203, from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h:337:58: error: expected primary-expression before ‘>’ token return v8::StringObject::New(value).As(); ^../node_modules/nan/nan_implementation_12_inl.h:337:60: error: expected primary-expression before ‘)’ token return v8::StringObject::New(value).As(); ^
                            2020-08-30 14:20:16.811 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local Nan::MakeCallback(v8::Local, v8::Local, int, v8::Local*)’:../node_modules/nan/nan.h:840:60: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, func, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:840:60: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, func, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~
                            2020-08-30 14:20:16.820 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local Nan::MakeCallback(v8::Local, v8::Local, int, v8::Local*)’:../node_modules/nan/nan.h:855:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, symbol, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:175:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:855:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, symbol, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:175:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local Nan::MakeCallback(v8::Local, const char*, int, v8::Local*)’:../node_modules/nan/nan.h:870:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, const char*, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, method, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:168:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:870:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, const char*, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, method, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:168:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~
                            2020-08-30 14:20:16.827 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local)’:../node_modules/nan/nan.h:916:53: error: no matching function for call to ‘v8::Value::ToString()’ v8::Local string = from->ToString(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2668:44: note: candidate: ‘v8::MaybeLocal v8::Value::ToString(v8::Local) const’ V8_WARN_UNUSED_RESULT MaybeLocal ToString( ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2668:44: note: candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2684:31: note: candidate: ‘v8::Local v8::Value::ToString(v8::Isolate*) const’ Local ToString(Isolate* isolate) const); ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2684:31: note: candidate expects 1 argument, 0 provided Local ToString(Isolate* isolate) const); ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                            2020-08-30 14:20:16.833 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:926:74: error: no matching function for call to ‘v8::String::WriteUtf8(char*&, int, int, const int&)’ length_ = string->WriteUtf8(str_, static_cast(len), 0, flags); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note: no known conversion for argument 1 from ‘char*’ to ‘v8::Isolate*’
                            2020-08-30 14:20:16.860 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::Callback::Call_(v8::Isolate*, v8::Local, int, v8::Local*) const’:../node_modules/nan/nan.h:1484:5: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] )); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:1484:5: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] )); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~
                            2020-08-30 14:20:16.880 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local&)’:../node_modules/nan/nan.h:1538:64: warning: ‘bool v8::Object::Set(v8::Local, v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Set(New(key).ToLocalChecked(), value); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3499:22: note: declared here bool Set(Local key, Local value)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                            2020-08-30 14:20:16.894 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local&, const v8::Local&)’:../node_modules/nan/nan.h:1544:42: warning: ‘bool v8::Object::Set(v8::Local, v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Set(key, value); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3499:22: note: declared here bool Set(Local key, Local value)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local&)’:../node_modules/nan/nan.h:1550:44: warning: ‘bool v8::Object::Set(uint32_t, v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Set(index, value); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3508:22: note: declared here bool Set(uint32_t index, Local value)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::AsyncWorker::GetFromPersistent(const char*) const’:../node_modules/nan/nan.h:1556:61: warning: ‘v8::Local v8::Object::Get(v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Get(New(key).ToLocalChecked())); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3553:51: note: declared here V8_DEPRECATED("Use maybe version", Local Get(Local key)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::AsyncWorker::GetFromPersistent(const v8::Local&) const’:../node_modules/nan/nan.h:1562:55: warning: ‘v8::Local v8::Object::Get(v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] return scope.Escape(New(persistentHandle)->Get(key)); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3553:51: note: declared here V8_DEPRECATED("Use maybe version", Local Get(Local key)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::AsyncWorker::GetFromPersistent(uint32_t) const’:../node_modules/nan/nan.h:1567:57: warning: ‘v8::Local v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations] return scope.Escape(New(persistentHandle)->Get(index)); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3557:51: note: declared here V8_DEPRECATED("Use maybe version", Local Get(uint32_t index)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                            2020-08-30 14:20:16.925 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../node_modules/nan/nan.h:1875:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast(AsyncExecuteComplete) ^
                            2020-08-30 14:20:17.017 - info: host.raspberrypi iobroker In file included from /usr/include/c++/8/cassert:44, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node_object_wrap.h:26, from ../node_modules/nan/nan.h:53, from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In destructor ‘virtual Nan::ObjectWrap::~ObjectWrap()’:../node_modules/nan/nan_object_wrap.h:24:25: error: ‘class Nan::Persistent’ has no member named ‘IsNearDeath’ assert(persistent().IsNearDeath()); ^~~~~~~~~~~
                            2020-08-30 14:20:17.027 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan.h:2365, from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:../node_modules/nan/nan_object_wrap.h:67:34: warning: ‘void v8::PersistentBase::MarkIndependent() [with T = v8::Object]’ is deprecated: Weak objects are always considered independent. Use TracedGlobal when trying to use EmbedderHeapTracer. Use a strong handle when trying to keep an object alive. [-Wdeprecated-declarations] persistent().MarkIndependent(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:570:22: note: declared here V8_INLINE void MarkIndependent()); ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                            2020-08-30 14:20:17.033 - info: host.raspberrypi iobroker In file included from /usr/include/c++/8/cassert:44, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node_object_wrap.h:26, from ../node_modules/nan/nan.h:53, from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In static member function ‘static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo&)’:../node_modules/nan/nan_object_wrap.h:124:26: error: ‘class Nan::Persistent’ has no member named ‘IsNearDeath’ assert(wrap->handle_.IsNearDeath()); ^~~~~~~~~~~
                            2020-08-30 14:20:17.118 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:1:../src/i2c.cc: At global scope:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/i2c.cc:88:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(i2c, InitAll) ^~~~~~~~~~~
                            2020-08-30 14:20:17.143 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:95:../src/./i2cfuncs.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE I2cFuncsAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./i2cfuncs.cc:48:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.149 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:95:../src/./i2cfuncs.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE I2cFuncsSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./i2cfuncs.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.166 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:96:../src/./readbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readbyte.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:96:../src/./readbyte.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.172 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:96:../src/./readbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readbyte.cc:62:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:96:../src/./readbyte.cc:63:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.187 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:97:../src/./readword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readword.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^
                            2020-08-30 14:20:17.193 - info: host.raspberrypi iobroker In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:97:../src/./readword.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.202 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:97:../src/./readword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readword.cc:62:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:97:../src/./readword.cc:63:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.217 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:98:../src/./readblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readblock.cc:66:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:98:../src/./readblock.cc:67:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.227 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:98:../src/./readblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readblock.cc:98:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:98:../src/./readblock.cc:99:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.248 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:99:../src/./readi2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readi2cblock.cc:69:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:70:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:71:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.262 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:99:../src/./readi2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readi2cblock.cc:109:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:110:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:111:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.283 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:100:../src/./receivebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReceiveByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./receivebyte.cc:48:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.289 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:100:../src/./receivebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReceiveByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./receivebyte.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.304 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:101:../src/./sendbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SendByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./sendbyte.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:101:../src/./sendbyte.cc:48:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.311 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:101:../src/./sendbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SendByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./sendbyte.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:101:../src/./sendbyte.cc:61:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.326 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:102:../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./setaddr.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:48:34: error: no matching function for call to ‘v8::Value::Int32Value()’ int addr = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:49:44: error: no matching function for call to ‘v8::Value::BooleanValue()’ bool forceAccess = info[2]->BooleanValue(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate: ‘bool v8::Value::BooleanValue(v8::Isolate*) const’ bool BooleanValue(Isolate* isolate) const; ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate: ‘v8::Maybe v8::Value::BooleanValue(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate expects 1 argument, 0 provided V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                            2020-08-30 14:20:17.336 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:102:../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./setaddr.cc:61:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:62:34: error: no matching function for call to ‘v8::Value::Int32Value()’ int addr = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:63:44: error: no matching function for call to ‘v8::Value::BooleanValue()’ bool forceAccess = info[2]->BooleanValue(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate: ‘bool v8::Value::BooleanValue(v8::Isolate*) const’ bool BooleanValue(Isolate* isolate) const; ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate: ‘v8::Maybe v8::Value::BooleanValue(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate expects 1 argument, 0 provided V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
                            2020-08-30 14:20:17.348 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:51:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.355 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:63:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:64:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:65:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.370 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:51:36: error: no matching function for call to ‘v8::Value::Int32Value()’ __u16 word = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.377 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:64:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:65:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:66:36: error: no matching function for call to ‘v8::Value::Int32Value()’ __u16 word = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.395 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:70:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:71:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:72:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.407 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:110:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:111:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:112:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.426 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:68:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:69:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:70:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.439 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:108:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:109:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:110:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.454 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:107:../src/./writequick.cc:48:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 bit = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:17.460 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:107:../src/./writequick.cc:61:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 bit = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
                            2020-08-30 14:20:18.248 - info: host.raspberrypi iobroker make: *** [i2c.target.mk:111: Release/obj.target/i2c/src/i2c.o] Fehler 1
                            2020-08-30 14:20:18.257 - info: host.raspberrypi iobroker gyp
                            2020-08-30 14:20:18.260 - info: host.raspberrypi iobroker ERR! build error
                            2020-08-30 14:20:18.264 - info: host.raspberrypi iobroker gyp
                            2020-08-30 14:20:18.267 - info: host.raspberrypi iobroker ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:315:20)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                            2020-08-30 14:20:18.274 - info: host.raspberrypi iobroker gyp ERR! System Linux 5.4.51-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/i2c-busgyp ERR! node -v v12.18.3gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                            2020-08-30 14:20:20.680 - info: host.raspberrypi iobroker npm ERR! code ELIFECYCLEnpm ERR! errno 1
                            2020-08-30 14:20:20.695 - info: host.raspberrypi iobroker npm ERR! i2c-bus@1.2.5 install: `node-gyp rebuild`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the i2c-bus@1.2.5 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                            2020-08-30 14:20:20.770 - info: host.raspberrypi iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-08-30T12_20_20_712Z-debug.log
                            2020-08-30 14:20:20.813 - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker.i2c@0.0.6: 1
                            2020-08-30 14:20:21.853 - info: host.raspberrypi iobroker exit 25
                            @Humidor Aber das hier hattest du gelesen, verstanden und befolgt?
                            IMPORTANT UPDATE
                            Development of this adapter will restart in August 2020. Stay tuned!
                            I will start by resolving the most pressing issues followed by a new major release that brings the adapter up to the latest development standards.
                            I2C Logo
                            ioBroker adapter for I2C
                            Number of Installations Number of Installations NPM version Downloads Travis GitHub issues
                            Communicates with devices connected to the local system using the I2C bus.
                            This adapter should work on Linux boards like the Raspberry Pi, C.H.I.P., BeagleBone or Intel Edison.
                            Install
                            Before installing, please read the installation guide of the i2c-bus module.
                            Especially make sure, that you have properly configured and enabled I2C on your system (if needed):
                            Configuring I2C on the Raspberry Pi
                            Configuring I2C on the Intel Edison Arduino Base Board
                            After you have enabled and configured I2C, you can install this adapter via ioBroker Admin:
                            Start the adapter (it must run for the discovery to work)
                            Open instance config dialog
                            Press the "Search Devices" button to discover all connected I2C devices - this will take some time, be patient!
                            Configure all found devices in their respective tabs.
                            Save the configuration (this will restart the adapter)
                            HumidorH 1 Antwort Letzte Antwort
                              IMPORTANT UPDATE
                              I2C Logo
                              Install
                              HumidorH Online
                              HumidorH Online
                              Humidor
                              schrieb am zuletzt editiert von Humidor
                              @Homoran sagte in Fehler: host.raspberrypi Cannot install iobroker.i2:
                              am Pi ist I2c enabled und mehrfach ein reboot wurde gemacht
                              BG
                              • HumidorH Humidor
                                @Humidor
                                sudo apt install build-essential libi2c-dev
                                probiert?
                                  @Humidor
                                  probiert?
                                  HumidorH Online
                                  HumidorH Online
                                  Humidor
                                  @Thomas-Braun sagte in Fehler: host.raspberrypi Cannot install iobroker.i2:
                                  @Humidor
                                  probiert?
                                  nein, wo hast du das gefunden,
                                  funktioniert aber auch nicht.
                                  BG
                                  • HumidorH Humidor
                                    @Humidor
                                    probiert?
                                    @Humidor sagte in Fehler: host.raspberrypi Cannot install iobroker.i2:
                                    was?
                                    die Installation des Paketes, oder der anschließende Versuch den Adapter zu installieren.
                                    Bitte immer die vollständige Konsolenein- und Ausgabe posten
                                      was?
                                      HumidorH Online
                                      HumidorH Online
                                      Humidor
                                      was?
                                      sry, die Installation vom Adapter, immer die selbe Fehlermeldung
                                      build-essential ist schon die neueste Version (12.6).
                                      Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                                        libbrotli1 libc-ares2 libuv1 nodejs-doc rpi-eeprom-images
                                      Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                                      Die folgenden zusätzlichen Pakete werden installiert:
                                        i2c-tools libi2c0 read-edid
                                      Vorgeschlagene Pakete:
                                        python-smbus
                                      Die folgenden NEUEN Pakete werden installiert:
                                        i2c-tools libi2c-dev libi2c0 read-edid
                                      0 aktualisiert, 4 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                      Es müssen 108 kB an Archiven heruntergeladen werden.
                                      Nach dieser Operation werden 351 kB Plattenplatz zusätzlich benutzt.
                                      Möchten Sie fortfahren? [J/n] j
                                      Holen:1 http://debian.anexia.at/raspbian/raspbian buster/main armhf libi2c0 armhf 4.1-1 [9.348 B]
                                      Holen:2 http://debian.anexia.at/raspbian/raspbian buster/main armhf i2c-tools armhf 4.1-1 [71,7 kB]
                                      Holen:3 http://debian.anexia.at/raspbian/raspbian buster/main armhf libi2c-dev armhf 4.1-1 [11,9 kB]
                                      Holen:4 http://debian.anexia.at/raspbian/raspbian buster/main armhf read-edid armhf 3.0.2-1 [15,4 kB]
                                      Es wurden 108 kB in 1 s geholt (97,7 kB/s).
                                      Vormals nicht ausgewähltes Paket libi2c0:armhf wird gewählt.
                                      (Lese Datenbank ... 46420 Dateien und Verzeichnisse sind derzeit installiert.)
                                      Vorbereitung zum Entpacken von .../libi2c0_4.1-1_armhf.deb ...
                                      Entpacken von libi2c0:armhf (4.1-1) ...
                                      Vormals nicht ausgewähltes Paket i2c-tools wird gewählt.
                                      Vorbereitung zum Entpacken von .../i2c-tools_4.1-1_armhf.deb ...
                                      Entpacken von i2c-tools (4.1-1) ...
                                      Vormals nicht ausgewähltes Paket libi2c-dev wird gewählt.
                                      Vorbereitung zum Entpacken von .../libi2c-dev_4.1-1_armhf.deb ...
                                      Entpacken von libi2c-dev (4.1-1) ...
                                      Vormals nicht ausgewähltes Paket read-edid wird gewählt.
                                      Vorbereitung zum Entpacken von .../read-edid_3.0.2-1_armhf.deb ...
                                      Entpacken von read-edid (3.0.2-1) ...
                                      libi2c0:armhf (4.1-1) wird eingerichtet ...
                                      read-edid (3.0.2-1) wird eingerichtet ...
                                      libi2c-dev (4.1-1) wird eingerichtet ...
                                      i2c-tools (4.1-1) wird eingerichtet ...
                                      Trigger für man-db (2.8.5-2) werden verarbeitet ...
                                      Trigger für libc-bin (2.28-10+rpi1) werden verarbeitet ...
                                      pi@raspberrypi:~ $ sudo reboot
                                      BG
                                      • HumidorH Humidor
                                        was?
                                          python-smbus
                                        @Humidor Kann es sein, dass du mal den ganzen node-* Kram von Debian installiert hattest oder noch hast? Da scheint mir noch irgendwas doppelt installiert zu sein.
                                        sudo apt autoremove
                                        sudo apt remove node-*
                                        Denn nodejs-doc kommt aus dem Debian-Repo:
                                        pi@raspberrypi:/opt/iobroker $ apt policy nodejs-doc
                                        nodejs-doc:
                                          Installiert:           (keine)
                                          Installationskandidat: 10.21.0~dfsg-1~deb10u1+rpi1
                                          Versionstabelle:
                                             10.21.0~dfsg-1~deb10u1+rpi1 500
                                        Vermutlich ist von dort noch mehr installiert worden.
                                          sudo apt autoremove
                                          nodejs-doc:
                                            Versionstabelle:
                                          HumidorH Online
                                          HumidorH Online
                                          Humidor
                                          sudo apt autoremove
                                          nodejs-doc:
                                            Versionstabelle:
                                          sudo apt autoremove
                                          Die folgenden Pakete werden ENTFERNT:
                                          0 aktualisiert, 0 neu installiert, 5 zu entfernen und 0 nicht aktualisiert.
                                          Nach dieser Operation werden 8.739 kB Plattenplatz freigegeben.
                                          (Lese Datenbank ... 46469 Dateien und Verzeichnisse sind derzeit installiert.)
                                          Entfernen von libbrotli1:armhf (1.0.7-2) ...
                                          Entfernen von libc-ares2:armhf (1.14.0-1) ...
                                          Entfernen von libuv1:armhf (1.24.1-1) ...
                                          Entfernen von nodejs-doc (10.21.0~dfsg-1~deb10u1+rpi1) ...
                                          Entfernen von rpi-eeprom-images (7.10-1) ...
                                          pi@raspberrypi:~ $ sudo apt remove node-*
                                          E: Paket node-v12.18.3-linux-armv6l.tar.xz kann nicht gefunden werden.
                                          E: Mittels des Musters »node-v12.18.3-linux-armv6l.tar.xz« konnte kein Paket gefunden werden.
                                          E: Mittels regulärem Ausdruck »node-v12.18.3-linux-armv6l.tar.xz« konnte kein Paket gefunden werden.
                                          nodejs-doc:
                                            Versionstabelle:
                                          pi@raspberrypi:~ $
                                          damit wäre wieder alles raus?
                                          which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                          /usr/bin/nodejs
                                          v12.18.3
                                          /usr/bin/node
                                          v12.18.3
                                          /usr/bin/npm
                                          6.14.6
                                          nodejs:
                                            Installiert:           12.18.3-1nodesource1
                                            Installationskandidat: 12.18.3-1nodesource1
                                            Versionstabelle:
                                           *** 12.18.3-1nodesource1 500
                                                  500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                                          pi@raspberrypi:~ $
                                          BG
                                          82.7k
