  4. Fehler: host.raspberrypi Cannot install iobroker.i2
    6.5k
i2cadapter
81 Beiträge 5 Kommentatoren 6.3k Aufrufe 4 Beobachtet
  • HumidorH Humidor
    @Homoran sagte in Fehler: host.raspberrypi Cannot install iobroker.i2:
    @Humidor du hast Fehler im log!
    Hast du die schon gelesen?
    host.raspberrypi	2020-08-30 14:20:21.853	info	iobroker exit 25
    host.raspberrypi	2020-08-30 14:20:20.813	error	iobroker host.raspberrypi Cannot install iobroker.i2c@0.0.6: 1
    host.raspberrypi	2020-08-30 14:20:20.770	info	iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-08-30T12_20_20_712Z-debug.log
    host.raspberrypi	2020-08-30 14:20:20.695	info	iobroker npm ERR! i2c-bus@1.2.5 install: `node-gyp rebuild`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the i2c-bus@1.2.5 install script.npm ERR! This is probably not a problem with npm. There i
    host.raspberrypi	2020-08-30 14:20:20.680	info	iobroker npm ERR! code ELIFECYCLEnpm ERR! errno 1
    host.raspberrypi	2020-08-30 14:20:18.274	info	iobroker gyp ERR! System Linux 5.4.51-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/i2c-busgyp
    host.raspberrypi	2020-08-30 14:20:18.267	info	iobroker ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildPr
    host.raspberrypi	2020-08-30 14:20:18.264	info	iobroker gyp
    host.raspberrypi	2020-08-30 14:20:18.260	info	iobroker ERR! build error
    host.raspberrypi	2020-08-30 14:20:18.257	info	iobroker gyp
    host.raspberrypi	2020-08-30 14:20:18.248	info	iobroker make: *** [i2c.target.mk:111: Release/obj.target/i2c/src/i2c.o] Fehler 1
    host.raspberrypi	2020-08-30 14:20:17.460	info	iobroker In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:60:32: error: no ma
    host.raspberrypi	2020-08-30 14:20:17.454	info	iobroker In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:47:32: error: no m
    host.raspberrypi	2020-08-30 14:20:17.439	info	iobroker In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:108:32: er
    host.raspberrypi	2020-08-30 14:20:17.426	info	iobroker In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:68:32: er
    host.raspberrypi	2020-08-30 14:20:17.407	info	iobroker In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:110:32: error: no m
    host.raspberrypi	2020-08-30 14:20:17.395	info	iobroker In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:70:32: error: no m
    host.raspberrypi	2020-08-30 14:20:17.377	info	iobroker In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:64:32: error: no match
    host.raspberrypi	2020-08-30 14:20:17.370	info	iobroker In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:49:32: error: no matc
    host.raspberrypi	2020-08-30 14:20:17.355	info	iobroker In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:63:32: error: no match
    host.raspberrypi	2020-08-30 14:20:17.348	info	iobroker In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:49:32: error: no matc
    host.raspberrypi	2020-08-30 14:20:17.336	info	iobroker In file included from ../src/i2c.cc:102:../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./setaddr.cc:61:32: error: no matching fu
    @Humidor da fehlt einiges
    die "frühesten" Meldungen fangen mit "in file...."
    an, aber die Ursache was sich in diesen files befinden soll fehlt
    HumidorH 1 Antwort Letzte Antwort
      HumidorH Offline
      HumidorH Offline
      Humidor
      und was soll ich da jetzt tun??
      BG
      • HumidorH Humidor
        @Humidor sagte in Fehler: host.raspberrypi Cannot install iobroker.i2:
        oben auf log herunterladen klicken, den gesamten Zusammenhang kopieren und hier wieder in code-tags posten
        Dann sind die Zeilen auch nicht am Ende abgeschnitten
          HumidorH Offline
          HumidorH Offline
          Humidor
          2020-08-30 14:19:30.900 - info: host.raspberrypi iobroker add i2c --host raspberrypi
          2020-08-30 14:19:37.560 - info: host.raspberrypi iobroker NPM version: 6.14.6
          2020-08-30 14:19:37.566 - info: host.raspberrypi iobroker npm install iobroker.i2c@0.0.6 --loglevel error --prefix "/opt/iobroker" (System call)
          2020-08-30 14:20:16.594 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_converters.h:67, from ../node_modules/nan/nan.h:202, from ../src/i2c.cc:2:../node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase::return_t Nan::imp::ToFactory::convert(v8::Local)’:../node_modules/nan/nan_converters_43_inl.h:18:69: warning: ‘v8::MaybeLocal v8::Value::ToBoolean(v8::Local) const’ is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations] val->To ## TYPE(v8::Isolate::GetCurrent()->GetCurrentContext()) \ ^../node_modules/nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’ X(Boolean) ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2664:59: note: declared here V8_WARN_UNUSED_RESULT MaybeLocal ToBoolean( ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
          2020-08-30 14:20:16.621 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_converters.h:67, from ../node_modules/nan/nan.h:202, from ../src/i2c.cc:2:../node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase::return_t Nan::imp::ToFactory::convert(v8::Local)’:../node_modules/nan/nan_converters_43_inl.h:37:57: warning: ‘v8::Maybe v8::Value::BooleanValue(v8::Local) const’ is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations] return val->NAME ## Value(isolate->GetCurrentContext()); \ ^../node_modules/nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’ X(bool, Boolean) ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: declared here V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
          2020-08-30 14:20:16.675 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_new.h:189, from ../node_modules/nan/nan.h:203, from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase::return_t Nan::imp::Factory::New(Nan::FunctionCallback, v8::Local)’:../node_modules/nan/nan_implementation_12_inl.h:105:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfo&), v8::Local&)’ , obj)); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:4275:31: note: candidate: ‘static v8::MaybeLocal v8::Function::New(v8::Local, v8::FunctionCallback, v8::Local, int, v8::ConstructorBehavior, v8::SideEffectType)’ static MaybeLocal New( ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:4275:31: note: no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local’
          2020-08-30 14:20:16.717 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_new.h:189, from ../node_modules/nan/nan.h:203, from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase::return_t Nan::imp::Factory::New(v8::Local)’:../node_modules/nan/nan_implementation_12_inl.h:337:37: error: no matching function for call to ‘v8::StringObject::New(v8::Local&)’ return v8::StringObject::New(value).As(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:5531:23: note: candidate: ‘static v8::Local v8::StringObject::New(v8::Isolate*, v8::Local)’ static Local New(Isolate* isolate, Local value); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:5531:23: note: candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189, from ../node_modules/nan/nan.h:203, from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h:337:58: error: expected primary-expression before ‘>’ token return v8::StringObject::New(value).As(); ^../node_modules/nan/nan_implementation_12_inl.h:337:60: error: expected primary-expression before ‘)’ token return v8::StringObject::New(value).As(); ^
          2020-08-30 14:20:16.811 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local Nan::MakeCallback(v8::Local, v8::Local, int, v8::Local*)’:../node_modules/nan/nan.h:840:60: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, func, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:840:60: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, func, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~
          2020-08-30 14:20:16.820 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local Nan::MakeCallback(v8::Local, v8::Local, int, v8::Local*)’:../node_modules/nan/nan.h:855:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, symbol, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:175:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:855:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, symbol, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:175:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local Nan::MakeCallback(v8::Local, const char*, int, v8::Local*)’:../node_modules/nan/nan.h:870:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, const char*, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, method, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:168:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:870:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, const char*, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, method, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:168:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~
          2020-08-30 14:20:16.827 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local)’:../node_modules/nan/nan.h:916:53: error: no matching function for call to ‘v8::Value::ToString()’ v8::Local string = from->ToString(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2668:44: note: candidate: ‘v8::MaybeLocal v8::Value::ToString(v8::Local) const’ V8_WARN_UNUSED_RESULT MaybeLocal ToString( ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2668:44: note: candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2684:31: note: candidate: ‘v8::Local v8::Value::ToString(v8::Isolate*) const’ Local ToString(Isolate* isolate) const); ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2684:31: note: candidate expects 1 argument, 0 provided Local ToString(Isolate* isolate) const); ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
          2020-08-30 14:20:16.833 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:926:74: error: no matching function for call to ‘v8::String::WriteUtf8(char*&, int, int, const int&)’ length_ = string->WriteUtf8(str_, static_cast(len), 0, flags); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note: no known conversion for argument 1 from ‘char*’ to ‘v8::Isolate*’
          2020-08-30 14:20:16.860 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::Callback::Call_(v8::Isolate*, v8::Local, int, v8::Local*) const’:../node_modules/nan/nan.h:1484:5: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] )); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:1484:5: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] )); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~
          2020-08-30 14:20:16.880 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local&)’:../node_modules/nan/nan.h:1538:64: warning: ‘bool v8::Object::Set(v8::Local, v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Set(New(key).ToLocalChecked(), value); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3499:22: note: declared here bool Set(Local key, Local value)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
          2020-08-30 14:20:16.894 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local&, const v8::Local&)’:../node_modules/nan/nan.h:1544:42: warning: ‘bool v8::Object::Set(v8::Local, v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Set(key, value); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3499:22: note: declared here bool Set(Local key, Local value)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local&)’:../node_modules/nan/nan.h:1550:44: warning: ‘bool v8::Object::Set(uint32_t, v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Set(index, value); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3508:22: note: declared here bool Set(uint32_t index, Local value)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::AsyncWorker::GetFromPersistent(const char*) const’:../node_modules/nan/nan.h:1556:61: warning: ‘v8::Local v8::Object::Get(v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Get(New(key).ToLocalChecked())); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3553:51: note: declared here V8_DEPRECATED("Use maybe version", Local Get(Local key)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::AsyncWorker::GetFromPersistent(const v8::Local&) const’:../node_modules/nan/nan.h:1562:55: warning: ‘v8::Local v8::Object::Get(v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] return scope.Escape(New(persistentHandle)->Get(key)); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3553:51: note: declared here V8_DEPRECATED("Use maybe version", Local Get(Local key)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::AsyncWorker::GetFromPersistent(uint32_t) const’:../node_modules/nan/nan.h:1567:57: warning: ‘v8::Local v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations] return scope.Escape(New(persistentHandle)->Get(index)); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3557:51: note: declared here V8_DEPRECATED("Use maybe version", Local Get(uint32_t index)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
          2020-08-30 14:20:16.925 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../node_modules/nan/nan.h:1875:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast(AsyncExecuteComplete) ^
          2020-08-30 14:20:17.017 - info: host.raspberrypi iobroker In file included from /usr/include/c++/8/cassert:44, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node_object_wrap.h:26, from ../node_modules/nan/nan.h:53, from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In destructor ‘virtual Nan::ObjectWrap::~ObjectWrap()’:../node_modules/nan/nan_object_wrap.h:24:25: error: ‘class Nan::Persistent’ has no member named ‘IsNearDeath’ assert(persistent().IsNearDeath()); ^~~~~~~~~~~
          2020-08-30 14:20:17.027 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan.h:2365, from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:../node_modules/nan/nan_object_wrap.h:67:34: warning: ‘void v8::PersistentBase::MarkIndependent() [with T = v8::Object]’ is deprecated: Weak objects are always considered independent. Use TracedGlobal when trying to use EmbedderHeapTracer. Use a strong handle when trying to keep an object alive. [-Wdeprecated-declarations] persistent().MarkIndependent(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:570:22: note: declared here V8_INLINE void MarkIndependent()); ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
          2020-08-30 14:20:17.033 - info: host.raspberrypi iobroker In file included from /usr/include/c++/8/cassert:44, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node_object_wrap.h:26, from ../node_modules/nan/nan.h:53, from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In static member function ‘static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo&)’:../node_modules/nan/nan_object_wrap.h:124:26: error: ‘class Nan::Persistent’ has no member named ‘IsNearDeath’ assert(wrap->handle_.IsNearDeath()); ^~~~~~~~~~~
          2020-08-30 14:20:17.118 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:1:../src/i2c.cc: At global scope:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/i2c.cc:88:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(i2c, InitAll) ^~~~~~~~~~~
          2020-08-30 14:20:17.143 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:95:../src/./i2cfuncs.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE I2cFuncsAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./i2cfuncs.cc:48:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.149 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:95:../src/./i2cfuncs.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE I2cFuncsSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./i2cfuncs.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.166 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:96:../src/./readbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readbyte.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:96:../src/./readbyte.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.172 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:96:../src/./readbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readbyte.cc:62:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:96:../src/./readbyte.cc:63:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.187 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:97:../src/./readword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readword.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^
          2020-08-30 14:20:17.193 - info: host.raspberrypi iobroker In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:97:../src/./readword.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.202 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:97:../src/./readword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readword.cc:62:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:97:../src/./readword.cc:63:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.217 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:98:../src/./readblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readblock.cc:66:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:98:../src/./readblock.cc:67:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.227 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:98:../src/./readblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readblock.cc:98:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:98:../src/./readblock.cc:99:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.248 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:99:../src/./readi2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readi2cblock.cc:69:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:70:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:71:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.262 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:99:../src/./readi2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readi2cblock.cc:109:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:110:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:111:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.283 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:100:../src/./receivebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReceiveByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./receivebyte.cc:48:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.289 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:100:../src/./receivebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReceiveByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./receivebyte.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.304 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:101:../src/./sendbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SendByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./sendbyte.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:101:../src/./sendbyte.cc:48:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.311 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:101:../src/./sendbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SendByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./sendbyte.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:101:../src/./sendbyte.cc:61:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.326 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:102:../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./setaddr.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:48:34: error: no matching function for call to ‘v8::Value::Int32Value()’ int addr = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:49:44: error: no matching function for call to ‘v8::Value::BooleanValue()’ bool forceAccess = info[2]->BooleanValue(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate: ‘bool v8::Value::BooleanValue(v8::Isolate*) const’ bool BooleanValue(Isolate* isolate) const; ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate: ‘v8::Maybe v8::Value::BooleanValue(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate expects 1 argument, 0 provided V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
          2020-08-30 14:20:17.336 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:102:../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./setaddr.cc:61:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:62:34: error: no matching function for call to ‘v8::Value::Int32Value()’ int addr = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:63:44: error: no matching function for call to ‘v8::Value::BooleanValue()’ bool forceAccess = info[2]->BooleanValue(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate: ‘bool v8::Value::BooleanValue(v8::Isolate*) const’ bool BooleanValue(Isolate* isolate) const; ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate: ‘v8::Maybe v8::Value::BooleanValue(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate expects 1 argument, 0 provided V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
          2020-08-30 14:20:17.348 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:51:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.355 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:63:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:64:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:65:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.370 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:51:36: error: no matching function for call to ‘v8::Value::Int32Value()’ __u16 word = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.377 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:64:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:65:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:66:36: error: no matching function for call to ‘v8::Value::Int32Value()’ __u16 word = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.395 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:70:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:71:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:72:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.407 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:110:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:111:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:112:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.426 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:68:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:69:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:70:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.439 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:108:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:109:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:110:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.454 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:107:../src/./writequick.cc:48:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 bit = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:17.460 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:107:../src/./writequick.cc:61:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 bit = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
          2020-08-30 14:20:18.248 - info: host.raspberrypi iobroker make: *** [i2c.target.mk:111: Release/obj.target/i2c/src/i2c.o] Fehler 1
          2020-08-30 14:20:18.257 - info: host.raspberrypi iobroker gyp
          2020-08-30 14:20:18.260 - info: host.raspberrypi iobroker ERR! build error
          2020-08-30 14:20:18.264 - info: host.raspberrypi iobroker gyp
          2020-08-30 14:20:18.267 - info: host.raspberrypi iobroker ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:315:20)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
          2020-08-30 14:20:18.274 - info: host.raspberrypi iobroker gyp ERR! System Linux 5.4.51-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/i2c-busgyp ERR! node -v v12.18.3gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
          2020-08-30 14:20:20.680 - info: host.raspberrypi iobroker npm ERR! code ELIFECYCLEnpm ERR! errno 1
          2020-08-30 14:20:20.695 - info: host.raspberrypi iobroker npm ERR! i2c-bus@1.2.5 install: `node-gyp rebuild`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the i2c-bus@1.2.5 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          2020-08-30 14:20:20.770 - info: host.raspberrypi iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-08-30T12_20_20_712Z-debug.log
          2020-08-30 14:20:20.813 - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker.i2c@0.0.6: 1
          2020-08-30 14:20:21.853 - info: host.raspberrypi iobroker exit 25
          BG
          • HumidorH Humidor
            @Homoran sagte in Fehler: host.raspberrypi Cannot install iobroker.i2:
            @Humidor sagte in Fehler: host.raspberrypi Cannot install iobroker.i2:
            und was soll ich da jetzt tun??
            oben auf log herunterladen klicken, den gesamten Zusammenhang kopieren und hier wieder in code-tags posten
            Dann sind die Zeilen auch nicht am Ende abgeschnitten
            2020-08-30 14:19:30.900 - info: host.raspberrypi iobroker add i2c --host raspberrypi
            2020-08-30 14:19:37.560 - info: host.raspberrypi iobroker NPM version: 6.14.6
            2020-08-30 14:19:37.566 - info: host.raspberrypi iobroker npm install iobroker.i2c@0.0.6 --loglevel error --prefix "/opt/iobroker" (System call)
            2020-08-30 14:20:16.594 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_converters.h:67, from ../node_modules/nan/nan.h:202, from ../src/i2c.cc:2:../node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase::return_t Nan::imp::ToFactory::convert(v8::Local)’:../node_modules/nan/nan_converters_43_inl.h:18:69: warning: ‘v8::MaybeLocal v8::Value::ToBoolean(v8::Local) const’ is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations] val->To ## TYPE(v8::Isolate::GetCurrent()->GetCurrentContext()) \ ^../node_modules/nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’ X(Boolean) ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2664:59: note: declared here V8_WARN_UNUSED_RESULT MaybeLocal ToBoolean( ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
            2020-08-30 14:20:16.621 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_converters.h:67, from ../node_modules/nan/nan.h:202, from ../src/i2c.cc:2:../node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase::return_t Nan::imp::ToFactory::convert(v8::Local)’:../node_modules/nan/nan_converters_43_inl.h:37:57: warning: ‘v8::Maybe v8::Value::BooleanValue(v8::Local) const’ is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations] return val->NAME ## Value(isolate->GetCurrentContext()); \ ^../node_modules/nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’ X(bool, Boolean) ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: declared here V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
            2020-08-30 14:20:16.675 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_new.h:189, from ../node_modules/nan/nan.h:203, from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase::return_t Nan::imp::Factory::New(Nan::FunctionCallback, v8::Local)’:../node_modules/nan/nan_implementation_12_inl.h:105:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfo&), v8::Local&)’ , obj)); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:4275:31: note: candidate: ‘static v8::MaybeLocal v8::Function::New(v8::Local, v8::FunctionCallback, v8::Local, int, v8::ConstructorBehavior, v8::SideEffectType)’ static MaybeLocal New( ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:4275:31: note: no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local’
            2020-08-30 14:20:16.717 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_new.h:189, from ../node_modules/nan/nan.h:203, from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase::return_t Nan::imp::Factory::New(v8::Local)’:../node_modules/nan/nan_implementation_12_inl.h:337:37: error: no matching function for call to ‘v8::StringObject::New(v8::Local&)’ return v8::StringObject::New(value).As(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:5531:23: note: candidate: ‘static v8::Local v8::StringObject::New(v8::Isolate*, v8::Local)’ static Local New(Isolate* isolate, Local value); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:5531:23: note: candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189, from ../node_modules/nan/nan.h:203, from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h:337:58: error: expected primary-expression before ‘>’ token return v8::StringObject::New(value).As(); ^../node_modules/nan/nan_implementation_12_inl.h:337:60: error: expected primary-expression before ‘)’ token return v8::StringObject::New(value).As(); ^
            2020-08-30 14:20:16.811 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local Nan::MakeCallback(v8::Local, v8::Local, int, v8::Local*)’:../node_modules/nan/nan.h:840:60: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, func, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:840:60: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, func, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~
            2020-08-30 14:20:16.820 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local Nan::MakeCallback(v8::Local, v8::Local, int, v8::Local*)’:../node_modules/nan/nan.h:855:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, symbol, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:175:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:855:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, symbol, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:175:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local Nan::MakeCallback(v8::Local, const char*, int, v8::Local*)’:../node_modules/nan/nan.h:870:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, const char*, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, method, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:168:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:870:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, const char*, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, method, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:168:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~
            2020-08-30 14:20:16.827 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local)’:../node_modules/nan/nan.h:916:53: error: no matching function for call to ‘v8::Value::ToString()’ v8::Local string = from->ToString(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2668:44: note: candidate: ‘v8::MaybeLocal v8::Value::ToString(v8::Local) const’ V8_WARN_UNUSED_RESULT MaybeLocal ToString( ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2668:44: note: candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2684:31: note: candidate: ‘v8::Local v8::Value::ToString(v8::Isolate*) const’ Local ToString(Isolate* isolate) const); ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2684:31: note: candidate expects 1 argument, 0 provided Local ToString(Isolate* isolate) const); ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
            2020-08-30 14:20:16.833 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:926:74: error: no matching function for call to ‘v8::String::WriteUtf8(char*&, int, int, const int&)’ length_ = string->WriteUtf8(str_, static_cast(len), 0, flags); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note: no known conversion for argument 1 from ‘char*’ to ‘v8::Isolate*’
            2020-08-30 14:20:16.860 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::Callback::Call_(v8::Isolate*, v8::Local, int, v8::Local*) const’:../node_modules/nan/nan.h:1484:5: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] )); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:1484:5: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] )); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~
            2020-08-30 14:20:16.880 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local&)’:../node_modules/nan/nan.h:1538:64: warning: ‘bool v8::Object::Set(v8::Local, v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Set(New(key).ToLocalChecked(), value); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3499:22: note: declared here bool Set(Local key, Local value)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
            2020-08-30 14:20:16.894 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local&, const v8::Local&)’:../node_modules/nan/nan.h:1544:42: warning: ‘bool v8::Object::Set(v8::Local, v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Set(key, value); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3499:22: note: declared here bool Set(Local key, Local value)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local&)’:../node_modules/nan/nan.h:1550:44: warning: ‘bool v8::Object::Set(uint32_t, v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Set(index, value); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3508:22: note: declared here bool Set(uint32_t index, Local value)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::AsyncWorker::GetFromPersistent(const char*) const’:../node_modules/nan/nan.h:1556:61: warning: ‘v8::Local v8::Object::Get(v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Get(New(key).ToLocalChecked())); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3553:51: note: declared here V8_DEPRECATED("Use maybe version", Local Get(Local key)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::AsyncWorker::GetFromPersistent(const v8::Local&) const’:../node_modules/nan/nan.h:1562:55: warning: ‘v8::Local v8::Object::Get(v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] return scope.Escape(New(persistentHandle)->Get(key)); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3553:51: note: declared here V8_DEPRECATED("Use maybe version", Local Get(Local key)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::AsyncWorker::GetFromPersistent(uint32_t) const’:../node_modules/nan/nan.h:1567:57: warning: ‘v8::Local v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations] return scope.Escape(New(persistentHandle)->Get(index)); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3557:51: note: declared here V8_DEPRECATED("Use maybe version", Local Get(uint32_t index)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
            2020-08-30 14:20:16.925 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../node_modules/nan/nan.h:1875:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast(AsyncExecuteComplete) ^
            2020-08-30 14:20:17.017 - info: host.raspberrypi iobroker In file included from /usr/include/c++/8/cassert:44, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node_object_wrap.h:26, from ../node_modules/nan/nan.h:53, from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In destructor ‘virtual Nan::ObjectWrap::~ObjectWrap()’:../node_modules/nan/nan_object_wrap.h:24:25: error: ‘class Nan::Persistent’ has no member named ‘IsNearDeath’ assert(persistent().IsNearDeath()); ^~~~~~~~~~~
            2020-08-30 14:20:17.027 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan.h:2365, from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:../node_modules/nan/nan_object_wrap.h:67:34: warning: ‘void v8::PersistentBase::MarkIndependent() [with T = v8::Object]’ is deprecated: Weak objects are always considered independent. Use TracedGlobal when trying to use EmbedderHeapTracer. Use a strong handle when trying to keep an object alive. [-Wdeprecated-declarations] persistent().MarkIndependent(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:570:22: note: declared here V8_INLINE void MarkIndependent()); ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
            2020-08-30 14:20:17.033 - info: host.raspberrypi iobroker In file included from /usr/include/c++/8/cassert:44, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node_object_wrap.h:26, from ../node_modules/nan/nan.h:53, from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In static member function ‘static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo&)’:../node_modules/nan/nan_object_wrap.h:124:26: error: ‘class Nan::Persistent’ has no member named ‘IsNearDeath’ assert(wrap->handle_.IsNearDeath()); ^~~~~~~~~~~
            2020-08-30 14:20:17.118 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:1:../src/i2c.cc: At global scope:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/i2c.cc:88:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(i2c, InitAll) ^~~~~~~~~~~
            2020-08-30 14:20:17.143 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:95:../src/./i2cfuncs.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE I2cFuncsAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./i2cfuncs.cc:48:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.149 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:95:../src/./i2cfuncs.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE I2cFuncsSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./i2cfuncs.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.166 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:96:../src/./readbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readbyte.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:96:../src/./readbyte.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.172 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:96:../src/./readbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readbyte.cc:62:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:96:../src/./readbyte.cc:63:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.187 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:97:../src/./readword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readword.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^
            2020-08-30 14:20:17.193 - info: host.raspberrypi iobroker In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:97:../src/./readword.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.202 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:97:../src/./readword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readword.cc:62:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:97:../src/./readword.cc:63:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.217 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:98:../src/./readblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readblock.cc:66:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:98:../src/./readblock.cc:67:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.227 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:98:../src/./readblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readblock.cc:98:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:98:../src/./readblock.cc:99:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.248 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:99:../src/./readi2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readi2cblock.cc:69:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:70:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:71:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.262 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:99:../src/./readi2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readi2cblock.cc:109:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:110:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:111:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.283 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:100:../src/./receivebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReceiveByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./receivebyte.cc:48:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.289 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:100:../src/./receivebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReceiveByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./receivebyte.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.304 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:101:../src/./sendbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SendByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./sendbyte.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:101:../src/./sendbyte.cc:48:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.311 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:101:../src/./sendbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SendByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./sendbyte.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:101:../src/./sendbyte.cc:61:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.326 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:102:../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./setaddr.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:48:34: error: no matching function for call to ‘v8::Value::Int32Value()’ int addr = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:49:44: error: no matching function for call to ‘v8::Value::BooleanValue()’ bool forceAccess = info[2]->BooleanValue(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate: ‘bool v8::Value::BooleanValue(v8::Isolate*) const’ bool BooleanValue(Isolate* isolate) const; ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate: ‘v8::Maybe v8::Value::BooleanValue(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate expects 1 argument, 0 provided V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
            2020-08-30 14:20:17.336 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:102:../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./setaddr.cc:61:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:62:34: error: no matching function for call to ‘v8::Value::Int32Value()’ int addr = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:63:44: error: no matching function for call to ‘v8::Value::BooleanValue()’ bool forceAccess = info[2]->BooleanValue(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate: ‘bool v8::Value::BooleanValue(v8::Isolate*) const’ bool BooleanValue(Isolate* isolate) const; ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate: ‘v8::Maybe v8::Value::BooleanValue(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate expects 1 argument, 0 provided V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
            2020-08-30 14:20:17.348 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:51:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.355 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:63:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:64:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:65:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.370 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:51:36: error: no matching function for call to ‘v8::Value::Int32Value()’ __u16 word = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.377 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:64:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:65:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:66:36: error: no matching function for call to ‘v8::Value::Int32Value()’ __u16 word = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.395 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:70:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:71:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:72:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.407 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:110:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:111:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:112:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.426 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:68:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:69:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:70:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.439 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:108:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:109:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:110:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.454 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:107:../src/./writequick.cc:48:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 bit = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:17.460 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:107:../src/./writequick.cc:61:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 bit = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
            2020-08-30 14:20:18.248 - info: host.raspberrypi iobroker make: *** [i2c.target.mk:111: Release/obj.target/i2c/src/i2c.o] Fehler 1
            2020-08-30 14:20:18.257 - info: host.raspberrypi iobroker gyp
            2020-08-30 14:20:18.260 - info: host.raspberrypi iobroker ERR! build error
            2020-08-30 14:20:18.264 - info: host.raspberrypi iobroker gyp
            2020-08-30 14:20:18.267 - info: host.raspberrypi iobroker ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:315:20)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
            2020-08-30 14:20:18.274 - info: host.raspberrypi iobroker gyp ERR! System Linux 5.4.51-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/i2c-busgyp ERR! node -v v12.18.3gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
            2020-08-30 14:20:20.680 - info: host.raspberrypi iobroker npm ERR! code ELIFECYCLEnpm ERR! errno 1
            2020-08-30 14:20:20.695 - info: host.raspberrypi iobroker npm ERR! i2c-bus@1.2.5 install: `node-gyp rebuild`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the i2c-bus@1.2.5 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            2020-08-30 14:20:20.770 - info: host.raspberrypi iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-08-30T12_20_20_712Z-debug.log
            2020-08-30 14:20:20.813 - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker.i2c@0.0.6: 1
            2020-08-30 14:20:21.853 - info: host.raspberrypi iobroker exit 25
            @Humidor Da dürften ein paar dev-files fehlen.
            sudo apt install build-essential libi2c-dev
            mal probieren.
            • HumidorH Humidor
              @Homoran sagte in Fehler: host.raspberrypi Cannot install iobroker.i2:
              @Humidor sagte in Fehler: host.raspberrypi Cannot install iobroker.i2:
              und was soll ich da jetzt tun??
              oben auf log herunterladen klicken, den gesamten Zusammenhang kopieren und hier wieder in code-tags posten
              Dann sind die Zeilen auch nicht am Ende abgeschnitten
              2020-08-30 14:19:30.900 - info: host.raspberrypi iobroker add i2c --host raspberrypi
              2020-08-30 14:19:37.560 - info: host.raspberrypi iobroker NPM version: 6.14.6
              2020-08-30 14:19:37.566 - info: host.raspberrypi iobroker npm install iobroker.i2c@0.0.6 --loglevel error --prefix "/opt/iobroker" (System call)
              2020-08-30 14:20:16.594 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_converters.h:67, from ../node_modules/nan/nan.h:202, from ../src/i2c.cc:2:../node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBase::return_t Nan::imp::ToFactory::convert(v8::Local)’:../node_modules/nan/nan_converters_43_inl.h:18:69: warning: ‘v8::MaybeLocal v8::Value::ToBoolean(v8::Local) const’ is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations] val->To ## TYPE(v8::Isolate::GetCurrent()->GetCurrentContext()) \ ^../node_modules/nan/nan_converters_43_inl.h:22:1: note: in expansion of macro ‘X’ X(Boolean) ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2664:59: note: declared here V8_WARN_UNUSED_RESULT MaybeLocal ToBoolean( ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
              2020-08-30 14:20:16.621 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_converters.h:67, from ../node_modules/nan/nan.h:202, from ../src/i2c.cc:2:../node_modules/nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase::return_t Nan::imp::ToFactory::convert(v8::Local)’:../node_modules/nan/nan_converters_43_inl.h:37:57: warning: ‘v8::Maybe v8::Value::BooleanValue(v8::Local) const’ is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations] return val->NAME ## Value(isolate->GetCurrentContext()); \ ^../node_modules/nan/nan_converters_43_inl.h:40:1: note: in expansion of macro ‘X’ X(bool, Boolean) ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: declared here V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
              2020-08-30 14:20:16.675 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_new.h:189, from ../node_modules/nan/nan.h:203, from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase::return_t Nan::imp::Factory::New(Nan::FunctionCallback, v8::Local)’:../node_modules/nan/nan_implementation_12_inl.h:105:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfo&), v8::Local&)’ , obj)); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:4275:31: note: candidate: ‘static v8::MaybeLocal v8::Function::New(v8::Local, v8::FunctionCallback, v8::Local, int, v8::ConstructorBehavior, v8::SideEffectType)’ static MaybeLocal New( ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:4275:31: note: no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local’
              2020-08-30 14:20:16.717 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan_new.h:189, from ../node_modules/nan/nan.h:203, from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBase::return_t Nan::imp::Factory::New(v8::Local)’:../node_modules/nan/nan_implementation_12_inl.h:337:37: error: no matching function for call to ‘v8::StringObject::New(v8::Local&)’ return v8::StringObject::New(value).As(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:5531:23: note: candidate: ‘static v8::Local v8::StringObject::New(v8::Isolate*, v8::Local)’ static Local New(Isolate* isolate, Local value); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:5531:23: note: candidate expects 2 arguments, 1 providedIn file included from ../node_modules/nan/nan_new.h:189, from ../node_modules/nan/nan.h:203, from ../src/i2c.cc:2:../node_modules/nan/nan_implementation_12_inl.h:337:58: error: expected primary-expression before ‘>’ token return v8::StringObject::New(value).As(); ^../node_modules/nan/nan_implementation_12_inl.h:337:60: error: expected primary-expression before ‘)’ token return v8::StringObject::New(value).As(); ^
              2020-08-30 14:20:16.811 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local Nan::MakeCallback(v8::Local, v8::Local, int, v8::Local*)’:../node_modules/nan/nan.h:840:60: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, func, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:840:60: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, func, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~
              2020-08-30 14:20:16.820 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local Nan::MakeCallback(v8::Local, v8::Local, int, v8::Local*)’:../node_modules/nan/nan.h:855:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, symbol, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:175:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:855:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, symbol, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:175:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘v8::Local Nan::MakeCallback(v8::Local, const char*, int, v8::Local*)’:../node_modules/nan/nan.h:870:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, const char*, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, method, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:168:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:870:62: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, const char*, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] v8::Isolate::GetCurrent(), target, method, argc, argv); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:168:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~
              2020-08-30 14:20:16.827 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Local)’:../node_modules/nan/nan.h:916:53: error: no matching function for call to ‘v8::Value::ToString()’ v8::Local string = from->ToString(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2668:44: note: candidate: ‘v8::MaybeLocal v8::Value::ToString(v8::Local) const’ V8_WARN_UNUSED_RESULT MaybeLocal ToString( ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2668:44: note: candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2684:31: note: candidate: ‘v8::Local v8::Value::ToString(v8::Isolate*) const’ Local ToString(Isolate* isolate) const); ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2684:31: note: candidate expects 1 argument, 0 provided Local ToString(Isolate* isolate) const); ^~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
              2020-08-30 14:20:16.833 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:926:74: error: no matching function for call to ‘v8::String::WriteUtf8(char*&, int, int, const int&)’ length_ = string->WriteUtf8(str_, static_cast(len), 0, flags); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ int WriteUtf8(Isolate* isolate, char* buffer, int length = -1, ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note: no known conversion for argument 1 from ‘char*’ to ‘v8::Isolate*’
              2020-08-30 14:20:16.860 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::Callback::Call_(v8::Isolate*, v8::Local, int, v8::Local*) const’:../node_modules/nan/nan.h:1484:5: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] )); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h:1484:5: warning: ‘v8::Local node::MakeCallback(v8::Isolate*, v8::Local, v8::Local, int, v8::Local*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations] )); ^In file included from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:182:50: note: declared here NODE_EXTERN v8::Local MakeCallback( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’ __attribute__((deprecated(message))) declarator ^~~~~~~~~~
              2020-08-30 14:20:16.880 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local&)’:../node_modules/nan/nan.h:1538:64: warning: ‘bool v8::Object::Set(v8::Local, v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Set(New(key).ToLocalChecked(), value); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3499:22: note: declared here bool Set(Local key, Local value)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
              2020-08-30 14:20:16.894 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Local&, const v8::Local&)’:../node_modules/nan/nan.h:1544:42: warning: ‘bool v8::Object::Set(v8::Local, v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Set(key, value); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3499:22: note: declared here bool Set(Local key, Local value)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Local&)’:../node_modules/nan/nan.h:1550:44: warning: ‘bool v8::Object::Set(uint32_t, v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Set(index, value); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3508:22: note: declared here bool Set(uint32_t index, Local value)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::AsyncWorker::GetFromPersistent(const char*) const’:../node_modules/nan/nan.h:1556:61: warning: ‘v8::Local v8::Object::Get(v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] New(persistentHandle)->Get(New(key).ToLocalChecked())); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3553:51: note: declared here V8_DEPRECATED("Use maybe version", Local Get(Local key)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::AsyncWorker::GetFromPersistent(const v8::Local&) const’:../node_modules/nan/nan.h:1562:55: warning: ‘v8::Local v8::Object::Get(v8::Local)’ is deprecated: Use maybe version [-Wdeprecated-declarations] return scope.Escape(New(persistentHandle)->Get(key)); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3553:51: note: declared here V8_DEPRECATED("Use maybe version", Local Get(Local key)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In member function ‘v8::Local Nan::AsyncWorker::GetFromPersistent(uint32_t) const’:../node_modules/nan/nan.h:1567:57: warning: ‘v8::Local v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations] return scope.Escape(New(persistentHandle)->Get(index)); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3557:51: note: declared here V8_DEPRECATED("Use maybe version", Local Get(uint32_t index)); ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
              2020-08-30 14:20:16.925 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:2:../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../node_modules/nan/nan.h:1875:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast(AsyncExecuteComplete) ^
              2020-08-30 14:20:17.017 - info: host.raspberrypi iobroker In file included from /usr/include/c++/8/cassert:44, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node_object_wrap.h:26, from ../node_modules/nan/nan.h:53, from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In destructor ‘virtual Nan::ObjectWrap::~ObjectWrap()’:../node_modules/nan/nan_object_wrap.h:24:25: error: ‘class Nan::Persistent’ has no member named ‘IsNearDeath’ assert(persistent().IsNearDeath()); ^~~~~~~~~~~
              2020-08-30 14:20:17.027 - info: host.raspberrypi iobroker In file included from ../node_modules/nan/nan.h:2365, from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:../node_modules/nan/nan_object_wrap.h:67:34: warning: ‘void v8::PersistentBase::MarkIndependent() [with T = v8::Object]’ is deprecated: Weak objects are always considered independent. Use TracedGlobal when trying to use EmbedderHeapTracer. Use a strong handle when trying to keep an object alive. [-Wdeprecated-declarations] persistent().MarkIndependent(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:570:22: note: declared here V8_INLINE void MarkIndependent()); ^~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
              2020-08-30 14:20:17.033 - info: host.raspberrypi iobroker In file included from /usr/include/c++/8/cassert:44, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node_object_wrap.h:26, from ../node_modules/nan/nan.h:53, from ../src/i2c.cc:2:../node_modules/nan/nan_object_wrap.h: In static member function ‘static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo&)’:../node_modules/nan/nan_object_wrap.h:124:26: error: ‘class Nan::Persistent’ has no member named ‘IsNearDeath’ assert(wrap->handle_.IsNearDeath()); ^~~~~~~~~~~
              2020-08-30 14:20:17.118 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:1:../src/i2c.cc: At global scope:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/i2c.cc:88:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(i2c, InitAll) ^~~~~~~~~~~
              2020-08-30 14:20:17.143 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:95:../src/./i2cfuncs.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE I2cFuncsAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./i2cfuncs.cc:48:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.149 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:95:../src/./i2cfuncs.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE I2cFuncsSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./i2cfuncs.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.166 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:96:../src/./readbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readbyte.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:96:../src/./readbyte.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.172 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:96:../src/./readbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readbyte.cc:62:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:96:../src/./readbyte.cc:63:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.187 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:97:../src/./readword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readword.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^
              2020-08-30 14:20:17.193 - info: host.raspberrypi iobroker In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:97:../src/./readword.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.202 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:97:../src/./readword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readword.cc:62:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:97:../src/./readword.cc:63:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.217 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:98:../src/./readblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readblock.cc:66:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:98:../src/./readblock.cc:67:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.227 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:98:../src/./readblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readblock.cc:98:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:98:../src/./readblock.cc:99:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.248 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:99:../src/./readi2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readi2cblock.cc:69:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:70:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:71:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.262 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:99:../src/./readi2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./readi2cblock.cc:109:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:110:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:99:../src/./readi2cblock.cc:111:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.283 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:100:../src/./receivebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReceiveByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./receivebyte.cc:48:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.289 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:100:../src/./receivebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReceiveByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./receivebyte.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.304 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:101:../src/./sendbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SendByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./sendbyte.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:101:../src/./sendbyte.cc:48:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.311 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:101:../src/./sendbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SendByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./sendbyte.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:101:../src/./sendbyte.cc:61:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.326 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:102:../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./setaddr.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:48:34: error: no matching function for call to ‘v8::Value::Int32Value()’ int addr = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:49:44: error: no matching function for call to ‘v8::Value::BooleanValue()’ bool forceAccess = info[2]->BooleanValue(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate: ‘bool v8::Value::BooleanValue(v8::Isolate*) const’ bool BooleanValue(Isolate* isolate) const; ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate: ‘v8::Maybe v8::Value::BooleanValue(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate expects 1 argument, 0 provided V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
              2020-08-30 14:20:17.336 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:102:../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./setaddr.cc:61:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:62:34: error: no matching function for call to ‘v8::Value::Int32Value()’ int addr = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:102:../src/./setaddr.cc:63:44: error: no matching function for call to ‘v8::Value::BooleanValue()’ bool forceAccess = info[2]->BooleanValue(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate: ‘bool v8::Value::BooleanValue(v8::Isolate*) const’ bool BooleanValue(Isolate* isolate) const; ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2699:8: note: candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27, from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate: ‘v8::Maybe v8::Value::BooleanValue(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2702:51: note: candidate expects 1 argument, 0 provided V8_WARN_UNUSED_RESULT Maybe BooleanValue( ^~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’ declarator __attribute__((deprecated(message))) ^~~~~~~~~~
              2020-08-30 14:20:17.348 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:51:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.355 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:103:../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writebyte.cc:63:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:64:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:103:../src/./writebyte.cc:65:35: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 byte = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.370 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:51:36: error: no matching function for call to ‘v8::Value::Int32Value()’ __u16 word = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.377 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:104:../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeword.cc:64:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:65:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:104:../src/./writeword.cc:66:36: error: no matching function for call to ‘v8::Value::Int32Value()’ __u16 word = info[2]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.395 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:70:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:71:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:72:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.407 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:105:../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writeblock.cc:110:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:111:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:105:../src/./writeblock.cc:112:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.426 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:68:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:69:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:70:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.439 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:106:../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writei2cblock.cc:108:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:109:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 cmd = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:106:../src/./writei2cblock.cc:110:39: error: no matching function for call to ‘v8::Value::Uint32Value()’ __u32 length = info[2]->Uint32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Uint32Value( ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.454 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickAsync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:107:../src/./writequick.cc:48:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 bit = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:17.460 - info: host.raspberrypi iobroker In file included from ../src/i2c.cc:107:../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/./writequick.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’ int fd = info[0]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 providedIn file included from ../src/i2c.cc:107:../src/./writequick.cc:61:34: error: no matching function for call to ‘v8::Value::Int32Value()’ __u8 bit = info[1]->Int32Value(); ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67, from ../src/i2c.cc:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Local) const’ V8_WARN_UNUSED_RESULT Maybe Int32Value(Local context) const; ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
              2020-08-30 14:20:18.248 - info: host.raspberrypi iobroker make: *** [i2c.target.mk:111: Release/obj.target/i2c/src/i2c.o] Fehler 1
              2020-08-30 14:20:18.257 - info: host.raspberrypi iobroker gyp
              2020-08-30 14:20:18.260 - info: host.raspberrypi iobroker ERR! build error
              2020-08-30 14:20:18.264 - info: host.raspberrypi iobroker gyp
              2020-08-30 14:20:18.267 - info: host.raspberrypi iobroker ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:315:20)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
              2020-08-30 14:20:18.274 - info: host.raspberrypi iobroker gyp ERR! System Linux 5.4.51-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/i2c-busgyp ERR! node -v v12.18.3gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
              2020-08-30 14:20:20.680 - info: host.raspberrypi iobroker npm ERR! code ELIFECYCLEnpm ERR! errno 1
              2020-08-30 14:20:20.695 - info: host.raspberrypi iobroker npm ERR! i2c-bus@1.2.5 install: `node-gyp rebuild`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the i2c-bus@1.2.5 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
              2020-08-30 14:20:20.770 - info: host.raspberrypi iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-08-30T12_20_20_712Z-debug.log
              2020-08-30 14:20:20.813 - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker.i2c@0.0.6: 1
              2020-08-30 14:20:21.853 - info: host.raspberrypi iobroker exit 25
              @Humidor Aber das hier hattest du gelesen, verstanden und befolgt?
              IMPORTANT UPDATE
              Development of this adapter will restart in August 2020. Stay tuned!
              I will start by resolving the most pressing issues followed by a new major release that brings the adapter up to the latest development standards.
              I2C Logo
              ioBroker adapter for I2C
              Number of Installations Number of Installations NPM version Downloads Travis GitHub issues
              Communicates with devices connected to the local system using the I2C bus.
              This adapter should work on Linux boards like the Raspberry Pi, C.H.I.P., BeagleBone or Intel Edison.
              Install
              Before installing, please read the installation guide of the i2c-bus module.
              Especially make sure, that you have properly configured and enabled I2C on your system (if needed):
              Configuring I2C on the Raspberry Pi
              Configuring I2C on the Intel Edison Arduino Base Board
              After you have enabled and configured I2C, you can install this adapter via ioBroker Admin:
              Start the adapter (it must run for the discovery to work)
              Open instance config dialog
              Press the "Search Devices" button to discover all connected I2C devices - this will take some time, be patient!
              Configure all found devices in their respective tabs.
              Save the configuration (this will restart the adapter)
              HumidorH 1 Antwort Letzte Antwort
                IMPORTANT UPDATE
                I2C Logo
                Install
                HumidorH Offline
                HumidorH Offline
                Humidor
                schrieb am zuletzt editiert von Humidor
                @Homoran sagte in Fehler: host.raspberrypi Cannot install iobroker.i2:
                am Pi ist I2c enabled und mehrfach ein reboot wurde gemacht
                BG
                • HumidorH Humidor
                  @Humidor
                  sudo apt install build-essential libi2c-dev
                  probiert?
                    @Humidor
                    probiert?
                    HumidorH Offline
                    HumidorH Offline
                    Humidor
                    @Thomas-Braun sagte in Fehler: host.raspberrypi Cannot install iobroker.i2:
                    @Humidor
                    probiert?
                    nein, wo hast du das gefunden,
                    funktioniert aber auch nicht.
                    BG
                    • HumidorH Humidor
                      @Humidor
                      probiert?
                      @Humidor sagte in Fehler: host.raspberrypi Cannot install iobroker.i2:
                      was?
                      die Installation des Paketes, oder der anschließende Versuch den Adapter zu installieren.
                      Bitte immer die vollständige Konsolenein- und Ausgabe posten
                        was?
                        HumidorH Offline
                        HumidorH Offline
                        Humidor
                        was?
                        sry, die Installation vom Adapter, immer die selbe Fehlermeldung
                        build-essential ist schon die neueste Version (12.6).
                        Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                          libbrotli1 libc-ares2 libuv1 nodejs-doc rpi-eeprom-images
                        Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                        Die folgenden zusätzlichen Pakete werden installiert:
                          i2c-tools libi2c0 read-edid
                        Vorgeschlagene Pakete:
                          python-smbus
                        Die folgenden NEUEN Pakete werden installiert:
                          i2c-tools libi2c-dev libi2c0 read-edid
                        0 aktualisiert, 4 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                        Es müssen 108 kB an Archiven heruntergeladen werden.
                        Nach dieser Operation werden 351 kB Plattenplatz zusätzlich benutzt.
                        Möchten Sie fortfahren? [J/n] j
                        Holen:1 http://debian.anexia.at/raspbian/raspbian buster/main armhf libi2c0 armhf 4.1-1 [9.348 B]
                        Holen:2 http://debian.anexia.at/raspbian/raspbian buster/main armhf i2c-tools armhf 4.1-1 [71,7 kB]
                        Holen:3 http://debian.anexia.at/raspbian/raspbian buster/main armhf libi2c-dev armhf 4.1-1 [11,9 kB]
                        Holen:4 http://debian.anexia.at/raspbian/raspbian buster/main armhf read-edid armhf 3.0.2-1 [15,4 kB]
                        Es wurden 108 kB in 1 s geholt (97,7 kB/s).
                        Vormals nicht ausgewähltes Paket libi2c0:armhf wird gewählt.
                        (Lese Datenbank ... 46420 Dateien und Verzeichnisse sind derzeit installiert.)
                        Vorbereitung zum Entpacken von .../libi2c0_4.1-1_armhf.deb ...
                        Entpacken von libi2c0:armhf (4.1-1) ...
                        Vormals nicht ausgewähltes Paket i2c-tools wird gewählt.
                        Vorbereitung zum Entpacken von .../i2c-tools_4.1-1_armhf.deb ...
                        Entpacken von i2c-tools (4.1-1) ...
                        Vormals nicht ausgewähltes Paket libi2c-dev wird gewählt.
                        Vorbereitung zum Entpacken von .../libi2c-dev_4.1-1_armhf.deb ...
                        Entpacken von libi2c-dev (4.1-1) ...
                        Vormals nicht ausgewähltes Paket read-edid wird gewählt.
                        Vorbereitung zum Entpacken von .../read-edid_3.0.2-1_armhf.deb ...
                        Entpacken von read-edid (3.0.2-1) ...
                        libi2c0:armhf (4.1-1) wird eingerichtet ...
                        read-edid (3.0.2-1) wird eingerichtet ...
                        libi2c-dev (4.1-1) wird eingerichtet ...
                        i2c-tools (4.1-1) wird eingerichtet ...
                        Trigger für man-db (2.8.5-2) werden verarbeitet ...
                        Trigger für libc-bin (2.28-10+rpi1) werden verarbeitet ...
                        pi@raspberrypi:~ $ sudo reboot
                        BG
                        • HumidorH Humidor
                          was?
                            python-smbus
                          @Humidor Kann es sein, dass du mal den ganzen node-* Kram von Debian installiert hattest oder noch hast? Da scheint mir noch irgendwas doppelt installiert zu sein.
                          sudo apt autoremove
                          sudo apt remove node-*
                          Denn nodejs-doc kommt aus dem Debian-Repo:
                          pi@raspberrypi:/opt/iobroker $ apt policy nodejs-doc
                          nodejs-doc:
                            Installiert:           (keine)
                            Installationskandidat: 10.21.0~dfsg-1~deb10u1+rpi1
                            Versionstabelle:
                               10.21.0~dfsg-1~deb10u1+rpi1 500
                          Vermutlich ist von dort noch mehr installiert worden.
                            sudo apt autoremove
                            nodejs-doc:
                              Versionstabelle:
                            HumidorH Offline
                            HumidorH Offline
                            Humidor
                            sudo apt autoremove
                            nodejs-doc:
                              Versionstabelle:
                            sudo apt autoremove
                            Die folgenden Pakete werden ENTFERNT:
                            0 aktualisiert, 0 neu installiert, 5 zu entfernen und 0 nicht aktualisiert.
                            Nach dieser Operation werden 8.739 kB Plattenplatz freigegeben.
                            (Lese Datenbank ... 46469 Dateien und Verzeichnisse sind derzeit installiert.)
                            Entfernen von libbrotli1:armhf (1.0.7-2) ...
                            Entfernen von libc-ares2:armhf (1.14.0-1) ...
                            Entfernen von libuv1:armhf (1.24.1-1) ...
                            Entfernen von nodejs-doc (10.21.0~dfsg-1~deb10u1+rpi1) ...
                            Entfernen von rpi-eeprom-images (7.10-1) ...
                            pi@raspberrypi:~ $ sudo apt remove node-*
                            E: Paket node-v12.18.3-linux-armv6l.tar.xz kann nicht gefunden werden.
                            E: Mittels des Musters »node-v12.18.3-linux-armv6l.tar.xz« konnte kein Paket gefunden werden.
                            E: Mittels regulärem Ausdruck »node-v12.18.3-linux-armv6l.tar.xz« konnte kein Paket gefunden werden.
                            nodejs-doc:
                              Versionstabelle:
                            pi@raspberrypi:~ $
                            damit wäre wieder alles raus?
                            which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                            /usr/bin/nodejs
                            v12.18.3
                            /usr/bin/node
                            v12.18.3
                            /usr/bin/npm
                            6.14.6
                            nodejs:
                              Installiert:           12.18.3-1nodesource1
                              Installationskandidat: 12.18.3-1nodesource1
                              Versionstabelle:
                             *** 12.18.3-1nodesource1 500
                                    500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                            pi@raspberrypi:~ $
                            BG
                            • HumidorH Humidor
                              sudo apt autoremove
                              nodejs-doc:
                                Versionstabelle:
                              sudo apt autoremove
                              nodejs-doc:
                                Versionstabelle:
                              pi@raspberrypi:~ $
                              /usr/bin/nodejs
                              v12.18.3
                              /usr/bin/node
                              v12.18.3
                              /usr/bin/npm
                              6.14.6
                              nodejs:
                                Versionstabelle:
                              pi@raspberrypi:~ $
                              Da hast du doch irgendwie manuell versucht irgendwas zu installieren...
                              Lösch die Datei.
                                Lösch die Datei.
                                HumidorH Offline
                                HumidorH Offline
                                Humidor
                                Lösch die Datei.
                                keine Ahnung was du da meinst, ich kenne mich bei Linux nicht aus, ich kopiere die Befehle aus den Docs oder von euch
                                BG
                                • HumidorH Humidor
                                  Lösch die Datei.
                                  ggf. auch von externen und/oder veralteten Quellen?
                                  • HumidorH Humidor
                                    Lösch die Datei.
                                    @Humidor
                                    rm node-v12.18.3-linux-armv6l.tar.xz
                                      HumidorH Offline
                                      HumidorH Offline
                                      Humidor
                                      im Admin(online) ist nur die latest drin, jetzt fkt. die Seite auch nicht mehr richtig?
                                      BG
                                        @Humidor
                                        HumidorH Offline
                                        HumidorH Offline
                                        Humidor
                                        @Humidor
                                        ist das von der Nodejs Intstallation?
                                        habe ich dort ev. eine falsche Zeile verwendet?
                                        BG
                                        • HumidorH Humidor
                                          @Humidor
                                          @Humidor Du hast da händisch eine Quelldatei hingelegt. Das macht man so nicht (wenn man keine Ahnung hat).
