  4. Shelly Adapter 4.0 - Shelly Firmware 1.8 - Tester gesucht ;)
    6.6k
shelly adapteradaptertesting
284 Beiträge 37 Kommentatoren 72.7k Aufrufe 41 Beobachtet
  • K Kueppert
    hab bei meinem SHelly Dimmer 1 (FW 1.8) nun das Problem nach dem Update auf SHelly 4, dass ich diverse Fehlermeldungen im LOG erhalte:
    host.ioBroker2	2020-08-14 10:16:19.386	error	instance system.adapter.shelly.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.ioBroker2	2020-08-14 10:16:19.386	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    host.ioBroker2	2020-08-14 10:16:19.386	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
    host.ioBroker2	2020-08-14 10:16:19.386	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.shelly/lib/datapoints.js:32:19)
    host.ioBroker2	2020-08-14 10:16:19.386	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
    host.ioBroker2	2020-08-14 10:16:19.386	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1019:19)
    host.ioBroker2	2020-08-14 10:16:19.386	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    host.ioBroker2	2020-08-14 10:16:19.385	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
    host.ioBroker2	2020-08-14 10:16:19.385	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    host.ioBroker2	2020-08-14 10:16:19.385	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1097:27)
    host.ioBroker2	2020-08-14 10:16:19.385	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:1047:16)
    host.ioBroker2	2020-08-14 10:16:19.385	error	Caught by controller[0]: SyntaxError: Unexpected identifier
    host.ioBroker2	2020-08-14 10:16:19.385	error	Caught by controller[0]: ^^^^^^^^^^^^^^^^^^
    host.ioBroker2	2020-08-14 10:16:19.384	error	Caught by controller[0]: coap_publish_funct: (value) => { return value === 1 ? true : false; },
    host.ioBroker2	2020-08-14 10:16:19.384	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.shelly/lib/devices/shellyix3.js:140
    Einen USer/PW für den Zugang hab ich im Dimmer nicht hinterlegt. Hab den Adapter auf COAP/HTTP stehen...
    harrymH Offline
    harrymH Offline
    harrym
    #68
    @Kueppert lad den adapter bitte nochmals via git. war ein fehler im code drinnen :/ sry
    ASRock FM2A88X-ITX+ mit 32GB RAM, 128GB SSD mit Proxmox, 3x1 TB SSD als RAID mit CT und VMs.
    • harrymH harrym
      Kueppert
      schrieb am zuletzt editiert von Kueppert
      #69
      @harrym top, lüpp, danke dir ;)
      Mir fällt gerade auf, dass der Name des SHelly, den ich in der App gesetzt habe, vom Adapter im DP nicht befüllt wird. Kann aber auch schon immer so gewesen sein:
      Ist der SHDM-1
      KOMMANDO ZURÜCK: in der Weboberfläche am PC hab ich noch ein anderes Feld für die Bezeichnung gefunden. Hab jetzt im DP im ioB auch den Namen stehen
      • R Offline
        Rocko84
        #70
        Beim DW1 hat sich immer noch nichts getan. Die coap massage seht ihr weiter oben. Auch nochmal in Bilder wie ioBroker die Daten empfängt.
        Vorher:
        Erste Aktualisierung:
        Zweite Aktualisierung:
        Ich hoffe das hilft
        • R Rocko84
          Vorher:
          Ich hoffe das hilft
          da_WoodyD Offline
          da_WoodyD Offline
          #71
          @Rocko84 haben uns das gerade belinst. im 2.pic meldet sich der dw zwar, ist aber noch offline! damit bekommst du keine daten. im 3. ist alles OK. timestamps wären interessannt.
          edith: wie man an der uptime sehen kann is das ding nur extrem kurz da zum senden... ist uns auch vor ein paar tagen aufgefallen...
          • R Offline
            Rocko84
            #72
            Also die uptimes waren schon immer so. Der dw ist halt battery betrieben.
            Hier einmal jetzt mit den timestamps. Zusätzlich ist mir aufgefallen, das der Lux wert sogar 3 mal aktualisiert wird. Eigentlich auch unnötig.
            Vorher:
            1. Aktualisierung:
            2. Aktualisierung:
            3. Aktualisierung:
            Zusätzlich ist mir aufgefallen, dass beim Shsw-1 der Input State sich nicht mehr ändert trotz Input. Der Input Counter zählt fleißig weiter. Braucht ihr dazu noch mehr Daten?
            harrymH 1 Antwort Letzte Antwort
            • R Rocko84
              Vorher:
              1. Aktualisierung:
              2. Aktualisierung:
              3. Aktualisierung:
              harrymH Offline
              harrymH Offline
              harrym
              #73
              @Rocko84 der Input State ... das ist noch falsch definiert. Da ist ein externer Schalter gemeint. (SW Kontakt)
              • snotechS Offline
                snotechS Offline
                snotech
                #74
                Hallo
                ich habe die 2.5 Shelly's und nach dem ich den Adapter auf 4.0 hochgezogen habe, läuft wierder alles !
                Danke für eure tolle Arbeit.👍 Wenn ich noch was testen oder nachschauen soll, sagt bescheidt.
                SNO
                • R Offline
                  Rocko84
                  #75
                  Das ist mir klar. Ich benutze den Input in einem Skript als trigger unabhängig vom Zustand des relays. Nun funktioniert das Skript leider nicht mehr.
                  Wann wird das korrigiert?
                  • R Rocko84
                    da_WoodyD Offline
                    da_WoodyD Offline
                    #76
                    @Rocko84 @harrym werkelt da neben mir...
                    edith: nachfrage bei dimitar ist auch draussen...
                    • R Offline
                      Rocko84
                      #77
                      coiot new convention jsons-3.zip
                      habe ich grad von Shelly bekommen. Hilft das?
                      • R Rocko84
                        harrymH Offline
                        harrymH Offline
                        harrym
                        #78
                        @Rocko84 fehler gefunden ... war ein typo :/
                        • HogyH Offline
                          HogyH Offline
                          Hogy
                          schrieb am zuletzt editiert von Hogy
                          #79
                          Habe mir die 4.0.0 installiert.
                          Anregung... könnt ihr einen Datenpunkt mehr mit aufnehmen?
                          Dann kann man im VIS schön mit den Namen weiter arbeiten und muss nur an einer Stelle und zwar am Shelly selbst pflegen.
                          Der neue Datenpunkt müsste dann bester Weise unterhalb des Kanals eingeordnet werden
                          Ich habe diese Shellys im Einsatz...
                          • HogyH Hogy
                            harrymH Offline
                            harrymH Offline
                            harrym
                            #80
                            @Hogy ist geplant bzw. schon umgesetzt.
                            HogyH 1 Antwort Letzte Antwort
                            • harrymH harrym
                              HogyH Offline
                              HogyH Offline
                              Hogy
                              #81
                              @harrym
                              Super cool! Vermutlich mit 4.0.1 verfügbar
                              • R Offline
                                Rocko84
                                #82
                                Am dw1 und shsw1 hat sich nichts getan. Beide Fehler weiterhin vorhanden trotz neu Installation und restart
                                  Strobelix
                                  #83
                                  Ich habe jetzt mal den Adapter mit CoAP und MQTT verglichen.
                                  MQTT ist gefühlt über 1 Sekunde schneller als CoAp.
                                  Das war in der alten Version nicht so, da war CoAp nahezu Echtzeit. Liegt das am neuen CoApProtokoll oder am neuen Adapter?
                                  Raspberrymatic, Homematic & Homematic IP Aktoren, ioBroker auf NUC i3, Nuki, Harmony Hub, Digitalstrom, Diverse Sonoff (Tasmota) und Shellies
                                  • R Rocko84
                                    harrymH Offline
                                    harrymH Offline
                                    harrym
                                    #84
                                    @Rocko84 shsw1 ist gefixt
                                    • S Strobelix
                                      harrymH Offline
                                      harrymH Offline
                                      harrym
                                      #85
                                      @Strobelix ich bemerke eigentlich keinen Unterschied.
                                      • R Offline
                                        Rocko84
                                        #86
                                        Ja super danke funktioniert.
                                        Nur dieser Delay den habe ich auch und der nervt echt. Der war vorher nicht da. Kann das auch noch gefixt werden?
                                        • R Rocko84
                                          harrymH Offline
                                          harrymH Offline
                                          harrym
                                          #87
                                          @Rocko84 Allterco hat ja laut Changelog zur 1.8er auch was bzgl. Wifi und NW-Protokoll geändert. Wir sind abhängig von den CoAP Messages, die eben vom jeweiligen Device geschickt werden. Da können wir nichts daran drehen :/
                                          R 1 Antwort Letzte Antwort
