  4. Fehler beim (de)installieren von Adaptern
    6.8k
fehleradapter
73 Beiträge 10 Kommentatoren 8.3k Aufrufe 6 Beobachtet
  • D.VED D.VE
    Moin jetzt hatte ich mal wieder etwas Zeit....
    @AlCalzone said in Fehler beim (de)installieren von Adaptern:
    Bitte wie hier beschrieben, direkt nach dem Installieren manuell per npm den Controller updaten!
    Hab ich gemacht, aber irgendwas hat da nicht funktioniert... Gab diverse Fehlermeldungen...
    thx again...
    C:\Program Files\iobroker\ioBroker>iobroker stop
    2020-08-12 23:06:54,166 INFO  - Stopping the service with id 'iobroker(ioBroker)'
    C:\Program Files\iobroker\ioBroker>npm i iobroker.js-controller@2.2.10
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    > iobroker.js-controller@2.2.10 preinstall C:\Program Files\iobroker\ioBroker\node_modules\iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.11.3
    > unix-dgram@2.0.3 install C:\Program Files\iobroker\ioBroker\node_modules\unix-dgram
    > node-gyp rebuild
    C:\Program Files\iobroker\ioBroker\node_modules\unix-dgram>if not defined npm_config_node_gyp (node "C:\Program Files\iobroker\ioBroker\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node "C:\Program Files\iobroker\ioBroker\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
    gyp ERR! find VS
    gyp ERR! find VS msvs_version not set from command line or npm config
    gyp ERR! find VS VCINSTALLDIR not set, not running in VS Command Prompt
    gyp ERR! find VS could not use PowerShell to find Visual Studio 2017 or newer
    gyp ERR! find VS looking for Visual Studio 2015
    gyp ERR! find VS - not found
    gyp ERR! find VS not looking for VS2013 as it is only supported up to Node.js 8
    gyp ERR! find VS
    gyp ERR! find VS **************************************************************
    gyp ERR! find VS You need to install the latest version of Visual Studio
    gyp ERR! find VS including the "Desktop development with C++" workload.
    gyp ERR! find VS For more information consult the documentation at:
    gyp ERR! find VS https://github.com/nodejs/node-gyp#on-windows
    gyp ERR! find VS
    gyp ERR! configure error
    gyp ERR! stack Error: Could not find any Visual Studio installation to use
    gyp ERR! stack     at VisualStudioFinder.fail (C:\Program Files\iobroker\ioBroker\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:121:47)
    gyp ERR! stack     at findVisualStudio2013 (C:\Program Files\iobroker\ioBroker\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:74:16)
    gyp ERR! stack     at VisualStudioFinder.findVisualStudio2013 (C:\Program Files\iobroker\ioBroker\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:344:14)
    gyp ERR! stack     at findVisualStudio2015 (C:\Program Files\iobroker\ioBroker\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:70:14)
    gyp ERR! stack     at regSearchKeys (C:\Program Files\iobroker\ioBroker\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:365:16)
    gyp ERR! stack     at regGetValue (C:\Program Files\iobroker\ioBroker\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:54:7)
    gyp ERR! stack     at C:\Program Files\iobroker\ioBroker\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:33:16gyp ERR! stack     at ChildProcess.exithandler (child_process.js:301:5)
    gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
    gyp ERR! System Windows_NT 10.0.17763
    gyp ERR! command "C:\\Program Files\\iobroker\\ioBroker\\nodejs\\node.exe" "C:\\Program Files\\iobroker\\ioBroker\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
    gyp ERR! cwd C:\Program Files\iobroker\ioBroker\node_modules\unix-dgram
    gyp ERR! node -v v10.17.0
    gyp ERR! node-gyp -v v5.0.3
    gyp ERR! not ok
    > iobroker.js-controller@2.2.10 install C:\Program Files\iobroker\ioBroker\node_modules\iobroker.js-controller
    > node iobroker.js setup first
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules\chokidar\node_modules\fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.3 (node_modules\unix-dgram):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@2.0.3 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    + iobroker.js-controller@2.2.10
    added 3 packages from 5 contributors, removed 925 packages, updated 61 packages, moved 6 packages and audited 303 packages in 140.331s
    found 1 low severity vulnerability
      run `npm audit fix` to fix them, or `npm audit` for details
       │      New minor version of npm available! 6.11.3 -> 6.14.7      │
       │   Changelog: https://github.com/npm/cli/releases/tag/v6.14.7   │
       │               Run npm install -g npm to update!                │
    @D-VE
    Hört sich nach einer klaren Sache an
    D.VED 1 Antwort Letzte Antwort
      @D-VE
      D.VED Offline
      D.VED Offline
      D.VE
      @Thomas-Braun said in Fehler beim (de)installieren von Adaptern:
      Geht so...
      Wieso brauche ich Visual Studio?
      Mein SmartHome-Podcast:
      http://www.scheiss-technik.com
      • D.VED D.VE
        Geht so...
        @D-VE Da dürfte der Support von C++ mit dabei sein.
          D.VED Offline
          D.VED Offline
          D.VE
          @Thomas-Braun
          Ich kann doch jetzt nicht allen ernstes da eine riesige Visual Studio Installation mit drauf packen (für die ich keine Lizenz habe)? Das lief doch bisher auch ohne... Warum werden die benötigten Pakete da nicht mit dem Installer gleich mitinstalliert?
          • D.VED D.VE
            @Thomas-Braun
            @D-VE Von Windows hab ich keine Ahnung. Da läuft ja die Installation eh etwas 'merkwürdig' ab, imho.
            Visual Studio ist aber kostenfrei, wenn ich das richtig sehe.
              D.VED Offline
              D.VED Offline
              D.VE
              @D-VE Von Windows hab ich keine Ahnung. Da läuft ja du ie Installation eh etwas 'merkwürdig' ab, imho.
              Kostenlos kenne ich nur Visual Studio Code... Ist aber ein komplett anderes Produkt.
              Kann mir nicht vorstellen, dass ich ioBroker nur upadten kann indem ich Visual Studio installiere...
              Thomas BraunT J.A.R.V.I.S.J 2 Antworten Letzte Antwort
              • D.VED D.VE
                @D-VE In dem Link sind doch mehrere Optionen genannt
                • D.VED D.VE
                  J.A.R.V.I.S.J Offline
                  J.A.R.V.I.S.
                  @D-VE du benötigst die Visual Studio Build Tools.
                  • J.A.R.V.I.S.J J.A.R.V.I.S.
                    D.VED Offline
                    D.VED Offline
                    D.VE
                    @J-A-R-V-I-S said in Fehler beim (de)installieren von Adaptern:
                    Warum sind die nicht Teil des Windows Installers?
                    Kann mir da irgendjemand helfen, mal zusammen in eine Skype/Teams-Session ioBroker so upzudaten, dass es läuft?
                    Bin mittlerweile auch bereit dazu, dafür zu bezahlen.
                    • D.VED D.VE
                      @D-VE Vermutlich rechtliche Gründe.
                        D.VED Offline
                        D.VED Offline
                        D.VE
                        @Thomas-Braun
                        Und warum braucht man die nur bei einem Update?
                        Finde ioBroker gerade irgfendwie nur anstrengend und frustrierend...
                        Ich hab immer nur sehr kleine Zeitfenster in denen ich dazu Zeit habe. Und die würde ich gerne mit Programmierung von meinem SmartHome verbringen und nicht mit Versuchen, das System überhaupt erstmal an's Laufen zu kriegen
                        • D.VED D.VE
                          @Thomas-Braun
                          @D-VE Installiert den ioBroker auf einem Linux. Ist aus meiner Sicht wesentlich einfacher als der Hantier mit Windows.
                          • D.VED D.VE
                            @Thomas-Braun
                            @D-VE sagte in Fehler beim (de)installieren von Adaptern:
                            Dann nimm Linux
                              Dann nimm Linux
                              D.VED Offline
                              D.VED Offline
                              D.VE
                              Der hauptsöchliche Grund, warum ich mich für ioBroker entschieden habe war, dass es eine Windows-Variante gab...
                              Mit Linux kenne ich mich nicht aus. Ich hatte ioBroker auch schonmal auf einem Pi laufen, bin ich nicht mit klargekommen...
                              • D.VED D.VE
                                @D-VE Geht mir umgekehrt genauso mit Windows. Wenn ich das Gefrickel mit der Windows-Installation hier im Forum anschaue... Nee, Danke. :-)
                                  D.VED Offline
                                  D.VED Offline
                                  D.VE
                                  Ja, kann ich verstehen... Imo sollte man das aber dann auch einfach nicht veröffentlichen, oder zumindest klar mit einem BETA Status versehen...
                                  So ist das alles ein großer Krampf und nervt nur!
                                  Ich weiß, wie man eine Windowskiste administriert, das mache ich z.T. beruflich. Linux ist mir zu stressig. Da muss ich selbst einfache Shell-Befehle jedes Mal nachschlagen. Hab ich mehrfach mit der NAS probiert.
                                  Das Hauptproblem ist: Man frickelt sich das mit Tutorials irgendwie zurecht, setzt das System auf, es läuft ein Jahr und dann knallt irgendwas. Das Halbwissen aus den Tutorials ist dann aber wieder weg, so dass man nicht in der Lage ist Probleme mal selber zu fixen...
                                  Daher kommt für mich nur Windows in Frage... Wenn es mit ioBroker nicht ohne weiteres geht (was ja offensichtlich der Fall zu scheint), muss ich mir was anderes suchen.
                                  HomoranH Thomas BraunT 3 Antworten Letzte Antwort
                                  • D.VED D.VE
                                    Mit Windows wahrscheinlich genauso wenig.
                                    brauchst du auch nicht. Die Installation besteht aus einer Zeile, dann fast nix mehr mit Linux.
                                    Das Problem bei Windows liegt daran, dass @Stabilostick da Wochen seiner Freizeit investiert hat um es darauf zum Laufen zu bringen. Bei jeder Änderung, die Microsoft da rein bringt muss wieder Zeit für die Anpassung investiert werden.Oder jemand anderes, der sich mit Windows auskennt, hilft, weil auch die Freizeit von Entwicklern endlich ist.
                                    Mit Linux hast du viele Helfer.
                                    Also hast du einen Pi.
                                    installiere dir da nochmal das aktuelle RaspiOS und dann curl -sLf https://iobroker.net/install.sh | bash -
                                    ggf. musst du noch eine Datei ssh auf der sd Karte anlegen, wenn du direkt mit putty vom PC arbeiten willst.
                                    Nach kurzer Zeit wirst du das einfache System nicht mehr missen wollen.
                                    ging mir vor einigen Jahren genauso
                                    • D.VED D.VE
                                      Weil M$ in der Zwischenzeit wieder was komplett verändert hat
                                      • D.VED D.VE
                                        Man frickelt sich das mit Tutorials irgendwie zurecht ... Das Halbwissen aus den Tutorials ist dann aber wieder weg,
                                        Und genau das ist das Problem.
                                        Viele so genannte Tutorium ersteller haben auch nur Halbwissen, oder die Tutorials sind hoffnungslos veraltet.
                                        Es gibt unsere Website und vor allem dieses Forum.
                                        Und unter Linux habe ich noch jedem Einsteiger uioBroker stabil ans Laufen bekommen.
                                        Es wäre ein Witz wenn du der erste wärst, bei dem es nicht klappt.
                                          D.VED Offline
                                          D.VED Offline
                                          D.VE
                                          @Homoran said in Fehler beim (de)installieren von Adaptern:
                                          Mit Micrsosoft Produkten verdiene ich meine Brötchen, wenn auch nur am Rande mit Windows Server.
                                          Steht nicht zur Debatte, wenn dann installiere ich Linux auf einer VM. Pi ist mir zu instabil, meine Experimente damit sind einfach komplett gescheitert (ioBroker, OpenHab, CCU2), weil da irgendwas am Betriebssystem schief gegangen ist.
