  4. NodeRed funktioniert nicht
nodered
38 Beiträge 4 Kommentatoren 3.8k Aufrufe 4 Beobachtet
    shaolinmaster
    schrieb am zuletzt editiert von shaolinmaster
    Hallo. Nach der Installation von NodeRed wird der Adapter zwar grün, aber im Log steht drin:
    Error: Cannot find module 'pause'
    Woran kann das liegen? Kann es auch trotz grünem Adapter nicht starten.
    node-red.0
    2020-08-10 21:42:29.911
    info
    (1197) node-red exited with 1
    node-red.0
    2020-08-10 21:42:29.879
    warn
    node-red.0
    warn
    node-red.0
    warn
    '/opt/iobroker/node_modules/node-red/red.js'
    node-red.0
    warn
    '/opt/iobroker/node_modules/node-red/lib/red.js',
    node-red.0
    warn
    '/opt/iobroker/node_modules/@node-red/editor-api/lib/index.js',
    node-red.0
    warn
    '/opt/iobroker/node_modules/@node-red/editor-api/node_modules/passport/lib/index.js',
    node-red.0
    warn
    '/opt/iobroker/node_modules/@node-red/editor-api/node_modules/passport/lib/authenticator.js',
    node-red.0
    warn
    '/opt/iobroker/node_modules/@node-red/editor-api/node_modules/passport/lib/strategies/session.js',
    node-red.0
    warn
    requireStack: [
    node-red.0
    warn
    code: 'MODULE_NOT_FOUND',
    node-red.0
    warn
    at Module.require (internal/modules/cjs/loader.js:1025:19) {
    node-red.0
    warn
    at Function.Module._load (internal/modules/cjs/loader.js:878:14)
    node-red.0
    warn
    at Module.load (internal/modules/cjs/loader.js:985:32)
    node-red.0
    warn
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
    node-red.0
    warn
    at Module._compile (internal/modules/cjs/loader.js:1137:30)
    node-red.0
    warn
    at Object.<anonymous> (/opt/iobroker/node_modules/@node-red/editor-api/node_modules/passport/lib/strategies/session.js:4:13)
    node-red.0
    warn
    at require (internal/modules/cjs/helpers.js:72:18)
    node-red.0
    warn
    node-red.0
    warn
    at Function.Module._load (internal/modules/cjs/loader.js:841:27)
    node-red.0
    warn
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
    node-red.0
    warn
    - /opt/iobroker/node_modules/node-red/red.js
    node-red.0
    warn
    - /opt/iobroker/node_modules/node-red/lib/red.js
    node-red.0
    warn
    - /opt/iobroker/node_modules/@node-red/editor-api/lib/index.js
    node-red.0
    warn
    - /opt/iobroker/node_modules/@node-red/editor-api/node_modules/passport/lib/index.js
    node-red.0
    warn
    - /opt/iobroker/node_modules/@node-red/editor-api/node_modules/passport/lib/authenticator.js
    node-red.0
    warn
    - /opt/iobroker/node_modules/@node-red/editor-api/node_modules/passport/lib/strategies/session.js
    node-red.0
    warn
    Require stack:
    node-red.0
    warn
    Error: Cannot find module 'pause'```
    • S shaolinmaster
      node-red.0
      info
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      requireStack: [
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      node-red.0
      warn
      Require stack:
      node-red.0
      warn
      @shaolinmaster Konsolentext bitte mit CodeTags </> versehen.
      werner2000xW 1 Antwort Letzte Antwort
        werner2000xW Offline
        werner2000x
        @Thomas-Braun Ich habe in NodeRed das Problem aus einem HTTP Request einen Zahlenwert herauszufiltern.
        Mein Output aus dem HTTP Request sieht so aus:
        <html><head><title>ISm</title></head><meta http-equiv="refresh" content="5;url="> <h2>IPswitch-S0m-WiFi: <hr><pre>S0 = 19.077.938Wh + 10W<FONT SIZE='-2'>, min= 0W, max. 743W</FONT><br>Limit Output = 1<br>MQTT connected= 1<FONT SIZE='-2'>, vor= 244s, connected= 28, reconnected= 28</FONT><br><hr><br><b><i><a href="http://192.168.198.38?ref=5">start refresh</a></i></b> <a href="http://192.168.198.38?inf=1">?</a> <a href="http://192.168.198.38?mmr=1">reset min/max</a><br><hr> <img src="/chart.cvg"/></FONT></pre><br>
        Aus dem langen Text möchte ich nur einen Wert (die 10) herausfiltern. Ich habe es mit einer Function versucht, doch die arbeitet ungenau, weil sich der Wert 10 auch mal von 0 bis 3000 bewegen kann.
        Hier die Function in NodeRed:
        var tmp = msg.payload.substr(142,4);
        msg.payload = tmp;
        return msg;
        Der NodeRed Flow sieht so aus:
        Ich möchte also immer einen Interzahl vom aktuellen Stromverbrauch bekommen und weiß nicht wie viele Stellen der Wert immer hat und wie viele Zeichen davor liegen. Der Output sieht z.B. so aus: " + 3" und steht für 3 Watt.
        Hat jemand einen Lösungsvorschlag?
        Raspi4 8 GB mit Aqara Zigbee USB, iob
        Innogy Smarthome
        Bosch Bridge 2
        HUE Bridge
        OpenWB Wallbox mit EVU Kit
        Google Nest Pro Hub
        HA auf uGreen dxp4800
        • werner2000xW werner2000x
          msg.payload = tmp;
          return msg;
          werner2000x
          @werner2000x Ich denke ich brauch ein Filter welcher mir aus dem String "19.077.938Wh + 10W"
          all Werte nach dem "+" und vor dem "W" nach dem Zahlenwert (hier 12W) liefert.
          Innogy Smarthome
          Bosch Bridge 2
          HUE Bridge
          Google Nest Pro Hub
            werner2000x
            @werner2000x Anbei habe ich meinen Flow mit der Filterung:
            flows.json
            Innogy Smarthome
            Bosch Bridge 2
            HUE Bridge
            Google Nest Pro Hub
              flows.json
              werner2000x
              @werner2000x Jetzt habe ich ein neues Problem. Die UI Ausgabe von Nodered klappt nicht mehr. Ich erhalte nach Aufruf der Seite http://ip:1880/ui den Fehler: Cannot GET /ui
              Ich habe keine Ahnung warum es nicht mehr geht. Gestern klappte es noch. Weiß jemand mehr?
              Innogy Smarthome
              Bosch Bridge 2
              HUE Bridge
              Google Nest Pro Hub
                werner2000x
                @werner2000x Jetzt habe ich die Lösung:
                Wenn ich Nodered über die Übersicht rechts im Fenster im starte klappt das UI.
                Wenn ich Nodered über die Übersicht unten mit node-red.0 starte klappt UI nicht.
                Warum?
                Innogy Smarthome
                Bosch Bridge 2
                HUE Bridge
                Google Nest Pro Hub
                  Warum?
                  werner2000x
                  @werner2000x Seit heute startet NodeRed bei mir nicht mehr. Im Log steht folgendes:
                  Ich habe ioBroker auch schon neu gestartet - ohne Erfolg. Es kommt der Fehler: Die Website ist nicht erreichbar
                  Was könnte man machen, ich habe auch den Raspi neu gebootet, jedoch ohne Erfolg?
                  Innogy Smarthome
                  Bosch Bridge 2
                  HUE Bridge
                  Google Nest Pro Hub
                    werner2000x
                    @werner2000x Jetzt sehe ich gerade, das VIS auch nicht mehr geht. Nodered hat Port 8081 und VIS hat Port 8082.
                    Hier mal ein Portscan:
                    Innogy Smarthome
                    Bosch Bridge 2
                    HUE Bridge
                    Google Nest Pro Hub
                    Thomas BraunT mickymM 2 Antworten Letzte Antwort
                      @werner2000x Konsolentext bitte mit CodeTags </> versehen, keine Screenshots von Text.
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @werner2000x NodeRed hat Port 1880 als Standard. Port 8081 ist Standard für den iobroker. Aus Deinem Screenshot geht hervor, dass NodeRed gar nicht läuft. (exit code 1) Du siehst ja auch dass der Adapter nicht läuft. Warum kann ich allerdings daraus nicht erkennen.
                        • mickymM mickym
                          werner2000x
                          @mickym Ja, stimmt das NodeRed auf Port 1880 läuft. Kann man vielleicht NodeRed neu installieren?
                          Innogy Smarthome
                          Bosch Bridge 2
                          HUE Bridge
                          Google Nest Pro Hub
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @werner2000x Natürlich kannst Du den Adapter neu installieren, in dem Du ihn komplett entfernst - also nicht nur die Instanz sondern in Adapter. Nur ist die Frage, was denn die Ursache ist - nicht dass die Neuinstallation keine Verbesserung bringt.
                            Mach ggf. in folgender Prio vorher:
                            1. Ein Backup des Images Deiner SD-Karte - falls Du so Deine backups machst
                            2. Backup mit backitup
                            3. Deine flows sicherst DU in dem Du die Datei flows.json sicherst (s. Screenshot)
                            • mickymM mickym
                              werner2000x
                              schrieb am zuletzt editiert von werner2000x
                              @mickym
                              Innogy Smarthome
                              Bosch Bridge 2
                              HUE Bridge
                              Google Nest Pro Hub
                                @mickym
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @werner2000x s. mein Screenshot den Pfad. Der node-red Ordner ist unter iobroker-data.
                                • mickymM mickym
                                  werner2000x
                                  @mickym Ja, habe ich gerade auch gesehen. Leider hat die Neuinstallation von NodeRed auf dem Raspi noch nicht geklappt.
                                  Innogy Smarthome
                                  Bosch Bridge 2
                                  HUE Bridge
                                  Google Nest Pro Hub
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @werner2000x said in NodeRed funktioniert nicht:
                                    Wie gesagt, ob die Neuinstallation überhaupt was bringt, ist fraglich - da die Ursache für das Nichtstarten ja u.Umständen noch die gleiche ist. ggf. musst Du halt das System nochmals mit Backup auf einen Stand zurücksetzen wo noch alles gelaufen ist.
                                    • mickymM mickym
                                      werner2000x
                                      @mickym Ja ich habe noch ein aktuelles Backup. Doch beim Schreiben der SD-Card kam der Fehler "Disk Write Error on Sector xxxxxx". Jetzt formatiere ich die SD Card mal. Vielleich ist der Diskfehler schuld an allem?
                                      Innogy Smarthome
                                      Bosch Bridge 2
                                      HUE Bridge
                                      Google Nest Pro Hub
                                      Thomas BraunT mickymM 3 Antworten Letzte Antwort
                                        Nicht formatieren, in die Tonne damit.
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          @werner2000x Ja das kann durchaus sein!!! Vielleicht mal austauschen. ;) Wenn das Backup ein Image ist, dann bekommst Du ggf. auch einen Fehler - da diese Images ja Sektorenweise zurückschreiben. Ist der Sektor aber kaputt - wirst wahrscheinlich nicht mehr wiederherstellen können.
                                          Wenn Du ein logisches Backup hast, dann hilft die Formatierung - aber Du kannst Dich darauf einstellen, dass sich die Fehler häufen werden, insofern ist der Rat mit der Tonne von @Thomas-Braun nicht von der Hand zu weisen. ;)
