  4. JSON Werte in Datenpunkte
    5.6k
18 Beiträge 4 Kommentatoren 5.2k Aufrufe 2 Beobachtet
    @Kevin sagte:
    An was kann das liegen?
    Das Objekt enthält keine Eigenschaft result und ist auch kein Array.
    Versuche es mal so:
    function iter(name, obj) {
       for(let i in obj) {
          if(typeof obj[i] == 'object') iter(name + '.' + i, obj[i]);
          else {
             log(name + '.' + i + ': ' + obj[i]);
             if(existsState(name + '.' + i)) setState(name + '.' + i, obj[i]);
             else createState(name + '.' + i, obj[i]); // type: "mixed"
    function SendRequest(){
        var options = {
            url: 'http://URLVON3DRUCKER'
        request(options, function (error, response, body){
            if (!error) iter('0_userdata.0.3DPrinter', JSON.parse(body));
            else console.error(error);
    schedule('*/5 * * * * *', SendRequest);
    KevinK Offline
    KevinK Offline
    Kevin
    @paul53 said in JSON Werte in Datenpunkte:
        function iter(name, obj) {        for(let i in obj) {        if(typeof obj[i] == 'object') iter(name + '.' + i, obj[i]);        else {        log(name + '.' + i + ': ' + obj[i]);        if(existsState(name + '.' + i) setState(name + '.' + i, obj[i]);        else createState(name + '.' + i, obj[i]); // type: "mixed"        }        }        }        function SendRequest(){        var options = {        url: 'http://URLVON3DRUCKER',        };        request(options, function (error, response, body){        if (!error) iter('0_userdata.0.3DPrinter', JSON.parse(body));        else console.error(error);        });        }        schedule('*/5 * * * * *', SendRequest);
    Danke schon mal für dein Hilfe :)
    Leider hat es nicht ganz funktioniert:
    javascript.0	2020-07-29 22:56:55.543	error	(24214) at process._tickCallback (internal/process/next_tick.js:68:7)
    javascript.0	2020-07-29 22:56:55.543	error	(24214) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    javascript.0	2020-07-29 22:56:55.542	error	(24214) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.0	2020-07-29 22:56:55.542	error	(24214) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17)
    javascript.0	2020-07-29 22:56:55.542	error	(24214) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:1124:17)
    javascript.0	2020-07-29 22:56:55.541	error	(24214) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1533:17)
    javascript.0	2020-07-29 22:56:55.541	error	(24214) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1480:37)
    javascript.0	2020-07-29 22:56:55.541	error	(24214) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:1257:28)
    javascript.0	2020-07-29 22:56:55.540	error	(24214) at Object.createScript (vm.js:277:10)
    javascript.0	2020-07-29 22:56:55.540	error	(24214) at new Script (vm.js:83:7)
    javascript.0	2020-07-29 22:56:55.540	error	(24214) SyntaxError: Unexpected identifier
    javascript.0	2020-07-29 22:56:55.539	error	(24214) ^^^^^^^^
    javascript.0	2020-07-29 22:56:55.539	error	(24214) if(existsState(name + '.' + i) setState(name + '.' + i, obj[i]);
    javascript.0	2020-07-29 22:56:55.539	error	at script.js.common.Skript_1:6
    javascript.0	2020-07-29 22:56:55.539	error	(24214) script.js.common.Skript_1 compile failed:
    • KevinK Kevin
      @Kevin sagte:
      existsState(id) wird anscheinend angemeckert. Welche Version des Javascript-Adapters ?
      KevinK 1 Antwort Letzte Antwort
        @Kevin sagte:
        KevinK Offline
        KevinK Offline
        Kevin
        @paul53 Sollte eigentlich die aktuellste Version sein: 4.6.21
        • KevinK Kevin
          @Kevin
          Sorry, da fehlt eine schließende Klammer vor setState. Habe sie ergänzt.
            @Kevin
            KevinK Offline
            KevinK Offline
            Kevin
            @paul53 Perfekt danke für die schnelle Hilfe. Genau wie ich es mir vorgestellt habe.
            • KevinK Kevin
              @Kevin sagte:
              Dann markiere bitte das Thema in der Überschrift des ersten Beitrags als [gelöst].
                @Kevin sagte:
                KevinK Offline
                KevinK Offline
                Kevin
                @paul53 Ich habe noch eine Frage :)
                Lässt sich verhindern, dass die Abfrage durchgeführt wird, wenn der Drucker ausgeschaltet ist?
                javascript.0	2020-07-31 07:08:11.796	error	(24214) Request error: Error: connect ETIMEDOUT 91.15.159.27:8000
                javascript.0	2020-07-31 07:08:11.795	error	(24214) script.js.common.3D_Printer: {'errno':'ETIMEDOUT','code':'ETIMEDOUT','syscall':'connect','address':'IP','port':8000}
                • KevinK Kevin
                  @Kevin sagte:
                  Wie kann man das feststellen ? Nur ping ?
                    @Kevin sagte:
                    KevinK Offline
                    KevinK Offline
                    Kevin
                    @paul53 Ich könnte es über einen Datenpunkt an der Fritzbox abfragen. Dann wäre Datenpunkt 3Drucker.active auf true sobald er im netzwerk ist
                    • KevinK Kevin
                      @Kevin sagte:
                      Dann mache die Abfrage als erstes in der Funktion SendRequest().
                        if(getState('abc.0.xyz.3Drucker.active').val) {
                          var options = {
