  4. JSON Werte in Datenpunkte
    5.6k
18 Beiträge 4 Kommentatoren 5.2k Aufrufe 2 Beobachtet
  • KevinK Offline
    KevinK Offline
    Kevin
    Ich bin ganz neu in der Welt des ioBrokers und Umsteiger von fhem.
    Ich versuche gerade auch eine Json von meinem 3D Drucker auszulesen und die entsprechenden Datensätze selbst anlegen zulassen. Leider komme ich nicht weiter:
    Das ist der Output von meiner URL von dem 3D Drucker.
    {"status":"P","coords":{"axesHomed":[1,1,1,1,1,1],"wpl":1,"xyz":[160.851,108.581,27.592,45.000,2.000,24.000],"machine":[115.842,58.395,33.482,45.000,2.000,18.110],"extr":[20722.2,0.0,0.0,0.0]},"speeds":{"requested":40.0,"top":40.0},"currentTool":0,"params":{"atxPower":-1,"fanPercent":[0,100,-1,90,100,0,100,0,100,50],"speedFactor":100.0,"extrFactors":[100.0,100.0,100.0,100.0],"babystep":0.000},"seq":2,"sensors":{"probeValue":0,"fanRPM":[-1,-1,-1,-1,-1,-1,-1,-1,-1,-1]},"temps":{"bed":{"current":90.0,"active":90.0,"standby":0.0,"state":2,"heater":0},"current":[90.0,235.4,30.4,31.9,32.7],"state":[2,2,0,0,0],"tools":{"active":[[235.0],[0.0],[0.0],[0.0]],"standby":[[235.0],[0.0],[0.0],[0.0]]},"extra":[]},"time":45569.0,"currentLayer":138,"currentLayerTime":77.1,"extrRaw":[20698.6,0.0,0.0,0.0],"fractionPrinted":88.1,"filePosition":16983003,"firstLayerDuration":749.6,"firstLayerHeight":0.20,"printDuration":24418.6,"warmUpDuration":397.2,"timesLeft":{"file":3431.8,"filament":2551.1,"layer":6133.5}}
    Das ist dazu mein Script:
    var request = require('request');
     Intervall = setInterval(SendRequest,5000);
    function SendRequest(){
        var options = {
            url: 'http://URLVON3DRUCKER',
        request(options, function (error, response, body){
            if (!error){
                CreateDevices(JSON.parse(body));
                console.log(body);
            else{ console.error(error);}
    }//End of Function SendRequest
    function CreateDevices(data){
    if ("undefined" !== typeof  data.result){
        for (i = 0; i < data.result.length; i++) {
                     for (var ObjName in data.result[i].acState) {
                         if (!getObject('0_userdata.0.3DPrinter.' +i +'.acState' +'.' +ObjName)){
                             createState('0_userdata.0.3DPrinter.' +i +'.acState' +'.' +ObjName,data.result[i].acState[ObjName],{type: typeof data.result[i].acState[ObjName], role: ObjName});
                             console.log('ERSTELLT');
                         else{setState('0_userdata.0.3DPrinter.' +i +'.acState' + '.' +ObjName,data.result[i].acState[ObjName],akt=true)}
    else{console.warn('Response in JSON nicht gefunden ! ')}
    }//End of Function CreateDevices
    Dann bekomme ich folgende Meldung in dem Log:
    javascript.0	2020-07-29 20:53:50.291	warn	(24214) script.js.common.3D_Printer: Response in JSON nicht gefunden !
    javascript.0	2020-07-29 20:53:45.258	info	(24214) script.js.common.3D_Printer: {"status":"P","coords":{"axesHomed":[1,1,1,1,1,1],"wpl":1,"xyz":[164.129,107.010,27.592,45.000,2.000,24.000],"machine":[123.229,61.852,33.48
    An was kann das liegen?
    Die Werte einzeln an ioBroker zu schreiben bekomme ich über ein anderes Skript hin. Nur hätte ich gerne alle Werte automatisch angelegt.
    • KevinK Kevin
          var options = {
              if (!error){
                  console.log(body);
      @Kevin sagte:
      Das Objekt enthält keine Eigenschaft result und ist auch kein Array.
      Versuche es mal so:
      function iter(name, obj) {
         for(let i in obj) {
            if(typeof obj[i] == 'object') iter(name + '.' + i, obj[i]);
            else {
               log(name + '.' + i + ': ' + obj[i]);
               if(existsState(name + '.' + i)) setState(name + '.' + i, obj[i]);
               else createState(name + '.' + i, obj[i]); // type: "mixed"
          var options = {
              if (!error) iter('0_userdata.0.3DPrinter', JSON.parse(body));
              else console.error(error);
      schedule('*/5 * * * * *', SendRequest);
      KevinK 1 Antwort Letzte Antwort
        @Kevin sagte:
        Versuche es mal so:
           for(let i in obj) {
              else {
            var options = {
        KevinK Offline
        KevinK Offline
        Kevin
        @paul53 said in JSON Werte in Datenpunkte:
        function iter(name, obj) {        for(let i in obj) {        if(typeof obj[i] == 'object') iter(name + '.' + i, obj[i]);        else {        log(name + '.' + i + ': ' + obj[i]);        if(existsState(name + '.' + i) setState(name + '.' + i, obj[i]);        else createState(name + '.' + i, obj[i]); // type: "mixed"        }        }        }        function SendRequest(){        var options = {        url: 'http://URLVON3DRUCKER',        };        request(options, function (error, response, body){        if (!error) iter('0_userdata.0.3DPrinter', JSON.parse(body));        else console.error(error);        });        }        schedule('*/5 * * * * *', SendRequest);
        Danke schon mal für dein Hilfe :)
        Leider hat es nicht ganz funktioniert:
        javascript.0	2020-07-29 22:56:55.543	error	(24214) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-07-29 22:56:55.543	error	(24214) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-07-29 22:56:55.542	error	(24214) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-07-29 22:56:55.542	error	(24214) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17)
        javascript.0	2020-07-29 22:56:55.542	error	(24214) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:1124:17)
        javascript.0	2020-07-29 22:56:55.541	error	(24214) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1533:17)
        javascript.0	2020-07-29 22:56:55.541	error	(24214) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1480:37)
        javascript.0	2020-07-29 22:56:55.541	error	(24214) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:1257:28)
        javascript.0	2020-07-29 22:56:55.540	error	(24214) at Object.createScript (vm.js:277:10)
        javascript.0	2020-07-29 22:56:55.540	error	(24214) at new Script (vm.js:83:7)
        javascript.0	2020-07-29 22:56:55.540	error	(24214) SyntaxError: Unexpected identifier
        javascript.0	2020-07-29 22:56:55.539	error	(24214) ^^^^^^^^
        javascript.0	2020-07-29 22:56:55.539	error	(24214) if(existsState(name + '.' + i) setState(name + '.' + i, obj[i]);
        javascript.0	2020-07-29 22:56:55.539	error	at script.js.common.Skript_1:6
        javascript.0	2020-07-29 22:56:55.539	error	(24214) script.js.common.Skript_1 compile failed:
        • KevinK Kevin
          @Kevin sagte:
          existsState(id) wird anscheinend angemeckert. Welche Version des Javascript-Adapters ?
            @Kevin sagte:
            KevinK Offline
            KevinK Offline
            Kevin
            @paul53 Sollte eigentlich die aktuellste Version sein: 4.6.21
            • KevinK Kevin
              @Kevin
              Sorry, da fehlt eine schließende Klammer vor setState. Habe sie ergänzt.
                @Kevin
                KevinK Offline
                KevinK Offline
                Kevin
                @paul53 Perfekt danke für die schnelle Hilfe. Genau wie ich es mir vorgestellt habe.
                • KevinK Kevin
                  @Kevin sagte:
                  Dann markiere bitte das Thema in der Überschrift des ersten Beitrags als [gelöst].
                    @Kevin sagte:
                    KevinK Offline
                    KevinK Offline
                    Kevin
                    @paul53 Ich habe noch eine Frage :)
                    Lässt sich verhindern, dass die Abfrage durchgeführt wird, wenn der Drucker ausgeschaltet ist?
                    javascript.0	2020-07-31 07:08:11.796	error	(24214) Request error: Error: connect ETIMEDOUT 91.15.159.27:8000
                    javascript.0	2020-07-31 07:08:11.795	error	(24214) script.js.common.3D_Printer: {'errno':'ETIMEDOUT','code':'ETIMEDOUT','syscall':'connect','address':'IP','port':8000}
                    • KevinK Kevin
                      @Kevin sagte:
                      Wie kann man das feststellen ? Nur ping ?
                        @Kevin sagte:
                        KevinK Offline
                        KevinK Offline
                        Kevin
                        @paul53 Ich könnte es über einen Datenpunkt an der Fritzbox abfragen. Dann wäre Datenpunkt 3Drucker.active auf true sobald er im netzwerk ist
                        • KevinK Kevin
                          @Kevin sagte:
                          Dann mache die Abfrage als erstes in der Funktion SendRequest().
                            if(getState('abc.0.xyz.3Drucker.active').val) {
                              var options = {
