  4. Zigbee Adapter mit CC2531 startet nicht mehr [gelöst]
    6.8k
zigbee adapter cc2531
19 Beiträge 2 Kommentatoren 3.5k Aufrufe 2 Beobachtet
  • mickymM mickym
    Ich habs nun auch mit einem Full Backup vor 2 Wochen versucht. Der Adapter will einfach nicht mehr. Ich weiß mir keinen Rat mehr. Ich weiß nicht, was das soll mit dem disbaling joining new devices - warum weshalb?
    zigbee.0	2020-07-28 16:23:41.250	info	(3682) terminating
    zigbee.0	2020-07-28 16:23:41.160	error	(3682) TypeError: Cannot read property 'newID' of null at Function.create (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:85:54) at Controller.createGroup (/opt/iobr
    zigbee.0	2020-07-28 16:23:41.138	error	(3682) unhandled promise rejection: Cannot read property 'newID' of null
    zigbee.0	2020-07-28 16:23:41.137	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0	2020-07-28 16:23:41.129	error	(3682) TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:200:55) at Funct
    zigbee.0	2020-07-28 16:23:41.126	error	(3682) unhandled promise rejection: Cannot read property 'getEntries' of null
    zigbee.0	2020-07-28 16:23:41.125	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0	2020-07-28 16:23:41.124	error	(3682) Failed to stop zigbee (TypeError: Cannot read property 'permitJoin' of undefined at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:161:39)
    zigbee.0	2020-07-28 16:23:41.107	info	(3682) Zigbee: disabling joining new devices.
    zigbee.0	2020-07-28 16:23:41.102	info	(3682) cleaned everything up...
    zigbee.0	2020-07-28 16:23:41.098	error	(3682) TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:64:55) at Functio
    zigbee.0	2020-07-28 16:23:41.096	error	(3682) unhandled promise rejection: Cannot read property 'getEntries' of null
    zigbee.0	2020-07-28 16:23:41.095	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.MWHome	2020-07-28 16:23:40.539	info	instance system.adapter.mqtt.2 started with pid 3778
    yahka.0	2020-07-28 16:23:37.638	info	(3708) adding Fernsehen Apple TV with UUID: d80be453-7
    arteckA Offline
    arteckA Offline
    arteck
    @mickym
    gesehen
    Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp
    adapter stoppen
    stick abziehen
    wieder rein und
    adapter starten
    • arteckA arteck
      @mickym
      gesehen
      adapter stoppen
      stick abziehen
      wieder rein und
      adapter starten
      mickymM Online
      mickymM Online
      mickym
      @arteck das habe ich inzwischen alles gemacht - ich bekomme den Adapter einfach nicht mehr zum Laufen, habe inzwischen sogar Hardware Reset gemacht.
      Die LED blinkt auch kurz während der Adapter startet aber bekomme keinen Kontakt mehr:
      zigbee.0	2020-07-28 17:06:49.892	error	at processTimers (internal/timers.js:492:7)
      zigbee.0	2020-07-28 17:06:49.892	error	at listOnTimeout (internal/timers.js:549:17)
      zigbee.0	2020-07-28 17:06:49.892	error	at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)
      zigbee.0	2020-07-28 17:06:49.892	error	(3402) Error: AREQ - ZDO - activeEpRsp after 10000ms
      zigbee.0	2020-07-28 17:06:49.890	error	(3402) Failed to start Zigbee
      zigbee.0	2020-07-28 17:06:37.325	info	(3402) Starting Zigbee...
      zigbee.0	2020-07-28 17:06:37.324	info	(3402) Try to reconnect. 1 attempts left
      zigbee.0	2020-07-28 17:06:27.322	error	at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:6:65)
      zigbee.0	2020-07-28 17:06:27.322	error	at Generator.throw (<anonymous>)
      zigbee.0	2020-07-28 17:06:27.322	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:71:23)
      zigbee.0	2020-07-28 17:06:27.322	error	(3402) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
      zigbee.0	2020-07-28 17:06:27.320	error	(3402) Failed to start Zigbee
      zigbee.0	2020-07-28 17:06:19.865	info	(3402) Starting Zigbee...
      Der HW Reset hat wahrscheinlich gar nichts gebracht - wenn der den Adapter gar nicht erreicht.
      • mickymM Online
        mickymM Online
        mickym
        Es kommt auch oft so eine Unhandeled promise rejection vor den zigbee Einträgen - aber wahrscheinlich ist das auch nur ein Folgefehler der nicht vorhandenen Kommunikation.
        zigbee.0	2020-07-28 17:18:41.745	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
        zigbee.0	2020-07-28 17:18:41.745	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
        zigbee.0	2020-07-28 17:18:41.745	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
        zigbee.0	2020-07-28 17:18:41.745	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
        zigbee.0	2020-07-28 17:18:41.745	error	at new Promise (<anonymous>)
        zigbee.0	2020-07-28 17:18:41.745	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
        zigbee.0	2020-07-28 17:18:41.745	error	at Generator.next (<anonymous>)
        zigbee.0	2020-07-28 17:18:41.745	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
        zigbee.0	2020-07-28 17:18:41.745	error	(6755) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
        zigbee.0	2020-07-28 17:18:41.744	error	(6755) Failed to start Zigbee
        zigbee.0	2020-07-28 17:18:41.440	info	(6755) Starting Zigbee...
        zigbee.0	2020-07-28 17:18:41.439	info	(6755) Try to reconnect. 1 attempts left
        zigbee.0	2020-07-28 17:18:31.436	error	at processTimers (internal/timers.js:492:7)
        zigbee.0	2020-07-28 17:18:31.436	error	at listOnTimeout (internal/timers.js:549:17)
        zigbee.0	2020-07-28 17:18:31.436	error	at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)
        zigbee.0	2020-07-28 17:18:31.436	error	(6755) Error: AREQ - ZDO - activeEpRsp after 10000ms
        zigbee.0	2020-07-28 17:18:31.434	error	(6755) Failed to start Zigbee
        zigbee.0	2020-07-28 17:18:19.897	info	(6755) Starting Zigbee...
        zigbee.0	2020-07-28 17:18:19.860	info	(6755) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.3, js-controller: 3.1.6
        host.MWHome	2020-07-28 17:18:17.918	info	instance system.adapter.zigbee.0 started with pid 6755
        host.MWHome	2020-07-28 17:17:47.878	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.MWHome	2020-07-28 17:17:47.877	info	instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
        zigbee.0	2020-07-28 17:17:47.301	info	(6237) Terminated (NO_ERROR): Without reason
        zigbee.0	2020-07-28 17:17:47.300	info	(6237) terminating
        zigbee.0	2020-07-28 17:17:47.271	error	at async Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:196:24)
        zigbee.0	2020-07-28 17:17:47.271	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
        zigbee.0	2020-07-28 17:17:47.271	error	at ZigbeeController.resolveEntity (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:263:53)
        zigbee.0	2020-07-28 17:17:47.271	error	at Controller.createGroup (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:253:32)
        zigbee.0	2020-07-28 17:17:47.271	error	at Function.create (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:85:54)
        zigbee.0	2020-07-28 17:17:47.271	error	(6237) TypeError: Cannot read property 'newID' of null
        zigbee.0	2020-07-28 17:17:47.270	error	(6237) unhandled promise rejection: Cannot read property 'newID' of null
        Unhandled	2020-07-28 17:17:47.269	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        zigbee.0	2020-07-28 17:17:47.247	error	at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8270:22)
        zigbee.0	2020-07-28 17:17:47.247	error	at Zigbee.emit (events.js:315:20)
        zigbee.0	2020-07-28 17:17:47.247	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:320:41)
        zigbee.0	2020-07-28 17:17:47.247	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:303:20)
        zigbee.0	2020-07-28 17:17:47.247	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:186:42)
        zigbee.0	2020-07-28 17:17:47.247	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:123:43)
        zigbee.0	2020-07-28 17:17:47.247	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:200:49)
        zigbee.0	2020-07-28 17:17:47.247	error	at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:223:31)
        zigbee.0	2020-07-28 17:17:47.247	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:16)
        zigbee.0	2020-07-28 17:17:47.247	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:200:55)
        zigbee.0	2020-07-28 17:17:47.247	error	(6237) TypeError: Cannot read property 'getEntries' of null
        zigbee.0	2020-07-28 17:17:47.244	error	(6237) unhandled promise rejection: Cannot read property 'getEntries' of null
        Unhandled	2020-07-28 17:17:47.244	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        zigbee.0	2020-07-28 17:17:47.242	error	at new Promise (<anonymous>))
        zigbee.0	2020-07-28 17:17:47.242	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:8:71
        zigbee.0	2020-07-28 17:17:47.242	error	at Generator.next (<anonymous>)
        zigbee.0	2020-07-28 17:17:47.242	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:188:24)
        zigbee.0	2020-07-28 17:17:47.242	error	at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:144:16)
        zigbee.0	2020-07-28 17:17:47.242	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:4:12)
        zigbee.0	2020-07-28 17:17:47.242	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:161:39)
        zigbee.0	2020-07-28 17:17:47.242	error	(6237) Failed to stop zigbee (TypeError: Cannot read property 'permitJoin' of undefined
        zigbee.0	2020-07-28 17:17:47.240	info	(6237) Zigbee: disabling joining new devices.
        zigbee.0	2020-07-28 17:17:47.236	info	(6237) cleaned everything up...
        zigbee.0	2020-07-28 17:17:47.235	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
        zigbee.0	2020-07-28 17:17:47.235	error	at StatesController.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:142:14)
        zigbee.0	2020-07-28 17:17:47.235	error	at StatesController.emit (events.js:315:20)
        zigbee.0	2020-07-28 17:17:47.235	error	at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:196:48)
        zigbee.0	2020-07-28 17:17:47.235	error	at ZigbeeController.resolveEntity (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:262:45)
        zigbee.0	2020-07-28 17:17:47.235	error	at Controller.getGroupByID (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:241:32)
        zigbee.0	2020-07-28 17:17:47.235	error	at Function.byGroupID (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:72:15)
        zigbee.0	2020-07-28 17:17:47.235	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:64:55)
        zigbee.0	2020-07-28 17:17:47.235	error	(6237) TypeError: Cannot read property 'getEntries' of null
        zigbee.0	2020-07-28 17:17:47.234	error	(6237) unhandled promise rejection: Cannot read property 'getEntries' of null
        Unhandled	2020-07-28 17:17:47.233	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        • mickymM Online
          mickymM Online
          mickym
          Ich habe nun den Stick mal 15 Minuten raus gezogen - um thermische Probleme auszuschließen. Er will einfach nicht mehr. Kann man denn noch irgendwas überprüfen oder hat der Stick plötzlich seinen Geist aufgegeben?
          Das OS kennt das Teil aber anscheinend:
           ls -l /dev/serial/by-id
          insgesamt 0
          lrwxrwxrwx 1 root root 13 Jul 28 17:41 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B000BE86CD0-if00 -> ../../ttyACM0
          • mickymM mickym
            insgesamt 0
            arteckA Offline
            arteckA Offline
            arteck
            @mickym die Meldungs sagt das das serialport belegt ist.. wo hast du den Stecken (pi,nuc) und ist da nochwas im USB drin ?
            • arteckA arteck
              mickymM Online
              mickymM Online
              mickym
              @arteck Ich habe noch USB Sticks drin - aber nichts was serielle Kommunikation ist .
              Es kommt immer das - nach frischen Neustart
              zigbee.0	2020-07-29 12:25:46.445	info	(2119) Terminated (NO_ERROR): Without reason
              zigbee.0	2020-07-29 12:25:46.443	info	(2119) terminating
              zigbee.0	2020-07-29 12:25:46.390	error	(2119) TypeError: Cannot read property 'newID' of null at Function.create (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:85:54) at Controller.createGroup (/opt/iobr
              zigbee.0	2020-07-29 12:25:46.389	error	(2119) unhandled promise rejection: Cannot read property 'newID' of null
              zigbee.0	2020-07-29 12:25:46.389	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              zigbee.0	2020-07-29 12:25:46.380	error	(2119) Failed to stop zigbee (TypeError: Cannot read property 'permitJoin' of undefined at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:161:39)
              zigbee.0	2020-07-29 12:25:46.377	info	(2119) Zigbee: disabling joining new devices.
              zigbee.0	2020-07-29 12:25:46.376	error	(2119) TypeError: Cannot read property 'mapped' of undefined at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:198:36) at processTicksAndRejections (internal/proce
              zigbee.0	2020-07-29 12:25:46.375	error	(2119) unhandled promise rejection: Cannot read property 'mapped' of undefined
              zigbee.0	2020-07-29 12:25:46.374	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              zigbee.0	2020-07-29 12:25:46.374	error	(2119) TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:64:55) at Functio
              zigbee.0	2020-07-29 12:25:46.373	error	(2119) unhandled promise rejection: Cannot read property 'getEntries' of null
              zigbee.0	2020-07-29 12:25:46.372	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              zigbee.0	2020-07-29 12:25:46.370	info	(2119) cleaned everything up...
              zigbee.0	2020-07-29 12:25:46.368	error	(2119) TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:200:55) at Funct
              zigbee.0	2020-07-29 12:25:46.367	error	(2119) unhandled promise rejection: Cannot read property 'getEntries' of null
              zigbee.0	2020-07-29 12:25:46.366	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              Wie gesagt - das ist nach komplettem Neustart und LED auf Stick ist grün.
              • mickymM mickym
                arteckA Offline
                arteckA Offline
                arteck
                @mickym
                installiere mal die GIT version über die Katze
                dann steck mal alles ab reboote neu und steck nur den stick rein
                • arteckA arteck
                  @mickym
                  mickymM Online
                  mickymM Online
                  mickym
                  @arteck
                  Die Installation lief ohne Fehler durch
                  $ ./iobroker url "https://github.com/ioBroker/ioBroker.zigbee/tarball/master" zigbee
                  install https://github.com/ioBroker/ioBroker.zigbee/tarball/master
                  NPM version: 6.14.6npm install https://github.com/ioBroker/ioBroker.zigbee/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
                  In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);        ^~~~~~~~~~~~~
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);        ^~~~~~~~~~~~~~~
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);        ^~~~~~~~~~~~~~
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);        ^~~~~~~~~~~~~~
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);        ^~~~~~~~~~~~
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);        ^~~~~~~~~~~~
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);        ^~~~~~~~~~~~~~~~~~~~
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);        ^~~~~~~~~~~~~~
                  ../src/serialport.cpp: At global scope:../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {                            ^
                  ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {                              ^
                  In file included from ../../../nan/nan.h:56,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(serialport, init); ^~~~~~~~~~~
                  In file included from ../src/serialport.h:6,                 from ../src/serialport_unix.cpp:2:../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
                  ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);                                                            ^~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);     ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                  ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);                                                            ^~~~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);     ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                  In file included from ../src/poller.cpp:1:../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
                  upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_magnet_aq2.png img/sensor_magnet_aq2.png image/png
                  upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/osram_a60_rgbw.png img/osram_a60_rgbw.png image/png
                  upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/innr3.png img/innr3.png image/png
                  upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_remote_control1.png img/ikea_remote_control1.png image/png
                  upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_bulb_E27_clear.png img/ikea_bulb_E27_clear.png image/png
                  upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hive.png img/hive.png image/png
                  upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gira_4_buttons.png img/gira_4_buttons.png image/png
                  upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/essentials_premium.png img/essentials_premium.png image/png
                  upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_ln2.png img/ctrl_ln2.png image/png
                  upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/battery_p.png img/battery_p.png image/png
                  upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/SGMHM-I1.png img/SGMHM-I1.png image/png
                  upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Ikea_fyrtur.png img/Ikea_fyrtur.png image/png
                  upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
                  upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
                  upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
                  upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
                  upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
                  upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
                  upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
                  upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
                  upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
                  Update "system.adapter.zigbee.0"
                  process exited with code 0
                  Aber jetzt startet der Adapter gar nicht mehr (rot) statt gelb vorher.
                  host.MWHome	2020-07-29 12:43:12.051	info	Restart adapter system.adapter.zigbee.0 because enabled
                  host.MWHome	2020-07-29 12:43:12.050	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  host.MWHome	2020-07-29 12:43:12.050	error	Caught by controller[0]: }
                  host.MWHome	2020-07-29 12:43:12.050	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.zigbee/main.js' ]
                  host.MWHome	2020-07-29 12:43:12.050	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                  host.MWHome	2020-07-29 12:43:12.049	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12) {
                  host.MWHome	2020-07-29 12:43:12.049	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:878:14)
                  host.MWHome	2020-07-29 12:43:12.049	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:985:32)
                  host.MWHome	2020-07-29 12:43:12.049	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
                  host.MWHome	2020-07-29 12:43:12.048	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1137:30)
                  host.MWHome	2020-07-29 12:43:12.048	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/main.js:8:15)
                  host.MWHome	2020-07-29 12:43:12.048	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
                  host.MWHome	2020-07-29 12:43:12.047	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1025:19)
                  host.MWHome	2020-07-29 12:43:12.047	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:841:27)
                  host.MWHome	2020-07-29 12:43:12.047	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
                  host.MWHome	2020-07-29 12:43:12.046	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                  host.MWHome	2020-07-29 12:43:12.046	error	Caught by controller[0]: Require stack:
                  host.MWHome	2020-07-29 12:43:12.045	error	Caught by controller[0]: Error: Cannot find module 'zigbee-herdsman/node_modules/debug'
                  host.MWHome	2020-07-29 12:43:12.045	error	Caught by controller[0]: ^
                  host.MWHome	2020-07-29 12:43:12.044	error	Caught by controller[0]: throw err;
                  host.MWHome	2020-07-29 12:43:12.044	error	Caught by controller[0]: internal/modules/cjs/loader.js:968
                  host.MWHome	2020-07-29 12:43:11.826	info	instance system.adapter.zigbee.0 started with pid 2373
                  host.MWHome	2020-07-29 12:43:05.884	info	Restart adapter system.adapter.zigbee.0 because enabled
                  host.MWHome	2020-07-29 12:43:05.884	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  host.MWHome	2020-07-29 12:43:05.884	error	Caught by controller[0]: }
                  host.MWHome	2020-07-29 12:43:05.883	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.zigbee/main.js' ]
                  host.MWHome	2020-07-29 12:43:05.883	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                  host.MWHome	2020-07-29 12:43:05.883	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12) {
                  host.MWHome	2020-07-29 12:43:05.882	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:878:14)
                  host.MWHome	2020-07-29 12:43:05.882	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:985:32)
                  host.MWHome	2020-07-29 12:43:05.881	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
                  host.MWHome	2020-07-29 12:43:05.881	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1137:30)
                  host.MWHome	2020-07-29 12:43:05.881	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/main.js:8:15)
                  host.MWHome	2020-07-29 12:43:05.881	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
                  host.MWHome	2020-07-29 12:43:05.880	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1025:19)
                  host.MWHome	2020-07-29 12:43:05.880	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:841:27)
                  host.MWHome	2020-07-29 12:43:05.880	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
                  host.MWHome	2020-07-29 12:43:05.880	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                  host.MWHome	2020-07-29 12:43:05.879	error	Caught by controller[0]: Require stack:
                  host.MWHome	2020-07-29 12:43:05.879	error	Caught by controller[0]: Error: Cannot find module 'zigbee-herdsman/node_modules/debug'
                  host.MWHome	2020-07-29 12:43:05.878	error	Caught by controller[0]: ^
                  host.MWHome	2020-07-29 12:43:05.878	error	Caught by controller[0]: throw err;
                  host.MWHome	2020-07-29 12:43:05.877	error	Caught by controller[0]: internal/modules/cjs/loader.js:968
                  host.MWHome	2020-07-29 12:43:05.648	info	instance system.adapter.zigbee.0 started with pid 2354
                  sql.0	2020-07-29 12:42:47.277	error	(1833) Error: connect ECONNREFUSED 127.0.0.1:3306
                  host.MWHome	2020-07-29 12:42:35.628	info	Restart adapter system.adapter.zigbee.0 because enabled
                  host.MWHome	2020-07-29 12:42:35.627	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  host.MWHome	2020-07-29 12:42:35.627	error	Caught by controller[0]: }
                  host.MWHome	2020-07-29 12:42:35.626	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.zigbee/main.js' ]
                  host.MWHome	2020-07-29 12:42:35.626	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                  host.MWHome	2020-07-29 12:42:35.625	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12) {
                  host.MWHome	2020-07-29 12:42:35.625	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:878:14)
                  host.MWHome	2020-07-29 12:42:35.624	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:985:32)
                  host.MWHome	2020-07-29 12:42:35.624	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
                  host.MWHome	2020-07-29 12:42:35.623	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1137:30)
                  host.MWHome	2020-07-29 12:42:35.623	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/main.js:8:15)
                  host.MWHome	2020-07-29 12:42:35.621	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
                  host.MWHome	2020-07-29 12:42:35.621	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1025:19)
                  host.MWHome	2020-07-29 12:42:35.620	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:841:27)
                  host.MWHome	2020-07-29 12:42:35.620	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
                  host.MWHome	2020-07-29 12:42:35.619	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                  host.MWHome	2020-07-29 12:42:35.619	error	Caught by controller[0]: Require stack:
                  host.MWHome	2020-07-29 12:42:35.618	error	Caught by controller[0]: Error: Cannot find module 'zigbee-herdsman/node_modules/debug'
                  host.MWHome	2020-07-29 12:42:35.618	error	Caught by controller[0]: ^
                  host.MWHome	2020-07-29 12:42:35.617	error	Caught by controller[0]: throw err;
                  host.MWHome	2020-07-29 12:42:35.615	error	Caught by controller[0]: internal/modules/cjs/loader.js:968
                  host.MWHome	2020-07-29 12:42:35.341	info	instance system.adapter.zigbee.0 started with pid 2214
                  Der sql Fehler kommt - da nun der USB Stick fehlt.
                  Ein Unterschied gibt es noch - dass nun auch die LED nach einer gewissen Zeit ausgeht auf dem Stick - das war vorher nicht. Wenn ich den Stick zwar dann wieder raus und reinstecke - geht sie wieder für eine gewisse Zeit an.
                  • mickymM Online
                    mickymM Online
                    mickym
                    Das System lief jetzt Monate stabil - bis dann gestern plötzlich um 13:28 diese unhandled promise rejection kam. Ich habe eigentlich nur noch den Verdacht, dass der Stick ab dieser Minute irgendwie Geist aufgegeben hat - weil ich nun wirklich schon viel versucht habe und auch Softwarestände von vor 4 Wochen - als alles noch stabil lief - und damit meine ich Images und nicht einzelne Softwarestände.
                    • mickymM mickym
                      Ich habe heute ein Firmware Update einer IKEA Lampe gemacht und das hat auch gut funktioniert. Ca. 1-2 Std. später wirft der Adapter aber nun Fehler und ich kann auch kein Zigbee Gerät mehr zugreifen. Das war aber auch die einzige Änderung!!! (siehe LOG Update der Firmware 11:45 und Fehler plötzlich seit 13:28)
                      2020-07-28 10:56:51.655 - info: info.0 (1274) Popup news was read...
                      2020-07-28 11:06:47.605 - info: host.MWHome Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                      2020-07-28 11:23:15.447 - info: zigbee.0 (2279) Start firmware update for 0xccccccfffe021ec0
                      2020-07-28 11:23:25.592 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 0%
                      2020-07-28 11:23:55.672 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 2.32%, +- 27 minutes remaining
                      2020-07-28 11:24:25.926 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 4.94%, +- 22 minutes remaining
                      2020-07-28 11:24:56.031 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 7.28%, +- 21 minutes remaining
                      2020-07-28 11:25:26.151 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 9.89%, +- 20 minutes remaining
                      2020-07-28 11:25:56.226 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 12.23%, +- 19 minutes remaining
                      2020-07-28 11:26:26.336 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 14.31%, +- 19 minutes remaining
                      2020-07-28 11:26:51.625 - info: info.0 (1274) Popup news was read...
                      2020-07-28 11:26:56.423 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 16.91%, +- 18 minutes remaining
                      2020-07-28 11:27:26.426 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 19.08%, +- 18 minutes remaining
                      2020-07-28 11:27:56.581 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 21.28%, +- 17 minutes remaining
                      2020-07-28 11:28:26.845 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 23.65%, +- 17 minutes remaining
                      2020-07-28 11:28:57.041 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 26.27%, +- 16 minutes remaining
                      2020-07-28 11:29:27.334 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 28.9%, +- 15 minutes remaining
                      2020-07-28 11:29:57.574 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 31.53%, +- 15 minutes remaining
                      2020-07-28 11:30:27.784 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 34.15%, +- 14 minutes remaining
                      2020-07-28 11:30:57.910 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 36.35%, +- 13 minutes remaining
                      2020-07-28 11:31:28.029 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 38.96%, +- 13 minutes remaining
                      2020-07-28 11:31:58.241 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 41.58%, +- 12 minutes remaining
                      2020-07-28 11:32:28.471 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 44.21%, +- 12 minutes remaining
                      2020-07-28 11:32:58.482 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 46.81%, +- 11 minutes remaining
                      2020-07-28 11:33:28.590 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 49.42%, +- 10 minutes remaining
                      2020-07-28 11:33:58.831 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 52.04%, +- 10 minutes remaining
                      2020-07-28 11:34:28.842 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 54.65%, +- 9 minutes remaining
                      2020-07-28 11:34:59.054 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 57.27%, +- 9 minutes remaining
                      2020-07-28 11:35:34.245 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 59.38%, +- 8 minutes remaining
                      2020-07-28 11:36:04.346 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 62%, +- 8 minutes remaining
                      2020-07-28 11:36:34.503 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 64.08%, +- 7 minutes remaining
                      2020-07-28 11:37:04.763 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 66.71%, +- 7 minutes remaining
                      2020-07-28 11:37:34.809 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 69.05%, +- 6 minutes remaining
                      2020-07-28 11:38:04.892 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 71.65%, +- 6 minutes remaining
                      2020-07-28 11:38:35.172 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 74.26%, +- 5 minutes remaining
                      2020-07-28 11:39:05.192 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 76.72%, +- 5 minutes remaining
                      2020-07-28 11:39:35.292 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 79.32%, +- 4 minutes remaining
                      2020-07-28 11:40:05.403 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 81.9%, +- 4 minutes remaining
                      2020-07-28 11:40:35.488 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 84.5%, +- 3 minutes remaining
                      2020-07-28 11:41:05.707 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 87.13%, +- 3 minutes remaining
                      2020-07-28 11:41:35.915 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 89.73%, +- 2 minutes remaining
                      2020-07-28 11:42:06.127 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 92.36%, +- 2 minutes remaining
                      2020-07-28 11:42:36.365 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 94.99%, +- 1 minutes remaining
                      2020-07-28 11:43:06.569 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 97.62%, +- 0 minutes remaining
                      2020-07-28 11:43:36.799 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 99.81%, +- 0 minutes remaining
                      2020-07-28 11:45:09.052 - info: zigbee.0 (2279) Update of '0xccccccfffe021ec0' at 100%
                      2020-07-28 11:45:15.601 - info: zigbee.0 (2279) Finished update of '0xccccccfffe021ec0', from '{"softwareBuildID":"2.0.023","dateCode":"20190407"}' to '{"softwareBuildID":"2.0.029","dateCode":"20200312"}'
                      2020-07-28 11:56:51.640 - info: info.0 (1274) Popup news was read...
                      2020-07-28 12:26:51.681 - info: info.0 (1274) Popup news was read...
                      2020-07-28 12:56:51.620 - info: info.0 (1274) Popup news was read...
                      2020-07-28 13:26:51.652 - info: info.0 (1274) Popup news was read...
                      2020-07-28 13:28:01.364 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2020-07-28 13:28:01.365 - error: zigbee.0 (2279) unhandled promise rejection: AREQ - AF - dataConfirm after 3000ms
                      2020-07-28 13:28:01.366 - error: zigbee.0 (2279) Error: AREQ - AF - dataConfirm after 3000ms
                      2020-07-28 13:28:01.367 - info: zigbee.0 (2279) cleaned everything up...
                      2020-07-28 13:28:01.370 - info: zigbee.0 (2279) Zigbee: disabling joining new devices.
                      2020-07-28 13:28:01.874 - info: zigbee.0 (2279) terminating
                      2020-07-28 13:28:01.875 - info: zigbee.0 (2279) Terminated (NO_ERROR): Without reason
                      2020-07-28 13:28:07.509 - info: host.MWHome instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
                      2020-07-28 13:28:07.521 - info: host.MWHome Restart adapter system.adapter.zigbee.0 because enabled
                      2020-07-28 13:28:37.600 - info: host.MWHome instance system.adapter.zigbee.0 started with pid 28509
                      2020-07-28 13:28:39.324 - info: zigbee.0 (28509) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.3, js-controller: 3.1.6
                      2020-07-28 13:28:39.363 - info: zigbee.0 (28509) Starting Zigbee...
                      2020-07-28 13:28:51.770 - error: zigbee.0 (28509) Failed to start Zigbee
                      2020-07-28 13:28:51.772 - error: zigbee.0 (28509) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
                      at ZStackAdapter. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:71:23)
                      at Generator.throw ()
                      2020-07-28 13:29:01.774 - info: zigbee.0 (28509) Try to reconnect. 1 attempts left
                      2020-07-28 13:29:01.776 - info: zigbee.0 (28509) Starting Zigbee...
                      2020-07-28 13:29:07.160 - error: zigbee.0 (28509) Failed to start Zigbee
                      2020-07-28 13:29:07.163 - error: zigbee.0 (28509) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                      at Znp. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
                      at Generator.next ()
                      at new Promise ()
                      at SerialPort. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
                      2020-07-28 13:56:44.701 - info: host.MWHome stopInstance system.adapter.zigbee.0 (force=false, process=true)
                      2020-07-28 13:56:44.713 - info: host.MWHome stopInstance system.adapter.zigbee.0 send kill signal
                      2020-07-28 13:56:44.721 - info: zigbee.0 (28509) Got terminate signal TERMINATE_YOURSELF
                      2020-07-28 13:56:44.723 - info: zigbee.0 (28509) cleaned everything up...
                      2020-07-28 13:56:44.729 - info: zigbee.0 (28509) Zigbee: disabling joining new devices.
                      2020-07-28 13:56:44.731 - error: zigbee.0 (28509) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
                      at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:15)
                      at Controller. (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:178:49)
                      at new Promise ()
                      at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:174:16)
                      at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:307:33)
                      at runMicrotasks ())
                      2020-07-28 13:56:44.732 - info: zigbee.0 (28509) terminating
                      2020-07-28 13:56:44.733 - info: zigbee.0 (28509) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2020-07-28 13:56:44.734 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2020-07-28 13:56:44.734 - error: zigbee.0 (28509) unhandled promise rejection: Cannot read property 'getEntries' of null
                      2020-07-28 13:56:44.737 - error: zigbee.0 (28509) TypeError: Cannot read property 'getEntries' of null
                      2020-07-28 13:56:45.719 - info: host.MWHome stopInstance system.adapter.zigbee.0 killing pid 28509
                      2020-07-28 13:56:47.761 - info: host.MWHome instance system.adapter.zigbee.0 started with pid 1863
                      2020-07-28 13:56:49.145 - error: zigbee.0 (1863) zigbee.0 already running
                      2020-07-28 13:56:49.148 - warn: zigbee.0 (1863) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                      2020-07-28 13:56:50.088 - error: host.MWHome instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                      2020-07-28 13:56:50.089 - info: host.MWHome Restart adapter system.adapter.zigbee.0 because enabled
                      2020-07-28 13:56:50.285 - error: host.MWHome instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                      2020-07-28 13:56:50.286 - info: host.MWHome Do not restart adapter system.adapter.zigbee.0 because desired by instance
                      Habe Maschine neu gestartet - und auch den Stick mal abgeogen (2531) - aber das hilft alles nichts. HILFE!
                      mickymM Online
                      mickymM Online
                      mickym
                      Ich habe jetzt alles wieder angesteckt und wieder ein Image vom 12.7. eingespielt.
                      Der Adapter startet nun wieder mit "gelb" - der Stick bleibt grün.
                      Für mich ist der Schlüssel oder Ursache wohl diese Unhandled promise rejection :(
                      zigbee.0	2020-07-29 13:50:28.988	error	(2576) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/zn
                      zigbee.0	2020-07-29 13:50:28.987	error	(2576) Failed to start Zigbee
                      zigbee.0	2020-07-29 13:50:28.691	info	(2576) Starting Zigbee...
                      zigbee.0	2020-07-29 13:50:28.690	info	(2576) Try to reconnect. 1 attempts left
                      zigbee.0	2020-07-29 13:50:18.689	error	(2576) Error: AREQ - ZDO - activeEpRsp after 10000ms at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24) at listOnTimeout (internal/timers.js:549:17
                      zigbee.0	2020-07-29 13:50:18.687	error	(2576) Failed to start Zigbee
                      zigbee.0	2020-07-29 13:50:07.200	info	(2576) Starting Zigbee...
                      zigbee.0	2020-07-29 13:50:07.158	info	(2576) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.2, js-controller: 3.1.6
                      host.MWHome	2020-07-29 13:50:04.680	info	instance system.adapter.zigbee.0 started with pid 2576
                      ping.0	2020-07-29 13:49:41.241	info	(2451) starting. Version 1.4.7 in /opt/iobroker/node_modules/iobroker.ping, node: v12.18.2, js-controller: 3.1.6
                      mqtt.2	2020-07-29 13:49:41.047	info	(2421) All states published
                      backitup.0	2020-07-29 13:49:39.513	info	(2401) [iobroker] backup was activated at 02:00 every 1 day(s)
                      backitup.0	2020-07-29 13:49:39.313	info	(2401) starting. Version 1.5.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.18.2, js-controller: 3.1.6
                      mqtt.2	2020-07-29 13:49:38.460	info	(2421) Subscribe on: "iobroker/#"
                      mqtt.2	2020-07-29 13:49:38.457	info	(2421) Connected to localhost
                      mqtt.2	2020-07-29 13:49:38.333	info	(2421) Try to connect to mqtt://mwmqtt:*******************@localhost:1883?clientId=mqttClientIobrokerPublishOnly
                      host.MWHome	2020-07-29 13:49:37.920	info	instance system.adapter.ping.0 started with pid 2451
                      mqtt.2	2020-07-29 13:49:36.741	info	(2421) starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v12.18.2, js-controller: 3.1.6
                      host.MWHome	2020-07-29 13:49:35.379	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                      host.MWHome	2020-07-29 13:49:34.665	info	Restart adapter system.adapter.zigbee.0 because enabled
                      host.MWHome	2020-07-29 13:49:34.664	info	instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
                      zigbee.0	2020-07-29 13:49:34.082	info	(2351) Terminated (NO_ERROR): Without reason
                      zigbee.0	2020-07-29 13:49:34.076	info	(2351) terminating
                      zigbee.0	2020-07-29 13:49:33.970	error	at async Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:196:24)
                      zigbee.0	2020-07-29 13:49:33.970	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                      zigbee.0	2020-07-29 13:49:33.970	error	at ZigbeeController.resolveEntity (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:263:53)
                      zigbee.0	2020-07-29 13:49:33.970	error	at Controller.createGroup (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:253:32)
                      zigbee.0	2020-07-29 13:49:33.970	error	at Function.create (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:85:54)
                      zigbee.0	2020-07-29 13:49:33.970	error	(2351) TypeError: Cannot read property 'newID' of null
                      zigbee.0	2020-07-29 13:49:33.969	error	(2351) unhandled promise rejection: Cannot read property 'newID' of null
                      Unhandled	2020-07-29 13:49:33.969	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      zigbee.0	2020-07-29 13:49:33.965	error	at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8270:22)
                      zigbee.0	2020-07-29 13:49:33.965	error	at Zigbee.emit (events.js:315:20)
                      zigbee.0	2020-07-29 13:49:33.965	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:320:41)
                      zigbee.0	2020-07-29 13:49:33.965	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:303:20)
                      zigbee.0	2020-07-29 13:49:33.965	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:186:42)
                      zigbee.0	2020-07-29 13:49:33.965	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:123:43)
                      zigbee.0	2020-07-29 13:49:33.965	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:200:49)
                      zigbee.0	2020-07-29 13:49:33.965	error	at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:223:31)
                      zigbee.0	2020-07-29 13:49:33.965	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:16)
                      zigbee.0	2020-07-29 13:49:33.965	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:200:55)
                      zigbee.0	2020-07-29 13:49:33.965	error	(2351) TypeError: Cannot read property 'getEntries' of null
                      zigbee.0	2020-07-29 13:49:33.962	error	(2351) unhandled promise rejection: Cannot read property 'getEntries' of null
                      Unhandled	2020-07-29 13:49:33.961	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      zigbee.0	2020-07-29 13:49:33.959	error	at new Promise (<anonymous>))
                      zigbee.0	2020-07-29 13:49:33.959	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:8:71
                      zigbee.0	2020-07-29 13:49:33.959	error	at Generator.next (<anonymous>)
                      zigbee.0	2020-07-29 13:49:33.959	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:188:24)
                      zigbee.0	2020-07-29 13:49:33.959	error	at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:144:16)
                      zigbee.0	2020-07-29 13:49:33.959	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:4:12)
                      zigbee.0	2020-07-29 13:49:33.959	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:161:39)
                      zigbee.0	2020-07-29 13:49:33.959	error	(2351) Failed to stop zigbee (TypeError: Cannot read property 'permitJoin' of undefined
                      zigbee.0	2020-07-29 13:49:33.956	info	(2351) Zigbee: disabling joining new devices.
                      zigbee.0	2020-07-29 13:49:33.946	info	(2351) cleaned everything up...
                      zigbee.0	2020-07-29 13:49:33.945	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                      zigbee.0	2020-07-29 13:49:33.945	error	at StatesController.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:142:14)
                      zigbee.0	2020-07-29 13:49:33.945	error	at StatesController.emit (events.js:315:20)
                      zigbee.0	2020-07-29 13:49:33.945	error	at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:196:48)
                      zigbee.0	2020-07-29 13:49:33.945	error	at ZigbeeController.resolveEntity (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:262:45)
                      zigbee.0	2020-07-29 13:49:33.945	error	at Controller.getGroupByID (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:241:32)
                      zigbee.0	2020-07-29 13:49:33.945	error	at Function.byGroupID (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:72:15)
                      zigbee.0	2020-07-29 13:49:33.945	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:64:55)
                      zigbee.0	2020-07-29 13:49:33.945	error	(2351) TypeError: Cannot read property 'getEntries' of null
                      zigbee.0	2020-07-29 13:49:33.943	error	(2351) unhandled promise rejection: Cannot read property 'getEntries' of null
                      Unhandled	2020-07-29 13:49:33.942	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      • mickymM Online
                        mickymM Online
                        mickym
                        Ich habe jetzt mal den ConBee II Stick bestellt - der soll am Freitag kommen. Ich würde den Adapter gerne weiter benutzen - auch wenn ich dann wohl wieder alles neu pairen muss, um nicht die deConz Software installieren zu müssen - auch wenn die ConBee Unterstützung noch im experimentellen Stadium ist.
                        Wäre natürlich trotzdem interessant, ob man irgendwie prüfen könnte ob der C2531 nun wirklich Schrott ist oder nicht.
                        • mickymM mickym
                          arteckA Offline
                          arteckA Offline
                          arteck
                          @mickym sagte in Zigbee Adapter mit C2531 startet PLÖTZLICH nicht mehr:
                          nein die wird nur geschmissen weil der rest nicht da ist..
                          dann wirds wohl den Stick zerlegt haben.. wobei ein conbee.. musst du wissen..
                          https://forum.iobroker.net/topic/30609/cc2538-cc2592-pa-zigbee-stick-platine?page=1
                          • arteckA arteck
                            mickymM Online
                            mickymM Online
                            mickym
                            @arteck So habe heute schon den Conbee II bekommen und muss sagen ich bin erst mal von dem Zigbee- Adapter begeistert.
                            Mal eine wirklich positive Rückmeldung. Das war wirklich fast Plug and Play. Habe nur den Typ des Sticks geändert und die Maschine neu gestartet und alle Objekte werden nun weiter beschrieben - ich muss keine Logik ändern und vor allen Dingen - ich musste noch nichts neu pairen - bis jetzt. Adapter auch sofort grün!!!! Also war wirklich der CC2531 einfach gestorben. :(
                            Die Netzwerkkarte schaut zwar noch sehr komisch aus und auch Link Quality ist teilweise gering (wesentlich schlechter als beim CC2531)- aber funktionell - habe ich vorerst nur bemerkt, dass die Firmwareupdates wohl mit dem Conbee keine gute Idee sind, das bringt den Adapter zum Absturz. Aber das ist ja nicht täglicher Betrieb. Pairen habe ich auch noch nicht getestet - da noch nicht notwendig.
                            Also hier mal ein Danke an die Entwickler.
                            Ggf. kann ich ja noch auf den anderen Stick ausweichen - aber finde es ja erst mal gut dass ihr den ConBee II nun unterstützt
                            • mickymM Online
                              mickymM Online
                              mickym
                              Es gibt einige Fehler im LOG - allerdings weiß ich noch nicht inwieweit sich das auswirkt.
                              • mickymM mickym
                                at new Promise ()
                                at new Promise ()
                                mickymM Online
                                mickymM Online
                                mickym
                                Ich habe nun wieder einen neuen CC2531 und alles schaut erst mal wieder perfekt aus. :)
