  4. BLE Adapter
BLE Adapter
bluetooth setcap fehler gelb s
57 Beiträge 12 Kommentatoren 12.4k Aufrufe 10 Beobachtet
  • chris12205C Offline
    chris12205C Offline
    chris12205
    schrieb am zuletzt editiert von chris12205
    bitte schön
    ble.0 2020-03-17 08:32:43.173 info (9339) starting scan for services ["fe95"]
    ble.0 2020-03-17 08:32:42.973 info (9339) monitored services: fe95
    ble.0 2020-03-17 08:32:42.972 info (9339) enabled plugins: Xiaomi, _default
    ble.0 2020-03-17 08:32:42.970 info (9339) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
    ble.0 2020-03-17 05:18:38.038 debug (1996) system.adapter.admin.0: logging false
    ble.0 2020-03-17 05:18:36.825 debug (1996) setting state ble.0.a4:c1:38:2b:bc:47.services.fe95
    ble.0 2020-03-17 05:18:36.825 debug (1996) a4:c1:38:2b:bc:47 > got values: {"services.fe95":"30585b05d047bc2b38c1a408"}
    ble.0 2020-03-17 05:18:36.824 debug (1996) _default: a4:c1:38:2b:bc:47 > got data 30585b05d047bc2b38c1a408 for fe95
    ble.0 2020-03-17 05:18:36.819 debug (1996) updating rssi state for a4:c1:38:2b:bc:47
    ble.0 2020-03-17 05:18:36.813 debug (1996) plugin _default is handling a4:c1:38:2b:bc:47
    ble.0 2020-03-17 05:18:36.813 debug (1996) has manufacturerData: false
    ble.0 2020-03-17 05:18:36.812 debug (1996) serviceData = [{"uuid":"fe95","data":{"type":"Buffer","data":[48,88,91,5,208,71,188,43,56,193,164,8]}}]
    ble.0 2020-03-17 05:18:36.812 debug (1996) has serviceData: true
    ble.0 2020-03-17 05:18:36.811 debug (1996) has advertisement: true
    ble.0 2020-03-17 05:18:36.806 debug (1996) discovered peripheral a4:c1:38:2b:bc:47
    ble.0 2020-03-17 05:18:33.527 debug (1996) setting state ble.0.a4:c1:38:2b:bc:47.services.fe95
    ble.0 2020-03-17 05:18:33.526 debug (1996) a4:c1:38:2b:bc:47 > got values: {"services.fe95":"30585b05d047bc2b38c1a408"}
    ble.0 2020-03-17 05:18:33.525 debug (1996) _default: a4:c1:38:2b:bc:47 > got data 30585b05d047bc2b38c1a408 for fe95
    ble.0 2020-03-17 05:18:33.520 debug (1996) updating rssi state for a4:c1:38:2b:bc:47
    ble.0 2020-03-17 05:18:33.518 debug (1996) plugin _default is handling a4:c1:38:2b:bc:47
    ble.0 2020-03-17 05:18:33.517 debug (1996) has manufacturerData: false
    ble.0 2020-03-17 05:18:33.517 debug (1996) serviceData = [{"uuid":"fe95","data":{"type":"Buffer","data":[48,88,91,5,208,71,188,43,56,193,164,8]}}]
    ble.0 2020-03-17 05:18:33.517 debug (1996) has serviceData: true
    ble.0 2020-03-17 05:18:33.517 debug (1996) has advertisement: true
    ble.0 2020-03-17 05:18:33.516 debug (1996) discovered peripheral a4:c1:38:2b:bc:47
    ble.0 2020-03-17 05:18:31.835 debug (1996) setting state ble.0.a4:c1:38:2b:bc:47.services.fe95
    ble.0 2020-03-17 05:18:31.832 debug (1996) a4:c1:38:2b:bc:47 > got values: {"services.fe95":"30585b05d047bc2b38c1a408"}
    ble.0 2020-03-17 05:18:31.830 debug (1996) _default: a4:c1:38:2b:bc:47 > got data 30585b05d047bc2b38c1a408 for fe95
    ble.0 2020-03-17 05:18:31.825 debug (1996) plugin _default is handling a4:c1:38:2b:bc:47
    ble.0 2020-03-17 05:18:31.824 debug (1996) has manufacturerData: false
    ble.0 2020-03-17 05:18:31.824 debug (1996) serviceData = [{"uuid":"fe95","data":{"type":"Buffer","data":[48,88,91,5,208,71,188,43,56,193,164,8]}}]
    ble.0 2020-03-17 05:18:31.823 debug (1996) has serviceData: true
    ble.0 2020-03-17 05:18:31.823 debug (1996) has advertisement: true
    ble.0 2020-03-17 05:18:31.822 debug (1996) discovered peripheral a4:c1:38:2b:bc:47
    ble.0 2020-03-17 05:18:30.069 debug (1996) setting state ble.0.a4:c1:38:2b:bc:47.services.fe95
    ble.0 2020-03-17 05:18:30.068 debug (1996) a4:c1:38:2b:bc:47 > got values: {"services.fe95":"30585b05d047bc2b38c1a408"}
    ble.0 2020-03-17 05:18:30.067 debug (1996) _default: a4:c1:38:2b:bc:47 > got data 30585b05d047bc2b38c1a408 for fe95
    ble.0 2020-03-17 05:18:30.061 debug (1996) updating rssi state for a4:c1:38:2b:bc:47
    ble.0 2020-03-17 05:18:30.058 debug (1996) plugin _default is handling a4:c1:38:2b:bc:47
    ble.0 2020-03-17 05:18:30.058 debug (1996) has manufacturerData: false
    ble.0 2020-03-17 05:18:30.058 debug (1996) serviceData = [{"uuid":"fe95","data":{"type":"Buffer","data":[48,88,91,5,208,71,188,43,56,193,164,8]}}]
    ble.0 2020-03-17 05:18:30.057 debug (1996) has serviceData: true
    ble.0 2020-03-17 05:18:30.057 debug (1996) has advertisement: true
    ble.0 2020-03-17 05:18:30.056 debug (1996) discovered peripheral a4:c1:38:2b:bc:47
    ble.0 2020-03-17 05:18:28.410 debug (1996) setting state ble.0.a4:c1:38:2b:bc:47.services.fe95
    ble.0 2020-03-17 05:18:28.410 debug (1996) a4:c1:38:2b:bc:47 > got values: {"services.fe95":"30585b05d047bc2b38c1a408"}
    ble.0 2020-03-17 05:18:28.409 debug (1996) _default: a4:c1:38:2b:bc:47 > got data 30585b05d047bc2b38c1a408 for fe95
    ble.0 2020-03-17 05:18:28.361 debug (1996) updating rssi state for a4:c1:38:2b:bc:47
    ble.0 2020-03-17 05:18:28.358 debug (1996) plugin _default is handling a4:c1:38:2b:bc:47
    • chris12205C chris12205
      bitte schön
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      @chris12205 Das hier gezeigte Gerät sendet leider keine Nutzdaten (erkennbar am Start "30"). Ich dachte du meinst das andere, was im Screenshot ebenfalls zu sehen ist (Start "70").
      chris12205C 1 Antwort Letzte Antwort
      • AlCalzoneA AlCalzone
        chris12205C Offline
        chris12205C Offline
        chris12205
        @AlCalzone du hast recht die Daten stammen vom LYWSD03MMC. Das Gerät ist anscheinend verquatschter. Ja ich weiß das es noch nicht unterstüzt wird.
        Hier die vom LYWSD02 Advertised service fe95: 70205b0485a458b3002ee7090610026202
        • R Offline
          Rushmed
          schrieb am zuletzt editiert von Rushmed
          Hab gerade ein LYWSD02 in Betrieb genommen und es scheint auf Anhieb zu funktionieren.
          Die Reichweite ist nur nicht so toll wie erwartet. Ich wollte das Teil ca. 5 m und zwei Holztüren entfernt betreiben und bekomme von dort kein Signal mehr.
          • Lenny.CBL Offline
            Lenny.CBL Offline
            Lenny.CB
            @AlCalzone grad wieder neues Spielzeug angekommen:
            Model: MHO-C401 Smart BT Thermometer-Hygrometer
            (gibts grad bei Banggood um 8€ +2,50€ Versand)
            value vom "fe95" ist "305887034b9959dd38c1a4280100"
            debug-log:
            ble.0	2020-07-25 09:36:51.951	debug	(1476) setting state ble.0.a4:c1:38:dd:59:99.services.fe95
            ble.0	2020-07-25 09:36:51.949	debug	(1476) a4:c1:38:dd:59:99 > got values: {"services.fe95":"305887034b9959dd38c1a4280100"}
            ble.0	2020-07-25 09:36:51.945	debug	(1476) _default: a4:c1:38:dd:59:99 > got data 305887034b9959dd38c1a4280100 for fe95
            ble.0	2020-07-25 09:36:51.918	debug	(1476) plugin _default is handling a4:c1:38:dd:59:99
            ble.0	2020-07-25 09:36:51.916	debug	(1476) has manufacturerData: false
            ble.0	2020-07-25 09:36:51.914	debug	(1476) serviceData = [{"uuid":"fe95","data":{"type":"Buffer","data":[48,88,135,3,75,153,89,221,56,193,164,40,1,0]}}]
            ble.0	2020-07-25 09:36:51.912	debug	(1476) has serviceData: true
            ble.0	2020-07-25 09:36:51.910	debug	(1476) has advertisement: true
            ble.0	2020-07-25 09:36:51.906	debug	(1476) discovered peripheral a4:c1:38:dd:59:99
            kannst Du hier was machen?
            3 Beiträge weiter oben hast Du geschrieben:
            @AlCalzone sagte in BLE Adapter:
            ....Das hier gezeigte Gerät sendet leider keine Nutzdaten (erkennbar am Start "30")...
            Gibt es da noch Unterschiede? Das runde e-Ink von Xiaomi fängt auch mit "30" an und das funktioniert ja recht gut.
            • Lenny.CBL Lenny.CB
              debug-log:
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              @Lenny-CB sagte in BLE Adapter:
              Da seht auch nur die Mac-Adresse drin.
              Wirklich? Hast du mal einen Datensatz für mich?
              Lenny.CBL 1 Antwort Letzte Antwort
                Lenny.CBL Offline
                Lenny.CBL Offline
                Lenny.CB
                https://forum.iobroker.net/post/322851
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  @Lenny-CB Ne, da steht auch nix drin. Die Werte müssen also von einem anderen Datensatz gekommen sein.
                    Lenny.CBL Offline
                    Lenny.CBL Offline
                    Lenny.CB
                    Stimmt, lt. Debug ist da nix mehr mit "30".
                    ble.0	2020-07-25 17:17:13.567	debug	(5027) setting state ble.0.58:2d:34:10:4d:d3.temperature
                    ble.0	2020-07-25 17:17:13.490	debug	(5027) setting state ble.0.58:2d:34:10:4d:d3.humidity
                    ble.0	2020-07-25 17:17:13.488	debug	(5027) 58:2d:34:10:4d:d3 > got values: {"humidity":62.9,"temperature":25.8}
                    ble.0	2020-07-25 17:17:13.485	debug	(5027) xiaomi >> <span style="color: #5bb12f">got temperature update => 25.8</span>
                    ble.0	2020-07-25 17:17:13.483	debug	(5027) xiaomi >> <span style="color: #5bb12f">got humidity update => 62.9</span>
                    ble.0	2020-07-25 17:17:13.480	debug	(5027) xiaomi >> got data: 503047034bd34d10342d580d100402017502
                    ble.0	2020-07-25 17:17:13.470	debug	(5027) plugin Xiaomi is handling 58:2d:34:10:4d:d3
                    Komisch nur, dass es damals so war. (Gut zu sehen im Objektbaum siehe Link.)
                      @adarof Sobald es um lesen/schreiben von Characteristics geht, muss der Adapter bisher passen. Das ist noch nicht implementiert.
                      Lenny.CBL Offline
                      Lenny.CBL Offline
                      Lenny.CB
                      @AlCalzone, steht das noch bei Dir auf der Timeline oder ist das Thema "aktive Verbindung" gestorben?
                      PS: hatte das jetzt auch mit dem ham-Adapter und dem passenden Plugin versucht, ging aber auch nicht. 😫
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        @Lenny-CB irgendwann komme ich noch dazu, aber zwave2 hat bei mir gerade Priorität und das frisst Zeit ohne Ende.
                          Lenny.CBL Offline
                          Lenny.CBL Offline
                          Lenny.CB
                          @Lenny-CB irgendwann komme ich noch dazu...
                          @AlCalzone darauf freue ich mich schon... 😀
                          habe mal ein wenig mit dem Teil gespielt. Folgendes Log bekomme ich:
                          javascript.3	2020-07-27 21:14:48.788	info	(31334) script.js.Testscripte.Peripheral_explorer: 0000010200656c622e746f696d2e696d (STDIO_TX) properties notify
                          javascript.3	2020-07-27 21:14:48.699	info	(31334) script.js.Testscripte.Peripheral_explorer: 0000010100656c622e746f696d2e696d (STDIO_RX) properties writeWithoutResponse
                          javascript.3	2020-07-27 21:14:48.520	info	(31334) script.js.Testscripte.Peripheral_explorer: 0000010000656c622e746f696d2e696d
                          javascript.3	2020-07-27 21:14:48.518	info	(31334) script.js.Testscripte.Peripheral_explorer: 19 (standard) properties writeWithoutResponse, notify
                          javascript.3	2020-07-27 21:14:48.429	info	(31334) script.js.Testscripte.Peripheral_explorer: 18 (ota_data) properties writeWithoutResponse, notify
                          javascript.3	2020-07-27 21:14:48.339	info	(31334) script.js.Testscripte.Peripheral_explorer: 17 (ota_ctrl) properties write, notify
                          javascript.3	2020-07-27 21:14:48.248	info	(31334) script.js.Testscripte.Peripheral_explorer: 10 (Authentication) properties writeWithoutResponse, notify
                          javascript.3	2020-07-27 21:14:48.159	info	(31334) script.js.Testscripte.Peripheral_explorer: 4 (Version) properties read value 312e302e305f3030303100000000000000000000 | '1.0.0_0001'
                          javascript.3	2020-07-27 21:14:47.980	info	(31334) script.js.Testscripte.Peripheral_explorer: fe95
                          javascript.3	2020-07-27 21:14:47.978	info	(31334) script.js.Testscripte.Peripheral_explorer: ebe0ccd97a0a4b0c8a1a6ff2997da3a6 (para_value_get) properties write, notify
                          javascript.3	2020-07-27 21:14:47.889	info	(31334) script.js.Testscripte.Peripheral_explorer: ebe0ccd87a0a4b0c8a1a6ff2997da3a6 (set conn interval) properties write
                          javascript.3	2020-07-27 21:14:47.829	info	(31334) script.js.Testscripte.Peripheral_explorer: ebe0ccd77a0a4b0c8a1a6ff2997da3a6 (comfortable temp and humi) properties read, write value 8c0a6c075514 | ' lU'
                          javascript.3	2020-07-27 21:14:47.709	info	(31334) script.js.Testscripte.Peripheral_explorer: ebe0ccd47a0a4b0c8a1a6ff2997da3a6 (display all) properties write
                          javascript.3	2020-07-27 21:14:47.649	info	(31334) script.js.Testscripte.Peripheral_explorer: ebe0ccd17a0a4b0c8a1a6ff2997da3a6 (clear data) properties write
                          javascript.3	2020-07-27 21:14:47.589	info	(31334) script.js.Testscripte.Peripheral_explorer: ebe0ccc87a0a4b0c8a1a6ff2997da3a6 (disconnect) properties write
                          javascript.3	2020-07-27 21:14:47.530	info	(31334) script.js.Testscripte.Peripheral_explorer: ebe0ccc47a0a4b0c8a1a6ff2997da3a6 (Batt) properties read value 64 | 'd'
                          javascript.3	2020-07-27 21:14:47.433	info	(31334) script.js.Testscripte.Peripheral_explorer: ebe0ccc17a0a4b0c8a1a6ff2997da3a6 (Temperature and Humidity) properties read, notify value 000000 | ''
                          javascript.3	2020-07-27 21:14:47.276	info	(31334) script.js.Testscripte.Peripheral_explorer: ebe0ccbe7a0a4b0c8a1a6ff2997da3a6 (Temperature Uint) properties read, write value 00 | ''
                          javascript.3	2020-07-27 21:14:47.154	info	(31334) script.js.Testscripte.Peripheral_explorer: ebe0ccbc7a0a4b0c8a1a6ff2997da3a6 (Data Notify) properties notify
                          javascript.3	2020-07-27 21:14:47.065	info	(31334) script.js.Testscripte.Peripheral_explorer: ebe0ccbb7a0a4b0c8a1a6ff2997da3a6 (Data Read) properties read value 51000000208104001d0142e10033 | 'Q Ba3'
                          javascript.3	2020-07-27 21:14:46.975	info	(31334) script.js.Testscripte.Peripheral_explorer: ebe0ccba7a0a4b0c8a1a6ff2997da3a6 (Index) properties read, write value 00000000 | ''
                          javascript.3	2020-07-27 21:14:46.884	info	(31334) script.js.Testscripte.Peripheral_explorer: ebe0ccb97a0a4b0c8a1a6ff2997da3a6 (Data Count) properties read value 5100000052000000 | 'QR'
                          javascript.3	2020-07-27 21:14:46.794	info	(31334) script.js.Testscripte.Peripheral_explorer: ebe0ccb77a0a4b0c8a1a6ff2997da3a6 (Time) properties read, write value 7b860400 | '{'
                          javascript.3	2020-07-27 21:14:46.247	info	(31334) script.js.Testscripte.Peripheral_explorer: ebe0ccb07a0a4b0c8a1a6ff2997da3a6
                          javascript.3	2020-07-27 21:14:46.246	info	(31334) script.js.Testscripte.Peripheral_explorer: 000102030405060708090a0b0c0d2b12 (OTA) properties read, writeWithoutResponse value 00 | ''
                          javascript.3	2020-07-27 21:14:46.076	info	(31334) script.js.Testscripte.Peripheral_explorer: 000102030405060708090a0b0c0d1912
                          javascript.3	2020-07-27 21:14:46.074	info	(31334) script.js.Testscripte.Peripheral_explorer: 2a19 (Battery Level) properties read, notify value 63 | 'c'
                          javascript.3	2020-07-27 21:14:45.962	info	(31334) script.js.Testscripte.Peripheral_explorer: 180f (Battery Service)
                          javascript.3	2020-07-27 21:14:45.961	info	(31334) script.js.Testscripte.Peripheral_explorer: 2a29 (Manufacturer Name String) properties read value 6d69616f6d69616f63652e636f6d00 | 'miaomiaoce.com'
                          javascript.3	2020-07-27 21:14:45.895	info	(31334) script.js.Testscripte.Peripheral_explorer: 2a28 (Software Revision String) properties read value 3030313000 | '0010'
                          javascript.3	2020-07-27 21:14:45.834	info	(31334) script.js.Testscripte.Peripheral_explorer: 2a27 (Hardware Revision String) properties read value 565f3134 | 'V_14'
                          javascript.3	2020-07-27 21:14:45.759	info	(31334) script.js.Testscripte.Peripheral_explorer: 2a26 (Firmware Revision String) properties read value 312e302e305f3030313000 | '1.0.0_0010'
                          javascript.3	2020-07-27 21:14:45.698	info	(31334) script.js.Testscripte.Peripheral_explorer: 2a25 (Serial Number String) properties read value 472d31392d303030303030303030303030303030 | 'G-19-000000000000000'
                          javascript.3	2020-07-27 21:14:45.639	info	(31334) script.js.Testscripte.Peripheral_explorer: 2a24 (Model Number String) properties read value 4d484f2d4334303100 | 'MHO-C401'
                          javascript.3	2020-07-27 21:14:45.526	info	(31334) script.js.Testscripte.Peripheral_explorer: 180a (Device Information)
                          javascript.3	2020-07-27 21:14:45.524	info	(31334) script.js.Testscripte.Peripheral_explorer: 2a05 (Service Changed) properties indicate
                          javascript.3	2020-07-27 21:14:45.431	info	(31334) script.js.Testscripte.Peripheral_explorer: 1801 (Generic Attribute)
                          javascript.3	2020-07-27 21:14:45.428	info	(31334) script.js.Testscripte.Peripheral_explorer: 2a04 (Peripheral Preferred Connection Parameters) properties read value 140028000000e803 | '(h'
                          javascript.3	2020-07-27 21:14:45.370	info	(31334) script.js.Testscripte.Peripheral_explorer: 2a01 (Appearance) properties read value 0000 | ''
                          javascript.3	2020-07-27 21:14:45.298	info	(31334) script.js.Testscripte.Peripheral_explorer: 2a00 (Device Name) properties read, notify value 4d484f2d4334303100 | 'MHO-C401'
                          javascript.3	2020-07-27 21:14:45.182	info	(31334) script.js.Testscripte.Peripheral_explorer: 1800 (Generic Access)
                          javascript.3	2020-07-27 21:14:43.122	info	(31334) script.js.Testscripte.Peripheral_explorer: services and characteristics:
                          javascript.3	2020-07-27 21:14:43.120	info	(31334) script.js.Testscripte.Peripheral_explorer: undefined
                          javascript.3	2020-07-27 21:14:43.119	info	(31334) script.js.Testscripte.Peripheral_explorer: Service UUIDs =
                          javascript.3	2020-07-27 21:14:43.117	info	(31334) script.js.Testscripte.Peripheral_explorer: Service Data = [ { "uuid": "fe95", "data": { "type": "Buffer", "data": [ 48, 88, 135, 3,
                          javascript.3	2020-07-27 21:14:43.116	info	(31334) script.js.Testscripte.Peripheral_explorer: Local Name = MHO-C401
                          javascript.3	2020-07-27 21:14:43.115	info	(31334) script.js.Testscripte.Peripheral_explorer: peripheral with ID a4c138dd5999 found
                          kann man mit den Daten was anfangen bzw. bin ich auf dem richtigen (Holz)Weg? 😨
                          • MagicMan3311M Offline
                            MagicMan3311
                            Habe folgendes gefunden:
                            https://www.room-assistant.io/integrations/xiaomi-mi.html#encryption
                            Vielleicht hilft das. Scheint sehr kompliziert zu sein, den Key zu bekommen, mit dem jedes Gerät die Daten verschlüsselt.
