  4. Test Adapter klf200 v1.0.x latest
veluxklf200io homecontrolsomfy2.0.0.71klf-200
37 Beiträge 12 Kommentatoren 7.0k Aufrufe 13 Beobachtet
    Andy61
    schrieb am zuletzt editiert von Andy61
    Hallo, erst einmal vielen Dank für die Entwicklung. Habe das Projekt in den letzten Tagen intensiv verfolgt. Jetzt habe ich den Adapter 1.0.0 installiert, bekomme ihn aber nicht zum laufen. Folgende Fehlermeldung erhalte ich:
    host.ioBroker 2020-06-27 13:49:26.485 info Restart adapter system.adapter.klf200.0 because enabled
    host.ioBroker 2020-06-27 13:49:26.485 error instance system.adapter.klf200.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.ioBroker 2020-06-27 13:49:26.485 error Caught by controller[0]: }
    host.ioBroker 2020-06-27 13:49:26.484 error Caught by controller[0]: requestPath: 'klf-200-api'
    host.ioBroker 2020-06-27 13:49:26.484 error Caught by controller[0]: path: '/opt/iobroker/node_modules/klf-200-api/package.json',
    host.ioBroker 2020-06-27 13:49:26.484 error Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.ioBroker 2020-06-27 13:49:26.483 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:986:32) {
    host.ioBroker 2020-06-27 13:49:26.483 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
    host.ioBroker 2020-06-27 13:49:26.482 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1138:30)
    host.ioBroker 2020-06-27 13:49:26.482 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.klf200/build/main.js:9:23)
    host.ioBroker 2020-06-27 13:49:26.481 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
    host.ioBroker 2020-06-27 13:49:26.481 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1026:19)
    host.ioBroker 2020-06-27 13:49:26.481 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:842:27)
    host.ioBroker 2020-06-27 13:49:26.481 error Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:953:27)
    host.ioBroker 2020-06-27 13:49:26.480 error Caught by controller[0]: at Function.Module._findPath (internal/modules/cjs/loader.js:683:18)
    host.ioBroker 2020-06-27 13:49:26.480 error Caught by controller[0]: at tryPackage (internal/modules/cjs/loader.js:322:19)
    host.ioBroker 2020-06-27 13:49:26.480 error Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/klf-200-api/dist/index.js'. Please verify that the package.json has a valid "main" entry
    host.ioBroker 2020-06-27 13:49:26.479 error Caught by controller[0]: ^
    host.ioBroker 2020-06-27 13:49:26.479 error Caught by controller[0]: throw err;
    host.ioBroker 2020-06-27 13:49:26.478 error Caught by controller[0]: internal/modules/cjs/loader.js:330
    host.ioBroker 2020-06-27 13:49:25.957 info instance system.adapter.klf200.0 started with pid 11654
    host.ioBroker 2020-06-27 13:48:55.917 info Restart adapter system.adapter.klf200.0 because enabled
    Habe mit WinSCP nachgesehen. Es fehlt "/opt/iobroker/node_modules/klf-200-api/dist/index.js". klf-200-api ist installiert. Das Gateway ist per IP eingerichtet und erreichbar. Auch mit Telnet komme ich rein. Was kann/ muss ich zur Behebung machen?
    Andreas
      schauaufdich
      Hallo, auch meinerseits ein herzliches Danke für die Entwicklung des Adapters. Ich bin gestern auf die neue Version umgestiegen und erhalte nun immer folgende Meldung
      2020-06-27 17:38:43.807 - error: host.hans-Lenovo-YOGA-900-13ISK instance system.adapter.klf200.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      2020-06-27 17:38:43.807 - info: host.hans-Lenovo-YOGA-900-13ISK Do not restart adapter system.adapter.klf200.0 because desired by instance
      2020-06-27 17:39:33.597 - info: host.hans-Lenovo-YOGA-900-13ISK instance system.adapter.klf200.0 started with pid 4364
      2020-06-27 17:39:34.284 - info: klf200.0 (4364) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.klf200, node: v12.18.1, js-controller: 3.1.5
      2020-06-27 17:39:34.313 - info: klf200.0 (4364) Host: VELUX-KLF-E5B7.fritz.box
      Die todo's aus der Anleitung habe ich schon alle durch ;-) . Ich hoffe mir kann geholfen werden ;-)
      lg Hans
      • A Andy61
        Andreas
        MiSchroe
        @Andy61 Es fehlt das klf-200-api-Modul. Das installiert sich mit der Installation des Adapters normalerweise mit. Wie hast Du die Installation des Adapters durchgeführt, über den Admin oder manuell?
        Wechsele mal in das Verzeichnis /opt/iobroker/node_modules/iobroker.klf200 und führe dort npm install aus. Dadurch installieren sich die fehlenden Abhängigkeiten nach.
        • S schauaufdich
          lg Hans
          MiSchroe
          @schauaufdich Kannst Du bitte auch die Log-Einträge vor der Fehlermeldung posten? Der Adapter beendet sich selbst, wenn er sich nicht mit der Box verbinden kann, das kann ein falsches Passwort sein oder irgendetwas anderes. Passwort ist entweder das WLAN-Passwort auf der Rückseite der Box oder ein selbst vergebenes.
          • M MiSchroe
            Andy61
            @MiSchroe einfach super, vielen Dank. Keine Fehlermeldungen mehr und verbunden ist er auch. Jetzt wird er eingebunden und getestet. Die api hatte ich auf der Konsole installiert, den Adapter als admin. Es könnte evtl. damit zusammenhängen, das ich den alten Adapter mal installiert hatte und die Steuerung bisher über Scripte gelöst hatte. Das wollte ich jetzt ablösen. Vielen Dank für die schnelle Hilfe. LG Andreas👍 🤗
            A 2 Antworten Letzte Antwort
            • M MiSchroe
              schauaufdich
              @MiSchroe danke, hier die Logeinträge
              2020-06-28 12:52:32.834 - info: javascript.0 (18503) script.js.common.Wäschewaschen: script Wäschewaschen läuft
              2020-06-28 12:52:32.834 - info: javascript.0 (18503) script.js.common.Wäschewaschen: 0.02
              2020-06-28 12:52:32.834 - info: javascript.0 (18503) script.js.common.Wäschewaschen: Trockner aus 28.06.2020 12:52:32
              2020-06-28 12:53:00.032 - info: javascript.0 (18503) script.js.common.ZeitenVisualisierung: Tageszeiten 1 gestartet
              2020-06-28 12:53:00.044 - info: javascript.0 (18503) script.js.common.Tageszeiten: Tageszeiten 1 gestartet
              2020-06-28 12:53:25.255 - info: javascript.0 (18503) script.js.common.divRoutinen: script Verbrauch seit letzter Ablesung läuft:
              2020-06-28 12:54:00.038 - info: javascript.0 (18503) script.js.common.Tageszeiten: Tageszeiten 1 gestartet
              2020-06-28 12:54:00.053 - info: javascript.0 (18503) script.js.common.ZeitenVisualisierung: Tageszeiten 1 gestartet
              2020-06-28 12:54:01.378 - info: host.hans-Lenovo-YOGA-900-13ISK instance system.adapter.klf200.0 started with pid 21670
              2020-06-28 12:54:01.939 - info: klf200.0 (21670) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.klf200, node: v12.18.1, js-controller: 3.1.6
              2020-06-28 12:54:01.961 - info: klf200.0 (21670) Host: velux-klf-e5b7.fritz.box
              2020-06-28 12:54:06.219 - info: klf200.0 (21670) Terminated (ADAPTER_REQUESTED_TERMINATION): Login to KLF-200 device at velux-klf-e5b7.fritz.box failed.
              2020-06-28 12:54:06.765 - error: host.hans-Lenovo-YOGA-900-13ISK instance system.adapter.klf200.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
              2020-06-28 12:54:06.766 - info: host.hans-Lenovo-YOGA-900-13ISK Do not restart adapter system.adapter.klf200.0 because desired by instance
              Wenn ich im klf200 Verzeichnis "npm install" durchführe erhalte ich folgendes:
              npm WARN @typescript-eslint/eslint-plugin@2.34.0 requires a peer of eslint@^5.0.0 || ^6.0.0 but none is installed. You must install peer dependencies yourself.
              npm WARN @typescript-eslint/parser@2.34.0 requires a peer of eslint@^5.0.0 || ^6.0.0 but none is installed. You must install peer dependencies yourself.
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/mocha/node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
              Muss ich noch etwas installieren?
              • S schauaufdich
                MiSchroe
                @schauaufdich Bitte prüfe das Passwort. Die Fehlermeldung wird gelogged, wenn das Pasword falsch ist.
                • M MiSchroe
                  schauaufdich
                  schrieb am zuletzt editiert von schauaufdich
                  @MiSchroe Danke nochmals, jetzt ist der Adapter grün. Ich habe das Web-Passwort und nicht das WLAN-Passwort verwendet ;-) Wer lesen kann, ist im Vorteil...
                    Boot007
                    Gibt es die Möglichkeit, den Wert des Regensensors bei einem Integra-Fenster auszulesen?
                    • B Boot007
                      MiSchroe
                      @Boot007 Da gibt es unter https://github.com/MiSchroe/ioBroker.klf200/issues/47 auch gerade eine Anfrage. Ich muss mir das angucken. Es müssen auf jeden Fall noch weitere States erzeugt werden.
                      Aktuell bekommt man es auf jeden Fall mit, wenn der Regensensor das Fenster schließt, das steht in irgendeinem der Status-Werte drin (habe gerade keinen Zugriff), aber wenn das Fenster schon zu ist oder nur die Lüftungsklappe offen, dann wird vermutlich keine Änderung passieren.
                      • A Andy61
                        Andy61
                        @Andy61 Ich benötige doch noch einmal Hilfe. Mit npm install läuft der Adapter erst einmal problemlos. Wenn er allerdings neu startet, stellt sich wieder das alte Verhalten ein (siehe meine Nachricht vom 27.06.). Den automatischen Reeboot habe ich ausgeschaltet. Nicht schön, aber läuft.
                        Nach dem Update auf 1.0.1. natürlich wieder die gleiche Prozedur. Was muss ich machen, um dieses Verhalten abzustellen?
                        Nach dem Update auf 1.0.1. lief erst alles sauber. Jetzt gibt es wieder keine Verbindung und folgende Fehlermeldung "startInstance klf200.0: cannot find start file!". Ein Downgrade auf 1.0 brachte Abhilfe. Was kann ich machen?
                        LG Andreas
                        • tcjT Offline
                          tcjT Offline
                          tcj
                          Vielen Dank für diese neue Version.
                          Ich konnte nun endlich die FHEM Installation runterwerfen, die ich nur für die Schnittstelle zur KLF laufen hatte.
                          Was nicht bedeuten soll, dass an FHEM etwas schlecht wäre.
                          LG
                          Thomas
                          „Am Ende wird alles gut.
                          Wenn es nicht gut wird,
                          ist es noch nicht das Ende.“
                          • A Andy61
                            Andy61
                            @Andy61 Hallo, ich bekomme beim npm update immer noch eine Warnung:
                            root@ioBroker:/opt/iobroker/node_modules/iobroker.klf200# npm update npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.1 (node_modules/ch okidar/node_modules/fsevents):
                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@ 2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"} )
                            Kann es daran liegen, das die Version 1.0.1 nicht läuft und ich nach jedem Neustart erst wieder ein npm update machen muss?
                            im log erscheint folgende Fehlermeldung beim Start:
                            host.ioBroker 2020-08-23 13:06:21.353 error startInstance klf200.0: cannot find start file!
                            Andreas
                            • A Andy61
                              Andreas
                              @Andy61 Könnte am root-Login liegen.
                                Andy61
                                @Thomas-Braun Danke für den Hinweis. Folgendes habe ich gemacht:
                                Ich habe den gesamten Adapter noch einmal deinstalliert (auch die Ordner gelöscht). Dann neu installiert (die Version 1.0.1, die vorher gar nicht lief). Dann im Ordner ein npm update -f gemacht, klf200 neu gebootet und jetzt scheint es zu laufen. Auch ein Neustart funktioniert jetzt. Super, jetzt kann es in den Urlaub gehen.
                                • maeusekingM Offline
                                  maeusekingM Offline
                                  maeuseking
                                  schrieb am zuletzt editiert von maeuseking
                                  Moin!
                                  Auch von mir ein großes Dankeschön für die Entwicklung des Adapters, welcher bisher einwandfrei funktioniert hat.
                                  Ich habe leider seit ca. 2 Wochen das Problem, dass der Adapter sich nicht mehr erfolgreich einloggen kann.
                                  klf200.0 2020-10-06 12:39:04.815 info (871094) Terminated (ADAPTER_REQUESTED_TERMINATION): Login to KLF-200 device at http://velux-klf-0CB8 failed.
                                  klf200.0 2020-10-06 12:39:04.804 info (871094) Host: http://velux-klf-0CB8
                                  klf200.0 2020-10-06 12:39:04.710 info (871094) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.klf200, node: v12.18.4, js-controller: 3.1.6
                                  Ich habe diesen bereits deinstalliert und neu installiert, jedoch ohne Erfolg. Grundsätzlich hat der Adapter bereits funktioniert, sodass das Dachfenster beim händischen öffnen eines Giebelfensters automatisch mit aufging (das ist für mich smart ;-) )
                                  In die KLF Config komme ich nur über WLAN http://klf200.velux, das war vorher aber auch schon so. Ping an die IP-Adresse über LAN funktioniert. Aber egal, was ich als Host in den Adapter-Einstellungen auch eingebe -> "Login failed"
                                  Ich habe es also mit folgendem probiert:
                                  • IP-Adresse
                                  • velux-klf-0CB8
                                  • velux-klf-0cb8
                                  • http://velux-klf-0cb8
                                  • klf200.velux
                                    und einiges mehr.
                                  Passwort habe ich beim Standard gelassen und kann mich damit auch über W-LAN erfolgreich einloggen.
                                  EDIT:
                                  Nachdem ich erst jetzt die oben aufgeführte Anleitung, insbesondere zum Thema fritz.box, gelesen habe, habe ich auch all das ausprobiert. Ping und Telnet funktioniert mit und ohne dem Zusatz fritz.box. Auch die IP Adresse funktioniert bei beidem, aber der Adapter will einfach nicht. Oben hatte ich die letzten 4 Ziffern der W-LAN MAC aufgeführt, was natürlich falsch ist. Vorher hatte ich die richtige MAC verwendet und auch jetzt wieder probiert, leider kein Erfolg :-(
                                  Auch die Konfig in der FB (selbstständige Portfreigabe sowie Internetzugang unbeschränkt) hat nichts geändert...
                                  Lösung für alle, die das gleiche Problem haben:
                                  In der Doku wird fälschlicherweise das Passwort der Website gefordert, bei mir hat nun aber das WLAN Passwort funktioniert.
                                  Loxone Miniserver Gen 1 / 1 Relay Extension / 2 Extension / 1 Air Extension / 1 1-Wire-Extension / 1 RS485 Extension
                                  1 Pi4 als ioBroker-Server und zur Visualisierung an einem HP E230t Monitor
                                    StefanS
                                    schrieb am zuletzt editiert von StefanS
                                    Hallo Michael,
                                    auch von mehr erstmal vielen Dank für die Entwicklung des Adapters.
                                    Bei mir funktioniert er bisher einwandfrei. Was mir im ioBroker wichtig war, endlich die Sicherheitsfeatures zu implementieren, die in der besch****nen gekapselten Velux ioHomecontrol Welt nicht möglich sind. Wer schonmal sein elektrisches Rollo ins offene Fenster gesemmelt hat, weiß was ich meine ;-)
                                    Ich habe dazu zwei Script entwicklet, die ich gerne mit der Community teilen möchte und genau das verhindern:
                                    /* Prüfe, ob Fenster weiter als bisher geöffnet werden soll*/
                                    on({ id: 'klf200.0.products.1.targetPosition'/*Position Fenster*/, change: "gt", ack: false }, async function (obj) {
                                        var valueFenster = obj.state.val;
                                        var oldValueFenster = obj.oldState.val;
                                        /* Prüfe, ob Rolle weiter als 50% geöffnet ist*/
                                        if (getState("klf200.0.products.0.currentPosition").val > 50) {
                                            /* Fenster anhalten */
                                            setState('klf200.0.products.1.stop'/*stop*/, true);
                                            /* Rolle auf 50% zurückfahren, dann kann das Fenster gefahrlos geöffnet werden */
                                            setState('klf200.0.products.0.targetPosition', 50, false, function () {
                                                /* Callback: Trigger, wenn Rolloänderung fertig (Status 5) */
                                                on({ id: 'klf200.0.products.0.state'/*state*/, val: 5, ack: true }, async function (obj) {
                                                    var valueRollo = obj.state.val;
                                                    var oldValueRollo = obj.oldState.val;
                                                    /* Wenn Trigger erfüllt, Fenster auf ursprünglich gewünste Position öffnen */
                                                    setState('klf200.0.products.1.targetPosition', valueFenster, false, function () {
                                                    /* Trigger auf Rolladenstatus abmelden*/
                                                    unsubscribe('klf200.0.products.0.state')
                                    /* Prüfe, ob Rolle weiter als bisher geschlossen werden soll*/
                                    on({ id: 'klf200.0.products.0.targetPosition'/*Position Fenster*/, change: "gt", ack: false }, async function (obj) {
                                        var valueRolle = obj.state.val;
                                        var oldValueRolle = obj.oldState.val;
                                        /* Prüfe, ob Fenster weiter als 10% geöffnet ist (dies ist der Stellwert für den Dampfabzug)*/
                                        if (getState("klf200.0.products.1.currentPosition").val > 10) {
                                            /* Rollo anhalten */
                                            setState('klf200.0.products.0.stop'/*stop*/, true);
                                            /* Fenster auf 10% zurückfahren, dann kann das Rolle gefahrlos geschlossen werden */
                                            setState('klf200.0.products.1.targetPosition', 10, false, function () {
                                                /* Callback: Trigger, wenn Fensteränderung fertig (Status 5) */
                                                on({ id: 'klf200.0.products.1.state'/*state*/, val: 5, ack: true }, async function (obj) {
                                                    /* Wenn Trigger erfüllt, Rollo auf ursprünglich gewünste Position schließen */
                                                    setState('klf200.0.products.0.targetPosition', valueRolle, false, function () {
                                                    /* Trigger auf Fensterstatus abmelden*/
                                                    unsubscribe('klf200.0.products.1.state')
                                    Wer mag kann sich gerne bedienen.
                                    Viele Grüße,
                                    Stefan
                                    • S StefanS
                                      Hallo Michael,
                                      Viele Grüße,
                                      Stefan
                                      docspoc71
                                      Hallo, liebes Forum!
                                      Vielen Dank für den feinen Adapter, den ich vor einem halben Jahr erfolgreich installiert und dann benutzt hatte! Aber jetzt bekomme ich es nicht mehr hin und checke nicht warum:
                                      Der Adapter lässt sich nicht mehr verbinden. Ich bekomme folgendes Log:Bildschirmfoto 2020-12-27 um 07.02.04.png
                                      Ich habe bisher:
                                      • den Adapter neu installiert
                                      • die KLF200 zurückgesetzt und neu installiert
                                      • die IP erfolgreich gepingt.
                                      • Adresse und Passwort kontrolliert (benutze die IP und das WLAN-Passwort).
                                        Könnte es an einem Zertifikat, einem versteckten Schlüssel oder so etwas liegen, weil ich einen neuen Router habe? Muss ich etwas in meiner iobroker-Installation resetten?
                                        Ich bin leider blutiger Anfänger und freue mich über Welpenschutz....
                                        Stefan
                                      • D docspoc71
                                        Ich habe bisher:
                                          Stefan
                                        docspoc71
                                        @docspoc71 Problem gelöst. Es lag nicht am Adapter, sondern an der Fritzbox, die unter der IP einen anderen Velux KLF200 geführt hat. Ich musste eine neue, feste IP vergeben, danach hat die Verbindung geklappt.
                                        • M MiSchroe
                                          Aktuelle Test Version 1.0.0
                                          Veröffentlichungsdatum 19.06.2020
                                          Github Link https://github.com/MiSchroe/ioBroker.klf200
                                          Support der Firmware 2.0.0.71
                                          Der Adapter wurde komplett neu entwickelt und arbeitet nun mit der neuen Firmware 2.0.0.71 zusammen. Ältere Firmwares werden nicht mehr unterstützt.
                                          Wichtig: Das KLF-200 muss per LAN-Kabel verbunden sein. Über das WLAN ist nur der interne Webserver erreichbar, jedoch nicht die offizielle API, die von diesem Adapter angesprochen wird.
                                          Installation:
                                          Der Adapter ist über das latest-Repository verfügbar.
                                          Über GitHub:
                                          per Kommandozeile:
                                          iobroker url https://github.com/MiSchroe/ioBroker.klf200/tarball/master
                                          oder die URL in der Admin-Oberfläche einbinden.
                                          Konfiguration:
                                          In der Konfiguration beim Host ist der DNS-Hostname anzugeben, dass ist üblicherweise velux-klf-xxxx, wobei xxxx den letzten 4 Hexziffern der MAC entspricht, wenn das nicht über einen DNS-Server angepasst wurde. Alternativ kann hier auch die IP-Adresse angegeben werden.
                                          Benutzer einer FritzBox müssen .fritz.box and den Host-Namen anhängen, also z.B. velux-klf-1234.fritz.box
                                          Bei anderen Routern kann das ähnlich sein.
                                          Passwort:
                                          Das Standard-Passwort entspricht dem auf der Rückseite des Geräts angegebenen WLAN-Passwort. Wenn Ihr das Passwort bereits geändert habt, entspricht es evtl. auch eurem geänderten Passwort.
                                          Features des Adapters
                                          • Direkte Steuerung der angeschlossenen Produkte inkl. Status- und Positionsrückmeldung
                                          • Unterbrechen von laufenden Vorgängen
                                          • Starten und Stoppen von im KLF-200 definierten Szenen
                                          • Steuerung der Produkte über vordefinierte Gruppen, z.B. alle Fenster schliessen
                                          Die komplette Dokumentation inkl. der Datenpunkte findet sich auf GitHub in der Readme: https://github.com/MiSchroe/ioBroker.klf200/blob/master/README.md
                                          Problembehandlung
                                          • Ich bekomme Login failed:
                                            • Der Adapter kommuniziert mit dem KLF-200 über den Port 51200, d.h. ioBroker muss über diesen Port auf das Gerät zugreifen können.
                                              Stellt bitte sicher, dass eine etwaige Firewall die Kommunikation nicht unterbindet.
                                            • Prüft zunächst, ob Ihr die Box per ping erreicht, und zwar mit genau dem Hostnamen, den Ihr in der Konfiguration eingetragen habt.
                                            • Prüft, ob Ihr Euch per telnet über Port 51200 mit der Box verbinden könnt.
                                            • FritzBox-Benutzer: Bitte die Anmerkung oben unter Konfiguration beachten.
                                            • Startet das KLF-200 neu, es können max. 2 Verbindungen gleichzeitig aktiv sein. Wenn eine Verbindung abbricht, so wird diese in der KLF-200 erst nach 15 Minuten geschlossen. Evtl. hat sich das ganze Gateway auch aufgehängt. Dazu einfach nur kurz das Stromkabel ziehen und wieder einstecken.
                                              Der Adatper versucht sich ggfs. selbstständig neu zu verbinden.
                                          Aktuelle Beschränkungen
                                          • Werden bei laufendem Adapter neue Szenen definiert, wird dies erst nach Neustart des Adapters erkannt.
                                          • Die Zeitzone wird auf mitteleuropäische Sommerzeit festgelegt, das soll später mal konfigurierbar sein,
                                            leider ist die interne Logik recht komplex und ich möchte das möglichst benutzerfreundlich lösen.
                                          • Der Adapter schaltet den sog. Haus Status Monitor ein. Das ist ein Prozess innerhalb des KLF-200, der regelmäßig den Status der
                                            angeschlossenen Produkte abfragt, wobei die Häufigkeit der Abfrage dabei von der Art der Stromversorgung des Produkts abhängt.
                                            Dieser Prozess bleibt dauerhaft an und wird auch nach einem Neustart des KLF-200 wieder gestartet. Erst dieser Prozess ermöglicht es,
                                            dass der Adapter Änderungen mitbekommt, die nicht über ioBroker gesteuert werden, d.h. wenn der Regensensor das Fenster automatisch
                                            schließt, bekommt Ihr das jetzt mit (und seht auch, dass es der Regensensor war).
                                          Wie melde ich ein Problem oder einen Fehler?
                                          Gerne hier im Forum als Antwort, offensichtliche Fehler des Adapters (also, z.B. ich lösche alle Szenen und nun startet der Adapter nicht mehr)
                                          bitte auch gerne ein Issue in Github anlegen (das erspart mir dann etwas Arbeit und ich bekomme es schneller mit).
                                          Was soll ich testen?
                                          Ich habe nur Velux-Fenster und Rollläden, wenn jemand andere io-homecontrol(R)-fähige Geräte angeschlossen hat, würde ich mich auch über eine
                                          Rückmeldung freuen, dass die auch funktionieren.
                                          Im Dauereinsatz wäre es auch noch interessant zu beobachten, ob es irgendwo Speicherlecks gibt und der Adapter im Laufe der Zeit immer mehr
                                          Speicher verbraucht. Im Rahmen der Entwicklung ist der Adapter bei mir bisher leider immer nur kurzzeitig im Betrieb gewesen.
                                          I Offline
                                          I Offline
                                          izmiruebel
                                          @MiSchroe
                                          Hallo Michael,
                                          auch von mir zunächst mal vielen Dank für den KLF200 Adapter.
                                          Ich habe nach einer Lösung gesucht, meine 13 Somfy Oximo io Rolladenmotoren anzusteuern. Das wäre prinzipiell auch über die Somfy Tahoma Box gegangen, da diese aber offenbar nur auf API Befehle reagiert, wenn eine Internetverbindung besteht, habe ich mich für das KLF200 als Gateway entschieden. Ohne deinen Adapter wäre mich die Verwendung von ioBroker also nicht möglich gewesen.
                                          Die 13 Rolläden wurden ohne Probleme im Objektmanager von ioBroker aufgelistet und auch die Kommunikation/Reaktion auf Stellbefehle hat gleich geklappt. Ich habe jetzt aber ein paar Fragen:
                                          1. Ich stelle meine Rolläden auch über vor lokale Funk-Taster und möchte natürlich gerne in der Vis den aktuellen Zustand (currentPosition) sehen. Kannst du mir sagen, wie lange die Aktualsierungszyklen sind? Einmal der Aktualisierungszyklus auf dem KLF200 selbst (das Gerät wird ja sicherlich nicht jede Sekunde den Zustand jedes Rolladens pollen) und zum anderen den Aktualisierungszyklus zwischen KLF200 und ioBroker.
                                          2. Lässt sich der Aktualsierungszyklus evtl. sogar iregndwo einstellen? (sowohl bei deinem Adapter als auch auf dem KLF200). Im KLF200 habe ich zumidest nichts gefunden, wo man das einstellen könnte.
                                          3. Heute hatte ich den Fall, dass auch nach sehr langer Wartezeit der currentPosition Wert nicht aktualisiert wurde (Rolladen war ganz auf, der currentPosition Wert ist aber dauerhaft auf dem alten Wert 50% stehen geblieben). Ich habe dann irgendwann gesehen, dass der GatewaySubState nicht auf Idle stand, obwohl das KLF200 gar nichts zu tun hatte. Was ist da passiert? Nach Neustart des KLF200 war wieder alles ok und der currentPosition Wert wurde wieder nach einigen Minuten aktualisiert.
                                          4. Ich möchte in der Vis gerne sehen, wann der Rolladen die gewünschte Position erreicht hat (d.h. z.B. Slider mit targetPosition verknüpft, Rollo-Darstellung mit currentPosition). Mit den mir bekannten Widgets kann man allerdings nur einen Wert verknüpfen, normalerwise natürlich den target-Wert. Gelöst habe ich das jetzt, in dem ich mir das alles aus einzelnen Widgets zusammenstelle. Ist dir (oder jemand anderem hier im Forum) ein Widget bekannt, dass das bereits kann?
