  4. Absturz jede Nacht - ECONNRESET - ECONNREFUSED
econnreseteconnrefusedabsturz
30 Beiträge 4 Kommentatoren 3.4k Aufrufe 3 Beobachtet
    besa
    Also nachdem was ich gegoogelt habe ist der Port 6379 mit dem Localhost der Redis-Server. Rufe ich den Redis-Server auf bekomme ich folgende Meldungen:
    linaro@tinkerboard:~$ redis-server
    15933:C 07 Jul 06:46:31.001 # Warning: no config file specified, using the defau                                  lt config. In order to specify a config file use redis-server /path/to/redis.con                                  f
    15933:M 07 Jul 06:46:31.004 * Increased maximum number of open files to 10032 (i                                  t was originally set to 1024).
    15933:M 07 Jul 06:46:31.005 # Warning: 32 bit instance detected but no memory li                                  mit set. Setting 3 GB maxmemory limit with 'noeviction' policy now.
                    _._
               _.-``__ ''-._
          _.-``    `.  `_.  ''-._           Redis 3.2.6 (00000000/0) 32 bit
      .-`` .-```.  ```\/    _.,_ ''-._
     (    '      ,       .-`  | `,    )     Running in standalone mode
     |`-._`-...-` __...-.``-._|'` _.-'|     Port: 6379
     |    `-._   `._    /     _.-'    |     PID: 15933
      `-._    `-._  `-./  _.-'    _.-'
     |`-._`-._    `-.__.-'    _.-'_.-'|
     |    `-._`-._        _.-'_.-'    |           http://redis.io
      `-._    `-._`-.__.-'_.-'    _.-'
     |    `-._`-._        _.-'_.-'    |
          `-._    `-.__.-'    _.-'
              `-._        _.-'
                  `-.__.-'
    15933:M 07 Jul 06:46:31.007 # WARNING: The TCP backlog setting of 511 cannot be                                   enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
    15933:M 07 Jul 06:46:31.007 # Server started, Redis version 3.2.6
    15933:M 07 Jul 06:46:31.008 # WARNING overcommit_memory is set to 0! Background                                   save may fail under low memory condition. To fix this issue add 'vm.overcommit_m                                  emory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.ove                                  rcommit_memory=1' for this to take effect.
    15933:M 07 Jul 06:46:31.010 * The server is now ready to accept connections on port 6379
    • B besa
                      _._
                 _.-``__ ''-._
       |    `-._`-._        _.-'_.-'    |
            `-._    `-.__.-'    _.-'
                `-._        _.-'
                    `-.__.-'
      Meister MopperM Offline
      Meister Mopper
      @besa sagte in Absturz jede Nacht - ECONNRESET - ECONNREFUSED:
      Bei so vielen laufenden Adaptern: Wieviel Arbeitsspeicher ist denn noch frei. Gib mal 'top' in der Konsole ein und poste hier das Ergebnis.
      Proxmox und HA ...
        besa
        @Meister-Mopper
        top - 08:24:57 up 5 min,  2 users,  load average: 0,24, 0,19, 0,09
        Tasks: 183 total,   1 running, 182 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 15,0 us,  3,9 sy,  0,0 ni, 81,1 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
        KiB Mem :  2060400 total,  1609648 free,   201248 used,   249504 buff/cache
        KiB Swap:   102396 total,   102396 free,        0 used.  1826856 avail Mem
          PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
         4100 iobroker  20   0  157192  69684  26412 S  54,7  3,4   0:01.68 node
            1 root      20   0   26736   5136   3812 S   2,3  0,2   0:04.17 systemd
         4057 linaro    20   0    7160   2840   2296 R   1,6  0,1   0:00.48 top
          179 root      20   0   13904   4808   4340 S   1,3  0,2   0:01.24 systemd-jo+
          431 message+  20   0    5536   3124   2464 S   1,0  0,2   0:00.88 dbus-daemon
          623 root      20   0    4412   1772   1540 S   1,0  0,1   0:01.07 link_monit+
          913 root      20   0  194760  56052  41768 S   0,7  2,7   0:03.08 Xorg
         4194 redis     20   0       0      0      0 D   0,7  0,0   0:00.02 run-parts
            7 root      20   0       0      0      0 S   0,3  0,0   0:00.24 rcu_sched
           24 root      20   0       0      0      0 S   0,3  0,0   0:00.06 kworker/3:0
           97 root      20   0       0      0      0 S   0,3  0,0   0:00.23 kworker/u8+
          134 root      20   0       0      0      0 S   0,3  0,0   0:00.03 kworker/u8+
          486 root      20   0   23100   2236   1676 S   0,3  0,1   0:00.24 rsyslogd
          622 root      20   0    3424    348    304 S   0,3  0,0   0:00.04 tail
            2 root      20   0       0      0      0 S   0,0  0,0   0:00.01 kthreadd
            3 root      20   0       0      0      0 S   0,0  0,0   0:00.03 ksoftirqd/0
            5 root       0 -20       0      0      0 S   0,0  0,0   0:00.00 kworker/0:+
        Meister MopperM Thomas BraunT 2 Antworten Letzte Antwort
        • B besa
          @Meister-Mopper
          Meister Mopper
          @besa Der wirft ja nur KiB aus, bei mir MiB:
          Tasks:  64 total,   2 running,  62 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 90.3 us,  0.0 sy,  0.0 ni,  9.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   4096.0 total,    983.8 free,   2744.1 used,    368.0 buff/cache
          MiB Swap:   2048.0 total,   2017.5 free,     30.5 used.   1351.9 avail Mem
          Proxmox und HA ...
          • B besa
            @Meister-Mopper
            @besa Konsolenausgaben bitte in CodeTags setzen.
            Dann das System ohne laufenden X-Server betreiben.
              besa
              @Meister-Mopper
              Datenträger verfügbar: 49.2 %, gesamte RAM-Nutzung: 987 MB / Frei: 62% = 1.241 MB [Host: tinkerboard - 20 Prozesse]
              Ich habe deshalb ein MULTI-HOST System eingerichtet und ein Teil gestern ausgelagert. Das brachte aber auch keinen Erfolg. MIt über 62% freien Speicher glaube ich hier nicht an einen Speicherfehler. Aber es könnte natürlich sein, dass der Redis-Server in einen Overflow oder Speicherengpass kommt, daher erst nachts. Tagsüber habe ich bisher immer einen Neustart gehabt.
                besa
                @Thomas-Braun
                Mit X-Server meinst Du ohne Redis-Server, oder ?. Ja dann wird es sehr langsam.
                • B besa
                  @Thomas-Braun
                  @besa Nein, ich meine die graphische Oberfläche des Systems. Die läuft da unnötiger Weise mit und frisst Ressourcen.
                  uname -a
                  who -r
                    uname -a
                    who -r
                    besa
                    @Thomas-Braun
                    AH Danke. Sehe gerade dass Redis mir folgendes meldet:
                    7908:M 07 Jul 08:48:04.146 # Background saving error
                    7908:M 07 Jul 08:48:10.062 * 100 changes in 300 seconds. Saving...
                    7908:M 07 Jul 08:48:10.063 * Background saving started by pid 19857
                    19857:C 07 Jul 08:48:10.063 # Failed opening the RDB file dump.rdb (in server root dir /etc/redis) for saving: Permission denied
                    • B besa
                      @Thomas-Braun
                      besa
                      @besa
                      Das ständig mit einer neuen PID
                      • B besa
                        @besa
                        @besa Alles krumm aufgesetzt, scheint mir.
                        Aber ohne Konsolenrückmeldung keine Hilfe möglich. Viel Spaß noch, ich bin dann raus.
                          besa
                          @Thomas-Braun
                          Sorry
                          Hier die Rückmeldung
                          linaro@tinkerboard:/etc/redis$ uname -a
                          Linux tinkerboard 4.4.132+ #1 SMP Wed Aug 21 19:15:55 CST 2019 armv7l GNU/Linux
                          linaro@tinkerboard:/etc/redis$ who -r
                                   Runlevel 5   2020-07-07 08:19
                          N 1 Antwort Letzte Antwort
                          • B besa
                            @Thomas-Braun
                            Sorry
                            N Offline
                            N Offline
                            Nordischerjung
                            @besa
                            setze mal deine kopierten Zeilen von der Konsole in Code tags </> diese Symbol anklicken und dazwischen einfügen
                            dann ercheint in der Antwort diese Fenster
                            hier steht dann dein Text
                            Gruß Nordischerjung
                            sonnige Grüße von der Ostsee
                            • N Nordischerjung
                              @besa
                              besa
                              @Nordischerjung
                              • N Offline
                                N Offline
                                Nordischerjung
                                schrieb am zuletzt editiert von Nordischerjung
                                @besa
                                guck mal hier, da hat @Thomas-Braun mir mal erklärt, das der Runlevel 5 nicht gut für ein Server ist. Vielleicht solltest du den mal auf Level 3 ändern, weiß aber nicht ob die Befehle die gleichen sind.
                                https://forum.iobroker.net/topic/33702/iobroker-startet-sporadisch-neu/20
                                da kann @Thomas-Braun dir bestimmt weiterhelfen
                                Gruß Nordischerjung
                                • N Nordischerjung
                                  @besa
                                  besa
                                  @Nordischerjung
                                  Gemäß der Anleitung von Thomas- Braun habe ich auf Runlevel 3 umgestellt
                                  sudo whoami
                                  systemctl get-default
                                  sudo systemctl set-default multi-user.target
                                  und dann
                                  sudo reboot
                                  Dann
                                  linaro@tinkerboard:/opt/iobroker$ who -r
                                           Runlevel 3   2020-07-07 09:30
                                  Ergebnis: IOBROKER läuft nicht mehr.
                                  • B besa
                                    @Nordischerjung
                                    sudo whoami
                                    und dann
                                    sudo reboot
                                    Dann
                                    besa
                                    @besa
                                    dann den Redis Server manuell gestartet mit
                                    redis-server
                                    IOBROKER läuft wieder !!!!!!!!!
                                    aber Redis gibt folgende Meldungen aus
                                    6122:C 07 Jul 09:40:36.703 # Warning: no config file specified, using the default config. In order to specify a config file use redis-server /path/to/redis.conf
                                    6122:M 07 Jul 09:40:36.704 * Increased maximum number of open files to 10032 (it was originally set to 1024).
                                    6122:M 07 Jul 09:40:36.705 # Warning: 32 bit instance detected but no memory limit set. Setting 3 GB maxmemory limit with 'noeviction' policy now.
                                                    _._
                                               _.-``__ ''-._
                                     |    `-._   `._    /     _.-'    |     PID: 6122
                                     |    `-._`-._        _.-'_.-'    |
                                          `-._    `-.__.-'    _.-'
                                              `-._        _.-'
                                                  `-.__.-'
                                    6122:M 07 Jul 09:40:36.706 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
                                    6122:M 07 Jul 09:40:36.706 # Server started, Redis version 3.2.6
                                    6122:M 07 Jul 09:40:36.706 * The server is now ready to accept connections on port 6379
                                    ^C6122:signal-handler (1594107715) Received SIGINT scheduling shutdown...
                                    6122:M 07 Jul 09:41:55.917 # User requested shutdown...
                                    6122:M 07 Jul 09:41:55.917 * Saving the final RDB snapshot before exiting.
                                    6122:M 07 Jul 09:41:55.955 * DB saved on disk
                                    6122:M 07 Jul 09:41:55.955 # Redis is now ready to exit, bye bye...
                                    • B besa
                                      @besa
                                      redis-server
                                                      _._
                                                 _.-``__ ''-._
                                       |    `-._`-._        _.-'_.-'    |
                                            `-._    `-.__.-'    _.-'
                                                `-._        _.-'
                                                    `-.__.-'
                                      besa
                                      @besa
                                      und schmiert beim laden der Instanzen ab........
                                      • B besa
                                        @besa
                                        besa
                                        @besa
                                        und kommt dann wieder. Sowas.
                                          besa
                                          So ich dokumentiere einmal den letzten Stand. Irgendwie hat sich der REDIS Server anscheinend in der Nacht verabschiedet. Ich habe daher folgendes gemacht
                                          Gem Rat von Thomas Braun hatte ich auf Runlevel 5 umgestellt. Aufruf von TOP ergibt jetzt:
                                          top - 16:42:06 up  4:41,  1 user,  load average: 1,31, 1,37, 1,36
                                          Tasks: 171 total,   2 running, 165 sleeping,   0 stopped,   4 zombie
                                          %Cpu(s):  6,7 us, 28,0 sy,  0,0 ni, 65,0 id,  0,0 wa,  0,0 hi,  0,3 si,  0,0 st
                                          KiB Mem :  2060400 total,   844668 free,   887164 used,   328568 buff/cache
                                          KiB Swap:   102396 total,   102396 free,        0 used.  1142028 avail Mem
                                          Ich hatte weiterhin den Redis Server deinstalliert mit
                                          sudo apt-get purge --auto-remove redis-server
                                          Dann gemäß der Anleitung unter
                                          how-to-install-and-secure-redis-on-ubuntu-18-04
                                          Hier die Kurzversion
                                          sudo apt update
                                          sudo apt install redis-server
                                          den Redis-Server neuinstalliert. Dann noch die Dateirechte geändert
                                          sudo chmod -R -v 777 /etc/redis
                                          und in redis.conf mit
                                          sudo nano /etc/redis/redis.conf
                                          bind 0.0.0.0
                                          supervised systemd
                                          protected-mode yes (unverändert)
                                          ergänzt.
                                          Dauerhaften Start eingetragen mit
                                          sudo systemctl restart redis.service
                                          Redis überprüft mit
                                          sudo systemctl status redis
                                          $ redis-cli ping
                                          PONG
                                          und ein Reboot durchgeführt. Dann musste ich nochmals das MULTIHOST system mit
                                          iobroker stop
                                          sudo iobroker multihost enable
                                          inkl. Passwort Eingabe initialisieren. Jetzt läuft alles und ich bin gespannt ob es auch über Nacht so bleibt. Falls ja werde ich es ergänzen oder morgen hier heulen.
                                          Danke und Viele Grüße
                                          Bernd
