  4. Fehler beim installieren vom mihome Vacuum Adapter
    5.4k
adapter fehlermihome vacuum
7 Beiträge 3 Kommentatoren 1.7k Aufrufe 3 Beobachtet
  • E Offline
    Ente
    schrieb am zuletzt editiert von Ente
    Hallo an alle,
    ich wollte heut Abend den Adapter von 1.1.5 auf 2.0.7 updaten. Anscheinend wurde er deinstalliert, da er nicht in der Übersicht auftaucht, aber installieren kann ich die neue Version nicht.
    Kann das bitte jemand übersetzen?
    Danke schön.
    Viele Grüße
    Chris
    $ ./iobroker add mihome-vacuum  --host raspberrypi
    NPM version: 6.14.4
    npm install iobroker.mihome-vacuum@2.0.7 --loglevel error --prefix "/opt/iobroker" (System call)
    Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' foundgyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp
     ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:315:20)gyp ERR! stack
         at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.19.118-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v
     v12.17.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    node-pre-gyp
     ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:315:20)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
    node-pre-gyp ERR! System Linux 4.19.118-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v12.17.0
    node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
    npm
     ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR!
     canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR!
     npm
    ERR! Failed at the canvas@2.6.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-06-25T21_39_36_498Z-debug.log
    ERROR: host.raspberrypi Cannot install iobroker.mihome-vacuum@2.0.7: 1
    • E Ente
      Hallo an alle,
      Danke schön.
      Viele Grüße
      Chris
      NPM version: 6.14.4
      gyp
      node-pre-gyp
       ERR! build error
      npm
      npm ERR! errno 1
      npm ERR!
       npm
      @Ente canvas bauen. Steht in zig Threads wie man das macht. Nutze die Suchfunktion.
      E 1 Antwort Letzte Antwort
        Ente
        @Thomas-Braun
        Jetzt bin ich leider nicht schlauer als zuvor. Beim Suchen nach canvas kamen Ergebnisse, die - so zumindest mein Eindruck - nichts mit meinem Problem zu tun haben.
        • E Ente
          @Thomas-Braun
          @Ente
          sudo apt install libpixman-1-dev libpango1.0-dev libjpeg62-turbo-dev libgif-dev
          cd /opt/iobroker
          npm rebuild canvas --build-from-source
          npm install canvas
          Dein node12 könntest du zuvor auch updaten.
          Wenn sauber installiert:
          sudo apt update
          sudo apt upgrade
          E M 2 Antworten Letzte Antwort
            @Ente
            cd /opt/iobroker
            npm install canvas
            sudo apt update
            sudo apt upgrade
            Ente
            @Thomas-Braun
            Danke schön. 😊
            • E Ente
              @Thomas-Braun
              Danke schön. 😊
              Ente
              Updates liefen erfolgreich durch.
              Danke schön @Thomas-Braun
                @Ente
                cd /opt/iobroker
                npm install canvas
                sudo apt update
                sudo apt upgrade
                Michaelnorge
                @thomas-braun Danke!
                • Smart mit: Rasp 4B / ioBroker / Conbee2 / Trådfri / Xiaomi / HUE / Logitech Harmony / Aqara / Easee Wallbox / Hyundai Ioniq / Alexa / Google Home / Fully Kiosk / VIS
