<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fehler beim installieren vom mihome Vacuum Adapter]]></title><description><![CDATA[<p dir="auto">Hallo an alle,</p>
<p dir="auto">ich wollte heut Abend den Adapter von 1.1.5 auf 2.0.7 updaten. Anscheinend wurde er deinstalliert, da er nicht in der Übersicht auftaucht, aber installieren kann ich die neue Version nicht.</p>
<p dir="auto">Kann das bitte jemand übersetzen?</p>
<p dir="auto">Danke schön.<br />
Viele Grüße<br />
Chris</p>
<pre><code>$ ./iobroker add mihome-vacuum  --host raspberrypi
NPM version: 6.14.4
npm install iobroker.mihome-vacuum@2.0.7 --loglevel error --prefix "/opt/iobroker" (System call)
Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' foundgyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
gyp
 ERR! configure error
gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:315:20)gyp ERR! stack
     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.19.118-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v
 v12.17.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
node-pre-gyp
 ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)node-pre-gyp ERR! stack     at ChildProcess.&lt;anonymous&gt; (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:315:20)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
node-pre-gyp ERR! System Linux 4.19.118-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v12.17.0
node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
npm
 ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR!
 canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR!
 npm
ERR! Failed at the canvas@2.6.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-06-25T21_39_36_498Z-debug.log
ERROR: host.raspberrypi Cannot install iobroker.mihome-vacuum@2.0.7: 1
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/34724/fehler-beim-installieren-vom-mihome-vacuum-adapter</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 12:11:51 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/34724.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 25 Jun 2020 21:44:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fehler beim installieren vom mihome Vacuum Adapter on Fri, 28 Apr 2023 12:23:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> Danke!</p>
]]></description><link>https://forum.iobroker.net/post/984983</link><guid isPermaLink="true">https://forum.iobroker.net/post/984983</guid><dc:creator><![CDATA[Michaelnorge]]></dc:creator><pubDate>Fri, 28 Apr 2023 12:23:32 GMT</pubDate></item><item><title><![CDATA[Reply to Fehler beim installieren vom mihome Vacuum Adapter on Sat, 04 Jul 2020 18:26:49 GMT]]></title><description><![CDATA[<p dir="auto">Updates liefen erfolgreich durch.</p>
<p dir="auto">Danke schön <a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a></p>
]]></description><link>https://forum.iobroker.net/post/458353</link><guid isPermaLink="true">https://forum.iobroker.net/post/458353</guid><dc:creator><![CDATA[Ente]]></dc:creator><pubDate>Sat, 04 Jul 2020 18:26:49 GMT</pubDate></item><item><title><![CDATA[Reply to Fehler beim installieren vom mihome Vacuum Adapter on Mon, 29 Jun 2020 08:34:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a><br />
Danke schön.  <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f60a.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--blush" style="height:23px;width:auto;vertical-align:middle" title=":blush:" alt="😊" /></p>
]]></description><link>https://forum.iobroker.net/post/456479</link><guid isPermaLink="true">https://forum.iobroker.net/post/456479</guid><dc:creator><![CDATA[Ente]]></dc:creator><pubDate>Mon, 29 Jun 2020 08:34:18 GMT</pubDate></item><item><title><![CDATA[Reply to Fehler beim installieren vom mihome Vacuum Adapter on Fri, 26 Jun 2020 21:46:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ente" aria-label="Profile: Ente">@<bdi>Ente</bdi></a></p>
<pre><code>sudo apt install libpixman-1-dev libpango1.0-dev libjpeg62-turbo-dev libgif-dev
cd /opt/iobroker
npm rebuild canvas --build-from-source
npm install canvas
</code></pre>
<p dir="auto">Dein node12 könntest du zuvor auch updaten.<br />
Wenn sauber installiert:</p>
<pre><code>sudo apt update
sudo apt upgrade
</code></pre>
]]></description><link>https://forum.iobroker.net/post/455337</link><guid isPermaLink="true">https://forum.iobroker.net/post/455337</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 26 Jun 2020 21:46:59 GMT</pubDate></item><item><title><![CDATA[Reply to Fehler beim installieren vom mihome Vacuum Adapter on Fri, 26 Jun 2020 20:51:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a><br />
Jetzt bin ich leider nicht schlauer als zuvor. Beim Suchen nach canvas kamen Ergebnisse, die - so zumindest mein Eindruck - nichts mit meinem Problem zu tun haben.</p>
]]></description><link>https://forum.iobroker.net/post/455319</link><guid isPermaLink="true">https://forum.iobroker.net/post/455319</guid><dc:creator><![CDATA[Ente]]></dc:creator><pubDate>Fri, 26 Jun 2020 20:51:04 GMT</pubDate></item><item><title><![CDATA[Reply to Fehler beim installieren vom mihome Vacuum Adapter on Thu, 25 Jun 2020 22:06:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ente" aria-label="Profile: Ente">@<bdi>Ente</bdi></a> canvas bauen. Steht in zig Threads wie man das macht. Nutze die Suchfunktion.</p>
]]></description><link>https://forum.iobroker.net/post/454893</link><guid isPermaLink="true">https://forum.iobroker.net/post/454893</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 25 Jun 2020 22:06:13 GMT</pubDate></item></channel></rss>
