  4. Fehlermeldungen bei Updates
    2.4k
    2.8k
    1.6k
update adapter
18 Beiträge 5 Kommentatoren 1.8k Aufrufe 5 Beobachtet
  • amg_666A Offline
    amg_666A Offline
    amg_666
    Hallo, ich bekomme neuerdings bei Updates oder Neuinstallationen jede Menge Fehlermeldungen/Warnings angezeigt (egal bei welchem Adapter), die Installationen selbst sind aber erfolgreich.
    Heute z.B. bei einem Update von tr-064. Am Ende funktioniert zwar alles aber ich würde das System schon gerne "sauber" haben damit auch Updates einwandfrei durchlaufen:
    $ ./iobroker upgrade tr-064
    Update tr-064 from @4.0.3 to @4.0.4
    NPM version: 6.14.4
    npm install iobroker.tr-064@4.0.4 --loglevel error --prefix "/opt/iobroker" (System call)
    Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' found
    gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp
     ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:310:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 4.19.66-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v12.16.3gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:310:20)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
    node-pre-gyp ERR! System Linux 4.19.66-v7+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v12.16.3node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp
     ERR! not ok
    ERR!
     sharp Use with glibc 2.24 requires manual installation of libvips >= 8.9.1info sharp Attempting to build from source via node-gyp but this may fail due to the above errorinfo sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
    ../src/common.cc:23:22: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden #include <vips/vips8>                      ^
    compilation terminated.
    make: *** [Release/obj.target/sharp/src/common.o] Fehler 1
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:310:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 4.19.66-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/sharpgyp ERR! node -v v12.16.3gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
    Update "system.adapter.tr-064.0"
    upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
    upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
    Adapter "tr-064" updated
    process exited with code 0
    3 Raspberry Pi im Master/Slave Verbund, alle mit node-js v12.16.3, npm 6.14.4 und js-controller 3.1.4.
    Die erste Fehlermeldung im Log mit der package "pixman-1 not found" habe ich in diversen Foren gefunden aber keine Antwort dazu die ich auch verstehe :-)
    Kann mir hier jemand weiter helfen?
    Andreas
    Thomas BraunT arteckA 2 Antworten Letzte Antwort
    • amg_666A amg_666
      NPM version: 6.14.4
      gyp
       ERR! not ok
      ERR!
      Andreas
      @amg_666 sagte in Fehlermeldungen bei Updates:
      pixman-1
      sudo apt install libpixman-1-dev libpango1.0-dev libjpeg62-turbo-dev libgif-dev
      cd /opt/iobroker
      npm rebuild canvas --build-from-source
      • amg_666A amg_666
        NPM version: 6.14.4
        gyp
         ERR! not ok
        ERR!
        Andreas
        arteckA Offline
        arteckA Offline
        arteck
        ist doch alles gut.. das ist wichtig...
        einen sauberen LOG wirst du nicht immer bekommen da die instlls nicht nur für DEIN System konfiguriert sind sondern die werden bei installation live gebaut.. und wenn diese nicht gebaut werden können dann wird halt Fehler geschmissen
        also
        ist wichtig am Ende
        • arteckA arteck
          also
          ist wichtig am Ende
          amg_666A Offline
          amg_666A Offline
          amg_666
          @arteck Das ist richtig, das die updates mit "code 0" abgeschlossen werden war mir klar. Bei Installationen/Updates gibt es immer Warnings und Erros, ich fand aber die reine Anzahl der Fehlermeldungen mittlerweise sehr hoch...
          • amg_666A amg_666
            arteckA Offline
            arteckA Offline
            arteck
            @amg_666 was heisst den mittlerweile.. das kann ich als Entwickler enstellen was du siehst.. und das ist von Adapter zu Adapter unerschiedlich.. da jeder Adapter unterschiedliche Abhängigkeiten hat
            also ignorieren..
            • arteckA arteck
              also ignorieren..
              amg_666A Offline
              amg_666A Offline
              amg_666
              @arteck Das mag ein subjektiver Eindruck sein aber in den letzten Wochen habe ich gefühlt viel längere Fehlermeldungen. Keine Ahnung warum aber die einzige größere Änderung an meinem System war ein Upgrade auf node.js 12.16.3. Aber ob es damit zusammenhängt weiß ich nicht.
              • XxJooOX Offline
                XxJooOX Offline
                XxJooO
                ich möchte mich hier mal anhängen, da ich das Erlebte von @amg_666 nachvollziehen kann und bei mir auch so nach der node 12.16 aufgetreten ist. Auch bei mir steht am Ende eines Adapter-Updates
                exited with code 0
                @Thomas-Braun sagte in Fehler nach Update:
                @Marcus-Hamburg Da hast du aber noch ein paar Leichen im gyp-Keller.
                Hallo @Thomas-Braun,
                könntest Du bitte mal einen Satz dazu schreiben, woher diese
                gyp ERR!
                node-pre-gyp ERR!
                Meldungen kommen? Ich hatte das erstmals gesehen, nachdem ich node von 10.x auf 12.x geupdatet habe. Der Broker läuft unauffällig, deshalb habe ich nichts weiter unternommen. Allerdings hatten aus der Anleitung zum Versionsupdate von node die Hinweise bis zum iobroker rebuild bei mir nicht geholfen, diese Meldungen zu unterdrücken. Ich habe dann neu installiert, die Meldungen kommen aber immer wieder, auch bei Updates von Adaptern.
                Ich kann nachvollziehen, dass man das was @arteck geschrieben hat durchaus einfach durchgehen lässt. Allerdings hat der Linux-Spezialist @Thomas-Braun das als Leichen bezeichnet und für mich bedutet das, dass da was hängt und geändert respektive auf meinem System verbessert werden könnte. Und ansonsten lernen wir was dazu!
                Vielen Dank
                ioBroker auf Intel NUC - Homematic CCU3/pivCCU auf Raspi 3B+
                GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                • XxJooOX XxJooO
                  exited with code 0
                  gyp ERR!
                  node-pre-gyp ERR!
                  Vielen Dank
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @XxJooO sagte in Fehlermeldungen bei Updates:
                  exited with code 0
                  es ist schon interessant was auch davor steht !!
                  @amg_666 hat die Meldung mit canvas und @Thomas-Braun hat Ihm daraufhin eine Codezeile genannt ... aber keine Antwort bekommen .
                  Was bei dir ist kann man nur jetzt Raten ;)
                  • XxJooOX XxJooO
                    exited with code 0
                    gyp ERR!
                    node-pre-gyp ERR!
                    Vielen Dank
                    gyp ERR!
                    node-pre-gyp ERR!
                    Meldungen kommen?
                    Die kommen von abgebrochenen Versuchen node-Module zu bauen. Oft fehlen da developer-Pakete, z. B. bei dem beliebten pixman-1/canvas.
                    gyp schleppt diese Fehlversuche solange mit, bis das Modul sauber im System ist. Deswegen wird die Liste der Leichen auch immer länger.
                    • GlasfaserG Glasfaser
                      exited with code 0
                      amg_666A Offline
                      amg_666A Offline
                      amg_666
                      @Glasfaser ok, sorry das ich hier kein Feedback gegeben habe. Nach dem Canvas rebuild Befehl ging bei mir nix mehr, ich hab den iobroker nicht mehr gestartet bekommen (was auch imer da zerschossen war). Ich habe darauf ein backup eingespielt und wie @arteck empfohlen hat, ignoriere ich das im Moment.
                      • XxJooOX Offline
                        XxJooOX Offline
                        XxJooO
                        Hallo Leute,
                        heute erst meinerseits ein Update über die Meldungen, die bei mir kommen. Kann jemand daraus ableiten, was vielleicht im Argen liegt?
                        $ ./iobroker upgrade hm-rpc
                        Update hm-rpc from @1.14.11 to @1.14.12
                        NPM version: 6.14.5
                        npm install iobroker.hm-rpc@1.14.12 --loglevel error --prefix "/opt/iobroker" (System call)
                        In file included from ../authenticate_pam.cc:23:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
                        ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);        ^In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1026:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);        ^In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1026:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~
                        ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:../authenticate_pam.cc:147:83: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.18.2/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.2/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.2/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.18.2/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.18.2/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], long unsigned int)’    serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);        ^In file included from /home/iobroker/.cache/node-gyp/12.18.2/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.18.2/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.2/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:152:69: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.18.2/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.2/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.2/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.18.2/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.18.2/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
                        ../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], long unsigned int)’    remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);        ^In file included from /home/iobroker/.cache/node-gyp/12.18.2/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.18.2/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.2/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], long unsigned int)’  username->WriteUtf8(m->username, sizeof(m->username) - 1);                                                          ^In file included from /home/iobroker/.cache/node-gyp/12.18.2/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.18.2/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.2/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], long unsigned int)’  password->WriteUtf8(m->password, sizeof(m->password) - 1);                                                          ^In file included from /home/iobroker/.cache/node-gyp/12.18.2/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.18.2/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.2/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc: At global scope:../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void void init(Handle<Object> exports) {           ^~~~~~../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
                        ../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’ void init(Handle<Object> exports) {           ^~~~~~           rand_r../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token void init(Handle<Object> exports) {                        ^../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope void init(Handle<Object> exports) {                          ^~~~~~~
                        In file included from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope NODE_MODULE(authenticate_pam, init);                               ^~~~/home/iobroker/.cache/node-gyp/12.18.2/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~
                        ../authenticate_pam.cc:175:31: note: suggested alternative: ‘int’ NODE_MODULE(authenticate_pam, init);                               ^~~~/home/iobroker/.cache/node-gyp/12.18.2/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~
                        make: *** [authenticate_pam.target.mk:111: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
                        gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:315:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                        gyp ERR! System Linux 4.19.0-9-amd64gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v12.18.2gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
                        Update "system.adapter.hm-rpc.2"
                        upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/94_hm-mod-re-8_thumb.png icons/94_hm-mod-re-8_thumb.png image/png
                        gekürzt
                        upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/100_hm-rc-8_thumb.png icons/100_hm-rc-8_thumb.png image/png
                        upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
                        Adapter "hm-rpc" updated
                        Vielen Dank fürs drüber schauen!
                        • XxJooOX XxJooO
                          Hallo Leute,
                          NPM version: 6.14.5
                          gekürzt
                          @XxJooO Vermutlich ein Versionskonflikt.
                          lsb_release -a
                          nodejs -v && node -v && npm -v
                          XxJooOX 1 Antwort Letzte Antwort
                            lsb_release -a
                            XxJooOX Offline
                            XxJooOX Offline
                            XxJooO
                            @Thomas-Braun sagte in Fehlermeldungen bei Updates:
                            lsb_release -a
                            iobroker@ioBrokerDebian10VM:~$ lsb_release -a
                            No LSB modules are available.
                            Distributor ID: Debian
                            Description:    Debian GNU/Linux 10 (buster)
                            Release:        10
                            Codename:       buster
                            iobroker@ioBrokerDebian10VM:~$ nodejs -v && node -v && npm -v
                            v12.18.2
                            v12.18.2
                            6.14.5
                            • XxJooOX XxJooO
                              lsb_release -a
                              Release:        10
                              Codename:       buster
                              v12.18.2
                              v12.18.2
                              6.14.5
                              @XxJooO Von der Kernel-Version her hätte ich gedacht das sei was älteres als Buster.
                              Rest-System auf Stand?
                              sudo apt update
                              sudo apt dist-upgrade
                              XxJooOX 2 Antworten Letzte Antwort
                                sudo apt update
                                XxJooOX Offline
                                XxJooOX Offline
                                XxJooO
                                sudo apt update sudo apt dist-upgrade
                                Sollte up to date sein, ich lass es aber nochmal laufen.
                                  sudo apt update
                                  XxJooOX Offline
                                  XxJooOX Offline
                                  XxJooO
                                  @Thomas-Braun
                                  iobroker@ioBrokerDebian10VM:~$ sudo apt update
                                  Holen:1 http://security.debian.org/debian-security buster/updates InRelease [65,4 kB]
                                  OK:2 http://deb.debian.org/debian buster InRelease
                                  Holen:3 http://deb.debian.org/debian buster-updates InRelease [51,9 kB]
                                  Holen:4 http://security.debian.org/debian-security buster/updates/main Sources [130 kB]
                                  Holen:5 http://security.debian.org/debian-security buster/updates/main amd64 Packages [208 kB]
                                  OK:6 https://deb.nodesource.com/node_12.x buster InRelease
                                  Es wurden 455 kB in 1 s geholt (480 kB/s).
                                  Alle Pakete sind aktuell.
                                  iobroker@ioBrokerDebian10VM:~$ sudo apt dist-upgrade
                                  Paketaktualisierung (Upgrade) wird berechnet... Fertig
                                  0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                  Konsequenz wäre also tatsächlich ignorieren?
                                  • XxJooOX XxJooO
                                    @Thomas-Braun
                                    @XxJooO Ja, würde ich ignorieren. Da ist zwar irgendwas mit PAM nicht ganz gerade, kann aber auch mit der VM zusammenhängen.
                                    • XxJooOX Offline
                                      XxJooOX Offline
                                      XxJooO
                                      Danke für Deine Einschätzung!
                                      83.2k
