  4. Zigbee Adapter CC2531 startet neu
    5.6k
zigbee cc2531zigbeerestart
4 Beiträge 3 Kommentatoren 546 Aufrufe 3 Beobachtet
  • Z Offline
    Z Offline
    zombiee77
    nachdem ich den eine Glühbirne angemacht habe und sie wieder ausmachen wollte, funktioniert es nicht und ich bekomme folgenden Log-Eintrag:
    zigbee.0	2020-07-01 07:19:37.745	info	(1361914) Zigbee started
    zigbee.0	2020-07-01 07:19:37.745	info	(1361914) 0x00124b001bb85f86 (addr 13083): CC2530.ROUTER - Custom devices (DiY) [CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/) (Router)
    zigbee.0	2020-07-01 07:19:37.743	info	(1361914) 0x7cb03eaa0a03a443 (addr 52080): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
    zigbee.0	2020-07-01 07:19:37.741	info	(1361914) 0x00158d000327c91d (addr 43085): 404006/404008/404004 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white (Router)
    zigbee.0	2020-07-01 07:19:37.739	info	(1361914) 0x00124b001949b7ed (addr 16043): CC2530.ROUTER - Custom devices (DiY) [CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/) (Router)
    zigbee.0	2020-07-01 07:19:37.733	info	(1361914) Currently 4 devices are joined:
    zigbee.0	2020-07-01 07:19:37.709	info	(1361914) --> transmitPower : normal
    zigbee.0	2020-07-01 07:19:37.697	info	(1361914) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190608}}
    zigbee.0	2020-07-01 07:19:35.759	info	(1361914) Starting Zigbee...
    zigbee.0	2020-07-01 07:19:35.706	info	(1361914) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.21.0, js-controller: 3.1.6
    host.ZBOX-NANO-Linux	2020-07-01 07:19:33.136	info	instance system.adapter.zigbee.0 started with pid 1361914
    host.ZBOX-NANO-Linux	2020-07-01 07:19:03.110	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.ZBOX-NANO-Linux	2020-07-01 07:19:03.105	info	instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
    zigbee.0	2020-07-01 07:19:02.542	info	(4040692) Terminated (NO_ERROR): Without reason
    zigbee.0	2020-07-01 07:19:02.539	info	(4040692) terminating
    zigbee.0	2020-07-01 07:19:02.141	info	(4040692) Zigbee: disabling joining new devices.
    zigbee.0	2020-07-01 07:19:02.133	info	(4040692) cleaned everything up...
    zigbee.0	2020-07-01 07:19:02.128	error	at process._tickCallback (internal/process/next_tick.js:68:7)
    zigbee.0	2020-07-01 07:19:02.128	error	at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:199:19)
    zigbee.0	2020-07-01 07:19:02.128	error	at Array.forEach (<anonymous>)
    zigbee.0	2020-07-01 07:19:02.128	error	at stateList.forEach (/opt/iobroker/node_modules/iobroker.zigbee/main.js:207:63)
    zigbee.0	2020-07-01 07:19:02.128	error	(4040692) ReferenceError: syncStateList is not defined
    zigbee.0	2020-07-01 07:19:02.126	error	(4040692) unhandled promise rejection: syncStateList is not defined
    Habt Ihr eine Idee, was genau nicht stimmt?
    LG
    z
    • Z zombiee77
      LG
      z
      arteckA Offline
      arteckA Offline
      arteck
      @zombiee77 sagte in Zigbee Adapter CC2531 startet neu:
      Version 1.0.4
      installiere bitte mal die GIT version
      • Z Offline
        Z Offline
        zombiee77
        Habe es grad instaliert.
        Und es funktioniert nun besser.
        Vielen Dank.
        • Z Offline
          Z Offline
          zombiee77
          Was genau bedeuten die Farben und die Zahlen?
          Wie kann ich sehen, wie der Empfang der einzelnen Teilnehmer ist?
