  4. wemos-d1-mini-infarot-mit-eignem-pcb - Diskussion
    6.7k
544 Beiträge 9 Kommentatoren 139.7k Aufrufe 11 Beobachtet
  • Ralla66R Ralla66
    @Hardwearhansi
    @Homoran
    Zur Info:
    IRsend2 wird der Code 2 mal gesendet.
    SetOption58 1 ist Pflicht bei Raw und ir.bin.
    Raw geht nur mit der tasmota ir.bin , de.bin / Generic geht kein Raw.
    Raw läuft im Kreis und geht.
    Command ist IRsend 0, dann die Raw Daten.
    0 bearbeitet das Programm, hier 38 Khz.
    Command IRsend 36,dann die Raw Daten sollte Data mit 36 Khz senden.
    Umstellung auf SetOption29 1 also Dec bringt Fehler.
    Default Wert IR_RCV_Buffer_Size im File my_user_config.h muß ich noch erkunden.
    Könnte sein das der Buffer zu klein ist ( default 100 ).
    RTL VU Taste 6
    15:57:12 MQT: tele/tasmota_14F48A/RESULT = {"IrReceived":{"Protocol":"RC6","Bits":36,"Data":"0xC80521006","DataLSB":"0x30014A0860","Repeat":0,"RawData":[2714,816,508,376,502,382,506,818,506,820,1384,824,500,384,506,378,500,382,508,378,502,382,508,376,502,382,942,824,944,822,502,382,942,824,500,384,506,378,500,384,940,826,508,376,504,380,508,376,504,380,508,374,504,380,500,384,504,378,946,380,508,818,506],"RawDataInfo":[63,63,0]}}
    IRsend 0,2714,816,508,376,502,382,506,818,506,820,1384,824,500,384,506,378,500,382,508,378,502,382,508,376,502,382,942,824,944,822,502,382,942,824,500,384,506,378,500,384,940,826,508,376,504,380,508,376,504,380,508,374,504,380,500,384,504,378,946,380,508,818,506
    IRsend empfangen Wemos 2
    16:03:54 MQT: tele/Wemos_11/RESULT = {"Time":"2020-06-17T16:03:54","IrReceived":{"Protocol":"RC6","Bits":36,"Data":"0xC80521006"}}
    DEC empfangen
    16:08:29 MQT: tele/tasmota_14F48A/RESULT = {"IrReceived":{"Protocol":"UNKNOWN","Bits":25,"Hash":3669001553,"Repeat":0,"RawData":[824,510,374,506,378,500,384,506,378,500,384,504,378,500,384,950,820,938,824,500,384,948,818,942,824,510,374,950,818,506,378,500,382,506,378,502,382,506,378,502,382,506,376,502,382,942,384,506,820,504],"RawDataInfo":[50,50,0]}}
    IRsend 0,824,510,374,506,378,500,384,506,378,500,384,504,378,500,384,950,820,938,824,500,384,948,818,942,824,510,374,950,818,506,378,500,382,506,378,502,382,506,378,502,382,506,376,502,382,942,384,506,820,504
    16:12:51 MQT: tele/Wemos_11/RESULT = {"Time":"2020-06-17T16:12:51","IrReceived":{"Protocol":"UNKNOWN","Bits":25,"Hash":"0x1909F770"}}
    36 Khz
    IRsend 36,2714,816,508,376,502,382,506,818,506,820,1384,824,500,384,506,378,500,382,508,378,502,382,508,376,502,382,942,824,944,822,502,382,942,824,500,384,506,378,500,384,940,826,508,376,504,380,508,376,504,380,508,374,504,380,500,384,504,378,946,380,508,818,506
    Leider schaltet die VU nicht.
    Da hilft wohl nur der LogicAnalyser zum vergleich oder Broadlink Data convertieren.
    Viel Arbeit so eine Protokolanalyse.
    Werde mal versuchen ob ich per LogicA den Stream mitschneiden und senden kann.
    Ganz ohne Tasmota.
    Hardwearhansi
    #304
    @Ralla66 said in wemos-d1-mini-infarot-mit-eignem-pcb - Diskussion:
    RTL VU Taste 6
    Hab dass hier nochmal angeschaut und ich versteh grad nicht wiso du raw data senden möchtest obwohl bei deiner VU fernbedinung ein Potokoll gefunden worden ist?
    Dann müsste man dass hier in die Tasmota Console eingeben:
    IRsend{"Protocol":"RC6","Bits":36,"Data":0xC80521006}
    sollte dann funktionieren sprich in der Tasmota Console muss IRsend done drin stehen
    Und dann sollte die Vu auch schalten probier mal aus und send mir den consolen outputt dann bitte nochmal
    • Ralla66R Offline
      Ralla66R Offline
      Ralla66
      #305
      @Hardwearhansi
      Sku Sensoren433 MHZ für Glasbruch und Sabotage.
      https://forum.iobroker.net/topic/22066/balkontüre-geöffnet-nach-30min-heizung-aus/11
      hatte RC6 gesendet, wird auch gesendet, habe ich ja mit im Kreisfahren geprüft.
      Box schaltet aber nicht.
      H 2 Antworten Letzte Antwort
      • Ralla66R Ralla66
        @Hardwearhansi
        Hardwearhansi
        #306
        @Ralla66 Mm okey ich versteh nicht wiso es nicht schaltet vl doch invetieren? Kann halt schlecht testen helfen da ich keine vu mehr hab
        • Ralla66R Ralla66
          @Hardwearhansi
          Hardwearhansi
          #307
          Dankeschön
          • Ralla66R Offline
            Ralla66R Offline
            Ralla66
            #308
            @Hardwearhansi
            werde gleich mal einen Kollegen kontaktieren mal sehen was der meint.
            Die Daten sind ja Glasklar im Logicanalyser.
            Dann kann das nur Invertiert oder MSB / LSB sein.
            werde mal Data LSB senden, 0x30014A0860
            so wie das aussieht gibt mein TSOP 31328 den output active low aus, bedeutet invertiert.
            Dann kann das nicht passen. :-)
            H 1 Antwort Letzte Antwort
            • Ralla66R Ralla66
              @Hardwearhansi
              Hardwearhansi
              #309
              @Ralla66 Dann brauchst du einen Anderen IR reciv ich benutzen immoment den Tsop1738
              • H Hardwearhansi
                Hardwearhansi
                schrieb am zuletzt editiert von Hardwearhansi
                #310
                @Ralla66 Welche sku sensoren für Fenster benutzt du finde die nicht auf Google
                (Hab's gefunden)
                • Ralla66R Offline
                  Ralla66R Offline
                  Ralla66
                  #311
                  @Hardwearhansi
                  im Fred der Link,
                  weiter unter wie ich die frisiert habe.
                  Vibrationssensoren habe ich noch welche.
                  Kann ich dir senden.
                  Löten kannste ja.
                  • Ralla66R Ralla66
                    @Hardwearhansi
                    im Fred der Link,
                    Löten kannste ja.
                    Hardwearhansi
                    #312
                    @Ralla66 Nene alles gut werd wahrscheinlich mit xiomi fenster Kontakte hohlen die sind schön klein😊
                    • Ralla66R Offline
                      Ralla66R Offline
                      Ralla66
                      #313
                      @Hardwearhansi
                      ich habe Gardinen davor, sieht eh keiner die Dinger :-)
                      Ja hast recht sehen häßlich aus.
                      Raw geht nun, ist ein Reichweitekonflikt.
                      Send IR SFH4550 braucht 1,5 bis 1,8 Volt bei 100 ma.
                      Werde das wohl per Spannungsteiler regeln müssen.
                      Invertierung drehe ich auch noch per Transistor.
                      • Ralla66R Ralla66
                        @Hardwearhansi
                        Hardwearhansi
                        #314
                        @Ralla66 Also lags am Ir send led okey wenn du fertig bist sag was ich auf dem pcb ändern muss
                        • Ralla66R Offline
                          Ralla66R Offline
                          Ralla66
                          #315
                          @Hardwearhansi
                          woran es gelegen hat teste ich gerade aus.
                          Hatte heute ein längeres Gespräch mit dem Kollege.
                          Das macht für mich eben nur Sinn wenn ich Linuxboxen bedienen kann
                          und das aus 5 m Entfernung..
                          Das kann ich aber easyer mit dem Broadlink.
                          Wenn dann muß dieses Projekt Hand und Fuß haben.
                          Bedeutet IRsend braucht einen Widerstand oder mehrere je nach Spannung.
                          NPN eine Frage der größe eben.
                          3 X IRsend sind bei mir 300 ma. Das muß der Transistor können.
                          Mal weg vom dem Invertierten TSOP, könnte man einen anderen kaufen.
                          Aber warum ? Spielfläche ist ja da.
                          Lass mich erst einmal richtig testen.
                          Der Ralla :-)
                          • Ralla66R Offline
                            Ralla66R Offline
                            Ralla66
                            #316
                            @Hardwearhansi
                            @Homoran
                            Testergebnisse soweit:
                            Mit der SFH4550 IRsend muß ich genau auf den IR Empfänger der VU zielen
                            hier das Feld wo das Programm angezeigt wird dann geht das.
                            Der Broadlink kann das aber anders und besser.
                            Warum ist die Frage ?
                            Abstrahlwinkel und Leistung der IR Led.
                            Der BL hat 6 Stück also je 60 Grad.
                            Dann sollte das Leistung sein.
                            Falsche IRsend die ich habe.
                            Aber welche ist im BL verbaut ?
                            H 3 Antworten Letzte Antwort
                            • Ralla66R Ralla66
                              @Hardwearhansi
                              @Homoran
                              Hardwearhansi
                              #317
                              @Ralla66 Weiß nicht welche im IR send im Broadklink sind.
                              Heißt im Klartext wir brauchen mehr Leistung auf ir send oder du brauchst andere IR send leds?
                              • H Offline
                                Hardwearhansi
                                #318
                                Der Broadlink wird ja auch mit 5V betrieben sprich du brauchst andere IR send Leds
                                • Ralla66R Ralla66
                                  @Hardwearhansi
                                  @Homoran
                                  Hardwearhansi
                                  #319
                                  @Ralla66
                                  Der Bl hat 7 stück um genau sein :
                                  ist aber auch egal 😂
                                  • H Hardwearhansi
                                    @Ralla66
                                    Hardwearhansi
                                    #320
                                    @Hardwearhansi Hab grad gesehen dass der broadlink den TSOP4838 benutzt:
                                    zu mindest schaut es danach aus
                                    • Ralla66R Offline
                                      Ralla66R Offline
                                      Ralla66
                                      #321
                                      @Hardwearhansi
                                      Ja 7, eine für die Decke ok. :-)
                                      5 Volt ist egal, wie werden die IR Send LED betrieben ?
                                      TSOP ist egal.
                                      Abstand ist eben wichtig, sollte zwischen 1,5 m und 4 m betragen.
                                      Also ist der Abstrahlwinkel plus Position im Gehäuse wichtig.
                                      Also Led max treiben nach Datasheet. Hier Widerstände und Spannung.
                                      Spannungsteiler ?
                                      Rechne mal 3 Grad Abstrahlwinkel auf 4 m wie eng die dann im Gehäuse sitzen müssen.
                                      Zumindest viel kleiner als 30 Grad.
                                      Obwohl das fürs PCB nicht entscheident ist.
                                      Der BL hat 6 sind 60 Grad, über 4m schafft der.
                                      Was sind das für IRsend Leds.
                                      • Ralla66R Ralla66
                                        @Hardwearhansi
                                        TSOP ist egal.
                                        Spannungsteiler ?
                                        Hardwearhansi
                                        #322
                                        @Ralla66 Was das für Ir send leds im Broadlink sind wprd ich auch gern wissen hab nürgends wo was gefunden hab mal bei broadlink direkt nach gefragt auch wenn ich irgendwie nicht glaub dass ich eine Antwort bekomme
                                        • H Offline
                                          Hardwearhansi
                                          #323
                                          @Ralla66 wo ich mir ziemlich sicher bin ist dass im Broadklink ir send leds mit 940 nm verbaut sind :)
