  4. Admin Seite funktioniert nach Admin update nicht mehr
    6.3k
adminupdate
35 Beiträge 3 Kommentatoren 3.6k Aufrufe 3 Beobachtet
  • Hermanito33H Hermanito33
    @Thomas-Braun ```
    So... Weiß auch nicht wie ich das hinbekommen habe....
    pi@ioBroker-Pi:/opt/iobroker $ sudo rm /usr/local/bin/node
    pi@ioBroker-Pi:/opt/iobroker $ sudo rm /usr/local/bin/npm
    pi@ioBroker-Pi:/opt/iobroker $ curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
    ## Installing the NodeSource Node.js 12.x repo...
    ## Populating apt-get cache...
    + apt-get update
    OK:1 http://archive.raspberrypi.org/debian stretch InRelease
    OK:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
    OK:3 https://deb.nodesource.com/node_10.x stretch InRelease
    ## Confirming "stretch" is supported...
    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_12.x/dists/stretch/Release'
    ## Adding the NodeSource signing key to your keyring...
    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
    OK
    ## Creating apt sources list file for the NodeSource Node.js 12.x repo...
    + echo 'deb https://deb.nodesource.com/node_12.x stretch main' > /etc/apt/sources.list.d/nodesource.list
    + echo 'deb-src https://deb.nodesource.com/node_12.x stretch main' >> /etc/apt/sources.list.d/nodesource.list
    ## Running `apt-get update` for you...
    + apt-get update
    Holen:3 https://deb.nodesource.com/node_12.x stretch InRelease [4.585 B]
    Holen:4 https://deb.nodesource.com/node_12.x stretch/main armhf Packages [775 B]
    Es wurden 5.360 B in 1 s geholt (3.784 B/s).
    ## Run `sudo apt-get install -y nodejs` to install Node.js 12.x and npm
    ## You may also need development tools to build native addons:
         sudo apt-get install gcc g++ make
    ## To install the Yarn package manager, run:
         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
         echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
         sudo apt-get update && sudo apt-get install yarn
    pi@ioBroker-Pi:/opt/iobroker $ sudo apt upgrade
    Paketaktualisierung (Upgrade) wird berechnet... Fertig
      nodejs
    1 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
    Es müssen 15,9 MB an Archiven heruntergeladen werden.
    Nach dieser Operation werden 5.960 kB Plattenplatz zusätzlich benutzt.
    Möchten Sie fortfahren? [J/n] j
    Holen:1 https://deb.nodesource.com/node_12.x stretch/main armhf nodejs armhf 12.16.3-1nodesource1 [15,9 MB]
    Es wurden 15,9 MB in 4 s geholt (3.855 kB/s).
    Lese Changelogs... Fertig
    (Lese Datenbank ... 41744 Dateien und Verzeichnisse sind derzeit installiert.)
    Vorbereitung zum Entpacken von .../nodejs_12.16.3-1nodesource1_armhf.deb ...
    Detected old npm client, removing...
    Entpacken von nodejs (12.16.3-1nodesource1) über (10.20.1-1nodesource1) ...
    nodejs (12.16.3-1nodesource1) wird eingerichtet ...
    Trigger für man-db (2.7.6.1-2) werden verarbeitet ...
    @Hermanito33
     nodejs -v && node -v && npm -v
    Hermanito33H 1 Antwort Letzte Antwort
      @Hermanito33
      Hermanito33H Offline
      Hermanito33
      @Thomas-Braun ```
      code_text
      pi@ioBroker-Pi:/opt/iobroker $  nodejs -v && node -v && npm -v
      v12.16.3
      -bash: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
        @Thomas-Braun ```
        code_text
        v12.16.3
        @Hermanito33 Log dich mal aus und wieder ein. Oder startet die Kiste durch. Wie du Lust hast.
          Hermanito33
          schrieb am zuletzt editiert von Hermanito33
          @Thomas-Braun ```
          Das sieht ganz gut aus :)
          pi@ioBroker-Pi:~ $  nodejs -v && node -v && npm -v
          v12.16.3
          v12.16.3
          6.14.4
          pi@ioBroker-Pi:~ $
            @Thomas-Braun ```
            v12.16.3
            v12.16.3
            6.14.4
            pi@ioBroker-Pi:~ $
            @Hermanito33
            cd /opt/iobroker
            npm rebuild
              @Hermanito33
              cd /opt/iobroker
              npm rebuild
              Hermanito33
              @Thomas-Braun ```
              code_text
              pi@ioBroker-Pi:~ $ cd /opt/iobroker
              pi@ioBroker-Pi:/opt/iobroker $ npm rebuild
              > iobroker@2.0.2 install /opt/iobroker/node_modules/iobroker
              > node lib/checkVersions.js
              NPM version: 6.14.4
              > iobroker@2.0.2 postinstall /opt/iobroker/node_modules/iobroker
              > node lib/install.js
              lib/install.js is not being run as part of an installation - skipping...
              > @abandonware/noble@1.9.2-5 install /opt/iobroker/node_modules/@abandonware/noble
              > node-gyp rebuild
              make: Verzeichnis „/opt/iobroker/node_modules/@abandonware/noble/build“ wird betreten
                SOLINK_MODULE(target) Release/obj.target/noble.node
                COPY Release/noble.node
              make: Verzeichnis „/opt/iobroker/node_modules/@abandonware/noble/build“ wird verlassen
              > @serialport/bindings@2.0.8 install /opt/iobroker/node_modules/@serialport/bindings
              > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
              prebuild-install WARN install No prebuilt binaries found (target=12.16.3 runtime=node arch=arm libc= platform=linux)
              make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird betreten
                CXX(target) Release/obj.target/bindings/src/serialport.o
              ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
              ../src/serialport.cpp:329:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               an::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
              In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14:0,
                               from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,
                               from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,
                               from ../../../nan/nan.h:54,
                               from ../src/./serialport.h:6,
                               from ../src/serialport.cpp:1:
              /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:3499:22: note: declared here
                               bool Set(Local<Value> key, Local<Value> value));
              /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
                 declarator __attribute__((deprecated(message)))
              ../src/serialport.cpp:330:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               an::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
              ../src/serialport.cpp:331:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               an::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
              ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
              ../src/serialport.cpp:378:106: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
               ::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
                CXX(target) Release/obj.target/bindings/src/serialport_unix.o
                CXX(target) Release/obj.target/bindings/src/poller.o
                CXX(target) Release/obj.target/bindings/src/serialport_linux.o
                SOLINK_MODULE(target) Release/obj.target/bindings.node
                COPY Release/bindings.node
              make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird verlassen
              > iobroker.javascript@4.5.1 postinstall /opt/iobroker/node_modules/iobroker.javascript
              > node ./install/installTypings.js
              Installing NodeJS typings...
              latest @types: 14, installed node: 12
              > iobroker.js-controller@2.2.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
              > node lib/preinstallCheck.js
              NPM version: 6.14.4
              > iobroker.js-controller@2.2.10 install /opt/iobroker/node_modules/iobroker.js-controller
              > node iobroker.js setup first
              > ws@0.6.5 install /opt/iobroker/node_modules/websocket-stream/node_modules/ws
              > (node-gyp rebuild 2> builderror.log) || (exit 0)
              make: Verzeichnis „/opt/iobroker/node_modules/websocket-stream/node_modules/ws/build“ wird betreten
                CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
              bufferutil.target.mk:111: die Regel für Ziel „Release/obj.target/bufferutil/src/bufferutil.o“ scheiterte
              make: Verzeichnis „/opt/iobroker/node_modules/websocket-stream/node_modules/ws/build“ wird verlassen
              > ws@0.7.0 install /opt/iobroker/node_modules/create-stream-server/node_modules/ws
              make: Verzeichnis „/opt/iobroker/node_modules/create-stream-server/node_modules/ws/build“ wird betreten
              make: Verzeichnis „/opt/iobroker/node_modules/create-stream-server/node_modules/ws/build“ wird verlassen
              > raw-socket@1.7.0 install /opt/iobroker/node_modules/iobroker.radar2/node_modules/raw-socket
              > node-gyp rebuild
              make: Verzeichnis „/opt/iobroker/node_modules/iobroker.radar2/node_modules/raw-socket/build“ wird betreten
                CXX(target) Release/obj.target/raw/src/raw.o
                SOLINK_MODULE(target) Release/obj.target/raw.node
                COPY Release/raw.node
              make: Verzeichnis „/opt/iobroker/node_modules/iobroker.radar2/node_modules/raw-socket/build“ wird verlassen
              > usb@1.6.1 install /opt/iobroker/node_modules/iobroker.radar2/node_modules/usb
              > prebuild-install --verbose || node-gyp rebuild
              prebuild-install info begin Prebuild-install version 5.3.3
              prebuild-install info looking for cached prebuild @ /home/iobroker/.npm/_prebuilds/86d719-usb-v1.6.1-node-v72-linux-arm.tar.gz
              prebuild-install http request GET https://github.com/tessel/node-usb/releases/download/v1.6.1/usb-v1.6.1-node-v72-linux-arm.tar.gz
              prebuild-install http 404 https://github.com/tessel/node-usb/releases/download/v1.6.1/usb-v1.6.1-node-v72-linux-arm.tar.gz
              make: Verzeichnis „/opt/iobroker/node_modules/iobroker.radar2/node_modules/usb/build“ wird betreten
                CC(target) Release/obj.target/libusb/libusb/libusb/core.o
                CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
                CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
                CC(target) Release/obj.target/libusb/libusb/libusb/io.o
                CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
                CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
                CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
                CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
                CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
                CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
                AR(target) Release/obj.target/usb.a
                COPY Release/usb.a
                CXX(target) Release/obj.target/usb_bindings/src/node_usb.o
              ../src/node_usb.cc: In function ‘void handleHotplug(std::pair<libusb_device*, libusb_hotplug_event>)’:
              ../src/node_usb.cc:151:58: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                Nan::MakeCallback(Nan::New(hotplugThis), "emit", 2, argv);
              In file included from ../src/helpers.h:3:0,
                               from ../src/node_usb.h:21,
                               from ../src/node_usb.cc:1:
              ../node_modules/nan/nan.h:1001:46: note: declared here
                 NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
                CXX(target) Release/obj.target/usb_bindings/src/device.o
              ../src/device.cc: In static member function ‘static void Req::default_after(uv_work_t*)’:
              ../src/device.cc:237:64: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                  Nan::MakeCallback(device, Nan::New(baton->callback), 1, argv);
                               from ../src/device.cc:1:
              ../node_modules/nan/nan.h:959:46: note: declared here
                CXX(target) Release/obj.target/usb_bindings/src/transfer.o
              ../src/transfer.cc: In function ‘void handleCompletion(Transfer*)’:
              ../src/transfer.cc:126:72: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                 Nan::MakeCallback(self->handle(), Nan::New(self->v8callback), 3, argv);
                               from ../src/transfer.cc:1:
                SOLINK_MODULE(target) Release/obj.target/usb_bindings.node
                COPY Release/usb_bindings.node
              make: Verzeichnis „/opt/iobroker/node_modules/iobroker.radar2/node_modules/usb/build“ wird verlassen
              > @abandonware/noble@1.9.2-5 install /opt/iobroker/node_modules/iobroker.radar2/node_modules/@abandonware/noble
              > node-gyp rebuild
              make: Verzeichnis „/opt/iobroker/node_modules/iobroker.radar2/node_modules/@abandonware/noble/build“ wird betreten
              make: Verzeichnis „/opt/iobroker/node_modules/iobroker.radar2/node_modules/@abandonware/noble/build“ wird verlassen
              > node-gyp rebuild
              > node-bluetooth@1.2.6 install /opt/iobroker/node_modules/iobroker.radar2/node_modules/node-bluetooth
              > node-gyp configure build
              make: Verzeichnis „/opt/iobroker/node_modules/iobroker.radar2/node_modules/node-bluetooth/build“ wird betreten
                CXX(target) Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o
              ../src/linux/BluetoothSerialPort.cc:18:14: error: variable or field ‘InitAll’ declared void
               void InitAll(Handle<Object> exports) {
              ../src/linux/BluetoothSerialPort.cc:18:14: error: ‘Handle’ was not declared in this scope
              ../src/linux/BluetoothSerialPort.cc:18:27: error: expected primary-expression before ‘>’ token
              ../src/linux/BluetoothSerialPort.cc:18:29: error: ‘exports’ was not declared in this scope
              In file included from ../src/linux/BluetoothSerialPort.cc:12:0:
              ../src/linux/BluetoothSerialPort.cc:23:34: error: ‘InitAll’ was not declared in this scope
               NODE_MODULE(BluetoothSerialPort, InitAll)
              /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
                     (node::addon_register_func) (regfunc),                          \
              ../src/linux/BluetoothSerialPort.cc:23:1: note: in expansion of macro ‘NODE_MODULE’
              BluetoothSerialPort.target.mk:115: die Regel für Ziel „Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o“ scheiterte
              make: *** [Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o] Fehler 1
              make: Verzeichnis „/opt/iobroker/node_modules/iobroker.radar2/node_modules/node-bluetooth/build“ wird verlassen
              gyp ERR! build error
              gyp ERR! stack Error: `make` failed with exit code: 2
              gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
              gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
              gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
              gyp ERR! System Linux 4.19.66-v7+
              gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"
              gyp ERR! cwd /opt/iobroker/node_modules/iobroker.radar2/node_modules/node-bluetooth
              gyp ERR! node -v v12.16.3
              gyp ERR! node-gyp -v v5.1.0
              gyp ERR! not ok
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! node-bluetooth@1.2.6 install: `node-gyp configure build`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the node-bluetooth@1.2.6 install script.
              npm ERR!     /home/iobroker/.npm/_logs/2020-05-15T22_08_46_202Z-debug.log
              Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                @Thomas-Braun ```
                code_text
                NPM version: 6.14.4
                > node lib/install.js
                > node-gyp rebuild
                NPM version: 6.14.4
                > node-gyp rebuild
                  COPY Release/usb.a
                > node-gyp rebuild
                > node-gyp rebuild
                gyp ERR! not ok
                npm ERR! errno 1
                npm ERR!
                @Hermanito33 Startet der iobroker nun?
                iobroker start
                iobroker list instances
                  @Thomas-Braun ```
                  code_text
                  NPM version: 6.14.4
                  > node lib/install.js
                  > node-gyp rebuild
                  NPM version: 6.14.4
                  > node-gyp rebuild
                    COPY Release/usb.a
                  > node-gyp rebuild
                  > node-gyp rebuild
                  gyp ERR! not ok
                  npm ERR! errno 1
                  npm ERR!
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @Hermanito33
                  Hallo ......
                  @Thomas-Braun hilft dir und du Antwortest nicht mehr , bzw. zumindest kann man eine kurze Rückmeldung geben ... "ich melde mich morgen wieder ...." !
                    iobroker start
                    Hermanito33
                    @Thomas-Braun Ja startet nun und funktioniert. Vielen dank!!
                    • GlasfaserG Glasfaser
                      @Hermanito33
                      Hallo ......
                      Hermanito33
                      @Glasfaser Sorry war eben nicht am PC. Natürlich bin ich dankbar und freue mich, dass ihr mir helft :D Scheint nun alles zu funktionieren und die Versionen stimmen...
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @Hermanito33
                        War nicht Böse gemeint ... aber ist ja auch schon sehr spät in der Nacht ;)
                          @Hermanito33
                          Hermanito33
                          @Glasfaser Okey :D So jetzt bin ich aber mal weg und schaue mir das morgen noch mal an :) Vielen dank noch mal!
