  4. Adapter Backitup kopiert nicht auf FTP
backitupadapter.backitup
55 Beiträge 4 Kommentatoren 6.9k Aufrufe 2 Beobachtet
  • TepManT Offline
    TepManT Offline
    TepMan
    Was für Bugs sind denn das? Die ganze Installation läuft seit einem viertel Jahr ohne Probleme...
    • TepManT TepMan
      Bei NFS kann ich keinen User mehr konfigurieren:
      Habe es dann per CIFS versucht, da kann er conntecten:
      backitup.0	2020-05-09 22:57:55.989	debug	(13740) [iobroker/iobroker] done
      backitup.0	2020-05-09 22:57:55.780	debug	(13740) [iobroker/iobroker] host.raspi4 Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      backitup.0	2020-05-09 22:57:54.981	debug	(13740) [iobroker/iobroker] host.raspi4 Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      backitup.0	2020-05-09 22:57:54.966	debug	(13740) [iobroker/iobroker] host.raspi4 Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2020_
      backitup.0	2020-05-09 22:57:53.853	debug	(13740) [iobroker/iobroker] host.raspi4 2154 objects saved
      backitup.0	2020-05-09 22:57:53.833	debug	(13740) [iobroker/iobroker] host.raspi4 3180 states saved
      backitup.0	2020-05-09 22:57:51.691	debug	(13740) [iobroker/mount] done
      backitup.0	2020-05-09 22:57:41.292	debug	(13740) Backup has started ...
      backitup.0	2020-05-09 22:57:14.962	debug	(13740) mount activ... umount in 2 Seconds!!
      backitup.0	2020-05-09 22:57:07.659	debug	(13740) detect last backup file: iobroker_2020_05_09-20_25_50_backupiobroker.tar.gz
      backitup.0	2020-05-09 22:57:07.656	debug	(13740) detect backup file 1: iobroker_2020_05_09-20_25_50_backupiobroker.tar.gz
      backitup.0	2020-05-09 22:57:04.962	debug	(13740) [iobroker] 10 00 02 */1 * *
      backitup.0	2020-05-09 22:57:04.951	info	(13740) [iobroker] backup was activated at 02:00 every 1 day(s)
      backitup.0	2020-05-09 22:57:04.897	info	(13740) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.15.0
      Aber wie du siehst, schlägt er dann wieder mit dem Permission-Fehler auf...
      simatecS Offline
      simatecS Offline
      simatec
      @TepMan sagte in Adapter Backitup kopiert nicht auf FTP:
      Das zeigt auch, dass du auf dem NAS keine Schreibrechte hast
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • TepManT TepMan
        simatecS Offline
        simatecS Offline
        simatec
        Was nicht richtig kompiliert oder defekt.
        Du kannst es mit einem rebuild versuchen, aber wenn du iobroker neu aufsetzt, bis du meist schneller und alles läuft danach sauber
        • TepManT Offline
          TepManT Offline
          TepMan
          Bei CIFS fehlte tatsächlich eine Berechtigung, jetzt hat das Erstellen und Hochladen geklappt. Die Schlusmeldung ist allerdings weiterhin "[DEBUG] [iobroker] - done". Würde aber erklären, warum er die Mountpoints nicht aushängt.
          Aber das Argument "das System ist schräg" kann ich so nicht gelten lassen. Es läuft, wie gesagt, seit einem viertel Jahr ohne Probleme. Alle anderen Adapter funktionieren auch ohne Probleme. Auch keine komischen Fehlermeldungen in den Logs oder so. Habe jetzt ehrlich gesagt keine Lust, das ganze System neu aufzusetzen und zu konfigurieren, zumal es eben stabil läuft.
          • TepManT Offline
            TepManT Offline
            TepMan
            Letzter Post für heute - versprochen. Offenbar unmounted der Adapter nicht mehr. Ich hatte ja per CIFS ein Backup erfolgreich auf das NAS bekommen. Dann habe ich auf NFS umgeschaltet, man sieht im Log, er sagt, er könne nicht mounten, weil er keine Credentials bekommt. Das Backup wird aber trotzdem erstellt und landet auf dem NAS, also ist der Mountpoint noch drin:
            backitup.0	2020-05-09 23:32:02.878	debug	(15061) [iobroker/iobroker] done
            backitup.0	2020-05-09 23:32:01.831	debug	(15061) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_05_09-23_31_57_backupiobroker.tar.gz
            backitup.0	2020-05-09 23:31:59.908	debug	(15061) [iobroker/iobroker] host.raspi4 2154 objects saved
            backitup.0	2020-05-09 23:31:59.888	debug	(15061) [iobroker/iobroker] host.raspi4 3180 states saved
            backitup.0	2020-05-09 23:31:57.803	debug	(15061) [iobroker/mount] mount.nfs: access denied by server while mounting 192.168.178.20:/ioBroker/ioBrokerBackups
            backitup.0	2020-05-09 23:31:57.802	debug	(15061) [iobroker/mount] [IGNORED] Error: Command failed: sudo mount 192.168.178.20:/ioBroker/ioBrokerBackups /opt/iobroker/backups
            backitup.0	2020-05-09 23:31:57.801	debug	(15061) [iobroker/mount] [undefined mount.nfs: access denied by server while mounting 192.168.178.20:/ioBroker/ioBrokerBackups
            backitup.0	2020-05-09 23:31:47.283	debug	(15061) Backup has started ...
            backitup.0	2020-05-09 23:30:25.756	debug	(15061) detect last backup file: iobroker_2020_05_09-23_27_29_backupiobroker.tar.gz
            backitup.0	2020-05-09 23:30:25.753	debug	(15061) detect backup file 4: iobroker_2020_05_09-23_27_29_backupiobroker.tar.gz
            backitup.0	2020-05-09 23:30:25.752	debug	(15061) detect backup file 3: iobroker_2020_05_09-23_24_25_backupiobroker.tar.gz
            backitup.0	2020-05-09 23:30:25.751	debug	(15061) detect backup file 2: iobroker_2020_05_09-23_12_17_backupiobroker.tar.gz
            backitup.0	2020-05-09 23:30:25.750	debug	(15061) detect backup file 1: iobroker_2020_05_09-20_25_50_backupiobroker.tar.gz
            backitup.0	2020-05-09 23:30:23.744	error	(15061) Error: Command failed: sudo mount 192.168.178.20:/ioBroker/ioBrokerBackups /opt/iobroker/backups mount.nfs: access denied by server while mounting 192.168.178.20:/ioBroker/ioBrokerBackups
            backitup.0	2020-05-09 23:30:23.271	debug	(15061) [iobroker] 10 00 02 */1 * *
            Per FTP geht es gerade auch, eben weil der Mountpoint noch drin hängt.
            Ich hoffe du fast die Kritik so konstruktiv auf, wie sie gemeint ist. Das einhängen der Mountpoints auf /opt/iobroker/backups ist zwar eine elegante Lösung, aber extrem verwirrend, wenn man nicht weiß, wie der Adapter arbeitet. Ausserdem birgt es - wie bei mir geschehen - das Risiko, das, wenn Mountpoints nicht ausgehängt werden können es, es zu einem echt seltsamen Systemverhalten führt. Dieses kann man sich dann schwer erklären, wenn man nicht weiß, was da passiert ist.
            Wäre es nicht eine Option, die Mountpoints woanders, z.B. unter mnt zu hängen und die Files dann einfach darüber zu kopieren?
            simatecS 2 Antworten Letzte Antwort
            • TepManT TepMan
              simatecS Offline
              simatecS Offline
              simatec
              @TepMan
              Hast du für den cifs mount ftp deaktiviert?
              • TepManT TepMan
                simatecS Offline
                simatecS Offline
                simatec
                Aus dem Grund überprüft backitup beim start des Adapters und auch vor jedem Backup, ob der mount noch vorhanden ist und führt einen umount aus.
                Den mount punkt woanders zu setzen ist nicht Ziel, da bei Systemen mit sd garnicht erst auf diese geschrieben werden soll
                • TepManT TepMan
                  simatecS Offline
                  simatecS Offline
                  simatec
                  Das zeigt, dass deine lokalen Rechte für FTP nicht passen
                  • TepManT Offline
                    TepManT Offline
                    TepMan
                    Ok, dann habe ich das Konzept jetzt glaube ich verstanden. Die remoten Verzeichnisse werden jeweils dauerhaft gemounted und es wird beim Backup überprüft, ob die da sind, richtig? Dann hatte ich die Probleme wahrscheinlich durch das dauernde hin- und herschalten.
                    Das mit den Rechten für FTP habe ich aber nicht verstanden. Ich kann per FTP-Client mit dem User ohne Probleme auf das FTP-Verzeichnis zugreifen und Datein lesen und schreiben, welche Rechte fehlen denn da noch oder sind nicht richtig. Also auf dem NAS sind definitiv die Rechte vorhanden.
                    Und bleibt noch das Problem, das der Backup-Prozess nicht richtig abgeschlossen wird. Kann das mit dem Rechte-Problem zusammenhängen? Kann man das noch irgendwie herausfinden? Ich kann auch gern eine Version mit mehr Debug-Ausgaben installieren, bräuchte nur eine Git-URL zum Installieren.
                    • TepManT TepMan
                      simatecS Offline
                      simatecS Offline
                      simatec
                      @TepMan
                      Erstmal wäre zu testen, warum der Backup Prozess nicht abgeschlossen wird
                      Dafür würde ich erstmal alles deaktivieren und nur noch ein lokales Backup erstellen.
                      NAS aus, FTP aus und auch alle anderen Hacken raus.
                      Hast du zigbee oder history, mysql oder irgendwas noch aktiv und nicht konfiguriert?
                      Ansonsten können wir gerne ein debug machen oder Remote ...
                      • TepManT Offline
                        TepManT Offline
                        TepMan
                        Jooo, es war ein Haken bei Zigbee! Keine Ahnung warum ich den gesetzt hatte, und natürlich hatte ich den auch überhaupt nicht im Blick. Jetzt ist er weg und das Backup läuft - auch per FTP - sauber durch und alle Backup-Files landen wo sie hin sollen.
                        Hab das jetzt spaßehalber auch mal mit Redis probiert (obwohl ich auch kein Redis im Einsatz habe) und da reagiert der Adapter mit entsprechenden Fehlermeldungen, arbeitet aber den Backup-Auftrag ansonsten korrekt ab:
                        Gestartet...
                        [DEBUG] [iobroker] - host.raspi4 3181 states saved
                        [DEBUG] [iobroker] - host.raspi4 2154 objects saved
                        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2020_05_11-17_12_21_backupiobroker.tar.gz
                        [ERROR] [redis] - [IGNORED] No source for compress!
                        [DEBUG] [ftp] - FTP connected.
                        [DEBUG] [ftp] - Send iobroker_2020_05_11-17_12_21_backupiobroker.tar.gz
                        [DEBUG] [ftp] - Send redis_2020_05_11-17_12_26_backupiobroker.tar.gz
                        [ERROR] [ftp] - File "/opt/iobroker/backups/redis_2020_05_11-17_12_26_backupiobroker.tar.gz" not found
                        [DEBUG] [ftp] - done
                        [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
                        [DEBUG] [clean] - done
                        [DEBUG] [history] - backitup.0.history.html
                        [DEBUG] [history] - backitup.0.history.json
                        [EXIT] 0
                        Ich gucke mir noch ein paar Tage an, ob die zeit gesteuerten, nächtlichen Backups durchlaufen, aber ich gehe davon aus, das es klappen wird. Vielleicht guckst du bei Zigbee noch mal hin, warum der Adapter da so komisch reagiert.
                        Ansonsten bleibt mir nur, mich für deine Geduld und Hilfe zu bedanken!
                        • TepManT TepMan
                          Gestartet...
                          [EXIT] 0
                          simatecS Offline
                          simatecS Offline
                          simatec
                          @TepMan
                          danke für den Hinweis ... zigbee schaue ich mir mal an ...
                          • TepManT TepMan
                            Gestartet...
                            [EXIT] 0
                            simatecS Offline
                            simatecS Offline
                            simatec
                            @TepMan
                            Könntest du mal testen, ob es jetzt mit gesetzten Häckchen bei zigbee trotzdem läuft und auch beendet wird?
                            Installation über Github:
                            https://github.com/simatec/ioBroker.backitup/tarball/dev
                            Den Link direkt in der Katze unter Adaptern einfügen.
                            Am besten auch mal die Debug Ausgaben hier posten
                            TepManT 1 Antwort Letzte Antwort
                            • simatecS simatec
                              @TepMan
                              TepManT Offline
                              TepManT Offline
                              TepMan
                              @simatec Hi, sieht gut aus (außer das die Meldung etwas sprechender sein könnte, "undefined backup done" wird einem unbedarften Anwender nicht viel sagen :-) ) :
                              Gestartet...
                              [DEBUG] [iobroker] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"local","host":"192.168.178.20","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/ioBrokerBackups","dirMinimal":"/backupDir/iobroker","user":"ioBroker","pass":"****","port":"21"},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"local","host":"192.168.178.20","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/ioBrokerBackups","dirMinimal":"/backupDir/iobroker","user":"ioBroker","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.20","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"ioBroker/ioBrokerBackups","dirMinimal":"sharename/backupDir","user":"ioBroker","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/var/lib/redis"},"historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"local","host":"192.168.178.20","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/ioBrokerBackups","dirMinimal":"/backupDir/iobroker","user":"ioBroker","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.20","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"ioBroker/ioBrokerBackups","dirMinimal":"sharename/backupDir","user":"ioBroker","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"media/usb/history"},"zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"local","host":"192.168.178.20","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/ioBrokerBackups","dirMinimal":"/backupDir/iobroker","user":"ioBroker","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.20","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"ioBroker/ioBrokerBackups","dirMinimal":"sharename/backupDir","user":"ioBroker","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                              [DEBUG] [iobroker] - host.raspi4 3447 states saved
                              [DEBUG] [iobroker] - host.raspi4 2417 objects saved
                              [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2020_05_12-17_32_23_backupiobroker.tar.gz
                              [DEBUG] [zigbee] - undefined backup done
                              [DEBUG] [ftp] start with {"type":"storage","source":"local","host":"192.168.178.20","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/ioBrokerBackups","dirMinimal":"/backupDir/iobroker","user":"ioBroker","pass":"****","port":"21","deleteBackupAfter":0}
                              [DEBUG] [ftp] - Send iobroker_2020_05_12-17_32_23_backupiobroker.tar.gz
                              [EXIT] 0
                              [EXIT] 0
                              [DEBUG] [history] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"ftp":{"enabled":true,"type":"storage","source":"local","host":"192.168.178.20","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/ioBrokerBackups","dirMinimal":"/backupDir/iobroker","user":"ioBroker","pass":"****","port":"21"},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"local","host":"192.168.178.20","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/ioBrokerBackups","dirMinimal":"/backupDir/iobroker","user":"ioBroker","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.20","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"ioBroker/ioBrokerBackups","dirMinimal":"sharename/backupDir","user":"ioBroker","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/var/lib/redis"},"historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"local","host":"192.168.178.20","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/ioBrokerBackups","dirMinimal":"/backupDir/iobroker","user":"ioBroker","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.20","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"ioBroker/ioBrokerBackups","dirMinimal":"sharename/backupDir","user":"ioBroker","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"media/usb/history"},"zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":true,"type":"storage","source":"local","host":"192.168.178.20","debugging":true,"deleteOldBackup":true,"ownDir":false,"dir":"/ioBrokerBackups","dirMinimal":"/backupDir/iobroker","user":"ioBroker","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.20","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"ioBroker/ioBrokerBackups","dirMinimal":"sharename/backupDir","user":"ioBroker","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"12. Mai 2020 um 17:32 Uhr"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                              • TepManT TepMan
                                Gestartet...
                                [EXIT] 0
                                [EXIT] 0
                                simatecS Offline
                                simatecS Offline
                                simatec
                                @TepMan
                                Danke für die Info und fürs testen ... konnte das selber auf die schnelle nicht testen, da mir aktuell keine laufende zigbee Installation vorliegt.
                                Den Log mache ich noch schick
                                • simatecS simatec
                                  @TepMan
                                  TepManT Offline
                                  TepManT Offline
                                  TepMan
                                  @simatec gerne. Kann ich die Dev-Version installiert lassen oder hat die noch "known issues"?
                                  • TepManT TepMan
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    @TepMan
                                    Kannst du installiert lassen ... Ich werde aber da noch ein paar Kleinigkeiten anpassen bevor die 1.5.8 ins latest geht
                                    • TepManT TepMan
                                      Gestartet...
                                      [EXIT] 0
                                      [EXIT] 0
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      @TepMan
                                      Jetzt sollten die Log-Ausgaben sauber sein und auch verständlich ...
                                      • simatecS simatec
                                        @TepMan
                                        TepManT Offline
                                        TepManT Offline
                                        TepMan
                                        @simatec sieht sehr gut aus:
                                        Gestartet...
                                        [DEBUG] [iobroker] - host.raspi4 3445 states saved
                                        [DEBUG] [iobroker] - host.raspi4 2298 objects saved
                                        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2020_05_13-17_32_17_backupiobroker.tar.gz
                                        [DEBUG] [zigbee] - no zigbee database found!!
                                        [DEBUG] [zigbee] - done
                                        [EXIT] 0
                                        [EXIT] 0
                                        [DEBUG] [ftp] - Send iobroker_2020_05_13-17_32_17_backupiobroker.tar.gz
                                        [EXIT] 0
