  4. Fehler Info Adapter
Fehler Info Adapter
info adapter
18 Beiträge 5 Kommentatoren 1.8k Aufrufe 4 Beobachtet
    muckel
    Hat das Problem schon wer gelöst?
    Adapter auf GIT wird nicht geladen.
    Aus der Konsole vom Chrome Browser.
    Access to fetch at 'https://api.github.com/search/repositories?q=iobroker+in:name&sort=updated&page=10&per_page=100' from origin 'http://192.168.0.230:8081' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource. If an opaque response serves your needs, set the request's mode to 'no-cors' to fetch the resource with CORS disabled.
    api.github.com/search/repositories?q=iobroker+in:name&sort=updated&page=10&per_page=100:1 Failed to load resource: net::ERR_FAILED
    searchGithub.js:85 TypeError: Failed to fetch
    tab_m.html:1 Failed to decode downloaded font: http://192.168.0.230:8081/adapter/info/lib/fonts/fontawesome-webfont.woff2?v=4.7.0
    tab_m.html:1 OTS parsing error: Failed to convert WOFF 2.0 font to SFNT
    DevTools failed to load SourceMap: Could not load content for http://192.168.0.230:8081/adapter/info/lib/js/showdown.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load SourceMap: Could not load content for http://192.168.0.230:8081/adapter/info/lib/js/chartist.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load SourceMap: Could not load content for http://192.168.0.230:8081/adapter/info/lib/js/format-google-calendar.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load SourceMap: Could not load content for http://192.168.0.230:8081/adapter/info/lib/css/bootstrap.min.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    • M muckel
      skokarl
      @muckel
      warte mal...das kann auch an GitHub liegen.....
      Fehler im Adapter habe ich nicht mehr .... 😬
      • S skokarl
        @muckel
        muckel
        @skokarl sagte in Fehler Info Adapter:
        @muckel
        Hast du eine Ausgabe beim GIT?
        • M muckel
          @muckel
          skokarl
          @muckel
          ich mach gerade nix mehr mit Github und dem Adapter.....läuft super bei mir.
          • S skokarl
            @muckel
            muckel
            @skokarl
            Ich meine dieses Fenster. Bekommst du da Daten angezeigt?
            • M muckel
              @skokarl
              skokarl
              schrieb am zuletzt editiert von skokarl
              @muckel sagte in Fehler Info Adapter:
              @skokarl
              lol...ich war eben geistig im falschen Thread ....... war noch bei hs100....
              warte, ich gucke....
              hab ich gar nicht...wie schalte ich das ein ?
                skokarl
                gefunden....
                nee, kommt nix.
                • S skokarl
                  gefunden....
                  nee, kommt nix.
                  muckel
                  gefunden....
                  Danke, dann ist das momentan eben so.
                  ich habe gerade gesucht, wo man das aktiviert.
                  jetzt frag ich dich: wo schaltet man das GIT ein/aus? :-)
                  • M muckel
                    gefunden....
                    skokarl
                    • S skokarl
                      muckel
                      @skokarl
                      :-) ... und wie komm ich dort hin? ich glaube mir fehlt da was
                      • M muckel
                        @skokarl
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Über den Reiter links Instanzen , dann Adapterkonfiguration: info.0
                        • GlasfaserG Glasfaser
                          muckel
                          @Glasfaser sagte in Fehler Info Adapter:
                          Manchmal sieht man den Wald vor lauter Bäumen nicht.
                          Danke schön.
