  4. Fehler Info Adapter
Fehler Info Adapter
info adapter
18 Beiträge 5 Kommentatoren 1.8k Aufrufe 4 Beobachtet
    Berchemer
    Habe auch nach Update den Folgenden:
    info.0	2020-04-23 16:12:30.649	error	(2926) Error: Request failed with status code 503
      skokarl
      funktioniert wieder.... warum auch immer.
      • B Berchemer
        Berchemer
        @Berchemer sagte in Fehler Info Adapter:
        Fehler trat in der letzten Stunde nicht mehr auf 👍
          muckel
          Hat das Problem schon wer gelöst?
          Adapter auf GIT wird nicht geladen.
          Aus der Konsole vom Chrome Browser.
          Access to fetch at 'https://api.github.com/search/repositories?q=iobroker+in:name&sort=updated&page=10&per_page=100' from origin 'http://192.168.0.230:8081' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource. If an opaque response serves your needs, set the request's mode to 'no-cors' to fetch the resource with CORS disabled.
          api.github.com/search/repositories?q=iobroker+in:name&sort=updated&page=10&per_page=100:1 Failed to load resource: net::ERR_FAILED
          searchGithub.js:85 TypeError: Failed to fetch
          tab_m.html:1 Failed to decode downloaded font: http://192.168.0.230:8081/adapter/info/lib/fonts/fontawesome-webfont.woff2?v=4.7.0
          tab_m.html:1 OTS parsing error: Failed to convert WOFF 2.0 font to SFNT
          DevTools failed to load SourceMap: Could not load content for http://192.168.0.230:8081/adapter/info/lib/js/showdown.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
          DevTools failed to load SourceMap: Could not load content for http://192.168.0.230:8081/adapter/info/lib/js/chartist.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
          DevTools failed to load SourceMap: Could not load content for http://192.168.0.230:8081/adapter/info/lib/js/format-google-calendar.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
          DevTools failed to load SourceMap: Could not load content for http://192.168.0.230:8081/adapter/info/lib/css/bootstrap.min.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
          • M muckel
            skokarl
            @muckel
            warte mal...das kann auch an GitHub liegen.....
            Fehler im Adapter habe ich nicht mehr .... 😬
            • S skokarl
              @muckel
              muckel
              @skokarl sagte in Fehler Info Adapter:
              @muckel
              Hast du eine Ausgabe beim GIT?
              • M muckel
                @muckel
                skokarl
                @muckel
                ich mach gerade nix mehr mit Github und dem Adapter.....läuft super bei mir.
                • S skokarl
                  @muckel
                  muckel
                  @skokarl
                  Ich meine dieses Fenster. Bekommst du da Daten angezeigt?
                  • M muckel
                    @skokarl
                    skokarl
                    schrieb am zuletzt editiert von skokarl
                    @muckel sagte in Fehler Info Adapter:
                    @skokarl
                    lol...ich war eben geistig im falschen Thread ....... war noch bei hs100....
                    warte, ich gucke....
                    hab ich gar nicht...wie schalte ich das ein ?
                      skokarl
                      gefunden....
                      nee, kommt nix.
                      • S skokarl
                        gefunden....
                        nee, kommt nix.
                        muckel
                        gefunden....
                        Danke, dann ist das momentan eben so.
                        ich habe gerade gesucht, wo man das aktiviert.
                        jetzt frag ich dich: wo schaltet man das GIT ein/aus? :-)
                        • M muckel
                          gefunden....
                          skokarl
                          • S skokarl
                            muckel
                            @skokarl
                            :-) ... und wie komm ich dort hin? ich glaube mir fehlt da was
                            • M muckel
                              @skokarl
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Über den Reiter links Instanzen , dann Adapterkonfiguration: info.0
                              • GlasfaserG Glasfaser
                                muckel
                                @Glasfaser sagte in Fehler Info Adapter:
                                Manchmal sieht man den Wald vor lauter Bäumen nicht.
                                Danke schön.
