  4. Test Adapter Z-Wave 2 (v0.11.x)
    6.5k
testz-wavezwave
132 Beiträge 11 Kommentatoren 18.6k Aufrufe 12 Beobachtet
  • F Flopsi
    Der Log geht nur bis Node11, 12 und 13 werden nicht berücksichtigt.
    Das sind genau die Module die nicht sauber laufen.
    Hier noch der LOG:
    zwave2.0	2020-04-26 19:43:47.437	warn	(1414) Deleting orphaned state zwave2.0.Node_011.Notification.system_unknown
    zwave2.0	2020-04-26 19:43:47.371	warn	(1414) Deleting orphaned state zwave2.0.Node_011.Notification.powerManagement_unknown
    zwave2.0	2020-04-26 19:43:47.298	warn	(1414) Deleting orphaned state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating
    zwave2.0	2020-04-26 19:43:47.228	warn	(1414) Deleting orphaned state zwave2.0.Node_011.Thermostat_Mode.mode
    zwave2.0	2020-04-26 19:43:47.166	warn	(1414) Deleting orphaned state zwave2.0.Node_011.Multilevel_Sensor.airTemperature
    zwave2.0	2020-04-26 19:43:46.982	info	(1414) Node 11: interview completed, all values are updated
    zwave2.0	2020-04-26 19:43:46.981	info	(1414) Node 11: ready to use
    zwave2.0	2020-04-26 19:42:56.670	warn	(1414) Deleting orphaned state zwave2.0.Node_010.Meter.deltaTime_w_consumed
    zwave2.0	2020-04-26 19:42:56.585	warn	(1414) Deleting orphaned state zwave2.0.Node_010.Meter.value_w_consumed
    zwave2.0	2020-04-26 19:42:56.506	warn	(1414) Deleting orphaned state zwave2.0.Node_010.Meter.deltaTime_kWh_Consumed
    zwave2.0	2020-04-26 19:42:56.427	warn	(1414) Deleting orphaned state zwave2.0.Node_010.Meter.value_kWh_Consumed
    zwave2.0	2020-04-26 19:42:56.346	info	(1414) Node 10: interview completed, all values are updated
    zwave2.0	2020-04-26 19:42:56.343	info	(1414) Node 10: ready to use
    zwave2.0	2020-04-26 19:42:38.599	info	(1414) Node 10: is now awake
    zwave2.0	2020-04-26 19:42:38.548	info	(1414) Node 11: is now awake
    zwave2.0	2020-04-26 19:42:35.048	info	(1414) Node 5: is now asleep
    zwave2.0	2020-04-26 19:42:25.006	info	(1414) Node 1: interview completed, all values are updated
    zwave2.0	2020-04-26 19:42:24.998	info	(1414) Node 1: ready to use
    zwave2.0	2020-04-26 19:42:24.935	info	(1414) The driver is ready. Found 7 nodes.
    zwave2.0	2020-04-26 19:42:22.502	info	(1414) starting. Version 0.11.7 in /opt/iobroker/node_modules/iobroker.zwave2, node: v10.20.1, js-controller: 3.0.18
    zwave2.0	2020-04-26 19:42:15.990	info	(1399) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zwave2.0	2020-04-26 19:42:15.989	info	(1399) terminating
    zwave2.0	2020-04-26 19:42:15.988	info	(1399) Shutting down driver...
    zwave2.0	2020-04-26 19:42:15.985	info	(1399) Got terminate signal TERMINATE_YOURSELF
    zwave2.0	2020-04-26 19:42:15.860	info	(1399) starting. Version 0.11.7 in /opt/iobroker/node_modules/iobroker.zwave2, node: v10.20.1, js-controller: 3.0.18
    zwave2.0	2020-04-26 19:42:10.307	info	(1383) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zwave2.0	2020-04-26 19:42:10.306	info	(1383) terminating
    zwave2.0	2020-04-26 19:42:10.306	info	(1383) Cleaned everything up!
    zwave2.0	2020-04-26 19:42:10.243	info	(1383) Resetting node status...
    zwave2.0	2020-04-26 19:42:10.162	info	(1383) Shutting down driver...
    zwave2.0	2020-04-26 19:42:10.160	info	(1383) Got terminate signal TERMINATE_YOURSELF
    zwave2.0	2020-04-26 19:42:01.813	warn	(1383) Deleting orphaned state zwave2.0.Node_011.Notification.system_unknown
    zwave2.0	2020-04-26 19:42:01.735	warn	(1383) Deleting orphaned state zwave2.0.Node_011.Notification.powerManagement_unknown
    zwave2.0	2020-04-26 19:42:01.640	warn	(1383) Deleting orphaned state zwave2.0.Node_011.Thermostat_Setpoint.setpoint_heating
    zwave2.0	2020-04-26 19:42:01.551	warn	(1383) Deleting orphaned state zwave2.0.Node_011.Thermostat_Mode.mode
    zwave2.0	2020-04-26 19:42:01.473	warn	(1383) Deleting orphaned state zwave2.0.Node_011.Multilevel_Sensor.airTemperature
    zwave2.0	2020-04-26 19:42:01.097	info	(1383) Node 11: ready to use
    zwave2.0	2020-04-26 19:42:01.078	info	(1383) Node 5: ready to use
    zwave2.0	2020-04-26 19:42:01.077	info	(1383) Node 1: interview completed, all values are updated
    zwave2.0	2020-04-26 19:42:01.070	info	(1383) Node 1: ready to use
    zwave2.0	2020-04-26 19:42:00.076	info	(1383) The driver is ready. Found 7 nodes.
    zwave2.0	2020-04-26 19:41:57.760	info	(1383) starting. Version 0.11.7 in /opt/iobroker/node_modules/iobroker.zwave2, node: v10.20.1, js-control
    Habe noch bis 19:50 gewartet..
    Wie Kann ich den alles auf null setzen also komplett reset. Das man wieder die Nodes sauber hat von 1 nach x.
    Ist ja kein Ding das eben neu zumachen Teste ja eh nur rum.
    Hier noch der zwave log:
    zwave-1414.log
    AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    #104
    @Flopsi sagte in Test Adapter Z-Wave 2 (v0.11.x):
    Dazu kannst du den Stick komplett resetten. Das löscht alle Verknüpfungen etc, betrifft das Fibaro-System auch und kann nicht rückgängig gemacht werden. Danach musst du alle Geräte komplett neu einbinden.
    Den entsprechenden Knopf habe ich aber noch nicht eingebaut - müsstest auf den "normalen" zwave-Adapter ausweichen.
    Log schaue ich mir später an, danke!
    • F Offline
      Flopsi
      #105
      @AlCalzone
      Wie das Fibaro System auch ich habe doch alle Module vor 2 Jahre dem Homecenter 2 zugeordnet. Und jetzt zum testen andere Module genommen. Die Module sind doch dem Aeotec Stick zugeordnet. Imprinzip habe ich zwei Zwave Netzwerke, dann können doch nur die Module weg sein die dem Stick zugeorndet sind.
      Oder sehe ich das falsch ?
      • F Flopsi
        @AlCalzone
        AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        #106
        @Flopsi Ah das wusste ich nicht. Ja, wenn du den Stick zurücksetzt, bleibt das Homecenter und seine Geräte unberührt.
        • F Offline
          Flopsi
          schrieb am zuletzt editiert von Flopsi
          #107
          Habe einen soft und hard reset gemacht im normalen Adapter .....alle geräte sind noch da ???
          Das kann doch nicht normal sein das bei mir ständig alles schief geht lol......
          host.raspberrypi4-iob	2020-04-28 16:36:32.277	info	Do not restart adapter system.adapter.zwave.0 because desired by instance
          host.raspberrypi4-iob	2020-04-28 16:36:32.277	error	instance system.adapter.zwave.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
          host.raspberrypi4-iob	2020-04-28 16:36:30.498	info	instance system.adapter.zwave.0 started with pid 7644
          host.raspberrypi4-iob	2020-04-28 16:30:39.213	info	instance system.adapter.zwave.0 started with pid 7444
          host.raspberrypi4-iob	2020-04-28 16:30:39.162	info	"system.adapter.zwave.0" enabled
          • F Flopsi
            AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
            #108
            @Flopsi Hm, früher ging es mal 😓
              Marsx79
              #109
              Hab das selbe Problem wie @Flopsi . Das Interview läuft nur bis Node 20 von 40. Die Restlichen werden mit einem Fragezeichen angezeigt. Geht dann nicht weiter. Beim Fibaro Doppelschalter ist das Interview z.B. nicht komplett. Es fehlen die Punkte zum schalten.
              Gibt es bereits eine Lösung? Kann man das Interview nicht manuell auslösen für die einzelnen Nodes?
              • M Marsx79
                AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                #110
                @Marsx79 Log bitte. Dann sieht man ggf. die Ursache.
                • F Offline
                  Flopsi
                  #111
                  Das ja schon mal gut das ich nicht alleine solche Probleme habe :)
                  • E Offline
                    el_rob
                    schrieb am zuletzt editiert von el_rob
                    #112
                    Hallo zusammen!
                    Erstmal vielen Dank für diesen Adapter!! 👍
                    Gibt es eine Möglichkeit, ein Interview mit einer bestimmten Node zu erzwingen? Ich habe mehrere batteriebetriebene Sensoren (1 Fibaro Tür-/Fenstersensor und 5 Aeotec Door/Window Sensor 7). Unter Instanzen->Z-Wave 2->Geräte werden diese aber nicht angezeigt und unter "Objekte" sind zwar die Nodes da, allerdings fehlen Name und gewisse Parameter (bei einem Aeotec z.B. die Configuration-Parameter und bei den anderen die Status-Werte Tür-/Fensterzustand, bzw. Tilt (Kippstand)).
                    Ich habe die Sensoren schon unzählige Male geweckt, die Wake-Up-Zeit auf Minimum eingestellt und es auch schon mit Entfernen und neu hinzufügen versucht, aber das schafft alles keine Abhilfe, es findet kein vollständiges Interview statt und die Geräteparameter bleiben unvollständig...
                    Wie bekomme ich die Geräte komplett erkannt?
                    Viele Grüsse,
                    Rob
                    R AlCalzoneA 2 Antworten Letzte Antwort
                    • E el_rob
                      Hallo zusammen!
                      Viele Grüsse,
                      Rob
                      Rolf_KA
                      #113
                      @el_rob
                      Am besten erstellst du, wie oben beschrieben, für @AlCalzone deine Cache Datei.
                      https://forum.iobroker.net/topic/30963/test-adapter-z-wave-2-v0-11-x/84
                      Ich selbst habe einen Fibaro FGDW002 Tür/Fenstersensor der gut mit dem Adapter funktioniert.
                      • E Offline
                        el_rob
                        #114
                        @Rolf_KA Danke für den Hinweis!
                        Hier meine Cache-Datei:
                        f3b3113a.json
                        Edit: Der Fibaro Tür-Sensor ist Node #6 und die Aeotecs #49 und #54-57
                        R 1 Antwort Letzte Antwort
                        • E el_rob
                          f3b3113a.json
                          Rolf_KA
                          #115
                          @el_rob
                          Gerne doch :-)
                          Das wäre vielleicht auch noch ein Versuch bei dir Wert - die Cache Datei zu löschen...
                          und vielleicht dann auch noch die Log Datei bereitzustellen.
                          https://forum.iobroker.net/topic/30963/test-adapter-z-wave-2-v0-11-x/101
                          • F Offline
                            Flopsi
                            #116
                            Ich habe nur noch Probleme mit dem Fibaro Heat Controller
                            Und die aktuelle Catch Datei:
                            d02b5de0.json
                            Der will einfach nicht es werden nicht alle Interview Daten übertragen.
                            Auch habe ich die Erfahrung gemacht das es besser ist erst die Geräte einzubinden die ohne Akku/Batterie sind.
                            Ich benutze aber gerade den ersten Zwave Adapter.
                            • E el_rob
                              Hallo zusammen!
                              Viele Grüsse,
                              Rob
                              AlCalzoneA Offline
                              AlCalzoneA Offline
                              AlCalzone
                              #117
                              @el_rob Bitte mal ein Log erstellen und posten.
                              E 1 Antwort Letzte Antwort
                              • AlCalzoneA AlCalzone
                                el_rob
                                #118
                                @AlCalzone Meine Log-Datei ist mit 8 MB zu gross für's Forum, daher habe ich sie bei Google Drive hochgeladen. Hier der Link: zwave-30132.log.
                                Vielen Dank für's Anschauen!!
                                • E el_rob
                                  AlCalzoneA Offline
                                  AlCalzoneA Offline
                                  AlCalzone
                                  #119
                                  @el_rob Was ich soweit erkennen kann:
                                  • 10 Minuten ist nicht viel für ein Interview, vor allem wenn man ein so großes Netzwerk hat. Bei meinen 16 Geräten dauert es nach Löschen des Caches gut und gerne mal 10 Minuten inklusive gezielten manuellen Aufwecken.
                                  • Bei den betreffenden Nodes erst mal keine Fehler. Jedoch auch kein vollständiges Interview.
                                  • Node 49 ist in den 10 Minuten relativ weit gekommen, aber noch nicht fertig. Hier könnte tatsächlich helfen, den nochmal manuell aufzuwecken, dann geht das Interview weiter.
                                  • Die Nodes 54-57 werden parallel interviewed, was etwas ungünstig ist, weil keiner richtig weit kommt. Ich plane ein paar Verbesserungen bei der Nachrichten-Priorisierung, da wird das auch ein Thema sein.
                                  Folgende Empfehlung, damit du dein Netzwerk an den Start bekommst: Die unvollständigen Nodes nacheinander manuell aufwecken. Vorher warten bis Ruhe ist (die fest verkabelten sollten durch sein), dann einen Node nehmen und aufwecken. ioBroker-Log beobachten. Wenn der wieder einschläft, nochmal aufwecken. Bei fertigem Interview mit dem nächsten weitermachen.
                                  Außerdem Adapter möglichst selten neu starten. Bei jedem Start wird ein Teil des Interviews wiederholt.
                                  • F Flopsi
                                    d02b5de0.json
                                    AlCalzoneA Offline
                                    AlCalzoneA Offline
                                    AlCalzone
                                    #120
                                    @Flopsi Zu deinem Heat Controller:
                                    Der Adapter erhält keine Antwort auf die Nachricht, mit der er die unterstützten CCs ermittelt. Da das ein FLiRS-Gerät ist, wird er auch nicht als schlafend markiert, sondern das Interview abgebrochen.
                                    Ein Grund dürfte ein ungünstiges Netzwerk-Layout sein. FLiRS-Geräte sollten bestenfalls direkt oder über netzbetriebene Geräte mit dem Controller sprechen. Ist das nicht der Fall, kann es sein, dass Antworten einfach nicht durchkommen. Ggf. hilft bei dir ein Netzwerk-Heal (dabei musst du alle batteriebetriebenen Geräte manuell aufwecken).
                                      el_rob
                                      #121
                                      @AlCalzone Okay, vielen Dank für die ausführlichen Tipps, dann werde ich mich mal in Geduld üben... 😉 Beim alten Z-Wave-Adapter wurden sämtliche Parameter der Aeotecs direkt beim Inkludieren der Sensoren (wenn ich's über den Adapter gemacht habe) bei den Objekten angezeigt, sogar der Name wurde autom. eingetragen, daher hatte ich mich gewundert, dass dies bei deinem Adapter nicht der Fall war. Selbst nach Entfernen und neu Hinzufügen der Sensoren.
                                      Eine weitere Frage hätte ich noch bezügl. meinen Fibaro Dimmern: Vermutlich stehe ich auf dem Schlauch, aber wie bekomme ich es hin, dass beim Einschalten der gleiche Dimmwert eingestellt wird, wie vor dem letzten Ausschalten? Ich komme von IP Symcon und da konnte man einfach ON/OFF schalten und bei ON wurde direkt der zuletzt verwendete Dimmwert Wert eingestellt. ON/OFF gibt's aber beim Z-Wave-2-Adapter irgenwie nicht, oder?! 🤔 Bzw. wenn ich "on_001" auf true setze, dann wird erstens ganz langsam hochgedimmt (obwohl Soft-Start deaktiviert ist) und zweitens auf den Maximalwert. Und mit "off_001" wird wiederum ganz langsam runtergedimmt. Muss ich mir für jeden Dimmer selbst einen Datenpunkt erstellen, in welchem ich jeweils den zuletzt eingestellten Dimmwert speichere oder geht das irgendwie mit ON/OFF?
                                      • E el_rob
                                        AlCalzoneA Offline
                                        AlCalzoneA Offline
                                        AlCalzone
                                        #122
                                        @el_rob sagte in Test Adapter Z-Wave 2 (v0.11.x):
                                        ON/OFF gibt's aber beim Z-Wave-2-Adapter irgenwie nicht, oder?! Bzw. wenn ich "on_001" auf true setze, dann wird erstens ganz langsam hochgedimmt
                                        Jein... on_001 und off_001 sind für die LevelChange-Funktionalität. Die Datenpunkte, die du suchst, habe ich geplant, erfordern aber einiges an Kern-Änderungen.
                                        Es gibt in Z-Wave noch den Spezial-Wert 255 (für targetValue), der den zuletzt eingestellten An-Wert wiederherstellen sollte. Bei meinem Test hat der Adapter sich aber irgendwie festgefahren, wenn ich das versuche. Das könnte ich aber kurzfristiger wieder hinbiegen.
                                        Edit: korrigiere, 255 funktioniert.
                                          el_rob
                                          #123
                                          @AlCalzone Jep, 255 funktioniert bestens, vielen Dank für den Tipp!! 👍
                                          Eine letzte Frage noch bezügl. Interview mit batteriebetriebenen Nodes: Macht es einen Unterschied, ob die Geräte nahe am Z-Wave-Controller stehen? Sprich, wird das Interview schneller vervollständigt, wenn der Controller eine direkte Verbindung mit den z.B. Tür-/Fenstersensoren hat, als wenn die Kommunikation über Repeater läuft?
