    1.0k
2.9k Beiträge 248 Kommentatoren 2.0m Aufrufe 123 Beobachtet
  • Q qosi
    @andre
    Vielen Dank, habe die --privileged hinzugefügt, erst im Portainer eingeschaltet:
    Brachte nix...dann noch in CMD hinzugefügt...
    Brachte auch nichts...
    Dann noch mehr von den capabilities eingeschaltet, NET_Admin war schon an...
    Das sind meine Pakete
    build-essential libcairo2-dev libcap2-bin libpango1.0-dev libjpeg-dev librsvg2-dev arp-scan bluetooth bluez libbluetooth-dev libudev-dev net-tools net-ping nano
    Leider will er einfach nicht...
    radar2.0	2020-04-27 23:51:48.223	info	(643) radar2 set to scan every 20 seconds and printers every 720 minutes.
    radar2.0	2020-04-27 23:51:48.222	info	(643) arp-scan will use the following interfaces: [ 'eth0' ]
    radar2.0	2020-04-27 23:51:48.221	info	(643) Remove name end for host names: .fritz.box
    radar2.0	2020-04-27 23:51:48.221	info	(643) use known IP list: [ '1.1.1.1' ]
    radar2.0	2020-04-27 23:51:48.220	info	(643) use known BT list: [ '01:12:23:34:45:56' ]
    radar2.0	2020-04-27 23:51:48.219	info	(643) radar2 set to flag items away if they are not seen for 2 minutes
    radar2.0	2020-04-27 23:51:48.218	warn	(643) node-bluetooth not found!
    radar2.0	2020-04-27 23:51:47.975	warn	(643) Noble not available, Error: { Error: EAFNOSUPPORT, Address family not supported by protocolat new Hci (/opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/hci.js:74:18)at new NobleBindi
    radar2.0	2020-04-27 23:51:47.024	info	(643) Adapter disconnected and stopped with dostop(false) and callback(true)
    radar2.0	2020-04-27 23:51:47.023	error	(643) Error: bind EACCES 0.0.0.0:67 at state.handle.lookup (dgram.js:242:18) at process._tickCallback (internal/process/next_tick.js:63:19)
    radar2.0	2020-04-27 23:51:47.022	error	(643) uncaught exception: bind EACCES 0.0.0.0:67
    radar2.0	2020-04-27 23:51:46.850	info	(643) net-ping not available! Will try to use normal ping!
    radar2.0	2020-04-27 23:51:46.815	info	(643) radar2 initialization started...
    radar2.0	2020-04-27 23:51:46.796	warn	(643) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
    radar2.0	2020-04-27 23:51:46.731	info	(643) starting. Version 1.0.9 in /opt/iobroker/node_modules/iobroker.radar2, node: v10.20.1, js-controller: 3.0.19
    Hab den js-controller auf 3.0.19 gebracht, vielleicht bin ich mit den aktuellen node usw. Versionen zu aktuell...?
    Ich habe den Container erst mal da, der Mount ist auch da, werde weiter stöbern dazu und auf neues Update hoffen.
    Im Moment wieder zurück auf dem RPI und hoffen, dass die SD Karte wieder mal eine Zeitlang hält.
    Danke für die Doku, werde die mir noch mal in Detail reinziehen.
    Hier vielleicht noch der Log vom Container start...log.txt
    duffbeer2000
    schrieb am zuletzt editiert von duffbeer2000
    #1784
    @qosi Sobald du den Privileged mode aktiviert hast interessieren die capabilities nicht mehr da sie dann alle aktiviert sind. Sicherheitstechnisch solltest du den Privileged mode deaktivieren und nur die benötigten capabilities aktivieren. Ich kann das nicht oft genug sagen.
    Wenn ein externer angreifer in einen Container eindringt der im Privileged mode läuft, kann er auf eurem Host (Diskstation) sehr großen Schaden anrichten, wie z.B. alle Platten löschen.
    Und nun zum eigentlichen Problem:
    • schalte den Container aus
    • Da du vorher ohne priviledged ausgekommen bist schalt es wieder aus
    • dreh die capabilities wieder auf den Ursprungszustand zurück
    • aktiviere folgende capabilities zusätzlich zu den Standardmäßigen.: "NET_ADMIN" "NET_RAW" und "NET_BIND_SERVICE"
    • Starte den Container wieder
    • Führe in der Console folgende Befehle aus:
    gosu root setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp-scan`)
    gosu root setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which node`)
    gosu root setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp`)
    gosu root setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hcitool`)
    gosu root setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hciconfig`)
    gosu root setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which l2ping`)
    • Starte den Container neu
    Q 1 Antwort Letzte Antwort
    • andreA andre
      @jgee2
      Hallo Jo,
      ich glaube du bringst da irgendwas durcheinander...
      @jgee2 sagte in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
      Heute habe ich versucht, NPM von Version 10 auf 12 zu aktualisieren, so wie in dem Blog beschrieben. Leider hat der Neustart nicht mehr geklappt.
      Was hast du jetzt genau vor? Du schreibst "NPM" aktualisieren, Nimmst die "Version 10 auf 12" (Versionen von Node) und postest die Fehlermeldungen vom Update des js-controllers... Das sind 3 völlig unterschiedliche Dinge...
      In meiner Knowledgebase ist das Update vom js-controller beschrieben. Da wäre das Update dann aktuell von Version 2 auf 3. Das wäre dann das Update was du unter Umständen auch im Admin des ioBrokers angezeigt bekommst...
      Ich ignoriere jetzt einfach mal "NPM" und "Version 10 auf 12" und beziehe mich auf deine Fehlermeldung beim Ausführen des "npm install..."
      Deine Fehlermeldung "sudo: Die Audit-Nachricht kann nicht gesendet werden: Die Operation ist nicht erlaubt" ist nicht neu. Hast du die mal durch die Suche in diesem Thread gejagt?
      Das ist ein Thema was hier alle paar Monate wieder aufschlägt.
      Es handelt sich um einen bekannten Bug der in Erscheinung tritt wenn man den Container auf einer Synology DS ausführt und das "Host-Netzwerk" verwendet. Synology verwendet in der aktuellen DSM Version einen veralteten Linux Kernel. In diesem Kernel gibt es einen Bug. Der verhindert das Ausführen von sudo innerhalb eines Containers der im Host Mode läuft.... Leider wird beim "npm install..." innerhalb der routine "sudo" aufgerufen. Resultat: Die Installation schlägt fehl.
      Eine Workaround für das Update des js-controllers im ioBroker-Container wäre folgendes (vorausgesetzt du hast dein ioBroker-Verzeichnis außerhalb des Containers liegen und in den Container gemountet):
      1. Backup machen! (z.B. per duplizieren des ioBroker-Verzeichnisses oder über "iobroker backup" und sichern des Backup-Files)
      2. Container löschen
      3. Container mit Bridge Netzwerk anstatt Host erstellen (restliche Config natürlich gleich)
      4. Update des js-controllers über Kommandozeile durchführen ("pkill io", "npm install..")
      5. Container löschen
      6. Neuen Container mit Host Netzwerk erstellen
      Ich hoffe das hilft dir weiter.
      MfG,
      André
      jgee2
      #1785
      @andre,
      Hi André,
      ja, da habe ich viel durcheinander gebracht, bitte entschuldige. Versucht hatte ich tatsächlich ein Update des js-controllers, das dann fehlgeschlagen ist. Nochmals danke für deine Hilfe.
      Leider bekomme ich auch mit deiner Anleitung hier den Container nicht zum Laufen. Weder im Bridge- noch im Host-Modus. Ich habe daraufhin einen neuen ("nackten") Container installiert und darin mein Backup mit "iobroker restore 0" hergestellt. Sobald das Backup wiederhergestellt wurde, funktioniert auch der Container nicht mehr. Ich scheine mir da richtig was kaputt gemacht zu haben.
      Ich habe bereits begonnen, alles neu aufsetzen, das ist soweit lediglich Arbeit... Nur einige meiner Javascripts würde ich gerne wiederherstellen, da da viel Arbeit reingeflossen ist. Weißt du (oder sonst jemand), wie ich aus dem ioBroker Backup einzelne Teile, nämlich die eigenen Javascript-Dateien, wiederherstellen kann? Soweit ich das sehen kann, liegen die alle in einer ziemlich großen JSON-Datei, in meinem Fall 8 MB. Da hat mein Atom Editor große Schwierigkeiten mit...
      Beste Grüße
      Jo
      D RK62R 2 Antworten Letzte Antwort
      • J jgee2
        @andre,
        Hi André,
        Beste Grüße
        Jo
        duffbeer2000
        #1786
        @jgee2 Probier mal folgendes bevor du einzelne Sachen wiederherstellst:
        • erstelle dir ein neues iobroker_data-Verzeichnis (kannst auch anders nennen)
        • lege in das neue iobroker_data-Verzeichnis das Backup-File
        • erstelle dir nochmal einen nackten Container mit dem neuen iobroker_data-Verzeichnis
        • starte den Container
        Jetzt sollte automatisch ein Restore laufen, das dauert einige Zeit bis es komplett abgeschlossen ist. Je nach Anzahl an Adaptern bis zu 2 Stunden oder mehr.
        Und heb dir das alte iobroker_data-Verzeichnis auf, dann kann man wenns nicht funktioniert auch damit weiter machen.
        • J jgee2
          @andre,
          Hi André,
          Beste Grüße
          Jo
          RK62R Offline
          RK62R Offline
          RK62
          #1787
          @jgee2 Beim neuen System / nach der Reparatur empfiehlt es sich diese Einstellung in der javascript-Instanz zu setzen:
          Das Verzeichnis solltest Du vorher manuell anlegen.
          Damit werden dann permanent alle Skripte lokal auf das Filesystem synchronisiert und können dort oder im Admin geändert werden.
          Mit Hyperbackup hat man dann auch Generationssicherungen der Skripte und kann problemlos auch ein einzelnes mal wieder zurückholen.
          Gruß, Ralf
          • D duffbeer2000
            jgee2
            #1788
            @duffbeer2000
            Hi! Das habe ich gemacht. Die Fehlermeldung beim Starten des Containers war sinngemäß, dass Dateien im Verzeichnis entdeckt wurden, die kein ioBroker Backup wären. Da habe ich dann aufgegeben. Vermutlich war das Backup bereits korrupt. Hab was draus gelernt: Meine ioBroker-Instanz wird bei mir jetzt genauso pfleglich behandelt, wie auch andere Daten. Backups mache ich jetzt regelmäßig und automatisch...
            Trotzdem danke und viele Grüße
            Jo
            • RK62R RK62
              Gruß, Ralf
              jgee2
              #1789
              @RK62
              Hi Ralf,
              super Tipp, danke dir! Schaue ich mir nachher direkt an. Der größte Aufwand war tatsächlich, die Scripte aus der JSON-File herauszuziehen und wieder in Betrieb zu nehmen.
              Viele Grüße
              Jo
              • D duffbeer2000
                Q Offline
                Q Offline
                qosi
                #1790
                @duffbeer2000 said in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
                gosu root setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f which arp-scan)
                Hallo duffbeer,
                schalte den Container aus --> check
                Da du vorher ohne priviledged ausgekommen bist schalt es wieder aus --> check
                dreh die capabilities wieder auf den Ursprungszustand zurück --> check
                aktiviere folgende capabilities zusätzlich zu den Standardmäßigen.: "NET_ADMIN" "NET_RAW" und "NET_BIND_SERVICE" --> check
                Starte den Container wieder --> check
                Führe in der Console folgende Befehle aus: --> ja das hab ich auch so versucht, leider passt ihm hier, wie bei vielen anderen Meldungen die man im log sieht im Moment, diese File Geschichte nicht.
                root@iobroker1:/opt/iobroker# gosu root setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp-scan`)
                Failed to set capabilities on file `/usr/sbin/arp-scan' (Operation not supported)
                The value of the capability argument is not permitted for a file. Or the file is not a regular (non-symlink) file
                • J jgee2
                  @duffbeer2000
                  Jo
                  duffbeer2000
                  #1791
                  @jgee2 Lass mich raten, du hast kein neues iobroker_data Verzeichnis angelegt sondern nur den Inhalt gelöscht? Wenn ja ist das logisch da in dem Verzeichnis auch versteckte Dateien sind. Daher sagte ich auch "erstelle dir ein neues iobroker_data-Verzeichnis"
                  @qosi
                  apr-scan ist aber installiert? kannst du das mal prüfen?
                  Gingen die anderen befehle durch? Wenn nicht dann versuchen wir es mal mit dem User iobroker, vielleicht hilft das.
                  gosu iobroker setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp-scan`)
                  gosu iobroker setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which node`)
                  gosu iobroker setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp`)
                  gosu iobroker setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hcitool`)
                  gosu iobroker setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hciconfig`)
                  gosu iobroker setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which l2ping`)
                  J Q 2 Antworten Letzte Antwort
                  • D duffbeer2000
                    @qosi
                    jgee2
                    #1792
                    Nein, das root-Verzeichnis war ein neues mit einem anderen Namen. Das Backup war bereits defekt. Der ioBroker hat sogar gestartet und alle Adapter ausgeführt (Daten wurden an influxDB gesendet und mit dem KNX-Bus ausgetauscht), aber die Weboberfläche des Admin-Adapters wollte nicht starten. Ältere Backups waren zu alt für meinen Zweck. Mittlerweile habe ich alles wieder hergestellt und bin dadurch etwas schlauer geworden als zuvor.
                    • D duffbeer2000
                      @qosi
                      Q Offline
                      Q Offline
                      qosi
                      #1793
                      @duffbeer2000
                      Sers,
                      also arp-scan ist wohl da...
                      root@iobroker1:/opt/iobroker# arp-scan -lgq --retry=7
                      Interface: eth0, datalink type: EN10MB (Ethernet)
                      Starting arp-scan 1.9.5 with 256 hosts (https://github.com/royhills/arp-scan)
                      192.168.0.2     02:42:c0:a8:00:02
                      Mit User iobroker sieht es etwas anders aus bei den Befehlen
                      root@iobroker1:/opt/iobroker# gosu iobroker setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which arp-scan`)
                      unable to set CAP_SETFCAP effective capability: Operation not permitted
                      Das CAP_SETFCAP ist jedoch an...
                      Auch bei den anderen Befehlen ist die Meldung die gleiche.
                      Habe mal den Privileged mode eingeschaltet, auch hier der gleiche Fehler.
                      Dazu sagt google, dass man andere User außer root nicht unbedingt in sudo/sudoers Gruppe legen soll.
                      Da ich kaum Linux Erfahrung habe, bin ich hierzu ratlos...
                      Danke für Eure Unterstützung!
                        Bongo
                        #1794
                        Ich wollte ein Recreate bei einem Container machen und ich glaube ich habe es versehentlich den Container für Portainer selbst gemacht. Jetzt kommt immer die Fehlermeldung:
                        unable to retrieve stacks
                        In Stacks sind keine Stacks und die Container List sieht so aus:
                        Kann mir einer der Portainerspezis sagen was man da tun kann?
                        Danke für die Unterstützung.
                        Bongo
                        Script - Die sprechende Kaffeemaschine – Home Connect
                        Script - JUDO Wasserenthärtung - Connectivity-Modul API
                          Bongo
                          #1795
                          Ich konnte den Portainer Container über Docker im DSM neu starten. Es scheint wieder zu laufen!
                          Bongo
                          • tugsiT Offline
                            tugsiT Offline
                            tugsi
                            schrieb am zuletzt editiert von tugsi
                            #1796
                            Moin,
                            hab die Tage auf die neueste V4.2 hochgerüstet.
                            Soweit läuft auch alles, nur meine Synology-Instanz kann sich nicht mehr mit der DS verbinden.
                            Ich habe ein MACVLAN und der Container schaut gleichzeitig auch auf das Bridge-Netzwerk.
                            Dies hatte ich damals mal eingerichtet, da der Container sonst nicht mehr auf einen anderen Container bzw auf sein Host schauen kann, hatte ja auch geklappt.
                            Jetzt ist der Thread hier mittlerweile doch sehr groß und unübersichtlich geworden, ich finde den Part nicht mehr, wo dies alles erklärt wurde. Beim Andre auf Buanet wird auch nur auf dieses Forum verwiesen bei den Kommentaren.
                            Mein Bridge-Netzwerk ist:
                            bridge
                            Subnet - 172.17.0.0/16 Gateway - 172.17.0.1
                            ioBroker-Container (MACVLAN):
                            iob_public
                            Subnet - 192.168.33.0/24 Gateway - 192.168.33.100
                            und hat die interne Adresse:
                            172.17.0.3
                            Die DS hat:
                            192.168.33.101
                            Wie gesagt, es lief ja bis vor kurzem, daher wundert mich jetzt, wenn ich in den Terminal gehe und einen Ping auf die Synology machen möchte, der die nicht erreichen kann.
                            Master ioBroker in Proxmox als LXC auf 1. Tiny-Lenovo, Proxmox-VM als Slave auf 2. Tinyi-Lenovo mit Zigbee und Monitor zur Visualisierung, Hauptautomatisierung über S7 auf Beckhoff CX, dazu noch Shelly, Homematic...
                            H 1 Antwort Letzte Antwort
                            • tugsiT tugsi
                              Moin,
                              bridge
                              iob_public
                              172.17.0.3
                              Die DS hat:
                              192.168.33.101
                              hetti72
                              #1797
                              @tugsi Aus dem Container solltest du die Synology unter der 172.17.0.1 erreichen können. Falls nicht könnte es sein das du die Firewall auf der Synology aktiviert hast?
                              gruß,
                              Hetti
                              tugsiT 1 Antwort Letzte Antwort
                              • H hetti72
                                gruß,
                                Hetti
                                tugsiT Offline
                                tugsiT Offline
                                tugsi
                                #1798
                                @hetti72
                                hallo Hetti,
                                ja die 172.17.0.1 kann ich erreichen, nur ich hatte im Adapter immer die 192.168.33.101 eingestellt gehabt und damit klappte es eigentlich auch.
                                Deswegen bin ich jetzt irritiert, dass ich die 192.168.33.x-Bereich nicht mehr erreichen kann aus den Container.
                                • tugsiT tugsi
                                  @hetti72
                                  hallo Hetti,
                                  hetti72
                                  schrieb am zuletzt editiert von hetti72
                                  #1799
                                  @tugsi Du hast wahrscheinlich mit dem iobroker update auf 4.2 nach der Buanet Anleitung ein MACVLAN eingerichtet, oder?
                                  Bei dieser Netzwerkvariante können sich die Synology und auch alle anderen Container die im MACVLAN Modus laufen Netzwerktechnisch untereinander nicht erreichen. Eine Kommunikation ist nur über das zuätzliche Docker interne Bridge Netzwerk möglich.
                                  Das lässt sich nur mit Synologys umgehen die 2 Netzwerkanschlüsse haben. Da lässt man über den einen die Diskstation kommunizieren und auf den anderen physikalischen Anschluss bindet man das MACVLAN, dann könnte der iobroker im Container wieder die Synology mit der "normalen" IP erreichen.
                                  • H hetti72
                                    tugsiT Offline
                                    tugsiT Offline
                                    tugsi
                                    #1800
                                    @hetti72
                                    Ich bin etwas verwirrt. Nein habe diese Variante schon seit der Version3 laufen. Damals hatte ich alles umgestellt. MACVLAN eingerichtet und das Bridge-Netzwerk.
                                    Wie gesagt, bisher lief es auch, nur nach dem Update auf die V4.2 ist mir im Log aufgefallen, dass dutzende Fehlermeldungen vom Synologyadapter kamen, dass er die DS nicht erreichen kann.
                                    In den Einstellungen war meine normale 192er-IP eingetragen, also lief es vorher ja auch so mit MACVLAN, sonst hätte ich ja auch so schon Errorlogs bekommen.
                                    Allerdings habe ich den Synologyadapter nicht in meiner VIS oder so eingebunden, daher bin ich jetzt verwirrt.
                                    Ich habe zwar die 918+, benutze die zwei Netzwerkschnittstellen aber im Bond.
                                    Mit der internen Docker-IP kann ich den Host erreichen, das klappt.
                                    Also hätte ich im MACVLAN nie meine DS über die "normale IP" erreichen können?
                                    Mich verwundert, dass ich die 192er da drin stehen hatte.
                                    • tugsiT tugsi
                                      @hetti72
                                      hetti72
                                      #1801
                                      @tugsi Ich habe nochmal ein wenig experiementiert und muss meine Aussage von weiter oben teilweise korrigieren. Alle Container die eine Adresse aus dem gleichen MACVLAN haben können sich über diese IP Adresse untereinander erreichen, und auch alle anderen Geräte im Netzwerk ausserhalb des MACVLAN´s auf der Synology können erreicht werden (z.B. eine CCU oder HUE Bridge).
                                      Lediglich der Docker Host ist nicht mit seiner "normalen" IP Adresse erreichbar, das wird im wohl Linux Kernel verhindert und ist eine Sicherheitsfunktion.
                                      Man kann das ganze aber aushebeln in dem man auf der Synology eine weitere Netzwerkbridge konfiguriert. Es gibt da verschiedene Anleitungen im Netz, zb hier
                                      https://www.synology-forum.de/showthread.html?103178-macvlan-Zugriff-auf-den-Host
                                      Wenn du also so eine Bridge vorher nicht konfiguriert hattest dann dürfte ein Zugriff aus dem IOBroker Container auf die Synology via der 192er Adresse nie funktioniert haben, aber so genau lässt sich das aus der ferne nicht diagnostizieren.
                                      andreA tugsiT 2 Antworten Letzte Antwort
                                      • R rostnagel
                                        wie reiche ich einen Bluetooth stick an den container durch?
                                        lsusb:
                                        |__usb1          1d6b:0002:0310 09  2.00  480MBit/s 0mA 1IF  (xhci_hcd 0000:00:14.0) hub
                                          |__1-2         1a40:0101:0111 09  2.00  480MBit/s 100mA 1IF  ( ffffffd6ffffffa3ffffffebffffffcb) hub
                                            |__1-2.1     0a12:0001:8891 e0  2.00   12MBit/s 100mA 2IFs ( ffffff84ffffffb5fffffff4ffffffd4)
                                          |__1-5         f400:f400:0100 00  2.00  480MBit/s 200mA 1IF  (Synology DiskStation 6500647A17A34F47)
                                        |__usb2          1d6b:0003:0310 09  3.00 5000MBit/s 0mA 1IF  (xhci_hcd 0000:00:14.0) hub
                                        |__usb3          1d6b:0002:0310 09  2.00  480MBit/s 0mA 1IF  (Linux 3.10.105 etxhci_hcd-170202 Etron xHCI Host Controller 0000:04:00.0) hub
                                          |__3-2         1d19:0100:0100 00  2.00  480MBit/s 500mA 1IF  (ITE Tech., Inc. TS Aggregator AF0102020700001)
                                        |__usb4          1d6b:0003:0310 09  3.00 5000MBit/s 0mA 1IF  (Linux 3.10.105 etxhci_hcd-170202 Etron xHCI Host Controller 0000:04:00.0) hub
                                          |__4-1         1058:10b8:1012 00  3.00 5000MBit/s 896mA 1IF  (Western Digital Elements 10B8 575846314541343239554B45)
                                        dmesg
                                        [1314575.781230] usb 1-2.1: USB disconnect, device number 4
                                        [1314576.488411] init: btacd main process (6752) killed by TERM signal
                                        [1314576.627053] usbcore: deregistering interface driver btusb
                                        [1314580.119372] usb 1-2.1: new full-speed USB device number 5 using xhci_hcd
                                        [1314580.145014] Got empty serial number. Generate serial number from product.
                                        [1314581.463887] init: bluetoothd main process (6730) killed by KILL signal
                                        [1314585.303769] Bluetooth: RFCOMM socket layer initialized
                                        [1314585.309743] Bluetooth: RFCOMM ver 1.11
                                        [1314585.329282] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
                                        [1314585.336142] Bluetooth: HIDP socket layer initialized
                                        [1314585.352945] usbcore: registered new interface driver btusb
                                        kann mir da jemand helfen?
                                        Daniel76
                                        #1802
                                        @rostnagel bist Du mit dem Bluetooth stick schon weiter gekommen? Ich habe ihn bisher auch nicht zum laufen bekommen.
                                        R 1 Antwort Letzte Antwort
                                        • H hetti72
                                          andreA Offline
                                          andreA Offline
                                          andre
                                          #1803
                                          @hetti72 Da hättest du nicht viel experimentieren müssen :) Ich habe zum Thema MACVLAN hier schon einige Male referiert:
                                          https://forum.iobroker.net/search?term=MACVLAN &in=posts&matchWords=all&by[]=andre&sortBy=timestamp&sortDirection=desc&showAs=posts
                                          Kann daher deine Erkenntnisse nur bestätigen. In einem der Beiträge habe ich auch einen Auszug der Docker Doku gepostet. Da steht es auch nochmal so drin.
                                          MfG,
                                          André
