State auslesen in Adapterentwicklung
Danke für Deine Antwort, aber das ist es leider auch nicht...
Code:
onStateChange(id, state) { if (state) { let mid = id.split('.')[2]; let trigger = id.split('.').pop(); this.log.info(`state ${id} changed: ${state.val} (ack = ${state.ack})`); if (trigger == 'command') { // wenn Befehl an Mower verändert wurde const command = state.val; const time = this.getState('husqvarna_mowers.0.6dcad25a-39f7-4baf-9f44-877302c35c1f.Control.duration').val; this.log.info('Variablen für Funktionsaufruf : command: ' + command + ' time: ' + time + ' mid: ' + mid); //this.await.sendCommand(command, time, mid); } } else { // The state was deleted this.log.info(`state ${id} deleted`); } }Fehler:
husqvarna_mowers.0 2020-04-20 08:52:54.205 error at processImmediate (internal/timers.js:456:21) husqvarna_mowers.0 2020-04-20 08:52:54.205 error at Immediate.<anonymous> (/usr/local/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4855:34) husqvarna_mowers.0 2020-04-20 08:52:54.205 error at HusqvarnaMowers.emit (events.js:311:20) husqvarna_mowers.0 2020-04-20 08:52:54.205 error at HusqvarnaMowers.onStateChange (/usr/local/iobroker/node_modules/iobroker.husqvarna_mowers/main.js:521:107) husqvarna_mowers.0 2020-04-20 08:52:54.205 error (71636) TypeError: Cannot read property 'val' of undefined husqvarna_mowers.0 2020-04-20 08:52:54.205 error (71636) uncaught exception: Cannot read property 'val' of undefinedund der State ist m.E. auch da und korrekter String:
{ "type": "state", "common": { "name": "Duration of Command", "def": "24", "type": "number", "role": "indicator", "read": true, "write": true }, "native": {}, "from": "system.adapter.husqvarna_mowers.0", "user": "system.user.admin", "ts": 1587365605661, "_id": "husqvarna_mowers.0.6dcad25a-39f7-4baf-9f44-877302c35c1f.Control.duration", "acl": { "object": 1638, "state": 1638 } }@reutli sagte in State auslesen in Adapterentwicklung:
husqvarna_mowers.0 2020-04-20 08:52:54.205 error (71636) TypeError: Cannot read property 'val' of undefined.val entfernen :)
const time = this.getState('husqvarna_mowers.0.6dcad25a-39f7-4baf-9f44-877302c35c1f.Control.duration').val; // zu ->>>> const time = this.getState('husqvarna_mowers.0.6dcad25a-39f7-4baf-9f44-877302c35c1f.Control.duration'); -
Code:
{ "type": "state", "common": { "name": "Duration of Command", "def": "24", "type": "number", "role": "indicator", "read": true, "write": true }, "native": {}, "from": "system.adapter.husqvarna_mowers.0", "user": "system.user.admin", "ts": 1587365605661, "_id": "husqvarna_mowers.0.6dcad25a-39f7-4baf-9f44-877302c35c1f.Control.duration", "acl": { "object": 1638, "state": 1638 } }Versuch eines der folgenden. Das was du oben versuchst funktioniert nicht, das ist vom JS Adapter.
Await/Async
const state = await this.getStateAsync('Dein Dp');oder
Callback
this.getState('Dein Dp', (error, state) => { });Bin mir beim unteren gerade nicht sicher, welche Werte alle übergeben werden
const time = this.getState('husqvarna_mowers.0.6dcad25a-39f7-4baf-9f44-877302c35c1f.Control.duration').val; // zu ->>>> const time = this.getState('husqvarna_mowers.0.6dcad25a-39f7-4baf-9f44-877302c35c1f.Control.duration');Das habe ich auch bereits versucht.... dann bekomme ich zwar keinen Fehler, aber auch keinen Wert (time ist dann undefined):
(71874) Variablen für Funktionsaufruf : command: Pause time: undefined mid: 6dcad25a-39f7-4baf-9f44-877302c35c1f -
Await/Async
Callback
@J-A-R-V-I-S sagte in State auslesen in Adapterentwicklung:
Await/Async
const state = await this.getStateAsync('Dein Dp');Dann müsste ich eine komplette ASYNC Funktion aufbauen, weil ich ja in der 'OnStateChange' keinen await aufrufen kann?!
Await/Async
@reutli du kannst die einfach zu einer Async machen, indem du async davor schreibst.
async onStateChange(id, state)@J-A-R-V-I-S
nope leider nicht.
Erhalte mit '.val' einen undefined bei 'time' (und ohne '.val' natürlich ein Object):(72098) Variablen für Funktionsaufruf : command: Pause time: undefined mid: 6dcad25a-39f7-4baf-9f44-877302c35c1fhier der code:
async onStateChange(id, state) { if (state) { let mid = id.split('.')[2]; let trigger = id.split('.').pop(); this.log.info(`state ${id} changed: ${state.val} (ack = ${state.ack})`); if (trigger == 'command') { // wenn Befehl an Mower verändert wurde const command = state.val; const time = await this.getStateAsync('husqvarna_mowers.0.6dcad25a-39f7-4baf-9f44-877302c35c1f.Control.duration').val; this.log.info('Variablen für Funktionsaufruf : command: ' + command + ' time: ' + time + ' mid: ' + mid); //this.await.sendCommand(command, time, mid); } } else { // The state was deleted this.log.info(`state ${id} deleted`); } } -
@J-A-R-V-I-S
nope leider nicht.
@reutli lass dir mal den ganzen State ausgeben, ohne .val.
this.log.info(JSON.stringify(time));Und mach mal einen try/catch Block drum. Damit fängst du die möglichen Fehler ab.
jetzt bekomme ich Werte zurück:
(72271) {"val":"24","ack":true,"ts":1587366996004,"q":0,"from":"system.adapter.husqvarna_mowers.0","user":"system.user.admin","lc":1587295118488}Warum bekommen ich diesen nicht in die const?
@reutli dann schreib es in eine neue Zeile;
const state = await this.getStateAsync('husqvarna_mowers.0.6dcad25a-39f7-4baf-9f44-877302c35c1f.Control.duration'); const time = state.val;@J-A-R-V-I-S
ok, danke.
Jetzt bekomme ich einen Wert:(72584) Variablen für Funktionsaufruf : command: Pause time: 24 mid: 6dcad25a-39f7-4baf-9f44-877302c35c1fmit dem Code:
async onStateChange(id, state) { if (state) { let mid = id.split('.')[2]; let trigger = id.split('.').pop(); this.log.info(`state ${id} changed: ${state.val} (ack = ${state.ack})`); if (trigger == 'command') { // wenn Befehl an Mower verändert wurde const command = state.val; const state_check = await this.getStateAsync('husqvarna_mowers.0.6dcad25a-39f7-4baf-9f44-877302c35c1f.Control.duration'); this.log.info(JSON.stringify(state_check)); const time = state_check.val; this.log.info('Variablen für Funktionsaufruf : command: ' + command + ' time: ' + time + ' mid: ' + mid); //this.await.sendCommand(command, time, mid); } } else { // The state was deleted this.log.info(`state ${id} deleted`); } }Aber: Warum muss ich aus dem ganzen 'onStateChange' eine Async machen? Das habe ich nicht verstanden (und auch noch nirgendwo so gesehen....?
Ich frage noch anders: Wie muss ich sonst (außerhalb des 'on StateChange') dann einen State abfragen?
Sorry wenn ich so nachfrage, versuche eben zu lernen...
Danke!
PS: kannst Du mir für mein Beispiel ein sauberes "Try/Catch" zeigen, damit ich das korrekt in andere Bereich übernehmen kann? Habe hier schon einiges an Doku gelesen, aber noch nicht so ganz kapiert...
@J-A-R-V-I-S
ok, danke.
Danke!
@reutli der Try/Catch sieht wie folgt aus:
try { /* Hier all der Code bei dem Fehler abgefangen werden sollen. Sollte ein Fehler geworfen werden, wird der Code, der im Try/Catch steht nicht weiter ausgeführt, Code nach dem Try/Catch wird aber weiter ausgeführt. */ } catch(error) { this.log.error(error); } -
@J-A-R-V-I-S
ok, danke.
Danke!
Entweder du machst es dort auch mit Async Methoden oder du verwendest die Möglichkeit mit Callbacks.
try { /* Hier all der Code bei dem Fehler abgefangen werden sollen. Sollte ein Fehler geworfen werden, wird der Code, der im Try/Catch steht nicht weiter ausgeführt, Code nach dem Try/Catch wird aber weiter ausgeführt. */ } catch(error) { this.log.error(error); }@J-A-R-V-I-S
Dann wäre mein try/catch so richtig, oder:
try { if (trigger == 'command') { // wenn Befehl an Mower verändert wurde const command = state.val; const state_check = await this.getStateAsync('husqvarna_mowers.0.6dcad25a-39f7-4baf-9f44-877302c35c1f.Control.duration'); this.log.info(JSON.stringify(state_check)); const time = state_check.val; this.log.info('Variablen für Funktionsaufruf : command: ' + command + ' time: ' + time + ' mid: ' + mid); //this.await.sendCommand(command, time, mid); } } catch(e) { this.log.error(e); } -
ok, aber im 'OnStateChange' muss ich beim Async bleiben, oder wie wäre dort das callback-Szenario zu lösen?
