  4. VIS App 2.0 -> keine Verbindung mehr zu ioBroker
    5.9k
vis app
179 Beiträge 31 Kommentatoren 34.0k Aufrufe 23 Beobachtet
  • twonkyT Offline
    twonkyT Offline
    twonky
    Per Chrome oder "Browser" App läuft das Vis auf dem Smartphone problemlos. Aber nicht in der iobroker app.
    Ich habe nun die debug.apk nun mal im Android Studio importiert und auf meinem Device laufen lassen.
    Hier der output:
    android-studio-debug.log
    Die roten Zeilen die ich auf anhieb gesehen habe sind:
    03-30 19:22:43.226 10826-10826/net.iobroker.vis E/Web Console: Cannot load widget set "coronavirus-statistics": SyntaxError: Unexpected token > at file:///android_asset/www/js/vis.js:395
    03-30 19:22:43.496 10826-10826/net.iobroker.vis E/Web Console: Cannot load widget set "ebus": SyntaxError: Unexpected token > at file:///android_asset/www/js/vis.js:395
    03-30 19:22:43.886 10826-10826/net.iobroker.vis E/Web Console: Cannot load widget set "history": SyntaxError: In strict mode code, functions can only be declared at top level or immediately within another function. at file:///android_asset/www/js/vis.js:395
    03-30 19:22:44.106 10826-10826/net.iobroker.vis E/Web Console: Cannot load widget set "info": SyntaxError: Unexpected token function at file:///android_asset/www/js/vis.js:395
    03-30 19:22:45.326 10826-10826/net.iobroker.vis E/Web Console: Cannot load widget set "material-webfont": TypeError: Object #<Object> has no method 'addFont' at file:///android_asset/www/js/vis.js:395
    03-30 19:22:45.336 10826-10826/net.iobroker.vis E/Web Console: Cannot load widget set "material": SyntaxError: Use of const in strict mode. at file:///android_asset/www/js/vis.js:395
    03-30 19:22:45.806 10826-10826/net.iobroker.vis E/Web Console: Cannot load widget set "materialdesign": SyntaxError: Use of const in strict mode. at file:///android_asset/www/js/vis.js:395
    03-30 19:22:47.206 10826-10826/net.iobroker.vis E/Web Console: Cannot load widget set "sbfspot": SyntaxError: Unexpected token > at file:///android_asset/www/js/vis.js:395
    03-30 19:22:47.776 10826-10826/net.iobroker.vis E/Web Console: Cannot load widget set "weather": SyntaxError: Unexpected token > at file:///android_asset/www/js/vis.js:395
    Die App bleibt beim laden der vis-views.json hängen.
      Bernd_Ku
      Bei mir auch keine Verbesserung mit 2.0.1
      • F Offline
        fuchs1978
        Bei mir leider auch noch keine Verbindung
        • BluefoxB Offline
          BluefoxB Offline
          Gibt es Leute, bei wem es läuft?
          • tobasiumT Offline
            tobasiumT Offline
            tobasium
            Bei mir läuft es leider auch nicht.
            Oneplus 6 Android 10
            web 3.0.2
            simple API 2.3.2
            • HomeZeckeH Offline
              HomeZeckeH Offline
              HomeZecke
              Also auf meinem Tablet galaxy 5200 mit CyanogenMod 6.0 geht es. Aber der Resync bleibt irgendwann hängen. Ich muss dann auf Neuladen. Und dann ist alles aktuell.
              • BluefoxB Bluefox
                sigi234S Online
                sigi234S Online
                @Bluefox sagte in VIS App 2.0 -> keine Verbindung mehr zu ioBroker:
                Ja
                IoBroker Pro
                Host: Windows
                APP: V 2.0.0
                Node.js: v10.16.3
                NPM: 6.9.0
                Admin: 4.0.5
                Web: 3.0.2
                SOCKETIO: 3.0.1
                App hat nach Update auf 2.0.0. ohne das ich was gemacht habe alles übernommen und hat sofort funktioniert.
                Aber warum es Huawei Batterie heißt ist mir schleierhaft.
                Edit: kann man in den Einstellungen ändern. (Gerätename)
                Edit2:
                Update auf V 2.0.1
                Funktioniert nicht
                Meldungen:
                vis-view.json Nicht gefunden
                • sigi234S sigi234
                  Ja
                  IoBroker Pro
                  Host: Windows
                  APP: V 2.0.0
                  Node.js: v10.16.3
                  NPM: 6.9.0
                  Admin: 4.0.5
                  Web: 3.0.2
                  SOCKETIO: 3.0.1
                  Edit2:
                  Update auf V 2.0.1
                  Funktioniert nicht
                  Meldungen:
                  @sigi234 sagte in VIS App 2.0 -> keine Verbindung mehr zu ioBroker:
                  Ja
                  mit welcher Konstellation?
                  • AlligatorA Offline
                    AlligatorA Offline
                    Alligator
                    schrieb am zuletzt editiert von Alligator
                    Bei mir weiterhin unverändert mit App 2.0.1:
                    Samsung Tab A mit Android 8.1 --- Geht
                    Xaiomi Mi 8 Pro mit Android 10 --- Geht NICHT --- keine Verbindung (keine Erkennung von WLAN und/oder Server)
                    It's done when it's done, but it's never really finished!
                    Lg euer Alligator :P
                    System: Dell Optiplex3020 mit Intel i3, 8gb Ram und 120gb SSD (Debian 11 mit ioBrocker)
                    PS: Wer Rechtschreibfehler findet darf sie gern behalten. Ich habe noch mehr davon. :)
                    • sigi234S sigi234
                      Ja
                      IoBroker Pro
                      Host: Windows
                      APP: V 2.0.0
                      Node.js: v10.16.3
                      NPM: 6.9.0
                      Admin: 4.0.5
                      Web: 3.0.2
                      SOCKETIO: 3.0.1
                      Edit2:
                      Update auf V 2.0.1
                      Funktioniert nicht
                      Meldungen:
                      @sigi234
                      Danke fürs Editieren.
                      Die Frage war eigentlich: Was für eine Konstellation am Handy?
                        @sigi234
                        sigi234S Online
                        sigi234S Online
                        @Homoran sagte in VIS App 2.0 -> keine Verbindung mehr zu ioBroker:
                        Was willst du wissen?
                        Huawei P20 lite
                        Android V 9
                        Kein root
                        • sigi234S sigi234
                          Huawei P20 lite
                          Android V 9
                          Kein root
                          Huawei P20 lite
                          Android V 9
                          das!
                          und
                          root oder nicht?
                            Bernd_Ku
                            schrieb am zuletzt editiert von Bernd_Ku
                            LG G8s ThinkQ (neu)
                            Android 9
                            kein root
                            geht nicht
                            • sigi234S sigi234
                              Huawei P20 lite
                              Android V 9
                              Kein root
                              Huawei P20 lite
                              Android V 9
                              Kein root
                              Danke nochmals fürs Editieren
                              • bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                Habe auch versucht 2.0.1 zu installieren.
                                Kein wlan gefunden.
                                Dann wieder 1.2.4 drauf; wlan einwandfrei gefunden.
                                Handy:
                                xiaomi mi max 3
                                Android 9
                                Miui global 11.0.7
                                kein root
                                Danke.
                                  Kueppert
                                  schrieb am zuletzt editiert von Kueppert
                                  GEHT NICHT :) App findet keine Projekte
                                  Huawei P20 (kein ROOT) (Android 9.1.0.387)
                                  VIS-App: 2.0.1
                                  node.js: 10.16.0
                                  NPM: 6.9.0
                                  Admin: 4.0.5
                                  Web Server: 3.0.2
                                  socket.io: 3.0.1
                                  GEHT
                                  FireHD7 (5th Gen)
                                  VIS-App 1.0.0 sowie 2.0.1 laufen einwandfrei
                                  • OstfrieseUnterwegsO Offline
                                    OstfrieseUnterwegs
                                    Kein Connect
                                    OnePlus 7, ohne Root, Oxygen 10.0.4 Android Sicherheitspatch 1.1.2020
                                    Vis App 2.0.1
                                    Node.js: v10.19.0
                                    NPM: 6.13.7
                                    Admin: 4.0.5
                                    Web: 3.0.2
                                    socket.io: 3.0.1
                                    Alles ohne ssl/authentication
                                      Ich glaube im Moment brauchen wir keine weiteren Informationen wo es nicht geht.
                                      Interessant wären Android 9/10 bei denen es im eigenen Netz geht.
                                      iobroker.pro scheint auch zu funktionieren wenn es im eigenen Netz nicht geht
                                        Kueppert
                                        @Homoran die Verbindung ins WLAN ist bei mir kein Problem. Hab zum Test gerade wie WLAN Verbindung getrennt und mich via ioBroker PRO eingelogget ==> auch keine Projekte aufgetaucht
                                        • K Kueppert
                                          @Kueppert Was bitte
                                          GEHT NICHT
                                          es bringt hier nichts den Thread mit anderen "Problemen" zu füllen.
                                          Kommt dein Handy über den Ladekreis hinaus?
                                          Wenn ja, bitte eigenen Thread aufmachen
