  4. Beta-Test Android App ioGo 2.1.x
    6.6k
iogoandroidgeofencetestbeta
272 Beiträge 10 Kommentatoren 44.6k Aufrufe 7 Beobachtet
    @e-s am besten wäre Verbose
    e-s
    schrieb am zuletzt editiert von e-s
    #237
    @nis
    Wenn man die Geräte alle mal in Ruhe lässt, dann scheint es doch zu funktionieren...
    Also könnte meine Ungeduld Schuld sein.
    Das Fire will aber wirklich nicht, um verbose Log passiert aber kaum was
    23:02:53:373 D/StateFirebaseServiceImp - 61: Service created
    23:02:53:425 D/EnumFirebaseServiceImpl - 54: Service created
    23:02:53:681 I/FirebaseService - 205: DeviceFirebaseServiceImpl successfully connected
    23:02:53:688 I/DeviceFirebaseServiceIm - 73: buffer is empty
    23:02:53:692 I/FirebaseService - 205: StateFirebaseServiceImpl successfully connected
    23:02:53:734 I/FirebaseService - 205: EnumFirebaseServiceImpl successfully connected
    23:02:58:358 D/HostFirebaseServiceImpl - 60: Service created
    23:02:58:369 D/InstanceFirebaseService - 60: Service created
    23:02:58:376 D/AdapterFirebaseServiceI - 54: Service created
    23:02:58:555 I/FirebaseService - 205: HostFirebaseServiceImpl successfully connected
    23:02:58:559 I/FirebaseService - 205: InstanceFirebaseServiceImpl successfully connected
    23:02:58:567 I/FirebaseService - 205: AdapterFirebaseServiceImpl successfully connected
    23:03:03:503 I/DeviceFirebaseServiceIm - 87: send device FireHD8
    23:03:03:504 I/HostFirebaseServiceImpl - 70: start syncing
    23:03:03:508 I/InstanceFirebaseService - 70: start syncing
    23:03:03:509 I/AdapterFirebaseServiceI - 77: start syncing
    23:03:03:582 I/EnumFirebaseServiceImpl - 77: start syncing
    23:03:03:647 I/StateFirebaseServiceImp - 91: start syncing
    23:03:03:863 I/EnumFirebaseServiceImpl - 123: no differences found
    23:03:03:868 I/StateFirebaseServiceImp - 150: no differences found
    23:03:03:872 I/AdapterFirebaseServiceI - 109: 0 differences found
    23:03:03:877 D/AdapterFirebaseServiceI - 119: system.adapter.icons-material-png found only local
    23:03:03:881 I/HostFirebaseServiceImpl - 133: no differences found
    23:03:03:884 I/InstanceFirebaseService - 137: no differences found
    23:03:09:841 I/DeviceFirebaseServiceIm - 87: send device FireHD8
    23:03:14:983 I/DeviceFirebaseServiceIm - 87: send device FireHD8
    23:03:19:029 I/DeviceFirebaseServiceIm - 87: send device FireHD8
    23:06:01:721 I/DeviceFirebaseServiceIm - 87: send device FireHD8
    23:06:21:891 I/DeviceFirebaseServiceIm - 87: send device FireHD8
    23:06:48:552 I/DeviceFirebaseServiceIm - 87: send device FireHD8
    23:07:36:881 I/DeviceFirebaseServiceIm - 87: send device FireHD8
    Werde es weiter beobachten, aber bisher bleibt die 0 stehen.
    Neustart hat auch nicht geholfen.
    • E e-s
      @nis
      #238
      @e-s es könte an der doch schon recht alten Android Version liegen, da muss ich mal recherchieren ob man da was zu findet an Inkompabilitäten...
      • E e-s
        @nis
        nach dem release ist vor den neuen Betas, oder wie sehe ich das?
        Geht das hier weiter oder machst du dann wieder einen neuen Thread auf?
        Ist es theoretisch möglich eine Pushnachricht mit verfallszeit zu senden, also push kommt auf handy an und wird nach Zeit x wieder von selbst gelöscht aus der Infobar auch wenn nicht weggedrückt oder gesehen?
        #239
        @e-s sagte in Beta-Test Android App ioGo 2.1.x:
        In der nächsten Version kann man einstellen, dass Pushnachrichten nach x Sekunden entfernt werden sollen. Die Nachrichten sind dann trotzdem noch in der Messageliste der App nachzusehen.
        E ? 2 Antworten Letzte Antwort
          e-s
          #240
          @nis
          Hab dir ne Mail gesendet...
            #241
            @nis Version 2.1.8 kommt gerade als Beta online:
            (Feature) Automatisches Löschen von Pushbenarichtigungen
              e-s
              #242
              @nis
              Habs gerade installiert aber noch nicht getestet. Geht das nur global oder wäre es auch möglich durch prio Wahl beim senden zu unterscheiden ob Nachrichten existent in der statusleiste bleiben oder nicht?
              Edit: klappt einwandfrei, nur möchte ich nicht alle Nachrichten sofort wieder weg haben.
              Edit2: hab mal auf dem fireHD eine akku app installiert, die kann prinzipiell den akkustand auslesen. Du kannst ja alternativ mal eine Beta bauen die den akkustand in der app selbst anzeigt um dem Fehler eingrenzen zu können.
              • E e-s
                @nis
                #243
                Geht aktuell nur global. Aber genau dafür ist ja die Beta Version auch da, einfach mal zum Ausprobieren.
                Ich finde die Idee gut, dass Nachrichten mit hoher Prio nicht automatisch gelöscht werden.
                Für Normale Nachrichten zieht dann der globale Timeout und zusätzlich kann ich auch noch einen individuellen Timeout als Payload der Nachricht selber einbauen. Dann kann man auch jede einzelne Nachricht individuell löschen lassen.
                • E e-s
                  @nis
                  #244
                  Ich würde das lieber erstmal über die Logs versuchen zu analysieren. Dazu bin ich gerade dabei die App mit weiteren sinnvollen Logging zu versehen.
                    #245
                    @nis Hi, könnte man das automatische löschen auch in Minuten eingeben? Hab da jetzt 86400 stehen... 🙈
                      e-s
                      #246
                      @ilovegym
                        #247
                        @ilovegym sagte in Beta-Test Android App ioGo 2.1.x:
                        ich versuche mal in der nächsten Version den folgenden Input zu ermöglichen:
                        • "30" = 30 Sekunden
                        • "30s" = 30 Sekunden
                        • "10m" = 10 Minuten
                        • "12h" = 12 Stunden
                        • "2d" = 2 Tage
                          • "2d" = 2 Tage
                          #248
                          @nis und da ist auch schon die neue Version 2.1.9 (als Beta) mit "smarter" Zeitangabe beim Löschen von Pushnachrichten...
                          Folgendes ist möglich als Eingabe:
                          "30s" = 30 Sekunden
                          "10m" = 10 Minuten
                          "12h" = 12 Stunden
                          "2d" = 2 Tage
                          E crunchipC 2 Antworten Letzte Antwort
                            "30s" = 30 Sekunden
                            "10m" = 10 Minuten
                            "12h" = 12 Stunden
                            "2d" = 2 Tage
                            e-s
                            #249
                            @nis
                            konntest du dir meine Mail von gestern ansehen?
                            • E e-s
                              @nis
                              #250
                              @e-s ja, habe ich gesehen. Ich kann es aber nicht nachstellen. Wenn ich das Passwort falsch eingebe kommt bei Information "iogo - account unknown". Wenn ich dann das richtige Passwort eingebe, steht dort sofort wieder "iogo -connected"
                              E 1 Antwort Letzte Antwort
                                e-s
                                #251
                                @nis
                                ist ja auch nicht so wichtig, schon komisch das es nur mit 2 verschiedene Geräten passiert ist.
                                Viel wichtiger wäre mir im Moment sowieso der Akkuwert und noch wichtiger die json Tabelle😊
                                • E e-s
                                  @nis
                                  #252
                                  @e-s hattest du mir schonmal wegen dem Akkuthema ein Log der App geschickt? Ich habe eine Vermutung woran es liegt und könnte das mit dem Log überprüfen.
                                  Tabellen wird vermutlich noch etwas länger dauern, ist nicht so einfach aus einem beliebigen JsonArray eine hübsche Tabelle zu zaubern
                                    e-s
                                    #253
                                    @nis
                                    das log von gestern ist auch von dem Gerät was kein Akkuwert anzeigt. Solltest du darin auch finden, aber ich sehe da nix.
                                    Die Tabelle muss nicht schön, aber wäre klasse wenn ich schon mal sehen könnte ob es überhaupt funktioniert, dann könnte ich weiter basteln in meinen Ideen.
                                    • E e-s
                                      @nis
                                      #254
                                      @e-s Das Log beinhaltet nur 3 Minuten nachdem erfolgreichen Anmelden, das ist etwas zuwenig um das Akkuproblem zu finden.
                                        e-s
                                        #255
                                        @nis
                                        Nach erneuten Neustart klappt es auf einmal, keine Ahnung warum.
                                        Für mich ist der akkustand ja nur interessant, damit ich nicht vergesse die Tablets aufzuladen.
                                        Jetzt will ich mir ein kleines script dazu basteln, ich überlege jedoch ob es nicht Sinn machen würde sowas direkt in die app zu integrieren.
                                        Also min / max Level Eingabe und zusätzlich die id die eine pushnachricht bekommen soll.
                                        • E e-s
                                          @nis
                                          #256
                                          Beim Neustart werden die Prozesse neu registriert die auf Änderungen der Batterie reagieren.
